[cgma-dev] r1379 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Mon Nov 12 13:39:36 CST 2007
Author: janehu
Date: 2007-11-12 13:39:36 -0600 (Mon, 12 Nov 2007)
New Revision: 1379
Modified:
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.hpp
Log:
First try to write outall entities as a compound shape, without any other attributs and see how it works.
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-11-12 14:30:53 UTC (rev 1378)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-11-12 19:39:36 UTC (rev 1379)
@@ -79,6 +79,7 @@
#include <BRepTools.hxx>
#include <TopExp_Explorer.hxx>
#include <TopoDS.hxx>
+#include "TopoDS_Compound.hxx"
#include <TopoDS_CompSolid.hxx>
#include <TopoDS_Solid.hxx>
#include <TopoDS_Shell.hxx>
@@ -751,7 +752,7 @@
if( export_solid_model( ref_entity_list, temp_filename.c_str(), "OCC",
cubit_version ) == CUBIT_FAILURE )
- PRINT_ERROR( "Error occured while trying to save temporary MESH_BASED_GEOMETRY file\n");
+ PRINT_ERROR( "Error occured while trying to save temporary OCC_BASED_GEOMETRY file\n");
return CUBIT_FAILURE;
@@ -785,14 +786,10 @@
- DLIList<OCCBody*> facet_bodies;
- DLIList<OCCLump*> facet_lumps;
- DLIList<OCCShell*> facet_shells;
- DLIList<OCCSurface*> facet_surfaces;
- DLIList<OCCLoop*> facet_loops;
- DLIList<OCCCoEdge*> facet_coedges;
- DLIList<OCCCurve*> facet_curves;
- DLIList<OCCPoint*> facet_points;
+ DLIList<OCCBody*> OCC_bodies;
+ DLIList<OCCSurface*> OCC_surfaces;
+ DLIList<OCCCurve*> OCC_curves;
+ DLIList<OCCPoint*> OCC_points;
DLIList<TopologyBridge*> ref_entities_handled;
@@ -806,19 +803,21 @@
//if it is a Vertex
if( OCCPoint* pt = CAST_TO( ref_entity_ptr, OCCPoint) )
- facet_points.append( pt );
+ OCC_points.append( pt );
//if it is a Curve
else if( OCCCurve* curve = CAST_TO( ref_entity_ptr, OCCCurve) )
- facet_curves.append( curve );
+ OCC_curves.append( curve );
//if it is a Surface -- I don't think you can ever have a free surface
//without it being a Body
else if( OCCSurface* surf = CAST_TO( ref_entity_ptr, OCCSurface) )
- facet_surfaces.append( surf );
+ OCC_surfaces.append( surf );
//if it is a Body
else if( OCCBody* body = CAST_TO( ref_entity_ptr, OCCBody ) )
- facet_bodies.append( body );
+ OCC_bodies.append( body );
else
handled = CUBIT_FALSE;
@@ -833,12 +832,14 @@
ref_entity_list.remove_all_with_value(NULL);
- int free_body_count = facet_bodies.size();
- int free_curve_count = facet_curves.size();
- int free_point_count = facet_points.size();
+ int free_body_count = OCC_bodies.size();
+ int free_curve_count = OCC_curves.size();
+ int free_point_count = OCC_points.size();
+ int free_surface_count = OCC_surfaces.size();
//if nothing to write out...return
- if( free_body_count == 0 && free_curve_count == 0 && free_point_count == 0)
+ if( free_body_count == 0 && free_surface_count == 0 &&
+ free_curve_count == 0 && free_point_count == 0)
return CUBIT_SUCCESS;
//get file pointer
@@ -847,9 +848,9 @@
//create a wrapper object for writing
CIOWrapper file_writer( file_ptr );
- // write out file type "MESHED_BASED_GEOMETRY"
