[cgma-dev] r1467 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Wed Dec 12 14:27:04 CST 2007
Author: janehu
Date: 2007-12-12 14:27:04 -0600 (Wed, 12 Dec 2007)
New Revision: 1467
Modified:
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.hpp
Log:
adding the down level entity unhook functions for entity deleting.
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2007-12-11 17:59:18 UTC (rev 1466)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2007-12-12 20:27:04 UTC (rev 1467)
@@ -1300,43 +1300,34 @@
   //remove the entry from the map
   int k;
+  OCCBody* occ_body_find = NULL;
   if(OCCMap->IsBound(*shape))
       k = OCCMap->Find(*shape);
       if(!OCCMap->UnBind(*shape))
 	PRINT_ERROR("The OccBody and TopoDS_Shape pair is not in the map!");
-      OCCBody* occ_body_find = (OCCBody*)(OccToCGM->find(k))->second;
-      BodyList->remove(occ_body_find);
+      occ_body_find = (OCCBody*)(OccToCGM->find(k))->second;
       if(!OccToCGM->erase(k))
-      for (int i = occ_body->lumps().size(); i--; )
-        Lump* sm_ptr = occ_body->lumps().get_and_step();
-        OCCLump* lump = CAST_TO(sm_ptr, OCCLump);
-        if (lump)
-          lump->remove_body();
-      occ_body->lumps().clean_out();
+  for(int i =0; i < occ_body->lumps().size(); i++)
+     Lump* lump = occ_body->lumps().get_and_step();
+     OCCLump* occ_lump = CAST_TO(lump, OCCLump);
+     if (occ_lump)
+       occ_lump->remove_body();
+     unhook_Lump_from_OCC(lump);
-  else //check for all lumps for deletion, this body was generated
-    //by its OCCLumps
-      for(int i =0; i < occ_body->lumps().size(); i++)
-	  Lump* lump = occ_body->lumps().get_and_step();
-	  delete_solid_model_entities(lump);
-  // Remove the links between OCC and Cubit
-  //  unhook_ENTITY_from_VGI(shape);
+  occ_body->lumps().clean_out();
+  if (occ_body_find)
+     BodyList->remove(occ_body_find);
+  else
+     BodyList->remove(occ_body);
   delete shape;
   delete bodysm;
   return CUBIT_SUCCESS;
@@ -1352,8 +1343,11 @@
 // Creation Date : 11/29/07
 CubitStatus
-OCCQueryEngine::delete_solid_model_entities( Lump* lump ) const
+OCCQueryEngine::unhook_Lump_from_OCC( Lump* lump ) const
+  if (lump == NULL)
+    return CUBIT_FAILURE;
   OCCLump* occ_lump = dynamic_cast<OCCLump*>(lump);
   if (!occ_lump)
@@ -1375,16 +1369,66 @@
 	PRINT_ERROR("The OccSurface and TopoDS_Face pair is not in the map!");
-  //  unhook_ENTITY_from_VGI(face);
-  BodyList->remove(CAST_TO(occ_lump->body(), OCCBody));
-  delete solid;
+  DLIList<TopologyBridge*> children;
+  occ_lump->get_children_virt(children);
+  for(int i = 0; i < children.size(); i++)
+     ShellSM* shell = CAST_TO(children.get_and_step(), ShellSM);
+     unhook_ShellSM_from_OCC(shell);
+  if (occ_lump->body() != NULL)
+    BodyList->remove(CAST_TO(occ_lump->body(), OCCBody));
   delete lump;
+// Purpose       : unhook a ShellSM from its underlining OCC entity.
