[cgma-dev] r1367 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Thu Nov 8 12:34:10 CST 2007
Author: janehu
Date: 2007-11-08 12:34:04 -0600 (Thu, 08 Nov 2007)
New Revision: 1367
Modified:
cgm/trunk/geom/OCC/OCCBody.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.hpp
Log:
Updated populate_topology_bridge for TopoDS_Shape, it's intended for TopoDS_Compound or TopoDS_CompSolid type objects. Each TopoDS_Solid will populate a lump and corresponding to a body; Added in update_bounding_box for OCCBody if when only lump_list is known.
Modified: cgm/trunk/geom/OCC/OCCBody.cpp
--- cgm/trunk/geom/OCC/OCCBody.cpp 2007-11-08 17:02:15 UTC (rev 1366)
+++ cgm/trunk/geom/OCC/OCCBody.cpp 2007-11-08 18:34:04 UTC (rev 1367)
@@ -61,6 +61,11 @@
update_bounding_box();
+OCCBody::OCCBody(DLIList<Lump*>& my_lumps)
+ myLumps += my_lumps;
OCCBody::~OCCBody()
//Not sure what to do..
@@ -231,16 +236,24 @@
void OCCBody::update_bounding_box()
Bnd_Box box;
- const TopoDS_Shape shape=*myTopoDSShape;
- //calculate the bounding box
- BRepBndLib::Add(shape, box);
- double min[3], max[3];
+ if (myTopoDSShape)
+ const TopoDS_Shape shape=*myTopoDSShape;
+ //calculate the bounding box
+ BRepBndLib::Add(shape, box);
+ double min[3], max[3];
- //get values
- box.Get(min[0], min[1], min[2], max[0], max[1], max[2]);
+ //get values
+ box.Get(min[0], min[1], min[2], max[0], max[1], max[2]);
- //update boundingbox.
- CubitBox cBox(min, max);
+ //update boundingbox.
+ CubitBox cBox(min, max);
+ boundingbox = cBox;
+ return;
+ CubitBox cBox;
+ for(int i = myLumps.size();i > 0; i--)
+ cBox |= myLumps.get_and_step()->bounding_box();
boundingbox = cBox;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-11-08 17:02:15 UTC (rev 1366)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-11-08 18:34:04 UTC (rev 1367)
@@ -1307,59 +1307,55 @@
return CUBIT_SUCCESS;
-BodySM* OCCQueryEngine::populate_topology_bridge(TopoDS_Shape aShape)
+void OCCQueryEngine::populate_topology_bridge(TopoDS_Shape aShape)
- TopoDS_Shape *poshape = new TopoDS_Shape;
- *poshape = aShape;
- BodySM *body;
- if (!OCCMap->IsBound(*poshape))
- printf("Adding Shape\n");
- iTotalTBCreated++;
- body = new OCCBody(poshape);
-// CGMList->append(lump);
-// imported_entities.append(lump);
- OCCMap->Bind(*poshape, iTotalTBCreated);
- OccToCGM->insert(valType(iTotalTBCreated,
- (TopologyBridge*)body));
- else
- int k = OCCMap->Find(*poshape);
- body = (OCCBody*)(OccToCGM->find(k))->second;
+ // suitable to popolate for a TopoDS_CompSolid or TopoDS_Compound shape.
TopExp_Explorer Ex;
for (Ex.Init(aShape, TopAbs_SOLID); Ex.More(); Ex.Next())
- populate_topology_bridge(TopoDS::Solid(Ex.Current()));
- return body;
+ populate_topology_bridge(TopoDS::Solid(Ex.Current()));
+ for (Ex.Init(aShape, TopAbs_SHELL, TopAbs_SOLID); Ex.More(); Ex.Next())
+ populate_topology_bridge(TopoDS::Shell(Ex.Current()));
+ for (Ex.Init(aShape, TopAbs_FACE, TopAbs_SHELL); Ex.More(); Ex.Next())
+ populate_topology_bridge(TopoDS::Face(Ex.Current()));
+ for (Ex.Init(aShape, TopAbs_WIRE, TopAbs_FACE); Ex.More(); Ex.Next())
+ populate_topology_bridge(TopoDS::Wire(Ex.Current()));
+ for (Ex.Init(aShape, TopAbs_EDGE, TopAbs_WIRE); Ex.More(); Ex.Next())
+ populate_topology_bridge(TopoDS::Edge(Ex.Current()));
+ for (Ex.Init(aShape, TopAbs_VERTEX, TopAbs_EDGE); Ex.More(); Ex.Next())
+ populate_topology_bridge(TopoDS::Vertex(Ex.Current()));
-Lump* OCCQueryEngine::populate_topology_bridge(TopoDS_Solid aShape)
+BodySM* OCCQueryEngine::populate_topology_bridge(TopoDS_Solid aShape)
+ //one OCCBody corresponds one OCCLump
TopoDS_Solid *posolid = new TopoDS_Solid;
*posolid = aShape;
OCCLump *lump;
+ OCCBody *body;
if (!OCCMap->IsBound(*posolid))
printf("Adding solid\n");
iTotalTBCreated++;
lump = new OCCLump(posolid);
+ body = new OCCBody(posolid);
OCCMap->Bind(*posolid, iTotalTBCreated);
- (TopologyBridge*)lump));
+ (TopologyBridge*)body));
else
int k = OCCMap->Find(*posolid);
- lump = (OCCLump*)(OccToCGM->find(k))->second;
+ body = (OCCBody*)(OccToCGM->find(k))->second;
TopExp_Explorer Ex;
for (Ex.Init(aShape, TopAbs_SHELL); Ex.More(); Ex.Next())
- return lump;
+ return body;
OCCShell* OCCQueryEngine::populate_topology_bridge(TopoDS_Shell aShape)
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2007-11-08 17:02:15 UTC (rev 1366)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2007-11-08 18:34:04 UTC (rev 1367)
@@ -320,8 +320,8 @@
virtual CubitBoolean volumes_overlap (Lump *lump1, Lump *lump2 ) const ;
- BodySM* populate_topology_bridge(TopoDS_Shape aShape);
- Lump* populate_topology_bridge(TopoDS_Solid aShape);
+ void populate_topology_bridge(TopoDS_Shape aShape);
+ BodySM* populate_topology_bridge(TopoDS_Solid aShape);
Surface* populate_topology_bridge(TopoDS_Face aShape);
Curve* populate_topology_bridge(TopoDS_Edge aShape);
Point* populate_topology_bridge(TopoDS_Vertex aShape);
More information about the cgma-dev
