[cgma-dev] r2468 - in cgm/trunk: . compat geom/OCC
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Thu Dec 4 13:02:10 CST 2008
Author: kraftche
Date: 2008-12-04 13:02:10 -0600 (Thu, 04 Dec 2008)
New Revision: 2468
Added:
   cgm/trunk/compat/Makefile.am
Modified:
   cgm/trunk/Makefile.am
   cgm/trunk/configure.in
   cgm/trunk/geom/OCC/Makefile.am
Log:
o Retain --with-occ and --with-acis options during 'make distcheck'
o Include compat/new/new.h in tarball
o Include geom/OCC/OCCCoFace.hpp in tarball
Modified: cgm/trunk/Makefile.am
--- cgm/trunk/Makefile.am	2008-12-04 17:32:31 UTC (rev 2467)
+++ cgm/trunk/Makefile.am	2008-12-04 19:02:10 UTC (rev 2468)
@@ -1,5 +1,5 @@
 AUTOMAKE_OPTIONS = foreign
-SUBDIRS = util geom init . itaps test cgm_apps
+SUBDIRS = compat util geom init . itaps test cgm_apps
 # Don't loose the autoconf include path
 ACLOCAL_AMFLAGS = -I m4
Added: cgm/trunk/compat/Makefile.am
--- cgm/trunk/compat/Makefile.am	                        (rev 0)
+++ cgm/trunk/compat/Makefile.am	2008-12-04 19:02:10 UTC (rev 2468)
@@ -0,0 +1 @@
+EXTRA_DIST = new/new.h
Modified: cgm/trunk/configure.in
--- cgm/trunk/configure.in	2008-12-04 17:32:31 UTC (rev 2467)
+++ cgm/trunk/configure.in	2008-12-04 19:02:10 UTC (rev 2468)
@@ -70,10 +70,13 @@
 AC_ARG_WITH( cubit,
              AC_HELP_STRING([--with-cubit=<dir>],[Use CGM from CUBIT shared library]),
-             [CUBIT_DIR="$withval"],[CUBIT_DIR=no])
+             [CUBIT_DIR="$withval"
+              DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-cubit=\"${withval}\""],
+             [CUBIT_DIR=no])
 AC_ARG_WITH( CUBIT,
              AC_HELP_STRING([--with-CUBIT=<dir>],[DEPRECATED.  Use --with-cubit (small case)]),
-             [CUBIT_DIR="$withval"])
+              DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-cubit=\"${withval}\""])
 if test "x$CUBIT_DIR" == "xyes"; then
   AC_MSG_ERROR([Option --with-CUBIT without specifying Cubit directory.])
 elif test "x$CUBIT_DIR" != "xno"; then
@@ -147,10 +150,13 @@
 AC_ARG_WITH( acis,
              AC_HELP_STRING([--with-acis=<dir>],[Build with ACIS support, specify directory where ACIS is installed.]),
-             [ACIS_DIR=$withval],[ACIS_DIR=no] )
+             [ACIS_DIR=$withval
+              DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-acis=\"${withval}\""],
+              [ACIS_DIR=no] )
 AC_ARG_WITH( ACIS,
              AC_HELP_STRING([--with-ACIS],[DEPRECATED.  Use --wtih-acis (small case)]),
-             [ACIS_DIR=$withval] )
+              DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-acis=\"${withval}\""] )
 AC_ARG_WITH( ACIS-system, AC_HELP_STRING([--with-acis-system=SYS],
           [Specify ACIS system name (e.g. linux_so), default is to autodetect.]),
              [ACIS_SYSTEM=$withval],[ACIS_SYSTEM=] )
@@ -264,7 +270,8 @@
 AC_ARG_WITH( occ,
              [AC_HELP_STRING([--with-occ=<dir>],[OpenCascade shared library directory])],
-             [occ_DIR="$withval"],
+             [occ_DIR="$withval"
+              DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-occ=\"${withval}\""],
              [occ_DIR=no] )
 # if user specified option (other than --without-occ)
@@ -395,6 +402,7 @@
 #                           Output Files
 AC_SUBST(AM_CPPFLAGS)
+AC_SUBST(DISTCHECK_CONFIGURE_FLAGS)
 AC_MSG_RESULT([CXXFLAGS = $CXXFLAGS])
 dnl AC_OUTPUT_COMMANDS( [if test -f util/CubitUtilConfigure.h; then true; else echo "#define CUBIT_UTIL_EXPORT" > util/CubitUtilConfigure.h; fi],
 dnl                     [if test -f geom/CubitGeomConfigure.h; then true; else echo "#define CUBIT_GEOM_EXPORT" > geom/CubitGeomConfigure.h; fi] )
@@ -411,6 +419,7 @@
            geom/parallel/Makefile
            geom/virtual/Makefile
            init/Makefile
+           compat/Makefile
            cgm.make
            itaps/Makefile
            itaps/iGeom-Defs.inc
Modified: cgm/trunk/geom/OCC/Makefile.am
--- cgm/trunk/geom/OCC/Makefile.am	2008-12-04 17:32:31 UTC (rev 2467)
+++ cgm/trunk/geom/OCC/Makefile.am	2008-12-04 19:02:10 UTC (rev 2468)
@@ -43,6 +43,7 @@
     OCCAttribSet.hpp \
     OCCBody.hpp \
     OCCCoEdge.hpp \
+    OCCCoFace.hpp \
     OCCCurve.hpp \
     OCCGeometryCreator.hpp \
     OCCLoop.hpp \
More information about the cgma-dev mailing list