+ // write out file type "OCC_BASED_GEOMETRY"
file_writer.BeginWriteBlock(0);
- file_writer.Write( "MESH_BASED_GEOMETRY", 19 );
+ file_writer.Write( "OCC_BASED_GEOMETRY", 19 );
// write out Endian value
UnsignedInt32 endian_value = CCubitFile::mintNativeEndian;
@@ -862,17 +863,15 @@
//save the facets (geometry info )
CubitStatus status;
- if( status == CUBIT_FAILURE ) return CUBIT_FAILURE;
//write out topology and attributes
status = write_topology( file_ptr,
- facet_bodies, facet_lumps,
- facet_shells, facet_surfaces,
- facet_loops, facet_coedges,
- facet_curves, facet_points );
+ OCC_bodies, OCC_surfaces,
+ OCC_curves, OCC_points );
- if( free_body_count || free_curve_count || free_point_count )
+ if( free_body_count || free_surface_count ||
+ free_curve_count || free_point_count )
PRINT_INFO( "\nExported:" );
int flg = 0;
@@ -883,392 +882,87 @@
if( DEBUG_FLAG( 153 ) )
if( free_body_count == 1 )
- PRINT_INFO( "%4d Facet Body\n", free_body_count );
+ PRINT_INFO( "%4d OCC Body\n", free_body_count );
else
- PRINT_INFO( "%4d Facet Bodies\n", free_body_count );
+ PRINT_INFO( "%4d OCC Bodies\n", free_body_count );
- if( facet_lumps.size() == 1 )
- PRINT_INFO( "%4d Facet Volume\n", facet_lumps.size() );
+ if( free_surface_count )
+ if( flg )PRINT_INFO( " " );else flg=1;
+ if( free_surface_count == 1 )
+ PRINT_INFO( "%4d OCC Surface\n", free_surface_count );
else
- PRINT_INFO( "%4d Facet Volumes\n", facet_lumps.size() );
if( free_curve_count )
if( free_curve_count == 1 )
- PRINT_INFO( "%4d Facet Curve\n", free_curve_count );
+ PRINT_INFO( "%4d OCC Curve\n", free_curve_count );
else
- PRINT_INFO( "%4d Facet Curves\n", free_curve_count );
+ PRINT_INFO( "%4d OCC Curves\n", free_curve_count );
if( free_point_count )
if( free_point_count == 1 )
- PRINT_INFO( "%4d Facet Point\n", free_point_count );
+ PRINT_INFO( "%4d OCC Point\n", free_point_count );
else
- PRINT_INFO( "%4d Facet Points\n", free_point_count );
+ PRINT_INFO( "%4d OCC Points\n", free_point_count );
PRINT_INFO( "\n" );
+ fclose( file_ptr );
- fclose( file_ptr );
- return CUBIT_SUCCESS;
+ return CUBIT_SUCCESS;
CubitStatus
OCCQueryEngine::write_topology( FILE *file_ptr,
- DLIList<OCCBody*> &facet_bodies,
- DLIList<OCCLump*> &facet_lumps,
- DLIList<OCCShell*> &facet_shells,
- DLIList<OCCSurface*> &facet_surfaces,
- DLIList<OCCLoop*> &facet_loops,
- DLIList<OCCCoEdge*> &facet_coedges,
- DLIList<OCCCurve*> &facet_curves,
- DLIList<OCCPoint*> &facet_points )
+ DLIList<OCCBody*> &OCC_bodies,
+ DLIList<OCCSurface*> &OCC_surfaces,
+ DLIList<OCCCurve*> &OCC_curves,
+ DLIList<OCCPoint*> &OCC_points )
int i;
+ //Create a compound shape to export
+ BRep_Builder B;
+ TopoDS_Compound Co;
+ B.MakeCompound(Co);
- //create a wrapper object for writing
- CIOWrapper file_writer( file_ptr );
- //-----------------write OCCPoints--------------
- UnsignedInt32 size = facet_points.size();
- //write out number of OCCPoints
- file_writer.Write( &size, 1 );
- facet_points.reset();
- for( i=0; i<facet_points.size(); i++)
+ //Add every shape to the compound
+ for (i = 0; i < OCC_bodies.size(); i++)
