[cgma-dev] r1466 - in cgm/trunk: geom/OCC test
janehu at mcs.anl.gov
Tue Dec 11 11:59:18 CST 2007
Author: janehu
Date: 2007-12-11 11:59:18 -0600 (Tue, 11 Dec 2007)
New Revision: 1466
Added:
cgm/trunk/test/62_shaver1.brep
cgm/trunk/test/72_shaver6.brep
Modified:
cgm/trunk/geom/OCC/OCCBody.cpp
cgm/trunk/geom/OCC/OCCBody.hpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/test/makept.cpp
Log:
changed the way for delete_solid_model_entities for BodySM. Tested reading 4 brep bodies(lumps) and created 4 bodies, then created a OCC vertex, then export the 4 bodies and 1 vertex to a brep file, then detete all bodies and free entities. all working fine. It seems that CompSolid type is very rare used and I check several models with one or more Solid, they all have Compound shape instead of CompSolidtype, trying to create CompSolid from solids gives frozentype error, indicating the solids are not free and can't be modified. Will do 1. supporting stand along shell and loop export if they were read in as such. 2.detailed query testing. in the next step. Please feel free to read/write OCC brep files through CGM now.
Modified: cgm/trunk/geom/OCC/OCCBody.cpp
--- cgm/trunk/geom/OCC/OCCBody.cpp 2007-12-11 17:58:50 UTC (rev 1465)
+++ cgm/trunk/geom/OCC/OCCBody.cpp 2007-12-11 17:59:18 UTC (rev 1466)
@@ -86,7 +86,6 @@
OCCBody::~OCCBody()
- disconnect_all_lumps();
GeometryQueryEngine* OCCBody::get_geometry_query_engine() const
@@ -271,30 +270,6 @@
-// Purpose : Tear down topology
-// Special Notes :
-// Creator : Jason Kraftcheck
-// Creation Date : 09/29/03
-void OCCBody::disconnect_all_lumps()
- myLumps.reset();
- for (int i = myLumps.size(); i--; )
- Lump* sm_ptr = myLumps.get_and_step();
- OCCLump* lump = CAST_TO(sm_ptr, OCCLump);
- if (lump)
- assert(lump->get_body() == this);
- lump->remove_body();
- myLumps.clean_out();
// Purpose : Find centroid
Modified: cgm/trunk/geom/OCC/OCCBody.hpp
--- cgm/trunk/geom/OCC/OCCBody.hpp 2007-12-11 17:58:50 UTC (rev 1465)
+++ cgm/trunk/geom/OCC/OCCBody.hpp 2007-12-11 17:59:18 UTC (rev 1466)
@@ -160,8 +160,6 @@
virtual void get_parents_virt( DLIList<TopologyBridge*>& parents );
virtual void get_children_virt( DLIList<TopologyBridge*>& children );
- void disconnect_all_lumps();
virtual CubitStatus mass_properties( CubitVector& result, double& volume );
virtual CubitPointContainment point_containment( const CubitVector& pos );
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-12-11 17:58:50 UTC (rev 1465)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-12-11 17:59:18 UTC (rev 1466)
@@ -861,13 +861,10 @@
if( free_body_count )
if( flg )PRINT_INFO( " " );else flg=1;
- if( DEBUG_FLAG( 153 ) )
- if( free_body_count == 1 )
- PRINT_INFO( "%4d OCC Body\n", free_body_count );
- else
- PRINT_INFO( "%4d OCC Bodies\n", free_body_count );
+ if( free_body_count == 1 )
+ PRINT_INFO( "%4d OCC Body\n", free_body_count );
+ else
+ PRINT_INFO( "%4d OCC Bodies\n", free_body_count );
if( free_surface_count )
@@ -933,7 +930,8 @@
for(int i = 0; i < lumps.size(); i++)
OCCLump *occ_lump = (OCCLump *) lumps.get_and_step();
- B.Add(Co, *(occ_lump->get_TopoDS_Solid()));
+ TopoDS_Solid solid = *(occ_lump->get_TopoDS_Solid());
+ B.Add(Co, solid);
@@ -1315,7 +1313,14 @@
if(!OccToCGM->erase(k))
PRINT_ERROR("The OccBody and TopoDS_Shape pair is not in the map!");
- delete bodysm;
+ for (int i = occ_body->lumps().size(); i--; )
+ Lump* sm_ptr = occ_body->lumps().get_and_step();
+ OCCLump* lump = CAST_TO(sm_ptr, OCCLump);
+ if (lump)
+ lump->remove_body();
+ occ_body->lumps().clean_out();
else //check for all lumps for deletion, this body was generated
@@ -1333,7 +1338,7 @@
// unhook_ENTITY_from_VGI(shape);
delete shape;
+ delete bodysm;
return CUBIT_SUCCESS;
Added: cgm/trunk/test/62_shaver1.brep
--- cgm/trunk/test/62_shaver1.brep (rev 0)
+++ cgm/trunk/test/62_shaver1.brep 2007-12-11 17:59:18 UTC (rev 1466)
@@ -0,0 +1,8034 @@
+DBRep_DrawableShape
+CASCADE Topology V1, (c) Matra-Datavision
+Locations 112
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 0
+2 1 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 41.25
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -35.25
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 2
+2 3 1 4 1 5 1 0
+1
+ 1 0 -0 5
+ -0 1 0 0
+ 0 0 1 0
+2 7 1 5 1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 38.25
+2 9 1 5 1 0
+2 3 1 5 1 0
+2 5 -1 4 -1 3 -1 0
+1
+ 1 0 -0 5
+ -0 1 0 0
+ 0 0 1 0
+2 13 1 5 1 0
+2 3 1 4 1 13 -1 0
+2 5 -1 13 -1 0
+2 3 1 4 1 0
+1
+ 1 0 -0 0
+ -0 1 0 -6.25
+ 0 0 1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 0
+2 18 1 19 1 0
+1
+ 1 0 -0 0
+ -0 1 0 12.5
+ 0 0 1 0
+2 18 1 21 1 19 1 0
+2 3 1 4 1 7 -1 0
+2 5 -1 7 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 3
+2 25 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 3
+2 27 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 3
+2 29 -1 0
+2 5 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 38.25
+2 32 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 38.25
+2 34 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 3
+2 36 -1 0
+2 9 -1 0
+2 7 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 26.25
+2 5 -1 9 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 2
+2 42 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 2
+2 44 -1 5 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 2
+2 46 -1 5 -1 0
+2 5 -1 3 -1 0
+1
+ 1 0 0 -0
+ 0 1 0 -306
+ 0 0 1 -0
+2 49 -1 0
+2 13 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 26.25
+2 52 -1 0
+2 18 1 19 1 5 1 0
+2 5 -1 19 -1 18 -1 0
+2 19 -1 18 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 28.75
+2 18 -1 0
+2 21 -1 18 -1 0
+2 19 1 5 1 0
+2 19 -1 0
+1
+ 1 0 -0 -0
+ -0 1 0 -0
+ 0 0 1 -3
+2 18 1 21 1 19 1 5 1 0
+2 5 -1 19 -1 21 -1 18 -1 0
+2 19 -1 21 -1 18 -1 0
+2 18 1 21 1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 26.25
+2 67 -1 0
+2 40 -1 0
+2 5 1 62 1 0
+2 62 -1 5 -1 0
+2 40 1 5 1 0
+2 5 1 46 1 0
+1
+ 1 0 0 -0
+ 0 1 0 306
+ 0 0 1 -0
+2 74 -1 0
+2 52 1 5 1 0
+2 5 -1 19 -1 0
+2 57 1 5 1 0
+2 57 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -100
+2 80 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -100
+2 82 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -100
+2 84 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -1
+2 86 -1 0
+2 62 -1 0
+2 25 1 5 1 0
+2 27 1 25 -1 0
+2 5 -1 25 -1 0
+1
+ 1 0 -0 -0
+ -0 1 0 -0
+ 0 0 1 15
+2 92 -1 0
+2 29 1 25 -1 0
+1
+ 1 0 -0 -0
+ -0 1 0 -0
+ 0 0 1 15
+2 95 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 19
+2 97 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -119
+2 99 -1 97 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 19
+2 101 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -119
+2 103 -1 101 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 26.5
+2 105 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -126.5
+2 107 -1 105 -1 0
+2 3 -1 0
+2 97 1 5 1 0
+2 101 1 5 1 0
+2 105 1 5 1 0
+Curve2ds 594
+1 3.76318199715292 -18.1500000059605 1 0
+1 -3.76318199715292 -9994 1 0
+1 -3.76318199715292 -10000 1 0
+1 22.4000000059605 4979.375 0 1
+1 0.723636005694161 -4979.375 0 1
+1 3.3237620847112 -5000 0 1
+1 8.47363600569416 -5000 0 -1
+1 1.40000000596047 4682.09682806365 0 1
+1 1607.09508945334 -5567.51817005324 0.342020148718266 0.939692618823164
+1 0 3.3237620847112 1 0
+2 11.4736360056942 -9964.75 0 1 -1 0 3
+1 5.15521060181957 4979.375 0 1
+1 5.72363600569416 -4979.375 0 1
+1 -3.76318199715292 -9961.75 1 0
+1 1.5707963267949 5.15521060181957 -1 0
+2 8.72363600569416 -9961.75 0 1 -1 0 3
+1 0.186262914760772 -5029.375 0 -1
+1 15.6307788534706 -5029.375 0 1
+1 -3.76318199715292 -9958.75 1 0
+2 4.47363600569416 -9990 0 1 -1 0 1.5
+1 10.9955742875643 -1.59999999403952 -1 0
+1 0.785309495603109 -14.3300691233623 -0.870022185848612 0.49301257198088
+1 7.74814091910491 -9994 1 0
+1 7.74814091910491 -10000 1 0
+1 4.19683997292571 0 0 -1
+1 3.76318199715292 4.15000000596046 1 0
+1 1.08862548018776 0.501948181293549 0.870022185848612 0.49301257198088
+1 -1.19459508370411 -9994 1 0
+2 12 1 0 -1 -1 -0 3.19999980926514
+1 4.71238898038469 -6 -1 0
+2 4.09999999403954 -2.38919016740822 0 1 -1 0 4
+1 1.5707963267949 -9994 1 0
+1 7.5 -0.750000000000001 1 0
+1 -7.5 -33.584918807682 1 0
+1 0.0999999940395355 -1.19459508370411 0 -1
+2 4.5 -3 0 -1 -1 -0 4
+2 4.09999999403954 -11.6108098325918 0 1 -1 0 4
+1 0.5 -1.5 0 1
+1 -1.5 -6 -1 0
+2 4.5 -11 0 -1 -1 -0 4
+1 10.9955742875643 -6 -1 0
+1 7.5 -13.25 1 0
+2 12 -15 0 -1 -1 -0 3.19999980926514
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+2 -9.75 -13.3561297425939 1 0 -0 1 2
+1 0 0 1 0
+1 0 -3 1 0
+2 -9.75 -3.14387025740611 1 0 -0 1 2
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 -1.19459508370411 -10000 1 0
+1 1.5707963267949 -10000 1 0
+1 -4.71238898038469 0 1 0
+2 13 -15.7321245982865 0 1 -1 0 3
+1 0 0 1 0
+1 0 -38.25 1 0
+1 0 0 1 0
+1 0 -38.25 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -38.25 1 0
+1 0 0 1 0
+1 0 -38.25 1 0
+1 0 0 1 0
+1 0 -38.25 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 -4.15470835064529 0 1 0
+2 13 1.73212459828649 0 1 -1 0 3
+1 0 0 1 0
+1 0 -38.25 1 0
+1 0 0 1 0
+1 0 -38.25 1 0
+1 0 0 1 0
+1 0 -3 1 0
+8 10.5 12
+1 -10.5 -14.6190217703188 1 0
+8 10.5 12
+1 10.5 -22.2373868519837 1 0
+1 1.5707963267949 0 0 1
+1 0 -35.25 1 0
+1 0 0 0 1
+1 0.905886677037226 0 0 -1
+8 1.87760529792955 3.37760529792955
+1 -1.87760529792955 0 1 0
+1 1.87760529792955 -8.5 1 0
+8 -12.5683887767598 2.05063299355898
+1 14.9395778359789 -4.29864219857637 -0.939692618823164 -0.342020148718266
+1 0 -12.5683887767598 0 -1
+1 -8.375 -6.91715553554136 -1 0
+1 10.8841934350268 -8.375 0 1
+3 -1.75 -3.65475544257969 0 -1 1 0 9.3561733753326 3.19999980926514
+7 0 0 8 9 2 3.72021974342313 -21.9549266752044 3.79971932885503 -22.3371674716672 3.87921891328051 -22.7725752874248 3.95871849774085 -23.2574688580644 4.03821808211433 -23.7874500667385 4.11771766659695 -24.357478375081 4.19721725100862 -24.9619695045803 4.27671683544645 -25.594913038131 4.35621642087835 -26.25
+ 0.578627089833329 9 1.21462376728856 9
+1 0 0 0 1
+1 19 -14.8262379212493 0 -1
+8 1.5707963267949 3.14159265358979
+1 -1.5707963267949 0.905886677037226 1 0
+1 0.557680629739399 0 0 1
+1 0 0 0 1
+1 0 -3 1 0
+1 -6.49739470207045 -15 -1 0
+1 13.25 -6.49739470207045 0 1
+1 0.255210595859102 -0.832540596158992 0 1
+1 -1.75 0.832540596158985 0 1
+1 0 0 1 0
+1 0 -2 1 0
+1 0 0 1 0
+1 0 -2 1 0
+1 0 0 1 0
+1 0 -2 1 0
+1 0 1.5707963267949 1 0
+2 13 -15.7321245982865 0.848484848484848 0.529219672623424 0.529219672623424 -0.848484848484848 6
+1 18.9477941176471 -20.8286764705882 -0.843661487732107 -0.536875492193159
+1 -4.80311824265666 -58.75 -1 0
+1 0 4.71238898038469 1 0
+2 27 -7 -0.814814814814815 0.579721327499945 -0.579721327499945 -0.814814814814815 10.5
+1 33.9000000059605 2.07500000298023 0 -1
+1 2.07500000298023 -9961.75 1 0
+2 13 1.73212459828649 0.848484848484849 -0.529219672623423 0.529219672623423 0.848484848484849 6
+1 15.7772058823529 8.84632352941177 -0.843661487732107 0.536875492193159
+1 -8.56124668800877 -58.75 -1 0
+1 0 0 0 1
+1 19 4.25 0 -1
+1 1.5707963267949 0.255210595859102 -1 0
+2 1.25 -1.33491880768202 0 1 -1 0 3
+1 16.25 -12.9947894041409 0 -1
+1 12.9198738646484 -5029.375 0 -1
+1 15.4636363658038 -5029.375 0 1
+1 -4.80311824265666 -100 -1 0
+1 46.146673097643 -79.5350433108733 -0.911929339518646 -0.410347267232384
+1 47.431773398896 -70.8693745234578 -0.764324826145627 -0.644831419936604
+1 15.8571428571429 -49.167459403841 0 -1
+1 9.31314629314664 -49.167459403841 0 1
+1 7.5 -13.25 1 0
+1 -7.5 1.66508119231798 1 0
+1 0 0 0 -1
+1 6.28318530717959 0 0 -1
+1 0 0 1 0
+1 0 -306 1 0
+1 3.14159265358979 0 0 -1
+8 -0.75 0.75
+1 0.75 -14.6190217703188 1 0
+8 -0.75 0.75
+1 0.75 -22.2373868519837 -1 0
+1 0.0999999940395497 4979.375 0 1
+1 0.0999999940395497 -5000 0 1
+1 1.40000000596046 4682.09682806365 0 -1
+1 1607.09508945334 -5567.51817005324 -0.342020148718266 -0.939692618823164
+1 0 0.0999999940395497 1 0
+1 1.5707963267949 0.0999999940395497 -1 0
+1 0.186262914760825 -5029.375 0 1
+1 15.6307788534706 -5029.375 0 -1
+2 4.47363600569416 -9990 0 -1 -1 -0 1.5
+1 -4.71238898038469 -1.59999999403955 1 0
+1 -6 -3.92908543710292 -1 0
+1 2.56296556375646 0 0 1
+1 2.08634533425388 0 0 -1
+1 0 0 1 0
+1 0 -26.25 1 0
+7 0 0 8 9 2 2.56296556375647 -21.9549266752044 2.48346597832456 -22.3371674716672 2.40396639389633 -22.7725752874358 2.32446680944395 -23.2574688580789 2.24496722504955 -23.7874500667094 2.16546764057784 -24.3574783750664 2.08596805616799 -24.9619695045913 2.00646847173313 -25.594913038131 1.92696888630123 -26.25
+ 0.578627089833327 9 1.21462376728856 9
+1 -5.67908543710291 -39.584918807682 0 -1
+1 3.72021974342312 0 0 1
+1 -0.959931047754832 0 1 0
+2 -11.0168330344604 -10.2155164303423 0 1 -1 0 2
+1 -7.5 -10.834918807682 -1 0
+1 7.5 -0.750000000000001 -1 0
+7 0 0 6 17 4 0 0 7.45752792852272e-10 0.0876922460252227 0.000784868160367047 0.175446845327875 0.00235595055044069 0.262264286756365 0.00465689721950913 0.3476484856856 0.00761716015793823 0.43119555692662 0.0151989408657958 0.605834427130195 0.0200022212476583 0.696324213540998 0.0254523298848559 0.783987341397015 0.0314434552436431 0.868876509648608 0.0378817101574853 0.95111011972895 0.0530257866083739 1.12850419162208 0.0619113536922642 1.22240797807263 0.0712287611869389 1.31317142050212 0.0808721834924233 1.40118413710047 0.0907546648548436 1.48687689567825 0.10081605671721 1.5707963267949
+ 0 7 0.282120453711328 5 0.605202594019347 5 1 7
+7 0 0 6 17 4 -7.19281086116926 -11.334918807682 -7.19281086647239 -11.2910726846694 -7.19839187399206 -11.2471949975943 -7.20956541107163 -11.2043951988488 -7.22582699437474 -11.1635221202639 -7.24650276756132 -11.1251672017056 -7.29869914735255 -11.0490709464091 -7.33137864239084 -11.0121990427474 -7.36786236449502 -10.9794705948011 -7.40716846703427 -10.9509588703667 -7.44849329270355 -10.9265441057836 -7.54349764514841 -10.8809531872847 -7.59784365247475 -10.8617179547392 -7.65323436309611 -10.8479297750095 -7.70888917361413 -10.8391443636847 -7.76426998573773 -10.8349188118185 -7.81904867630909 -10.834918807682
+1 0 0 1 0
+1 0 -12.5 1 0
+1 -7.19281086116926 -39.584918807682 0 -1
+1 0.59740641664535 0 0 1
+1 12.8305715742865 7.72024465297414 -0.707106781186548 0.707106781186548
+1 -3.61354682014011 -87.5 -1 0
+1 15.8571428571429 -49.167459403841 0 1
+1 9.31314629314664 -49.167459403841 0 -1
+1 -7.5 -13.334918807682 -1 0
+1 5 -0.832540596158992 0 1
+1 1.5707963267949 5 -1 0
+1 0.0999999940395355 5000 -0 -1
+1 2.61080983259178 -5000 -0 -1
+1 -1.19459508370411 -10003 1 0
+1 1.10000005364417 5000 0 1
+1 6.61080983259178 -5000 0 1
+1 0 0 1 0
+1 0.59740641664535 -28.25 1 0
+1 0 0 0 1
+1 0 -28.25 1 0
+1 0 0 1 0
+1 3.14159265358979 -28.25 1 0
+1 5.68577889053424 0 0 1
+1 -0.959931047754832 1.5 1 0
+1 7.5 -13.25 -1 0
+7 0 0 6 17 4 2.54418623694444 0 2.54418623619869 0.0876922460251412 2.54340136878407 0.175446845327593 2.54183028639402 0.262264286756194 2.53952933972494 0.347648485685083 2.53656907678652 0.431195556926171 2.52898729607868 0.605834427129601 2.52418401569681 0.696324213540455 2.51873390705963 0.783987341396402 2.51274278170084 0.86887650964807 2.506304526787 0.951110119728367 2.49116045033611 1.12850419162165 2.48227488325222 1.22240797807219 2.47295747575752 1.313171420502 2.46331405345205 1.40118413710023 2.4534315720896 1.4868768956782 2.44337018022723 1.5707963267949
+ 0 7 0.28212045371094 5 0.60520259401891 5 1 7
+7 0 0 6 17 4 -7.19281086116926 -11.334918807682 -7.19281086647239 -11.2910726846695 -7.19839187399203 -11.2471949975945 -7.20956541107162 -11.2043951988489 -7.22582699437464 -11.1635221202642 -7.24650276756121 -11.1251672017059 -7.29869914735235 -11.0490709464093 -7.33137864239064 -11.0121990427476 -7.36786236449473 -10.9794705948014 -7.40716846703403 -10.9509588703669 -7.44849329270326 -10.9265441057838 -7.54349764514816 -10.8809531872848 -7.5978436524745 -10.8617179547393 -7.65323436309601 -10.8479297750095 -7.70888917361398 -10.8391443636847 -7.7642699857377 -10.8349188118185 -7.8190486763091 -10.834918807682
+1 -3.61354682014011 -100 -1 0
+1 7.5 -13.25 -1 0
+1 0 0 1 0
+1 0 -26.25 1 0
+1 0 0 1 0
+1 0 -26.25 1 0
+1 -6 -3.92908543710291 -1 0
+1 2.51876606817779 0 0 -1
+1 4.85853535973926 0 0 -1
+1 2.77022531890606 0 0 -1
+1 1.42464994744033 0 0 -1
+1 3.51295998827352 0 0 -1
+1 3.7644192390018 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 3.69927328332919 0 0 -1
+1 0.557680629739399 35.25 -1 0
+1 0 3.14159265358979 1 0
+1 0 0 0 1
+1 2.58391202385039 0 0 -1
+1 0 6.28318530717959 1 0
+1 2.52320601170379 -35.25 1 0
+1 0 -35.25 1 0
+1 2.51787540171351 0 0 -1
+1 0 35.25 1 0
+1 20.25 -6.625 0 1
+1 6.625 -16.75 1 0
+1 1.1760672716254 3.14159265358979 0 1
+1 0 0 0 1
+1 0 0 0 -1
+1 0.060706012146603 3.14159265358979 0 1
+1 0 0 0 1
+1 2.07500000298023 -9958.75 1 0
+1 6.83636364611711 -5029.375 0 1
+1 -1.5707963267949 2.51787540171351 1 0
+1 -8.56124668800877 -100 -1 0
+1 11.0647000619703 -92.1788742148999 -0.911929339518646 0.410347267232384
+1 18.0281543032655 -95.6760755543856 -0.764324826145627 -0.644831419936604
+8 -0.75 0.75
+1 0.75 0 1 0
+8 -0.75 0.75
+1 0.75 -8.5 -1 0
+1 -1.375 -6.91715553554136 -1 0
+1 10.8841934350268 1.375 0 -1
+1 0 0 0 1
+1 0 -3 1 0
+1 2.125 -15 -1 0
+1 13.25 2.125 0 1
+1 16.25 4.25 0 -1
+1 0 0 0 -1
+1 0 0 1 0
+1 0 -306 1 0
+1 20.25 -6.625 0 1
+1 6.625 2.75 1 0
+1 -7.375 -1.5 1 0
+1 2.13225296407472 -7.375 0 -1
+1 0.610865279040064 0 0 1
+1 0.630597622660254 0 0 -1
+1 1.25 0.375 0 -1
+1 1.98316696553956 -0.375000000000001 0 -1
+1 0 0 0 1
+1 14.6870571284314 0 0 -1
+2 4.13225296407472 -15.3805976226603 0 1 -1 0 2
+1 0.0745429992675817 -16 -1 0
+1 -0.0745429992675781 -2.25 -1 0
+2 4.5 -3 1 0 -0 1 3.5
+1 0 0 0 1
+1 8 -6.25 0 1
+1 11.5354707943123 -16 -1 0
+1 11.5354707943123 -6.25 1 0
+2 4.5 -3 0.826797284707685 0.5625 -0.5625 0.826797284707685 3.5
+1 1.25 0.375 0 -1
+1 1 -3 0 -1
+1 11.5354707943123 -7.75 1 0
+2 4.5 -11 -1 0 -0 -1 3.5
+1 0 0 0 1
+1 8 -7.75 0 -1
+2 4.5 -11 1 0 0 -1 3.5
+1 1.25 0.375 0 -1
+1 -0.0745429992675781 -11.75 -1 0
+1 2.22908628561616 -1.5 1 0
+1 9.63954785932797 -4.02847269130262 -0.573576469806894 -0.819152020862954
+1 2.53072737454973 0 0 -1
+8 0 1.5707963267949
+1 2.54418623694444 0 0 1
+1 0 0 1 0
+1 1.5707963267949 0 0 -1
+1 4.71238898038469 -1.5 -1 0
+2 15.1490859985352 -5.16508119231798 0 -1 -1 -0 5.16508119231798
+1 0 0 1 0
+1 0 -100 1 0
+2 6.88573503494262 -6.25 0 -1 1 0 4
+1 -1.5707963267949 -100 1 0
+1 5 -4.88880294945254 0 -1
+1 -4.88880294945254 -100 1 0
+1 5.14446404910223 -4.4663852153232 0.450893288729739 -0.892577863370183
+1 -6.30620088633297 -100 1 0
+1 2.5 -11 1 0
+1 -2.5 -100 1 0
+1 0 0 1 0
+1 0 -100 1 0
+1 0 0 1 0
+1 0 -100 1 0
+1 0 0 1 0
+1 0 -1 1 0
+1 0 8 1 0
+1 0 0 0 1
+1 -7.375 -11 1 0
+1 0.630597622660254 -11 0 -1
+1 0 0 0 1
+1 14.6870571284314 -11 0 -1
+1 2.22908628561616 -11 1 0
+1 4.71238898038469 -11 -1 0
+2 27 -7 0 1 -1 0 15
+1 1.5707963267949 -16 1 0
+1 4.875 -2 1 0
+1 -4.875 -16 1 0
+1 4.875 -6.5 1 0
+1 -4.875 -16 1 0
+1 9.75 -0.999999999999999 0 -1
+1 -1 -16 1 0
+1 4.71238898038469 -16 -1 0
+1 4.875 -7.5 1 0
+1 -4.875 -16 1 0
+1 4.875 -12 1 0
+1 -4.875 -16 1 0
+1 9.75 -6 0 1
+1 6 -16 1 0
+1 1.5 -1.5 0 -1
+1 -1.5 -23.5 1 0
+2 4.5 -3 0 1 -1 0 3
+1 -4.71238898038469 -23.5 1 0
+1 0.75 -6.5 1 0
+1 -0.75 -23.5 1 0
+1 7.5 -1.5 0 -1
+1 -1.5 -23.5 1 0
+1 3 -3.25 0 -1
+1 -3.25 -23.5 1 0
+1 3 -6.5 1 0
+1 -3 -23.5 1 0
+1 0.75 -7.5 1 0
+1 -0.75 -23.5 1 0
+1 6 -3.25 0 -1
+1 -3.25 -23.5 1 0
+1 1.5 -3.75 0 -1
+1 -3.75 -23.5 1 0
+1 3 -7.5 1 0
+1 -3 -23.5 1 0
+2 4.5 -11 0 1 -1 0 3
+1 1.5707963267949 -23.5 1 0
+1 7.5 -3.75 0 -1
+1 -3.75 -23.5 1 0
+1 0 0 1 0
+1 0 -15 1 0
+1 0 0 1 0
+1 0 -15 1 0
+7 0 0 7 20 4 0.215960498684955 4.71238898038469 0.213748143222487 4.78298049630045 0.211566063409149 4.85430744003296 0.20942333109009 4.92664193581628 0.207330699812392 5.000220015995 0.205300288595374 5.07526182445167 0.203345555035751 5.15200531015008 0.199853562807506 5.29953114464843 0.198295834602881 5.3697939091339 0.196817965673124 5.4417543288093 0.19543297349198 5.51556461112551 0.194156371504826 5.59134033655351 0.193005497525073 5.6691710651891 0.191091160118289 5.82124305135541 0.190300186173132 5.89514030604873 0.189642579477121 5.970669139312 0.189134340048525 6.04761759138473 0.18878892213815 6.12568559703784 0.188616386363251 6.20445864624387 0.188616386175404 6.28318530717959
+ 0 8 0.375751664485204 6 0.703929077829973 6 1 8
+7 0 0 7 20 4 8.06778458132949 -16 8.10391972158124 -16.0000000035261 8.14041064846906 -16.002906900046 8.17710382116986 -16.0088293975073 8.21379652176416 -16.0179108178389 8.25023257410755 -16.0303068852857 8.28609617290914 -16.0461763789719 8.35149178461846 -16.0827229609757 8.38123088493269 -16.1025260139299 8.40997242130566 -16.1252013402722 8.43738351203788 -16.1508379440354 8.46305299712865 -16.1794756064938 8.48650728795085 -16.2110738657428 8.52593708111617 -16.2765213645573 8.54243267138473 -16.3098693127902 8.55629450522448 -16.3453372819275 8.56709461632846 -16.3826148844141 8.57446366661435 -16.4212500884914 8.57814440590318 -16.4606366695321 8.57814440991059 -16.5
+1 8.57814440991059 -44.75 0 -1
+1 0.188616386175404 0 0 1
+1 8.57454299926758 -24.75 -1 0
+1 -8.57454299926758 4.75 -1 0
+1 2.81937942159155 0 0 1
+1 12.921032723403 -3.5 0 1
+1 -0.0745429992675781 -2.25 1 0
+1 0.0745429992675817 -3.5 1 0
+7 0 0 6 17 4 0.0889246303241094 0 0.0889246297363653 0.0880258282933077 0.088303707770331 0.176117381227634 0.0870607005844281 0.263357367673046 0.0852311373392386 0.349267812289181 0.0828586223129425 0.433436568872972 0.0767409135901781 0.609228591089449 0.0728461448632931 0.700279778170543 0.0683919809285719 0.788474593822318 0.0634519171217931 0.873807429136138 0.058094829303565 0.956343663982428 0.0454002285604779 1.13374341197176 0.0378906053925959 1.22728656377513 0.0299362642905601 1.31738156803778 0.0216192025246711 1.40438035853218 0.0130111639216716 1.48868389812379 0.00416273669359097 1.5707963267949
+ 0 7 0.282973705255243 5 0.606133423193939 5 1 7
+7 0 0 6 17 4 12.921032723403 -6.50000000000001 12.9210327512435 -6.23592251512009 12.95044308195 -5.97164573624344 13.0093314780399 -5.71361996515427 13.0951471865865 -5.46693264648641 13.2043211134318 -5.2352865367393 13.4792392740142 -4.77644626006933 13.6509253625217 -4.55437937552539 13.8421314340277 -4.35756168398912 14.0472631241037 -4.18655358784071 14.2617388422194 -4.0406158492025 14.7508499076927 -3.76950797037203 15.0281988826172 -3.65596915974776 15.3082779297531 -3.57524500193916 15.5867944618701 -3.52427339193991 15.86097050799 -3.50000002435097 16.1292175782681 -3.50000000000001
+1 0 3.25 1 0
+1 0 4.71238898038469 0 1
+1 0 -28.25 1 0
+1 -3.14159265358979 0 1 0
+2 15.0709415886246 -16.5 0 -1 1 0 0.5
+1 3.25 -28.25 -1 0
+1 -7.375 -5.5 -1 0
+1 21.087774623085 -7.375 0 1
+2 19.087774623085 -15.3805976226603 0 1 1 -0 2
+1 -4.43014444051471 -5.5 -1 0
+1 9.76090167630801 1.42644961540016 -0.573576469806894 0.819152020862954
+1 4.71238898038469 -5.5 -1 0
+2 8.07094158862457 -5.16508119231798 0 -1 1 0 5.16508119231798
+1 14.5709415886246 -22.375 0 -1
+1 3.25 -22.375 0 1
+1 3.03547079431229 -24.75 -1 0
+1 3.03547079431229 0.749999999999999 1 0
+1 0.188616386175404 0 0 -1
+1 3.09157179678402 0 0 1
+1 11.0521798552032 -3.5 0 1
+1 11.5354707943123 -6.25 -1 0
+1 11.5354707943123 -3.5 1 0
+7 0 0 6 17 4 0.361117005516578 0 0.361117005429118 0.0873501447285746 0.361025323548147 0.174752593939668 0.360841800951428 0.261596490716586 0.360569917377859 0.347544990855572 0.360214030581252 0.432291621692011 0.35930375244666 0.607235457754617 0.358732449290066 0.697165865700044 0.358074998100984 0.785065810010474 0.357339840666363 0.870880104030936 0.356535469345667 0.954598943573836 0.354661861338892 1.13142214051863 0.353571080347366 1.22379130922928 0.352408529942576 1.31365707670418 0.351185128560088 1.40124795750247 0.349911590643972 1.4868334270693 0.348597100525857 1.5707963267949
+ 0 7 0.295412758008581 5 0.621027117059385 5 1 7
+7 0 0 6 17 4 11.0521798552032 -6.50000000000001 11.0521798289653 -6.23794956581428 11.0246760872175 -5.97574064978529 10.9696149726439 -5.71881604529252 10.8888189188736 -5.47176527211256 10.7850398413599 -5.23827444971187 10.5259677097396 -4.78164920580072 10.3663977276645 -4.56185120199876 10.1874443020354 -4.3648165965144 9.99378954161121 -4.19190239103313 9.78960301685674 -4.04327830835216 9.33241327780119 -3.77305992431972 9.07695650064042 -3.65992479093329 8.81713454586854 -3.5779771874999 8.55709734865854 -3.52537899098525 8.29986327092227 -3.50000002518271 8.04748115562806 -3.50000000000001
+1 -7.375 -7 -1 0
+1 0.630597622660254 -5.5 0 -1
+1 -4.43014444051471 -7 -1 0
+1 0 0 1 0
+2 15.0709415886246 -16.5 0 1 -1 0 0.5
+1 4.71238898038469 -7 -1 0
+1 4.75 -22.375 0 1
+1 3.03547079431229 -0.750000000000001 1 0
+1 3.19161351039556 0 0 1
+1 11.5354707943123 -7.75 -1 0
+7 0 0 6 17 4 0.461158719128118 0 0.461158719215578 0.0873501447286339 0.461250401096549 0.174752593939748 0.461433923693268 0.261596490716751 0.461705807266838 0.347544990855764 0.462061694063445 0.432291621692251 0.462971972198037 0.607235457754865 0.463543275354633 0.697165865700438 0.464200726543714 0.785065810010624 0.464935883978336 0.870880104031301 0.465740255299031 0.954598943574099 0.467613863305807 1.13142214051888 0.468704644297332 1.2237913092294 0.469867194702122 1.3136570767044 0.471090596084609 1.40124795750249 0.472364134000725 1.48683342706936 0.473678624118839 1.5707963267949
+ 0 7 0.295412758008839 5 0.621027117059642 5 1 7
+7 0 0 6 17 4 11.0521798552032 -6.50000000000001 11.0521798289653 -6.23794956581411 11.0246760872175 -5.97574064978505 10.9696149726438 -5.71881604529204 10.8888189188734 -5.47176527211202 10.7850398413596 -5.23827444971121 10.5259677097392 -4.78164920580011 10.3663977276638 -4.56185120199783 10.187444302035 -4.36481659651413 9.99378954161039 -4.19190239103238 9.7896030168561 -4.04327830835172 9.33241327780051 -3.77305992431943 9.07695650064007 -3.65992479093313 8.81713454586792 -3.57797718749985 8.55709734865844 -3.5253789909852 8.2998632709221 -3.50000002518271 8.04748115562806 -3.50000000000001
+1 4.75 -28.25 1 0
+1 0 3.25 1 0
+1 6.28318530717959 -28.25 -1 0
+7 0 0 7 20 4 0.215960498684956 4.71238898038469 0.213748143222487 4.78298049630046 0.21156606340915 4.85430744003299 0.209423331090087 4.92664193581628 0.20733069981239 5.00022001599499 0.205300288595376 5.0752618244517 0.203345555035749 5.1520053101501 0.199853562807507 5.29953114464842 0.198295834602882 5.36979390913397 0.196817965673125 5.44175432880929 0.19543297349198 5.51556461112549 0.194156371504824 5.59134033655357 0.193005497525071 5.66917106518908 0.191091160118289 5.82124305135541 0.190300186173129 5.89514030604873 0.189642579477129 5.97066913931207 0.189134340048514 6.04761759138463 0.188788922138157 6.12568559703789 0.18861638636325 6.20445864624387 0.188616386175403 6.28318530717959
+ 0 8 0.375751664485214 6 0.703929077830005 6 1 8
+7 0 0 7 20 4 8.06778458132949 -16 8.10391972158125 -16.0000000035261 8.14041064846908 -16.002906900046 8.17710382116986 -16.0088293975073 8.21379652176416 -16.0179108178389 8.25023257410755 -16.0303068852857 8.28609617290915 -16.0461763789719 8.35149178461846 -16.0827229609757 8.38123088493272 -16.1025260139299 8.40997242130567 -16.1252013402722 8.43738351203787 -16.1508379440354 8.46305299712867 -16.1794756064938 8.48650728795085 -16.2110738657428 8.52593708111617 -16.2765213645573 8.54243267138475 -16.3098693127901 8.55629450522443 -16.3453372819275 8.56709461632852 -16.382614884414 8.57446366661433 -16.4212500884914 8.57814440590318 -16.4606366695321 8.57814440991059 -16.5
+1 6.09456892100418 0 0 1
+1 -8.57454299926758 -4.75 -1 0
+1 3.46380588558803 0 0 1
+1 -0.0745429992675781 -11.75 1 0
+7 0 0 6 17 4 0.733351094320587 0 0.733351094908331 0.0880258282933274 0.733972016874365 0.176117381227695 0.735215024060268 0.263357367673104 0.73704458730546 0.349267812289285 0.739417102331757 0.433436568873086 0.745534811054524 0.609228591089603 0.749429579781407 0.700279778170635 0.753883743716135 0.788474593822512 0.758823807522908 0.873807429136238 0.764180895341141 0.956343663982577 0.776875496084228 1.13374341197189 0.784385119252104 1.22728656377514 0.792339460354145 1.31738156803796 0.800656522120026 1.40438035853215 0.809264560723027 1.48868389812382 0.818112987951105 1.5707963267949
+ 0 7 0.282973705255253 5 0.606133423193934 5 1 7
+7 0 0 6 17 4 12.921032723403 -6.50000000000001 12.9210327512435 -6.23592251512002 12.95044308195 -5.97164573624324 13.00933147804 -5.71361996515414 13.0951471865865 -5.46693264648609 13.204321113432 -5.23528653673899 13.4792392740145 -4.77644626006895 13.6509253625219 -4.55437937552516 13.8421314340281 -4.35756168398872 14.047263124104 -4.18655358784052 14.2617388422198 -4.04061584920225 14.7508499076931 -3.76950797037187 15.0281988826173 -3.65596915974783 15.3082779297534 -3.57524500193892 15.5867944618701 -3.52427339194001 15.8609705079901 -3.50000002435097 16.1292175782681 -3.50000000000001
+1 12.720379992278 -2.25 1 0
+1 -12.720379992278 -3.5 1 0
+1 28.8857350349426 -1.125 0 -1
+1 -1.125 -3.5 1 0
+1 2.06171215809096 0 0 -1
+1 1.29164683019059 0 0 -1
+2 27 -7 0 1 -1 0 4
+1 7.85398163397448 -3.5 -1 0
+1 22.6304253436608 3.3132730666547 -0.450893288729739 0.892577863370183
+1 7.2465527139594 -3.5 1 0
+1 4.22147314908862 0 0 -1
+2 27 -7 0 -1 -1 -0 4
+1 -1.5707963267949 -96.5 1 0
+1 4.991538476989 0 0 -1
+1 28.8857350349426 -5.26380294945254 0 1
+1 -5.26380294945254 -96.5 -1 0
+1 25.4476269214972 -11.7364063714053 0.450893288729739 0.892577863370183
+1 0.998507670368117 -96.5 -1 0
+1 14.4428675174713 -11.75 1 0
+1 14.4428675174713 -96.5 -1 0
+1 0.914414057839782 0 0 -1
+1 24.1087601264419 -11.0600664383107 -0.450893288729739 -0.892577863370183
+1 0.998507670368117 -3.5 1 0
+2 27 -7 0 1 -1 0 4
+1 -1.5707963267949 -3.5 1 0
+1 21.2915585486055 2.6369331335601 -0.450893288729739 0.892577863370183
+2 27 -7 0 1 -1 0 4
+1 1.5707963267949 -3.5 -1 0
+1 0 0 0 -1
+1 2.80175574413567 0 0 -1
+1 0 0 1 0
+1 0 -119 1 0
+1 3.10825314432849 0 0 -1
+1 0 0 1 0
+1 0 -119 1 0
+1 0 0 0 -1
+1 0 0 1 0
+1 0 -126.5 1 0
+1 0 0 1 0
+1 0 -126.5 1 0
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 4.71238898038469 -20 -1 0
+2 -12.5 4 0 -1 -1 -0 4
+1 1.5707963267949 -21.25 1 0
+2 10 8.88178419700125e-16 0 1 -1 0 15
+1 2 -20 1 0
+1 -8.5 2 0 -1
+1 0 0 1 0
+1 2.73045479126745 -3 1 0
+2 27 -7 -0.916666666666667 0.399652626942727 -0.399652626942727 -0.916666666666667 12
+1 0 0 0 1
+1 14.6870571284314 -5.5 0 -1
+1 2 -20 1 0
+1 -8.5 2 0 -1
+1 10.9955742875643 -20 -1 0
+2 -12.5 -4 0 -1 -1 -0 4
+Curves 370
+1 19.4736360056942 11.1500000059605 10019 0 0 -1
+1 23.2368180028471 11.1500000059605 25 -1 0 0
+1 23.2368180028471 11.1500000059605 19 -1 0 0
+1 18.75 11.1500000059605 5039.625 0 0 1
+1 11 11.1500000059605 5019 0 0 -1
+1 -1587.62145344765 11.1500000059605 4451.48182994676 -0.342020148718266 0 0.939692618823164
+2 8 11.1500000059605 54.25 0 1 0 0 -0 1 1 0 -0 3
+1 13.75 11.1500000059605 5039.625 0 0 1
+1 23.2368180028471 11.1500000059605 57.25 -1 0 0
+8 -3.5527136788005e-15 1.5707963267949
+2 10.75 11.1500000059605 57.25 0 1 0 0 -0 1 1 0 -0 3
+1 3.84285715222361 11.1500000059605 4989.625 -0 0 1
+1 23.2368180028471 11.1500000059605 60.25 -1 0 0
+8 4.71238898038469 10.9955742875643
+2 15 11.1500000059605 29 -0 1 -0 0 0 1 1 0 -0 1.5
+1 26.2146905043969 7.33006912336227 25 0.870022185848612 -0.49301257198088 0
+1 26.2146905043969 7.33006912336227 19 0.870022185848612 -0.49301257198088 0
+1 24.872050254443 8.09089850638447 10019 0 0 -1
+1 13.75 -11.25 23 0 1 0
+1 23.2368180028471 -11.1500000059605 25 -1 0 0
+1 13.75 -9.74999999999999 23 1 0 0
+1 25.9113745198122 -7.50194818129354 25 -0.870022185848612 -0.49301257198088 0
+8 0.992169236961567 2.14942341662822
+2 15 -7.99999999999999 23 0 0 -1 0 1 0 1 -0 0 3.19999980926514
+8 0.515549007458979 1.5707963267949
+2 22.9000000059605 -4.61080983259177 25 0 0 1 0 -1 0 1 0 -0 4
+1 19.5 -6.24999999999999 23 -1 0 0
+1 26.9000000059605 -5.80540491629588 25 0 1 0
+8 1.5707963267949 4.11498256373934
+2 22.5 -3.99999999999999 23 0 0 -1 0 1 0 1 -0 0 4
+8 1.5707963267949 2.62604364613081
+2 22.9000000059605 4.6108098325918 25 0 0 1 0 -1 0 1 0 -0 4
+1 26.5 -5.49999999999999 23 0 -1 0
+8 5.30979539703004 7.85398163397448
+2 22.5 4.00000000000001 23 0 0 -1 0 1 0 1 -0 0 4
+1 19.5 6.25000000000001 23 -1 0 0
+1 13.75 11.25 23 0 -1 0
+8 0.992169236961567 2.14942341662823
+2 15 8.00000000000001 23 0 0 -1 0 1 0 1 -0 0 3.19999980926514
+1 13.75 9.75000000000001 23 1 0 0
+2 14 -8.24999999999999 17 0 0 1 -1 0 0 0 -1 0 3
+2 0 1.24344978758018e-14 17 0 0 1 -1 0 0 0 -1 0 14.5553271261858
+2 14 8.25000000000001 17 0 0 1 -1 0 0 0 -1 0 3
+1 10 10 17 -1 0 0
+1 18.8837342850239 10.1624722676892 17 0.870022185848612 -0.49301257198088 0
+2 23.75 5.10612974259391 17 0 0 1 -1 0 0 0 -1 0 2
+1 25.75 0 17 0 1 0
+2 23.75 -5.10612974259387 17 0 0 1 -1 0 0 0 -1 0 2
+1 26.3837342850239 -5.91247226768922 17 -0.870022185848612 -0.49301257198088 0
+1 10 -9.99999999999999 17 -1 0 0
+2 14 -8.24999999999999 17 0 0 1 -1 0 0 0 -1 0 2.25
+2 14 8.25000000000001 17 0 0 -1 -1 0 0 0 1 0 2.25
+1 25.9390125274658 2.00000000000001 17 1 0 0
+1 26.9000000059605 -5.80540491629588 19 0 1 0
+1 25.7999999523163 -2.40538358688354 17 0 1 0
+2 22.9000000059605 4.6108098325918 19 0 0 1 0 -1 0 1 0 -0 4
+1 27 -1.99999999999999 17 -1 0 0
+2 22.9000000059605 -4.61080983259177 19 0 0 1 0 -1 0 1 0 -0 4
+1 11 0 17 0 1 0
+1 25.9113745198122 -7.50194818129354 19 -0.870022185848612 -0.49301257198088 0
+8 4.71238898038469 5.27006961012409
+2 14 8.7321245982865 17 0 0 1 0 -1 0 1 0 -0 3
+1 23.2368180028471 -11.1500000059605 19 -1 0 0
+2 0 1.24344978758018e-14 17 0 0 1 -1 0 0 0 -1 0 13.5
+1 11 0 17 0 1 0
+8 4.15470835064529 4.71238898038469
+2 14 -8.73212459828648 17 0 0 1 0 -1 0 1 0 -0 3
+1 18.75 -0.749999999999986 36.0126131480163 0 1 0
+1 13.75 9.75000000000001 23 0 0 1
+1 11 7.82623792124928 52.25 0 1 0
+1 11 8.7321245982865 17 0 0 1
+1 13.75 7.87239470207046 49.75 0 1 0
+1 18.0486421985764 9.75000000000001 37.9395778359789 0.342020148718266 0 -0.939692618823164
+1 16.1158065649732 1.37500000000001 43.25 0 -1 0
+8 0.578627089833329 1.21462376728856
+3 15 8.00000000000001 46.3156532870041 0.939692618823164 0 0.342020148718266 0.342020148718266 0 -0.939692618823164 -0 1 0 9.3561733753326 3.19999980926514
+1 8 7.82623792124928 55.25 0 1 0
+2 8 8.7321245982865 52.25 -4.9960036108132e-16 1 0 -1 -4.9960036108132e-16 0 0 0 1 3
+1 13.75 5.99478940414091 55.25 0 1 0
+1 13.75 -0.502605297929537 43.25 0 -1 0
+1 13.75 6.25000000000001 57.417459403841 0 0 1
+2 0 1.24344978758018e-14 55.25 0 0 1 -1 0 0 0 -1 0 1.5
+2 14 8.7321245982865 55.25 0 0 -1 -0.848484848484848 -0.529219672623424 -0 -0.529219672623424 0.848484848484848 0 6
+1 8.05220588235294 13.8286764705882 17 0.843661487732107 0.536875492193159 0
+2 0 1.24344978758018e-14 55.25 0 0 1 0.814814814814815 -0.579721327499945 0 0.579721327499945 0.814814814814815 -0 10.5
+1 -6.90000000596046 -9.07500000298022 57.25 0 1 0
+2 14 -8.73212459828648 55.25 0 0 1 -0.848484848484849 0.529219672623424 0 -0.529219672623424 -0.848484848484849 0 6
+1 11.2227941176471 -15.8463235294118 17 0.843661487732107 -0.536875492193159 0
+1 8 -11.25 55.25 0 1 0
+1 23.2368180028471 -11.1500000059605 57.25 -1 0 0
+2 10.75 6.25000000000001 55.25 0 1 0 0 -0 1 1 0 -0 3
+1 10.75 5.99478940414091 58.25 0 1 0
+1 -6.90000000596047 4.31363635984334 4989.625 -0 0 1
+1 8.05220588235294 13.8286764705882 58.25 0.843661487732107 0.536875492193159 0
+1 -36.0163605114848 -14.2149566891267 29.1193745234578 0.644831419936604 0.410347267232384 0.644831419936604
+1 -3.85714285714286 6.25000000000001 7.41745940384101 0 0 -1
+1 19.5 6.25000000000001 58.25 -1 0 0
+1 13.5 12.75 29 -0 -1 -0
+2 15 12.75 29 0 -1 0 -1 -0 -0 -0 -0 -1 1.5
+1 26.8999999259605 4.6108098325918 10019 0 0 -1
+1 18.75 -10.5 36.0126131480163 0 -1 0
+1 18.75 -11.1500000059605 5039.625 0 0 1
+1 13.75 -9.74999999999999 23 0 0 1
+1 19.4736360056942 -11.1500000059605 10019 0 0 -1
+1 11 -11.1500000059605 5019 0 0 -1
+1 -1587.62145344765 -11.1500000059605 4451.48182994676 0.342020148718266 0 -0.939692618823164
+2 8 -11.1500000059605 54.25 0 1 0 0 -0 1 1 0 -0 3
+1 13.75 -11.1500000059605 5039.625 0 0 1
+2 10.75 -11.1500000059605 57.25 0 1 0 0 -0 1 1 0 -0 3
+1 3.84285715222356 -11.1500000059605 4989.625 -0 0 -1
+1 23.2368180028471 -11.1500000059605 60.25 -1 0 0
+2 15 -11.1500000059605 29 -0 -1 -0 0 0 -1 1 -0 0 1.5
+1 17.6790854371029 -9.74999999999999 17 0 0 -1
+1 18.0486421985764 -9.74999999999999 37.9395778359789 0.342020148718266 0 -0.939692618823164
+1 24.872050254443 -8.09089850638444 10019 0 0 -1
+2 15 -7.99999999999999 17 0 0 1 -1 0 0 0 -1 0 3.19999980926514
+8 0.578627089833327 1.21462376728856
+3 15 -7.99999999999999 46.3156532870041 -0.939692618823164 0 -0.342020148718266 0.342020148718266 0 -0.939692618823164 0 -1 -0 9.3561733753326 3.19999980926514
+1 17.6790854371029 -6.24999999999999 17 0 0 -1
+1 26.8999999259605 -4.61080983259177 10019 0 0 -1
+1 25.0168330344604 1.4210854715202e-14 42.822617770164 0 0 -1
+8 0.959931047754832 1.5707963267949
+2 23.0168330344604 -6.24999999999999 48.3694023773397 0 1 0 0 -0 1 1 0 -0 2