+// Special Notes :
+// Creator       : Jane Hu
+// Creation Date : 12/12/07
+CubitStatus
+OCCQueryEngine::unhook_ShellSM_from_OCC( ShellSM* shell ) const
+  OCCShell* occ_shell = dynamic_cast<OCCShell*>(shell);
+  if (!occ_shell)
+  TopoDS_Shell* Shell = occ_shell->get_TopoDS_Shell();
+  if(!Shell)
+  //remove the entry from the map
+  int k;
+  if(OCCMap->IsBound(*Shell))
+      k = OCCMap->Find(*Shell);
+      if(!OCCMap->UnBind(*Shell))
+        PRINT_ERROR("The OccSurface and TopoDS_Face pair is not in the map!");
+      if(!OccToCGM->erase(k))
+  occ_shell->get_children_virt(children);
+     Surface* surface = CAST_TO(children.get_and_step(), Surface);
+     unhook_Surface_from_OCC(surface);
+  delete shell;
+  return CUBIT_SUCCESS;
 // Purpose       : Delete a OCCSurface and child entities.
 // Special Notes :
@@ -1394,7 +1438,7 @@
 // Creation Date : 10/29/07
 CubitStatus
-OCCQueryEngine::delete_solid_model_entities( Surface* surface ) const
+OCCQueryEngine::delete_solid_model_entities( Surface* surface)const
   OCCSurface* fsurf = dynamic_cast<OCCSurface*>(surface);
   if (!fsurf)
@@ -1405,6 +1449,34 @@
   if(!face)
+  delete face;
+  delete surface;
+// Purpose       : unhook a Surface from its underlining OCC entity.
+// Special Notes :
+CubitStatus
+OCCQueryEngine::unhook_Surface_from_OCC( Surface* surface ) const
+  OCCSurface* fsurf = dynamic_cast<OCCSurface*>(surface);
+  if (!fsurf)
+  TopoDS_Face* face = fsurf->get_TopoDS_Face();
+  if(!face)
   int k;
   if(OCCMap->IsBound(*face))
@@ -1412,19 +1484,65 @@
       k = OCCMap->Find(*face);
       if(!OCCMap->UnBind(*face))
-	PRINT_ERROR("The OccSurface and TopoDS_Face pair is not in the map!");
       SurfaceList->remove((OCCSurface*)(OccToCGM->find(k))->second);
+  fsurf->get_children_virt(children);
+     LoopSM* loop = CAST_TO(children.get_and_step(), LoopSM);
+     unhook_LoopSM_from_OCC(loop);
-  delete face;
-  delete surface;
+// Purpose       : unhook a LoopSM from its underlining OCC entity.
+// Special Notes :
+CubitStatus
+OCCQueryEngine::unhook_LoopSM_from_OCC( LoopSM* loopsm ) const
+  OCCLoop* occ_loop = dynamic_cast<OCCLoop*>(loopsm);
+  if (!occ_loop)
+  TopoDS_Wire* wire = occ_loop->get_TopoDS_Wire();
+  if(!wire)
+  int k;
+  if(OCCMap->IsBound(*wire))
+      k = OCCMap->Find(*wire);
+      if(!OCCMap->UnBind(*wire))
+        PRINT_ERROR("The OccLoop and TopoDS_Wire pair is not in the map!");
+  DLIList<OCCCoEdge*> children;
+  occ_loop->coedges(children);
+     Curve* curve = children.get_and_step()->curve();
+     unhook_Curve_from_OCC(curve);
+  delete loopsm;
@@ -1438,7 +1556,7 @@
 // Creation Date : 09/29/03
 CubitStatus
-OCCQueryEngine::delete_solid_model_entities( Curve* curve ) const
+OCCQueryEngine::delete_solid_model_entities( Curve* curve)const
   OCCCurve* fcurve = dynamic_cast<OCCCurve*>(curve);
   if (!fcurve )
@@ -1448,6 +1566,33 @@
   if (!edge)
+  delete edge;
+  delete curve;
+// Purpose       : unhook a Curve from its underlining OCC entity.