- OCCPoint *curr_point = facet_points.get_and_step();
- //file_writer.Write( reinterpret_cast<UnsignedInt32*>(&id), 1 );
- if( curr_point->save_attribs(file_ptr) == CUBIT_FAILURE )
- return CUBIT_FAILURE;
+ TopoDS_Shape *shape = OCC_bodies.get_and_step()->get_TopoDS_Shape();
+ B.Add(Co, *shape);
- //-----------------write FacetCurves--------------
- size = facet_curves.size();
- //write out number of FacetCurves
- facet_curves.reset();
- for( i=0; i<facet_curves.size(); i++)
+ for (i = 0; i < OCC_surfaces.size(); i++)
- OCCCurve *curr_curve = facet_curves.get_and_step();
- Point *s_point, *e_point;
- s_point = curr_curve->start_point();
- e_point = curr_curve->end_point();
- int data_to_write[4];
- // get start&end points implicit ids
- OCCPoint *temp_point = NULL;
- temp_point = CAST_TO( s_point, OCCPoint );
- if( !temp_point ) assert(0);
- int found;
- found = facet_points.where_is_item( temp_point );
- if( found == -1)
- assert(0);
- data_to_write[0] = found;
- temp_point = CAST_TO( e_point, OCCPoint );
- if( found == -1)
- PRINT_ERROR("Problem saving Facet Curves\n");
- data_to_write[1] = found;
- //convert Sense info to integer
- if( curr_curve->get_sense() == CUBIT_UNKNOWN )
- data_to_write[2] = -1;
- else
- data_to_write[2] = (curr_curve->get_sense() == CUBIT_REVERSED) ? 1 : 0;
- //write the data
- file_writer.Write( reinterpret_cast<UnsignedInt32*>(data_to_write), 4 );
- if( curr_curve->save_attribs(file_ptr) == CUBIT_FAILURE )
+ TopoDS_Face *face = OCC_surfaces.get_and_step()->get_TopoDS_Face();
+ B.Add(Co, *face);
- //-----------------write FacetCoedges--------------
- size = facet_coedges.size();
- // write out number of FacetCurves
- facet_coedges.reset();
- for( i=0; i<facet_coedges.size(); i++)
+ for (i = 0; i < OCC_curves.size(); i++)
- OCCCoEdge *curr_coedge = facet_coedges.get_and_step();
- Curve *curve_sm;
- curve_sm = curr_coedge->curve();
- OCCCurve *temp_curve = NULL;
- temp_curve = CAST_TO( curve_sm, OCCCurve );
- int data_to_write[2];
- // get implicit id of this curve
- int found;
- found = facet_curves.where_is_item( temp_curve );
- if( found == -1)
- PRINT_ERROR("Problem saving Facet CoEdges\n");
- // convert sense info to integer
- if( curr_coedge->get_sense() == CUBIT_UNKNOWN )
- data_to_write[1] = -1;
- else
- data_to_write[1] = (curr_coedge->get_sense() == CUBIT_REVERSED) ? 1 : 0;
- // write out the data
- file_writer.Write( reinterpret_cast<UnsignedInt32*>(data_to_write), 2 );
+ TopoDS_Edge *edge = OCC_curves.get_and_step()->get_TopoDS_Edge();
+ B.Add(Co, *edge);
- //-----------------write OCCLoops--------------
- size = facet_loops.size();
- // write out number of OCCLoops
- facet_loops.reset();
- for( i=0; i<facet_loops.size(); i++)
+ for (i = 0; i < OCC_points.size(); i++)
- OCCLoop *curr_loop = facet_loops.get_and_step();
- DLIList<OCCCoEdge*> coedge_list;
- curr_loop->get_coedges( coedge_list );
- // get number of coedges in this loop
- UnsignedInt32 *data_to_write;
- size = coedge_list.size();
- data_to_write = new UnsignedInt32[ size + 1 ];
- data_to_write[0] = size;