+1 19.5 -6.24999999999999 45.75 1 0 0
+1 14.0008172030213 1.4210854715202e-14 62.7324996843398 0.573576469806894 0 -0.819152020862954
+8 0 1
+7 0 0 6 17 4 19.1928108611693 -6.24999999999999 45.25 19.1928108664724 -6.24999999999999 45.2938461230126 19.1983918739921 -6.24999999999999 45.3377238100877 19.2095654110716 -6.24999999999999 45.3805236088332 19.2258269943747 -6.24999999999999 45.4213966874181 19.2465027675613 -6.24999999999999 45.4597516059764 19.2986991473526 -6.24999999999999 45.5358478612729 19.3313786423908 -6.24999999999999 45.5727197649346 19.367862364495 -6.24999999999999 45.6054482128809 19.4071684670343 -6.24999999999999 45.6339599373153 19.4484932927036 -6.24999999999999 45.6583747018984 19.5434976451484 -6.24999999999999 45.7039656203973 19.5978436524747 -6.24999999999999 45.7232008529428 19.6532343630961 -6.24999999999999 45.7369890326725 19.7088891736141 -6.24999999999999 45.7457744439973 19.7642699857377 -6.24999999999999 45.7499999958635 19.8190486763091 -6.24999999999999 45.75
+2 12 1.4210854715202e-14 56.584918807682 0 1 0 -1 0 0 0 -0 1 5.16508119231798
+1 19.1928108611693 -6.24999999999999 17 0 0 -1
+1 -6.88573503494262 1.4210854715202e-14 61.75 1 0 0
+1 -0.830571574286463 -6.24999999999998 64.3051634606562 0.707106781186548 0 0.707106781186548
+1 -3.85714285714286 -6.24999999999999 7.41745940384101 0 0 1
+1 19.5 -6.24999999999999 43.25 1 0 0
+1 19.5 -6.24999999999999 58.25 -1 0 0
+1 13.75 -6.24999999999999 57.417459403841 0 0 1
+2 10.75 -6.24999999999999 55.25 0 1 0 0 -0 1 1 0 -0 3
+1 26.9000000059605 -1.99999999999999 5019 0 -0 -1
+1 26.9000000059605 -5.80540491629588 16 0 1 0
+1 26.9000000059605 2.00000000000001 5019 -0 0 1
+1 26.5 -3.99999999999999 17 0 0 1
+2 22.5 -3.99999999999999 45.25 0 0 1 -0.826797284707685 -0.5625 0 0.5625 -0.826797284707685 0 4
+1 26.5 -3.99999999999999 45.25 0 1 0
+1 26.5 4.00000000000001 17 0 0 1
+2 22.5 4.00000000000001 45.25 0 0 1 1 0 -0 -0 1 0 4
+1 19.1928108611693 6.25000000000001 17 0 0 -1
+2 23.0168330344604 6.25000000000001 48.3694023773397 0 1 0 0 -0 1 1 0 -0 2
+1 19.5 6.25000000000001 45.75 1 0 0
+8 0 1
+7 0 0 6 17 4 19.1928108611693 6.25000000000001 45.25 19.1928108664724 6.25000000000001 45.2938461230126 19.198391873992 6.25000000000001 45.3377238100875 19.2095654110716 6.25000000000001 45.3805236088331 19.2258269943746 6.25000000000001 45.4213966874179 19.2465027675612 6.25000000000001 45.4597516059762 19.2986991473523 6.25000000000001 45.5358478612727 19.3313786423906 6.25000000000001 45.5727197649344 19.3678623644947 6.25000000000001 45.6054482128807 19.407168467034 6.25000000000001 45.6339599373151 19.4484932927033 6.25000000000001 45.6583747018982 19.5434976451482 6.25000000000001 45.7039656203972 19.5978436524745 6.25000000000001 45.7232008529427 19.653234363096 6.25000000000001 45.7369890326726 19.708889173614 6.25000000000001 45.7457744439973 19.7642699857377 6.25000000000001 45.7499999958635 19.8190486763091 6.25000000000001 45.75
+1 -0.830571574286463 6.25000000000003 64.3051634606562 0.707106781186548 0 0.707106781186548
+1 17.6790854371029 6.25000000000001 17 0 0 -1
+1 19.5 6.25000000000001 43.25 1 0 0
+2 15 8.00000000000001 17 0 0 1 -1 0 0 0 -1 0 3.19999980926514
+1 17.6790854371029 9.75000000000001 17 0 0 -1
+1 16.4366985862022 -9.99999999999999 17 0 0 1
+1 13.5631199490234 -5.28198116228033 17 0 0 1
+1 13.5631199490234 5.28198116228036 17 0 0 1
+1 16.4366985862022 10 17 0 0 1
+1 19.1704500515343 10 17 0 0 1
+1 24.7360251439618 6.84617411429113 17 0 0 1
+1 25.75 5.10612974259391 17 0 0 1
+1 25.75 -5.10612974259387 17 0 0 1
+1 24.7360251439618 -6.8461741142911 17 0 0 1
+1 19.1704500515343 -9.99999999999999 17 0 0 1
+1 11.75 -8.24999999999999 17 0 0 1
+1 11.75 8.25000000000001 17 0 0 1
+1 25.7999999523163 2.00000000000001 19 -0 -0 -1
+1 25.7999999523163 -1.99999999999999 19 -0 -0 -1
+1 11.4545454545455 7.14446558041623 17 0 0 1
+2 14 8.7321245982865 52.25 0 0 -1 -0.848484848484848 -0.529219672623424 -0 -0.529219672623424 0.848484848484848 0 3
+1 11.4545454545455 -7.14446558041621 17 0 0 1
+2 0 1.24344978758018e-14 52.25 0 0 1 0.814814814814815 -0.579721327499945 0 0.579721327499945 0.814814814814815 -0 13.5
+1 11 -11.25 52.25 0 1 0
+1 11 -8.73212459828648 17 0 0 1
+2 14 -8.73212459828648 52.25 0 0 1 -0.848484848484849 0.529219672623424 0 -0.529219672623424 -0.848484848484849 0 3
+1 20.375 9.75000000000001 43.25 -1 0 0
+2 8.90909090909091 5.55680656254596 52.25 -0.529219672623424 0.848484848484848 0 -0.848484848484848 -0.529219672623424 0 0 0 1 3
+1 -1.5 1.24344978758018e-14 57.25 0 0 1
+2 8.90909090909091 -5.55680656254594 52.25 0.529219672623424 0.848484848484849 0 -0.848484848484849 0.529219672623424 0 0 -0 1 3
+1 -6.90000000596046 -9.07500000298022 60.25 0 1 0
+1 -6.90000000596047 -4.31363635984334 4989.625 -0 0 1
+2 8 -8.73212459828648 52.25 0 1 0 -1 0 0 0 -0 1 3
+1 11.2227941176471 -15.8463235294118 58.25 0.843661487732107 -0.536875492193159 0
+1 -11.209659480557 -1.57112578510008 53.9260755543856 0.644831419936604 -0.410347267232384 0.644831419936604
+1 -6.88573503494262 -93.75 58.25 0 1 0
+1 -3.38573503494262 -93.75 61.75 0 1 0
+1 13.75 -10.5 49.75 0 -1 0
+1 16.1158065649732 -8.37499999999999 43.25 0 1 0
+1 13.75 -11.25 55.25 0 1 0
+1 13.75 -9.12499999999999 43.25 0 -1 0
+1 10.75 -11.25 58.25 0 1 0
+1 13.5 -12.75 29 -0 1 -0
+2 15 -12.75 29 -0 -1 -0 -1 0 0 0 0 -1 1.5
+1 20.375 -9.74999999999999 43.25 -1 0 0
+1 25.0168330344604 -4.74999999999999 54.375 0 0 -1
+1 25.0168330344604 -6.24999999999999 48.3694023773397 0 1 0
+1 25.0168330344604 -6.62499999999999 45.75 0 1 0
+1 24.6551370761863 -6.24999999999999 49.5165553169535 0 1 0
+2 23.0168330344604 -4.74999999999999 48.3694023773397 0 1 0 0 -0 1 1 0 -0 2
+1 27.0745429992676 -4.74999999999999 45.75 1 0 0
+2 22.5 -3.99999999999999 45.75 0 0 1 -1 0 0 0 -1 0 3.5
+1 19 -0.749999999999986 45.75 0 -1 0
+1 15.4645292056877 -0.749999999999986 45.75 -1 0 0
+2 22.5 -3.99999999999999 45.75 0 0 1 -0.826797284707685 -0.5625 0 0.5625 -0.826797284707685 0 3.5
+1 26 -3.99999999999999 45.75 0 1 0
+1 15.4645292056877 0.750000000000014 45.75 -1 0 0
+2 22.5 4.00000000000001 45.75 0 0 1 1 0 -0 -0 1 0 3.5
+1 19 0.750000000000014 45.75 0 1 0
+2 22.5 4.00000000000001 45.75 0 0 -1 -1 0 0 0 1 0 3.5
+1 27.0745429992676 4.75000000000001 45.75 1 0 0
+1 17.5095381392072 -4.74999999999999 57.7215273086974 0.573576469806894 0 -0.819152020862954
+1 16.2309866966085 -6.24999999999999 59.5474878442378 0 1 0
+2 26 -3.99999999999999 45.25 0 -1 0 1 0 0 -0 0 1 0.5
+1 12 -6.24999999999999 61.75 0 1 0
+8 2.18166160583496 3.14159265358979
+2 12 -4.74999999999999 56.584918807682 0 -1 0 0 0 -1 1 0 0 5.16508119231798
+1 21.5688667297363 -4.74999999999999 61.75 -1 0 0
+1 -1.88573503494262 -6.24999999999999 61.75 0 1 0
+2 0 1.4210854715202e-14 61.75 0 0 -1 1 0 0 0 -1 0 4
+1 -0.669433397527637 -0.33816996654729 61.75 0.450893288729739 -0.892577863370183 0
+8 5.79226947588352 6.56233480378389
+2 0 1.4210854715202e-14 61.75 0 0 -1 0 1 0 1 -0 0 4
+1 -1.88573503494262 -1.36119705054744 61.75 0 1 0
+1 -1.74127098584039 -1.78361478467679 61.75 0.450893288729739 0.892577863370183 0
+1 -4.38573503494262 4.75000000000001 61.75 1 0 0
+1 21.5688667297363 4.75000000000001 61.75 -1 0 0
+1 0.669433397527637 -0.33816996654729 61.75 0.450893288729739 0.892577863370183 0
+2 0 1.4210854715202e-14 61.75 0 0 1 1 0 -0 -0 1 0 4
+1 0.669433397527637 0.338169966547318 61.75 0.450893288729739 -0.892577863370183 0
+1 14.0008172030213 0.750000000000014 61.75 1 0 0
+1 14.0008172030213 -0.749999999999986 61.75 1 0 0
+2 0 1.4210854715202e-14 63.75 0 0 -1 -1 0 -0 0 1 0 2.5
+2 26 4.00000000000001 45.25 0 -1 0 1 0 0 -0 0 1 0.5
+1 25.0168330344604 4.75000000000001 54.375 0 0 -1
+1 25.0168330344604 4.75000000000001 48.3694023773397 0 1 0
+2 23.0168330344604 4.75000000000001 48.3694023773397 0 1 0 0 -0 1 1 0 -0 2
+1 24.6551370761863 4.75000000000001 49.5165553169535 0 1 0
+1 17.5095381392072 4.75000000000001 57.7215273086974 0.573576469806894 0 -0.819152020862954
+2 12 4.75000000000001 56.584918807682 0 -1 0 0 0 -1 1 0 0 5.16508119231798
+8 1.23095941734077 1.53745681753359
+2 0 1.24344978758018e-14 20 0 0 1 0 -1 0 1 0 -0 15
+1 22.125 -4.99999999999999 20 -1 0 0
+1 22.125 -0.499999999999988 20 -1 0 0
+1 17.25 -5.99999999999999 20 0 1 0
+8 1.6041358360562 1.91063323624902
+2 0 1.59872115546023e-14 20 0 0 1 0 -1 0 1 0 -0 15
+1 22.125 0.500000000000016 20 -1 0 0
+1 22.125 5.00000000000002 20 -1 0 0
+1 17.25 -0.999999999999985 20 0 -1 0
+1 25.5 -5.49999999999999 20 0 1 0
+8 4.71238898038469 7.85398163397448
+2 22.5 -3.99999999999999 20 0 0 1 0 -1 0 1 0 -0 3
+1 26.25 -0.499999999999988 20 -1 0 0
+1 19.5 -5.49999999999999 20 0 1 0
+1 24 -3.74999999999999 20 0 1 0
+1 24 -0.499999999999988 20 -1 0 0
+1 26.25 0.500000000000012 20 -1 0 0
+1 21 -3.74999999999999 20 0 1 0
+1 25.5 -3.24999999999999 20 0 1 0
+1 24 0.500000000000012 20 -1 0 0
+8 1.5707963267949 4.71238898038469
+2 22.5 4.00000000000001 20 0 0 1 0 -1 0 1 0 -0 3
+1 19.5 -3.24999999999999 20 0 1 0
+2 14 -8.24999999999999 22 -0 -0 1 1 0 0 -0 1 0 0.75
+2 14 8.25000000000001 22 -0 -0 1 1 0 0 -0 1 0 0.75
+8 0 1
+7 0 0 7 20 4 19.0813014172057 -4.74999999999999 45.75 19.0451662769539 -4.74999999999999 45.7499999964739 19.0086753500661 -4.74999999999999 45.747093099954 18.9719821773653 -4.74999999999999 45.7411706024927 18.935289476771 -4.74999999999999 45.7320891821611 18.8988534244276 -4.74999999999999 45.7196931147143 18.862989825626 -4.74999999999999 45.7038236210281 18.7975942139167 -4.74999999999999 45.6672770390243 18.7678551136025 -4.74999999999999 45.6474739860701 18.7391135772295 -4.74999999999999 45.6247986597278 18.7117024864973 -4.74999999999999 45.5991620559646 18.6860330014065 -4.74999999999999 45.5705243935062 18.6625787105843 -4.74999999999999 45.5389261342572 18.623148917419 -4.74999999999999 45.4734786354427 18.6066533271504 -4.74999999999999 45.4401306872098 18.5927914933107 -4.74999999999999 45.4046627180725 18.5819913822067 -4.74999999999999 45.3673851155859 18.5746223319208 -4.74999999999999 45.3287499115086 18.570941592632 -4.74999999999999 45.2893633304679 18.5709415886246 -4.74999999999999 45.25
+1 18.5709415886246 -4.74999999999999 17 0 0 -1
+1 18.5745429992676 -4.74999999999999 37 1 0 0
+1 3.23976567214837 -4.74999999999999 61.75 0 0 -1
+1 14.2280532751322 -4.74999999999999 58.25 0 0 1
+1 27.0745429992676 -4.74999999999999 58.25 -1 0 0
+7 0 0 6 17 4 14.2280532751322 -4.74999999999999 55.25 14.2280532472917 -4.74999999999999 55.5140774848799 14.1986429165851 -4.74999999999999 55.7783542637566 14.1397545204952 -4.74999999999999 56.0363800348457 14.0539388119487 -4.74999999999999 56.2830673535136 13.9447648851033 -4.74999999999999 56.5147134632607 13.6698467245209 -4.74999999999999 56.9735537399307 13.4981606360134 -4.74999999999999 57.1956206244746 13.3069545645074 -4.74999999999998 57.3924383160109 13.1018228744315 -4.74999999999999 57.5634464121593 12.8873471563157 -4.74999999999999 57.7093841507975 12.3982360908425 -4.74999999999999 57.980492029628 12.120887115918 -4.74999999999999 58.0940308402522 11.8408080687821 -4.74999999999998 58.1747549980608 11.5622915366651 -4.74999999999998 58.2257266080601 11.2881154905452 -4.74999999999999 58.249999975649 11.0198684202671 -4.74999999999999 58.25
+2 19 -3.99999999999999 45.25 0 -1 0 0 0 1 -1 0 0 0.5
+2 22.5 -3.99999999999999 45.25 0 0 1 -1 0 0 0 -1 0 4
+8 3.14159265358979 4.71238898038469
+2 19 -0.749999999999986 45.25 0 -1 0 0 0 -1 1 0 0 0.5
+1 18.5 -0.749999999999986 45.25 0 -1 0
+1 25.0168330344604 -0.749999999999986 54.375 0 0 1
+2 23.0168330344604 -0.749999999999986 48.3694023773397 0 1 0 0 -0 1 1 0 -0 2
+1 13.6899600876834 -0.749999999999986 63.1764496154002 -0.573576469806894 0 0.819152020862954
+2 12 -0.749999999999986 56.584918807682 0 -1 0 0 0 -1 1 0 0 5.16508119231798
+1 18.5 -0.749999999999986 39.375 0 0 -1
+1 6.96452920568771 -0.749999999999986 37 -1 0 0
+1 3.92905841137543 -0.749999999999986 61.75 0 0 -1
+1 14.9812382665786 -0.749999999999986 58.25 0 0 1
+1 15.4645292056877 -0.749999999999986 58.25 1 0 0
+7 0 0 6 17 4 14.9812382665786 -0.749999999999986 55.25 14.9812382403408 -0.749999999999986 55.5120504341857 14.9537344985929 -0.749999999999986 55.7742593502147 14.8986733840194 -0.749999999999985 56.0311839547075 14.817877330249 -0.749999999999987 56.2782347278874 14.7140982527354 -0.749999999999985 56.5117255502881 14.455026121115 -0.749999999999985 56.9683507941993 14.2954561390399 -0.749999999999991 57.1881487980012 14.1165027134108 -0.749999999999974 57.3851834034856 13.9228479529866 -0.749999999999993 57.5580976089669 13.7186614282322 -0.749999999999985 57.7067216916478 13.2614716891766 -0.749999999999985 57.9769400756803 13.0060149120158 -0.749999999999987 58.0900752090667 12.746192957244 -0.749999999999988 58.1720228125001 12.486155760034 -0.749999999999984 58.2246210090148 12.2289216822977 -0.749999999999986 58.2499999748173 11.9765395670035 -0.749999999999986 58.25
+1 25.0168330344604 0.750000000000014 54.375 0 0 1
+1 25.0168330344604 -0.749999999999986 48.3694023773397 0 1 0
+2 23.0168330344604 0.750000000000014 48.3694023773397 0 1 0 0 -0 1 1 0 -0 2
+1 13.6899600876834 0.750000000000014 63.1764496154002 -0.573576469806894 0 0.819152020862954
+2 19 0.750000000000014 45.25 0 -1 0 0 0 1 -1 0 0 0.5
+2 12 0.750000000000014 56.584918807682 0 -1 0 0 0 -1 1 0 0 5.16508119231798
+1 18.5 0.750000000000014 39.375 0 0 -1
+1 6.96452920568771 0.750000000000014 37 -1 0 0
+1 3.92905841137543 0.750000000000014 61.75 0 0 -1
+1 14.9812382665786 0.750000000000014 58.25 0 0 1
+1 15.4645292056877 0.750000000000014 58.25 1 0 0
+7 0 0 6 17 4 14.9812382665786 0.750000000000015 55.25 14.9812382403408 0.750000000000015 55.5120504341859 14.9537344985929 0.75000000000001 55.774259350215 14.8986733840192 0.750000000000021 56.031183954708 14.8178773302488 0.750000000000012 56.278234727888 14.7140982527351 0.750000000000014 56.5117255502888 14.4550261211146 0.750000000000014 56.9683507941999 14.2954561390392 0.750000000000013 57.1881487980022 14.1165027134104 0.750000000000015 57.3851834034859 13.9228479529858 0.750000000000016 57.5580976089676 13.7186614282315 0.750000000000013 57.7067216916483 13.2614716891759 0.750000000000013 57.9769400756806 13.0060149120155 0.750000000000018 58.0900752090669 12.7461929572434 0.750000000000011 58.1720228125002 12.4861557600339 0.750000000000015 58.2246210090148 12.2289216822975 0.750000000000014 58.2499999748173 11.9765395670035 0.750000000000014 58.25
+1 18.5 0.750000000000014 45.25 0 1 0
+2 19 4.00000000000001 45.25 0 -1 0 0 0 1 -1 0 0 0.5
+2 22.5 4.00000000000001 45.25 0 0 -1 -1 0 0 0 1 0 4
+8 0 1
+7 0 0 7 20 4 19.0813014172057 4.75000000000001 45.75 19.0451662769539 4.75000000000001 45.7499999964739 19.0086753500661 4.75000000000001 45.747093099954 18.9719821773653 4.75000000000001 45.7411706024927 18.935289476771 4.75000000000001 45.7320891821611 18.8988534244276 4.75000000000001 45.7196931147143 18.862989825626 4.75000000000001 45.7038236210281 18.7975942139167 4.75000000000001 45.6672770390243 18.7678551136024 4.75000000000001 45.6474739860701 18.7391135772295 4.75000000000001 45.6247986597278 18.7117024864973 4.75000000000001 45.5991620559646 18.6860330014065 4.75000000000001 45.5705243935062 18.6625787105843 4.75000000000001 45.5389261342572 18.623148917419 4.75000000000001 45.4734786354427 18.6066533271504 4.75000000000001 45.4401306872099 18.5927914933107 4.75000000000001 45.4046627180725 18.5819913822066 4.75000000000001 45.367385115586 18.5746223319208 4.75000000000001 45.3287499115086 18.570941592632 4.75000000000001 45.2893633304679 18.5709415886246 4.75000000000001 45.25
+1 18.5709415886246 4.75000000000001 17 0 0 -1
+1 18.5745429992676 4.75000000000001 37 1 0 0
+1 3.23976567214837 4.75000000000001 61.75 0 0 -1
+1 14.2280532751322 4.75000000000001 58.25 0 0 1
+1 27.0745429992676 4.75000000000001 58.25 -1 0 0
+7 0 0 6 17 4 14.2280532751322 4.75000000000001 55.25 14.2280532472917 4.75000000000001 55.51407748488 14.1986429165852 4.75000000000002 55.7783542637568 14.1397545204951 4.75000000000001 56.0363800348459 14.0539388119486 4.75000000000002 56.2830673535139 13.9447648851032 4.75000000000002 56.514713463261 13.6698467245207 4.75000000000002 56.973553739931 13.4981606360132 4.75000000000001 57.1956206244748 13.306954564507 4.75000000000002 57.3924383160113 13.1018228744312 4.75000000000001 57.5634464121595 12.8873471563153 4.75000000000002 57.7093841507978 12.3982360908421 4.75000000000002 57.9804920296281 12.1208871159178 4.75000000000001 58.0940308402522 11.8408080687818 4.75000000000002 58.1747549980611 11.562291536665 4.75000000000001 58.22572660806 11.2881154905451 4.75000000000002 58.249999975649 11.0198684202671 4.75000000000002 58.25
+1 1.55924001544396 -4.74999999999999 61.75 0 0 -1
+1 14.279620007722 -4.74999999999999 58.25 -1 0 0
+1 -1.88573503494262 -4.74999999999999 61.75 0 0 -1
+1 -1.88573503494262 -5.87499999999999 58.25 0 1 0
+1 -1.88573503494262 -3.52760589890507 61.75 0 0 -1
+1 1.10215267118867 -3.84516052842941 61.75 0 0 -1
+2 0 1.4210854715202e-14 58.25 0 0 1 0 -1 0 1 0 -0 4
+1 4.36957465633924 -10.3132730666547 58.25 0.450893288729739 -0.892577863370183 0
+1 -1.88573503494262 3.5276058989051 -38.25 0 0 1
+2 0 1.4210854715202e-14 58.25 0 0 -1 0 1 0 1 -0 0 4
+1 1.10215267118867 3.84516052842944 -38.25 0 0 1
+1 -1.88573503494262 -1.73619705054744 58.25 0 -1 0
+1 -1.88573503494262 4.75000000000001 -38.25 0 0 1
+1 1.55237307850282 4.73640637140536 58.25 -0.450893288729739 -0.892577863370183 0
+1 1.55924001544396 4.75000000000001 -38.25 0 0 1
+1 12.5571324825287 4.75000000000001 58.25 -1 0 0
+1 2.44101946624395 3.16882059533483 61.75 0 0 -1
+1 2.8912398735581 4.06006643831075 58.25 0.450893288729739 0.892577863370183 0
+8 1.7594127129703 2.48521038463468
+1 2.44101946624395 -3.16882059533481 61.75 0 0 -1
+1 5.70844145139451 -9.63693313356008 58.25 0.450893288729739 -0.892577863370183 0
+8 0.656382268955115 1.38217994061949
+1 -2.5 1.4210854715202e-14 63.75 0 0 -1
+1 14.142135623731 -4.99999999999999 36 0 0 -1
+2 0 1.24344978758018e-14 17 0 0 1 -1 0 0 0 -1 0 15
+1 14.9916643505649 -0.499999999999988 36 0 0 -1
+1 17.25 -4.99999999999999 36 0 0 -1
+1 10 -4.99999999999999 17 -1 0 0
+1 17.25 -0.499999999999988 36 0 0 -1
+1 10 -0.499999999999988 17 -1 0 0
+1 17.25 0 17 0 1 0
+1 14.142135623731 5.00000000000002 36 0 0 -1
+2 0 1.59872115546023e-14 17 0 0 -1 -1 0 0 0 1 0 15
+1 14.9916643505649 0.500000000000016 36 0 0 -1
+1 17.25 0.500000000000016 36 0 0 -1
+1 10 0.500000000000016 17 -1 0 0
+1 17.25 5.00000000000002 36 0 0 -1
+1 10 5.00000000000002 17 -1 0 0
+1 17.25 2.8421709430404e-14 17 0 -1 0
+1 25.5 -3.99999999999999 43.5 0 0 -1
+1 25.5 -3.99999999999999 17 0 1 0
+1 25.5 -0.499999999999988 43.5 0 0 -1
+1 19.5 -3.99999999999999 43.5 0 0 -1
+2 22.5 -3.99999999999999 17 0 0 1 -1 0 0 0 -1 0 3
+1 24 -0.499999999999988 43.5 0 0 -1
+1 19.5 -1.99999999999999 17 0 1 0
+1 19.5 -0.499999999999988 43.5 0 0 -1
+1 24 -3.99999999999999 17 0 1 0
+1 24 0.500000000000012 43.5 0 0 -1
+1 21 -0.499999999999988 43.5 0 0 -1
+1 25.5 0.500000000000013 43.5 0 0 -1
+1 10 0.500000000000012 17 -1 0 0
+1 21 -3.99999999999999 17 0 1 0
+1 21 0.500000000000013 43.5 0 0 -1
+1 25.5 4.00000000000001 43.5 0 0 -1
+1 19.5 0.500000000000012 43.5 0 0 -1
+2 22.5 4.00000000000001 17 0 0 1 -1 0 0 0 -1 0 3
+1 19.5 4.00000000000001 43.5 0 0 -1
+1 14.75 -8.24999999999999 22 -0 -0 1
+1 14.75 8.25000000000001 22 -0 -0 1
+1 18.5 -3.99999999999999 17 0 0 1
+8 4.52377259420929 4.71238898038469
+2 22.5 -3.99999999999999 37 0 0 -1 0 1 0 1 -0 0 4
+8 1.24858309479666 1.52077546998913
+2 0 1.24344978758018e-14 37 0 0 1 0 -1 0 1 0 -0 15
+1 18.5 -1.99999999999999 37 0 1 0
+2 0 1.24344978758018e-14 55.25 0 0 1 0.916666666666667 -0.399652626942727 0 0.399652626942727 0.916666666666667 -0 15
+2 0 1.24344978758018e-14 58.25 0 0 1 0.916666666666667 -0.399652626942727 0 0.399652626942727 0.916666666666667 -0 12
+1 24.6551370761863 -0.749999999999986 49.5165553169535 0 1 0
+1 18.5 4.00000000000001 17 0 0 1
+8 1.62081718360067 1.89300955879314
+8 4.71238898038469 4.90100536656009
+2 22.5 4.00000000000001 37 0 0 -1 0 1 0 1 -0 0 4
+Polygon3D 0
+PolygonOnTriangulations 0
+Surfaces 132
+1 19.4736360056942 11.1500000059605 10019 0 1 0 -1 0 0 0 -0 1
+1 27 -6.99999999999999 17 0 0 1 -1 0 0 0 -1 0
+1 13.75 -11.25 58.25 1 0 0 -0 1 0 0 -0 1
+1 11 7.82623792124928 17 -1 0 0 0 1 0 0 0 -1
+1 13.75 9.75000000000001 49.75 0.939692618823164 0 0.342020148718266 -0 1 0 -0.342020148718266 -0 0.939692618823164
+2 8 7.82623792124928 52.25 0 1 0 0 -0 1 1 0 -0 3
+1 13.75 5.99478940414091 58.25 1 0 0 -0 1 0 0 -0 1
+2 10.75 5.99478940414091 55.25 0 1 0 1 0 0 -0 -0 1 3
+1 4 11.25 -41.75 0.536875492193159 -0.843661487732107 0 -0.843661487732107 -0.536875492193159 0 0 -0 -1
+2 15 12.75 29 -0 1 -0 -1 -0 -0 -0 -0 -1 1.5
+1 19.4736360056942 11.1500000059605 10019 -0.49301257198088 -0.870022185848612 -0 0.870022185848612 -0.49301257198088 0 -0 0 1
+2 22.9000000059605 4.6108098325918 10019 0 0 1 -1 0 0 0 -1 0 4
+1 19.4736360056942 -11.1500000059605 10019 0 1 0 -1 0 0 0 -0 1
+1 24.872050293884 -8.09089857598622 10019 -0.49301257198088 0.870022185848612 0 -0.870022185848612 -0.49301257198088 0 0 0 1
+2 15 -7.99999999999999 17 0 0 -1 -1 0 0 -0 -1 -0 3.19999980926514
+2 22.9000000059605 -4.61080983259177 10019 0 0 1 -1 0 0 0 -1 0 4
+1 12 1.4210854715202e-14 56.584918807682 0 1 0 -1 0 0 0 -0 1
+1 26.9000000059605 -4.61080983259177 10019 1 0 0 -0 1 0 0 -0 1
+2 22.5 -3.99999999999999 17 0 0 -1 -1 0 0 -0 -1 -0 4
+1 26.5 -3.99999999999999 17 -1 0 0 0 1 0 0 0 -1
+2 22.5 4.00000000000001 17 0 0 -1 -1 0 0 -0 -1 -0 4
+2 15 8.00000000000001 17 0 0 -1 -1 0 0 -0 -1 -0 3.19999980926514
+2 14 -8.24999999999999 17 0 0 -1 -1 0 0 -0 -1 -0 3
+2 0 1.24344978758018e-14 17 0 0 -1 -1 0 0 -0 -1 -0 14.5553271261858
+2 14 8.25000000000001 17 0 0 -1 -1 0 0 -0 -1 -0 3
+1 14 -8.24999999999999 17 0 0 1 -1 0 0 0 -1 0
+2 23.75 5.10612974259391 17 0 0 -1 -1 0 0 -0 -1 -0 2
+2 23.75 -5.10612974259387 17 0 0 -1 -1 0 0 -0 -1 -0 2
+2 14 -8.24999999999999 17 0 0 -1 -1 0 0 -0 -1 -0 2.25
+2 14 8.7321245982865 17 0 0 1 -1 0 0 0 -1 0 3
+2 14 8.7321245982865 17 0 0 -1 0 -1 0 1 0 0 3
+2 0 1.24344978758018e-14 17 0 0 -1 -1 0 0 -0 -1 -0 13.5
+2 14 -8.73212459828648 17 0 0 1 -0.848484848484849 0.529219672623423 0 -0.529219672623423 -0.848484848484849 0 3
+2 14 -8.73212459828648 17 0 0 -1 0 -1 0 1 0 0 3
+1 13.75 9.75000000000001 23 0 -1 0 0 0 1 -1 0 0
+5 14 8.7321245982865 52.25 0 0 1 -0.848484848484848 -0.529219672623424 0 -0.529219672623424 0.848484848484848 -0 6 3
+2 0 1.24344978758018e-14 55.25 0 0 -1 -1 0 0 -0 -1 -0 1.5
+2 0 1.24344978758018e-14 57.25 -0 -0 -1 -1 0 0 -0 -1 0 1.5
+5 0 1.24344978758018e-14 52.25 0 0 -1 0.814814814814815 -0.579721327499945 0 0.579721327499945 0.814814814814815 0 10.5 3
+1 -6.90000000596046 -11.1500000059605 10019 1 0 0 -0 1 0 0 -0 1
+5 14 -8.73212459828648 52.25 0 0 1 -0.848484848484849 0.529219672623424 0 -0.529219672623424 -0.848484848484849 0 6 3
+1 4 -11.25 -41.75 -0.536875492193159 -0.843661487732107 0 -0.843661487732107 0.536875492193159 0 -0 0 -1
+2 8 -11.25 52.25 0 1 0 0 -0 1 1 0 -0 3
+1 -3.38573503494262 -93.75 61.75 -0.707106781186548 0 0.707106781186548 -0.707106781186548 0 -0.707106781186548 -0 -1 0
+1 13.75 -9.74999999999999 49.75 -0.939692618823164 0 -0.342020148718266 0 -1 -0 -0.342020148718266 -0 0.939692618823164
+1 11 -11.25 17 -1 0 0 0 1 0 0 0 -1
+2 10.75 -11.25 55.25 0 1 0 1 0 0 -0 -0 1 3
+1 13.75 -9.74999999999999 23 0 -1 0 0 0 1 -1 0 0
+2 23.0168330344604 -6.24999999999999 48.3694023773397 0 1 0 0.819152020862954 -0 0.573576469806894 0.573576469806894 0 -0.819152020862954 2
+5 22.5 -3.99999999999999 45.25 0 0 1 -0.826797284707685 -0.5625 0 0.5625 -0.826797284707685 0 3.5 0.5
+2 12 -6.24999999999999 56.584918807682 0 -1 0 -1 0 0 0 0 1 5.16508119231798
+1 27 -1.99999999999999 19 0 1 -0 -1 0 0 0 0 1
+1 27 -6.99999999999999 19 0 0 1 -1 0 0 0 -1 0
+1 25.7999999523163 2.00000000000001 19 0 -1 0 1 0 0 -0 0 1
+2 26 -3.99999999999999 45.25 0 1 0 1 0 0 -0 -0 1 0.5
+5 22.5 4.00000000000001 45.25 0 0 1 1 0 -0 -0 1 0 3.5 0.5
+2 23.0168330344604 4.75000000000001 48.3694023773397 0 1 0 0.819152020862954 -0 0.573576469806894 0.573576469806894 0 -0.819152020862954 2
+1 19.1704500515343 10 17 0 -1 0 -1 0 0 -0 -0 -1
+1 19.1704500515343 10 17 0.49301257198088 0.870022185848612 0 0.870022185848612 -0.49301257198088 0 0 0 -1
+1 25.75 -5.10612974259387 17 -1 0 0 0 1 0 0 0 -1
+1 24.7360251439618 -6.8461741142911 17 0.49301257198088 -0.870022185848612 0 -0.870022185848612 -0.49301257198088 0 0 -0 -1
+1 19.1704500515343 -9.99999999999999 17 0 -1 0 -1 0 0 -0 -0 -1
+1 25.7999999523163 -1.99999999999999 19 1 0 0 -0 1 0 0 -0 1
+1 19.5 12.75 19 0 1 0 -1 0 -0 0 0 -1
+1 25.0168330344604 -6.24999999999999 47 -1 0 0 0 0 -1 -0 -1 -0
+1 27.1490859985352 -4.74999999999999 61.75 0 1 0 -1 0 0 0 -0 1
+1 16.2309866966085 -6.24999999999999 59.5474878442378 -0.819152020862954 0 -0.573576469806894 0.573576469806894 0 -0.819152020862954 0 -1 -0
+5 22.5 -3.99999999999999 45.25 0 0 -1 -1 0 0 -0 -1 -0 3.5 0.5
+2 19 -0.749999999999986 45.25 0 -1 0 0 0 1 -1 0 0 0.5
+1 3.92905841137543 -0.749999999999986 61.75 0 -1 0 1 0 0 -0 0 1
+1 3.92905841137543 0.750000000000014 61.75 0 -1 0 1 0 0 -0 0 1
+2 19 0.750000000000014 45.25 0 1 0 0 -0 1 -1 -0 0 0.5
+5 22.5 4.00000000000001 45.25 0 0 -1 -1 0 0 0 1 0 3.5 0.5
+1 27.1490859985352 4.75000000000001 61.75 0 1 0 -1 0 0 0 -0 1
+1 -6.88573503494262 -6.24999999999999 61.75 0 0 -1 1 0 0 0 -1 0
+2 0 1.4210854715202e-14 61.75 0 0 1 1 0 -0 0 -1 -0 4
+2 0 1.4210854715202e-14 -38.25 0 0 -1 1 0 0 0 -1 0 4
+1 -1.88573503494262 3.5276058989051 -38.25 -1 0 0 0 1 0 0 0 -1
+1 1.10215267118867 3.84516052842944 -38.25 -0.892577863370183 0.450893288729739 0 0.450893288729739 0.892577863370183 0 0 0 -1
+1 -1.88573503494262 4.75000000000001 -38.25 0 1 0 1 0 0 0 0 -1
+2 0 1.4210854715202e-14 63.75 -0 -0 1 -1 0 0 0 1 0 2.5
+2 0 1.24344978758018e-14 36 0 0 1 -1 0 0 0 -1 0 15
+1 17.25 -4.99999999999999 36 0 1 0 -1 0 0 0 -0 1
+1 17.25 -0.499999999999988 36 0 1 0 -1 0 0 0 -0 1
+1 17.25 -4.99999999999999 36 1 0 0 -0 1 0 0 -0 1
+2 0 1.59872115546023e-14 36 0 0 1 -1 0 0 -0 1 -0 15
+1 17.25 0.500000000000016 36 0 1 0 -1 0 0 0 -0 1
+1 17.25 5.00000000000002 36 0 1 0 -1 0 0 0 -0 1
+1 17.25 5.00000000000002 36 -1 0 0 0 -1 0 0 0 1
+1 25.5 -3.99999999999999 43.5 1 0 0 -0 1 0 0 -0 1
+2 22.5 -3.99999999999999 43.5 0 0 1 -1 0 0 0 -1 0 3
+1 25.5 -0.499999999999988 43.5 0 1 0 -1 0 0 0 -0 1
+1 19.5 -3.99999999999999 43.5 1 0 0 -0 1 0 0 -0 1
+1 24 -0.499999999999988 43.5 1 0 0 -0 1 0 0 -0 1
+1 21 -0.499999999999988 43.5 0 1 0 -1 0 0 0 -0 1
+1 25.5 0.500000000000012 43.5 0 1 0 -1 0 0 0 -0 1
+1 21 -0.499999999999988 43.5 1 0 0 -0 1 0 0 -0 1
+1 25.5 0.500000000000013 43.5 1 0 0 -0 1 0 0 -0 1
+1 21 0.500000000000012 43.5 0 1 0 -1 0 0 0 -0 1
+2 22.5 4.00000000000001 43.5 0 0 1 -1 0 0 0 -1 0 3
+1 19.5 0.500000000000012 43.5 1 0 0 -0 1 0 0 -0 1
+2 14 -8.24999999999999 22 -0 0 -1 1 0 0 -0 1 0 0.75
+2 14 8.25000000000001 22 -0 0 -1 1 0 0 -0 1 0 0.75
+1 27 -6.99999999999999 57.25 0 0 1 -1 0 0 0 -1 0
+1 19.5 -12.75 19 0 -1 0 -1 0 0 0 0 -1
+1 10 1.33226762955019e-14 37 0 0 1 -1 0 0 0 -1 0
+2 0 1.24344978758018e-14 58.25 0 0 1 -1 0 0 0 -1 0 15
+5 0 1.24344978758018e-14 55.25 0 0 1 0.916666666666667 -0.399652626942727 0 0.399652626942727 0.916666666666667 -0 12 3
+1 18.5 -3.99999999999999 17 -1 0 0 0 1 0 0 0 -1
+2 23.0168330344604 -0.749999999999986 48.3694023773397 0 1 0 0.819152020862954 -0 0.573576469806894 0.573576469806894 0 -0.819152020862954 2
+1 1.55924001544396 -4.74999999999999 61.75 0 1 0 -1 0 0 0 -0 1
+1 -1.88573503494262 -4.74999999999999 61.75 1 0 0 -0 1 0 0 -0 1
+1 1.10215267118867 -3.84516052842941 61.75 -0.892577863370183 -0.450893288729739 0 0.450893288729739 -0.892577863370183 0 0 0 1
+1 2.44101946624395 3.16882059533483 61.75 0.892577863370183 -0.450893288729739 0 0.450893288729739 0.892577863370183 0 -0 0 1
+1 2.44101946624395 -3.16882059533481 61.75 -0.892577863370183 -0.450893288729739 0 0.450893288729739 -0.892577863370183 0 0 0 1
+1 0 1.4210854715202e-14 63.75 0 0 -1 -1 0 -0 0 1 0
+1 14 -8.24999999999999 22 0 -0 1 1 0 0 -0 1 0
+1 14 8.25000000000001 22 0 -0 1 1 0 0 -0 1 0
+Triangulations 0
+TShapes 953
+Ve
+0.0001
+19.4736360056942 11.1500000059605 25
+0 0
+0101101
+Ve
+0.0001
+19.4736360056942 11.1500000059605 19
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1 0 9994 10000
+0
+0101000
++953 2 -952 2 *
+Ve
+0.0001
+18.75 11.1500000059605 25
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 2 0 3.76318199715292 4.48681800284708
+2 1 2 6 3.76318199715292 4.48681800284708
+2 2 1 1 3.76318199715292 4.48681800284708
+0
+0101000
++953 0 -950 0 *
+Ve
+0.0001
+11 11.1500000059605 19
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 3 0 3.76318199715292 12.2368180028471
+2 3 2 5 3.76318199715292 12.2368180028471
+2 4 1 1 3.76318199715292 12.2368180028471
+0
+0101000
++952 0 -948 0 *
+Ve
+0.0001
+18.75 11.1500000059605 38.0126131480163
+0 0
+0101101
+Ed
+ 1.36424205265939e-12 1 1 0
+1 4 0 -5014.625 -5001.61238685198
+2 5 3 8 -5014.625 -5001.61238685198
+2 6 1 1 -5014.625 -5001.61238685198
+0
+0101000
++950 0 -946 0 *
+Ve
+0.0001
+11 11.1500000059605 54.25
+0 0
+0101101
+Ed
+1 5 0 4964.75 5000
+2 7 4 5 4964.75 5000
+2 8 1 1 4964.75 5000
+0
+0101000
++944 0 -948 0 *
+Ve
+0.0001
+13.75 11.1500000059605 51.75
+0 0
+0101101
+Ed
+ 1.48243976013409e-12 1 1 0
+1 6 0 -4696.71584983397 -4682.09682806365
+2 9 5 5 -4696.71584983397 -4682.09682806365
+2 10 1 1 -4696.71584983397 -4682.09682806365
+0
+0101000
++946 0 -942 0 *
+Ve
+0.0001
+8 11.1500000059605 57.25
+0 0
+0101101
+Ed
+ 1.25766064229538e-12 1 1 0
+1 7 0 0 1.5707963267949
+2 11 6 5 0 1.5707963267949
+2 12 1 1 0 1.5707963267949
+0
+0101000
++940 0 -944 0 *
+Ve
+0.0001
+13.75 11.1500000059605 57.25
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 8 0 -4987.875 -4982.375
+2 13 7 5 -4987.875 -4982.375
+2 14 1 1 -4987.875 -4982.375
+0
+0101000
++942 0 -938 0 *
+Ve
+0.0001
+3.84285715222361 11.1500000059605 57.25
+0 0
+0101101
+Ed
+ 2.66453525910038e-15 1 1 0
+1 9 0 15.2368180028471 19.3939608506235
+2 15 2 10 15.2368180028471 19.3939608506235
+2 16 1 1 15.2368180028471 19.3939608506235
+0
+0101000
++940 0 -936 0 *
+Ve
+0.0001
+10.75 11.1500000059605 60.25
+0 0
+0101101
+Ed
+ 1.24700250125898e-12 1 1 0
+1 10 0 -3.5527136788005e-15 1.5707963267949
+2 17 8 5 -3.5527136788005e-15 1.5707963267949
+2 18 1 1 -3.5527136788005e-15 1.5707963267949
+0
+0101000
++934 0 -938 0 *
+Ve
+0.0001
+3.84285715222361 11.1500000059605 60.25
+0 0
+0101101
+Ed
+ 6.66133814775094e-16 1 1 0
+1 11 0 -4932.375 -4929.375
+2 19 9 5 -4932.375 -4929.375
+2 20 1 1 -4932.375 -4929.375
+0
+0101000
++936 0 -932 0 *
+Ed
+1 12 0 12.4868180028471 19.3939608506235
+2 21 2 11 12.4868180028471 19.3939608506235
+2 22 1 1 12.4868180028471 19.3939608506235
+0
+0101000
++934 0 -932 0 *
+Wi
+0101100
++951 1 -949 0 +947 0 -945 0 -943 0 -941 0 -939 0 -937 0 +935 0 +933 0
++931 0 -930 0 *
+Ve
+3.060000002e-05
+13.5 11.1500000059605 29
+0 0
+0101101
+Ed
+ 1.49999999999722e-08 1 1 0
+1 13 0 4.71238898038469 10.9955742875643
+2 23 1 1 4.71238898038469 10.9955742875643
+2 24 10 0 4.71238898038469 10.9955742875643
+0
+0101100
++928 0 -928 0 *
+Wi
+0101100
+-927 0 *
+Fa
+0 1e-07 1 0
+0101000
++929 2 +926 2 *
+Ve
+0.0001
+24.872050293884 8.09089857598624 25
+0 0
+0101101
+Ed
+ 5.95808196779346e-15 1 1 0
+1 14 0 -7.74814091910491 -1.54322525603563
+2 25 2 6 -7.74814091910491 -1.54322525603563
+2 26 11 1 -7.74814091910491 -1.54322525603563
+0
+0101000
++953 0 -924 0 *
+Ve
+0.0001
+24.872050293884 8.09089857598624 19
+0 0
+0101101
+Ed
+1 15 0 -7.74814091910491 -1.54322525603563
+2 27 2 5 -7.74814091910491 -1.54322525603563
+2 28 11 1 -7.74814091910491 -1.54322525603563
+0
+0101000
++952 0 -922 0 *
+Ed
+ 1e-07 1 1 0
+1 16 0 9994 10000
+2 29 12 0 9994 10000
+4 G1 12 0 11 0
+0
+0101000
++924 2 -922 2 *
+Wi
+0101100
++951 1 -923 0 +921 0 -920 1 *
+Fa
+0 1e-07 11 0
+0101000
++919 2 *
+Ve
+0.0001
+18.75 -11.1500000059605 25
+0 0
+0101101
+Ve
+1e-07
+13.75 -9.74999999999999 23
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 17 0 0.0999999940395495 1.5
+4 CN 2 15 2 15
+0
+0101000
++917 16 -916 0 *
+Ve
+0.0001
+19.4736360056942 -11.1500000059605 25
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 18 0 3.76318199715292 4.48681800284708
+2 30 2 6 3.76318199715292 4.48681800284708
+2 31 13 1 3.76318199715292 4.48681800284708
+0
+0101000
++914 0 -917 0 *
+Ve
+2.62500002e-06
+17.6790854371029 -9.74999999999999 23
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 19 0 3.92908543710292 5
+4 CN 2 17 2 17
+0
+0101000
++912 0 -916 13 *
+Ve
+0.0001
+24.872050293884 -8.09089857598622 25
+0 0
+0101101
+Ed
+1 20 0 1.19459508370411 7.39951074677339
+2 32 2 6 1.19459508370411 7.39951074677339
+2 33 14 1 1.19459508370411 7.39951074677339
+0
+0101000
++910 0 -914 0 *
+Ve
+2.62500002e-06
+17.6790854371029 -6.24999999999999 23
+0 0
+0101101
+Ed
+ 3.19999980926383e-08 1 1 0
+1 21 0 0.992169236961567 2.14942341662822
+2 34 2 17 0.992169236961567 2.14942341662822
+2 35 15 0 0.992169236961567 2.14942341662822
+0
+0101000
++908 0 -912 0 *
+Ve
+0.0001
+26.9000000059605 -4.61080983259177 25
+0 0
+0101101
+Ed
+ 5.49308015822668e-15 1 1 0
+1 22 0 0.515549007458979 1.5707963267949
+2 36 2 6 0.515549007458979 1.5707963267949
+2 37 16 1 0.515549007458979 1.5707963267949
+0
+0101000
++910 0 -906 0 *
+Ve
+2.87500002e-06
+19.1928108611693 -6.24999999999999 23
+0 0
+0101101
+Ed
+ 5.32907051820075e-15 1 1 0
+1 23 0 0.307189138830741 1.82091456289709
+2 38 2 17 0.307189138830741 1.82091456289709
+2 39 17 20 0.307189138830741 1.82091456289709
+0
+0101000
+-908 0 +904 0 *
+Ve
+0.0001
+26.9000000059605 4.6108098325918 25
+0 0
+0101101
+Ed
+ 1.33226762955019e-15 1 1 0
+1 24 0 1.19459508370411 10.4162147488877
+2 40 2 6 1.19459508370411 10.4162147488877
+2 41 18 1 1.19459508370411 10.4162147488877
+0
+0101000
++906 0 -902 0 *
+Ve
+2.87500002e-06
+26.5 -3.99999999999999 23
+0 0
+0101101
+Ed
+ 3.99999999999896e-08 1 1 0
+1 25 0 1.5707963267949 4.11498256373934
+2 42 2 17 1.5707963267949 4.11498256373934
+2 43 19 0 1.5707963267949 4.11498256373934
+0
+0101000
++900 0 -904 0 *
+Ed
+1 26 0 1.5707963267949 2.62604364613081
+2 44 2 6 1.5707963267949 2.62604364613081
+2 45 12 1 1.5707963267949 2.62604364613081
+0
+0101000
++902 0 -924 0 *
+Ve
+2.87500002e-06
+26.5 4.00000000000001 23
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 27 0 -9.5 -1.5
+2 46 2 17 -9.5 -1.5
+2 47 20 0 -9.5 -1.5
+0
+0101000
++897 0 -900 0 *
+Ve
+2.87500002e-06
+19.1928108611693 6.25000000000001 23
+0 0
+0101101
+Ed
+1 28 0 5.30979539703004 7.85398163397448
+2 48 2 17 5.30979539703004 7.85398163397448
+2 49 21 0 5.30979539703004 7.85398163397448
+0
+0101000
++895 0 -897 0 *
+Ve
+2.62500002e-06
+17.6790854371029 6.25000000000001 23
+0 0
+0101101
+Ed
+1 29 0 0.307189138830739 1.82091456289709
+2 50 2 17 0.307189138830739 1.82091456289709
+2 51 17 22 0.307189138830739 1.82091456289709
+0
+0101000
+-893 0 +895 0 *
+Ve
+1e-07
+13.75 9.75000000000001 23
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 30 0 0.0999999940395211 1.5
+4 CN 2 23 2 23
+0
+0101000
++950 24 -891 0 *
+Ve
+2.62500002e-06
+17.6790854371029 9.75000000000001 23
+0 0
+0101101
+Ed
+1 31 0 0.992169236961567 2.14942341662823
+2 52 2 17 0.992169236961567 2.14942341662823
+2 53 22 0 0.992169236961567 2.14942341662823
+0
+0101000
++889 0 -893 0 *
+Ed
+ 1e-07 1 1 0
+1 32 0 3.92908543710291 5
+4 CN 2 17 2 17
+0
+0101000
++889 0 -891 7 *
+Wi
+0101100
+-915 14 -913 0 +911 5 -909 0 +907 5 +905 0 +903 5 +901 0 +899 5 +898 0
++896 5 -923 0 +894 5 +949 0 -892 5 +890 8 +888 5 -887 5 *
+Fa
+0 1e-07 2 0
+0101000
++886 12 *
+Ve
+1e-07
+16.4366985862022 -9.99999999999999 17
+0 0
+0101101
+Ve
+1e-07
+13.5631199490234 -5.28198116228033 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 33 0 2.51876606817779 4.85853535973926
+2 54 23 0 2.51876606817779 4.85853535973926
+2 55 23 26 2.51876606817779 4.85853535973926
+4 CN 2 0 2 0
+0
+0101000
++884 0 -883 0 *
+Ve
+1e-07
+13.5631199490234 5.28198116228036 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 34 0 2.77022531890606 3.51295998827352
+2 56 24 0 2.77022531890606 3.51295998827352
+2 57 24 26 2.77022531890606 3.51295998827352
+4 CN 2 0 2 0
+0
+0101000
++883 0 -881 0 *
+Ve
+1e-07
+16.4366985862022 10 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 35 0 1.42464994744033 3.7644192390018
+2 58 25 0 1.42464994744033 3.7644192390018
+2 59 25 26 1.42464994744033 3.7644192390018
+4 CN 2 0 2 0
+0
+0101000
++881 0 -879 0 *
+Ve
+1e-07
+19.1704500515343 10 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 36 0 -9.17045005153431 -6.43669858620223
+4 CN 2 0 2 0
+0
+0101000
++877 0 -879 0 *
+Ve
+1e-07
+24.7360251439618 6.84617411429113 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 37 0 0.329549948465691 6.72659956737722
+4 CN 2 0 2 0
+0
+0101000
++877 0 -875 0 *
+Ve
+1e-07
+25.75 5.10612974259391 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+2 60 26 0 3.14159265358979 4.19683997292571
+1 38 0 3.14159265358979 4.19683997292571
+2 61 27 0 3.14159265358979 4.19683997292571
+2 62 27 26 3.14159265358979 4.19683997292571
+4 CN 2 0 2 0
+0
+0101000
++873 0 -875 0 *
+Ve
+1e-07