+// Special Notes :
+CubitStatus
+OCCQueryEngine::unhook_Curve_from_OCC( Curve* curve ) const
+  OCCCurve* fcurve = dynamic_cast<OCCCurve*>(curve);
+  if (!fcurve )
+  TopoDS_Edge * edge = fcurve->get_TopoDS_Edge();
+  if (!edge)
   int k;
   if(OCCMap->IsBound(*edge))
@@ -1455,21 +1600,19 @@
       k = OCCMap->Find(*edge);
       if(!OCCMap->UnBind(*edge))
-	PRINT_ERROR("The OccCurve and TopoDS_Edge pair is not in the map!");
+        PRINT_ERROR("The OccCurve and TopoDS_Edge pair is not in the map!");
       CurveList->remove((OCCCurve*)(OccToCGM->find(k))->second);
+        PRINT_ERROR("The OccCurve and TopoDS_Edge pair is not in the map!");    }
-  //unhook_ENTITY_from_VGI(edge);
-  delete edge;
-  delete curve;
-  return CUBIT_SUCCESS;
+  fcurve->get_children_virt(children);
+     Point* point = CAST_TO(children.get_and_step(), Point);
+     unhook_Point_from_OCC(point);
 // Purpose       : Delete a OCCPoint and child entities.
@@ -1480,7 +1623,7 @@
 CubitStatus
-OCCQueryEngine::delete_solid_model_entities( Point* point ) const
+OCCQueryEngine::delete_solid_model_entities( Point* point) const
   OCCPoint* fpoint = dynamic_cast<OCCPoint*>(point);
   if (!fpoint)
@@ -1490,6 +1633,33 @@
   if (!vertex)
+  delete vertex;
+  delete point;
+// Purpose       : unhook a Point from its underlining OCC entity.
+// Special Notes :
+CubitStatus
+OCCQueryEngine::unhook_Point_from_OCC( Point* point ) const
+  OCCPoint* fpoint = dynamic_cast<OCCPoint*>(point);
+  if (!fpoint)
+  TopoDS_Vertex *vertex = fpoint->get_TopoDS_Vertex();
+  if (!vertex)
   int k;
   if(OCCMap->IsBound(*vertex))
@@ -1497,18 +1667,11 @@
       k = OCCMap->Find(*vertex);
       if(!OCCMap->UnBind(*vertex))
-	PRINT_ERROR("The OccPoint and TopoDS_Vertex pair is not in the map!");
+        PRINT_ERROR("The OccPoint and TopoDS_Vertex pair is not in the map!");
-  //unhook_ENTITY_from_VGI(vertex);
-  delete vertex;
-  delete point;
 CubitStatus OCCQueryEngine::fire_ray(BodySM * body,
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2007-12-11 17:59:18 UTC (rev 1466)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2007-12-12 20:27:04 UTC (rev 1467)
@@ -256,16 +256,21 @@
                                  CubitBoolean import_vertices = CUBIT_TRUE,
                                  CubitBoolean free_surfaces = CUBIT_TRUE);
-  CubitStatus delete_solid_model_entities( Lump* lump ) const;
+  CubitStatus unhook_Lump_from_OCC( Lump* lump ) const;
+  CubitStatus unhook_ShellSM_from_OCC( ShellSM* shell ) const;
+  CubitStatus unhook_LoopSM_from_OCC( LoopSM* loopsm ) const;
+  CubitStatus unhook_Surface_from_OCC( Surface* surface ) const;
+  CubitStatus unhook_Curve_from_OCC( Curve* curve ) const;
+  CubitStatus unhook_Point_from_OCC( Point* point ) const;
 public:
   virtual void delete_solid_model_entities(DLIList<BodySM*>& body_list) const;
     //- Deletes all solid model entities associated with the Bodies in
     //- the input list.
   virtual CubitStatus delete_solid_model_entities( BodySM* body_ptr ) const;
-  virtual CubitStatus delete_solid_model_entities(Surface* surf_ptr ) const;
-  virtual CubitStatus delete_solid_model_entities( Curve* curve_ptr ) const;
-  virtual CubitStatus delete_solid_model_entities( Point* point_ptr ) const;
+  virtual CubitStatus delete_solid_model_entities(Surface* surf_ptr)const;
+  virtual CubitStatus delete_solid_model_entities( Curve* curve_ptr)const;
+  virtual CubitStatus delete_solid_model_entities( Point* point_ptr)const;
   virtual CubitStatus fire_ray(BodySM *body,
                                const CubitVector &ray_point,
More information about the cgma-dev mailing list
