[cgma-dev] r1371 - cgm/trunk/geom/OCC
    janehu at mcs.anl.gov
    Fri Nov  9 10:19:55 CST 2007
Author: janehu
Date: 2007-11-09 10:19:55 -0600 (Fri, 09 Nov 2007)
New Revision: 1371
Modified:
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.hpp
Log:
Assume when writing the OCC file, export all entity as a compound TopoDS_Shape, and when read in, read the compound TopoDS_Shape, then build a body on each TopoDS_Solid.
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2007-11-09 15:53:17 UTC (rev 1370)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2007-11-09 16:19:55 UTC (rev 1371)
@@ -115,6 +115,7 @@
 std::map<int, TopologyBridge*>* OccToCGM = new std::map<int, TopologyBridge*>;
 typedef std::map<int, TopologyBridge*>::value_type valType;
 int iTotalTBCreated = 0;
+CubitBoolean PRINT_RESULT = CUBIT_FALSE;
 // Description:
 // Author     :
@@ -745,9 +746,9 @@
   int size_before = ref_entity_list.size();
   CubitString temp_filename(file_name);
-  temp_filename += ".mbg";
+  temp_filename += ".occ";
-  if( export_solid_model( ref_entity_list, temp_filename.c_str(), "FACET",
+  if( export_solid_model( ref_entity_list, temp_filename.c_str(), "OCC",
                           cubit_version ) == CUBIT_FAILURE )
     PRINT_ERROR( "Error occured while trying to save temporary MESH_BASED_GEOMETRY file\n");
@@ -759,7 +760,7 @@
   if( size_before > size_after )
     created_file +=  temp_filename;
-    created_file_type += "FACET";
+    created_file_type += "OCC";
   return CUBIT_SUCCESS;
@@ -778,9 +779,12 @@
                                                      const CubitString &,
                                                      const char*)
-  if( strcmp( file_type, "FACET" ) )
-    return CUBIT_SUCCESS;
+  if( strcmp( file_type, "OCC" ) != 0 )
+     //PRINT_ERROR("The specified file type, %s, is not supported!\n", filetype );
+     return CUBIT_FAILURE;
   DLIList<OCCBody*>    facet_bodies;
   DLIList<OCCLump*>    facet_lumps;
   DLIList<OCCShell*>   facet_shells;
@@ -1299,35 +1303,35 @@
   BRep_Builder aBuilder;
   Standard_Boolean result = BRepTools::Read(*aShape, (char*) file_name, aBuilder);
   if (result==0) return CUBIT_FAILURE;
-  OCCBody *body = new OCCBody(aShape);
-//  CGMList->append(body);
-  imported_entities.append(body);
-//  OCCMap->Bind(*aShape, CGMList->where_is_item(body));
-  populate_topology_bridge(*aShape);
+  PRINT_RESULT = print_results;
+  imported_entities = populate_topology_bridge(*aShape);
-void OCCQueryEngine::populate_topology_bridge(TopoDS_Shape aShape)
+DLIList<TopologyBridge*> OCCQueryEngine::populate_topology_bridge(TopoDS_Shape aShape)
+	DLIList<TopologyBridge*> tblist;
         // suitable to popolate for a TopoDS_CompSolid or TopoDS_Compound shape.
         TopExp_Explorer Ex;
         for (Ex.Init(aShape, TopAbs_SOLID); Ex.More(); Ex.Next())
-		populate_topology_bridge(TopoDS::Solid(Ex.Current()));
+ 	  tblist.append(populate_topology_bridge(TopoDS::Solid(Ex.Current())));
 	for (Ex.Init(aShape, TopAbs_SHELL, TopAbs_SOLID); Ex.More(); Ex.Next())
-                populate_topology_bridge(TopoDS::Shell(Ex.Current()));
+          tblist.append(populate_topology_bridge(TopoDS::Shell(Ex.Current())));
         for (Ex.Init(aShape, TopAbs_FACE, TopAbs_SHELL); Ex.More(); Ex.Next())
-                populate_topology_bridge(TopoDS::Face(Ex.Current()));
+          tblist.append(populate_topology_bridge(TopoDS::Face(Ex.Current())));
 	for (Ex.Init(aShape, TopAbs_WIRE, TopAbs_FACE); Ex.More(); Ex.Next())
-                populate_topology_bridge(TopoDS::Wire(Ex.Current()));
+          tblist.append(populate_topology_bridge(TopoDS::Wire(Ex.Current())));
 	for (Ex.Init(aShape, TopAbs_EDGE, TopAbs_WIRE); Ex.More(); Ex.Next())
-                populate_topology_bridge(TopoDS::Edge(Ex.Current()));
+          tblist.append(populate_topology_bridge(TopoDS::Edge(Ex.Current())));
 	for (Ex.Init(aShape, TopAbs_VERTEX, TopAbs_EDGE); Ex.More(); Ex.Next())
-                populate_topology_bridge(TopoDS::Vertex(Ex.Current()));
+          tblist.append(populate_topology_bridge(TopoDS::Vertex(Ex.Current())));
+	return tblist;
 BodySM* OCCQueryEngine::populate_topology_bridge(TopoDS_Solid aShape)
@@ -1339,7 +1343,8 @@
         OCCBody *body;
 	if (!OCCMap->IsBound(*posolid))
-		printf("Adding solid\n");
+		if(PRINT_RESULT)
+			PRINT_INFO("Adding solid\n");
                 iTotalTBCreated++;
 		lump = new OCCLump(posolid);
 		body = new OCCBody(posolid);
@@ -1378,7 +1383,8 @@
 	OCCSurface *surface;
 	if (!OCCMap->IsBound(*poface))
-		printf("Adding face\n");
+		if(PRINT_RESULT)
+                        PRINT_INFO("Adding face.\n");
         	iTotalTBCreated++;
 		surface = new OCCSurface(poface);
 //		CGMList->append(surface);
@@ -1418,7 +1424,8 @@
 	*poedge = aShape;
 	if (!OCCMap->IsBound(*poedge))
-		printf("Adding coedge\n");
+		if(PRINT_RESULT)
+                        PRINT_INFO("Adding edge.\n");
                 iTotalTBCreated++;
                 curve = new OCCCurve(poedge);
 		coedge = new OCCCoEdge(poedge, curve);
@@ -1448,7 +1455,8 @@
 	*povertex = aShape;
 	if (!OCCMap->IsBound(*povertex))
- 	  printf("Adding vertex\n");
+ 	  if(PRINT_RESULT)
+                        PRINT_INFO("Adding vertex\n");
           iTotalTBCreated++;
  	  point = new OCCPoint(povertex);
 //	  CGMList->append(point);
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2007-11-09 15:53:17 UTC (rev 1370)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2007-11-09 16:19:55 UTC (rev 1371)
@@ -320,7 +320,7 @@
   virtual CubitBoolean volumes_overlap (Lump *lump1, Lump *lump2 ) const ;
-  void populate_topology_bridge(TopoDS_Shape aShape);
+  DLIList<TopologyBridge*> populate_topology_bridge(TopoDS_Shape aShape);
   BodySM* populate_topology_bridge(TopoDS_Solid aShape);
   Surface* populate_topology_bridge(TopoDS_Face aShape);
   Curve* populate_topology_bridge(TopoDS_Edge aShape);
@@ -352,6 +352,7 @@
   static DLIList<TopologyBridge*>* CGMList;
   static int iTotalTBCreated ;
   static OCCQueryEngine* instance_;
+  static CubitBoolean PRINT_RESULTS;
     //- static pointer to unique instance of this class
   static const int OCCQE_MAJOR_VERSION;
More information about the cgma-dev