- UnsignedInt32 j;
- // get implicit ids of coedges
- coedge_list.reset();
- for( j=1; j<size+1; j++)
- OCCCoEdge *temp_coedge = coedge_list.get_and_step();
- int found;
- found = facet_coedges.where_is_item( temp_coedge );
- if( found == -1)
- PRINT_ERROR("Problem saving Facet Loops\n");
- data_to_write[j] = found;
- file_writer.Write( data_to_write, size + 1);
- delete [] data_to_write;
+ TopoDS_Vertex *vertex = OCC_points.get_and_step()->get_TopoDS_Vertex();
+ B.Add(Co, *vertex);
- //-----------------write OCCSurfaces--------------
- size = facet_surfaces.size();
- // write out number of OCCSurfaces
- facet_surfaces.reset();
- for( i=0; i<facet_surfaces.size(); i++)
- OCCSurface *curr_surface = facet_surfaces.get_and_step();
- DLIList<OCCLoop*> loop_list;
- curr_surface->get_loops( loop_list );
- int num_loops = loop_list.size();
- int data_to_write[6];
- // if( curr_surface->get_relative_surface_sense() == CUBIT_UNKNOWN )
-// data_to_write[0] = -1;
-// else
-// data_to_write[0] = (curr_surface->get_relative_surface_sense() == CUBIT_REVERSED) ? 1 : 0;
- data_to_write[0]=0;
- // get "useFacets"
- data_to_write[1] = 1;
- // get output id of FacetEvalTool
- //data_to_write[2] = curr_surface->get_eval_tool()->get_output_id();
- // get Shell Sense stuff
- CubitSense sense0;
- curr_surface->get_shell_sense( sense0 );
- if( sense0 == CUBIT_UNKNOWN )
- data_to_write[3] = -1;
- else
- data_to_write[3] = (sense0 == CUBIT_REVERSED) ? 1 : 0;
-// if( sense1 == CUBIT_UNKNOWN )
- data_to_write[4] = -1;
-// else
-// data_to_write[4] = (sense1 == CUBIT_REVERSED) ? 1 : 0;
- // get number of loops
- data_to_write[5] = num_loops;
- file_writer.Write( reinterpret_cast<UnsignedInt32*>(data_to_write), 6 );
- // get implicit ids of loops
- if( num_loops > 0 )
- int *loop_ids = new int[num_loops];
- int j;
- loop_list.reset();
- for( j=0; j<num_loops; j++)
- OCCLoop *temp_loop = loop_list.get_and_step();
- int found;
- found = facet_loops.where_is_item( temp_loop );
- if( found == -1 )
- PRINT_ERROR("Problem saving Facet Surfaces\n");
- loop_ids[j] = found;
- // write out data
- file_writer.Write( reinterpret_cast<UnsignedInt32*>(loop_ids), num_loops );
- delete [] loop_ids;
- if( curr_surface->save_attribs(file_ptr) == CUBIT_FAILURE )
- //-----------------write OCCShells--------------
- size = facet_shells.size();
- // write out number of OCCShells
- facet_shells.reset();
- for( i=0; i<facet_shells.size(); i++)
- OCCShell *curr_shell= facet_shells.get_and_step(); //number of surfaces
- DLIList<OCCSurface*> temp_facet_surf_list;
- curr_shell->get_surfaces( temp_facet_surf_list );
- // get number of surfaces in this shell
- int num_surfs = temp_facet_surf_list.size();
- data_to_write = new UnsignedInt32[ num_surfs + 1];
- data_to_write[0] = num_surfs;
- // get implicit ids of surfaces
- int j;
- temp_facet_surf_list.reset();
- for( j=1; j<num_surfs+1; j++)
- OCCSurface *temp_facet_surface = temp_facet_surf_list.get_and_step();
- int found;
- found = facet_surfaces.where_is_item( temp_facet_surface );
- if( found == -1 )