+25.75 -5.10612974259387 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 39 0 -5.10612974259387 5.10612974259391
+4 CN 2 0 2 0
+0
+0101000
++871 0 -873 0 *
+Ve
+1e-07
+24.7360251439618 -6.8461741142911 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+2 63 28 0 2.08634533425388 3.14159265358979
+1 40 0 2.08634533425388 3.14159265358979
+2 64 29 0 2.08634533425388 3.14159265358979
+2 65 29 26 2.08634533425388 3.14159265358979
+4 CN 2 0 2 0
+0
+0101000
++869 0 -871 0 *
+Ve
+1e-07
+19.1704500515343 -9.99999999999999 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 41 0 1.89387025740611 8.29091987631765
+4 CN 2 0 2 0
+0
+0101000
++869 0 -867 0 *
+Ed
+ 1e-07 1 1 0
+1 42 0 -9.17045005153431 -6.43669858620223
+4 CN 2 0 2 0
+0
+0101000
++867 0 -884 0 *
+Wi
+0101100
++882 0 +880 0 +878 0 -876 0 +874 0 -872 0 -870 0 -868 0 +866 0 +865 0
+Ve
+1e-07
+11.75 -8.24999999999999 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 43 0 0 6.28318530717959
+2 66 30 0 0 6.28318530717959
+2 67 30 28 0 6.28318530717959
+4 CN 2 0 2 0
+0
+0101100
++863 0 -863 0 *
+Wi
+0101100
++862 0 *
+Ve
+1e-07
+11.75 8.25000000000001 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 44 0 0 6.28318530717959
+2 68 31 0 0 6.28318530717959
+2 69 31 30 0 6.28318530717959
+4 CN 2 0 2 0
+0
+0101100
++860 0 -860 0 *
+Wi
+0101100
++859 0 *
+Ve
+0.0001
+26.9000000059605 2.00000000000001 19
+0 0
+0101101
+Ve
+1e-07
+25.7999999523163 2.00000000000001 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 45 0 -0.139012575149536 0.960987478494666
+4 CN 2 0 2 0
+0
+0101000
+-857 31 +856 0 *
+Ve
+0.0001
+26.9000000059605 4.6108098325918 19
+0 0
+0101101
+Ed
+1 46 0 7.80540491629589 10.4162147488877
+2 70 2 5 7.80540491629589 10.4162147488877
+2 71 18 1 7.80540491629589 10.4162147488877
+0
+0101000
++857 0 -854 0 *
+Ve
+1e-07
+25.7999999523163 -1.99999999999999 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 47 0 0.405383586883557 4.40538358688356
+4 CN 2 0 2 0
+0
+0101000
++852 0 -856 0 *
+Ed
+1 48 0 1.5707963267949 2.62604364613081
+2 72 2 5 1.5707963267949 2.62604364613081
+2 73 12 1 1.5707963267949 2.62604364613081
+0
+0101000
++854 0 -922 0 *
+Ve
+0.0001
+26.9000000059605 -1.99999999999999 19
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 49 0 0.0999999940395359 1.20000004768372
+4 CN 2 0 2 0
+0
+0101000
++849 31 -852 0 *
+Ve
+0.0001
+26.9000000059605 -4.61080983259177 19
+0 0
+0101101
+Ed
+1 50 0 1.19459508370411 3.80540491629589
+2 74 2 5 1.19459508370411 3.80540491629589
+2 75 18 1 1.19459508370411 3.80540491629589
+0
+0101000
++847 0 -849 0 *
+Ve
+0.0001
+24.872050293884 -8.09089857598622 19
+0 0
+0101101
+Ed
+1 51 0 0.515549007458979 1.5707963267949
+2 76 2 5 0.515549007458979 1.5707963267949
+2 77 16 1 0.515549007458979 1.5707963267949
+0
+0101000
++845 0 -847 0 *
+Ve
+1e-07
+11 8.7321245982865 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 52 0 8.7321245982865 11.1500000059605
+4 CN 2 0 2 0
+0
+0101000
+-948 31 +843 0 *
+Ve
+0.0001
+19.4736360056942 -11.1500000059605 19
+0 0
+0101101
+Ed
+1 53 0 1.19459508370411 7.39951074677339
+2 78 2 5 1.19459508370411 7.39951074677339
+2 79 14 1 1.19459508370411 7.39951074677339
+0
+0101000
++845 0 -841 0 *
+Ve
+1e-07
+11.4545454545455 7.14446558041623 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 54 0 4.71238898038469 5.27006961012409
+2 80 32 0 4.71238898038469 5.27006961012409
+2 81 2 0 4.71238898038469 5.27006961012409
+2 82 33 0 4.71238898038469 5.27006961012409
+2 83 33 33 4.71238898038469 5.27006961012409
+2 84 34 0 4.71238898038469 5.27006961012409
+2 85 34 35 4.71238898038469 5.27006961012409
+2 86 35 0 4.71238898038469 5.27006961012409
+2 87 35 37 4.71238898038469 5.27006961012409
+0
+0101000
++843 0 -839 0 *
+Ve
+0.0001
+11 -11.1500000059605 19
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 55 0 3.76318199715292 12.2368180028471
+2 88 2 5 3.76318199715292 12.2368180028471
+2 89 13 1 3.76318199715292 12.2368180028471
+0
+0101000
++841 0 -837 0 *
+Ve
+1e-07
+11.4545454545455 -7.14446558041621 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 56 0 2.58391202385039 3.69927328332919
+4 CN 2 0 2 0
+2 90 36 0 2.58391202385039 3.69927328332919
+2 91 36 38 2.58391202385039 3.69927328332919
+2 92 37 0 2.58391202385039 3.69927328332919
+2 93 37 33 2.58391202385039 3.69927328332919
+2 94 38 0 2.58391202385039 3.69927328332919
+2 95 38 35 2.58391202385039 3.69927328332919
+2 96 39 0 2.58391202385039 3.69927328332919
+2 97 39 37 2.58391202385039 3.69927328332919
+0
+0101000
++835 0 -839 0 *
+Ve
+1e-07
+11 -8.73212459828648 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 57 0 -11.1500000059605 -8.73212459828648
+4 CN 2 0 2 0
+0
+0101000
++837 31 -833 0 *
+Ed
+ 1e-07 1 1 0
+1 58 0 4.15470835064529 4.71238898038469
+2 98 40 0 4.15470835064529 4.71238898038469
+2 99 2 0 4.15470835064529 4.71238898038469
+2 100 41 0 4.15470835064529 4.71238898038469
+2 101 41 33 4.15470835064529 4.71238898038469
+2 102 42 0 4.15470835064529 4.71238898038469
+2 103 42 35 4.15470835064529 4.71238898038469
+2 104 43 0 4.15470835064529 4.71238898038469
+2 105 43 37 4.15470835064529 4.71238898038469
+0
+0101000
++835 0 -833 0 *
+Wi
+0101100
++855 5 +853 0 +851 5 +850 0 +848 5 -921 0 +846 0 +947 0 +844 0 -842 5
+-840 0 +838 5 -836 0 -834 5 -832 5 +831 5 *
+Fa
+0 1e-07 2 0
+0101000
++864 0 -861 0 +858 0 +830 31 *
+Ve
+1e-07
+18.75 9.75000000000001 36.0126131480163
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 59 39 10.5 11.9000000059605
+2 106 5 39 10.5 11.9000000059605
+2 107 3 0 10.5 11.9000000059605
+0
+0101000
+-946 24 +828 39 *
+Ed
+ 1e-07 1 1 0
+1 60 0 0 13.0126131480163
+4 CN 7 0 7 0
+0
+0101000
++891 0 -828 39 *
+Wi
+0101100
+-827 8 +945 0 -826 8 -890 8 *
+Fa
+0 1e-07 3 0
+0101000
++825 24 *
+Ve
+1e-07
+11 8.7321245982865 52.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 61 0 0.905886677037226 3.3237620847112
+2 108 6 0 0.905886677037226 3.3237620847112
+2 109 4 0 0.905886677037226 3.3237620847112
+4 G1 6 0 4 0
+0
+0101000
+-944 31 +823 0 *
+Ed
+ 1e-07 1 1 0
+1 62 0 0 35.25
+2 110 32 0 0 35.25
+2 111 4 0 0 35.25
+4 G1 32 0 4 0
+0
+0101000
++843 0 -823 0 *
+Wi
+0101100
++822 5 +943 0 +821 5 -842 5 *
+Fa
+0 1e-07 4 0
+0101000
++820 31 *
+Ve
+1e-07
+13.75 9.75000000000001 49.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 63 0 1.87760529792955 3.27760530389002
+2 112 5 0 1.87760529792955 3.27760530389002
+2 113 7 0 1.87760529792955 3.27760530389002
+0
+0101000
+-942 31 +818 0 *
+Ve
+1.46657008983787e-06
+16.1158065649732 9.75000000000001 43.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 64 0 -12.5683887767598 -5.65123324121845
+2 114 44 0 -12.5683887767598 -5.65123324121845
+2 115 5 0 -12.5683887767598 -5.65123324121845
+0
+0101000
+-816 0 +818 0 *
+Ve
+2.62500002e-06
+16.1158065649732 10.9991622978525 43.25
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 65 0 -9.62416229785244 -8.375
+2 116 5 0 -9.62416229785244 -8.375
+2 117 2 40 -9.62416229785244 -8.375
+0
+0101000
++814 0 -816 0 *
+Ve
+2.62500002e-06
+17.6790854371029 9.75000000000001 38.9549266752044
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 64 0 -1.08051166826981 2.05063299355898
+2 114 44 0 -1.08051166826981 2.05063299355898
+2 115 5 0 -1.08051166826981 2.05063299355898
+0
+0101000
++812 0 -828 0 *
+Ed
+ 1e-08 1 1 0
+1 66 0 0.578627089833329 1.21462376728856
+2 118 5 0 0.578627089833329 1.21462376728856
+2 119 22 0 0.578627089833329 1.21462376728856
+0
+0101000
++812 0 -814 0 *
+Wi
+0101100
+-817 5 +941 0 +815 5 +827 8 -813 5 +811 5 -810 5 *
+Fa
+0 1e-07 5 0
+0101000
++809 31 *
+Ve
+1e-07
+8 8.7321245982865 55.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 67 0 0.905886677037226 3.32376208471117
+2 120 6 0 0.905886677037226 3.32376208471117
+2 121 2 9 0.905886677037226 3.32376208471117
+4 G1 6 0 2 9
+0
+0101000
+-940 31 +807 0 *
+Ed
+ 1e-07 1 1 0
+1 68 0 1.5707963267949 3.14159265358979
+2 122 6 0 1.5707963267949 3.14159265358979
+2 123 45 0 1.5707963267949 3.14159265358979
+4 G1 45 0 6 0
+0
+0101100
++807 0 -823 0 *
+Wi
+0101100
+-806 5 -939 0 +805 5 +822 5 *
+Fa
+0 0 6 0
+0101000
++804 31 *
+Ve
+3.37629321304289e-06
+13.75 9.75000000000001 43.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 60 0 20.25 26.75
+4 CN 7 0 7 0
+0
+0101000
++802 0 -818 0 *
+Ve
+8.28115912972762e-05
+13.75 6.25000000000001 55.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 69 0 0.255210595859101 5.15521060181957
+2 124 8 0 0.255210595859101 5.15521060181957
+2 125 7 0 0.255210595859101 5.15521060181957
+4 G1 8 0 7 0
+0
+0101000
+-938 31 +800 0 *
+Ve
+1.38125332369362e-05
+13.75 6.25000000000001 43.25
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 70 0 -10.2526052979296 -6.75260529792955
+2 126 7 0 -10.2526052979296 -6.75260529792955
+2 127 2 40 -10.2526052979296 -6.75260529792955
+0
+0101000
++802 0 -798 0 *
+Ed
+1 71 0 -14.167459403841 -2.16745940384101
+2 128 7 0 -14.167459403841 -2.16745940384101
+2 129 17 22 -14.167459403841 -2.16745940384101
+0
+0101000
++798 0 -800 0 *
+Wi
+0101100
++817 5 +937 0 +801 5 -799 5 -797 5 -796 5 *
+Fa
+0 1e-07 7 0
+0101000
++795 31 *
+Ve
+1e-07
+-1.5 1.24344978758018e-14 55.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 72 0 0 6.28318530717959
+2 130 46 0 0 6.28318530717959
+2 131 46 43 0 6.28318530717959
+4 CN 2 9 2 9
+2 132 47 31 0 6.28318530717959
+2 133 47 45 0 6.28318530717959
+2 134 48 31 0 6.28318530717959
+2 135 48 47 0 6.28318530717959
+0
+0101100
++793 0 -793 0 *
+Wi
+0101100
++792 5 *
+Ve
+1e-07
+8.90909090909091 5.55680656254596 55.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 73 0 0 0.557680629739399
+2 136 45 0 0 0.557680629739399
+2 137 2 9 0 0.557680629739399
+4 G1 45 0 2 9
+0
+0101100
++790 0 -807 0 *
+Ve
+0.0001
+-6.90000000596046 4.31363635984334 57.25
+0 0
+0101101
+Ed
+ 6.66133814775094e-15 1 1 0
+1 74 0 -17.722992107305 -4.98938115741738
+2 138 2 0 -17.722992107305 -4.98938115741738
+2 139 9 0 -17.722992107305 -4.98938115741738
+4 CN 9 38 9 38
+0
+0101000
++788 41 -936 41 *
+Ve
+1e-07
+8.90909090909091 -5.55680656254594 55.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 75 0 0.060706012146603 1.1760672716254
+2 140 49 0 0.060706012146603 1.1760672716254
+2 141 2 9 0.060706012146603 1.1760672716254
+4 G1 49 0 2 9
+0
+0101100
++786 0 -790 0 *
+Ve
+0.0001
+-6.90000000596046 -4.31363635984334 57.25
+0 0
+0101101
+Ed
+1 76 0 4.76136364313691 13.3886363628236
+2 142 2 10 4.76136364313691 13.3886363628236
+2 143 50 1 4.76136364313691 13.3886363628236
+0
+0101000
++784 0 -788 0 *
+Ve
+1e-07
+8 -8.73212459828648 55.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 77 0 0 0.557680629739399
+2 144 51 0 0 0.557680629739399
+2 145 2 9 0 0.557680629739399
+4 G1 51 0 2 9
+0
+0101100
++786 0 -782 0 *
+Ve
+0.0001
+3.84285715222357 -11.1500000059605 57.25
+0 0
+0101101
+Ed
+1 78 0 -21.4811205526573 -8.74750960276965
+2 146 2 0 -21.4811205526573 -8.74750960276965
+2 147 52 0 -21.4811205526573 -8.74750960276965
+4 CN 52 38 52 38
+0
+0101000
++784 41 -780 41 *
+Ve
+0.0001
+8 -11.1500000059605 57.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 79 0 0.0999999940395396 2.51787540171351
+2 148 53 0 0.0999999940395396 2.51787540171351
+2 149 2 9 0.0999999940395396 2.51787540171351
+4 G1 53 0 2 9
+0
+0101000
++778 31 -782 0 *
+Ed
+ 0 1 1 0
+1 80 0 15.2368180028471 19.3939608506235
+2 150 2 10 15.2368180028471 19.3939608506235
+2 151 13 1 15.2368180028471 19.3939608506235
+0
+0101000
++778 0 -780 0 *
+Wi
+0101100
++806 5 +935 0 +789 5 -787 10 +785 5 -783 0 -781 5 +779 10 +777 5 -776 0
+Fa
+0 1e-07 2 0
+0101000
+-791 41 +775 41 *
+Ve
+4.51755626041239e-06
+10.75 6.25000000000002 58.25
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 81 0 0 1.5707963267949
+2 152 8 0 0 1.5707963267949
+2 153 17 22 0 1.5707963267949
+0
+0101000
++773 0 -800 0 *
+Ed
+ 1e-07 1 1 0
+1 82 0 0.255210595859102 5.15521060181957
+2 154 8 0 0.255210595859102 5.15521060181957
+2 155 2 3 0.255210595859102 5.15521060181957
+4 G1 8 0 2 3
+0
+0101000
+-934 31 +773 0 *
+Wi
+0101100
+-799 5 +933 0 -772 5 +771 5 *
+Fa
+0 0 8 0
+0101000
++770 31 *
+Ve
+0.0001
+-6.90000000596046 4.31363635984334 60.25
+0 0
+0101101
+Ed
+ 1.88411095042053e-15 1 1 0
+1 83 0 -4932.375 -4929.375
+2 156 9 5 -4932.375 -4929.375
+2 157 50 1 -4932.375 -4929.375
+0
+0101000
++788 0 -768 0 *
+Ve
+2.000000002e-05
+-6.88573503494262 4.32271406867289 58.25
+0 0
+0101101
+Ed
+1 84 0 -17.722992107305 -17.7060837012379
+2 158 2 3 -17.722992107305 -17.7060837012379
+2 159 9 0 -17.722992107305 -17.7060837012379
+0
+0101000
++768 31 -766 0 *
+Ve
+2.000000002e-05
+-3.85714285714286 6.25000000000001 58.25
+0 0
+0101101
+Ed
+ 6.28429384001312e-15 1 1 0
+1 85 0 -14.1162645358033 -4.98938115741743
+2 160 2 3 -14.1162645358033 -4.98938115741743
+2 161 9 0 -14.1162645358033 -4.98938115741743
+0
+0101000
+-932 31 +764 0 *
+Ve
+2.000000002e-05
+-3.85714285714286 6.25000000000001 61.2785921777998
+0 0
+0101101
+Ed
+ 3.02633030411684e-14 1 1 0
+1 86 0 45.175567715677 49.8722870196116
+2 162 54 19 45.175567715677 49.8722870196116
+2 163 9 0 45.175567715677 49.8722870196116
+0
+0101000
++766 0 -762 0 *
+Ed
+ 1.07410850191483e-14 1 1 0
+1 87 0 -53.8611327739588 -50.832540596159
+2 164 17 22 -53.8611327739588 -50.832540596159
+2 165 9 0 -53.8611327739588 -50.832540596159
+0
+0101000
++762 0 -764 0 *
+Wi
+0101100
++787 10 -767 0 +931 0 -765 5 -763 5 -761 5 -760 5 *
+Fa
+0 1e-07 9 0
+0101000
++759 31 *
+Ed
+1 88 0 8.75 23.3571428571429
+2 166 2 3 8.75 23.3571428571429
+2 167 17 22 8.75 23.3571428571429
+0
+0101000
+-764 0 +773 0 *
+Wi
+0101100
+-763 5 +930 0 -757 5 +771 5 *
+Fa
+0 1e-07 2 0
+0101000
++756 48 *
+Ve
+1e-07
+13.5 12.75 29
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 89 0 0 1.59999999403952
+3 168 169CN 10 0 0 1.59999999403952
+0
+0101000
+-928 0 +754 0 *
+Ed
+ 1e-07 1 1 0
+1 90 0 0 6.28318530717959
+2 170 10 0 0 6.28318530717959
+2 171 10 50 0 6.28318530717959
+0
+0101100
++754 0 -754 0 *
+Wi
+0101100
++753 0 -927 0 -752 0 -753 0 *
+Fa
+0 1e-07 10 0
+0101000
++751 0 *
+Ed
+ 1e-07 1 1 0
+1 91 0 9994 10000
+2 172 12 0 9994 10000
+4 G1 18 0 12 0
+0
+0101000
++902 2 -854 2 *
+Wi
+0101100
++749 1 -898 0 +850 0 -920 1 *
+Fa
+0 1e-07 12 0
+0101000
++748 2 *
+Ve
+0.0001
+18.75 -11.1500000059605 38.0126131480163
+0 0
+0101101
+Ve
+1e-07
+18.75 -9.74999999999999 36.0126131480163
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 92 51 -0.75 0.650000005960461
+2 173 55 51 -0.75 0.650000005960461
+2 174 3 0 -0.75 0.650000005960461
+0
+0101000
+-746 16 +745 51 *
+Ed
+1 93 0 -5014.625 -5001.61238685198
+2 175 3 14 -5014.625 -5001.61238685198
+2 176 13 1 -5014.625 -5001.61238685198
+0
+0101000
++917 0 -746 0 *
+Ed
+ 1e-07 1 1 0
+1 94 0 0 13.0126131480163
+4 CN 3 0 3 0
+0
+0101000
++916 0 -745 51 *
+Wi
+0101100
++744 14 -743 0 +742 14 +915 14 *
+Fa
+0 1e-07 3 0
+0101000
++741 16 *
+Ed
+ 1e-07 1 1 0
+1 95 0 9994 10000
+0
+0101000
++914 2 -841 2 *
+Ve
+0.0001
+11 -11.1500000059605 54.25
+0 0
+0101101
+Ed
+1 96 0 4964.75 5000
+2 177 56 5 4964.75 5000
+2 178 13 1 4964.75 5000
+0
+0101000
++738 0 -837 0 *
+Ve
+0.0001
+13.75 -11.1500000059605 51.75
+0 0
+0101101
+Ed
+ 1.5348856403246e-12 1 1 0
+1 97 0 4682.09682806365 4696.71584983397
+2 179 55 5 4682.09682806365 4696.71584983397
+2 180 13 1 4682.09682806365 4696.71584983397
+0
+0101000
++736 0 -746 0 *
+Ed
+1 98 0 0 1.5707963267949
+2 181 53 5 0 1.5707963267949
+2 182 13 1 0 1.5707963267949
+0
+0101000
++778 0 -738 0 *
+Ve
+0.0001
+13.75 -11.1500000059605 57.25
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 99 0 -4987.875 -4982.375
+2 183 3 5 -4987.875 -4982.375
+2 184 13 1 -4987.875 -4982.375
+0
+0101000
++736 0 -733 0 *
+Ve
+0.0001
+10.75 -11.1500000059605 60.25
+0 0
+0101101
+Ed
+1 100 0 -3.5527136788005e-15 1.5707963267949
+2 185 57 5 -3.5527136788005e-15 1.5707963267949
+2 186 13 1 -3.5527136788005e-15 1.5707963267949
+0
+0101000
++731 0 -733 0 *
+Ve
+0.0001
+3.84285715222357 -11.1500000059605 60.25
+0 0
+0101101
+Ed
+1 101 0 4929.375 4932.375
+2 187 52 5 4929.375 4932.375
+2 188 13 1 4929.375 4932.375
+0
+0101000
++729 0 -780 0 *
+Ed
+ 0 1 1 0
+1 102 0 12.4868180028471 19.3939608506235
+2 189 2 11 12.4868180028471 19.3939608506235
+2 190 13 1 12.4868180028471 19.3939608506235
+0
+0101000
++731 0 -729 0 *
+Wi
+0101100
++739 1 -913 0 +836 0 -743 0 -737 0 +735 0 -734 0 -732 0 +776 0 +730 0
+-728 0 -727 0 *
+Ve
+3.060000002e-05
+13.5 -11.1500000059605 29
+0 0
+0101101
+Ed
+1 103 0 4.71238898038469 10.9955742875643
+2 191 13 1 4.71238898038469 10.9955742875643
+2 192 58 0 4.71238898038469 10.9955742875643
+0
+0101100
++725 0 -725 0 *
+Wi
+0101100
++724 0 *
+Fa
+0 1e-07 13 0
+0101000
++726 2 +723 2 *
+Ve
+2.62500002e-06
+17.6790854371029 -9.74999999999999 38.9549266752043
+0 0
+0101101
+Ed
+1 104 0 -21.9549266752043 -6
+2 193 59 0 -21.9549266752043 -6
+2 194 15 0 -21.9549266752043 -6
+0
+0101000
++721 0 -912 0 *
+Ed
+ 1e-07 1 1 0
+1 105 0 -1.0805116682698 2.05063299355898
+2 195 55 0 -1.0805116682698 2.05063299355898
+2 196 59 0 -1.0805116682698 2.05063299355898
+0
+0101000
++721 0 -745 0 *
+Wi
+0101100
++911 0 +720 0 +742 13 -719 0 *
+Fa
+0 1e-07 59 0
+0101000
++718 0 *
+Ed
+ 1e-07 1 1 0
+1 106 0 9994 10000
+2 197 16 0 9994 10000
+4 G1 14 0 16 0
+0
+0101000
++910 2 -845 2 *
+Wi
+0101100
++716 1 -909 0 +840 0 -739 1 *
+Fa
+0 1e-07 14 0
+0101000
++715 2 *
+Ve
+2.62500002e-06
+16.1158065649732 -10.9991622978524 43.25
+0 0
+0101101
+Ve
+1.38125308263389e-05
+17.6790854371029 -6.24999999999999 43.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 107 0 1.92696888630123 3.72021974342312
+2 198 15 0 1.92696888630123 3.72021974342312
+2 199 15 53 1.92696888630123 3.72021974342312
+0
+0101000
++713 53 -712 53 *
+Ed
+ 1e-08 1 1 0
+1 108 0 0.578627089833327 1.21462376728856
+2 200 55 0 0.578627089833327 1.21462376728856
+2 201 15 0 0.578627089833327 1.21462376728856
+0
+0101000
++721 0 -713 0 *
+Ed
+1 109 0 -26.25 -6
+2 202 17 20 -26.25 -6
+2 203 15 0 -26.25 -6
+0
+0101000
++712 0 -908 0 *
+Wi
+0101100
++711 52 +710 0 +709 0 -720 0 +907 0 *
+Fa
+0 1e-07 15 0
+0101000
++708 0 *
+Ed
+ 1e-07 1 1 0
+1 110 0 9994 10000
+2 204 16 0 9994 10000
+4 G1 16 0 18 0
+0
+0101000
++906 2 -847 2 *
+Wi
+0101100
++716 1 -905 0 +844 0 -706 1 *
+Fa
+0 1e-07 16 0
+0101000
++705 2 *
+Ve
+1e-07
+25.0168330344604 -6.24999999999999 48.3694023773397
+0 0
+0101101
+Ve
+4.02290257459661e-06
+25.0168330344604 -6.24999999999999 45.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 111 0 -3.54678460717576 -2.92738222983602
+0
+0101000
++703 55 -702 56 *
+Ve
+1e-07
+24.6551370761863 -6.24999999999999 49.5165553169535
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 112 0 0.959931047754832 1.5707963267949
+2 205 60 0 0.959931047754832 1.5707963267949
+2 206 17 54 0.959931047754832 1.5707963267949
+0
+0101000
++700 0 -703 0 *
+Ve
+3.46326051900294e-07
+19.8190486763091 -6.24999999999999 45.75
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 113 0 0.319048676309097 5.51683303446044
+2 207 17 20 0.319048676309097 5.51683303446044
+2 208 2 57 0.319048676309097 5.51683303446044
+0
+0101000
++698 0 -702 0 *
+Ve
+1e-07
+16.2309866966085 1.4210854715202e-14 59.5474878442378
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 114 0 3.88818163049481 18.5752387589262
+0
+0101000
+-700 55 +696 0 *
+Ve
+19.1928108611693 -6.24999999999999 45.25
+0 0
+0101101
+Ed
+ 3.46326051900294e-07 1 1 0
+1 115 0 0 1
+2 209 61 0 0 1
+2 210 17 20 0 1
+0
+0101000
++694 0 -698 0 *
+Ve
+1e-07
+12 1.4210854715202e-14 61.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 116 0 1.5707963267949 2.53072737454973
+2 211 62 58 1.5707963267949 2.53072737454973
+2 212 62 59 1.5707963267949 2.53072737454973
+0
+0101000
++692 0 -696 0 *
+Ed
+1 117 0 -28.25 -6
+2 213 17 20 -28.25 -6
+2 214 19 0 -28.25 -6
+0
+0101000
++694 0 -904 0 *
+Ve
+2.000000002e-05
+-3.38573503494262 -6.24999999999999 61.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 118 0 3.5 18.8857350349426
+0
+0101000
++689 58 -692 0 *
+Ve
+2.000000002e-05
+-3.85714285714286 -6.24999999999999 61.2785921777998
+0 0
+0101101
+Ed
+ 1.50728876033642e-14 1 1 0
+1 119 0 -4.28021815570446 -3.61354682014011
+2 215 17 18 -4.28021815570446 -3.61354682014011
+2 216 54 0 -4.28021815570446 -3.61354682014011
+0
+0101000
++687 61 -689 0 *
+Ve
+2.000000002e-05
+-3.85714285714286 -6.24999999999999 58.25
+0 0
+0101101
+Ed
+1 120 0 50.832540596159 53.8611327739588
+2 217 17 20 50.832540596159 53.8611327739588
+2 218 52 0 50.832540596159 53.8611327739588
+0
+0101000
++685 0 -687 0 *
+Ve
+13.75 -6.24999999999999 43.25
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 121 0 -5.75 -1.82091456289709
+2 219 17 20 -5.75 -1.82091456289709
+2 220 2 52 -5.75 -1.82091456289709
+0
+0101000
++683 0 -712 0 *
+Ve
+10.75 -6.24999999999999 58.25
+0 0
+0101101
+Ed
+1 122 0 8.75 23.3571428571429
+2 221 2 3 8.75 23.3571428571429
+2 222 17 20 8.75 23.3571428571429
+0
+0101000
+-685 0 +681 0 *
+Ve
+8.28115940667555e-05
+13.75 -6.24999999999999 55.25
+0 0
+0101101
+Ed
+1 123 0 -14.167459403841 -2.16745940384101
+2 223 3 0 -14.167459403841 -2.16745940384101
+2 224 17 20 -14.167459403841 -2.16745940384101
+0
+0101000
++683 0 -679 0 *
+Ed
+ 0 1 1 0
+1 124 0 0 1.5707963267949
+2 225 57 0 0 1.5707963267949
+2 226 17 20 0 1.5707963267949
+0
+0101000
++681 0 -679 0 *
+Wi
+0101100
++701 54 +699 0 -697 5 +695 54 -693 5 +691 54 +690 5 +688 54 +903 5 +686 60
+-709 5 +684 5 -682 5 +680 5 +678 5 -677 5 *
+Fa
+0 1e-07 17 0
+0101000
++676 55 *
+Ve
+0.0001
+26.9000000059605 -1.99999999999999 16
+0 0
+0101101
+Ed
+ 3.33066907387547e-16 1 1 0
+1 125 0 5000 5003
+2 227 63 0 5000 5003
+2 228 18 1 5000 5003
+0
+0101000
++849 0 -674 0 *
+Ve
+0.0001
+26.9000000059605 2.00000000000001 16
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 126 0 3.80540491629589 7.80540491629589
+2 229 64 62 3.80540491629589 7.80540491629589
+2 230 18 1 3.80540491629589 7.80540491629589
+0
+0101000
++674 0 -672 0 *
+Ed
+1 127 0 -5003 -5000
+2 231 65 0 -5003 -5000
+2 232 18 1 -5003 -5000
+0
+0101000
++672 0 -857 0 *
+Wi
+0101100
++706 1 -901 0 +846 0 -749 1 +673 0 +853 0 +671 0 +670 0 *
+Fa
+0 1e-07 18 0
+0101000
++669 2 *
+Ve
+1e-07
+26.5 -3.99999999999999 45.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 128 0 6 28.25
+2 233 19 0 6 28.25
+4 G1 19 0 20 0
+0
+0101000
+-667 0 +900 0 *
+Ed
+ 1e-07 1 1 0
+1 129 0 0 2.54418623694444
+2 234 61 0 0 2.54418623694444
+2 235 19 0 0 2.54418623694444
+4 G1 61 0 19 0
+0
+0101100
++694 0 -667 0 *
+Wi
+0101100
+-666 0 +665 0 +899 0 -690 0 *
+Fa
+0 1e-07 19 0
+0101000
++664 0 *
+Ve
+1e-07
+26.5 4.00000000000001 45.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 130 0 0 8
+2 236 66 0 0 8
+2 237 20 0 0 8
+4 G1 66 0 20 0
+0
+0101000
++667 0 -662 0 *
+Ed
+ 1e-07 1 1 0
+1 131 0 6 28.25
+2 238 21 0 6 28.25
+4 G1 20 0 21 0
+0
+0101000
+-662 0 +897 0 *
+Wi
+0101100
++666 0 +661 0 +896 0 -660 0 *
+Fa
+0 1e-07 20 0
+0101000
++659 0 *
+Ve
+3.46326112341981e-07
+19.1928108611693 6.25000000000001 45.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 132 0 0 2.54418623694444
+2 239 67 0 0 2.54418623694444
+2 240 21 0 0 2.54418623694444
+4 G1 67 0 21 0
+0
+0101100
++662 0 -657 0 *
+Ed
+1 133 0 -28.25 -6
+2 241 17 22 -28.25 -6
+2 242 21 0 -28.25 -6
+0
+0101000
++657 0 -895 0 *
+Wi
+0101100
++660 0 +656 0 +894 0 +655 0 *
+Fa
+0 1e-07 21 0
+0101000
++654 0 *
+Ve
+1e-07
+25.0168330344604 6.25000000000001 48.3694023773397
+0 0
+0101101
+Ve
+25.0168330344604 6.25000000000001 45.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+0
+0101000
++652 64 -651 65 *
+Ve
+1e-07
+24.6551370761863 6.25000000000001 49.5165553169535
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 134 0 0.959931047754832 1.5707963267949
+2 243 68 0 0.959931047754832 1.5707963267949
+2 244 17 63 0.959931047754832 1.5707963267949
+0
+0101000
++649 0 -652 0 *
+Ve
+19.8190486763091 6.25000000000001 45.75
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 135 0 0.319048676309098 5.51683303446044
+2 245 17 22 0.319048676309098 5.51683303446044
+2 246 2 57 0.319048676309098 5.51683303446044
+0
+0101000
++647 0 -651 0 *
+Ed
+ 1e-07 1 1 0
+0
+0101000
+-649 64 +696 0 *
+Ed
+ 3.46326112341981e-07 1 1 0
+1 136 0 0 1
+2 247 67 0 0 1
+2 248 17 22 0 1
+0
+0101000
++657 0 -647 0 *
+Ve
+2.000000002e-05
+-3.38573503494262 6.25000000000001 61.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+0
+0101000
++643 59 -692 0 *
+Ed
+ 2.14821700382967e-14 1 1 0
+1 137 0 -4.28021815570445 -3.61354682014011
+2 249 17 66 -4.28021815570445 -3.61354682014011
+2 250 54 0 -4.28021815570445 -3.61354682014011
+0
+0101000
++762 61 -643 0 *
+Ve
+17.6790854371029 6.25000000000001 43.25
+0 0
+0101101
+Ed
+1 138 0 -26.25 -6
+2 251 17 22 -26.25 -6
+2 252 22 0 -26.25 -6
+0
+0101000
++640 0 -893 0 *
+Ed
+ 1e-08 1 1 0
+1 139 0 -5.75 -1.82091456289709
+2 253 17 22 -5.75 -1.82091456289709
+2 254 2 40 -5.75 -1.82091456289709
+0
+0101000
++798 0 -640 0 *
+Wi
+0101100
++650 63 +648 0 -646 5 +645 63 -644 5 +691 63 +655 5 +642 63 +892 5 +641 60
+-639 5 -760 5 -638 5 +757 5 +796 5 -772 5 *
+Fa
+0 1e-07 17 0
+0101000
++637 64 *
+Ed
+ 1e-07 1 1 0
+1 140 0 2.56296556375646 4.35621642087836
+2 255 69 0 2.56296556375646 4.35621642087836
+2 256 69 68 2.56296556375646 4.35621642087836
+2 257 22 0 2.56296556375646 4.35621642087836
+2 258 22 69 2.56296556375646 4.35621642087836
+0
+0101000
++640 69 -814 69 *
+Ed
+1 141 0 -21.9549266752044 -6
+2 259 44 0 -21.9549266752044 -6
+2 260 22 0 -21.9549266752044 -6
+0
+0101000
++812 0 -889 0 *
+Wi
+0101100
++635 40 -639 0 -810 0 +888 0 +634 0 *
+Fa
+0 1e-07 22 0
+0101000
++633 0 *
+Wi
+0101100
++887 0 +634 0 +826 7 -811 0 *
+Fa
+0 1e-07 44 0
+0101000
++631 0 *
+Ed
+ 1e-07 1 1 0
+1 142 0 0 3
+2 261 23 0 0 3
+0
+0101000
++884 0 -884 25 *
+Ed
+ 1e-07 1 1 0
+1 143 0 0 3
+2 262 23 0 0 3
+2 263 24 0 0 3
+0
+0101000
++883 0 -883 25 *
+Wi
+0101000
++629 0 -628 0 -882 0 +882 25 *
+Fa
+0 1e-07 23 0
+0101000
++627 0 *
+Ed
+ 1e-07 1 1 0
+1 144 0 0 3
+2 264 25 0 0 3
+2 265 24 0 0 3
+0
+0101000
++881 0 -881 25 *
+Wi
+0101000
++628 0 -625 0 -880 0 +880 25 *
+Fa
+0 1e-07 24 0
+0101000
++624 0 *
+Ed
+ 1e-07 1 1 0
+1 145 0 0 3
+2 266 25 0 0 3
+0
+0101000
++879 0 -879 25 *
+Wi
+0101000
++625 0 -622 0 -878 0 +878 25 *
+Fa
+0 1e-07 25 0
+0101000
++621 0 *
+Ed
+ 1e-07 1 1 0
+1 146 0 0 3
+0
+0101000
++877 0 -877 25 *
+Wi
+0101000
++619 0 -622 0 -876 0 +876 25 *
+Fa
+0 1e-07 70 0
+0101000
++618 0 *
+Ed
+ 1e-07 1 1 0
+1 147 0 0 3
+2 267 27 0 0 3
+4 G1 27 0 71 0
+0
+0101000
++875 0 -875 25 *
+Wi
+0101000
++619 0 -616 0 -874 0 +874 25 *
+Fa
+0 1e-07 71 0
+0101000
++615 0 *
+Ed
+ 1e-07 1 1 0
+1 148 0 0 3
+2 268 27 0 0 3
+4 G1 72 0 27 0
+0
+0101000
++873 0 -873 25 *
+Wi
+0101000
++613 0 -616 0 -872 0 +872 25 *
+Fa
+0 1e-07 27 0
+0101000
++612 0 *
+Ed
+ 1e-07 1 1 0
+1 149 0 0 3
+2 269 29 0 0 3
+4 G1 29 0 72 0
+0
+0101000
++871 0 -871 25 *
+Wi
+0101000
++610 0 -613 0 -870 0 +870 25 *
+Fa
+0 1e-07 72 0
+0101000
++609 0 *
+Ed
+ 1e-07 1 1 0
+1 150 0 0 3
+2 270 29 0 0 3
+4 G1 73 0 29 0
+0
+0101000
++869 0 -869 25 *
+Wi
+0101000
++607 0 -610 0 -868 0 +868 25 *
+Fa
+0 1e-07 29 0
+0101000
++606 0 *
+Ed
+ 1e-07 1 1 0
+1 151 0 0 3
+0
+0101000
++867 0 -867 25 *
+Wi
+0101000
++607 0 -604 0 -866 0 +866 25 *
+Fa
+0 1e-07 73 0
+0101000
++603 0 *
+Wi
+0101000
++604 0 -629 0 -865 0 +865 25 *
+Fa
+0 1e-07 74 0
+0101000
++601 0 *
+Ed
+ 1e-07 1 1 0
+1 152 0 0 3
+3 271 272CN 30 0 0 3
+0
+0101000
++863 0 -863 27 *
+Wi
+0101000
++599 0 -599 0 -862 0 +862 27 *
+Fa
+0 1e-07 30 0
+0101000
++598 0 *
+Ed
+ 1e-07 1 1 0
+1 153 0 0 3
+3 273 274CN 31 0 0 3
+0
+0101000
++860 0 -860 29 *
+Wi
+0101000
++596 0 -596 0 -859 0 +859 29 *
+Fa
+0 1e-07 31 0
+0101000
++595 0 *
+Ed
+ 1e-07 1 1 0
+1 154 0 0 3
+0
+0101000
++856 5 -856 70 *
+Ed
+ 1e-07 1 1 0
+4 CN 2 0 2 0
+0
+0101000
+-672 71 +856 0 *
+Wi
+0101100
+-855 5 +670 0 +593 0 +592 70 *
+Fa
+0 1e-07 65 0
+0101000
++591 0 *
+Ed
+ 1e-07 1 1 0
+1 155 0 0 3
+0
+0101000
++852 5 -852 70 *
+Wi
+0101000
++589 0 -593 0 -851 5 +851 70 *
+Fa
+0 1e-07 75 0
+0101000
++588 0 *
+Ed
+ 1e-07 1 1 0
+4 CN 2 0 2 0
+0
+0101000
++674 71 -852 0 *
+Wi
+0101100
+-848 5 +673 0 -589 0 +586 70 *
+Fa
+0 1e-07 63 0
+0101000
++585 0 *
+Ve
+1e-07
+11.4545454545455 7.14446558041623 52.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 156 0 0 35.25
+2 275 32 0 0 35.25
+2 276 36 0 0 35.25
+4 G1 32 0 36 0
+0
+0101000
++839 0 -583 0 *
+Ed
+ 1e-07 1 1 0
+1 157 0 0 0.557680629739399
+2 277 32 0 0 0.557680629739399
+2 278 45 0 0 0.557680629739399
+4 G1 45 0 32 0
+0
+0101100
++583 0 -823 0 *
+Wi
+0101100
++838 0 -821 0 +582 0 +581 0 *
+Fa
+0 0 32 0
+0101000
++580 0 *
+Ve
+1e-07
+11.4545454545455 -7.14446558041621 52.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 158 0 0 35.25
+2 279 40 0 0 35.25
+2 280 36 0 0 35.25
+4 G1 40 0 36 0
+0
+0101000
++835 0 -578 0 *
+Ed
+ 1e-07 1 1 0
+1 159 0 0.060706012146603 1.1760672716254
+2 281 49 0 0.060706012146603 1.1760672716254
+2 282 36 0 0.060706012146603 1.1760672716254
+4 G1 49 0 36 0
+0
+0101100
++578 0 -583 0 *
+Wi
+0101100
+-834 0 +577 0 -582 0 +576 0 *
+Fa
+0 1e-07 36 0
+0101000
++575 0 *
+Ve
+1e-07
+11 -8.73212459828648 52.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 160 0 0.0999999940395503 2.51787540171351
+2 283 53 0 0.0999999940395503 2.51787540171351
+2 284 56 0 0.0999999940395503 2.51787540171351
+4 G1 53 0 56 0
+0
+0101000
++738 31 -573 0 *
+Ed
+ 1e-07 1 1 0
+1 161 0 0 35.25
+2 285 40 0 0 35.25
+2 286 56 0 0 35.25
+4 G1 40 0 56 0
+0
+0101000
++833 0 -573 0 *
+Wi
+0101100
++572 5 -737 0 -571 5 -832 5 *
+Fa
+0 1e-07 56 0
+0101000
++570 31 *
+Ed
+ 1e-07 1 1 0
+1 162 0 0 0.557680629739399
+2 287 40 0 0 0.557680629739399
+2 288 51 0 0 0.557680629739399
+4 G1 51 0 40 0
+0
+0101100
++578 0 -573 0 *
+Wi
+0101100
++831 0 -577 0 +571 0 -568 0 *
+Fa
+0 0 40 0
+0101000
++567 0 *
+Ed
+ 1e-08 1 1 0
+1 163 0 4.25919343502677 6.625
+2 289 44 0 4.25919343502677 6.625
+2 290 2 40 4.25919343502677 6.625
+0
+0101000
++816 0 -802 0 *
+Wi
+0101100
+-815 0 -565 0 -801 0 *
+Fa
+0 1e-07 44 0
+0101000
++564 0 *
+Wi
+0101100
++635 40 +638 0 +813 0 +797 0 +565 0 *
+Fa
+0 1e-07 2 0
+0101000
++562 69 *
+Ed
+ 1e-07 1 1 0
+1 164 0 1.5707963267949 3.14159265358979
+2 291 49 0 1.5707963267949 3.14159265358979
+2 292 45 0 1.5707963267949 3.14159265358979
+4 G1 45 0 49 0
+0
+0101100
++790 0 -583 0 *
+Wi
+0101100
+-560 0 +789 0 -581 0 +805 0 *
+Fa
+0 0 45 0
+0101000
++559 0 *
+Ed
+ 1e-07 1 1 0
+1 165 0 0 2
+3 293 294CN 48 0 0 2
+0
+0101000
++793 5 -793 73 *
+Wi
+0101000
++557 0 -557 0 -792 5 +792 73 *
+Fa
+0 1e-07 48 0
+0101000
++556 0 *
+Ed
+ 1e-07 1 1 0
+1 166 0 1.5707963267949 3.14159265358979
+2 295 49 0 1.5707963267949 3.14159265358979
+2 296 51 0 1.5707963267949 3.14159265358979
+4 G1 51 0 49 0
+0
+0101100
++786 0 -578 0 *
+Wi
+0101100
+-554 0 +785 0 -576 0 +560 0 *
+Fa
+0 0 49 0
+0101000
++553 0 *
+Ve
+0.0001
+-6.90000000596046 -4.31363635984331 60.25
+0 0
+0101101
+Ed
+1 167 0 4.76136364313691 13.3886363628236
+2 297 2 11 4.76136364313691 13.3886363628236
+2 298 50 1 4.76136364313691 13.3886363628236
+0
+0101000
++551 0 -768 0 *
+Ed
+1 168 0 -4932.375 -4929.375
+2 299 52 5 -4932.375 -4929.375
+2 300 50 1 -4932.375 -4929.375
+0
+0101000
++784 0 -551 0 *
+Wi
+0101100
+-550 0 -549 0 +767 0 +783 0 *
+Fa
+0 1e-07 50 0
+0101000
++548 2 *
+Ed
+ 1e-07 1 1 0
+1 169 0 1.5707963267949 3.14159265358979
+2 301 53 0 1.5707963267949 3.14159265358979
+2 302 51 0 1.5707963267949 3.14159265358979
+4 G1 51 0 53 0
+0
+0101100
++782 0 -573 0 *
+Wi
+0101100
+-554 0 +781 0 -568 0 +546 0 *
+Fa
+0 0 51 0
+0101000
++545 0 *
+Ve
+2.000000002e-05
+-6.88573503494262 -4.32271406867287 58.25
+0 0
+0101101
+Ed
+1 170 0 -21.4811205526572 -21.46421214659
+2 303 2 3 -21.4811205526572 -21.46421214659
+2 304 52 0 -21.4811205526572 -21.46421214659
+0
+0101000
++551 31 -543 0 *
+Ed
+ 4.80355925098406e-15 1 1 0
+1 171 0 -17.8743929811554 -8.74750960276959
+2 305 2 3 -17.8743929811554 -8.74750960276959
+2 306 52 0 -17.8743929811554 -8.74750960276959
+0
+0101000
+-729 31 +685 0 *
+Ed
+ 1.73194791841524e-14 1 1 0
+1 172 0 6.70551141264096 11.4022307165755
+2 307 54 19 6.70551141264096 11.4022307165755
+2 308 52 0 6.70551141264096 11.4022307165755
+0
+0101000
++543 0 -687 0 *
+Wi
+0101100
++779 10 -549 0 -728 0 -542 5 -541 5 -540 5 +684 5 *
+Fa
+0 1e-07 52 0
+0101000
++539 31 *
+Wi
+0101100
+-777 5 +734 0 -546 5 +572 5 *
+Fa
+0 0 53 0
+0101000
++537 31 *
+Ed
+ 1e-07 1 1 0
+1 173 0 89.4272859313271 98.0727140686729
+0
+0101000
+-766 61 +543 61 *
+Wi
+0101100
+-765 5 -550 0 +535 60 +542 5 *
+Fa
+0 1e-07 2 0
+0101000
++534 48 *
+Ed
+ 1e-07 1 1 0
+1 174 0 87.5 100
+0
+0101000
++689 0 -643 0 *
+Wi
+0101100
+-535 19 -761 0 +540 0 -641 19 +686 19 +532 19 *
+Fa
+0 1e-07 54 0
+0101000
++531 61 *
+Wi
+0101000
++752 0 *
+Fa
+0 1e-07 76 0
+0101000
++529 0 *
+Ve
+1e-07
+13.75 -9.74999999999999 49.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 175 0 -0.75 0.650000005960451
+2 309 55 0 -0.75 0.650000005960451
+2 310 3 0 -0.75 0.650000005960451
+0
+0101000
+-736 31 +527 0 *
+Ve
+16.1158065649732 -9.74999999999999 43.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 105 0 -12.5683887767598 -5.65123324121845
+2 195 55 0 -12.5683887767598 -5.65123324121845
+2 196 59 0 -12.5683887767598 -5.65123324121845
+0
+0101000
+-525 0 +527 0 *
+Ed
+ 1e-08 1 1 0
+1 176 0 -2.62416229785244 -1.375
+2 311 55 0 -2.62416229785244 -1.375
+2 312 2 52 -2.62416229785244 -1.375
+0
+0101000
++713 0 -525 0 *
+Wi
+0101100
+-526 5 -735 0 +524 5 +744 14 -523 5 +719 5 -710 5 *
+Fa
+0 1e-07 55 0
+0101000
++522 31 *
+Ve
+13.75 -9.74999999999999 43.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 94 0 20.25 26.75
+4 CN 3 0 3 0
+0
+0101000
++520 0 -527 0 *
+Ed
+ 1e-07 1 1 0
+1 177 0 0.0999999940395497 5
+2 313 57 0 0.0999999940395497 5
+2 314 3 0 0.0999999940395497 5
+4 G1 57 0 3 0
+0
+0101000
++733 31 -679 0 *
+Ed
+ 1e-08 1 1 0
+1 178 0 -2.875 0.625
+2 315 3 0 -2.875 0.625
+2 316 2 52 -2.875 0.625
+0
+0101000
++683 0 -520 0 *
+Wi
+0101100
+-526 5 -732 0 -519 5 -518 5 -517 5 +678 5 *
+Fa
+0 1e-07 3 0
+0101000
++516 31 *
+Ed
+ 1e-07 1 1 0
+1 179 0 0.0999999940395391 5
+2 317 57 0 0.0999999940395391 5
+2 318 2 3 0.0999999940395391 5
+4 G1 57 0 2 3
+0
+0101000
++731 31 -681 0 *
+Wi
+0101100
+-518 5 -730 0 +677 5 +514 5 *
+Fa
+0 0 57 0
+0101000
++513 31 *
+Wi
+0101100
++541 5 -727 0 +680 5 +514 5 *
+Fa
+0 1e-07 2 0
+0101000
++511 48 *
+Ve
+1e-07
+13.5 -12.75 29
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 180 0 0 1.59999999403955
+3 319 320CN 58 0 0 1.59999999403955
+0
+0101000
+-725 0 +509 0 *
+Ed
+ 1e-07 1 1 0
+1 181 0 0 6.28318530717959
+2 321 58 0 0 6.28318530717959
+2 322 58 75 0 6.28318530717959
+0
+0101100
++509 0 -509 0 *
+Wi
+0101100
++508 0 +724 0 -507 0 -508 0 *
+Fa
+0 1e-07 58 0
+0101000
++506 0 *
+Ed
+ 1e-08 1 1 0
+1 182 0 4.25919343502677 6.625
+2 323 59 0 4.25919343502677 6.625
+2 324 2 52 4.25919343502677 6.625
+0
+0101000
++525 0 -520 0 *
+Wi
+0101100
++711 52 -523 0 -682 0 -504 0 +517 0 *
+Fa
+0 1e-07 2 0
+0101000
++503 53 *
+Ve
+1e-07
+25.0168330344604 -4.74999999999999 48.3694023773397
+0 0
+0101101
+Ve
+9.60688378529136e-06
+25.0168330344604 -4.74999999999999 45.75
+0 0
+0101101
+Ed
+1 183 0 8.00559762266025 8.625
+2 325 77 0 8.00559762266025 8.625
+2 326 78 0 8.00559762266025 8.625
+0
+0101000
++501 77 -500 61 *
+Ed
+ 1e-07 1 1 0
+1 184 0 -0 1.5
+2 327 60 0 -0 1.5
+2 328 77 60 -0 1.5
+4 G1 60 0 77 60
+0
+0101000
++703 0 -501 0 *
+Ed
+ 1e-08 1 1 0
+1 185 0 0.375 1.875
+2 329 77 19 0.375 1.875
+2 330 2 57 0.375 1.875
+0
+0101000
++702 0 -500 0 *
+Wi
+0101100
++499 60 +498 0 -497 5 -701 54 *
+Fa
+0 1e-07 77 0
+0101000
++496 77 *
+Ve
+1e-07
+24.6551370761863 -4.74999999999999 49.5165553169535
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 186 0 -0 1.5
+2 331 60 0 -0 1.5
+2 332 79 60 -0 1.5
+4 G1 60 0 79 60
+0
+0101000
++700 0 -494 0 *
+Ed
+ 1e-07 1 1 0
+1 187 0 0.959931047754832 1.5707963267949
+2 333 60 0 0.959931047754832 1.5707963267949
+2 334 78 60 0.959931047754832 1.5707963267949
+0
+0101000
++494 0 -501 0 *
+Wi
+0101100
++699 0 -493 0 +498 0 -492 0 *
+Fa
+0 0 60 0
+0101000
++491 0 *
+Ve
+1.81180119621372e-07
+19.0813014172057 -4.74999999999999 45.75
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 188 0 -7.99324158206191 -2.05770996480714
+2 335 78 19 -7.99324158206191 -2.05770996480714
+2 336 2 57 -7.99324158206191 -2.05770996480714
+0
+0101000
++489 0 -500 0 *
+Ve
+1e-07
+19 -3.99999999999999 45.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 189 0 0 0.215960498684956
+2 337 80 0 0 0.215960498684956
+2 338 2 57 0 0.215960498684956
+4 G1 80 0 2 57
+0
+0101100
++487 0 -489 0 *
+Ve
+1e-07
+19 -0.749999999999986 45.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 190 0 0 3.25
+2 339 81 0 0 3.25
+2 340 2 57 0 3.25
+4 G1 81 0 2 57
+0
+0101000
++485 0 -487 0 *
+Ve
+6.59317044100071e-06
+25.0168330344604 -0.749999999999986 45.75
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 191 0 -9.55230382877273 -3.53547079431229
+2 341 82 19 -9.55230382877273 -3.53547079431229
+2 342 2 57 -9.55230382877273 -3.53547079431229
+0
+0101000
+-485 0 +483 0 *
+Ve
+1e-07
+26 -3.99999999999999 45.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 192 0 0.10081605671721 2.54418623694444
+2 343 61 0 0.10081605671721 2.54418623694444
+2 344 2 57 0.10081605671721 2.54418623694444
+4 G1 61 0 2 57
+0
+0101100
++698 0 -481 0 *
+Ve
+6.59317037424796e-06
+25.0168330344604 0.750000000000014 45.75
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 193 0 5.875 7.375
+2 345 77 19 5.875 7.375
+2 346 2 57 5.875 7.375
+0
+0101000
++483 0 -479 0 *
+Ve
+1e-07
+26 4.00000000000001 45.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 194 0 0 8
+2 347 66 0 0 8
+2 348 2 57 0 8
+4 G1 66 0 2 57
+0
+0101000
++481 0 -477 0 *
+Ve
+1e-07
+19 0.750000000000014 45.75
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 195 0 -9.55230382877273 -3.53547079431229
+2 349 83 19 -9.55230382877273 -3.53547079431229
+2 350 2 57 -9.55230382877273 -3.53547079431229
+0
+0101000
+-475 0 +479 0 *
+Ed
+ 1e-07 1 1 0
+1 196 0 0 2.44337018022723
+2 351 67 0 0 2.44337018022723
+2 352 2 57 0 2.44337018022723
+4 G1 67 0 2 57
+0
+0101100
++477 0 -647 0 *
+Ve
+1e-07
+19 4.00000000000001 45.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 197 0 0 3.25
+2 353 84 0 0 3.25
+2 354 2 57 0 3.25
+4 G1 84 0 2 57
+0
+0101000
++475 0 -472 0 *
+Ve
+19.0813014172057 4.75000000000001 45.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 198 0 0 0.215960498684956
+2 355 85 0 0 0.215960498684956
+2 356 2 57 0 0.215960498684956
+4 G1 85 0 2 57
+0
+0101100
++472 0 -470 0 *
+Ve
+2.55535477580914e-06
+25.0168330344604 4.75000000000001 45.75
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 199 0 11.375 12.875
+2 357 77 19 11.375 12.875
+2 358 2 57 11.375 12.875
+0
+0101000
++468 0 -651 0 *
+Ed
+ 1e-08 1 1 0
+1 200 0 -7.99324158206191 -2.05770996480714
+2 359 86 19 -7.99324158206191 -2.05770996480714
+2 360 2 57 -7.99324158206191 -2.05770996480714
+0
+0101000
++470 0 -468 0 *
+Wi
+0101100
++488 0 +486 0 -497 0 +484 0 -697 0 +482 0 +480 0 -478 0 +476 0 -474 0
++473 0 -471 0 +646 0 -469 0 -467 0 -466 0 *
+Fa
+0 1e-07 2 0
+0101000
++465 79 *
+Ve
+1.000000002e-05
+16.2309866966085 -4.74999999999999 59.5474878442378
+0 0
+0101101
+Ed
+ 1.19161639355869e-14 1 1 0
+1 201 0 -2.22908628561616 12.4579708428152
+2 361 79 0 -2.22908628561616 12.4579708428152
+2 362 78 0 -2.22908628561616 12.4579708428152
+0
+0101000
+-494 77 +463 0 *
+Ed
+ 1e-07 1 1 0
+1 202 0 0 1.5
+2 363 62 0 0 1.5
+4 G1 62 0 79 0
+0
+0101000
+-463 0 +696 18 *
+Wi
+0101100
++462 60 -493 0 +461 60 -695 54 *
+Fa
+0 1e-07 79 0
+0101000
++460 77 *
+Ed
+ 1e-07 1 1 0
+1 203 0 0 1.5707963267949
+2 364 61 0 0 1.5707963267949
+2 365 66 0 0 1.5707963267949
+4 G1 61 0 66 0
+0
+0101100
++667 0 -481 0 *
+Wi
+0101100
+-693 0 +665 0 -480 0 +458 0 *
+Fa
+0 0 61 0
+0101000
++457 0 *
+Ve
+1.000000002e-05
+12 -4.74999999999999 61.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 204 0 0 1.5
+2 366 62 0 0 1.5
+4 G1 62 0 87 0
+0
+0101000
+-455 0 +692 18 *
+Ed
+ 0 1 1 0
+1 205 0 2.18166160583496 3.14159265358979
+2 367 62 0 2.18166160583496 3.14159265358979
+2 368 78 0 2.18166160583496 3.14159265358979
+0
+0101000
++463 0 -455 0 *
+Wi
+0101100
++454 0 -453 0 -691 18 -461 0 *
+Fa
+0 1e-07 62 0
+0101000
++452 0 *
+Ve
+1e-07
+1.55924001544396 -4.74999999999999 61.75
+0 0
+0101101
+Ve
+1e-07
+-1.88573503494262 -4.74999999999999 61.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 206 0 20.0096267142924 23.454601764679
+4 CN 87 0 87 0
+0
+0101000
++450 0 -449 0 *
+Ve
+1e-07
+-1.88573503494262 -3.52760589890507 61.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 207 0 1.5 2.72239410109492
+4 CN 87 0 87 0
+0
+0101000
++449 0 -447 0 *
+Ve
+1e-07
+1.10215267118867 -3.84516052842941 61.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 208 0 1.29164683019059 2.06171215809096
+2 369 88 0 1.29164683019059 2.06171215809096
+2 370 88 81 1.29164683019059 2.06171215809096
+4 CN 87 0 87 0
+0
+0101000
++445 0 -447 0 *
+Ed
+ 1e-07 1 1 0
+1 209 0 3.92905841137543 4.9427957094909
+4 CN 87 0 87 0
+0
+0101000
++445 0 -450 0 *
+Wi
+0101100
++448 0 +446 0 -444 0 +443 0 *
+Ve
+2.000000002e-05
+-1.88573503494263 3.5276058989051 61.75
+0 0
+0101101
+Ve
+2.000000002e-05
+1.10215267118867 3.84516052842944 61.75
+0 0
+0101101
+Ed
+ 1.48952049194836e-15 1 1 0
+1 210 0 5.79226947588352 6.56233480378389
+2 371 87 0 5.79226947588352 6.56233480378389
+2 372 89 0 5.79226947588352 6.56233480378389
+0
+0101000
++441 0 -440 0 *
+Ve
+2.000000002e-05
+-1.88573503494262 4.75000000000001 61.75
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 211 0 4.88880294945254 6.11119705054746
+2 373 87 0 4.88880294945254 6.11119705054746
+2 374 90 0 4.88880294945254 6.11119705054746
+0
+0101000
++441 0 -438 0 *
+Ve
+2.000000002e-05
+1.55924001544396 4.75000000000001 61.75
+0 0
+0101101
+Ed
+1 212 0 6.30620088633296 7.31993818444844
+2 375 87 0 6.30620088633296 7.31993818444844
+2 376 91 0 6.30620088633296 7.31993818444844
+0
+0101000
++440 0 -436 0 *
+Ed
+1 213 0 2.5 5.94497505038658
+2 377 87 0 2.5 5.94497505038658
+2 378 92 0 2.5 5.94497505038658
+0
+0101000
++438 0 -436 0 *
+Wi
+0101100
++439 0 -437 0 +435 0 -434 0 *
+Ve
+1.000000002e-05
+12 4.75000000000001 61.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 204 0 11 12.5
+2 366 62 0 11 12.5
+4 G1 62 0 87 0
+0
+0101000
++432 0 -692 66 *
+Ve
+1e-07
+3.23976567214837 4.75000000000001 61.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 214 0 9.56886672973633 18.329101057588
+0
+0101000
++432 0 -430 0 *
+Ve
+1e-07
+2.44101946624395 3.16882059533483 61.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 215 0 3.92905841137543 5.70053344963706
+0
+0101000
++428 0 -430 0 *
+Ve
+1e-07
+3.23976567214837 -4.74999999999999 61.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 216 0 9.56886672973633 18.329101057588
+0
+0101000
++455 0 -426 0 *
+Ve
+1e-07
+3.92905841137543 0.750000000000014 61.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 217 0 0.188616386175404 0.914414057839782
+2 379 93 0 0.188616386175404 0.914414057839782
+2 380 93 83 0.188616386175404 0.914414057839782
+0
+0101000
++424 0 -428 0 *
+Ve
+1e-07
+2.44101946624395 -3.16882059533481 61.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 218 0 3.92905841137543 5.70053344963706
+0
+0101000
++422 0 -426 0 *
+Ve
+1.000000002e-05
+12 0.750000000000014 61.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 219 0 -10.0717587916458 -2.00081720302127
+0
+0101000
+-420 0 +424 0 *
+Ve
+1e-07
+3.92905841137543 -0.749999999999986 61.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 220 0 0.188616386175404 0.914414057839782
+2 381 94 0 0.188616386175404 0.914414057839782
+2 382 94 85 0.188616386175404 0.914414057839782
+0
+0101000
++418 0 -422 0 *
+Ve
+1.000000002e-05
+12 -0.749999999999986 61.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 204 0 5.5 7
+2 366 62 0 5.5 7
+4 G1 62 0 87 0
+0
+0101000
+-420 0 +416 0 *
+Ed
+ 1e-07 1 1 0
+1 221 0 -10.0717587916458 -2.00081720302127
+0
+0101000
+-416 0 +418 0 *
+Wi
+0101100
++642 66 +532 0 -431 0 -688 18 +429 0 -454 0 -427 0 -425 0 -423 0 +421 0
++419 0 +417 0 -415 0 -414 0 *
+Ve
+1e-07
+-2.5 1.4210854715202e-14 63.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 222 0 0 6.28318530717959
+2 383 95 0 0 6.28318530717959
+2 384 95 87 0 6.28318530717959
+0
+0101100
++412 0 -412 0 *
+Wi
+0101100
++411 0 *
+Fa
+0 1e-07 87 0
+0101000
+-442 0 +433 0 +413 0 -410 77 *
+Wi
+0101100
+-592 70 +671 0 -851 70 -586 70 *
+Fa
+0 1e-07 64 0
+0101000
++408 88 *
+Ed
+ 1e-07 1 1 0
+1 223 0 0 1.5707963267949
+2 385 66 0 0 1.5707963267949
+2 386 67 0 0 1.5707963267949
+4 G1 66 0 67 0
+0
+0101100
++662 0 -477 0 *
+Wi
+0101100
++458 0 -661 0 +476 0 -406 0 *
+Fa
+0 0 66 0
+0101000
++405 0 *
+Wi
+0101100
+-406 0 +656 0 -473 0 +644 0 *
+Fa
+0 0 67 0
+0101000
++403 0 *
+Ve
+1e-07
+25.0168330344604 4.75000000000001 48.3694023773397
+0 0
+0101101
+Ed
+1 224 0 8.00559762266025 8.625
+2 387 77 0 8.00559762266025 8.625
+2 388 86 0 8.00559762266025 8.625
+0
+0101000
++401 77 -468 61 *
+Ed
+ 1e-07 1 1 0
+1 225 0 -0 1.5
+2 389 68 0 -0 1.5
+2 390 77 60 -0 1.5
+4 G1 68 0 77 60
+0
+0101000
++401 0 -652 0 *
+Wi
+0101100
+-400 60 +399 0 -467 5 +650 63 *
+Fa
+0 1e-07 77 0
+0101000
++398 77 *
+Ve
+1e-07
+24.6551370761863 4.75000000000001 49.5165553169535
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 226 0 0.959931047754832 1.5707963267949
+2 391 68 0 0.959931047754832 1.5707963267949
+2 392 86 60 0.959931047754832 1.5707963267949
+0
+0101000
++396 0 -401 0 *
+Ed
+ 1e-07 1 1 0
+1 227 0 -0 1.5
+2 393 68 0 -0 1.5
+2 394 79 60 -0 1.5
+4 G1 68 0 79 60
+0
+0101000
++396 0 -649 0 *
+Wi
+0101100
++395 0 -394 0 +399 0 -648 0 *
+Fa
+0 0 68 0
+0101000
++393 0 *
+Ve
+1.000000002e-05
+16.2309866966085 4.75000000000001 59.5474878442378
+0 0
+0101101
+Ed
+1 228 0 -2.22908628561616 12.4579708428152
+2 395 79 0 -2.22908628561616 12.4579708428152
+2 396 86 0 -2.22908628561616 12.4579708428152
+0
+0101000
+-396 77 +391 0 *
+Ed
+ 1e-07 1 1 0
+1 202 0 11 12.5
+2 363 62 0 11 12.5
+4 G1 62 0 79 0
+0
+0101000
++391 0 -696 66 *
+Wi
+0101100
+-390 60 -394 0 +389 60 +645 63 *
+Fa
+0 1e-07 79 0
+0101000
++388 77 *
+Ed
+ 0 1 1 0
+1 229 0 2.18166160583496 3.14159265358979
+2 397 62 0 2.18166160583496 3.14159265358979
+2 398 86 0 2.18166160583496 3.14159265358979
+0
+0101000
++391 0 -432 0 *
+Wi
+0101100
++431 0 +386 0 +691 66 -389 0 *
+Fa
+0 1e-07 62 0
+0101000
++385 0 *
+Wi
+0101100
+-882 0 -865 0 -866 0 +868 0 +870 0 +872 0 -874 0 +876 0 -878 0 -880 0
+Ve
+1.190000002e-05
+14.142135623731 -4.99999999999999 20
+0 0
+0101101
+Ve
+1.190000002e-05
+14.9916643505649 -0.49999999999999 20
+0 0
+0101101
+Ed
+1 230 0 1.23095941734077 1.53745681753359
+2 399 2 25 1.23095941734077 1.53745681753359
+2 400 96 0 1.23095941734077 1.53745681753359
+0
+0101000
++382 0 -381 0 *
+Ve
+1.190000002e-05
+17.25 -4.99999999999999 20
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 231 0 4.875 7.98286437626905
+2 401 2 25 4.875 7.98286437626905
+2 402 97 0 4.875 7.98286437626905
+0
+0101000
++379 0 -382 0 *
+Ve
+1.190000002e-05
+17.25 -0.499999999999988 20
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 232 0 4.875 7.13333564943505
+2 403 2 25 4.875 7.13333564943505
+2 404 98 0 4.875 7.13333564943505
+0
+0101000
++377 0 -381 0 *
+Ed
+1 233 0 1 5.5
+2 405 2 25 1 5.5
+2 406 99 0 1 5.5
+0
+0101000
++379 0 -377 0 *
+Wi
+0101100
++380 0 +378 0 -376 0 -375 0 *
+Ve
+1.190000002e-05
+14.9916643505649 0.500000000000018 20
+0 0
+0101101
+Ve
+1.190000002e-05
+14.142135623731 5.00000000000002 20
+0 0
+0101101
+Ed
+1 234 0 1.6041358360562 1.91063323624902
+2 407 2 25 1.6041358360562 1.91063323624902
+2 408 100 0 1.6041358360562 1.91063323624902
+0
+0101000
++373 0 -372 0 *
+Ve
+1.190000002e-05
+17.25 0.500000000000016 20
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 235 0 4.875 7.13333564943505
+2 409 2 25 4.875 7.13333564943505
+2 410 101 0 4.875 7.13333564943505
+0
+0101000
++370 0 -373 0 *
+Ve
+1.190000002e-05
+17.25 5.00000000000002 20
+0 0
+0101101
+Ed
+1 236 0 4.875 7.98286437626905
+2 411 2 25 4.875 7.98286437626905
+2 412 102 0 4.875 7.98286437626905
+0
+0101000
++368 0 -372 0 *
+Ed
+ 1.99840144432528e-15 1 1 0
+1 237 0 -6 -1.5
+2 413 2 25 -6 -1.5
+2 414 103 0 -6 -1.5
+0
+0101000
++368 0 -370 0 *
+Wi
+0101100
++371 0 +369 0 -367 0 +366 0 *
+Ve
+1.265000002e-05
+25.5 -3.99999999999999 20
+0 0
+0101101
+Ve
+1.265000002e-05
+25.5 -0.499999999999988 20
+0 0
+0101101
+Ed
+1 238 0 1.5 5
+2 415 2 25 1.5 5
+2 416 104 0 1.5 5
+0
+0101000
++364 0 -363 0 *
+Ve
+1.265000002e-05
+19.5 -3.99999999999999 20
+0 0
+0101101
+Ed
+1 239 0 4.71238898038469 7.85398163397448
+2 417 2 25 4.71238898038469 7.85398163397448
+2 418 105 0 4.71238898038469 7.85398163397448
+0
+0101000
++361 0 -364 0 *
+Ve
+1.265000002e-05
+24 -0.499999999999988 20
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 240 0 0.75 2.25
+2 419 2 25 0.75 2.25
+2 420 106 0 0.75 2.25
+0
+0101000
++363 0 -359 0 *
+Ve
+1.265000002e-05
+19.5 -0.499999999999988 20
+0 0
+0101101
+Ed
+1 241 0 1.5 5
+2 421 2 25 1.5 5
+2 422 107 0 1.5 5
+0
+0101000
++361 0 -357 0 *
+Ve
+1.265000002e-05
+24 0.500000000000012 20
+0 0
+0101101
+Ed
+1 242 0 3.25 4.25
+2 423 2 25 3.25 4.25
+2 424 108 0 3.25 4.25
+0
+0101000
++359 0 -355 0 *
+Ve
+1.265000002e-05
+21 -0.499999999999988 20
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 243 0 3 4.5
+2 425 2 25 3 4.5
+2 426 109 0 3 4.5
+0
+0101000
++353 0 -357 0 *
+Ve
+1.265000002e-05
+25.5 0.500000000000012 20
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 244 0 0.75 2.25
+2 427 2 25 0.75 2.25
+2 428 110 0 0.75 2.25
+0
+0101000
++351 0 -355 0 *
+Ve
+1.265000002e-05
+21 0.500000000000012 20
+0 0
+0101101
+Ed
+1 245 0 3.25 4.25
+2 429 2 25 3.25 4.25
+2 430 111 0 3.25 4.25
+0
+0101000
++353 0 -349 0 *
+Ve
+1.265000002e-05
+25.5 4.00000000000001 20
+0 0
+0101101
+Ed
+1 246 0 3.75 7.25
+2 431 2 25 3.75 7.25
+2 432 112 0 3.75 7.25
+0
+0101000
++351 0 -347 0 *
+Ve
+1.265000002e-05
+19.5 0.500000000000012 20
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 247 0 3 4.5
+2 433 2 25 3 4.5
+2 434 113 0 3 4.5
+0
+0101000
++349 0 -345 0 *
+Ve
+1.265000002e-05
+19.5 4.00000000000001 20
+0 0
+0101101
+Ed
+1 248 0 1.5707963267949 4.71238898038469
+2 435 2 25 1.5707963267949 4.71238898038469
+2 436 114 0 1.5707963267949 4.71238898038469
+0
+0101000
++347 0 -343 0 *
+Ed
+1 249 0 3.75 7.25
+2 437 2 25 3.75 7.25
+2 438 115 0 3.75 7.25
+0
+0101000
++345 0 -343 0 *
+Wi
+0101100
+-362 0 -360 0 -358 0 +356 0 -354 0 -352 0 +350 0 +348 0 -346 0 +344 0
+-342 0 +341 0 *
+Fa
+0 1e-07 2 0
+0101000
++383 0 +374 26 +365 26 +340 26 *
+Wi
+0101000
++862 0 *
+Ve
+1e-07
+14.75 -8.24999999999999 22
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 250 0 0 6.28318530717959
+2 439 116 0 0 6.28318530717959
+2 440 116 93 0 6.28318530717959
+0
+0101100
++337 0 -337 0 *
+Wi
+0101100
+-336 0 *
+Fa
+0 1e-07 2 0
+0101000
++338 90 +335 91 *
+Wi
+0101000
++859 0 *
+Ve
+1e-07
+14.75 8.25000000000001 22
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 251 0 0 6.28318530717959
+2 441 117 0 0 6.28318530717959
+2 442 117 96 0 6.28318530717959
+0
+0101100
++332 0 -332 0 *
+Wi
+0101100
+-331 0 *
+Fa
+0 1e-07 2 0
+0101000
+-333 94 +330 91 *
+Wi
+0101100
++792 0 *
+Fa
+0 1e-07 118 0
+0101000
++328 5 *
+Wi
+0101100
+-524 0 -504 0 -519 0 *
+Fa
+0 1e-07 59 0
+0101000
++326 0 *
+Wi
+0101000
++507 0 *
+Fa
+0 1e-07 119 0
+0101000
++324 0 *
+Ve
+18.5709415886246 -4.74999999999999 45.25
+0 0
+0101101
+Ed
+ 1.81180119621372e-07 1 1 0
+1 252 0 0 1
+2 443 80 0 0 1
+2 444 78 19 0 1
+0
+0101000
++489 0 -322 0 *
+Ve
+9.78077506588802e-06
+18.5709415886246 -4.74999999999999 37
+0 0
+0101101
+Ed
+1 253 0 -28.25 -20
+2 445 78 19 -28.25 -20
+2 446 19 0 -28.25 -20
+0
+0101000
+-320 0 +322 0 *
+Ve
+3.26273660780147e-06
+14.2280532751322 -4.74999999999999 37
+0 0
+0101101
+Ed
+1 254 0 -4.34648972413538 -0.00360141064300734
+2 447 78 19 -4.34648972413538 -0.00360141064300734
+2 448 120 0 -4.34648972413538 -0.00360141064300734
+0
+0101000
++318 0 -320 0 *
+Ve
+3.23976567214837 -4.74999999999999 58.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 255 0 0 3.5
+0
+0101000
+-316 61 +426 0 *
+Ve
+14.2280532751322 -4.74999999999999 55.25
+0 0
+0101101
+Ed
+1 256 0 -21.25 -3
+2 449 121 0 -21.25 -3
+2 450 78 19 -21.25 -3
+0
+0101000
++318 0 -314 0 *
+Ve
+11.0198684202671 -4.74999999999999 58.25
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 257 0 16.0546745790005 23.8347773271192
+2 451 2 3 16.0546745790005 23.8347773271192
+2 452 78 19 16.0546745790005 23.8347773271192
+0
+0101000
++312 0 -316 0 *
+Ed
+ 2.45528507238042e-07 1 1 0
+1 258 0 0 1
+2 453 122 0 0 1
+2 454 78 19 0 1
+0
+0101000
++314 0 -312 0 *
+Wi
+0101100
++499 60 +492 0 -488 5 +462 60 +321 5 -453 60 +319 5 -425 60 -317 5 -315 60
++313 5 +311 5 +310 5 *
+Fa
+0 1e-07 78 0
+0101000
++309 77 *
+Ve
+1e-07
+18.5 -3.99999999999999 45.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 259 0 0 1.5707963267949
+2 455 81 0 0 1.5707963267949
+2 456 80 0 0 1.5707963267949
+4 G1 81 0 80 0
+0
+0101100
++487 0 -307 0 *
+Ed
+ 1e-07 1 1 0
+1 260 0 0 0.188616386175404
+2 457 80 0 0 0.188616386175404
+2 458 19 0 0 0.188616386175404
+4 G1 80 0 19 0
+0
+0101100
++307 0 -322 0 *
+Wi
+0101100
+-306 0 +486 0 -305 0 +321 0 *
+Fa
+0 0 80 0
+0101000
++304 0 *
+Ve
+1e-07
+18.5 -0.749999999999986 45.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 261 0 3.14159265358979 4.71238898038469
+2 459 81 0 3.14159265358979 4.71238898038469
+2 460 82 19 3.14159265358979 4.71238898038469
+0
+0101000
++485 0 -302 0 *
+Ed
+ 1e-07 1 1 0
+1 262 0 0 3.25
+2 461 81 0 0 3.25
+2 462 123 0 0 3.25
+4 G1 81 0 123 0
+0
+0101000
++302 0 -307 0 *
+Wi
+0101100
++301 0 -484 0 +300 0 -306 0 *
+Fa
+0 0 81 0
+0101000
++299 0 *
+Ve
+1e-07
+25.0168330344604 -0.749999999999986 48.3694023773397
+0 0
+0101101
+Ed
+1 263 0 -8.625 -8.00559762266025
+2 463 77 0 -8.625 -8.00559762266025
+2 464 82 0 -8.625 -8.00559762266025
+0
+0101000
+-297 77 +483 61 *
+Ve
+1e-07
+24.6551370761863 -0.749999999999986 49.5165553169535
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 264 0 0.959931047754832 1.5707963267949
+2 465 124 0 0.959931047754832 1.5707963267949
+2 466 82 60 0.959931047754832 1.5707963267949
+0
+0101000
++295 0 -297 0 *
+Ve
+1.000000002e-05
+16.2309866966085 -0.749999999999986 59.5474878442378
+0 0
+0101101
+Ed
+1 265 0 -19.1172015689461 -4.43014444051471
+2 467 79 0 -19.1172015689461 -4.43014444051471
+2 468 82 0 -19.1172015689461 -4.43014444051471
+0
+0101000
++295 77 -293 0 *
+Ed
+1 266 0 2.18166160583496 3.14159265358979
+2 469 62 0 2.18166160583496 3.14159265358979
+2 470 82 0 2.18166160583496 3.14159265358979
+0
+0101000
++293 0 -416 0 *
+Ve
+6.71022315657679e-06
+18.5 -0.749999999999986 37
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 267 0 -5.875 2.375
+2 471 82 19 -5.875 2.375
+2 472 123 0 -5.875 2.375
+0
+0101000
+-290 0 +302 0 *
+Ve
+14.9812382665786 -0.749999999999985 37
+0 0
+0101101
+Ed
+1 268 0 -11.5354707943123 -8.01670906089092
+2 473 82 19 -11.5354707943123 -8.01670906089092
+2 474 120 0 -11.5354707943123 -8.01670906089092
+0
+0101000
++290 0 -288 0 *
+Ve
+4.47500002e-06
+3.92905841137543 -0.749999999999986 58.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 269 0 0 3.5
+2 475 94 0 0 3.5
+0
+0101000
+-286 61 +418 0 *
+Ve
+14.9812382665786 -0.749999999999985 55.25
+0 0
+0101101
+Ed
+1 270 0 -21.25 -3
+2 476 121 0 -21.25 -3
+2 477 82 19 -21.25 -3
+0
+0101000
++288 0 -284 0 *
+Ve
+11.9765395670035 -0.749999999999987 58.25
+0 0
+0101101
+Ed
+ 2.66453525910038e-15 1 1 0
+1 271 0 -11.5354707943123 -3.48798963868423
+2 478 2 3 -11.5354707943123 -3.48798963868423
+2 479 82 19 -11.5354707943123 -3.48798963868423
+0
+0101000
++286 0 -282 0 *
+Ed
+ 1.685053480946e-07 1 1 0
+1 272 0 0 1
+2 480 122 0 0 1
+2 481 82 19 0 1
+0
+0101000
++284 0 -282 0 *
+Wi
+0101100
++296 60 -294 0 -482 5 +292 60 -301 5 +291 60 -289 5 -414 60 -287 5 +285 60
+-283 5 +281 5 -280 5 *
+Fa
+0 1e-07 82 0
+0101000
++279 77 *
+Ve
+1e-07
+25.0168330344604 0.750000000000014 48.3694023773397
+0 0
+0101101
+Ed
+1 273 0 -8.625 -8.00559762266025
+2 482 77 0 -8.625 -8.00559762266025
+2 483 83 0 -8.625 -8.00559762266025
+0
+0101000
+-277 77 +479 61 *
+Ed
+ 1e-07 1 1 0
+1 274 0 0 1.5
+2 484 124 0 0 1.5
+2 485 77 60 0 1.5
+4 G1 124 0 77 60
+0
+0101000
++297 0 -277 0 *
+Wi
+0101100
+-276 60 +275 0 -478 5 +296 60 *
+Fa
+0 1e-07 77 0
+0101000
++274 77 *
+Ve
+1e-07
+24.6551370761863 0.750000000000014 49.5165553169535
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 275 0 0.959931047754832 1.5707963267949
+2 486 124 0 0.959931047754832 1.5707963267949
+2 487 83 60 0.959931047754832 1.5707963267949
+0
+0101000
++272 0 -277 0 *
+Ve
+1.000000002e-05
+16.2309866966085 0.750000000000014 59.5474878442378
+0 0
+0101101
+Ed
+1 276 0 -19.1172015689461 -4.43014444051471
+2 488 79 0 -19.1172015689461 -4.43014444051471
+2 489 83 0 -19.1172015689461 -4.43014444051471
+0
+0101000
++272 77 -270 0 *
+Ve
+1e-07
+18.5 0.750000000000014 45.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 277 0 0 1.5707963267949
+2 490 84 0 0 1.5707963267949
+2 491 83 19 0 1.5707963267949
+0
+0101000
++475 0 -268 0 *
+Ed
+1 278 0 2.18166160583496 3.14159265358979
+2 492 62 0 2.18166160583496 3.14159265358979
+2 493 83 0 2.18166160583496 3.14159265358979
+0
+0101000
++270 0 -420 0 *
+Ve
+6.71022308863895e-06
+18.5 0.750000000000014 37
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 279 0 -5.875 2.375
+2 494 83 19 -5.875 2.375
+2 495 123 0 -5.875 2.375
+0
+0101000
+-265 0 +268 0 *
+Ve
+14.9812382665786 0.750000000000017 37
+0 0
+0101101
+Ed
+1 280 0 -11.5354707943123 -8.01670906089092
+2 496 83 19 -11.5354707943123 -8.01670906089092
+2 497 120 0 -11.5354707943123 -8.01670906089092
+0
+0101000
++265 0 -263 0 *
+Ve
+4.47500002e-06
+3.92905841137543 0.750000000000014 58.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 281 0 0 3.5
+2 498 93 0 0 3.5
+0
+0101000
+-261 61 +424 0 *
+Ve
+14.9812382665786 0.750000000000017 55.25
+0 0
+0101101
+Ed
+1 282 0 -21.25 -3
+2 499 121 0 -21.25 -3
+2 500 83 19 -21.25 -3
+0
+0101000
++263 0 -259 0 *
+Ve
+11.9765395670035 0.750000000000014 58.25
+0 0
+0101101
+Ed
+1 283 0 -11.5354707943123 -3.48798963868423
+2 501 2 3 -11.5354707943123 -3.48798963868423
+2 502 83 19 -11.5354707943123 -3.48798963868423
+0
+0101000
++261 0 -257 0 *
+Ed
+ 1.68505346388563e-07 1 1 0
+1 284 0 0 1
+2 503 122 0 0 1
+2 504 83 19 0 1
+0
+0101000
++259 0 -257 0 *
+Wi
+0101100
++276 60 -271 0 -474 5 +269 60 -267 5 +266 60 -264 5 -419 60 -262 5 +260 60
+-258 5 +256 5 -255 5 *
+Fa
+0 1e-07 83 0
+0101000
++254 77 *
+Ve
+1e-07
+18.5 4.00000000000001 45.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 285 0 0 3.25
+2 505 84 0 0 3.25
+2 506 123 0 0 3.25
+4 G1 84 0 123 0
+0
+0101000
++268 0 -252 0 *
+Ed
+ 1e-07 1 1 0
+1 286 0 0 1.5707963267949
+2 507 84 0 0 1.5707963267949
+2 508 85 0 0 1.5707963267949
+4 G1 84 0 85 0
+0
+0101100
++472 0 -252 0 *
+Wi
+0101100
++267 0 -471 0 +251 0 -250 0 *
+Fa
+0 0 84 0
+0101000
++249 0 *
+Ve
+18.5709415886246 4.75000000000001 45.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 287 0 0 0.188616386175404
+2 509 85 0 0 0.188616386175404
+2 510 21 0 0 0.188616386175404
+4 G1 85 0 21 0
+0
+0101100
++252 0 -247 0 *
+Ed
+1 288 0 0 1
+2 511 85 0 0 1
+2 512 86 19 0 1
+0
+0101000
++470 0 -247 0 *
+Wi
+0101100
+-250 0 +469 0 -246 0 +245 0 *
+Fa
+0 0 85 0
+0101000
++244 0 *
+Ve
+9.78077495586098e-06
+18.5709415886246 4.75000000000001 37
+0 0
+0101101
+Ed
+ 3.99999999999896e-08 1 1 0
+1 289 0 -28.25 -20
+2 513 86 19 -28.25 -20
+2 514 21 0 -28.25 -20
+0
+0101000
+-242 0 +247 0 *
+Ve
+14.2280532751322 4.75000000000002 37
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 290 0 -4.34648972413538 -0.00360141064300734
+2 515 86 19 -4.34648972413538 -0.00360141064300734
+2 516 120 0 -4.34648972413538 -0.00360141064300734
+0
+0101000
++240 0 -242 0 *
+Ve
+3.23976567214837 4.75000000000001 58.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 291 0 0 3.5
+0
+0101000
+-238 61 +430 0 *
+Ve
+14.2280532751322 4.75000000000002 55.25
+0 0
+0101101
+Ed
+ 5.32907051820075e-15 1 1 0
+1 292 0 -21.25 -3
+2 517 121 0 -21.25 -3
+2 518 86 19 -21.25 -3
+0
+0101000
++240 0 -236 0 *
+Ve
+11.0198684202671 4.75000000000001 58.25
+0 0
+0101101
+Ed
+ 1.33226762955019e-15 1 1 0
+1 293 0 16.0546745790005 23.8347773271192
+2 519 2 3 16.0546745790005 23.8347773271192
+2 520 86 19 16.0546745790005 23.8347773271192
+0
+0101000
++234 0 -238 0 *
+Ed
+ 2.45528504476014e-07 1 1 0
+1 294 0 0 1
+2 521 122 0 0 1
+2 522 86 19 0 1
+0
+0101000
++236 0 -234 0 *
+Wi
+0101100
++400 60 +395 0 -466 5 +390 60 +245 5 -386 60 +241 5 -429 60 -239 5 -237 60
++235 5 +233 5 +232 5 *
+Fa
+0 1e-07 86 0
+0101000
++231 77 *
+Ve
+4.47500002e-06
+1.55924001544396 -4.74999999999999 58.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 295 0 0 3.5
+0
+0101000
+-229 61 +450 0 *
+Ve
+4.47500002e-06
+-1.88573503494262 -4.74999999999999 58.25
+0 0
+0101101
+Ed
+1 296 0 12.720379992278 16.1653550426646
+2 523 2 3 12.720379992278 16.1653550426646
+2 524 125 19 12.720379992278 16.1653550426646
+0
+0101000
++229 0 -227 0 *
+Ed
+ 1e-07 1 1 0
+1 297 0 0 3.5
+0
+0101000
+-227 61 +449 0 *
+Wi
+0101100
++228 19 +226 0 -448 19 -225 19 *
+Fa
+0 1e-07 125 0
+0101000
++224 61 *
+Ve
+4.47500002e-06
+-1.88573503494262 -3.52760589890507 58.25
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 298 0 1.125 2.34739410109492
+2 525 2 3 1.125 2.34739410109492
+2 526 126 19 1.125 2.34739410109492
+0
+0101000
++227 0 -222 0 *
+Ed
+ 1e-07 1 1 0
+1 299 0 0 3.5
+2 527 88 0 0 3.5
+0
+0101000
+-222 61 +447 0 *
+Wi
+0101100
++225 19 +221 0 -446 19 -220 19 *
+Fa
+0 1e-07 126 0
+0101000
++219 61 *
+Ve
+4.47500002e-06
+1.10215267118867 -3.84516052842941 58.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 300 0 0 3.5
+2 528 88 0 0 3.5
+0
+0101000
+-217 61 +445 0 *
+Ed
+ 2.33146835171283e-15 1 1 0
+1 301 0 5.79226947588352 6.56233480378389
+2 529 2 3 5.79226947588352 6.56233480378389
+2 530 88 19 5.79226947588352 6.56233480378389
+0
+0101000
++222 0 -217 0 *
+Wi
+0101100
++216 19 -215 0 -444 19 -220 19 *
+Fa
+0 1e-07 88 0
+0101000
++214 61 *
+Ed
+1 302 0 -7.2465527139594 -6.23281541584392
+2 531 2 3 -7.2465527139594 -6.23281541584392
+2 532 127 19 -7.2465527139594 -6.23281541584392
+0
+0101000
++217 0 -229 0 *
+Wi
+0101100
++216 19 +212 0 -443 19 -228 19 *
+Fa
+0 1e-07 127 0
+0101000
++211 61 *
+Ve
+4.47500002e-06
+-1.88573503494263 3.5276058989051 58.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 303 0 96.5 100
+2 533 89 0 96.5 100
+0
+0101000
++209 61 -441 0 *
+Ve
+4.47500002e-06
+1.10215267118867 3.84516052842944 58.25
+0 0
+0101101
+Ed
+ 2.68527125478709e-15 1 1 0
+1 304 0 5.79226947588352 6.56233480378389
+2 534 2 3 5.79226947588352 6.56233480378389
+2 535 89 19 5.79226947588352 6.56233480378389
+0
+0101000
++209 0 -207 0 *
+Ed
+ 1e-07 1 1 0
+1 305 0 96.5 100
+2 536 89 0 96.5 100
+0
+0101000
++207 61 -440 0 *
+Wi
+0101100
++208 19 -206 0 +439 19 -205 19 *
+Fa
+0 1e-07 89 0
+0101000
++204 61 *
+Ve
+4.47500002e-06
+-1.88573503494262 4.75000000000001 58.25
+0 0
+0101101
+Ed
+1 306 0 -6.48619705054746 -5.26380294945254
+2 537 2 3 -6.48619705054746 -5.26380294945254
+2 538 90 19 -6.48619705054746 -5.26380294945254
+0
+0101000
++202 0 -209 0 *
+Ed
+ 1e-07 1 1 0
+1 307 0 96.5 100
+0
+0101000
++202 61 -438 0 *
+Wi
+0101100
++208 19 +201 0 +437 19 -200 19 *
+Fa
+0 1e-07 90 0
+0101000
++199 61 *
+Ve
+4.47500002e-06
+1.55924001544396 4.75000000000001 58.25
+0 0
+0101101
+Ed
+ 4.26533757476001e-15 1 1 0
+1 308 0 -0.0152296277473575 0.998507670368117
+2 539 2 3 -0.0152296277473575 0.998507670368117
+2 540 91 19 -0.0152296277473575 0.998507670368117
+0
+0101000
++197 0 -207 0 *
+Ed
+ 1e-07 1 1 0
+1 309 0 96.5 100
+0
+0101000
++197 61 -436 0 *
+Wi
+0101100
++205 19 +196 0 +435 19 -195 19 *
+Fa
+0 1e-07 91 0
+0101000
++194 61 *
+Ed
+1 310 0 10.9978924670847 14.4428675174713
+2 541 2 3 10.9978924670847 14.4428675174713
+2 542 92 19 10.9978924670847 14.4428675174713
+0
+0101000
++197 0 -202 0 *
+Wi
+0101100
++200 19 +192 0 +434 19 -195 19 *
+Fa
+0 1e-07 92 0
+0101000
++191 61 *
+Ve
+4.47500002e-06
+2.44101946624395 3.16882059533483 58.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 311 0 0 3.5
+2 543 93 0 0 3.5
+0
+0101000
+-189 61 +428 0 *
+Ed
+ 2.40177962549203e-15 1 1 0
+1 312 0 -0.998507670368117 0.772967367893514
+2 544 2 3 -0.998507670368117 0.772967367893514
+2 545 128 19 -0.998507670368117 0.772967367893514
+0
+0101000
++189 0 -238 0 *
+Wi
+0101100
++188 19 +187 0 -427 19 -237 19 *
+Fa
+0 1e-07 128 0
+0101000
++186 61 *
+Ed
+ 2.97904098389673e-15 1 1 0
+1 313 0 1.7594127129703 2.48521038463468
+2 546 2 3 1.7594127129703 2.48521038463468
+2 547 93 19 1.7594127129703 2.48521038463468
+0
+0101000
++261 0 -189 0 *
+Wi
+0101100
++260 19 +184 0 -423 19 -188 19 *
+Fa
+0 1e-07 93 0
+0101000
++183 61 *
+Ve
+4.47500002e-06
+2.44101946624395 -3.16882059533481 58.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 314 0 0 3.5
+2 548 94 0 0 3.5
+0
+0101000
+-181 61 +422 0 *
+Ed
+1 315 0 -7.2465527139594 -5.47507767569777
+2 549 2 3 -7.2465527139594 -5.47507767569777
+2 550 129 19 -7.2465527139594 -5.47507767569777
+0
+0101000
++181 0 -316 0 *
+Wi
+0101100
++180 19 +179 0 -421 19 -315 19 *
+Fa
+0 1e-07 129 0
+0101000
++178 61 *
+Ed
+ 2.74654007911334e-15 1 1 0
+1 316 0 0.656382268955115 1.38217994061949
+2 551 2 3 0.656382268955115 1.38217994061949
+2 552 94 19 0.656382268955115 1.38217994061949
+0
+0101000
++181 0 -286 0 *
+Wi
+0101100
++285 19 -176 0 -417 19 -180 19 *
+Fa
+0 1e-07 94 0
+0101000
++175 61 *
+Ed
+ 1e-07 1 1 0
+1 202 0 5.5 7
+2 363 62 0 5.5 7
+4 G1 62 0 79 0
+0
+0101000
+-270 0 +293 0 *
+Wi
+0101100
++415 0 -266 0 +291 0 -173 0 *
+Fa
+0 1e-07 62 0
+0101000
++172 0 *
+Ed
+ 1e-07 1 1 0
+1 317 0 0 1
+3 553 554CN 95 0 0 1
+0
+0101000
++412 0 -412 86 *
+Wi
+0101000
++170 0 -170 0 -411 0 +411 86 *
+Fa
+0 1e-07 95 0
+0101000
++169 0 *
+Ve
+1e-07
+14.142135623731 -4.99999999999999 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 318 0 0 16
+2 555 96 0 0 16
+0
+0101000
+-382 0 +167 97 *
+Ve
+1e-07
+14.9916643505649 -0.499999999999988 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 319 0 2.80175574413567 3.10825314432849
+2 556 96 98 2.80175574413567 3.10825314432849
+2 557 96 100 2.80175574413567 3.10825314432849
+0
+0101000
++167 0 -165 0 *
+Ed
+ 1e-07 1 1 0
+1 320 0 0 16
+2 558 96 0 0 16
+0
+0101000
+-381 0 +165 97 *
+Wi
+0101100
++166 0 +380 0 -164 97 -163 0 *
+Fa
+0 1e-07 96 0
+0101000
++162 0 *
+Ve
+1e-07
+17.25 -4.99999999999999 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 321 0 0 16
+0
+0101000
+-379 0 +160 97 *
+Ed
+ 1e-07 1 1 0
+1 322 0 -7.24999999999999 -4.14213562373094
+0
+0101000
++160 0 -167 0 *
+Wi
+0101100
++159 0 +378 0 -158 97 -166 0 *
+Fa
+0 1e-07 97 0
+0101000
++157 0 *
+Ve
+1e-07
+17.25 -0.499999999999988 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 323 0 0 16
+0
+0101000
+-377 0 +155 97 *
+Ed
+ 1e-07 1 1 0
+1 324 0 -7.24999999999999 -4.99166435056494
+0
+0101000
++155 0 -165 0 *
+Wi
+0101100
++154 0 +376 0 -153 97 -163 0 *
+Fa
+0 1e-07 98 0
+0101000
++152 0 *
+Ed
+ 1e-07 1 1 0
+1 325 0 -4.99999999999999 -0.499999999999988
+0
+0101000
++160 0 -155 0 *
+Wi
+0101100
++159 0 +375 0 -150 97 -154 0 *
+Fa
+0 1e-07 99 0
+0101000
++149 0 *
+Ve
+1e-07
+14.142135623731 5.00000000000002 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 326 0 0 16
+2 559 100 0 0 16
+0
+0101000
+-372 0 +147 101 *
+Ve
+1e-07
+14.9916643505649 0.500000000000016 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 327 0 2.80175574413567 3.10825314432849
+2 560 100 102 2.80175574413567 3.10825314432849
+2 561 100 104 2.80175574413567 3.10825314432849
+0
+0101000
++147 0 -145 0 *
+Ed
+ 1e-07 1 1 0
+1 328 0 0 16
+2 562 100 0 0 16
+0
+0101000
+-373 0 +145 101 *
+Wi
+0101100
++146 0 -371 0 -144 101 -143 0 *
+Fa
+0 1e-07 100 0
+0101000
++142 0 *
+Ve
+1e-07
+17.25 0.500000000000016 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 329 0 0 16
+0
+0101000
+-370 0 +140 101 *
+Ed
+ 1e-07 1 1 0
+1 330 0 -7.24999999999999 -4.99166435056494
+0
+0101000
++140 0 -145 0 *
+Wi
+0101100
++139 0 +369 0 -138 101 -143 0 *
+Fa
+0 1e-07 101 0
+0101000
++137 0 *
+Ve
+1e-07
+17.25 5.00000000000002 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 331 0 0 16
+0
+0101000
+-368 0 +135 101 *
+Ed
+ 1e-07 1 1 0
+1 332 0 -7.24999999999999 -4.14213562373094
+0
+0101000
++135 0 -147 0 *
+Wi
+0101100
++134 0 +367 0 -133 101 -146 0 *
+Fa
+0 1e-07 102 0
+0101000
++132 0 *
+Ed
+ 1e-07 1 1 0
+1 333 0 -4.99999999999999 -0.499999999999988
+0
+0101000
++135 0 -140 0 *
+Wi
+0101100
++134 0 +366 0 -130 101 -139 0 *
+Fa
+0 1e-07 103 0
+0101000
++129 0 *
+Ve
+1e-07
+25.5 -3.99999999999999 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 334 0 0 23.5
+2 563 105 0 0 23.5
+4 G1 104 0 105 0
+0
+0101000
+-364 0 +127 105 *
+Ve
+1e-07
+25.5 -0.499999999999988 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 335 0 0 3.5
+0
+0101000
++127 0 -125 0 *
+Ed
+ 1e-07 1 1 0
+1 336 0 0 23.5
+0
+0101000
+-363 0 +125 105 *
+Wi
+0101100
++126 0 +362 0 -124 105 -123 0 *
+Fa
+0 1e-07 104 0
+0101000
++122 0 *
+Ve
+1e-07
+19.5 -3.99999999999999 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 337 0 0 23.5
+2 564 105 0 0 23.5
+4 G1 107 0 105 0
+0
+0101000
+-361 0 +120 105 *
+Ed
+ 1e-07 1 1 0
+1 338 0 0 3.14159265358979
+2 565 105 106 0 3.14159265358979
+2 566 105 108 0 3.14159265358979
+0
+0101000
++120 0 -127 0 *
+Wi
+0101100
++119 0 +360 0 -118 105 -126 0 *
+Fa
+0 1e-07 105 0
+0101000
++117 0 *
+Ve
+1e-07
+24 -0.499999999999988 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 339 0 -15.5 -14
+0
+0101000
++125 0 -115 0 *
+Ed
+ 1e-07 1 1 0
+1 340 0 0 23.5
+0
+0101000
+-359 0 +115 105 *
+Wi
+0101100
++123 0 +358 0 -114 105 -113 0 *
+Fa
+0 1e-07 106 0
+0101000
++112 0 *
+Ve
+1e-07
+19.5 -0.499999999999988 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 341 0 -2 1.5
+0
+0101000
++120 0 -110 0 *
+Ed
+ 1e-07 1 1 0
+1 342 0 0 23.5
+0
+0101000
+-357 0 +110 105 *
+Wi
+0101100
++119 0 +356 0 -109 105 -108 0 *
+Fa
+0 1e-07 107 0
+0101000
++107 0 *
+Ve
+1e-07
+24 0.500000000000012 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 343 0 3.5 4.5
+0
+0101000
++115 0 -105 0 *
+Ed
+ 1e-07 1 1 0
+1 344 0 0 23.5
+0
+0101000
+-355 0 +105 105 *
+Wi
+0101100
++113 0 +354 0 -104 105 -103 0 *
+Fa
+0 1e-07 108 0
+0101000
++102 0 *
+Ve
+1e-07
+21 -0.499999999999988 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 345 0 0 23.5
+0
+0101000
+-353 0 +100 105 *
+Ed
+ 1e-07 1 1 0
+1 346 0 -11 -9.49999999999999
+0
+0101000
++100 0 -110 0 *
+Wi
+0101100
++99 0 +352 0 -98 105 -108 0 *
+Fa
+0 1e-07 109 0
+0101000
++97 0 *
+Ve
+1e-07
+25.5 0.500000000000013 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 347 0 0 23.5
+0
+0101000
+-351 0 +95 105 *
+Ed
+ 1e-07 1 1 0
+1 348 0 -15.5 -14
+0
+0101000
++95 0 -105 0 *
+Wi
+0101100
++94 0 +350 0 -93 105 -103 0 *
+Fa
+0 1e-07 110 0
+0101000
++92 0 *
+Ve
+1e-07
+21 0.500000000000013 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 349 0 3.5 4.5
+0
+0101000
++100 0 -90 0 *
+Ed
+ 1e-07 1 1 0
+1 350 0 0 23.5
+0
+0101000
+-349 0 +90 105 *
+Wi
+0101100
++99 0 +348 0 -89 105 -88 0 *
+Fa
+0 1e-07 111 0
+0101000
++87 0 *
+Ve
+1e-07
+25.5 4.00000000000001 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 351 0 4.5 8
+0
+0101000
++95 0 -85 0 *
+Ed
+ 1e-07 1 1 0
+1 352 0 0 23.5
+2 567 114 0 0 23.5
+4 G1 112 0 114 0
+0
+0101000
+-347 0 +85 105 *
+Wi
+0101100
++94 0 +346 0 -84 105 -83 0 *
+Fa
+0 1e-07 112 0
+0101000
++82 0 *
+Ve
+1e-07
+19.5 0.500000000000012 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 353 0 -11 -9.49999999999999
+0
+0101000
++90 0 -80 0 *
+Ed
+ 1e-07 1 1 0
+1 354 0 0 23.5
+0
+0101000
+-345 0 +80 105 *
+Wi
+0101100
++88 0 +344 0 -79 105 -78 0 *
+Fa
+0 1e-07 113 0
+0101000
++77 0 *
+Ve
+1e-07
+19.5 4.00000000000001 17
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 355 0 3.14159265358979 6.28318530717959
+2 568 114 106 3.14159265358979 6.28318530717959
+2 569 114 108 3.14159265358979 6.28318530717959
+0
+0101000
++85 0 -75 0 *
+Ed
+ 1e-07 1 1 0
+1 356 0 0 23.5
+2 570 114 0 0 23.5
+4 G1 114 0 115 0
+0
+0101000
+-343 0 +75 105 *
+Wi
+0101100
++83 0 +342 0 -74 105 -73 0 *
+Fa
+0 1e-07 114 0
+0101000
++72 0 *
+Ed
+ 1e-07 1 1 0
+1 357 0 2.5 6
+0
+0101000
++80 0 -75 0 *
+Wi
+0101100
++78 0 +341 0 -70 105 -73 0 *
+Fa
+0 1e-07 115 0
+0101000
++69 0 *
+Ed
+ 1e-07 1 1 0
+1 358 0 0 15
+3 571 572CN 116 0 0 15
+0
+0101000
++337 0 -337 92 *
+Wi
+0101100
+-336 0 +67 0 -67 0 +336 92 *
+Fa
+0 1e-07 116 0
+0101000
++66 0 *
+Ed
+ 1e-07 1 1 0
+1 359 0 0 15
+3 573 574CN 117 0 0 15
+0
+0101000
++332 0 -332 95 *
+Wi
+0101100
+-331 0 +64 0 -64 0 +331 95 *
+Fa
+0 1e-07 117 0
+0101000
++63 0 *
+Ve
+2.26215410883875e-06
+18.5 -3.99999999999999 37
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 360 0 20 28.25
+2 575 19 0 20 28.25
+4 G1 19 0 123 0
+0
+0101000
++61 0 -307 0 *
+Ed
+ 5.49308015822668e-15 1 1 0
+1 361 0 4.52377259420929 4.71238898038469
+2 576 19 0 4.52377259420929 4.71238898038469
+2 577 120 0 4.52377259420929 4.71238898038469
+0
+0101000
++320 0 -61 0 *
+Wi
+0101100
++60 0 +59 0 +305 0 +319 0 *
+Fa
+0 1e-07 19 0
+0101000
++58 0 *
+Ed
+ 0 1 1 0
+1 362 0 1.24858309479666 1.52077546998913
+2 578 121 0 1.24858309479666 1.52077546998913
+2 579 120 0 1.24858309479666 1.52077546998913
+0
+0101000
++318 0 -288 0 *
+Ed
+ 6.66133814775094e-16 1 1 0
+1 363 0 -2 1.25
+2 580 123 0 -2 1.25
+2 581 120 0 -2 1.25
+0
+0101000
++61 0 -290 0 *
+Wi
+0101100
+-56 0 +317 0 +287 0 +59 0 +55 0 *
+Fa
+0 1e-07 120 0
+0101000
++54 0 *
+Ed
+ 1e-07 1 1 0
+1 364 0 0.0889246303241095 0.361117005516578
+2 582 122 0 0.0889246303241095 0.361117005516578
+2 583 121 0 0.0889246303241095 0.361117005516578
+4 G1 122 0 121 0
+0
+0101000
++314 0 -284 0 *
+Wi
+0101100
+-313 0 +56 0 -52 0 +283 0 *
+Fa
+0 1e-07 121 0
+0101000
++51 0 *
+Ed
+ 1e-07 1 1 0
+1 365 0 0.00416273669359097 0.348597100525857
+2 584 122 0 0.00416273669359097 0.348597100525857
+2 585 2 3 0.00416273669359097 0.348597100525857
+4 G1 122 0 2 3
+0
+0101000
++312 0 -282 0 *
+Wi
+0101100
++49 0 -311 0 -281 0 +179 0 -176 0 *
+Fa
+0 1e-07 2 0
+0101000
++48 109 *
+Wi
+0101100
++52 0 -310 0 +280 0 -49 0 *
+Fa
+0 0 122 0
+0101000
++46 0 *
+Wi
+0101100
++60 0 -55 0 -300 0 +289 0 *
+Fa
+0 1e-07 123 0
+0101000
++44 0 *
+Ed
+ 1e-07 1 1 0
+1 366 0 0 1.5
+2 586 124 0 0 1.5
+2 587 79 60 0 1.5
+4 G1 124 0 79 60
+0
+0101000
++295 0 -272 0 *
+Wi
+0101100
++294 0 -42 0 +275 0 -271 0 *
+Fa
+0 0 124 0
+0101000
++41 0 *
+Wi
+0101100
+-269 60 -42 0 +173 60 +292 60 *
+Fa
+0 1e-07 79 0
+0101000
++39 77 *
+Ve
+18.5 4.00000000000001 37