- PRINT_ERROR("Problem saving Facet Shells\n");
- // write the data
- file_writer.Write( data_to_write, num_surfs + 1 );
- //-----------------write OCCLumps--------------
- size = facet_lumps.size();
- // write out number of OCCLumps
- facet_lumps.reset();
- for( i=0; i<facet_lumps.size(); i++)
- OCCLump *curr_lump = facet_lumps.get_and_step();
- DLIList<OCCShell*> temp_facet_shell_list;
- curr_lump->get_shells( temp_facet_shell_list );
- // get number of shells in this lump
- int num_shells= temp_facet_shell_list.size();
- data_to_write = new UnsignedInt32[ num_shells+ 1];
- data_to_write[0] = num_shells;
- //get implicit ides of the lumps in this shell
- int j;
- temp_facet_shell_list.reset();
- for( j=1; j<num_shells+1; j++)
- OCCShell *temp_facet_shell = temp_facet_shell_list.get_and_step();
- int found;
- found = facet_shells.where_is_item( temp_facet_shell );
- if( found == -1 )
- PRINT_ERROR("Problem saving Facet Lumps\n");
- //write the data
- file_writer.Write( data_to_write, num_shells + 1 );
- if( curr_lump->save_attribs(file_ptr) == CUBIT_FAILURE )
- //-----------------write FacetBodies--------------
- size = facet_bodies.size();
- // write out number of FacetBodies
- facet_bodies.reset();
- for( i=0; i<facet_bodies.size(); i++)
- OCCBody *curr_body = facet_bodies.get_and_step();
- DLIList<OCCLump*> temp_facet_lump_list;
- // get the number of lumps in this body
- int num_lumps = temp_facet_lump_list.size();
- data_to_write = new UnsignedInt32[ num_lumps + 1];
- data_to_write[0] = num_lumps;
- // get the implicit ids of the lumps in this body
- int j;
- temp_facet_lump_list.reset();
- for( j=1; j<num_lumps+1; j++)
- OCCLump *temp_facet_lump = temp_facet_lump_list.get_and_step();
- int found;
- found = facet_lumps.where_is_item( temp_facet_lump );
- if( found == -1 )
- PRINT_ERROR("Problem saving Facet Bodies\n");
- // write the data
- file_writer.Write( data_to_write, num_lumps + 1 );
- // write the transformation matrix of this body
- CubitTransformMatrix trans_matrix;
- curr_body->get_transforms( trans_matrix );
- UnsignedInt32 num_rows = trans_matrix.num_rows();
- UnsignedInt32 num_cols = trans_matrix.num_cols();
- UnsignedInt32 rows_and_cols[2];
- rows_and_cols[0] = num_rows;
- rows_and_cols[1] = num_cols;
- file_writer.Write( rows_and_cols, 2 );
- double *trans_matrix_array;
- trans_matrix_array = new double[ num_rows*num_cols ];
- //fill up the array row-by-row
- unsigned u, k = 0;
- for(u=0; u<num_rows; u++)
- for(k=0; k<num_cols; k++)
- trans_matrix_array[(u*num_cols)+k] = trans_matrix.get(u,k);
- file_writer.Write( trans_matrix_array, u*k );
- delete [] trans_matrix_array;
- if( curr_body->save_attribs(file_ptr) == CUBIT_FAILURE )
+ if(!BRepTools::Write(Co, (char *) file_ptr))
+ return CUBIT_FAILURE;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2007-11-12 14:30:53 UTC (rev 1378)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2007-11-12 19:39:36 UTC (rev 1379)
@@ -337,11 +337,7 @@
CubitStatus write_topology( FILE *file_ptr,
DLIList<OCCPoint*> &facet_points );
More information about the cgma-dev