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 367 0 20 28.25
+2 588 21 0 20 28.25
+4 G1 21 0 123 0
+0
+0101000
++37 0 -252 0 *
+Ed
+1 368 0 2.75 6
+2 589 123 0 2.75 6
+2 590 120 0 2.75 6
+0
+0101000
++265 0 -37 0 *
+Wi
+0101100
+-36 0 -35 0 +251 0 -264 0 *
+Fa
+0 1e-07 123 0
+0101000
++34 0 *
+Ed
+ 0 1 1 0
+1 369 0 1.62081718360067 1.89300955879314
+2 591 121 0 1.62081718360067 1.89300955879314
+2 592 120 0 1.62081718360067 1.89300955879314
+0
+0101000
++263 0 -240 0 *
+Ed
+1 370 0 4.71238898038469 4.90100536656009
+2 593 21 0 4.71238898038469 4.90100536656009
+2 594 120 0 4.71238898038469 4.90100536656009
+0
+0101000
++37 0 -242 0 *
+Wi
+0101100
+-32 0 -262 0 -239 0 +35 0 +31 0 *
+Fa
+0 1e-07 120 0
+0101000
++30 0 *
+Ed
+ 1e-07 1 1 0
+1 364 0 0.461158719128118 0.733351094320587
+2 582 122 0 0.461158719128118 0.733351094320587
+2 583 121 0 0.461158719128118 0.733351094320587
+4 G1 122 0 121 0
+0
+0101000
++259 0 -236 0 *
+Wi
+0101100
+-258 0 +32 0 -28 0 +235 0 *
+Fa
+0 1e-07 121 0
+0101000
++27 0 *
+Ed
+ 1e-07 1 1 0
+1 365 0 0.473678624118839 0.818112987951105
+2 584 122 0 0.473678624118839 0.818112987951105
+2 585 2 3 0.473678624118839 0.818112987951105
+4 G1 122 0 2 3
+0
+0101000
++257 0 -234 0 *
+Wi
+0101100
++25 0 +256 0 +233 0 -184 0 -187 0 *
+Fa
+0 1e-07 2 0
+0101000
++24 109 *
+Wi
+0101100
++28 0 -255 0 +232 0 -25 0 *
+Fa
+0 0 122 0
+0101000
++22 0 *
+Wi
+0101100
+-36 0 +31 0 -246 0 -241 0 *
+Fa
+0 1e-07 21 0
+0101000
++20 0 *
+Wi
+0101100
+-226 0 -212 0 -221 0 -215 0 *
+Fa
+0 1e-07 2 0
+0101000
++18 109 *
+Wi
+0101100
++206 0 +201 0 -196 0 +192 0 *
+Fa
+0 1e-07 2 0
+0101000
++16 109 *
+Fa
+0 1e-07 130 0
+0101000
++410 0 *
+Wi
+0101100
++164 0 -153 0 -150 0 +158 0 *
+Fa
+0 1e-07 2 0
+0101000
+-13 0 *
+Wi
+0101100
++144 0 -138 0 -130 0 +133 0 *
+Fa
+0 1e-07 2 0
+0101000
++11 0 *
+Wi
+0101100
++124 0 +114 0 +104 0 -93 0 +84 0 +74 0 -70 0 -79 0 -89 0 +98 0
+-109 0 +118 0 *
+Fa
+0 1e-07 2 0
+0101000
++9 0 *
+Wi
+0101100
++336 0 *
+Fa
+0 1e-07 131 0
+0101000
++7 0 *
+Wi
+0101100
++331 0 *
+Fa
+0 1e-07 132 0
+0101000
++5 0 *
+Sh
+0101100
++925 1 -918 1 +885 6 -829 5 +824 8 +819 5 +808 5 -803 5 +794 5 -774 10
+-769 5 -758 5 +755 11 -750 0 +747 1 +740 14 -722 1 -717 5 -714 1 -707 5
++704 1 -675 54 +668 1 -663 5 -658 5 -653 5 +636 63 -632 5 +630 5 -626 5
+-623 5 -620 5 +617 5 -614 5 +611 5 +608 5 +605 5 -602 5 -600 5 +597 5
+-594 5 -590 0 -587 0 -584 0 +579 5 +574 5 +569 5 +566 5 +563 5 +561 72
++558 5 +555 0 +552 5 -547 1 -544 5 +538 5 -536 5 +533 11 +530 60 -528 0
+-521 5 +515 5 -512 5 +510 11 +505 0 +502 76 -495 60 +490 0 +464 78 -459 60
++456 5 -451 60 -409 60 -407 62 -404 5 +402 5 -397 60 +392 0 -387 60 -384 60
+-339 89 -334 89 -329 89 -327 46 -325 5 +323 0 +308 60 -303 5 +298 5 +278 60
+-273 60 -253 60 -248 5 +243 5 -230 60 +223 60 +218 60 -213 60 +210 60 +203 60
+-198 60 +193 60 -190 60 +185 60 +182 60 -177 60 -174 60 -171 60 +168 0 +161 5
++156 5 -151 5 -148 5 -141 5 +136 5 -131 5 +128 5 -121 5 -116 5 -111 5
++106 5 -101 5 -96 5 +91 5 +86 5 -81 5 +76 5 -71 5 +68 5 +65 0
++62 0 -57 5 +53 5 +50 5 +47 11 +45 5 +43 5 +40 0 -38 60 +33 5
++29 5 +26 5 +23 11 +21 5 -19 5 +17 11 +15 11 -14 86 -12 110 -10 111
+-8 112 -6 92 -4 95 *
+So
+0100000
++3 0 *
+Co
+0100000
++2 0 *
++1 0
\ No newline at end of file
Added: cgm/trunk/test/72_shaver6.brep
--- cgm/trunk/test/72_shaver6.brep (rev 0)
+++ cgm/trunk/test/72_shaver6.brep 2007-12-11 17:59:18 UTC (rev 1466)
@@ -0,0 +1,36397 @@
+DBRep_DrawableShape
+CASCADE Topology V1, (c) Matra-Datavision
+Locations 194
+1
+ 1 0 0 -0
+ 0 1 0 -0
+ 0 0 1 7
+2 1 -1 0
+1
+ 1 0 0 -0
+ 0 1 0 -0
+ 0 0 1 3
+2 3 -1 0
+1
+ 1 0 0 -8
+ 0 1 0 0
+ 0 0 1 0
+2 5 -1 0
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 -5
+2 7 -1 0
+1
+ -1 -1.22464679914735e-16 0 49.9999996896502
+1.22464679914735e-16 -1 0 -8.50949042292288e-06
+ 0 0 1 0
+2 9 -1 0
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 -5
+2 11 -1 9 -1 0
+2 5 1 9 -1 0
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 -10
+2 14 -1 0
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 -10
+2 16 -1 0
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 -10
+2 18 -1 0
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 -10
+2 20 -1 0
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 -10
+2 22 -1 0
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 -32
+2 5 1 24 1 0
+2 24 -1 5 -1 0
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 -3
+2 27 -1 0
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 -7.5
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 -7.5
+2 9 1 11 1 0
+1
+1.11022302462516e-16 0 1 0
+ 0 1 0 0
+ -1 0 1.11022302462516e-16 0
+1
+ 1 0 0 0
+ 0 1.11022302462516e-16 -1 0
+ 0 1 1.11022302462516e-16 0
+1
+ 1 0 0 0
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 -2.75
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 0
+2 32 1 33 1 34 1 35 1 36 1 0
+2 36 -1 35 -1 34 -1 33 -1 32 -1 0
+1
+ 1 0 0 0
+ 0 -1 -1.22464679914735e-16 0
+ 0 1.22464679914735e-16 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 -2.1001434263674e-23
+ 0 0 1 52.5
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 0
+2 39 1 40 1 41 1 0
+1
+ 1 0 -0 3.5
+ -0 1 0 0
+ 0 0 1 0
+2 41 -1 40 -1 39 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 34
+2 43 1 32 1 33 1 34 1 35 1 36 1 0
+2 43 -1 0
+1
+ 0 1 0 0
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 0
+1
+ 1 0 0 13
+ 0 1 0 0
+ 0 0 1 0.75
+1
+0.984807759068988 0.173648143317221 -1.68667756772623e-18 0.197499132103156
+-0.173648143317221 0.984807759068988 -1.92788166894188e-17 2.25742586312388
+-1.68667756772623e-18 1.92788166894188e-17 1 0
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 0
+2 48 1 49 1 50 1 51 1 52 1 35 -1 34 -1 33 -1 32 -1 43 -1 0
+2 35 -1 34 -1 33 -1 32 -1 43 -1 0
+2 43 1 32 1 33 1 34 1 35 1 0
+2 48 1 49 1 50 1 51 1 52 1 0
+1
+ 1 0 -0 3.5
+ -0 1 0 0
+ 0 0 1 0
+2 57 -1 0
+2 52 -1 51 -1 50 -1 49 -1 48 -1 0
+2 45 1 39 1 40 1 41 1 0
+2 45 -1 0
+2 48 1 49 1 50 1 51 1 52 1 36 1 0
+2 35 -1 34 -1 33 -1 32 -1 0
+2 32 1 33 1 34 1 35 1 0
+2 57 1 48 1 49 1 50 1 51 1 52 1 0
+2 52 -1 51 -1 50 -1 49 -1 48 -1 57 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -1
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 2
+2 67 1 68 1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -1
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 2
+2 70 1 71 1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -1
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -1
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 0
+2 48 1 49 1 50 1 51 1 52 1 36 1 75 -1 0
+2 48 1 49 1 50 1 51 1 52 1 35 -1 34 -1 33 -1 32 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -3.5
+2 78 -1 0
+1
+ 1 0 -0 1.5
+ -0 1 0 0
+ 0 0 1 0
+1
+ 1 0 -0 -3
+ -0 1 0 0
+ 0 0 1 0
+2 80 1 81 1 0
+2 80 -1 0
+2 81 -1 80 -1 0
+1
+ 1 0 -0 -1.5
+ -0 1 0 0
+ 0 0 1 0
+1
+ 1 0 -0 3
+ -0 1 0 0
+ 0 0 1 0
+2 85 1 86 1 0
+2 85 -1 0
+2 86 -1 85 -1 0
+2 67 1 68 1 39 1 40 1 41 1 0
+2 70 1 71 1 39 1 40 1 41 1 0
+2 73 1 39 1 40 1 41 1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 34
+2 93 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -0.5
+2 95 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 1
+2 97 -1 95 -1 0
+2 73 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 2
+2 100 -1 73 -1 0
+2 74 1 39 1 40 1 41 1 0
+2 74 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 2
+2 104 -1 74 -1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -25
+1
+ 1 0 -0 0
+ -0 1 0 -13
+ 0 0 1 0
+2 106 1 107 1 0
+1
+ 1 0 -0 0
+ -0 1 0 -13
+ 0 0 1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -20
+1
+ 1 0 -0 0
+ -0 1 0 -13
+ 0 0 1 0
+2 110 1 111 1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -5
+1
+ 1 0 -0 0
+ -0 1 0 -13
+ 0 0 1 0
+2 113 1 114 1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -15
+1
+ 1 0 -0 0
+ -0 1 0 -13
+ 0 0 1 0
+2 116 1 117 1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -10
+1
+ 1 0 -0 0
+ -0 1 0 -13
+ 0 0 1 0
+2 119 1 120 1 0
+2 80 1 81 1 39 1 40 1 41 1 0
+2 85 1 86 1 39 1 40 1 41 1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -25
+1
+ 1 0 -0 0
+ -0 1 0 13
+ 0 0 1 0
+2 124 1 125 1 0
+1
+ 1 0 -0 0
+ -0 1 0 13
+ 0 0 1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -20
+1
+ 1 0 -0 0
+ -0 1 0 13
+ 0 0 1 0
+2 128 1 129 1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -5
+1
+ 1 0 -0 0
+ -0 1 0 13
+ 0 0 1 0
+2 131 1 132 1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -15
+1
+ 1 0 -0 0
+ -0 1 0 13
+ 0 0 1 0
+2 134 1 135 1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -10
+1
+ 1 0 -0 0
+ -0 1 0 13
+ 0 0 1 0
+2 137 1 138 1 0
+2 73 1 100 1 0
+2 74 1 104 1 0
+2 36 -1 52 -1 51 -1 50 -1 49 -1 48 -1 0
+2 107 1 39 1 40 1 41 1 0
+2 109 1 39 1 40 1 41 1 0
+2 111 1 39 1 40 1 41 1 0
+2 114 1 39 1 40 1 41 1 0
+2 117 1 39 1 40 1 41 1 0
+2 120 1 39 1 40 1 41 1 0
+2 125 1 39 1 40 1 41 1 0
+2 127 1 39 1 40 1 41 1 0
+2 129 1 39 1 40 1 41 1 0
+2 132 1 39 1 40 1 41 1 0
+2 135 1 39 1 40 1 41 1 0
+2 138 1 39 1 40 1 41 1 0
+2 73 1 100 1 39 1 40 1 41 1 0
+2 74 1 104 1 39 1 40 1 41 1 0
+2 75 -1 0
+1
+ 0 1 0 0
+1
+ 1 0 0 0
+1
+ 1 0 0 0
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 -2.75
+1
+ 1 0 0 8.88178419700125e-16
+ 0 1 0 0
+ 0 0 1 -4
+1
+ 1 0 0 13
+ 0 1 0 0
+ 0 0 1 0
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 0
+1
+ 1 0 0 0
+ 0 1 0 0
+ 0 0 1 0
+2 158 1 159 1 160 1 161 1 162 1 163 1 164 1 165 1 0
+2 78 1 39 1 40 1 41 1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 60
+2 165 -1 164 -1 163 -1 162 -1 161 -1 160 -1 159 -1 158 -1 0
+2 168 1 39 1 40 1 41 1 0
+2 168 -1 0
+1
+ 1 0 -0 3.5
+ -0 1 0 0
+ 0 0 1 0
+1
+ 1 0 -0 0
+ -0 1 0 0
+ 0 0 1 -64
+2 168 1 173 1 0
+1
+ 0 1 0 0
+1
+ 1 0 0 24.9999998448251
+ 0 1 0 0
+ 0 0 1 -3.25
+1
+0.984807759068988 -0.173648143317221 -1.68667756772623e-18 0.379806020917847
+0.173648143317221 0.984807759068988 1.92788166894188e-17 -4.3412035559847
+-1.68667756772623e-18 -1.92788166894188e-17 1 0
+2 175 1 176 1 177 1 165 1 0
+2 158 1 159 1 160 1 161 1 162 1 163 1 164 1 177 -1 176 -1 175 -1 0
+2 177 -1 176 -1 175 -1 0
+2 175 1 176 1 177 1 0
+1
+ 1 0 -0 3.5
+ -0 1 0 0
+ 0 0 1 0
+2 182 -1 0
+2 172 1 158 1 159 1 160 1 161 1 162 1 163 1 164 1 0
+2 164 -1 163 -1 162 -1 161 -1 160 -1 159 -1 158 -1 172 -1 0
+2 172 -1 0
+2 168 1 173 1 39 1 40 1 41 1 0
+2 173 -1 168 -1 0
+2 158 1 159 1 160 1 161 1 162 1 163 1 164 1 0
+2 182 1 175 1 176 1 177 1 0
+2 177 -1 176 -1 175 -1 182 -1 0
+2 164 -1 163 -1 162 -1 161 -1 160 -1 159 -1 158 -1 0
+2 182 1 175 1 176 1 177 1 165 1 0
+2 158 1 159 1 160 1 161 1 162 1 163 1 164 1 177 -1 176 -1 175 -1 182 -1 0
+Curve2ds 2514
+1 0 0 0 -1
+1 6.28318530717959 0 0 -1
+1 0 0 1 0
+1 0 -6.75 1 0
+1 0 0 1 0
+1 0 -7 1 0
+8 0 0.353553390593274
+1 6.28318530717959 0 0 1
+1 0 0 0 1
+1 0 0.353553390593274 1 0
+2 0 0 1 0 -0 1 0.75
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 0 -1
+1 0 4.71238898038469 1 0
+2 0 0 1 0 -0 1 12.75
+1 0 0 1 0
+1 0 -5 1 0
+1 0 0 1 0
+1 0 -5 1 0
+1 0 0 1 0
+1 0 -10 1 0
+1 0 0 1 0
+1 0 -10 1 0
+1 0 0 1 0
+1 0 -10 1 0
+1 0 0 1 0
+1 0 -10 1 0
+1 0 0 1 0
+1 0 -10 1 0
+1 0 0 1 0
+1 0 -10 1 0
+1 0 0 1 0
+1 0 -10 1 0
+1 0 0 1 0
+1 0 -10 1 0
+1 0 0 1 0
+1 0 -10 1 0
+1 0 0 1 0
+1 0 -10 1 0
+1 0 0 1 0
+1 0 -10 1 0
+1 0 0 1 0
+1 0 -10 1 0
+1 0 0 1 0
+1 0 -10 1 0
+1 0 0 1 0
+1 0 -10 1 0
+1 0 0 1 0
+1 0 -10 1 0
+1 0 0 1 0
+1 0 -10 1 0
+1 0 0 1 0
+1 0 -10 1 0
+8 4.71238898038469 6.28318530717959
+1 0 0 0 1
+1 0 6.28318530717959 1 0
+1 0 -1 1 0
+1 0 0 0 -1
+1 0 0 1 0
+1 0 -32 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 1.13159732727015 0 0 -1
+1 4.27318998085994 0 0 -1
+1 0.439198999524751 0 0 -1
+1 6.72238430670434 0 0 -1
+1 3.58079165311454 0 0 -1
+1 0 0 0 -1
+1 0 0 1 0
+2 0 0 1 0 -0 1 6.875
+2 -3.23815048849004e-16 -7.05661503423724e-15 -1.10555925536877e-32 1 1 1.10555925536877e-32 1.5
+1 -1.5707963267949 -4.16666666666667 1 0
+1 0 0 0 1
+1 0 0.583333333333333 1 0
+1 0 0 0 -1
+2 0 0 0 -1 1 0 1.5
+1 -1.5707963267949 -22.5 1 0
+2 0 0 -1 0 0 1 2.375
+1 -3.14159265358979 0.583333333333333 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+2 0 0 0 -1 1 0 9.5
+1 7.94124809403556 31.0099999997765 -1 0
+1 -6.15018367767334 3 -1 0
+1 6.15018367767334 -37.5 -1 0
+1 6.15018367767334 3 1 0
+1 -9 1.5 0 1
+1 1.5 -37.5 -1 0
+1 9 1.5 0 1
+1 1.5 -37.5 -1 0
+1 -4.5 -3 1 0
+1 -4.5 -37.5 -1 0
+1 4.5 -3 -1 0
+1 -4.5 -37.5 -1 0
+1 -7.63656151700618 -4.46010324328665 -0.675283841708162 0.737557952386025
+1 1.86726198309587 -1 -1 0
+1 -4.0732598573327 -2.04729703897629 -0.926999210875127 -0.375063278710263
+1 4.54377461336901 -1 -1 0
+1 -8.89749336242676 1.5259712934494 0 1
+1 1.5259712934494 -1 -1 0
+1 -3.88720297813416 -3.54477834701538 -1 0
+1 3.88720297813416 -1 -1 0
+1 -7.36207979327511 4.80322269159811 0.659244393355508 0.75192873986125
+1 -1.24172864138617 -1 -1 0
+1 -7.27440595626831 -1.77238917350769 0 -1
+1 1.77238917350769 -1 -1 0
+1 -4.53820972575637 0.957958455179706 0.781120370403359 -0.624380466495325
+1 -4.14301860907919 -1 -1 0
+1 -3.63720297813416 -2.80323314666748 -1 0
+1 3.63720297813416 -1 -1 0
+1 -3.63720297813416 3.54477834701538 1 0
+1 -3.63720297813416 -1 -1 0
+1 -6.96637487411499 -1.40161657333374 0 -1
+1 1.40161657333374 -1 -1 0
+1 -7.27440595626831 1.40161657333374 0 -1
+1 -1.40161657333374 -1 -1 0
+1 -3.4831874370575 2.80323314666748 1 0
+1 -3.4831874370575 -1 -1 0
+1 7.63656151700618 -4.46010324328665 0.675283841708162 0.737557952386025
+1 4.0732598573327 -2.04729703897629 0.926999210875127 -0.375063278710263
+1 8.89749336242676 1.5259712934494 0 1
+1 3.88720297813416 -3.54477834701538 1 0
+1 7.36207979327511 4.80322269159811 -0.659244393355508 0.75192873986125
+1 7.27440595626831 -1.77238917350769 0 -1
+1 4.53820972575637 0.957958455179706 -0.781120370403359 -0.624380466495325
+1 3.63720297813416 -2.80323314666748 1 0
+1 3.63720297813416 3.54477834701538 -1 0
+1 6.96637487411499 -1.40161657333374 0 -1
+1 7.27440595626831 1.40161657333374 0 -1
+1 3.4831874370575 2.80323314666748 -1 0
+1 -2 3.375 0 1
+1 3.375 -1 -1 0
+1 -1 4.75 -1 0
+1 1 -1 -1 0
+1 1 6.75 1 0
+1 1 -1 -1 0
+1 2 2.375 0 -1
+1 -2.375 -1 -1 0
+1 -2 -3.375 0 -1
+1 3.375 -1 -1 0
+1 -1 -4.75 -1 0
+1 1 -1 -1 0
+1 1 -6.75 1 0
+1 1 -1 -1 0
+1 2 -2.375 0 1
+1 -2.375 -1 -1 0
+1 0 0 0 1
+1 0 0 1 0
+2 0 0 1 0 -0 1 2.375
+1 0.472437057647217 -3.5 -2.33361217238386e-16 -1
+1 0.314022504840777 7.04184338500774e-18 0 1
+1 0.698131700797731 0 0 -1
+1 2.87979326579064 0 0 -1
+1 0 0 0 -1
+1 6.17846555205992 0 0 -1
+1 0 0 0 -1
+1 0.698131700797732 0 0 -1
+1 2.61799387799149 0 0 -1
+1 6.07374579694026 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 2.35619449019234 0 0 -1
+1 0 0 0 -1
+1 5.9690260418206 0 0 -1
+1 0 0 0 -1
+1 2.0943951023932 0 0 -1
+1 0.698131700797733 0 0 -1
+1 5.86430628670094 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.698131700797727 0 0 -1
+1 1.83259571459405 0 0 -1
+1 0 0 0 -1
+1 5.75958653158128 0 0 -1
+1 0 0 0 -1
+1 0.698131700797722 0 0 -1
+1 1.5707963267949 0 0 -1
+1 5.65486677646162 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 1.30899693899575 0 0 -1
+1 0 0 0 -1
+1 5.55014702134197 0 0 -1
+1 0 0 0 -1
+1 1.0471975511966 0 0 -1
+1 0.698131700797726 0 0 -1
+1 5.44542726622231 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.785398163397448 0 0 -1
+1 0 0 0 -1
+1 5.34070751110265 0 0 -1
+1 0 0 0 -1
+1 0.523598775598299 0 0 -1
+1 0.698131700797736 0 0 -1
+1 5.23598775598299 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.698131700797783 0 0 -1
+1 0.261799387799149 0 0 -1
+1 0 0 0 -1
+1 5.13126800086333 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.69813170079773 0 0 -1
+1 5.02654824574367 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.698131700797734 0 0 -1
+1 6.02138591938044 0 0 -1
+1 0 0 0 -1
+1 4.92182849062401 0 0 -1
+1 0 0 0 -1
+1 5.75958653158129 0 0 -1
+1 4.81710873550435 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 5.49778714378214 0 0 -1
+1 0 0 0 -1
+1 4.71238898038469 0 0 -1
+1 0 0 0 -1
+1 0.698131700797729 0 0 -1
+1 4.60766922526503 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 4.97418836818384 0 0 -1
+1 0 0 0 -1
+1 4.50294947014537 0 0 -1
+1 0 0 0 -1
+1 4.39822971502571 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.698131700797678 0 0 -1
+1 4.45058959258554 0 0 -1
+1 0 0 0 -1
+1 4.29350995990605 0 0 -1
+1 0 0 0 -1
+1 4.18879020478639 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 3.92699081698724 0 0 -1
+1 0 0 0 -1
+1 4.08407044966673 0 0 -1
+1 0 0 0 -1
+1 3.66519142918809 0 0 -1
+1 0.698131700797735 0 0 -1
+1 3.97935069454707 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 3.40339204138894 0 0 -1
+1 0 0 0 -1
+1 3.87463093942741 0 0 -1
+1 0 0 0 -1
+1 3.14159265358979 0 0 -1
+1 3.76991118430775 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.392083308401239 -8.96107896093357e-18 0 1
+1 0.182992513907313 -3.5 -2.31518709897174e-16 -1
+1 0.698131700797723 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.10471975511966 0 0 -1
+1 0 0 0 -1
+1 3.56047167406843 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.20943951023932 0 0 -1
+1 3.45575191894877 0 0 -1
+1 0 0 0 -1
+1 0.31415926535898 0 0 -1
+1 0 0 0 -1
+1 3.35103216382911 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.698131700797728 0 0 -1
+1 0.418879020478639 0 0 -1
+1 3.24631240870945 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.628318530717959 0 0 -1
+1 3.03687289847013 0 0 -1
+1 0 0 0 -1
+1 0.733038285837618 0 0 -1
+1 0 0 0 -1
+1 2.93215314335047 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.837758040957278 0 0 -1
+1 2.82743338823081 0 0 -1
+1 0 0 0 -1
+1 0.942477796076938 0 0 -1
+1 0 0 0 -1
+1 2.72271363311115 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.698131699497974 0 0 -1
+1 1.0471975512219 0 0 -1
+1 0 0 0 -1
+1 1.15191636953285 0 0 -1
+1 0 0 0 -1
+1 2.51327412287183 0 0 -1
+1 0.698111091562759 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.698131700797724 0 0 -1
+1 1.25663706143592 0 0 -1
+1 2.40855436775217 0 0 -1
+1 0 0 0 -1
+1 1.36135681655558 0 0 -1
+1 0 0 0 -1
+1 2.30383461263251 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 1.46607657167524 0 0 -1
+1 2.19911485751285 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.698131700797718 0 0 -1
+1 2.09439510239319 0 0 -1
+1 0.698131700797755 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.698131700797701 0 0 -1
+1 1.67551608191456 0 0 -1
+1 1.98967534727353 0 0 -1
+1 0 0 0 -1
+1 1.78023583703422 0 0 -1
+1 0 0 0 -1
+1 1.88495559215388 0 0 -1
+1 0.698131700797743 0 0 -1
+1 0 0 0 -1
+1 3.55014770291568 0 0 1
+1 3.28648916668671 -6.49000000022352 0 -1
+1 6.04916317797585 0 0 1
+1 0 31 1 0
+2 0 0 -1 -1.1686558153949e-17 -1.1686558153949e-17 1 9.5
+1 6.15018367767334 -3.5 -1 0
+1 5.86531315269332 -3.52460790584744 0.996194698313003 -0.0871557402186753
+1 6.15018367767334 -4.49000000022352 -1 0
+1 6.15018367767334 -37.4900000002235 -1 0
+1 2.87766980546001 0 0 1
+1 1.19856569975942 -3.5 0 1
+1 6.15018367767334 -5.49000000022352 -1 0
+1 6.15018367767334 -36.4900000002235 -1 0
+1 6.15018367767334 -6.49000000022352 -1 0
+1 6.15018367767334 -35.4900000002235 -1 0
+1 6.15018367767334 -7.49000000022352 -1 0
+1 6.15018367767334 -34.4900000002235 -1 0
+1 6.15018367767334 -9.49000000022352 -1 0
+1 6.15018367767334 -32.4900000002235 -1 0
+1 6.15018367767334 -10.4900000002235 -1 0
+1 6.15018367767334 -31.4900000002235 -1 0
+1 6.15018367767334 -11.4900000002235 -1 0
+1 6.15018367767334 -30.4900000002235 -1 0
+1 6.15018367767334 -12.4900000002235 -1 0
+1 6.15018367767334 -29.4900000002235 -1 0
+1 6.15018367767334 -14.4900000002235 -1 0
+1 6.15018367767334 -27.4900000002235 -1 0
+1 6.15018367767334 -15.4900000002235 -1 0
+1 6.15018367767334 -26.4900000002235 -1 0
+1 6.15018367767334 -16.4900000002235 -1 0
+1 6.15018367767334 -25.4900000002235 -1 0
+1 6.15018367767334 -17.4900000002235 -1 0
+1 6.15018367767334 -24.4900000002235 -1 0
+1 6.15018367767334 -19.4900000002235 -1 0
+1 6.15018367767334 -22.4900000002235 -1 0
+1 6.15018367767334 -20.4900000002235 -1 0
+1 6.15018367767334 -21.4900000002235 -1 0
+1 -6.38824759400537 -2.45256028403057 -0.996194698313003 0.0871557402186753
+1 0.263922848129788 0 0 1
+1 -9 1.5 0 1
+1 1.5 -3.5 -1 0
+1 -3.96596165426659 -19.8889145019957 0.500000000000001 -0.866025403784438
+1 -15.2413243852917 -0.5 1 0
+1 10.7173500291329 -20.8554208529418 -0.500000000000001 -0.866025403784438
+1 -12.7026492506969 -0.5 1 0
+2 3.5 -34.8203394145464 0 -1 1 0 1
+1 -1.5707963267949 -0.5 1 0
+2 3.5 -31.3562377994086 0 -1 1 0 1
+1 4.71238898038469 -0.5 1 0
+1 -5.84235002913288 -20.6389145019957 0.500000000000001 -0.866025403784438
+1 -14.9526492506969 -0.5 1 0
+1 -2.860299221564 -18.339876396319 -0.500000000000001 0.866025403784438
+1 14.4526492506969 -0.5 1 0
+2 2.5 -33.0882886069775 0 -1 1 0 1
+1 9.96735002913288 -18.6903573434807 -0.500000000000001 -0.866025403784438
+1 -11.2026492506969 -0.5 1 0
+1 8.84096165426659 -20.1054208529418 -0.500000000000001 -0.866025403784438
+1 -12.9913243852917 -0.5 1 0
+2 3.5 -27.8921361842709 0 -1 1 0 1
+1 -4.73668759643029 -19.089876396319 -0.500000000000001 0.866025403784438
+1 14.1639741161021 -0.5 1 0
+1 -2.4659616542666 -15.5587874830735 0.500000000000001 -0.866025403784438
+1 -12.2413243852917 -0.5 1 0
+2 2.5 -29.6241869918398 0 -1 1 0 1
+1 9.21735002913288 -16.5252938340196 -0.5 -0.866025403784439
+1 -9.70264925069688 -0.5 1 0
+1 8.09096165426659 -17.9403573434807 -0.500000000000001 -0.866025403784438
+1 -11.4913243852917 -0.5 1 0
+2 3.5 -24.4280345691331 0 -1 1 0 1
+1 -4.34235002913288 -16.3087874830735 0.500000000000001 -0.866025403784438
+1 -11.9526492506969 -0.5 1 0
+1 -1.71596165426659 -13.3937239736124 0.5 -0.866025403784439
+1 -10.7413243852917 -0.5 1 0
+2 2.5 -26.160085376702 0 -1 1 0 1
+1 8.46735002913288 -14.3602303245585 -0.5 -0.866025403784439
+1 -8.20264925069687 -0.5 1 0
+1 7.34096165426659 -15.7752938340196 -0.5 -0.866025403784439
+1 -9.99132438529169 -0.5 1 0
+2 3.5 -20.9639329539954 0 -1 1 0 1
+1 -3.59235002913287 -14.1437239736124 0.5 -0.866025403784439
+1 -10.4526492506969 -0.5 1 0
+1 -0.965961654266588 -11.2286604641513 0.5 -0.866025403784439
+1 -9.24132438529168 -0.5 1 0
+2 2.5 -22.6959837615642 0 -1 1 0 1
+1 7.71735002913287 -12.1951668150974 -0.5 -0.866025403784439
+1 -6.70264925069687 -0.5 1 0
+1 6.59096165426659 -13.6102303245585 -0.5 -0.866025403784439
+1 -8.49132438529169 -0.5 1 0
+2 3.5 -17.4998313388576 0 -1 1 0 1
+1 -2.84235002913287 -11.9786604641513 0.5 -0.866025403784439
+1 -8.95264925069687 -0.5 1 0
+1 -0.215961654266591 -9.06359695469019 0.5 -0.866025403784439
+1 -7.74132438529168 -0.5 1 0
+2 2.5 -19.2318821464265 0 -1 1 0 1
+1 6.96735002913287 -10.0301033056363 -0.5 -0.866025403784439
+1 -5.20264925069687 -0.5 1 0
+1 5.84096165426659 -11.4451668150974 -0.5 -0.866025403784439
+1 -6.99132438529168 -0.5 1 0
+2 3.5 -14.0357297237199 0 -1 1 0 1
+1 -2.09235002913287 -9.81359695469019 0.5 -0.866025403784439
+1 -7.45264925069687 -0.5 1 0
+1 0.534038345733409 -6.89853344522909 0.5 -0.866025403784439
+1 -6.24132438529168 -0.5 1 0
+2 2.5 -15.7677805312887 0 -1 1 0 1
+1 6.21735002913287 -7.8650397961752 -0.5 -0.866025403784439
+1 -3.70264925069687 -0.5 1 0
+1 5.09096165426659 -9.2801033056363 -0.5 -0.866025403784439
+1 -5.49132438529168 -0.5 1 0
+2 3.5 -10.5716281085821 0 -1 1 0 1
+1 -1.34235002913287 -7.64853344522909 0.5 -0.866025403784439
+1 -5.95264925069687 -0.5 1 0
+1 1.28403834573341 -4.73346993576799 0.5 -0.866025403784439
+1 -4.74132438529168 -0.5 1 0
+2 2.5 -12.303678916151 0 -1 1 0 1
+1 5.46735002913287 -5.69997628671411 -0.5 -0.866025403784439
+1 -2.20264925069687 -0.5 1 0
+1 4.34096165426659 -7.1150397961752 -0.5 -0.866025403784439
+1 -3.99132438529168 -0.5 1 0
+2 3.5 -7.10752649344435 0 -1 1 0 1
+1 -0.592350029132874 -5.48346993576799 0.5 -0.866025403784439
+1 -4.45264925069687 -0.5 1 0
+1 1.889700778436 -2.3184064263069 0.5 -0.866025403784439
+1 -2.95264925069687 -0.5 1 0
+2 2.5 -8.83957730101323 0 -1 1 0 1
+2 2.5 -5.37547568587548 0 -1 1 0 1
+1 3.59096165426659 -4.94997628671411 -0.5 -0.866025403784439
+1 -2.49132438529168 -0.5 1 0
+1 0.157649970867126 -3.3184064263069 0.5 -0.866025403784439
+1 9 1.5 0 1
+1 1.5 -3.5 -1 0
+1 -3.96596165426659 -19.8889145019957 -0.500000000000001 0.866025403784438
+1 -15.2413243852917 -0.5 -1 0
+2 3.5 -34.8203394145464 0 1 1 -0 1
+1 7.85398163397448 -0.5 -1 0
+1 10.7173500291329 -20.8554208529418 0.500000000000001 0.866025403784438
+1 -12.7026492506969 -0.5 -1 0
+1 -5.84235002913288 -20.6389145019957 -0.500000000000001 0.866025403784438
+1 -14.9526492506969 -0.5 -1 0
+2 3.5 -31.3562377994086 0 1 1 -0 1
+2 2.5 -33.0882886069775 0 1 1 -0 1
+1 -2.860299221564 -18.339876396319 0.500000000000001 -0.866025403784438
+1 14.4526492506969 -0.5 -1 0
+1 8.84096165426659 -20.1054208529418 0.500000000000001 0.866025403784438
+1 -12.9913243852917 -0.5 -1 0
+1 9.96735002913288 -18.6903573434807 0.500000000000001 0.866025403784438
+1 -11.2026492506969 -0.5 -1 0
+1 -4.73668759643029 -19.089876396319 0.500000000000001 -0.866025403784438
+1 14.1639741161021 -0.5 -1 0
+2 3.5 -27.8921361842709 0 1 1 -0 1
+2 2.5 -29.6241869918398 0 1 1 -0 1
+1 -2.4659616542666 -15.5587874830735 -0.500000000000001 0.866025403784438
+1 -12.2413243852917 -0.5 -1 0
+1 8.09096165426659 -17.9403573434807 0.500000000000001 0.866025403784438
+1 -11.4913243852917 -0.5 -1 0
+1 9.21735002913288 -16.5252938340196 0.5 0.866025403784439
+1 -9.70264925069688 -0.5 -1 0
+1 -4.34235002913288 -16.3087874830735 -0.500000000000001 0.866025403784438
+1 -11.9526492506969 -0.5 -1 0
+2 3.5 -24.4280345691331 0 1 1 -0 1
+2 2.5 -26.160085376702 0 1 1 -0 1
+1 -1.71596165426659 -13.3937239736124 -0.5 0.866025403784439
+1 -10.7413243852917 -0.5 -1 0
+1 7.34096165426659 -15.7752938340196 0.5 0.866025403784439
+1 -9.99132438529169 -0.5 -1 0
+1 8.46735002913288 -14.3602303245585 0.5 0.866025403784439
+1 -8.20264925069687 -0.5 -1 0
+1 -3.59235002913287 -14.1437239736124 -0.5 0.866025403784439
+1 -10.4526492506969 -0.5 -1 0
+2 3.5 -20.9639329539954 0 1 1 -0 1
+2 2.5 -22.6959837615642 0 1 1 -0 1
+1 -0.965961654266588 -11.2286604641513 -0.5 0.866025403784439
+1 -9.24132438529168 -0.5 -1 0
+1 6.59096165426659 -13.6102303245585 0.5 0.866025403784439
+1 -8.49132438529169 -0.5 -1 0
+1 7.71735002913287 -12.1951668150974 0.5 0.866025403784439
+1 -6.70264925069687 -0.5 -1 0
+1 -2.84235002913287 -11.9786604641513 -0.5 0.866025403784439
+1 -8.95264925069687 -0.5 -1 0
+2 3.5 -17.4998313388576 0 1 1 -0 1
+2 2.5 -19.2318821464265 0 1 1 -0 1
+1 -0.215961654266591 -9.06359695469019 -0.5 0.866025403784439
+1 -7.74132438529168 -0.5 -1 0
+1 5.84096165426659 -11.4451668150974 0.5 0.866025403784439
+1 -6.99132438529168 -0.5 -1 0
+1 6.96735002913287 -10.0301033056363 0.5 0.866025403784439
+1 -5.20264925069687 -0.5 -1 0
+1 -2.09235002913287 -9.81359695469019 -0.5 0.866025403784439
+1 -7.45264925069687 -0.5 -1 0
+2 3.5 -14.0357297237199 0 1 1 -0 1
+2 2.5 -15.7677805312887 0 1 1 -0 1
+1 0.534038345733409 -6.89853344522909 -0.5 0.866025403784439
+1 -6.24132438529168 -0.5 -1 0
+1 5.09096165426659 -9.2801033056363 0.5 0.866025403784439
+1 -5.49132438529168 -0.5 -1 0
+1 6.21735002913287 -7.8650397961752 0.5 0.866025403784439
+1 -3.70264925069687 -0.5 -1 0
+1 -1.34235002913287 -7.64853344522909 -0.5 0.866025403784439
+1 -5.95264925069687 -0.5 -1 0
+2 3.5 -10.5716281085821 0 1 1 -0 1
+2 2.5 -12.303678916151 0 1 1 -0 1
+1 1.28403834573341 -4.73346993576799 -0.5 0.866025403784439
+1 -4.74132438529168 -0.5 -1 0
+1 4.34096165426659 -7.1150397961752 0.5 0.866025403784439
+1 -3.99132438529168 -0.5 -1 0
+1 5.46735002913287 -5.69997628671411 0.5 0.866025403784439
+1 -2.20264925069687 -0.5 -1 0
+1 -0.592350029132874 -5.48346993576799 -0.5 0.866025403784439
+1 -4.45264925069687 -0.5 -1 0
+2 3.5 -7.10752649344435 0 1 1 -0 1
+2 2.5 -8.83957730101323 0 1 1 -0 1
+1 1.889700778436 -2.3184064263069 -0.5 0.866025403784439
+1 -2.95264925069687 -0.5 -1 0
+1 3.59096165426659 -4.94997628671411 0.5 0.866025403784439
+1 -2.49132438529168 -0.5 -1 0
+2 2.5 -5.37547568587548 0 1 1 -0 1
+1 0.157649970867126 -3.3184064263069 -0.5 0.866025403784439
+1 -4.5 -3 1 0
+1 -4.5 -3.5 -1 0
+1 2.90757052438606 0 0 1
+1 0.013878188659973 -6.49000000022352 0 -1
+1 4.74434336306454 2.59638326395497 -0.996194698313003 0.0871557402186753
+1 -4.5 -4.49000000022352 -1 0
+1 -4.5 -37.4900000002235 -1 0
+1 3.40551550171958 0 0 1
+1 2.10180165558726 -3.5 0 1
+1 -4.5 -5.49000000022352 -1 0
+1 -4.5 -36.4900000002235 -1 0
+1 0.0138781886599713 -6.49000000022352 0 -1
+1 -4.5 -6.49000000022352 -1 0
+1 -4.5 -35.4900000002235 -1 0
+1 -4.5 -7.49000000022352 -1 0
+1 -4.5 -34.4900000002235 -1 0
+1 -4.5 -9.49000000022352 -1 0
+1 -4.5 -32.4900000002235 -1 0
+1 -4.5 -10.4900000002235 -1 0
+1 -4.5 -31.4900000002235 -1 0
+1 -4.5 -11.4900000002235 -1 0
+1 -4.5 -30.4900000002235 -1 0
+1 -4.5 -12.4900000002235 -1 0
+1 -4.5 -29.4900000002235 -1 0
+1 -4.5 -14.4900000002235 -1 0
+1 -4.5 -27.4900000002235 -1 0
+1 -4.5 -15.4900000002235 -1 0
+1 -4.5 -26.4900000002235 -1 0
+1 -4.5 -16.4900000002235 -1 0
+1 -4.5 -25.4900000002235 -1 0
+1 -4.5 -17.4900000002235 -1 0
+1 -4.5 -24.4900000002235 -1 0
+1 -4.5 -19.4900000002235 -1 0
+1 -4.5 -22.4900000002235 -1 0
+1 -4.5 -20.4900000002235 -1 0
+1 -4.5 -21.4900000002235 -1 0
+1 4.5 -3 -1 0
+1 -4.5 -3.5 -1 0
+1 0.408555049325884 0 0 1
+1 -4.22140892175249 3.38078492592305 0.996194698313003 -0.0871557402186753
+1 6.0192624590498 0 0 1
+1 3.375 -3 1 0
+1 -2 3.375 0 -1
+1 1 -3 1 0
+1 -1 4.75 1 0
+1 1 -3 1 0
+1 1 6.75 -1 0
+1 -2.375 -3 1 0
+1 2 2.375 0 1
+1 -2 -3.375 0 -1
+1 3.375 -3 -1 0
+1 -1 -4.75 -1 0
+1 1 -3 -1 0
+1 1 -6.75 1 0
+1 1 -3 -1 0
+1 2 -2.375 0 1
+1 -2.375 -3 -1 0
+2 0 0 -1 0 0 1 6.875
+1 7.85398163397448 -33.9900000002235 -1 0
+2 0 0 -0.0871557402186753 -0.996194698313003 -0.996194698313003 0.0871557402186753 11.5
+1 1.9638703556417 -11.2138345982539 0.996194698313003 -0.0871557402186753
+1 2.93374729156494 -37.4900000002235 -1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+2 0 0 0 -1 1 0 9.5
+1 7.94124809403556 -2.99000000022352 -1 0
+1 0 -2 1 0
+1 7.85398163397448 -0.990000000223517 -1 0
+1 2.93374729156494 -4.49000000022352 -1 0
+1 1.86675924829246 0 0 1
+1 2.5133926168802 -3.5 0 1
+1 7.85398163397448 -1.99000000022352 -1 0
+1 7.85398163397448 -32.9900000002235 -1 0
+1 2.93374729156494 -5.49000000022352 -1 0
+1 0 -1 1 0
+1 2.93374729156494 -36.4900000002235 -1 0
+1 0 30 1 0
+1 0 0 1 0
+1 0 29 1 0
+1 7.85398163397448 -2.99000000022352 -1 0
+1 2.93374729156494 -6.49000000022352 -1 0
+1 7.85398163397448 -31.9900000002235 -1 0
+1 2.93374729156494 -35.4900000002235 -1 0
+1 7.85398163397448 -3.99000000022352 -1 0
+1 7.85398163397448 -30.9900000002235 -1 0
+1 2.93374729156494 -7.49000000022352 -1 0
+1 0 1 1 0
+1 2.93374729156494 -34.4900000002235 -1 0
+1 0 28 1 0
+1 0 3 1 0
+1 5.35391727489809 0 0 1
+1 2.92961097694933 -11.9222527892982 -1 0
+1 7.94124809403556 1.11471725441515 -1 0
+2 5 -20 0 -1 -1 -0 9.5
+1 7.94124809403556 2.92961097694933 -1 0
+2 5 -20 0 -1 1 0 9.5
+1 4.24539360599343 0 0 1
+1 -1.11471725441515 -11.9222527892982 1 0
+1 0 26 1 0
+1 27.9296109769493 -11.9222527892982 -1 0
+1 7.94124809403556 26.1147172544152 -1 0
+1 7.94124809403556 27.9296109769493 -1 0
+1 -26.1147172544152 -11.9222527892982 1 0
+1 7.85398163397448 -5.99000000022352 -1 0
+1 2.93374729156494 -9.49000000022352 -1 0
+1 7.85398163397448 -28.9900000002235 -1 0
+1 2.93374729156494 -32.4900000002235 -1 0
+1 7.85398163397448 -6.99000000022352 -1 0
+1 7.85398163397448 -27.9900000002235 -1 0
+1 2.93374729156494 -10.4900000002235 -1 0
+1 0 4 1 0
+1 2.93374729156494 -31.4900000002235 -1 0
+1 0 25 1 0
+1 0 5 1 0
+1 0 24 1 0
+1 7.85398163397448 -7.99000000022352 -1 0
+1 2.93374729156494 -11.4900000002235 -1 0
+1 7.85398163397448 -26.9900000002235 -1 0
+1 2.93374729156494 -30.4900000002235 -1 0
+1 7.85398163397448 -8.99000000022352 -1 0
+1 7.85398163397448 -25.9900000002235 -1 0
+1 2.93374729156494 -12.4900000002235 -1 0
+1 0 6 1 0
+1 2.93374729156494 -29.4900000002235 -1 0
+1 0 23 1 0
+1 0 8 1 0
+1 7.92961097694933 -11.9222527892982 -1 0
+1 7.94124809403556 6.11471725441515 -1 0
+1 7.94124809403556 7.92961097694933 -1 0
+1 -6.11471725441515 -11.9222527892982 1 0
+1 0 21 1 0
+1 22.9296109769493 -11.9222527892982 -1 0
+1 7.94124809403556 21.1147172544152 -1 0
+1 7.94124809403556 22.9296109769493 -1 0
+1 -21.1147172544152 -11.9222527892982 1 0
+1 7.85398163397448 -10.9900000002235 -1 0
+1 2.93374729156494 -14.4900000002235 -1 0
+1 7.85398163397448 -23.9900000002235 -1 0
+1 2.93374729156494 -27.4900000002235 -1 0
+1 7.85398163397448 -11.9900000002235 -1 0
+1 7.85398163397448 -22.9900000002235 -1 0
+1 2.93374729156494 -15.4900000002235 -1 0
+1 0 9 1 0
+1 2.93374729156494 -26.4900000002235 -1 0
+1 0 20 1 0
+1 0 10 1 0
+1 0 19 1 0
+1 7.85398163397448 -12.9900000002235 -1 0
+1 2.93374729156494 -16.4900000002235 -1 0
+1 7.85398163397448 -21.9900000002235 -1 0
+1 2.93374729156494 -25.4900000002235 -1 0
+1 7.85398163397448 -13.9900000002235 -1 0
+1 7.85398163397448 -20.9900000002235 -1 0
+1 2.93374729156494 -17.4900000002235 -1 0
+1 0 11 1 0
+1 2.93374729156494 -24.4900000002235 -1 0
+1 0 18 1 0
+1 0 13 1 0
+1 12.9296109769493 -11.9222527892982 -1 0
+1 7.94124809403556 11.1147172544152 -1 0
+1 7.94124809403556 12.9296109769493 -1 0
+1 -11.1147172544152 -11.9222527892982 1 0
+1 0 16 1 0
+1 17.9296109769493 -11.9222527892982 -1 0
+1 7.94124809403556 16.1147172544152 -1 0
+1 7.94124809403556 17.9296109769493 -1 0
+1 -16.1147172544152 -11.9222527892982 1 0
+1 7.85398163397448 -15.9900000002235 -1 0
+1 2.93374729156494 -19.4900000002235 -1 0
+1 7.85398163397448 -18.9900000002235 -1 0
+1 2.93374729156494 -22.4900000002235 -1 0
+1 7.85398163397448 -16.9900000002235 -1 0
+1 7.85398163397448 -17.9900000002235 -1 0
+1 2.93374729156494 -20.4900000002235 -1 0
+1 0 14 1 0
+1 2.93374729156494 -21.4900000002235 -1 0
+1 0 15 1 0
+1 1.27483340529733 0 0 1
+1 9.22159654937957 -3.5 0 1
+1 6.80678408277789 0 0 -1
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 6.80678408277788 0 0 -1
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 0 0 1 0
+1 0 -3 1 0
+1 3.88129664045255 10.7024487646322 0.996194698313003 -0.0871557402186753
+1 4.41642605888712 0 0 1
+1 1.10380095240364 0 0 1
+1 2.92705512978137 -11.9222527892982 -1 0
+1 7.94124809403556 1.06049705483019 -1 0
+2 5 -20 0 1 -1 0 9.5
+1 7.94124809403556 2.92705512978137 -1 0
+2 5 -20 0 1 1 -0 9.5
+1 2.2123246213083 0 0 1
+1 -1.06049705483019 -11.9222527892982 1 0
+1 27.9270551297814 -11.9222527892982 -1 0
+1 7.94124809403556 26.0604970548302 -1 0
+1 7.94124809403556 27.9270551297814 -1 0
+1 -26.0604970548302 -11.9222527892982 1 0
+1 7.92705512978137 -11.9222527892982 -1 0
+1 7.94124809403556 6.06049705483019 -1 0
+1 7.94124809403556 7.92705512978137 -1 0
+1 -6.06049705483019 -11.9222527892982 1 0
+1 22.9270551297814 -11.9222527892982 -1 0
+1 7.94124809403556 21.0604970548302 -1 0
+1 7.94124809403556 22.9270551297814 -1 0
+1 -21.0604970548302 -11.9222527892982 1 0
+1 12.9270551297814 -11.9222527892982 -1 0
+1 7.94124809403556 11.0604970548302 -1 0
+1 7.94124809403556 12.9270551297814 -1 0
+1 -11.0604970548302 -11.9222527892982 1 0
+1 17.9270551297814 -11.9222527892982 -1 0
+1 7.94124809403556 16.0604970548302 -1 0
+1 7.94124809403556 17.9270551297814 -1 0
+1 -16.0604970548302 -11.9222527892982 1 0
+1 5.00835190188226 0 0 1
+1 0 0 1 0
+1 0 -34 1 0
+1 0 0 1 0
+1 0 -1 1 0
+1 0 0 1 0
+1 0 -2 1 0
+1 0 0 1 0
+1 0 -34 1 0
+1 0 0 1 0
+1 0 -1 1 0
+1 0 0 1 0
+1 0 -2 1 0
+1 0 0 1 0
+1 0 -2 1 0
+1 0 0 1 0
+1 0 -2 1 0
+1 0 0 0 1
+1 0 0 1 0
+1 0 0 0 1
+1 0 0 1 0
+1 0 0 0 -1
+1 0 0 1 0
+1 0 -3 1 0
+1 2.04656324156928 0 0 -1
+1 1.09706513192818 0 0 -1
+2 -6.47630097698008e-17 6.82426187587988e-15 -1.10555925536877e-32 -1 1 -1.10555925536877e-32 1.5
+1 -1.5707963267949 -1.83333333333333 1 0
+1 -2.96705976326997 -2.33333333333334 1 0
+2 0 -0 -0.984807759068988 0.173648143317221 0.173648143317221 0.984807759068988 2
+8 0 0.707106781186548
+1 0 0 0 1
+1 0 0.707106781186548 1 0
+2 0 0 1 0 -0 1 8
+1 0 0 1 0
+1 0 -0.5 1 0
+1 0 0 0 -1
+2 1.59653145349507e-47 -6.47630097698009e-16 -1 2.46519032881566e-32 -2.46519032881566e-32 -1 2
+1 -2.96705976326997 -4 1 0
+2 0 0 0 -1 1 0 1.5
+1 -1.5707963267949 -60 1 0
+1 0 0 0 1
+2 0 0 1 0 -0 1 1
+1 0 0 1 0
+1 0 0 1 0
+1 0 -63.5 1 0
+1 0 0 0 1
+1 0 0 0 1
+2 0 0 1 0 -0 1 1
+2 0 0 -1 0 0 1 1.125
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 1 0
+1 0 -3.5 1 0
+1 0 0 0 1
+1 0 0 1 0
+2 0 0 1 0 -0 1 1.125
+1 0.582332237511624 4.57662260355285e-17 0 1
+1 0.475430415035387 -3.5 -2.33361217238386e-16 -1
+1 0 0 0 -1
+1 2.69279370307697 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 2.24399475256414 0 0 -1
+1 0 0 0 -1
+1 1.79519580205131 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.698131700797737 0 0 -1
+1 0 0 0 -1
+1 1.34639685153848 0 0 -1
+1 0 0 0 -1
+1 0.897597901025655 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.448798950512828 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 5.83438635666676 0 0 -1
+1 0 0 0 -1
+1 5.38558740615393 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 4.9367884556411 0 0 -1
+1 0 0 0 -1
+1 4.48798950512828 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 4.03919055461545 0 0 -1
+1 0 0 0 -1
+1 3.59039160410262 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0.157382650922508 -3.5 -2.32836603326017e-16 -1
+1 0.122452388467583 -4.80969060814186e-16 0 1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 -1
+1 0 0 0 1
+1 0 0 1 0
+1 0 0 0 1
+1 0 0 1 0
+Curves 1650
+1 25.9999998448251 -4.25474520993063e-06 -13.25 -0 -0 1
+2 24.9999998448251 -4.25474520993063e-06 -6.5 0 0 -1 1 0 0 0 -1 0 1
+2 24.9999998448251 -4.25474520993063e-06 -13.25 0 0 -1 1 0 0 0 -1 0 1
+1 25.9999998448251 -4.25474520993063e-06 -6.5 -0.707106781186548 0 0.707106781186547
+2 24.9999998448251 -4.25474520993063e-06 -6.25 0 0 -1 1 0 0 0 -1 0 0.75
+2 24.9999998448251 -4.25474520993063e-06 -16.25 0 0 -1 1 0 0 0 -1 0 5
+1 29.9999998448251 -4.25474520993063e-06 -16.25 -0 -0 1
+2 24.9999998448251 -4.25474520993063e-06 -16.25 0 0 -1 1 0 0 0 -1 0 12.75
+2 24.9999998448251 7.99999574525479 -16.25 0 0 -1 1 0 0 0 -1 0 1
+2 28.6143241317361 -7.69329093528985 -16.25 0 0 -1 1 0 0 0 -1 0 1.5
+2 24.9999998448251 -4.25474520993063e-06 -16.25 0 0 -1 1 0 0 0 -1 0 7
+2 32.6932865253697 -3.61432854165618 -16.25 0 0 -1 1 0 0 0 -1 0 1.5
+2 24.9999998448251 -4.25474520993063e-06 -16.25 0 0 -1 1 0 0 0 -1 0 10
+2 28.6143241317361 7.69329093528985 -16.25 0 0 1 1 -0 -0 -0 1 0 1.5
+2 24.9999998448251 4.25474520993063e-06 -16.25 0 0 1 1 -0 -0 -0 1 0 7
+2 32.6932865253697 3.61432854165618 -16.25 0 0 1 1 -0 -0 -0 1 0 1.5
+2 24.9999998448251 4.25474520993063e-06 -16.25 0 0 1 1 -0 -0 -0 1 0 10
+2 21.3856755579141 -7.69329093528985 -16.25 0 -0 1 -1 -0 0 -0 -1 -0 1.5
+2 24.9999998448251 -4.25474520993063e-06 -16.25 0 -0 1 -1 -0 0 -0 -1 -0 10
+2 17.3067131642804 -3.61432854165618 -16.25 0 -0 1 -1 -0 0 -0 -1 -0 1.5
+2 24.9999998448251 -4.25474520993063e-06 -16.25 0 -0 1 -1 -0 0 -0 -1 -0 7
+2 17.3067128914066 3.61431945133876 -16.25 -0 0 1 -7.54978997097311e-08 0.999999999999997 -0 -0.999999999999997 -7.54978995987088e-08 -0 1.5
+2 24.9999998448251 -4.25474521037472e-06 -16.25 -0 0 1 -7.54978997097311e-08 0.999999999999997 -0 -0.999999999999997 -7.54978995987088e-08 -0 10
+2 21.3856749770871 7.69328215292552 -16.25 -0 0 1 -7.54978997097311e-08 0.999999999999997 -0 -0.999999999999997 -7.54978995987088e-08 -0 1.5
+2 24.9999998448251 -4.25474521037472e-06 -16.25 -0 0 1 -7.54978997097311e-08 0.999999999999997 -0 -0.999999999999997 -7.54978995987088e-08 -0 7
+2 14.9999998448251 -4.25474520993063e-06 -16.25 0 0 -1 1 0 0 0 -1 0 1.5
+2 37.7499998448251 -4.25474520993063e-06 -17.25 -0 1 0 1 0 0 0 0 -1 1
+2 24.9999998448251 -4.25474520993063e-06 -17.25 0 0 -1 1 0 0 0 -1 0 13.75
+1 38.7499998448251 -4.25474520993063e-06 -16.25 0 0 -1
+2 32.9999998448251 -4.25474520993063e-06 -16.25 0 0 -1 1 0 0 0 -1 0 13.75
+2 24.9999998448251 -4.25474520993063e-06 -48.25 0 0 -1 1 0 0 0 -1 0 5
+1 25.3456745147705 -11.0365209579468 -48.25 1.22464679914735e-16 1 0
+1 27.5695056915283 -12 -48.25 -1 1.22464679914735e-16 -0
+1 22.3456745147705 -10.3627099990845 -48.25 0 -1 0
+1 22.3456745147705 -12.25 -48.25 1 0 0
+1 25.3456745147705 11.0365209579468 -48.25 1.22464679914735e-16 -1 -0
+1 27.5695056915283 12 -48.25 -1 -1.22464679914735e-16 -0
+1 22.3456745147705 10.3627099990845 -48.25 -0 1 0
+1 22.3456745147705 12.25 -48.25 1 -0 -0
+1 29.9999998448251 -4.25474520993063e-06 -48.25 0 0 -1
+1 25.3456745147705 -12.25 -48.25 0 0 -1
+1 25.3456745147705 -12 -48.25 0 0 -1
+1 22.3456745147705 -12.25 -48.25 0 0 -1
+1 22.3456745147705 -12 -48.25 0 0 -1
+1 25.3456745147705 12.25 -48.25 0 0 -1
+1 25.3456745147705 12 -48.25 0 0 -1
+1 22.3456745147705 12.25 -48.25 0 0 -1
+1 22.3456745147705 12 -48.25 0 0 -1
+1 25.9999998448251 7.99999574525479 -16.25 0 0 -1
+1 23.9999998448251 -8.00000425474521 -16.25 0 0 -1
+1 29.2521460647203 -9.05092976126831 -16.25 0 0 -1
+1 27.9765021987518 -6.33565210931138 -16.25 0 0 -1
+1 34.0509253513482 -4.25215047464047 -16.25 0 0 -1
+1 31.3356476993913 -2.97650660867189 -16.25 0 0 -1
+1 29.2521460647203 9.05092976126831 -16.25 0 0 -1
+1 27.9765021987518 6.33565210931138 -16.25 0 0 -1
+1 34.0509253513482 4.25215047464047 -16.25 0 0 -1
+1 31.3356476993913 2.97650660867189 -16.25 0 0 -1
+1 20.7478536249298 -9.05092976126831 -16.25 0 0 -1
+1 22.0234974908984 -6.33565210931138 -16.25 0 0 -1
+1 15.949074338302 -4.25215047464047 -16.25 0 0 -1
+1 18.6643519902589 -2.97650660867189 -16.25 0 0 -1
+1 15.9490740172739 4.25214128182417 -16.25 0 0 -1
+1 18.6643517655393 2.97649762085335 -16.25 0 0 -1
+1 20.747852941604 9.05092093074975 -16.25 0 0 -1
+1 22.0234970125703 6.33564337510126 -16.25 0 0 -1
+1 16.4999998448251 -4.25474520993063e-06 -16.25 0 0 -1
+2 2.91666666666667 0 0 1 0 0 0 0 1 0 -1 0 6.875
+8 1.5707963267949 7.85398163397448
+2 0 -6.40898493653923e-15 0.166666666666668 0 -1.22464679914735e-16 -1 0 1 -1.22464679914735e-16 1 0 0 1.5
+1 2.91666666666667 0 6.875 1 0 0
+8 0 6.28318530717959
+2 3.5 0 0 1 0 0 0 0 1 0 -1 0 6.875
+1 1.5 0 56.5 0 0 -1
+2 0 0 34 0 0 1 0 -1 0 1 0 -0 1.5
+8 3.14159265358979 9.42477796076938
+2 0 0 0 -1 0 0 0 0 -1 -0 -1 -0 2.375
+1 0 0.795603032049121 9.53287449408005 0 -0.998629534754574 0.0523359562429475
+2 0 1.0077593076089 -3.60879397446127 1 0 0 0 -0.897855597092752 0.440290048455808 0 -0.440290048455808 -0.897855597092752 1.94395801708275
+2 0 -0.995438171441418 8.77713367899895 1 0 0 0 0.955678042979317 -0.294413787325294 -0 0.294413787325294 0.955678042979317 1.94395801708275
+2 0 0 0 1 0 0 0 0 1 0 -1 0 2.85
+2 0 0 0 1 0 0 0 0 1 0 -1 0 8.25
+2 0 -3.26439613146082 -1.83920925103261 1 0 0 0 0.516867883338996 -0.856065179278229 -0 0.856065179278229 0.516867883338996 1.94395801708275
+2 0 3.65900142822974 8.03994286798066 1 0 0 0 -0.756109257202842 0.654445407327584 0 -0.654445407327584 -0.756109257202842 1.94395801708275
+1 0 -2.79915536931599 -3.08936908449356 0 0.793353340291234 -0.608761429008722
+1 0 2.76021325135306 9.15914314286783 0 -0.965925826289068 0.258819045102523
+2 0 -0.931651825941123 -3.62918691271211 1 0 0 0 -0.557420731784463 0.830230165542588 0 -0.830230165542588 -0.557420731784463 1.94395801708274
+2 0 0.851183244659894 8.79229548276163 1 0 0 0 0.873582116491336 -0.486676777488425 -0 0.486676777488425 0.873582116491336 1.94395801708275
+2 0 -3.74665460337702 0.0393961314608192 1 0 0 0 0.0195881277327475 -0.999808134219724 -0 0.999808134219724 0.0195881277327475 1.94395801708275
+2 0 5.25064158386452 7.10350165270432 1 0 0 0 -0.603519604640184 0.797348159096737 0 -0.797348159096737 -0.603519604640184 1.94395801708274
+1 0 -3.96882420121404 -1.2758944241797 0 0.382683432365089 -0.923879532511287
+1 0 4.60418890660018 8.38511328586726 0 -0.891006524188367 0.453990499739548
+2 0 -2.62142760510323 -2.67714214852014 1 0 0 0 -0.0676254315501626 0.997710780240273 0 -0.997710780240273 -0.0676254315501626 1.94395801708274
+2 0 2.66060386853919 8.42319178381299 1 0 0 0 0.753306459600605 -0.657669657141032 -0 0.657669657141032 0.753306459600605 1.94395801708276
+2 0 -3.225 1.90744535234444 1 0 0 0 -0.482940250880724 -0.875653307010979 0 0.875653307010979 -0.482940250880724 1.94395801708277
+2 0 6.61280350691073 5.85660332882204 1 0 0 0 -0.424553249346382 0.905402970212396 0 -0.905402970212396 -0.424553249346382 1.94395801708275
+1 0 -4.07504979349569 0.87945511672048 0 -0.130526192220053 -0.99144486137381
+1 0 6.24693941327929 7.24461374203661 0 -0.777145961456969 0.62932039104984
+2 0 -3.60879397446127 -1.00775930760889 1 0 0 -0 0.440290048455809 0.897855597092751 0 -0.897855597092751 0.440290048455809 1.94395801708275
+2 0 4.35374333636952 7.68595418495311 1 0 0 0 0.600107695659879 -0.799919216927428 -0 0.799919216927428 0.600107695659879 1.94395801708274
+2 0 -1.8392092510326 3.26439613146083 1 0 0 0 -0.856065179278228 -0.516867883338997 0 0.516867883338997 -0.856065179278228 1.94395801708276
+2 0 7.68595418495314 4.35374333636947 1 0 0 0 -0.227031879823628 0.973887326924296 0 -0.973887326924296 -0.227031879823628 1.94395801708276
+1 0 -3.08936908449356 2.79915536931599 0 -0.608761429008722 -0.793353340291234
+1 0 7.61666869145698 5.78748981416527 0 -0.629320391049836 0.777145961456972
+2 0 -3.62918691271211 0.931651825941123 1 0 0 -0 0.830230165542588 0.557420731784463 0 -0.557420731784463 0.830230165542588 1.94395801708274
+2 0 5.85660332882207 6.6128035069107 1 0 0 0 0.420681345782605 -0.907208468495823 -0 0.907208468495823 0.420681345782605 1.94395801708274
+2 0 0.0393961314608199 3.74665460337702 1 0 0 0 -0.999808134219724 -0.0195881277327477 0 0.0195881277327477 -0.999808134219724 1.94395801708275
+2 0 8.42319178381299 2.66060386853918 1 0 0 0 -0.0195881277327439 0.999808134219724 0 -0.999808134219724 -0.0195881277327439 1.94395801708274
+1 0 -1.2758944241797 3.96882420121404 0 -0.923879532511287 -0.38268343236509
+1 0 8.6535129989866 4.07742480995759 0 -0.453990499739538 0.891006524188372
+2 0 -2.67714214852014 2.62142760510322 1 0 0 -0 0.997710780240273 0.0676254315501632 0 -0.0676254315501632 0.997710780240273 1.94395801708275
+2 0 7.10350165270441 5.25064158386437 1 0 0 0 0.222869202441545 -0.974848356721736 -0 0.974848356721736 0.222869202441545 1.9439580170826
+2 0 1.90744535234441 3.225 1 0 0 0 -0.875653307010975 0.48294025088073 0 -0.48294025088073 -0.875653307010975 1.94395801708275
+2 0 8.79229548276163 0.851183244659852 1 0 0 -0 0.188711719534317 0.982032528438036 0 -0.982032528438036 0.188711719534317 1.94395801708275
+1 0 0.879455116720486 4.07504979349569 0 -0.99144486137381 0.130526192220054
+1 0 9.31215726429811 2.18915677589975 0 -0.25881904510252 0.965925826289069
+2 0 -1.00775930760888 3.60879397446127 1 0 0 0 0.897855597092751 -0.440290048455811 -0 0.440290048455811 0.897855597092751 1.94395801708275
+2 0 8.03994286798068 3.6590014282297 1 0 0 0 0.0153166055087473 -0.999882693917486 -0 0.999882693917486 0.0153166055087473 1.94395801708274
+2 0 3.26439613146082 1.83920925103261 1 0 0 0 -0.516867883338995 0.856065179278229 0 -0.856065179278229 -0.516867883338995 1.94395801708275
+2 0 8.77713367899895 -0.995438171441455 1 0 0 -0 0.388763959118435 0.92133738884871 0 -0.92133738884871 0.388763959118435 1.94395801708275
+1 0 2.79915536931599 3.08936908449356 0 -0.793353340291235 0.608761429008721
+1 0 9.56381557247154 0.205212085995401 0 -0.0523359562429416 0.998629534754574
+2 0 0.931651825941121 3.62918691271211 1 0 0 0 0.557420731784463 -0.830230165542588 -0 0.830230165542588 0.557420731784463 1.94395801708275
+2 0 8.625 1.90744535234441 1 0 0 0 -0.192905400582032 -0.981217359419556 0 0.981217359419556 -0.192905400582032 1.94395801708274
+2 0 3.74665460337702 -0.0393961314608269 1 0 0 0 -0.0195881277327481 0.999808134219724 0 -0.999808134219724 -0.0195881277327481 1.94395801708275
+2 0 8.37836901610377 -2.79855416280847 1 0 0 -0 0.571825348192627 0.820375384299395 0 -0.820375384299395 0.571825348192627 1.94395801708274
+1 0 3.96882420121404 1.2758944241797 0 -0.382683432365089 0.923879532511287
+1 0 9.39748924784919 -1.78770135678379 0 0.156434465040228 0.987688340595138
+2 0 2.62142760510323 2.67714214852014 1 0 0 0 0.0676254315501626 -0.997710780240273 -0 0.997710780240273 0.0676254315501626 1.94395801708274
+2 0 8.83310324467748 0.0725247616233621 1 0 0 0 -0.392696515004565 -0.919668117911711 0 0.919668117911711 -0.392696515004565 1.94395801708275
+2 0 3.225 -1.90744535234441 1 0 0 -0 0.482940250880728 0.875653307010977 0 -0.875653307010977 0.482940250880728 1.94395801708275
+2 0 7.61342942332977 -4.47935990830797 1 0 0 -0 0.729895225628348 0.683559038858344 0 -0.683559038858344 0.729895225628348 1.94395801708275
+1 0 4.07504979349569 -0.879455116720479 0 0.130526192220052 0.99144486137381
+1 0 8.8204475489393 -3.70248367192868 0 0.3583679495453 0.933580426497202
+2 0 3.60879397446127 1.0077593076089 1 0 0 0 -0.440290048455808 -0.897855597092752 0 0.897855597092752 -0.440290048455808 1.94395801708275
+2 0 8.65515749163058 -1.7655655091929 1 0 0 0 -0.575324907354431 -0.817924966593889 0 0.817924966593889 -0.575324907354431 1.94395801708289
+2 0 1.83920925103261 -3.26439613146082 1 0 0 -0 0.856065179278228 0.516867883338998 0 -0.516867883338998 0.856065179278228 1.94395801708275
+2 0 6.51574643146859 -5.96439613146081 1 0 0 -0 0.856065179278228 0.516867883338998 0 -0.516867883338998 0.856065179278228 1.94395801708275
+1 0 3.08936908449356 -2.79915536931599 0 0.60876142900872 0.793353340291236
+1 0 7.85790996693753 -5.45544968412244 0 0.544639035015025 0.838670567945425
+2 0 3.62918691271211 -0.931651825941115 1 0 0 0 -0.830230165542587 -0.557420731784465 0 0.557420731784465 -0.830230165542587 1.94395801708275
+2 0 8.09893982414579 -3.52649209513443 1 0 0 0 -0.732808840537747 -0.680434569396443 0 0.680434569396443 -0.732808840537747 1.94395801708275
+2 0 -0.0393961314608182 -3.74665460337702 1 0 0 -0 0.999808134219724 0.0195881277327488 0 -0.0195881277327488 0.999808134219724 1.94395801708275
+2 0 5.13329405453195 -7.18875962332079 1 0 0 -0 0.944820976737161 0.327587121110456 0 -0.327587121110456 0.944820976737161 1.94395801708274
+1 0 1.2758944241797 -3.96882420121404 0 0.923879532511287 0.38268343236509
+1 0 6.55194401294509 -6.96998636696807 0 0.707106781186545 0.707106781186551
+2 0 2.67714214852015 -2.62142760510322 1 0 0 0 -0.997710780240273 -0.0676254315501645 0 0.0676254315501645 -0.997710780240273 1.94395801708275
+2 0 7.18875962332082 -5.13329405453191 1 0 0 0 -0.858265510982587 -0.513205916429067 0 0.513205916429067 -0.858265510982587 1.94395801708275
+2 0 -1.90744535234441 -3.225 1 0 0 0 0.875653307010977 -0.482940250880728 -0 0.482940250880728 0.875653307010977 1.94395801708275
+2 0 3.52649209513445 -8.09893982414578 1 0 0 -0 0.992283563758622 0.123989229751979 0 -0.123989229751979 0.992283563758622 1.94395801708276
+1 0 -0.879455116720479 -4.07504979349569 0 0.99144486137381 -0.130526192220052
+1 0 4.9596266658714 -8.17990119987186 0 0.838670567945423 0.544639035015028
+2 0 1.90744535234445 8.62499999999999 1 0 0 0 -0.875653307010975 0.482940250880731 0 -0.482940250880731 -0.875653307010975 1.94395801708275
+2 0 5.96439613146085 -6.51574643146855 1 0 0 0 -0.946211860182636 -0.32354770227853 0 0.32354770227853 -0.946211860182636 1.94395801708277
+2 0 -2.79855416280849 8.37836901610376 1 0 0 0 0.99600625313706 -0.0892835019019452 -0 0.0892835019019452 0.99600625313706 1.94395801708276
+2 0 1.76556550919306 -8.65515749163053 1 0 0 0 0.996378597539011 -0.0850275859129999 -0 0.0850275859129999 0.996378597539011 1.94395801708275
+1 0 -1.20377885748233 9.48997348609396 0 -0.987688340595137 -0.156434465040233
+1 0 3.15054983456993 -9.03231509882041 0 0.933580426497202 0.3583679495453
+2 0 0.0725247616233552 8.83310324467748 1 0 0 0 -0.956927105451974 0.290328288065952 0 -0.290328288065952 -0.956927105451974 1.94395801708274
+2 0 4.47935990830799 -7.61342942332976 1 0 0 0 -0.992804210664447 -0.119748900984286 0 0.119748900984286 -0.992804210664447 1.94395801708275
+2 0 -4.47935990830798 7.61342942332977 1 0 0 -0 0.992804210664447 0.119748900984285 0 -0.119748900984285 0.992804210664447 1.94395801708275
+2 0 -0.0725247616233471 -8.83310324467748 1 0 0 0 0.956927105451975 -0.29032828806595 -0 0.29032828806595 0.956927105451975 1.94395801708275
+1 0 -3.15054983456992 9.03231509882041 0 -0.933580426497203 -0.358367949545297
+1 0 1.20377885748234 -9.48997348609396 0 0.987688340595138 0.156434465040233
+2 0 -1.76556550919304 8.65515749163054 1 0 0 0 -0.996378597539012 0.0850275859129976 0 -0.0850275859129976 -0.996378597539012 1.94395801708276
+2 0 2.79855416280848 -8.37836901610376 1 0 0 0 -0.99600625313706 0.0892835019019461 0 -0.0892835019019461 -0.99600625313706 1.94395801708274
+2 0 -5.96439613146083 6.51574643146857 1 0 0 -0 0.946211860182637 0.323547702278527 0 -0.323547702278527 0.946211860182637 1.94395801708276
+2 0 -1.9074453523444 -8.625 1 0 0 0 0.875653307010977 -0.482940250880727 -0 0.482940250880727 0.875653307010977 1.94395801708275
+1 0 -4.95962666587139 8.17990119987187 0 -0.838670567945425 -0.544639035015026
+1 0 -0.795603032049074 -9.53287449408006 0 0.998629534754574 -0.0523359562429411
+2 0 -3.52649209513444 8.09893982414579 1 0 0 0 -0.992283563758622 -0.123989229751976 0 0.123989229751976 -0.992283563758622 1.94395801708275
+2 0 0.995438171441464 -8.77713367899895 1 0 0 0 -0.955678042979318 0.294413787325289 0 -0.294413787325289 -0.955678042979318 1.94395801708275
+2 0 -7.18875962332081 5.13329405453192 1 0 0 -0 0.858265510982589 0.513205916429064 0 -0.513205916429064 0.858265510982589 1.94395801708275
+2 0 -3.6590014282297 -8.03994286798068 1 0 0 0 0.756109257202844 -0.654445407327581 -0 0.654445407327581 0.756109257202844 1.94395801708274
+1 0 -6.55194401294508 6.96998636696808 0 -0.707106781186547 -0.707106781186548
+1 0 -2.76021325135302 -9.15914314286784 0 0.965925826289069 -0.258819045102518
+2 0 -5.13329405453192 7.18875962332081 1 0 0 0 -0.944820976737162 -0.327587121110454 0 0.327587121110454 -0.944820976737162 1.94395801708275
+2 0 -0.851183244659862 -8.79229548276163 1 0 0 0 -0.873582116491338 0.486676777488422 0 -0.486676777488422 -0.873582116491338 1.94395801708275
+2 0 -8.09893982414579 3.52649209513444 1 0 0 -0 0.73280884053775 0.68043456939644 0 -0.68043456939644 0.73280884053775 1.94395801708275
+2 0 -5.25064158386451 -7.10350165270433 1 0 0 0 0.603519604640189 -0.797348159096734 -0 0.797348159096734 0.603519604640189 1.94395801708276
+1 0 -7.85790996693752 5.45544968412246 0 -0.544639035107479 -0.838670567885385
+1 0 -4.60418890660016 -8.38511328586728 0 0.891006524188369 -0.453990499739544
+2 0 -6.5157464292362 5.9643961342655 1 0 0 0 -0.856065178937484 -0.516867883903356 0 0.516867883903356 -0.856065178937484 1.9439580206637
+2 0 -2.66060386853918 -8.42319178381299 1 0 0 0 -0.753306459600606 0.657669657141031 0 -0.657669657141031 -0.753306459600606 1.94395801708274
+2 0 -8.6551615005749 1.76550817861768 1 0 0 -0 0.575311782061362 0.817934198711229 0 -0.817934198711229 0.575311782061362 1.9440147991904
+2 0 -6.61280350691072 -5.85660332882206 1 0 0 0 0.424553249346384 -0.905402970212395 -0 0.905402970212395 0.424553249346384 1.94395801708275
+1 0 -8.8204475489393 3.70248367192868 0 -0.358367949545301 -0.933580426497202
+1 0 -6.24693941327927 -7.24461374203662 0 0.777145961456971 -0.629320391049838
+2 0 -7.61342942332976 4.47935990830799 1 0 0 0 -0.729895225628346 -0.683559038858346 0 0.683559038858346 -0.729895225628346 1.94395801708277
+2 0 -4.35374333636949 -7.68595418495313 1 0 0 0 -0.600107695659883 0.799919216927425 0 -0.799919216927425 -0.600107695659883 1.94395801708276
+2 0 -8.83310324467747 -0.072524761623355 1 0 0 -0 0.392696515004565 0.919668117911711 0 -0.919668117911711 0.392696515004565 1.94395801708274
+2 0 -7.68595418495313 -4.35374333636949 1 0 0 0 0.227031879823626 -0.973887326924296 -0 0.973887326924296 0.227031879823626 1.94395801708275
+1 0 -9.39748924784919 1.78770135678379 0 -0.156434465040234 -0.987688340595137
+1 0 -7.61666869145698 -5.78748981416528 0 0.629320391049835 -0.777145961456973
+2 0 -8.37836901610376 2.79855416280848 1 0 0 0 -0.571825348192628 -0.820375384299395 0 0.820375384299395 -0.571825348192628 1.94395801708275
+2 0 -5.85660332882206 -6.61280350691071 1 0 0 0 -0.420681345782606 0.907208468495822 0 -0.907208468495822 -0.420681345782606 1.94395801708274
+2 0 -8.62500000000001 -1.90744535234434 1 0 0 -0 0.192905400582043 0.981217359419554 0 -0.981217359419554 0.192905400582043 1.94395801708268
+2 0 -8.42319178381301 -2.66060386853914 1 0 0 0 0.0195881277327562 -0.999808134219724 -0 0.999808134219724 0.0195881277327562 1.94395801708279
+1 0 -9.56381557247154 -0.205212085995403 0 0.0523359562429418 -0.998629534754574
+1 0 -8.65351299898661 -4.07742480995759 0 0.453990499739546 -0.891006524188368
+2 0 -8.77713367899895 0.995438171441455 1 0 0 0 -0.388763959118435 -0.92133738884871 0 0.92133738884871 -0.388763959118435 1.94395801708275
+2 0 -7.10350165270429 -5.25064158386457 1 0 0 0 -0.222869202441582 0.974848356721728 0 -0.974848356721728 -0.222869202441582 1.94395801708283
+2 0 -8.03994286798068 -3.65900142822967 1 0 0 0 -0.0153166055087457 0.999882693917486 0 -0.999882693917486 -0.0153166055087457 1.94395801708272
+2 0 -8.79229548276164 -0.851183244659837 1 0 0 0 -0.188711719534311 -0.982032528438037 0 0.982032528438037 -0.188711719534311 1.94395801708277
+1 0 -9.3121572642981 -2.18915677589976 0 0.258819045102517 -0.965925826289069
+8 1.65806278685597 7.94124809403556
+2 0 0 34 0 0 1 0 -1 0 1 0 -0 9.5
+1 -6.15018367767334 3 34 -1 0 0
+1 6.15018367767334 3 34 1 0 0
+1 -9 1.5 34 0 1 0
+1 9 1.5 34 0 1 0
+1 -4.5 -3 34 1 0 0
+1 4.5 -3 34 -1 0 0
+1 -7.63656151700618 -4.46010324328665 34 -0.675283841708162 0.737557952386025 0
+1 -4.0732598573327 -2.04729703897629 34 -0.926999210875127 -0.375063278710263 0
+1 -8.89749336242676 1.5259712934494 34 0 1 0
+1 -3.88720297813416 -3.54477834701538 34 -1 0 0
+1 -7.36207979327511 4.80322269159811 34 0.659244393355508 0.75192873986125 0
+1 -7.27440595626831 -1.77238917350769 34 0 -1 0
+1 -4.53820972575637 0.957958455179706 34 0.781120370403359 -0.624380466495325 0
+1 -3.63720297813416 -2.80323314666748 34 -1 0 0
+1 -3.63720297813416 3.54477834701538 34 1 0 0
+1 -6.96637487411499 -1.40161657333374 34 0 -1 0
+1 -7.27440595626831 1.40161657333374 34 0 -1 0
+1 -3.4831874370575 2.80323314666748 34 1 0 0
+1 7.63656151700618 -4.46010324328665 34 0.675283841708162 0.737557952386025 0
+1 4.0732598573327 -2.04729703897629 34 0.926999210875127 -0.375063278710263 0
+1 8.89749336242676 1.5259712934494 34 0 1 0
+1 3.88720297813416 -3.54477834701538 34 1 0 0
+1 7.36207979327511 4.80322269159811 34 -0.659244393355508 0.75192873986125 0
+1 7.27440595626831 -1.77238917350769 34 0 -1 0
+1 4.53820972575637 0.957958455179706 34 -0.781120370403359 -0.624380466495325 0
+1 3.63720297813416 -2.80323314666748 34 1 0 0
+1 3.63720297813416 3.54477834701538 34 -1 0 0
+1 6.96637487411499 -1.40161657333374 34 0 -1 0
+1 7.27440595626831 1.40161657333374 34 0 -1 0
+1 3.4831874370575 2.80323314666748 34 -1 0 0
+1 -2 3.375 34 0 1 0
+1 -1 4.75 34 -1 0 0
+1 1 6.75 34 1 0 0
+1 2 2.375 34 0 -1 0
+1 -2 -3.375 34 0 -1 0
+1 -1 -4.75 34 -1 0 0
+1 1 -6.75 34 1 0 0
+1 2 -2.375 34 0 1 0
+1 0.583333333333333 0 2.375 -1 0 0
+2 0.583333333333333 0 0 -1 0 0 0 0 1 0 1 -0 2.375
+1 9.55759993925662 -0.32381343297006 0.75 -1.11022302462516e-16 0 1
+1 0 0.795603032049121 9.53287449408005 1 0 0
+1 0 -0.737634278542183 -2.75288860492384 1 0 0
+1 0 0.862359821958175 8.20480563678825 1 0 0
+1 0 -1.425 -2.46817240078565 1 0 0
+1 0 1.71527144924655 8.06971770605389 1 0 0
+1 0 -2.25962666587139 -3.5033640194359 1 0 0
+1 0 2.18915677589979 9.3121572642981 1 0 0
+1 0 -2.79915536931599 -3.08936908449356 1 0 0
+1 0 2.76021325135306 9.15914314286783 1 0 0
+1 0 -2.01525432638166 -2.01525432638166 1 0 0
+1 0 2.54939020359334 7.84621625943501 1 0 0
+1 0 -2.46817240078565 -1.425 1 0 0
+1 0 3.35557730537538 7.53675002555145 1 0 0
+1 0 -3.7085761054313 -1.90418890660016 1 0 0
+1 0 4.07742480995763 8.65351299898659 1 0 0
+1 0 -3.96882420121404 -1.2758944241797 1 0 0
+1 0 4.60418890660018 8.38511328586726 1 0 0
+1 0 -2.75288860492384 -0.737634278542183 1 0 0
+1 0 4.12500000000002 7.14470958122161 1 0 0
+1 0 -2.85 -6.32827124036339e-16 1 0 0
+1 0 4.84922833141292 6.6743902035933 1 0 0
+1 0 -4.16381557247155 0.205212085995401 1 0 0
+1 0 5.7874898141653 7.61666869145696 1 0 0
+1 0 -4.07504979349569 0.87945511672048 1 0 0
+1 0 6.24693941327929 7.24461374203661 1 0 0
+1 0 -2.75288860492384 0.737634278542184 1 0 0
+1 0 5.52032750246059 6.13094481018849 1 0 0
+1 0 -2.46817240078565 1.425 1 0 0
+1 0 6.13094481018851 5.52032750246057 1 0 0
+1 0 -3.5033640194359 2.25962666587139 1 0 0
+1 0 7.24461374203663 6.24693941327926 1 0 0
+1 0 -3.08936908449356 2.79915536931599 1 0 0
+1 0 7.61666869145698 5.78748981416527 1 0 0
+1 0 -2.01525432638166 2.01525432638166 1 0 0
+1 0 6.67439020359333 4.84922833141289 1 0 0
+1 0 -1.425 2.46817240078565 1 0 0
+1 0 7.14470958122163 4.12499999999999 1 0 0
+1 0 -1.90418890660016 3.7085761054313 1 0 0
+1 0 8.38511328586728 4.60418890660014 1 0 0
+1 0 -1.2758944241797 3.96882420121404 1 0 0
+1 0 8.6535129989866 4.07742480995759 1 0 0
+1 0 -0.737634278542184 2.75288860492384 1 0 0
+1 0 7.53675002555146 3.35557730537535 1 0 0
+1 0 0 2.85 1 0 0
+1 0 7.84621625943502 2.54939020359331 1 0 0
+1 0 0.205212085995409 4.16381557247154 1 0 0
+1 0 9.15914314286784 2.76021325135302 1 0 0
+1 0 0.879455116720486 4.07504979349569 1 0 0
+1 0 9.31215726429811 2.18915677589975 1 0 0
+1 0 0.737634278542188 2.75288860492384 1 0 0
+1 0 8.0697177060539 1.71527144924651 1 0 0
+1 0 1.425 2.46817240078565 1 0 0
+1 0 8.20480563678826 0.862359821958139 1 0 0
+1 0 2.25962666587139 3.5033640194359 1 0 0
+1 0 9.53287449408006 0.795603032049078 1 0 0
+1 0 2.79915536931599 3.08936908449356 1 0 0
+1 0 9.56381557247154 0.205212085995401 1 0 0
+1 0 2.01525432638166 2.01525432638166 1 0 0
+1 0 8.25 0 1 0 0
+1 0 2.46817240078565 1.425 1 0 0
+1 0 8.20480563678826 -0.862359821958139 1 0 0
+1 0 3.7085761054313 1.90418890660016 1 0 0
+1 0 9.48997348609396 -1.20377885748232 1 0 0
+1 0 3.96882420121404 1.2758944241797 1 0 0
+1 0 9.39748924784919 -1.78770135678379 1 0 0
+1 0 2.75288860492384 0.737634278542183 1 0 0
+1 0 8.0697177060539 -1.71527144924651 1 0 0
+1 0 2.85 0 1 0 0
+1 0 7.84621625943502 -2.54939020359331 1 0 0
+1 0 4.16381557247154 -0.205212085995401 1 0 0
+1 0 9.03231509882042 -3.15054983456991 1 0 0
+1 0 4.07504979349569 -0.879455116720479 1 0 0
+1 0 8.8204475489393 -3.70248367192868 1 0 0
+1 0 2.75288860492384 -0.737634278542183 1 0 0
+1 0 7.53675002555146 -3.35557730537535 1 0 0
+1 0 2.46817240078565 -1.425 1 0 0
+1 0 7.14470958122163 -4.12499999999999 1 0 0
+1 0 3.5033640194359 -2.25962666587138 1 0 0
+1 0 8.17990119987188 -4.95962666587137 1 0 0
+1 0 3.08936908449356 -2.79915536931599 1 0 0
+1 0 7.85790996693753 -5.45544968412244 1 0 0
+1 0 2.01525432638166 -2.01525432638166 1 0 0
+1 0 6.67439020359333 -4.84922833141289 1 0 0
+1 0 1.425 -2.46817240078565 1 0 0
+1 0 6.13094481018851 -5.52032750246057 1 0 0
+1 0 1.90418890660016 -3.7085761054313 1 0 0
+1 0 6.9699863669681 -6.55194401294507 1 0 0
+1 0 1.2758944241797 -3.96882420121404 1 0 0
+1 0 6.55194401294509 -6.96998636696807 1 0 0
+1 0 0.737634278542186 -2.75288860492384 1 0 0
+1 0 5.52032750246059 -6.13094481018849 1 0 0
+1 0 1.26565424807268e-15 -2.85 1 0 0
+1 0 4.84922833141291 -6.67439020359331 1 0 0
+1 0 -0.205212085995399 -4.16381557247154 1 0 0
+1 0 5.45544968412247 -7.85790996693751 1 0 0
+1 8.84212561159607 0.0243489537268056 -2.75 -1.11022302462516e-16 -2.22044604925031e-16 -1
+1 0 4.9596266658714 -8.17990119987186 1 0 0
+1 0 0 8.25 1 0 0
+1 0 4.12500000000001 -7.14470958122161 1 0 0
+1 0 -0.862359821958141 8.20480563678825 1 0 0
+1 0 3.35557730537536 -7.53675002555145 1 0 0
+1 0 -1.20377885748233 9.48997348609396 1 0 0
+1 0 3.70248367192869 -8.8204475489393 1 0 0
+1 0 -1.78770135678379 9.39748924784919 1 0 0
+1 0 3.15054983456993 -9.03231509882041 1 0 0
+1 0 -1.71527144924651 8.0697177060539 1 0 0
+1 0 2.54939020359333 -7.84621625943501 1 0 0
+1 0 -2.54939020359332 7.84621625943502 1 0 0
+1 0 1.71527144924652 -8.06971770605389 1 0 0
+1 0 -3.15054983456992 9.03231509882041 1 0 0
+1 0 1.78770135678381 -9.39748924784919 1 0 0
+1 0 -3.70248367192868 8.8204475489393 1 0 0
+1 0 1.20377885748234 -9.48997348609396 1 0 0
+1 0 -3.35557730537535 7.53675002555146 1 0 0
+1 0 0.86235982195815 -8.20480563678825 1 0 0
+1 0 -4.125 7.14470958122162 1 0 0
+1 0 7.32747196252603e-15 -8.25 1 0 0
+1 0 -4.95962666587139 8.17990119987187 1 0 0
+1 0 -0.205212085995393 -9.56381557247154 1 0 0
+1 0 -5.45544968412246 7.85790996693752 1 0 0
+1 0 -0.795603032049074 -9.53287449408006 1 0 0
+1 0 -4.8492283314129 6.67439020359332 1 0 0
+1 0 -0.862359821958135 -8.20480563678826 1 0 0
+1 0 -5.52032750246058 6.1309448101885 1 0 0
+1 0 -1.71527144924651 -8.0697177060539 1 0 0
+1 0 -6.55194401294508 6.96998636696808 1 0 0
+1 0 -2.18915677589975 -9.31215726429811 1 0 0
+1 0 -6.96998636696808 6.55194401294508 1 0 0
+1 0 -2.76021325135302 -9.15914314286784 1 0 0
+1 0 -6.1309448101885 5.52032750246058 1 0 0
+1 0 -2.54939020359331 -7.84621625943502 1 0 0
+1 0 -6.67439020359332 4.8492283314129 1 0 0
+1 0 -3.35557730537535 -7.53675002555146 1 0 0
+1 0 -7.85790996693752 5.45544968412246 1 0 0
+1 0 -4.0774248099576 -8.6535129989866 1 0 0
+1 0 -8.17990120004263 4.9596266657281 1 0 0
+1 0 -4.60418890660016 -8.38511328586728 1 0 0
+1 0 -7.144709581326 4.1249999998192 1 0 0
+1 0 -4.125 -7.14470958122162 1 0 0
+1 0 -7.53674688209901 3.35558436567625 1 0 0
+1 0 -4.8492283314129 -6.67439020359332 1 0 0
+1 0 -8.8204475489393 3.70248367192868 1 0 0
+1 0 -5.78748981416528 -7.61666869145697 1 0 0
+1 0 -9.03231509882041 3.15054983456992 1 0 0
+1 0 -6.24693941327927 -7.24461374203662 1 0 0
+1 0 -7.84621625943502 2.54939020359331 1 0 0
+1 0 -5.52032750246058 -6.1309448101885 1 0 0
+1 0 -8.0697177060539 1.71527144924652 1 0 0
+1 0 -6.1309448101885 -5.52032750246058 1 0 0
+1 0 -9.39748924784919 1.78770135678379 1 0 0
+1 0 -7.24461374203662 -6.24693941327927 1 0 0
+1 0 -9.48997348609396 1.20377885748233 1 0 0
+1 0 -7.61666869145698 -5.78748981416528 1 0 0
+1 0 -8.20480563678825 0.862359821958142 1 0 0
+1 0 -6.67439020359332 -4.8492283314129 1 0 0
+1 0 -8.25 -1.83186799063151e-15 1 0 0
+1 0 -7.14470958122162 -4.125 1 0 0
+1 0 -9.56381557247154 -0.205212085995403 1 0 0
+1 0 -8.38511328586728 -4.60418890660016 1 0 0
+1 0 -9.53287449408006 -0.795603032049078 1 0 0
+1 0 -8.65351299898661 -4.07742480995759 1 0 0
+1 0 -8.20480563678826 -0.862359821958139 1 0 0
+1 0 -7.53675002555146 -3.35557730537534 1 0 0
+1 0 -8.0697177060539 -1.71527144924651 1 0 0
+1 0 -7.84621625943502 -2.54939020359331 1 0 0
+1 0 -9.3121572642981 -2.18915677589976 1 0 0
+1 0 -9.15914314286784 -2.76021325135302 1 0 0
+1 -9.01387818865997 3 2.99000000022352 0 0 1
+1 9.01387818865997 3 2.99000000022352 0 0 1
+2 0 0 33.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+1 -9 3 -3.5 0 0 1
+1 -6.15018367767334 3 0 -1 0 0
+1 -6.15018367767334 3 0.990000000223517 -1 0 0
+1 -6.15018367767334 3 33.9900000002235 -1 0 0
+1 -11.1018016555873 3 0 0 0 -1
+1 -6.15018367767334 3 1.99000000022352 -1 0 0
+1 -6.15018367767334 3 32.9900000002235 -1 0 0
+1 -6.15018367767334 3 2.99000000022352 -1 0 0
+1 -6.15018367767334 3 31.9900000002235 -1 0 0
+1 -6.15018367767334 3 3.99000000022352 -1 0 0
+1 -6.15018367767334 3 30.9900000002235 -1 0 0
+1 -6.15018367767334 3 5.99000000022352 -1 0 0
+1 -6.15018367767334 3 28.9900000002235 -1 0 0
+1 -6.15018367767334 3 6.99000000022352 -1 0 0
+1 -6.15018367767334 3 27.9900000002235 -1 0 0
+1 -6.15018367767334 3 7.99000000022352 -1 0 0
+1 -6.15018367767334 3 26.9900000002235 -1 0 0
+1 -6.15018367767334 3 8.99000000022352 -1 0 0
+1 -6.15018367767334 3 25.9900000002235 -1 0 0
+1 -6.15018367767334 3 10.9900000002235 -1 0 0
+1 -6.15018367767334 3 23.9900000002235 -1 0 0
+1 -6.15018367767334 3 11.9900000002235 -1 0 0
+1 -6.15018367767334 3 22.9900000002235 -1 0 0
+1 -6.15018367767334 3 12.9900000002235 -1 0 0
+1 -6.15018367767334 3 21.9900000002235 -1 0 0
+1 -6.15018367767334 3 13.9900000002235 -1 0 0
+1 -6.15018367767334 3 20.9900000002235 -1 0 0
+1 -6.15018367767334 3 15.9900000002235 -1 0 0
+1 -6.15018367767334 3 18.9900000002235 -1 0 0
+1 -6.15018367767334 3 16.9900000002235 -1 0 0
+1 -6.15018367767334 3 17.9900000002235 -1 0 0
+1 9 3 -3.5 0 0 1
+1 6.15018367767334 3 0 1 0 0
+1 6.15018367767334 3 0.990000000223517 1 0 0
+1 6.15018367767334 3 33.9900000002235 1 0 0
+1 11.1018016555873 3 0 0 0 -1
+1 6.15018367767334 3 1.99000000022352 1 0 0
+1 6.15018367767334 3 32.9900000002235 1 0 0
+1 6.15018367767334 3 2.99000000022352 1 0 0
+1 6.15018367767334 3 31.9900000002235 1 0 0
+1 6.15018367767334 3 3.99000000022352 1 0 0
+1 6.15018367767334 3 30.9900000002235 1 0 0
+1 6.15018367767334 3 5.99000000022352 1 0 0
+1 6.15018367767334 3 28.9900000002235 1 0 0
+1 6.15018367767334 3 6.99000000022352 1 0 0
+1 6.15018367767334 3 27.9900000002235 1 0 0
+1 6.15018367767334 3 7.99000000022352 1 0 0
+1 6.15018367767334 3 26.9900000002235 1 0 0
+1 6.15018367767334 3 8.99000000022352 1 0 0
+1 6.15018367767334 3 25.9900000002235 1 0 0
+1 6.15018367767334 3 10.9900000002235 1 0 0
+1 6.15018367767334 3 23.9900000002235 1 0 0
+1 6.15018367767334 3 11.9900000002235 1 0 0
+1 6.15018367767334 3 22.9900000002235 1 0 0
+1 6.15018367767334 3 12.9900000002235 1 0 0
+1 6.15018367767334 3 21.9900000002235 1 0 0
+1 6.15018367767334 3 13.9900000002235 1 0 0
+1 6.15018367767334 3 20.9900000002235 1 0 0
+1 6.15018367767334 3 15.9900000002235 1 0 0
+1 6.15018367767334 3 18.9900000002235 1 0 0
+1 6.15018367767334 3 16.9900000002235 1 0 0
+1 6.15018367767334 3 17.9900000002235 1 0 0
+1 -9 1.5 0 0 1 0
+1 -9 -3 -3.5 0 0 1
+1 -9 6.96596165426659 16.3889145019957 0 -0.500000000000001 0.866025403784438
+1 -9 -7.71735002913288 17.3554208529418 0 0.500000000000001 0.866025403784438
+8 5.23598775598299 8.37758040957278
+2 -9 -0.5 31.3203394145464 1 0 0 0 0 1 0 -1 0 1
+8 1.0471975511966 2.0943951023932
+2 -9 -0.5 27.8562377994086 1 0 0 0 0 1 0 -1 0 1
+1 -9 8.84235002913288 17.1389145019957 0 -0.500000000000001 0.866025403784438
+1 -9 5.860299221564 14.839876396319 0 0.500000000000001 -0.866025403784438
+8 4.18879020478639 5.23598775598299
+2 -9 0.5 29.5882886069775 1 0 0 0 0 1 0 -1 0 1
+1 -9 -6.96735002913288 15.1903573434807 0 0.500000000000001 0.866025403784438
+1 -9 -5.84096165426659 16.6054208529418 0 0.500000000000001 0.866025403784438
+2 -9 -0.5 24.3921361842709 1 0 0 0 0 1 0 -1 0 1
+1 -9 7.73668759643029 15.589876396319 0 0.500000000000001 -0.866025403784438
+1 -9 5.4659616542666 12.0587874830735 0 -0.500000000000001 0.866025403784438
+2 -9 0.5 26.1241869918398 1 0 0 0 0 1 0 -1 0 1
+1 -9 -6.21735002913288 13.0252938340196 0 0.5 0.866025403784439
+1 -9 -5.09096165426659 14.4403573434807 0 0.500000000000001 0.866025403784438
+2 -9 -0.5 20.9280345691331 1 0 0 0 0 1 0 -1 0 1
+1 -9 7.34235002913288 12.8087874830735 0 -0.500000000000001 0.866025403784438
+1 -9 4.71596165426659 9.89372397361238 0 -0.5 0.866025403784439
+2 -9 0.5 22.660085376702 1 0 0 0 0 1 0 -1 0 1
+1 -9 -5.46735002913288 10.8602303245585 0 0.5 0.866025403784439
+1 -9 -4.34096165426659 12.2752938340196 0 0.5 0.866025403784439
+2 -9 -0.5 17.4639329539954 1 0 0 0 0 1 0 -1 0 1
+1 -9 6.59235002913287 10.6437239736124 0 -0.5 0.866025403784439
+1 -9 3.96596165426659 7.72866046415128 0 -0.5 0.866025403784439
+2 -9 0.5 19.1959837615642 1 0 0 0 0 1 0 -1 0 1
+1 -9 -4.71735002913287 8.69516681509739 0 0.5 0.866025403784439
+1 -9 -3.59096165426659 10.1102303245585 0 0.5 0.866025403784439
+2 -9 -0.5 13.9998313388576 1 0 0 0 0 1 0 -1 0 1
+1 -9 5.84235002913287 8.47866046415128 0 -0.5 0.866025403784439
+1 -9 3.21596165426659 5.56359695469019 0 -0.5 0.866025403784439
+2 -9 0.5 15.7318821464265 1 0 0 0 0 1 0 -1 0 1
+1 -9 -3.96735002913287 6.5301033056363 0 0.5 0.866025403784439
+1 -9 -2.84096165426659 7.94516681509739 0 0.5 0.866025403784439
+2 -9 -0.5 10.5357297237199 1 0 0 0 0 1 0 -1 0 1
+1 -9 5.09235002913287 6.31359695469019 0 -0.5 0.866025403784439
+1 -9 2.46596165426659 3.39853344522909 0 -0.5 0.866025403784439
+2 -9 0.5 12.2677805312887 1 0 0 0 0 1 0 -1 0 1
+1 -9 -3.21735002913287 4.3650397961752 0 0.5 0.866025403784439
+1 -9 -2.09096165426659 5.7801033056363 0 0.5 0.866025403784439
+8 1.0471975511966 2.09439510239319
+2 -9 -0.5 7.07162810858211 1 0 0 0 0 1 0 -1 0 1
+1 -9 4.34235002913287 4.14853344522909 0 -0.5 0.866025403784439
+1 -9 1.71596165426659 1.23346993576799 0 -0.5 0.866025403784439
+2 -9 0.5 8.80367891615099 1 0 0 0 0 1 0 -1 0 1
+1 -9 -2.46735002913287 2.19997628671411 0 0.5 0.866025403784439
+1 -9 -1.34096165426659 3.6150397961752 0 0.5 0.866025403784439
+2 -9 -0.5 3.60752649344435 1 0 0 0 0 1 0 -1 0 1
+1 -9 3.59235002913287 1.98346993576799 0 -0.5 0.866025403784439
+1 -9 1.110299221564 -1.1815935736931 0 -0.5 0.866025403784439
+2 -9 0.5 5.33957730101323 1 0 0 0 0 1 0 -1 0 1
+8 2.0943951023932 5.23598775598299
+2 -9 0.5 1.87547568587548 1 0 0 0 0 1 0 -1 0 1
+1 -9 -0.59096165426659 1.44997628671411 0 0.5 0.866025403784439
+1 -9 2.84235002913287 -0.181593573693101 0 -0.5 0.866025403784439
+1 9 1.5 0 0 1 0
+1 9 -3 -3.5 0 0 1
+1 9 6.96596165426659 16.3889145019957 0 0.500000000000001 -0.866025403784438
+8 1.0471975511966 4.18879020478639
+2 9 -0.5 31.3203394145464 -1 0 0 0 0 -1 -0 -1 -0 1
+1 9 -7.71735002913288 17.3554208529418 0 -0.500000000000001 -0.866025403784438
+1 9 8.84235002913288 17.1389145019957 0 0.500000000000001 -0.866025403784438
+2 9 -0.5 27.8562377994086 -1 0 0 0 0 -1 -0 -1 -0 1
+2 9 0.5 29.5882886069775 -1 0 0 0 0 -1 -0 -1 -0 1
+1 9 5.860299221564 14.839876396319 0 -0.500000000000001 0.866025403784438
+1 9 -5.84096165426659 16.6054208529418 0 -0.500000000000001 -0.866025403784438
+1 9 -6.96735002913288 15.1903573434807 0 -0.500000000000001 -0.866025403784438
+1 9 7.73668759643029 15.589876396319 0 -0.500000000000001 0.866025403784438
+2 9 -0.5 24.3921361842709 -1 0 0 0 0 -1 -0 -1 -0 1
+2 9 0.5 26.1241869918398 -1 0 0 0 0 -1 -0 -1 -0 1
+1 9 5.4659616542666 12.0587874830735 0 0.500000000000001 -0.866025403784438
+1 9 -5.09096165426659 14.4403573434807 0 -0.500000000000001 -0.866025403784438
+1 9 -6.21735002913288 13.0252938340196 0 -0.5 -0.866025403784439
+1 9 7.34235002913288 12.8087874830735 0 0.500000000000001 -0.866025403784438
+2 9 -0.5 20.9280345691331 -1 0 0 0 0 -1 -0 -1 -0 1
+2 9 0.5 22.660085376702 -1 0 0 0 0 -1 -0 -1 -0 1
+1 9 4.71596165426659 9.89372397361238 0 0.5 -0.866025403784439
+1 9 -4.34096165426659 12.2752938340196 0 -0.5 -0.866025403784439
+1 9 -5.46735002913288 10.8602303245585 0 -0.5 -0.866025403784439
+1 9 6.59235002913287 10.6437239736124 0 0.5 -0.866025403784439
+2 9 -0.5 17.4639329539954 -1 0 0 0 0 -1 -0 -1 -0 1
+2 9 0.5 19.1959837615642 -1 0 0 0 0 -1 -0 -1 -0 1
+1 9 3.96596165426659 7.72866046415128 0 0.5 -0.866025403784439
+1 9 -3.59096165426659 10.1102303245585 0 -0.5 -0.866025403784439
+1 9 -4.71735002913287 8.69516681509739 0 -0.5 -0.866025403784439
+1 9 5.84235002913287 8.47866046415128 0 0.5 -0.866025403784439
+2 9 -0.5 13.9998313388576 -1 0 0 0 0 -1 -0 -1 -0 1
+2 9 0.5 15.7318821464265 -1 0 0 0 0 -1 -0 -1 -0 1
+1 9 3.21596165426659 5.56359695469019 0 0.5 -0.866025403784439
+1 9 -2.84096165426659 7.94516681509739 0 -0.5 -0.866025403784439
+1 9 -3.96735002913287 6.5301033056363 0 -0.5 -0.866025403784439
+1 9 5.09235002913287 6.31359695469019 0 0.5 -0.866025403784439
+2 9 -0.5 10.5357297237199 -1 0 0 0 0 -1 -0 -1 -0 1
+2 9 0.5 12.2677805312887 -1 0 0 0 0 -1 -0 -1 -0 1
+1 9 2.46596165426659 3.39853344522909 0 0.5 -0.866025403784439
+1 9 -2.09096165426659 5.7801033056363 0 -0.5 -0.866025403784439
+1 9 -3.21735002913287 4.3650397961752 0 -0.5 -0.866025403784439
+1 9 4.34235002913287 4.14853344522909 0 0.5 -0.866025403784439
+2 9 -0.5 7.07162810858211 -1 0 0 0 0 -1 -0 -1 -0 1
+2 9 0.5 8.80367891615099 -1 0 0 0 0 -1 -0 -1 -0 1
+1 9 1.71596165426659 1.23346993576799 0 0.5 -0.866025403784439
+1 9 -1.34096165426659 3.6150397961752 0 -0.5 -0.866025403784439
+1 9 -2.46735002913287 2.19997628671411 0 -0.5 -0.866025403784439
+1 9 3.59235002913287 1.98346993576799 0 0.5 -0.866025403784439
+2 9 -0.5 3.60752649344435 -1 0 0 0 0 -1 -0 -1 -0 1
+2 9 0.5 5.33957730101323 -1 0 0 0 0 -1 -0 -1 -0 1
+1 9 1.110299221564 -1.1815935736931 0 0.5 -0.866025403784439
+1 9 -0.59096165426659 1.44997628671411 0 -0.5 -0.866025403784439
+8 4.18879020478639 7.33038285837618
+2 9 0.5 1.87547568587548 -1 0 0 0 0 -1 -0 -1 -0 1
+1 9 2.84235002913287 -0.181593573693101 0 0.5 -0.866025403784439
+1 -4.5 -3 0 1 0 0
+1 -9.01387818865997 -3 2.99000000022352 0 0 1
+1 -4.5 -3 0.990000000223517 1 0 0
+1 -4.5 -3 33.9900000002235 1 0 0
+1 -11.1018016555873 -3 0 0 0 -1
+1 -4.5 -3 1.99000000022352 1 0 0
+1 -4.5 -3 32.9900000002235 1 0 0
+1 -4.5 -3 2.99000000022352 1 0 0
+1 -4.5 -3 31.9900000002235 1 0 0
+1 -4.5 -3 3.99000000022352 1 0 0
+1 -4.5 -3 30.9900000002235 1 0 0
+1 -4.5 -3 5.99000000022352 1 0 0
+1 -4.5 -3 28.9900000002235 1 0 0
+1 -4.5 -3 6.99000000022352 1 0 0
+1 -4.5 -3 27.9900000002235 1 0 0
+1 -4.5 -3 7.99000000022352 1 0 0
+1 -4.5 -3 26.9900000002235 1 0 0
+1 -4.5 -3 8.99000000022352 1 0 0
+1 -4.5 -3 25.9900000002235 1 0 0
+1 -4.5 -3 10.9900000002235 1 0 0
+1 -4.5 -3 23.9900000002235 1 0 0
+1 -4.5 -3 11.9900000002235 1 0 0
+1 -4.5 -3 22.9900000002235 1 0 0
+1 -4.5 -3 12.9900000002235 1 0 0
+1 -4.5 -3 21.9900000002235 1 0 0
+1 -4.5 -3 13.9900000002235 1 0 0
+1 -4.5 -3 20.9900000002235 1 0 0
+1 -4.5 -3 15.9900000002235 1 0 0
+1 -4.5 -3 18.9900000002235 1 0 0
+1 -4.5 -3 16.9900000002235 1 0 0
+1 -4.5 -3 17.9900000002235 1 0 0
+1 4.5 -3 0 -1 0 0
+1 9.01387818865997 -3 2.99000000022352 0 0 1
+1 4.5 -3 0.990000000223517 -1 0 0
+1 4.5 -3 33.9900000002235 -1 0 0
+1 11.1018016555873 -3 0 0 0 -1
+1 4.5 -3 1.99000000022352 -1 0 0
+1 4.5 -3 32.9900000002235 -1 0 0
+1 4.5 -3 2.99000000022352 -1 0 0
+1 4.5 -3 31.9900000002235 -1 0 0
+1 4.5 -3 3.99000000022352 -1 0 0
+1 4.5 -3 30.9900000002235 -1 0 0
+1 4.5 -3 5.99000000022352 -1 0 0
+1 4.5 -3 28.9900000002235 -1 0 0
+1 4.5 -3 6.99000000022352 -1 0 0
+1 4.5 -3 27.9900000002235 -1 0 0
+1 4.5 -3 7.99000000022352 -1 0 0
+1 4.5 -3 26.9900000002235 -1 0 0
+1 4.5 -3 8.99000000022352 -1 0 0
+1 4.5 -3 25.9900000002235 -1 0 0
+1 4.5 -3 10.9900000002235 -1 0 0
+1 4.5 -3 23.9900000002235 -1 0 0
+1 4.5 -3 11.9900000002235 -1 0 0
+1 4.5 -3 22.9900000002235 -1 0 0
+1 4.5 -3 12.9900000002235 -1 0 0
+1 4.5 -3 21.9900000002235 -1 0 0
+1 4.5 -3 13.9900000002235 -1 0 0
+1 4.5 -3 20.9900000002235 -1 0 0
+1 4.5 -3 15.9900000002235 -1 0 0
+1 4.5 -3 18.9900000002235 -1 0 0
+1 4.5 -3 16.9900000002235 -1 0 0
+1 4.5 -3 17.9900000002235 -1 0 0
+1 -8.89749336242676 -3.08288931846619 33 0 0 1
+1 -8.89749336242676 -3.08288931846619 34 0.675283841708162 -0.737557952386025 0
+1 -8.28533533832021 -3.75150004318693 33 0 0 1
+1 -8.27493894917191 -3.74729367088913 34 0.926999210875127 0.375063278710263 0
+1 -7.77440595626831 -3.54477834701538 33 0 0 1
+1 -8.89749336242676 3.0519425868988 33 0 0 1
+1 -8.89749336242676 3.0519425868988 34 0 -1 0
+1 -7.81938457489014 -3.54477834701538 34 1 0 0
+1 -7.27440595626831 -3.54477834701538 33 0 0 1
+1 -8.1806824381779 3.86953123903098 33 0 0 1
+1 -8.41229774563379 3.60535272189346 34 -0.659244393355508 -0.75192873986125 0
+1 -7.27440595626831 -3.54477834701538 34 0 1 0
+1 -7.27440595626831 -2.80323314666748 33 0 0 1
+1 -7.77440595626831 3.54477834701538 33 0 0 1
+1 -7.60105427046639 3.40621147493027 34 -0.781120370403359 0.624380466495325 0
+1 -7.34549045562744 -2.80323314666748 34 1 0 0
+1 -6.96637487411499 -2.80323314666748 33 0 0 1
+1 -7.27440595626831 3.54477834701538 33 0 0 1
+1 -7.27440595626831 3.54477834701538 34 -1 0 0
+1 -6.96637487411499 -3.21316576004028 34 0 1 0
+1 -6.96637487411499 2.80323314666748 33 0 0 1
+1 -7.27440595626831 2.80323314666748 33 0 0 1
+1 -7.27440595626831 2.80323314666748 34 0 1 0
+1 -6.96637487411499 2.80323314666748 34 -1 0 0
+1 8.89749336242676 -3.08288931846619 33 0 0 1
+1 8.89749336242676 -3.08288931846619 34 -0.675283841708162 -0.737557952386025 0
+1 8.28533533832021 -3.75150004318693 33 0 0 1
+1 8.27493894917191 -3.74729367088913 34 -0.926999210875127 0.375063278710263 0
+1 7.77440595626831 -3.54477834701538 33 0 0 1
+1 8.89749336242676 3.0519425868988 33 0 0 1
+1 8.89749336242676 3.0519425868988 34 0 -1 0
+1 7.81938457489014 -3.54477834701538 34 -1 0 0
+1 7.27440595626831 -3.54477834701538 33 0 0 1
+1 8.1806824381779 3.86953123903098 33 0 0 1
+1 8.41229774563379 3.60535272189346 34 0.659244393355508 -0.75192873986125 0
+1 7.27440595626831 -3.54477834701538 34 0 1 0
+1 7.27440595626831 -2.80323314666748 33 0 0 1
+1 7.77440595626831 3.54477834701538 33 0 0 1
+1 7.60105427046639 3.40621147493027 34 0.781120370403359 0.624380466495325 0
+1 7.34549045562744 -2.80323314666748 34 -1 0 0
+1 6.96637487411499 -2.80323314666748 33 0 0 1
+1 7.27440595626831 3.54477834701538 33 0 0 1
+1 7.27440595626831 3.54477834701538 34 1 0 0
+1 6.96637487411499 -3.21316576004028 34 0 1 0
+1 6.96637487411499 2.80323314666748 33 0 0 1
+1 7.27440595626831 2.80323314666748 33 0 0 1
+1 7.27440595626831 2.80323314666748 34 0 1 0
+1 6.96637487411499 2.80323314666748 34 1 0 0
+1 -2 6.75 33 0 0 1
+1 -2 3.375 36 0 -1 0
+1 -2 4.75 33 0 0 1
+1 -1 4.75 36 1 0 0
+1 2 4.75 33 0 0 1
+1 2 6.75 33 0 0 1
+1 1 6.75 36 -1 0 0
+1 2 2.375 36 0 1 0
+1 -2 -6.75 33 0 0 1
+1 -2 -3.375 36 0 -1 0
+1 -2 -4.75 33 0 0 1
+1 -1 -4.75 36 -1 0 0
+1 2 -4.75 33 0 0 1
+1 2 -6.75 33 0 0 1
+1 1 -6.75 36 1 0 0
+1 2 -2.375 36 0 1 0
+2 0 0 0 -1 0 0 0 0 -1 -0 -1 -0 6.875
+2 3.5 0 0 1 0 0 0 0 1 0 -1 0 2.375
+2 0 0 33.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 33.9900000002235 -1 0 0
+2 0 0 0 0 0 1 1 0 -0 -0 1 0 8.5
+2 0 0 0 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 0.990000000223517 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 0.990000000223517 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 0.990000000223517 -1 0 0
+1 -3.35410196624968 11 0 0 0 -1
+2 0 0 1.99000000022352 0 0 -1 0 1 0 1 -0 0 11.5
+2 0 0 32.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 1.99000000022352 -1 0 0
+2 0 0 1.99000000022352 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+1 -2.93374729156494 11 32.9900000002235 -1 0 0
+2 0 0 32.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 2.99000000022352 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 31.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 2.99000000022352 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 2.99000000022352 -1 0 0
+2 0 0 31.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 31.9900000002235 -1 0 0
+2 0 0 3.99000000022352 0 0 -1 0 1 0 1 -0 0 11.5
+2 0 0 30.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 3.99000000022352 -1 0 0
+2 0 0 3.99000000022352 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+1 -2.93374729156494 11 30.9900000002235 -1 0 0
+2 0 0 30.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 5.99000000022352 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+1 5 8.07774721070176 2.99000000022352 0 0 1
+8 2.58733081913747 3.69585448804212
+2 0 0 4.10471725463867 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 5.91961097717285 0 0 1 0 -1 0 1 0 -0 9.5
+1 -5 8.07774721070176 2.99000000022352 0 0 1
+2 0 0 28.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 29.1047172546387 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 30.9196109771729 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 5.99000000022352 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 5.99000000022352 -1 0 0
+2 0 0 28.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 28.9900000002235 -1 0 0
+2 0 0 6.99000000022352 0 0 -1 0 1 0 1 -0 0 11.5
+2 0 0 27.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 6.99000000022352 -1 0 0
+2 0 0 6.99000000022352 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+1 -2.93374729156494 11 27.9900000002235 -1 0 0
+2 0 0 27.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 7.99000000022352 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 26.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 7.99000000022352 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 7.99000000022352 -1 0 0
+2 0 0 26.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 26.9900000002235 -1 0 0
+2 0 0 8.99000000022352 0 0 -1 0 1 0 1 -0 0 11.5
+2 0 0 25.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 8.99000000022352 -1 0 0
+2 0 0 8.99000000022352 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+1 -2.93374729156494 11 25.9900000002235 -1 0 0
+2 0 0 25.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 10.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 9.10471725463867 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 10.9196109771729 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 23.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 24.1047172546387 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 25.9196109771729 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 10.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 10.9900000002235 -1 0 0
+2 0 0 23.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 23.9900000002235 -1 0 0
+2 0 0 11.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+2 0 0 22.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 11.9900000002235 -1 0 0
+2 0 0 11.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+1 -2.93374729156494 11 22.9900000002235 -1 0 0
+2 0 0 22.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 12.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 21.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 12.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 12.9900000002235 -1 0 0
+2 0 0 21.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 21.9900000002235 -1 0 0
+2 0 0 13.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+2 0 0 20.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 13.9900000002235 -1 0 0
+2 0 0 13.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+1 -2.93374729156494 11 20.9900000002235 -1 0 0
+2 0 0 20.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 15.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 14.1047172546387 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 15.9196109771729 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 18.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+2 0 0 19.1047172546387 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 20.9196109771729 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 15.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 15.9900000002235 -1 0 0
+2 0 0 18.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 18.9900000002235 -1 0 0
+2 0 0 16.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+2 0 0 17.9900000002235 0 0 -1 0 1 0 1 -0 0 11.5
+1 -2.93374729156494 11 16.9900000002235 -1 0 0
+2 0 0 16.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+1 -2.93374729156494 11 17.9900000002235 -1 0 0
+2 0 0 17.9900000002235 0 0 -1 0.996194698313003 0.0871557402186753 0 0.0871557402186753 -0.996194698313003 0 9.5
+1 3.35410196624968 11 0 0 0 -1
+1 -8.5 -0.654700538379252 29.5882886069775 -1 0 0
+1 -10 -0.366025403784438 29.0882886069775 0 -0.500000000000001 0.866025403784438
+1 -8.5 -1.36602540378444 30.8203394145464 -1 0 0
+1 -8.5 -1.36602540378444 28.3562377994086 -1 0 0
+1 -10 -1.36602540378444 28.3562377994086 0 0.500000000000001 0.866025403784438
+1 -8.5 0.366025403784438 31.8203394145464 -1 0 0
+2 -10 -0.5 31.3203394145464 1 0 0 0 -1 0 0 0 -1 1
+2 -10 -0.5 27.8562377994086 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 27.3562377994086 -1 0 0
+1 -8.5 1.36602540378444 30.0882886069775 -1 0 0
+1 -10 1.36602540378444 30.0882886069775 0 -0.500000000000001 0.866025403784438
+1 -10 -1.36602540378444 27.3562377994086 0 0.500000000000001 -0.866025403784438
+1 -8.5 -0.654700538379252 26.1241869918398 -1 0 0
+1 -8.5 1.36602540378444 29.0882886069775 -1 0 0
+2 -10 0.5 29.5882886069775 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 24.8921361842709 -1 0 0
+1 -10 -1.36602540378444 24.8921361842709 0 0.500000000000001 0.866025403784438
+1 -8.5 0.654700538379251 27.8562377994086 -1 0 0
+1 -10 0.366025403784438 27.3562377994086 0 0.500000000000001 0.866025403784438
+2 -10 -0.5 24.3921361842709 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 23.8921361842709 -1 0 0
+1 -10 0.366025403784438 28.3562377994086 0 0.500000000000001 -0.866025403784438
+1 -8.5 1.36602540378444 26.6241869918398 -1 0 0
+1 -8.5 -0.654700538379251 22.660085376702 -1 0 0
+1 -10 -0.366025403784438 22.160085376702 0 -0.500000000000001 0.866025403784438
+1 -8.5 1.36602540378444 25.6241869918398 -1 0 0
+2 -10 0.5 26.1241869918398 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 21.4280345691331 -1 0 0
+1 -10 -1.36602540378444 21.4280345691331 0 0.5 0.866025403784439
+1 -8.5 0.654700538379252 24.3921361842709 -1 0 0
+1 -10 0.366025403784438 23.8921361842709 0 0.500000000000001 0.866025403784438
+2 -10 -0.5 20.9280345691331 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 20.4280345691331 -1 0 0
+1 -8.5 1.36602540378444 23.160085376702 -1 0 0
+1 -10 1.36602540378444 23.160085376702 0 -0.500000000000001 0.866025403784438
+1 -8.5 -0.654700538379251 19.1959837615642 -1 0 0
+1 -10 -0.366025403784439 18.6959837615642 0 -0.5 0.866025403784439
+1 -8.5 1.36602540378444 22.160085376702 -1 0 0
+2 -10 0.5 22.660085376702 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 17.9639329539954 -1 0 0
+1 -10 -1.36602540378444 17.9639329539954 0 0.5 0.866025403784439
+1 -8.5 0.654700538379252 20.9280345691331 -1 0 0
+1 -10 0.366025403784439 20.4280345691331 0 0.5 0.866025403784439
+2 -10 -0.5 17.4639329539954 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 16.9639329539954 -1 0 0
+1 -8.5 1.36602540378444 19.6959837615642 -1 0 0
+1 -10 1.36602540378444 19.6959837615642 0 -0.5 0.866025403784439
+1 -8.5 -0.654700538379251 15.7318821464265 -1 0 0
+1 -10 -0.366025403784439 15.2318821464265 0 -0.5 0.866025403784439
+1 -8.5 1.36602540378444 18.6959837615642 -1 0 0
+2 -10 0.5 19.1959837615642 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 14.4998313388576 -1 0 0
+1 -10 -1.36602540378444 14.4998313388576 0 0.5 0.866025403784439
+1 -8.5 0.654700538379252 17.4639329539954 -1 0 0
+1 -10 0.366025403784439 16.9639329539954 0 0.5 0.866025403784439
+2 -10 -0.5 13.9998313388576 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 13.4998313388576 -1 0 0
+1 -8.5 1.36602540378444 16.2318821464265 -1 0 0
+1 -10 1.36602540378444 16.2318821464265 0 -0.5 0.866025403784439
+1 -8.5 -0.654700538379252 12.2677805312887 -1 0 0
+1 -10 -0.366025403784439 11.7677805312887 0 -0.5 0.866025403784439
+1 -8.5 1.36602540378444 15.2318821464265 -1 0 0
+2 -10 0.5 15.7318821464265 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 11.0357297237199 -1 0 0
+1 -10 -1.36602540378444 11.0357297237199 0 0.5 0.866025403784439
+1 -8.5 0.654700538379252 13.9998313388576 -1 0 0
+1 -10 0.366025403784439 13.4998313388576 0 0.5 0.866025403784439
+2 -10 -0.5 10.5357297237199 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 10.0357297237199 -1 0 0
+1 -8.5 1.36602540378444 12.7677805312887 -1 0 0
+1 -10 1.36602540378444 12.7677805312887 0 -0.5 0.866025403784439
+1 -8.5 -0.654700538379252 8.80367891615099 -1 0 0
+1 -10 -0.366025403784439 8.30367891615099 0 -0.5 0.866025403784439
+1 -8.5 1.36602540378444 11.7677805312887 -1 0 0
+2 -10 0.5 12.2677805312887 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 7.57162810858211 -1 0 0
+1 -10 -1.36602540378444 7.57162810858211 0 0.5 0.866025403784439
+1 -8.5 0.654700538379252 10.5357297237199 -1 0 0
+1 -10 0.366025403784439 10.0357297237199 0 0.5 0.866025403784439
+2 -10 -0.5 7.07162810858211 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 6.57162810858211 -1 0 0
+1 -8.5 1.36602540378444 9.30367891615099 -1 0 0
+1 -10 1.36602540378444 9.30367891615099 0 -0.5 0.866025403784439
+1 -8.5 -0.654700538379252 5.33957730101323 -1 0 0
+1 -10 -0.366025403784439 4.83957730101323 0 -0.5 0.866025403784439
+1 -8.5 1.36602540378444 8.30367891615099 -1 0 0
+2 -10 0.5 8.80367891615099 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 4.10752649344435 -1 0 0
+1 -10 -1.36602540378444 4.10752649344435 0 0.5 0.866025403784439
+1 -8.5 0.654700538379252 7.07162810858211 -1 0 0
+1 -10 0.366025403784439 6.57162810858211 0 0.5 0.866025403784439
+2 -10 -0.5 3.60752649344435 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 3.10752649344435 -1 0 0
+1 -8.5 1.36602540378444 5.83957730101323 -1 0 0
+1 -10 1.36602540378444 5.83957730101323 0 -0.5 0.866025403784439
+1 -8.5 -0.366025403784439 1.37547568587548 -1 0 0
+1 -10 -0.366025403784439 1.37547568587548 0 -0.5 0.866025403784439
+1 -8.5 1.36602540378444 4.83957730101323 -1 0 0
+2 -10 0.5 5.33957730101323 1 0 0 0 -1 0 0 0 -1 1
+2 -10 0.5 1.87547568587548 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 1.36602540378444 2.37547568587548 -1 0 0
+1 -8.5 0.654700538379251 3.60752649344435 -1 0 0
+1 -10 0.366025403784439 3.10752649344435 0 0.5 0.866025403784439
+1 -10 1.36602540378444 2.37547568587548 0 -0.5 0.866025403784439
+1 8.5 -0.654700538379252 29.5882886069775 1 0 0
+1 10 -0.366025403784438 29.0882886069775 0 -0.500000000000001 0.866025403784438
+1 8.5 -1.36602540378444 30.8203394145464 1 0 0
+1 8.5 0.366025403784438 31.8203394145464 1 0 0
+2 10 -0.5 31.3203394145464 1 0 0 0 -1 0 0 0 -1 1
+1 8.5 -1.36602540378444 28.3562377994086 1 0 0
+1 10 -1.36602540378444 28.3562377994086 0 0.500000000000001 0.866025403784438
+1 8.5 1.36602540378444 30.0882886069775 1 0 0
+1 10 1.36602540378444 30.0882886069775 0 -0.500000000000001 0.866025403784438
+2 10 -0.5 27.8562377994086 1 0 0 0 -1 0 0 0 -1 1
+1 8.5 -1.36602540378444 27.3562377994086 1 0 0
+1 8.5 1.36602540378444 29.0882886069775 1 0 0
+2 10 0.5 29.5882886069775 1 0 0 0 -1 0 0 0 -1 1
+1 10 -1.36602540378444 27.3562377994086 0 0.500000000000001 -0.866025403784438
+1 8.5 -0.654700538379252 26.1241869918398 1 0 0
+1 8.5 0.654700538379251 27.8562377994086 1 0 0
+1 10 0.366025403784438 27.3562377994086 0 0.500000000000001 0.866025403784438
+1 8.5 -1.36602540378444 24.8921361842709 1 0 0
+1 10 -1.36602540378444 24.8921361842709 0 0.500000000000001 0.866025403784438
+1 10 0.366025403784438 28.3562377994086 0 0.500000000000001 -0.866025403784438
+1 8.5 1.36602540378444 26.6241869918398 1 0 0
+2 10 -0.5 24.3921361842709 1 0 0 0 -1 0 0 0 -1 1
+1 8.5 -1.36602540378444 23.8921361842709 1 0 0
+1 8.5 1.36602540378444 25.6241869918398 1 0 0
+2 10 0.5 26.1241869918398 1 0 0 0 -1 0 0 0 -1 1
+1 8.5 -0.654700538379251 22.660085376702 1 0 0
+1 10 -0.366025403784438 22.160085376702 0 -0.500000000000001 0.866025403784438
+1 8.5 0.654700538379252 24.3921361842709 1 0 0
+1 10 0.366025403784438 23.8921361842709 0 0.500000000000001 0.866025403784438
+1 8.5 -1.36602540378444 21.4280345691331 1 0 0
+1 10 -1.36602540378444 21.4280345691331 0 0.5 0.866025403784439
+1 8.5 1.36602540378444 23.160085376702 1 0 0
+1 10 1.36602540378444 23.160085376702 0 -0.500000000000001 0.866025403784438
+2 10 -0.5 20.9280345691331 1 0 0 0 -1 0 0 0 -1 1
+1 8.5 -1.36602540378444 20.4280345691331 1 0 0
+1 8.5 1.36602540378444 22.160085376702 1 0 0
+2 10 0.5 22.660085376702 1 0 0 0 -1 0 0 0 -1 1
+1 8.5 -0.654700538379251 19.1959837615642 1 0 0
+1 10 -0.366025403784439 18.6959837615642 0 -0.5 0.866025403784439
+1 8.5 0.654700538379252 20.9280345691331 1 0 0
+1 10 0.366025403784439 20.4280345691331 0 0.5 0.866025403784439
+1 8.5 -1.36602540378444 17.9639329539954 1 0 0
+1 10 -1.36602540378444 17.9639329539954 0 0.5 0.866025403784439
+1 8.5 1.36602540378444 19.6959837615642 1 0 0
+1 10 1.36602540378444 19.6959837615642 0 -0.5 0.866025403784439
+2 10 -0.5 17.4639329539954 1 0 0 0 -1 0 0 0 -1 1
+1 8.5 -1.36602540378444 16.9639329539954 1 0 0
+1 8.5 1.36602540378444 18.6959837615642 1 0 0
+2 10 0.5 19.1959837615642 1 0 0 0 -1 0 0 0 -1 1
+1 8.5 -0.654700538379251 15.7318821464265 1 0 0
+1 10 -0.366025403784439 15.2318821464265 0 -0.5 0.866025403784439
+1 8.5 0.654700538379252 17.4639329539954 1 0 0
+1 10 0.366025403784439 16.9639329539954 0 0.5 0.866025403784439
+1 8.5 -1.36602540378444 14.4998313388576 1 0 0
+1 10 -1.36602540378444 14.4998313388576 0 0.5 0.866025403784439
+1 8.5 1.36602540378444 16.2318821464265 1 0 0
+1 10 1.36602540378444 16.2318821464265 0 -0.5 0.866025403784439
+2 10 -0.5 13.9998313388576 1 0 0 0 -1 0 0 0 -1 1
+1 8.5 -1.36602540378444 13.4998313388576 1 0 0
+1 8.5 1.36602540378444 15.2318821464265 1 0 0
+2 10 0.5 15.7318821464265 1 0 0 0 -1 0 0 0 -1 1
+1 8.5 -0.654700538379252 12.2677805312887 1 0 0
+1 10 -0.366025403784439 11.7677805312887 0 -0.5 0.866025403784439
+1 8.5 0.654700538379252 13.9998313388576 1 0 0
+1 10 0.366025403784439 13.4998313388576 0 0.5 0.866025403784439
+1 8.5 -1.36602540378444 11.0357297237199 1 0 0
+1 10 -1.36602540378444 11.0357297237199 0 0.5 0.866025403784439
+1 8.5 1.36602540378444 12.7677805312887 1 0 0
+1 10 1.36602540378444 12.7677805312887 0 -0.5 0.866025403784439
+2 10 -0.5 10.5357297237199 1 0 0 0 -1 0 0 0 -1 1
+1 8.5 -1.36602540378444 10.0357297237199 1 0 0
+1 8.5 1.36602540378444 11.7677805312887 1 0 0
+2 10 0.5 12.2677805312887 1 0 0 0 -1 0 0 0 -1 1
+1 8.5 -0.654700538379252 8.80367891615099 1 0 0
+1 10 -0.366025403784439 8.30367891615099 0 -0.5 0.866025403784439
+1 8.5 0.654700538379252 10.5357297237199 1 0 0
+1 10 0.366025403784439 10.0357297237199 0 0.5 0.866025403784439
+1 8.5 -1.36602540378444 7.57162810858211 1 0 0
+1 10 -1.36602540378444 7.57162810858211 0 0.5 0.866025403784439
+1 8.5 1.36602540378444 9.30367891615099 1 0 0
+1 10 1.36602540378444 9.30367891615099 0 -0.5 0.866025403784439
+2 10 -0.5 7.07162810858211 1 0 0 0 -1 0 0 0 -1 1
+1 8.5 -1.36602540378444 6.57162810858211 1 0 0
+1 8.5 1.36602540378444 8.30367891615099 1 0 0
+2 10 0.5 8.80367891615099 1 0 0 0 -1 0 0 0 -1 1
+1 8.5 -0.654700538379252 5.33957730101323 1 0 0
+1 10 -0.366025403784439 4.83957730101323 0 -0.5 0.866025403784439
+1 8.5 0.654700538379252 7.07162810858211 1 0 0
+1 10 0.366025403784439 6.57162810858211 0 0.5 0.866025403784439
+1 8.5 -1.36602540378444 4.10752649344435 1 0 0
+1 10 -1.36602540378444 4.10752649344435 0 0.5 0.866025403784439
+1 8.5 1.36602540378444 5.83957730101323 1 0 0
+1 10 1.36602540378444 5.83957730101323 0 -0.5 0.866025403784439
+2 10 -0.5 3.60752649344435 1 0 0 0 -1 0 0 0 -1 1
+1 8.5 -1.36602540378444 3.10752649344435 1 0 0
+1 8.5 1.36602540378444 4.83957730101323 1 0 0
+2 10 0.5 5.33957730101323 1 0 0 0 -1 0 0 0 -1 1
+1 8.5 -0.366025403784439 1.37547568587548 1 0 0
+1 10 -0.366025403784439 1.37547568587548 0 -0.5 0.866025403784439
+1 8.5 0.654700538379251 3.60752649344435 1 0 0
+1 10 0.366025403784439 3.10752649344435 0 0.5 0.866025403784439
+2 10 0.5 1.87547568587548 1 0 0 0 -1 0 0 0 -1 1
+1 8.5 1.36602540378444 2.37547568587548 1 0 0
+1 10 1.36602540378444 2.37547568587548 0 -0.5 0.866025403784439
+1 -2.93374729156494 -11 0.990000000223517 -1 0 0
+1 -2.93374729156494 -11 33.9900000002235 -1 0 0
+1 -3.35410196624968 -11 0 0 0 -1
+1 -2.93374729156494 -11 1.99000000022352 -1 0 0
+1 -2.93374729156494 -11 32.9900000002235 -1 0 0
+1 -2.93374729156494 -11 2.99000000022352 -1 0 0
+1 -2.93374729156494 -11 31.9900000002235 -1 0 0
+1 -2.93374729156494 -11 3.99000000022352 -1 0 0
+1 -2.93374729156494 -11 30.9900000002235 -1 0 0
+1 5 -8.07774721070176 2.99000000022352 0 0 1
+8 5.72892347272726 6.83744714163191
+2 0 0 4.05049705505371 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 5.91705513000488 0 0 1 0 -1 0 1 0 -0 9.5
+1 -5 -8.07774721070176 2.99000000022352 0 0 1
+2 0 0 29.0504970550537 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 30.9170551300049 0 0 1 0 -1 0 1 0 -0 9.5
+1 -2.93374729156494 -11 5.99000000022352 -1 0 0
+1 -2.93374729156494 -11 28.9900000002235 -1 0 0
+1 -2.93374729156494 -11 6.99000000022352 -1 0 0
+1 -2.93374729156494 -11 27.9900000002235 -1 0 0
+1 -2.93374729156494 -11 7.99000000022352 -1 0 0
+1 -2.93374729156494 -11 26.9900000002235 -1 0 0
+1 -2.93374729156494 -11 8.99000000022352 -1 0 0
+1 -2.93374729156494 -11 25.9900000002235 -1 0 0
+2 0 0 9.05049705505371 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 10.9170551300049 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 24.0504970550537 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 25.9170551300049 0 0 1 0 -1 0 1 0 -0 9.5
+1 -2.93374729156494 -11 10.9900000002235 -1 0 0
+1 -2.93374729156494 -11 23.9900000002235 -1 0 0
+1 -2.93374729156494 -11 11.9900000002235 -1 0 0
+1 -2.93374729156494 -11 22.9900000002235 -1 0 0
+1 -2.93374729156494 -11 12.9900000002235 -1 0 0
+1 -2.93374729156494 -11 21.9900000002235 -1 0 0
+1 -2.93374729156494 -11 13.9900000002235 -1 0 0
+1 -2.93374729156494 -11 20.9900000002235 -1 0 0
+2 0 0 14.0504970550537 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 15.9170551300049 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 19.0504970550537 0 0 1 0 -1 0 1 0 -0 9.5
+2 0 0 20.9170551300049 0 0 1 0 -1 0 1 0 -0 9.5
+1 -2.93374729156494 -11 15.9900000002235 -1 0 0
+1 -2.93374729156494 -11 18.9900000002235 -1 0 0
+1 -2.93374729156494 -11 16.9900000002235 -1 0 0
+1 -2.93374729156494 -11 17.9900000002235 -1 0 0
+1 3.35410196624968 -11 0 0 0 -1
+1 0 0 37 -0.458020324345375 0.888941720523094 0
+2 0 0 37 0 0 1 1 0 -0 -0 1 0 4.5
+1 0 0 37 0.456209740184649 0.889872279015733 0
+2 0 0 37 0 0 1 1 0 -0 -0 1 0 7.75
+1 0 0 37 -0.458020324345375 -0.888941720523094 0
+2 0 0 37 0 0 -1 1 0 0 0 -1 0 4.5
+1 0 0 37 0.456209740184649 -0.889872279015733 0
+2 0 0 37 0 0 -1 1 0 0 0 -1 0 7.75
+1 0.583333333333333 0 6.875 -1 0 0
+2 0.583333333333333 0 0 -1 0 0 0 0 1 0 1 -0 6.875
+1 2.91666666666667 0 2.375 1 0 0
+2 2.91666666666667 0 0 1 0 0 0 0 1 0 -1 0 2.375
+1 8.5 0 0 0 0 -1
+2 0 0 -3 0 0 1 1 0 -0 -0 1 0 8.5
+1 5 20 5.91961097717285 0 -1 0
+1 5 20 30.9196109771729 0 0 -1
+1 5 20 4.10471725463867 0 -1 0
+1 1.81674337387085 20 29.1047172546387 -1 0 0
+1 -5 20 4.10471725463867 0 -1 0
+1 -5 20 5.91961097717285 0 -1 0
+1 -2.20906782150269 20 30.9196109771729 1 0 0
+1 -5 20 29.1047172546387 0 0 1
+1 5 20 30.9196109771729 0 -1 0
+1 5 20 29.1047172546387 0 -1 0
+1 -5 20 29.1047172546387 0 -1 0
+1 -5 20 30.9196109771729 0 -1 0
+1 5 20 10.9196109771729 0 -1 0
+1 5 20 9.10471725463867 0 -1 0
+1 -5 20 9.10471725463867 0 -1 0
+1 -5 20 10.9196109771729 0 -1 0
+1 5 20 25.9196109771729 0 -1 0
+1 5 20 24.1047172546387 0 -1 0
+1 -5 20 24.1047172546387 0 -1 0
+1 -5 20 25.9196109771729 0 -1 0
+1 5 20 15.9196109771729 0 -1 0
+1 5 20 14.1047172546387 0 -1 0
+1 -5 20 14.1047172546387 0 -1 0
+1 -5 20 15.9196109771729 0 -1 0
+1 5 20 20.9196109771729 0 -1 0
+1 5 20 19.1047172546387 0 -1 0
+1 -5 20 19.1047172546387 0 -1 0
+1 -5 20 20.9196109771729 0 -1 0
+1 5 -20 5.91705513000488 0 1 0
+1 5 -20 30.9170551300049 0 0 -1
+1 5 -20 4.05049705505371 0 1 0
+1 3.37570285797119 -20 29.0504970550537 -1 0 0
+1 -5 -20 4.05049705505371 0 1 0
+1 -5 -20 5.91705513000488 0 1 0
+1 -2.92040348052979 -20 30.9170551300049 1 0 0
+1 -5 -20 29.0504970550537 0 0 1
+1 5 -20 30.9170551300049 0 1 0
+1 5 -20 29.0504970550537 0 1 0
+1 -5 -20 29.0504970550537 0 1 0
+1 -5 -20 30.9170551300049 0 1 0
+1 5 -20 10.9170551300049 0 1 0
+1 5 -20 9.05049705505371 0 1 0
+1 -5 -20 9.05049705505371 0 1 0
+1 -5 -20 10.9170551300049 0 1 0
+1 5 -20 25.9170551300049 0 1 0
+1 5 -20 24.0504970550537 0 1 0
+1 -5 -20 24.0504970550537 0 1 0
+1 -5 -20 25.9170551300049 0 1 0
+1 5 -20 15.9170551300049 0 1 0
+1 5 -20 14.0504970550537 0 1 0
+1 -5 -20 14.0504970550537 0 1 0
+1 -5 -20 15.9170551300049 0 1 0
+1 5 -20 20.9170551300049 0 1 0
+1 5 -20 19.0504970550537 0 1 0
+1 -5 -20 19.0504970550537 0 1 0
+1 -5 -20 20.9170551300049 0 1 0
+1 -2.06109145955419 4.00023774235392 36 0 0 1
+1 -3.54965751367666 6.88929833405398 36 0 0 1
+1 2.05294383083092 4.0044252555708 36 0 0 1
+1 3.53562548643103 6.89651016237193 36 0 0 1
+1 -2.06109145955419 -4.00023774235392 36 0 0 1
+1 -3.54965751367666 -6.88929833405398 36 0 0 1
+1 2.05294383083092 -4.0044252555708 36 0 0 1
+1 3.53562548643103 -6.89651016237193 36 0 0 1
+8 1.5707963267949 7.85398163397448
+2 0 -6.69473585634028e-15 -2.16666666666667 0 -1.22464679914735e-16 -1 0 1 -1.22464679914735e-16 1 0 0 1.5
+8 2.96705976326997 9.25024507044956
+2 13 0 -2.16666666666667 -1.11022302462516e-16 0 1 -1 0 -1.11022302462516e-16 -0 -1 0 2
+1 8.5 0 -3 -0.707106781186548 0 -0.707106781186547
+2 0 0 -3.5 0 0 1 1 0 -0 -0 1 0 8
+2 0 0 56 0 0 1 1 0 -0 -0 1 0 1.5
+1 14.969615518138 -0.347296286634442 0.166666666666667 1.11022302462516e-16 -0 -1
+2 13 0 -3.83333333333333 -1.11022302462516e-16 0 1 -1 0 -1.11022302462516e-16 -0 -1 0 2
+2 0 0 -3.5 0 0 1 0 -1 0 1 0 -0 1.5
+1 1.5 0 56 -0.707106781186548 0 0.707106781186547
+2 0 0 56.5 0 0 1 1 0 -0 -0 1 0 1
+2 2.91666666666667 0 0 1 0 0 0 0 1 0 -1 0 6.875
+2 0 0 -7 0 0 1 1 0 -0 -0 1 0 1.5
+1 2.91666666666667 0 6.875 1 0 0
+8 0 6.28318530717959
+2 3.5 0 0 1 0 0 0 0 1 0 -1 0 6.875
+1 1.5 0 -7 -0.707106781186548 0 -0.707106781186547
+2 0 0 -7.5 0 0 1 1 0 -0 -0 1 0 1
+8 3.14159265358979 9.42477796076938
+2 0 0 0 -1 0 0 0 0 -1 -0 -1 -0 1.125
+2 0 1.90744535234441 -1.725 1 0 0 0 -0.981217359419556 0.192905400582032 0 -0.192905400582032 -0.981217359419556 1.94395801708275
+1 0 0.795603032049121 9.53287449408005 0 -0.998629534754574 0.0523359562429475
+2 0 0 0 1 0 0 0 0 1 0 -1 0 1.35
+2 0 -0.995438171441418 8.77713367899895 1 0 0 0 0.955678042979317 -0.294413787325294 -0 0.294413787325294 0.955678042979317 1.94395801708275
+2 0 -2.46699832966526 -0.726561775494072 1 0 0 0 0.579396446870187 -0.815045862117097 -0 0.815045862117097 0.579396446870187 1.94395801708275
+2 0 0 0 1 0 0 0 0 1 0 -1 0 8.25
+1 0 -1.95470723521056 -1.82130311288263 0 0.78183148246803 -0.623489801858733
+2 0 3.65900142822974 8.03994286798066 1 0 0 0 -0.756109257202842 0.654445407327584 0 -0.654445407327584 -0.756109257202842 1.94395801708275
+2 0 -0.15938658246777 -2.5668207357565 1 0 0 0 -0.46095950169171 0.887421172724727 0 -0.887421172724727 -0.46095950169171 1.94395801708275
+1 0 2.76021325135306 9.15914314286783 0 -0.965925826289068 0.258819045102523
+2 0 0.851183244659894 8.79229548276163 1 0 0 0 0.873582116491336 -0.486676777488425 -0 0.486676777488425 0.873582116491336 1.94395801708275
+2 0 -2.10619716978796 1.47577310388742 1 0 0 0 -0.275980738801696 -0.961163166070397 0 0.961163166070397 -0.275980738801696 1.94395801708275
+1 0 -2.64269213954193 0.392687738519768 0 -5.65448276439762e-16 -1
+2 0 5.25064158386452 7.10350165270432 1 0 0 0 -0.603519604640184 0.797348159096737 0 -0.797348159096737 -0.603519604640184 1.94395801708274
+2 0 -2.10619716978795 -1.4757731038874 1 0 0 -0 0.406410262670229 0.913690701712738 0 -0.913690701712738 0.406410262670229 1.94395801708273
+1 0 4.60418890660018 8.38511328586726 0 -0.891006524188367 0.453990499739548
+2 0 2.66060386853919 8.42319178381299 1 0 0 0 0.753306459600605 -0.657669657141032 -0 0.657669657141032 0.753306459600605 1.94395801708276
+2 0 -0.15938658246777 2.5668207357565 1 0 0 0 -0.92353879917478 -0.383505001817193 0 0.383505001817193 -0.92353879917478 1.94395801708275
+1 0 -1.3406759617027 2.31097671344672 0 -0.78183148246803 -0.623489801858733
+2 0 6.61280350691073 5.85660332882204 1 0 0 0 -0.424553249346382 0.905402970212396 0 -0.905402970212396 -0.424553249346382 1.94395801708275
+2 0 -2.46699832966526 0.726561775494073 1 0 0 -0 0.967744809982941 0.251932496417358 0 -0.251932496417358 0.967744809982941 1.94395801708275
+1 0 6.24693941327929 7.24461374203661 0 -0.777145961456969 0.62932039104984
+2 0 4.35374333636952 7.68595418495311 1 0 0 0 0.600107695659879 -0.799919216927428 -0 0.799919216927428 0.600107695659879 1.94395801708274
+2 0 1.90744535234441 1.725 1 0 0 0 -0.875653307010976 0.482940250880728 0 -0.482940250880728 -0.875653307010976 1.94395801708275
+1 0 0.970896560104362 2.48905308781432 0 -0.974927912181824 0.222520933956314
+2 0 7.68595418495314 4.35374333636947 1 0 0 0 -0.227031879823628 0.973887326924296 0 -0.973887326924296 -0.227031879823628 1.94395801708276
+2 0 -0.970099429709683 2.38178081876927 1 0 0 0 0.800347776981936 -0.59953601716667 -0 0.59953601716667 0.800347776981936 1.94395801708275
+1 0 7.61666869145698 5.78748981416527 0 -0.629320391049836 0.777145961456972
+2 0 5.85660332882207 6.6128035069107 1 0 0 0 0.420681345782605 -0.907208468495823 -0 0.907208468495823 0.420681345782605 1.94395801708274
+2 0 2.53793203204693 -0.415780919343873 1 0 0 0 -0.168383014595658 0.985721644479657 0 -0.985721644479657 -0.168383014595658 1.94395801708275
+1 0 2.55136416947229 0.792821719627716 0 -0.433883739117558 0.900968867902419
+2 0 8.42319178381299 2.66060386853918 1 0 0 0 -0.0195881277327439 0.999808134219724 0 -0.999808134219724 -0.0195881277327439 1.94395801708274
+2 0 1.25730412723934 2.2434703260367 1 0 0 0 0.030272543794149 -0.9995416815182 -0 0.9995416815182 0.030272543794149 1.94395801708275
+1 0 8.6535129989866 4.07742480995759 0 -0.453990499739538 0.891006524188372
+2 0 7.10350165270441 5.25064158386437 1 0 0 0 0.222869202441545 -0.974848356721736 -0 0.974848356721736 0.222869202441545 1.9439580170826
+2 0 1.25730412723934 -2.2434703260367 1 0 0 -0 0.665683122197733 0.746234534728244 0 -0.746234534728244 0.665683122197733 1.94395801708275
+1 0 2.21060252088314 -1.50042057405435 0 0.433883739117558 0.900968867902419
+2 0 8.79229548276163 0.851183244659852 1 0 0 -0 0.188711719534317 0.982032528438036 0 -0.982032528438036 0.188711719534317 1.94395801708275
+2 0 2.53793203204693 0.415780919343874 1 0 0 0 -0.762598532317987 -0.646872072751987 0 0.646872072751987 -0.762598532317987 1.94395801708276
+1 0 9.31215726429811 2.18915677589975 0 -0.25881904510252 0.965925826289069
+2 0 8.03994286798068 3.6590014282297 1 0 0 0 0.0153166055087473 -0.999882693917486 -0 0.999882693917486 0.0153166055087473 1.94395801708274
+2 0 -0.970099429709683 -2.38178081876927 1 0 0 0 0.998476290515191 -0.055182400083943 -0 0.055182400083943 0.998476290515191 1.94395801708275
+1 0 0.205212085995401 -2.66381557247155 0 0.974927912181824 0.222520933956314
+2 0 8.77713367899895 -0.995438171441455 1 0 0 -0 0.388763959118435 0.92133738884871 0 -0.92133738884871 0.388763959118435 1.94395801708275
+1 0 9.56381557247154 0.205212085995401 0 -0.0523359562429416 0.998629534754574
+2 0 8.625 1.90744535234441 1 0 0 0 -0.192905400582032 -0.981217359419556 0 0.981217359419556 -0.192905400582032 1.94395801708274
+2 0 8.37836901610377 -2.79855416280847 1 0 0 -0 0.571825348192627 0.820375384299395 0 -0.820375384299395 0.571825348192627 1.94395801708274
+1 0 9.39748924784919 -1.78770135678379 0 0.156434465040228 0.987688340595138
+2 0 8.83310324467748 0.0725247616233621 1 0 0 0 -0.392696515004565 -0.919668117911711 0 0.919668117911711 -0.392696515004565 1.94395801708275
+2 0 7.61342942332977 -4.47935990830797 1 0 0 -0 0.729895225628348 0.683559038858344 0 -0.683559038858344 0.729895225628348 1.94395801708275
+1 0 8.8204475489393 -3.70248367192868 0 0.3583679495453 0.933580426497202
+2 0 8.65515749163058 -1.7655655091929 1 0 0 0 -0.575324907354431 -0.817924966593889 0 0.817924966593889 -0.575324907354431 1.94395801708289
+2 0 6.51574643146859 -5.96439613146081 1 0 0 -0 0.856065179278228 0.516867883338998 0 -0.516867883338998 0.856065179278228 1.94395801708275
+1 0 7.85790996693753 -5.45544968412244 0 0.544639035015025 0.838670567945425
+2 0 8.09893982414579 -3.52649209513443 1 0 0 0 -0.732808840537747 -0.680434569396443 0 0.680434569396443 -0.732808840537747 1.94395801708275
+2 0 5.13329405453195 -7.18875962332079 1 0 0 -0 0.944820976737161 0.327587121110456 0 -0.327587121110456 0.944820976737161 1.94395801708274
+1 0 6.55194401294509 -6.96998636696807 0 0.707106781186545 0.707106781186551
+2 0 7.18875962332082 -5.13329405453191 1 0 0 0 -0.858265510982587 -0.513205916429067 0 0.513205916429067 -0.858265510982587 1.94395801708275
+2 0 3.52649209513445 -8.09893982414578 1 0 0 -0 0.992283563758622 0.123989229751979 0 -0.123989229751979 0.992283563758622 1.94395801708276
+1 0 4.9596266658714 -8.17990119987186 0 0.838670567945423 0.544639035015028
+2 0 5.96439613146085 -6.51574643146855 1 0 0 0 -0.946211860182636 -0.32354770227853 0 0.32354770227853 -0.946211860182636 1.94395801708277
+2 0 1.76556550919306 -8.65515749163053 1 0 0 0 0.996378597539011 -0.0850275859129999 -0 0.0850275859129999 0.996378597539011 1.94395801708275
+1 0 3.15054983456993 -9.03231509882041 0 0.933580426497202 0.3583679495453
+2 0 4.47935990830799 -7.61342942332976 1 0 0 0 -0.992804210664447 -0.119748900984286 0 0.119748900984286 -0.992804210664447 1.94395801708275
+2 0 -0.0725247616233471 -8.83310324467748 1 0 0 0 0.956927105451975 -0.29032828806595 -0 0.29032828806595 0.956927105451975 1.94395801708275
+1 0 1.20377885748234 -9.48997348609396 0 0.987688340595138 0.156434465040233
+2 0 2.79855416280848 -8.37836901610376 1 0 0 0 -0.99600625313706 0.0892835019019461 0 -0.0892835019019461 -0.99600625313706 1.94395801708274
+2 0 -1.9074453523444 -8.625 1 0 0 0 0.875653307010977 -0.482940250880727 -0 0.482940250880727 0.875653307010977 1.94395801708275
+1 0 -0.795603032049074 -9.53287449408006 0 0.998629534754574 -0.0523359562429411
+2 0 0.995438171441464 -8.77713367899895 1 0 0 0 -0.955678042979318 0.294413787325289 0 -0.294413787325289 -0.955678042979318 1.94395801708275
+2 0 -3.6590014282297 -8.03994286798068 1 0 0 0 0.756109257202844 -0.654445407327581 -0 0.654445407327581 0.756109257202844 1.94395801708274
+1 0 -2.76021325135302 -9.15914314286784 0 0.965925826289069 -0.258819045102518
+2 0 -0.851183244659862 -8.79229548276163 1 0 0 0 -0.873582116491338 0.486676777488422 0 -0.486676777488422 -0.873582116491338 1.94395801708275
+2 0 -5.25064158386451 -7.10350165270433 1 0 0 0 0.603519604640189 -0.797348159096734 -0 0.797348159096734 0.603519604640189 1.94395801708276
+1 0.583333333333333 0 1.125 -1 0 0
+2 0.583333333333333 0 0 -1 0 0 0 0 1 0 1 -0 1.125
+1 22.5577565994779 -0.320824177874158 -3.25 -1.11022302462516e-16 0 1
+1 0 0 -1.35 1 0 0
+1 0 -0.585743047808703 -1.21630797166827 1 0 0
+1 0 -1.3406759617027 -2.31097671344672 1 0 0
+1 0 -1.95470723521056 -1.82130311288263 1 0 0
+1 0 -1.05547250133184 -0.84171123250929 1 0 0
+1 0 -1.31615268144546 -0.300403260841024 1 0 0
+1 0 -2.64269213954193 -0.392687738519769 1 0 0
+1 0 -2.64269213954193 0.392687738519768 1 0 0
+1 0 -1.31615268144546 0.300403260841024 1 0 0
+1 0 -1.05547250133184 0.84171123250929 1 0 0
+1 0 -1.95470723521056 1.82130311288263 1 0 0
+1 0 -1.3406759617027 2.31097671344672 1 0 0
+1 0 -0.585743047808703 1.21630797166827 1 0 0
+1 0 0 1.35 1 0 0
+1 0 0.205212085995401 2.66381557247155 1 0 0
+1 0 0.970896560104362 2.48905308781432 1 0 0
+1 0 0.585743047808703 1.21630797166827 1 0 0
+1 0 1.05547250133184 0.84171123250929 1 0 0
+1 0 2.21060252088314 1.50042057405435 1 0 0
+1 0 2.55136416947229 0.792821719627716 1 0 0
+1 0 1.31615268144546 0.300403260841024 1 0 0
+1 0 1.31615268144546 -0.300403260841024 1 0 0
+1 0 2.55136416947229 -0.792821719627716 1 0 0
+1 0 2.21060252088314 -1.50042057405435 1 0 0
+1 0 1.05547250133184 -0.84171123250929 1 0 0
+1 0 0.585743047808703 -1.21630797166827 1 0 0
+1 0 0.970896560104362 -2.48905308781432 1 0 0
+1 22.3488637857124 -0.103285162141172 -6.75 -1.11022302462516e-16 -2.22044604925031e-16 -1
+1 0 0 8.25 1 0 0
+1 0 8.25 0 1 0 0
+2 3.5 0 0 1 0 0 0 0 1 0 -1 0 1.125
+1 2.91666666666667 0 1.125 1 0 0
+2 2.91666666666667 0 0 1 0 0 0 0 1 0 -1 0 1.125
+Polygon3D 0
+PolygonOnTriangulations 0
+Surfaces 647
+2 24.9999998448251 -4.25474520993063e-06 -13.25 0 0 -1 1 0 0 0 -1 0 1
+3 24.9999998448251 -4.25474520993063e-06 -6.5 -0 -0 1 1 0 0 0 -1 0 1
+-0.785398163397448
+1 24.9999998448251 -4.25474520993063e-06 -16.25 0 0 -1 1 0 0 0 -1 0
+1 24.9999998448251 -4.25474520993063e-06 -13.25 0 0 -1 1 0 0 0 -1 0
+2 24.9999998448251 -4.25474520993063e-06 -16.25 0 0 -1 1 0 0 0 -1 0 5
+1 32.9999998448251 -4.25474520993063e-06 -16.25 0 0 -1 1 0 0 0 -1 0
+5 24.9999998448251 -4.25474520993063e-06 -17.25 0 0 -1 1 0 0 0 -1 0 12.75 1
+2 24.9999998448251 7.99999574525479 -16.25 0 0 1 1 0 0 0 -1 0 1
+2 24.9999998448251 -8.00000425474521 -16.25 -0 -0 1 -1 1.22464679914735e-16 0 1.22464679914735e-16 1 0 1
+2 28.6143241317361 -7.69329093528985 -16.25 -0 -0 1 1 0 0 0 -1 0 1.5
+2 24.9999998448251 -4.25474520993063e-06 -16.25 -0 -0 1 1 0 0 0 -1 0 7
+2 32.6932865253697 -3.61432854165618 -16.25 -0 -0 1 1 0 0 0 -1 0 1.5
+2 24.9999998448251 -4.25474520993063e-06 -16.25 -0 -0 1 1 0 0 0 -1 0 10
+2 28.6143241317361 7.69329093528985 -16.25 0 0 1 1 -0 -0 -0 1 0 1.5
+2 24.9999998448251 4.25474520993063e-06 -16.25 0 0 1 1 -0 -0 -0 1 0 7
+2 32.6932865253697 3.61432854165618 -16.25 0 0 1 1 -0 -0 -0 1 0 1.5
+2 24.9999998448251 4.25474520993063e-06 -16.25 0 0 1 1 -0 -0 -0 1 0 10
+2 21.3856755579141 -7.69329093528985 -16.25 0 -0 1 -1 -0 0 -0 -1 -0 1.5
+2 24.9999998448251 -4.25474520993063e-06 -16.25 0 -0 1 -1 -0 0 -0 -1 -0 10
+2 17.3067131642804 -3.61432854165618 -16.25 0 -0 1 -1 -0 0 -0 -1 -0 1.5
+2 24.9999998448251 -4.25474520993063e-06 -16.25 0 -0 1 -1 -0 0 -0 -1 -0 7
+2 17.3067128914066 3.61431945133876 -16.25 -0 0 1 -7.54978997097311e-08 0.999999999999997 -0 -0.999999999999997 -7.54978995987088e-08 -0 1.5
+2 24.9999998448251 -4.25474521037472e-06 -16.25 -0 0 1 -7.54978997097311e-08 0.999999999999997 -0 -0.999999999999997 -7.54978995987088e-08 -0 10
+2 21.3856749770871 7.69328215292552 -16.25 -0 0 1 -7.54978997097311e-08 0.999999999999997 -0 -0.999999999999997 -7.54978995987088e-08 -0 1.5
+2 24.9999998448251 -4.25474521037472e-06 -16.25 -0 0 1 -7.54978997097311e-08 0.999999999999997 -0 -0.999999999999997 -7.54978995987088e-08 -0 7
+2 14.9999998448251 -4.25474520993063e-06 -16.25 -0 -0 1 1 0 0 0 -1 0 1.5
+2 24.9999998448251 -4.25474520993063e-06 -16.25 0 0 1 1 0 0 0 -1 0 13.75
+2 24.9999998448251 -4.25474520993063e-06 -48.25 -0 -0 1 1 0 0 0 -1 0 5
+1 24.9999998448251 -4.25474520993063e-06 -48.25 0 0 -1 1 0 0 0 -1 0
+1 25.3456745147705 -12.25 -48.25 1 -1.22464679914735e-16 0 1.22464679914735e-16 1 0 -0 0 1
+1 22.3456745147705 -12.25 -48.25 0 -1 0 1 0 0 -0 0 1
+1 22.3456745147705 -12 -48.25 -1 -0 -0 0 -1 0 -0 0 1
+1 25.3456745147705 -12 -48.25 1.22464679914735e-16 1 0 -1 1.22464679914735e-16 0 0 -0 1
+1 25.3456745147705 12.25 -48.25 -1 -1.22464679914735e-16 -0 1.22464679914735e-16 -1 0 -0 0 1
+1 22.3456745147705 12.25 -48.25 -0 -1 -0 1 -0 0 -0 0 1
+1 22.3456745147705 12 -48.25 1 0 0 -0 1 0 0 -0 1
+1 25.3456745147705 12 -48.25 -1.22464679914735e-16 1 0 -1 -1.22464679914735e-16 -0 0 -0 1
+1 2.91666666666667 0 0 1 0 0 0 0 1 0 -1 0
+2 0 0 56.5 0 0 1 1 0 -0 -0 1 0 1.5
+1 0 0 0 1 0 0 0 0 1 0 -1 0
+1 0 0 0 0 0 1 1 0 -0 -0 1 0
+2 0.583333333333333 0 0 -1 0 0 0 0 1 0 1 -0 2.375
+2 0 1.0077593076089 -3.60879397446127 -1 0 0 0 -0.897855597092752 0.440290048455808 -0 -0.440290048455808 -0.897855597092752 1.94395801708275
+2 0 -0.995438171441418 8.77713367899895 -1 0 0 0 0.955678042979317 -0.294413787325294 0 0.294413787325294 0.955678042979317 1.94395801708275
+2 0 0 0 -1 0 0 0 0 1 -0 -1 0 2.85
+2 0 0 0 -1 0 0 0 0 1 -0 -1 0 8.25
+2 0 -3.26439613146082 -1.83920925103261 -1 0 0 0 0.516867883338996 -0.856065179278229 0 0.856065179278229 0.516867883338996 1.94395801708275
+2 0 3.65900142822974 8.03994286798066 -1 0 0 0 -0.756109257202842 0.654445407327584 -0 -0.654445407327584 -0.756109257202842 1.94395801708275
+2 0 -0.931651825941123 -3.62918691271211 -1 0 0 0 -0.557420731784463 0.830230165542588 -0 -0.830230165542588 -0.557420731784463 1.94395801708274
+2 0 0.851183244659894 8.79229548276163 -1 0 0 0 0.873582116491336 -0.486676777488425 0 0.486676777488425 0.873582116491336 1.94395801708275
+2 0 -3.74665460337702 0.0393961314608192 -1 0 0 0 0.0195881277327475 -0.999808134219724 0 0.999808134219724 0.0195881277327475 1.94395801708275
+2 0 5.25064158386452 7.10350165270432 -1 0 0 0 -0.603519604640184 0.797348159096737 -0 -0.797348159096737 -0.603519604640184 1.94395801708274
+2 0 -2.62142760510323 -2.67714214852014 -1 0 0 0 -0.0676254315501626 0.997710780240273 -0 -0.997710780240273 -0.0676254315501626 1.94395801708274
+2 0 2.66060386853919 8.42319178381299 -1 0 0 0 0.753306459600605 -0.657669657141032 0 0.657669657141032 0.753306459600605 1.94395801708276
+2 0 -3.225 1.90744535234444 -1 0 0 -0 -0.482940250880724 -0.875653307010979 -0 0.875653307010979 -0.482940250880724 1.94395801708277
+2 0 6.61280350691073 5.85660332882204 -1 0 0 0 -0.424553249346382 0.905402970212396 -0 -0.905402970212396 -0.424553249346382 1.94395801708275
+2 0 -3.60879397446127 -1.00775930760889 -1 0 0 0 0.440290048455809 0.897855597092751 -0 -0.897855597092751 0.440290048455809 1.94395801708275
+2 0 4.35374333636952 7.68595418495311 -1 0 0 0 0.600107695659879 -0.799919216927428 0 0.799919216927428 0.600107695659879 1.94395801708274
+2 0 -1.8392092510326 3.26439613146083 -1 0 0 -0 -0.856065179278228 -0.516867883338997 -0 0.516867883338997 -0.856065179278228 1.94395801708276
+2 0 7.68595418495314 4.35374333636947 -1 0 0 0 -0.227031879823628 0.973887326924296 -0 -0.973887326924296 -0.227031879823628 1.94395801708276
+2 0 -3.62918691271211 0.931651825941123 -1 0 0 0 0.830230165542588 0.557420731784463 -0 -0.557420731784463 0.830230165542588 1.94395801708274
+2 0 5.85660332882207 6.6128035069107 -1 0 0 0 0.420681345782605 -0.907208468495823 0 0.907208468495823 0.420681345782605 1.94395801708274
+2 0 0.0393961314608199 3.74665460337702 -1 0 0 -0 -0.999808134219724 -0.0195881277327477 -0 0.0195881277327477 -0.999808134219724 1.94395801708275
+2 0 8.42319178381299 2.66060386853918 -1 0 0 0 -0.0195881277327439 0.999808134219724 -0 -0.999808134219724 -0.0195881277327439 1.94395801708274
+2 0 -2.67714214852014 2.62142760510322 -1 0 0 0 0.997710780240273 0.0676254315501632 -0 -0.0676254315501632 0.997710780240273 1.94395801708275
+2 0 7.10350165270441 5.25064158386437 -1 0 0 0 0.222869202441545 -0.974848356721736 0 0.974848356721736 0.222869202441545 1.9439580170826
+2 0 1.90744535234441 3.225 -1 0 0 0 -0.875653307010975 0.48294025088073 -0 -0.48294025088073 -0.875653307010975 1.94395801708275
+2 0 8.79229548276163 0.851183244659852 -1 0 0 0 0.188711719534317 0.982032528438036 -0 -0.982032528438036 0.188711719534317 1.94395801708275
+2 0 -1.00775930760888 3.60879397446127 -1 0 0 0 0.897855597092751 -0.440290048455811 0 0.440290048455811 0.897855597092751 1.94395801708275
+2 0 8.03994286798068 3.6590014282297 -1 0 0 0 0.0153166055087473 -0.999882693917486 0 0.999882693917486 0.0153166055087473 1.94395801708274
+2 0 3.26439613146082 1.83920925103261 -1 0 0 0 -0.516867883338995 0.856065179278229 -0 -0.856065179278229 -0.516867883338995 1.94395801708275
+2 0 8.77713367899895 -0.995438171441455 -1 0 0 0 0.388763959118435 0.92133738884871 -0 -0.92133738884871 0.388763959118435 1.94395801708275
+2 0 0.931651825941121 3.62918691271211 -1 0 0 0 0.557420731784463 -0.830230165542588 0 0.830230165542588 0.557420731784463 1.94395801708275
+2 0 8.625 1.90744535234441 -1 0 0 -0 -0.192905400582032 -0.981217359419556 -0 0.981217359419556 -0.192905400582032 1.94395801708274
+2 0 3.74665460337702 -0.0393961314608269 -1 0 0 0 -0.0195881277327481 0.999808134219724 -0 -0.999808134219724 -0.0195881277327481 1.94395801708275
+2 0 8.37836901610377 -2.79855416280847 -1 0 0 0 0.571825348192627 0.820375384299395 -0 -0.820375384299395 0.571825348192627 1.94395801708274
+2 0 2.62142760510323 2.67714214852014 -1 0 0 0 0.0676254315501626 -0.997710780240273 0 0.997710780240273 0.0676254315501626 1.94395801708274
+2 0 8.83310324467748 0.0725247616233621 -1 0 0 -0 -0.392696515004565 -0.919668117911711 -0 0.919668117911711 -0.392696515004565 1.94395801708275
+2 0 3.225 -1.90744535234441 -1 0 0 0 0.482940250880728 0.875653307010977 -0 -0.875653307010977 0.482940250880728 1.94395801708275
+2 0 7.61342942332977 -4.47935990830797 -1 0 0 0 0.729895225628348 0.683559038858344 -0 -0.683559038858344 0.729895225628348 1.94395801708275
+2 0 3.60879397446127 1.0077593076089 -1 0 0 -0 -0.440290048455808 -0.897855597092752 -0 0.897855597092752 -0.440290048455808 1.94395801708275
+2 0 8.65515749163058 -1.7655655091929 -1 0 0 -0 -0.575324907354431 -0.817924966593889 -0 0.817924966593889 -0.575324907354431 1.94395801708289
+2 0 1.83920925103261 -3.26439613146082 -1 0 0 0 0.856065179278228 0.516867883338998 -0 -0.516867883338998 0.856065179278228 1.94395801708275
+2 0 6.51574643146859 -5.96439613146081 -1 0 0 0 0.856065179278228 0.516867883338998 -0 -0.516867883338998 0.856065179278228 1.94395801708275
+2 0 3.62918691271211 -0.931651825941115 -1 0 0 -0 -0.830230165542587 -0.557420731784465 -0 0.557420731784465 -0.830230165542587 1.94395801708275
+2 0 8.09893982414579 -3.52649209513443 -1 0 0 -0 -0.732808840537747 -0.680434569396443 -0 0.680434569396443 -0.732808840537747 1.94395801708275
+2 0 -0.0393961314608182 -3.74665460337702 -1 0 0 0 0.999808134219724 0.0195881277327488 -0 -0.0195881277327488 0.999808134219724 1.94395801708275
+2 0 5.13329405453195 -7.18875962332079 -1 0 0 0 0.944820976737161 0.327587121110456 -0 -0.327587121110456 0.944820976737161 1.94395801708274
+2 0 2.67714214852015 -2.62142760510322 -1 0 0 -0 -0.997710780240273 -0.0676254315501645 -0 0.0676254315501645 -0.997710780240273 1.94395801708275
+2 0 7.18875962332082 -5.13329405453191 -1 0 0 -0 -0.858265510982587 -0.513205916429067 -0 0.513205916429067 -0.858265510982587 1.94395801708275
+2 0 -1.90744535234441 -3.225 -1 0 0 0 0.875653307010977 -0.482940250880728 0 0.482940250880728 0.875653307010977 1.94395801708275
+2 0 3.52649209513445 -8.09893982414578 -1 0 0 0 0.992283563758622 0.123989229751979 -0 -0.123989229751979 0.992283563758622 1.94395801708276
+2 0 1.90744535234445 8.62499999999999 -1 0 0 0 -0.875653307010975 0.482940250880731 -0 -0.482940250880731 -0.875653307010975 1.94395801708275
+2 0 5.96439613146085 -6.51574643146855 -1 0 0 -0 -0.946211860182636 -0.32354770227853 -0 0.32354770227853 -0.946211860182636 1.94395801708277
+2 0 -2.79855416280849 8.37836901610376 -1 0 0 0 0.99600625313706 -0.0892835019019452 0 0.0892835019019452 0.99600625313706 1.94395801708276
+2 0 1.76556550919306 -8.65515749163053 -1 0 0 0 0.996378597539011 -0.0850275859129999 0 0.0850275859129999 0.996378597539011 1.94395801708275
+2 0 0.0725247616233552 8.83310324467748 -1 0 0 0 -0.956927105451974 0.290328288065952 -0 -0.290328288065952 -0.956927105451974 1.94395801708274
+2 0 4.47935990830799 -7.61342942332976 -1 0 0 -0 -0.992804210664447 -0.119748900984286 -0 0.119748900984286 -0.992804210664447 1.94395801708275
+2 0 -4.47935990830798 7.61342942332977 -1 0 0 0 0.992804210664447 0.119748900984285 -0 -0.119748900984285 0.992804210664447 1.94395801708275
+2 0 -0.0725247616233471 -8.83310324467748 -1 0 0 0 0.956927105451975 -0.29032828806595 0 0.29032828806595 0.956927105451975 1.94395801708275
+2 0 -1.76556550919304 8.65515749163054 -1 0 0 0 -0.996378597539012 0.0850275859129976 -0 -0.0850275859129976 -0.996378597539012 1.94395801708276
+2 0 2.79855416280848 -8.37836901610376 -1 0 0 0 -0.99600625313706 0.0892835019019461 -0 -0.0892835019019461 -0.99600625313706 1.94395801708274
+2 0 -5.96439613146083 6.51574643146857 -1 0 0 0 0.946211860182637 0.323547702278527 -0 -0.323547702278527 0.946211860182637 1.94395801708276
+2 0 -1.9074453523444 -8.625 -1 0 0 0 0.875653307010977 -0.482940250880727 0 0.482940250880727 0.875653307010977 1.94395801708275
+2 0 -3.52649209513444 8.09893982414579 -1 0 0 -0 -0.992283563758622 -0.123989229751976 -0 0.123989229751976 -0.992283563758622 1.94395801708275
+2 0 0.995438171441464 -8.77713367899895 -1 0 0 0 -0.955678042979318 0.294413787325289 -0 -0.294413787325289 -0.955678042979318 1.94395801708275
+2 0 -7.18875962332081 5.13329405453192 -1 0 0 0 0.858265510982589 0.513205916429064 -0 -0.513205916429064 0.858265510982589 1.94395801708275
+2 0 -3.6590014282297 -8.03994286798068 -1 0 0 0 0.756109257202844 -0.654445407327581 0 0.654445407327581 0.756109257202844 1.94395801708274
+2 0 -5.13329405453192 7.18875962332081 -1 0 0 -0 -0.944820976737162 -0.327587121110454 -0 0.327587121110454 -0.944820976737162 1.94395801708275
+2 0 -0.851183244659862 -8.79229548276163 -1 0 0 0 -0.873582116491338 0.486676777488422 -0 -0.486676777488422 -0.873582116491338 1.94395801708275
+2 0 -8.09893982414579 3.52649209513444 -1 0 0 0 0.73280884053775 0.68043456939644 -0 -0.68043456939644 0.73280884053775 1.94395801708275
+2 0 -5.25064158386451 -7.10350165270433 -1 0 0 0 0.603519604640189 -0.797348159096734 0 0.797348159096734 0.603519604640189 1.94395801708276
+2 0 -6.5157464292362 5.9643961342655 -1 0 0 -0 -0.856065178937484 -0.516867883903356 -0 0.516867883903356 -0.856065178937484 1.9439580206637
+2 0 -2.66060386853918 -8.42319178381299 -1 0 0 0 -0.753306459600606 0.657669657141031 -0 -0.657669657141031 -0.753306459600606 1.94395801708274
+2 0 -8.6551615005749 1.76550817861768 -1 0 0 0 0.575311782061362 0.817934198711229 -0 -0.817934198711229 0.575311782061362 1.9440147991904
+2 0 -6.61280350691072 -5.85660332882206 -1 0 0 0 0.424553249346384 -0.905402970212395 0 0.905402970212395 0.424553249346384 1.94395801708275
+2 0 -7.61342942332976 4.47935990830799 -1 0 0 -0 -0.729895225628346 -0.683559038858346 -0 0.683559038858346 -0.729895225628346 1.94395801708277
+2 0 -4.35374333636949 -7.68595418495313 -1 0 0 0 -0.600107695659883 0.799919216927425 -0 -0.799919216927425 -0.600107695659883 1.94395801708276
+2 0 -8.83310324467747 -0.072524761623355 -1 0 0 0 0.392696515004565 0.919668117911711 -0 -0.919668117911711 0.392696515004565 1.94395801708274
+2 0 -7.68595418495313 -4.35374333636949 -1 0 0 0 0.227031879823626 -0.973887326924296 0 0.973887326924296 0.227031879823626 1.94395801708275
+2 0 -8.37836901610376 2.79855416280848 -1 0 0 -0 -0.571825348192628 -0.820375384299395 -0 0.820375384299395 -0.571825348192628 1.94395801708275
+2 0 -5.85660332882206 -6.61280350691071 -1 0 0 0 -0.420681345782606 0.907208468495822 -0 -0.907208468495822 -0.420681345782606 1.94395801708274
+2 0 -8.62500000000001 -1.90744535234434 -1 0 0 0 0.192905400582043 0.981217359419554 -0 -0.981217359419554 0.192905400582043 1.94395801708268
+2 0 -8.42319178381301 -2.66060386853914 -1 0 0 0 0.0195881277327562 -0.999808134219724 0 0.999808134219724 0.0195881277327562 1.94395801708279
+2 0 -8.77713367899895 0.995438171441455 -1 0 0 -0 -0.388763959118435 -0.92133738884871 -0 0.92133738884871 -0.388763959118435 1.94395801708275
+2 0 -7.10350165270429 -5.25064158386457 -1 0 0 0 -0.222869202441582 0.974848356721728 -0 -0.974848356721728 -0.222869202441582 1.94395801708283
+2 0 -8.03994286798068 -3.65900142822967 -1 0 0 0 -0.0153166055087457 0.999882693917486 -0 -0.999882693917486 -0.0153166055087457 1.94395801708272
+2 0 -8.79229548276164 -0.851183244659837 -1 0 0 -0 -0.188711719534311 -0.982032528438037 -0 0.982032528438037 -0.188711719534311 1.94395801708277
+2 0 0 2.99000000022352 0 0 1 0.996194698313003 0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0 9.5
+1 -12.3003673553467 3 -3.5 0 1 0 1 0 0 0 0 -1
+1 12.3003673553467 3 -3.5 0 -1 0 -1 0 0 -0 -0 -1
+1 -9 3 -3.5 1 0 0 0 -1 0 0 0 -1
+1 9 3 -3.5 1 0 0 0 -1 0 0 0 -1
+1 -9 -3 -3.5 0 -1 0 -1 0 0 -0 -0 -1
+1 9 -3 -3.5 0 1 0 1 0 0 0 0 -1
+1 -8.89749336242676 -3.08288931846619 33 0.737557952386025 0.675283841708162 0 0.675283841708162 -0.737557952386025 0 0 0 -1
+1 -8.28533533832021 -3.75150004318693 33 -0.375063278710263 0.926999210875127 0 0.926999210875127 0.375063278710263 0 0 0 -1
+1 -8.89749336242676 3.0519425868988 33 1 0 0 0 -1 0 0 0 -1
+1 -7.77440595626831 -3.54477834701538 33 0 1 0 1 0 0 0 0 -1
+1 -8.1806824381779 3.86953123903098 33 0.75192873986125 -0.659244393355508 0 -0.659244393355508 -0.75192873986125 0 0 -0 -1
+1 -7.27440595626831 -3.54477834701538 33 -1 0 0 0 1 0 0 0 -1
+1 -7.77440595626831 3.54477834701538 33 -0.624380466495325 -0.781120370403359 0 -0.781120370403359 0.624380466495325 0 -0 0 -1
+1 -7.27440595626831 -2.80323314666748 33 0 1 0 1 0 0 0 0 -1
+1 -7.27440595626831 3.54477834701538 33 0 -1 0 -1 0 0 -0 -0 -1
+1 -6.96637487411499 -2.80323314666748 33 -1 0 0 0 1 0 0 0 -1
+1 -7.27440595626831 2.80323314666748 33 -1 0 0 0 1 0 0 0 -1
+1 -6.96637487411499 2.80323314666748 33 0 -1 0 -1 0 0 -0 -0 -1
+1 8.89749336242676 -3.08288931846619 33 0.737557952386025 -0.675283841708162 0 -0.675283841708162 -0.737557952386025 0 0 -0 -1
+1 8.28533533832021 -3.75150004318693 33 -0.375063278710263 -0.926999210875127 0 -0.926999210875127 0.375063278710263 0 -0 0 -1
+1 8.89749336242676 3.0519425868988 33 1 0 0 0 -1 0 0 0 -1
+1 7.77440595626831 -3.54477834701538 33 0 -1 0 -1 0 0 -0 -0 -1
+1 8.1806824381779 3.86953123903098 33 0.75192873986125 0.659244393355508 0 0.659244393355508 -0.75192873986125 0 0 0 -1
+1 7.27440595626831 -3.54477834701538 33 -1 0 0 0 1 0 0 0 -1
+1 7.77440595626831 3.54477834701538 33 -0.624380466495325 0.781120370403359 0 0.781120370403359 0.624380466495325 0 0 0 -1
+1 7.27440595626831 -2.80323314666748 33 0 -1 0 -1 0 0 -0 -0 -1
+1 7.27440595626831 3.54477834701538 33 0 1 0 1 0 0 0 0 -1
+1 6.96637487411499 -2.80323314666748 33 -1 0 0 0 1 0 0 0 -1
+1 7.27440595626831 2.80323314666748 33 -1 0 0 0 1 0 0 0 -1
+1 6.96637487411499 2.80323314666748 33 0 1 0 1 0 0 0 0 -1
+1 -2 6.75 33 1 0 0 0 -1 0 0 0 -1
+1 -2 4.75 33 0 1 0 1 0 0 0 0 -1
+1 2 6.75 33 0 -1 0 -1 0 0 -0 -0 -1
+1 2 4.75 33 -1 0 0 0 1 0 0 0 -1
+1 -2 -6.75 33 -1 0 0 0 1 0 0 0 -1
+1 -2 -4.75 33 0 1 0 1 0 0 0 0 -1
+1 2 -6.75 33 0 -1 0 -1 0 0 -0 -0 -1
+1 2 -4.75 33 1 0 0 0 -1 0 0 0 -1
+1 0.583333333333333 0 0 -1 0 0 0 0 1 0 1 -0
+1 0 0.795603032049121 9.53287449408005 0 -0.0523359562429475 -0.998629534754574 0 -0.998629534754574 0.0523359562429475 -1 -0 0
+1 0 -2.79915536931599 -3.08936908449356 0 0.608761429008722 0.793353340291234 0 0.793353340291234 -0.608761429008722 -1 0 0
+1 0 2.76021325135306 9.15914314286783 0 -0.258819045102523 -0.965925826289068 0 -0.965925826289068 0.258819045102523 -1 -0 0
+1 0 -3.96882420121404 -1.2758944241797 0 0.923879532511287 0.382683432365089 0 0.382683432365089 -0.923879532511287 -1 0 0
+1 0 4.60418890660018 8.38511328586726 0 -0.453990499739548 -0.891006524188367 0 -0.891006524188367 0.453990499739548 -1 -0 0
+1 0 -4.07504979349569 0.87945511672048 0 0.99144486137381 -0.130526192220053 0 -0.130526192220053 -0.99144486137381 -1 0 -0
+1 0 6.24693941327929 7.24461374203661 0 -0.62932039104984 -0.777145961456969 0 -0.777145961456969 0.62932039104984 -1 -0 0
+1 0 -3.08936908449356 2.79915536931599 0 0.793353340291234 -0.608761429008722 0 -0.608761429008722 -0.793353340291234 -1 0 -0
+1 0 7.61666869145698 5.78748981416527 0 -0.777145961456972 -0.629320391049837 0 -0.629320391049837 0.777145961456972 -1 -0 0
+1 0 -1.2758944241797 3.96882420121404 0 0.38268343236509 -0.923879532511287 0 -0.923879532511287 -0.38268343236509 -1 0 -0
+1 0 8.6535129989866 4.07742480995759 0 -0.891006524188372 -0.453990499739538 0 -0.453990499739538 0.891006524188372 -1 -0 0
+1 0 0.879455116720486 4.07504979349569 0 -0.130526192220054 -0.99144486137381 0 -0.99144486137381 0.130526192220054 -1 -0 0
+1 0 9.31215726429811 2.18915677589975 0 -0.965925826289069 -0.25881904510252 0 -0.25881904510252 0.965925826289069 -1 -0 0
+1 0 2.79915536931599 3.08936908449356 0 -0.608761429008721 -0.793353340291235 0 -0.793353340291235 0.608761429008721 -1 -0 0
+1 0 9.56381557247154 0.205212085995401 0 -0.998629534754574 -0.0523359562429416 0 -0.0523359562429416 0.998629534754574 -1 -0 0
+1 0 3.96882420121404 1.2758944241797 0 -0.923879532511287 -0.382683432365089 0 -0.382683432365089 0.923879532511287 -1 -0 0
+1 0 9.39748924784919 -1.78770135678379 0 -0.987688340595138 0.156434465040228 0 0.156434465040228 0.987688340595138 -1 0 0
+1 0 4.07504979349569 -0.879455116720479 0 -0.99144486137381 0.130526192220052 0 0.130526192220052 0.99144486137381 -1 0 0
+1 0 8.8204475489393 -3.70248367192868 0 -0.933580426497202 0.3583679495453 0 0.3583679495453 0.933580426497202 -1 0 0
+1 0 3.08936908449356 -2.79915536931599 0 -0.793353340291236 0.60876142900872 0 0.60876142900872 0.793353340291236 -1 0 0
+1 0 7.85790996693753 -5.45544968412244 0 -0.838670567945425 0.544639035015025 0 0.544639035015025 0.838670567945425 -1 0 0
+1 0 1.2758944241797 -3.96882420121404 0 -0.38268343236509 0.923879532511287 0 0.923879532511287 0.38268343236509 -1 0 0
+1 0 6.55194401294509 -6.96998636696807 0 -0.707106781186551 0.707106781186545 0 0.707106781186545 0.707106781186551 -1 0 0
+1 0 -0.879455116720479 -4.07504979349569 0 0.130526192220052 0.99144486137381 0 0.99144486137381 -0.130526192220052 -1 0 0
+1 0 4.9596266658714 -8.17990119987186 0 -0.544639035015028 0.838670567945423 0 0.838670567945423 0.544639035015028 -1 0 0
+1 0 -1.20377885748233 9.48997348609396 0 0.156434465040233 -0.987688340595137 0 -0.987688340595137 -0.156434465040233 -1 0 -0
+1 0 3.15054983456993 -9.03231509882041 0 -0.3583679495453 0.933580426497202 0 0.933580426497202 0.3583679495453 -1 0 0
+1 0 -3.15054983456992 9.03231509882041 0 0.358367949545297 -0.933580426497203 0 -0.933580426497203 -0.358367949545297 -1 0 -0
+1 0 1.20377885748234 -9.48997348609396 0 -0.156434465040233 0.987688340595138 0 0.987688340595138 0.156434465040233 -1 0 0
+1 0 -4.95962666587139 8.17990119987187 0 0.544639035015026 -0.838670567945425 0 -0.838670567945425 -0.544639035015026 -1 0 -0
+1 0 -0.795603032049074 -9.53287449408006 0 0.0523359562429411 0.998629534754574 0 0.998629534754574 -0.0523359562429411 -1 0 0
+1 0 -6.55194401294508 6.96998636696808 0 0.707106781186548 -0.707106781186547 0 -0.707106781186547 -0.707106781186548 -1 0 -0
+1 0 -2.76021325135302 -9.15914314286784 0 0.258819045102518 0.965925826289069 0 0.965925826289069 -0.258819045102518 -1 0 0
+1 0 -7.85790996693752 5.45544968412246 0 0.838670567885385 -0.544639035107479 0 -0.544639035107479 -0.838670567885385 -1 0 -0
+1 0 -4.60418890660016 -8.38511328586728 0 0.453990499739544 0.891006524188369 0 0.891006524188369 -0.453990499739544 -1 0 0
+1 0 -8.8204475489393 3.70248367192868 0 0.933580426497202 -0.358367949545301 0 -0.358367949545301 -0.933580426497202 -1 0 -0
+1 0 -6.24693941327927 -7.24461374203662 0 0.629320391049838 0.777145961456971 0 0.777145961456971 -0.629320391049838 -1 0 0
+1 0 -9.39748924784919 1.78770135678379 0 0.987688340595137 -0.156434465040234 0 -0.156434465040234 -0.987688340595137 -1 0 -0
+1 0 -7.61666869145698 -5.78748981416528 0 0.777145961456973 0.629320391049835 0 0.629320391049835 -0.777145961456973 -1 0 0
+1 0 -9.56381557247154 -0.205212085995403 0 0.998629534754574 0.0523359562429418 0 0.0523359562429418 -0.998629534754574 -1 0 0
+1 0 -8.65351299898661 -4.07742480995759 0 0.891006524188368 0.453990499739546 0 0.453990499739546 -0.891006524188368 -1 0 0
+1 0 -9.3121572642981 -2.18915677589976 0 0.965925826289069 0.258819045102517 0 0.258819045102517 -0.965925826289069 -1 0 0
+1 0 0 33.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 0.990000000223517 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+2 0 0 0 0 0 -1 1 0 0 -0 1 -0 11.5
+1 0 0 1.99000000022352 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 32.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 2.99000000022352 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 31.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 3.99000000022352 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 30.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 5.99000000022352 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 28.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 6.99000000022352 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 27.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 7.99000000022352 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 26.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 8.99000000022352 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 25.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 10.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 23.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 11.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 22.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 12.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 21.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 13.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 20.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 15.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 18.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 16.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 0 0 17.9900000002235 0 0 -1 -0.996194698313003 -0.0871557402186753 -0 0.0871557402186753 -0.996194698313003 -0
+1 -8.5 -0.654700538379252 29.5882886069775 0 0.866025403784438 0.500000000000001 0 -0.500000000000001 0.866025403784438 1 0 -0
+1 -8.5 -1.36602540378444 28.3562377994086 0 0.866025403784438 -0.500000000000001 0 0.500000000000001 0.866025403784438 1 -0 0
+2 -8.5 -0.5 31.3203394145464 1 0 0 0 -1 0 0 0 -1 1
+2 -8.5 -0.5 27.8562377994086 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 1.36602540378444 30.0882886069775 0 0.866025403784438 0.500000000000001 0 -0.500000000000001 0.866025403784438 1 0 -0
+1 -8.5 -1.36602540378444 27.3562377994086 0 -0.866025403784438 -0.500000000000001 0 0.500000000000001 -0.866025403784438 1 0 0
+2 -8.5 0.5 29.5882886069775 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 24.8921361842709 0 0.866025403784438 -0.500000000000001 0 0.500000000000001 0.866025403784438 1 -0 0
+1 -8.5 0.654700538379251 27.8562377994086 0 0.866025403784438 -0.500000000000001 0 0.500000000000001 0.866025403784438 1 -0 0
+2 -8.5 -0.5 24.3921361842709 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 0.654700538379251 27.8562377994086 0 -0.866025403784438 -0.500000000000001 0 0.500000000000001 -0.866025403784438 1 0 0
+1 -8.5 -0.654700538379252 22.660085376702 0 0.866025403784438 0.500000000000001 0 -0.500000000000001 0.866025403784438 1 0 -0
+2 -8.5 0.5 26.1241869918398 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 21.4280345691331 0 0.866025403784439 -0.5 0 0.5 0.866025403784439 1 -0 0
+1 -8.5 0.654700538379252 24.3921361842709 0 0.866025403784438 -0.500000000000001 0 0.500000000000001 0.866025403784438 1 -0 0
+2 -8.5 -0.5 20.9280345691331 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 1.36602540378444 23.160085376702 0 0.866025403784438 0.500000000000001 0 -0.500000000000001 0.866025403784438 1 0 -0
+1 -8.5 -0.654700538379252 19.1959837615642 0 0.866025403784439 0.5 0 -0.5 0.866025403784439 1 0 -0
+2 -8.5 0.5 22.660085376702 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 17.9639329539954 0 0.866025403784439 -0.5 0 0.5 0.866025403784439 1 -0 0
+1 -8.5 0.654700538379252 20.9280345691331 0 0.866025403784439 -0.5 0 0.5 0.866025403784439 1 -0 0
+2 -8.5 -0.5 17.4639329539954 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 1.36602540378444 19.6959837615642 0 0.866025403784439 0.5 0 -0.5 0.866025403784439 1 0 -0
+1 -8.5 -0.654700538379252 15.7318821464265 0 0.866025403784439 0.5 0 -0.5 0.866025403784439 1 0 -0
+2 -8.5 0.5 19.1959837615642 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 14.4998313388576 0 0.866025403784439 -0.5 0 0.5 0.866025403784439 1 -0 0
+1 -8.5 0.654700538379252 17.4639329539954 0 0.866025403784439 -0.5 0 0.5 0.866025403784439 1 -0 0
+2 -8.5 -0.5 13.9998313388576 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 1.36602540378444 16.2318821464265 0 0.866025403784439 0.5 0 -0.5 0.866025403784439 1 0 -0
+1 -8.5 -0.654700538379252 12.2677805312887 0 0.866025403784439 0.5 0 -0.5 0.866025403784439 1 0 -0
+2 -8.5 0.5 15.7318821464265 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 11.0357297237199 0 0.866025403784439 -0.5 0 0.5 0.866025403784439 1 -0 0
+1 -8.5 0.654700538379252 13.9998313388576 0 0.866025403784439 -0.5 0 0.5 0.866025403784439 1 -0 0
+2 -8.5 -0.5 10.5357297237199 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 1.36602540378444 12.7677805312887 0 0.866025403784439 0.5 0 -0.5 0.866025403784439 1 0 -0
+1 -8.5 -0.654700538379252 8.80367891615099 0 0.866025403784439 0.5 0 -0.5 0.866025403784439 1 0 -0
+2 -8.5 0.5 12.2677805312887 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 7.57162810858211 0 0.866025403784439 -0.5 0 0.5 0.866025403784439 1 -0 0
+1 -8.5 0.654700538379252 10.5357297237199 0 0.866025403784439 -0.5 0 0.5 0.866025403784439 1 -0 0
+2 -8.5 -0.5 7.07162810858211 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 1.36602540378444 9.30367891615099 0 0.866025403784439 0.5 0 -0.5 0.866025403784439 1 0 -0
+1 -8.5 -0.654700538379252 5.33957730101323 0 0.866025403784439 0.5 0 -0.5 0.866025403784439 1 0 -0
+2 -8.5 0.5 8.80367891615099 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 -1.36602540378444 4.10752649344435 0 0.866025403784439 -0.5 0 0.5 0.866025403784439 1 -0 0
+1 -8.5 0.654700538379253 7.07162810858211 0 0.866025403784439 -0.5 0 0.5 0.866025403784439 1 -0 0
+2 -8.5 -0.5 3.60752649344435 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 1.36602540378444 5.83957730101323 0 0.866025403784439 0.5 0 -0.5 0.866025403784439 1 0 -0
+1 -8.5 -0.366025403784439 1.37547568587548 0 0.866025403784439 0.5 0 -0.5 0.866025403784439 1 0 -0
+2 -8.5 0.5 5.33957730101323 1 0 0 0 -1 0 0 0 -1 1
+2 -8.5 0.5 1.87547568587548 1 0 0 0 -1 0 0 0 -1 1
+1 -8.5 0.654700538379251 3.60752649344435 0 0.866025403784439 -0.5 0 0.5 0.866025403784439 1 -0 0
+1 -8.5 1.36602540378444 2.37547568587548 0 0.866025403784439 0.5 0 -0.5 0.866025403784439 1 0 -0
+1 8.5 -0.654700538379252 29.5882886069775 0 -0.866025403784438 -0.500000000000001 0 -0.500000000000001 0.866025403784438 -1 -0 0
+2 8.5 -0.5 31.3203394145464 -1 0 0 0 -1 0 -0 -0 -1 1
+1 8.5 -1.36602540378444 28.3562377994086 0 -0.866025403784438 0.500000000000001 0 0.500000000000001 0.866025403784438 -1 0 0
+1 8.5 1.36602540378444 30.0882886069775 0 -0.866025403784438 -0.500000000000001 0 -0.500000000000001 0.866025403784438 -1 -0 0
+2 8.5 -0.5 27.8562377994086 -1 0 0 0 -1 0 -0 -0 -1 1
+2 8.5 0.5 29.5882886069775 -1 0 0 0 -1 0 -0 -0 -1 1
+1 8.5 -1.36602540378444 27.3562377994086 0 0.866025403784438 0.500000000000001 0 0.500000000000001 -0.866025403784438 -1 0 0
+1 8.5 0.654700538379251 27.8562377994086 0 -0.866025403784438 0.500000000000001 0 0.500000000000001 0.866025403784438 -1 0 0
+1 8.5 -1.36602540378444 24.8921361842709 0 -0.866025403784438 0.500000000000001 0 0.500000000000001 0.866025403784438 -1 0 0
+1 8.5 0.654700538379251 27.8562377994086 0 0.866025403784438 0.500000000000001 0 0.500000000000001 -0.866025403784438 -1 0 0
+2 8.5 -0.5 24.3921361842709 -1 0 0 0 -1 0 -0 -0 -1 1
+2 8.5 0.5 26.1241869918398 -1 0 0 0 -1 0 -0 -0 -1 1
+1 8.5 -0.654700538379252 22.660085376702 0 -0.866025403784438 -0.500000000000001 0 -0.500000000000001 0.866025403784438 -1 -0 0
+1 8.5 0.654700538379252 24.3921361842709 0 -0.866025403784438 0.500000000000001 0 0.500000000000001 0.866025403784438 -1 0 0
+1 8.5 -1.36602540378444 21.4280345691331 0 -0.866025403784439 0.5 0 0.5 0.866025403784439 -1 0 0
+1 8.5 1.36602540378444 23.160085376702 0 -0.866025403784438 -0.500000000000001 0 -0.500000000000001 0.866025403784438 -1 -0 0
+2 8.5 -0.5 20.9280345691331 -1 0 0 0 -1 0 -0 -0 -1 1
+2 8.5 0.5 22.660085376702 -1 0 0 0 -1 0 -0 -0 -1 1
+1 8.5 -0.654700538379252 19.1959837615642 0 -0.866025403784439 -0.5 0 -0.5 0.866025403784439 -1 -0 0
+1 8.5 0.654700538379252 20.9280345691331 0 -0.866025403784439 0.5 0 0.5 0.866025403784439 -1 0 0
+1 8.5 -1.36602540378444 17.9639329539954 0 -0.866025403784439 0.5 0 0.5 0.866025403784439 -1 0 0
+1 8.5 1.36602540378444 19.6959837615642 0 -0.866025403784439 -0.5 0 -0.5 0.866025403784439 -1 -0 0
+2 8.5 -0.5 17.4639329539954 -1 0 0 0 -1 0 -0 -0 -1 1
+2 8.5 0.5 19.1959837615642 -1 0 0 0 -1 0 -0 -0 -1 1
+1 8.5 -0.654700538379252 15.7318821464265 0 -0.866025403784439 -0.5 0 -0.5 0.866025403784439 -1 -0 0
+1 8.5 0.654700538379252 17.4639329539954 0 -0.866025403784439 0.5 0 0.5 0.866025403784439 -1 0 0
+1 8.5 -1.36602540378444 14.4998313388576 0 -0.866025403784439 0.5 0 0.5 0.866025403784439 -1 0 0
+1 8.5 1.36602540378444 16.2318821464265 0 -0.866025403784439 -0.5 0 -0.5 0.866025403784439 -1 -0 0
+2 8.5 -0.5 13.9998313388576 -1 0 0 0 -1 0 -0 -0 -1 1
+2 8.5 0.5 15.7318821464265 -1 0 0 0 -1 0 -0 -0 -1 1
+1 8.5 -0.654700538379252 12.2677805312887 0 -0.866025403784439 -0.5 0 -0.5 0.866025403784439 -1 -0 0
+1 8.5 0.654700538379252 13.9998313388576 0 -0.866025403784439 0.5 0 0.5 0.866025403784439 -1 0 0
+1 8.5 -1.36602540378444 11.0357297237199 0 -0.866025403784439 0.5 0 0.5 0.866025403784439 -1 0 0
+1 8.5 1.36602540378444 12.7677805312887 0 -0.866025403784439 -0.5 0 -0.5 0.866025403784439 -1 -0 0
+2 8.5 -0.5 10.5357297237199 -1 0 0 0 -1 0 -0 -0 -1 1
+2 8.5 0.5 12.2677805312887 -1 0 0 0 -1 0 -0 -0 -1 1
+1 8.5 -0.654700538379252 8.80367891615099 0 -0.866025403784439 -0.5 0 -0.5 0.866025403784439 -1 -0 0
+1 8.5 0.654700538379252 10.5357297237199 0 -0.866025403784439 0.5 0 0.5 0.866025403784439 -1 0 0
+1 8.5 -1.36602540378444 7.57162810858211 0 -0.866025403784439 0.5 0 0.5 0.866025403784439 -1 0 0
+1 8.5 1.36602540378444 9.30367891615099 0 -0.866025403784439 -0.5 0 -0.5 0.866025403784439 -1 -0 0
+2 8.5 -0.5 7.07162810858211 -1 0 0 0 -1 0 -0 -0 -1 1
+2 8.5 0.5 8.80367891615099 -1 0 0 0 -1 0 -0 -0 -1 1
+1 8.5 -0.654700538379252 5.33957730101323 0 -0.866025403784439 -0.5 0 -0.5 0.866025403784439 -1 -0 0
+1 8.5 0.654700538379253 7.07162810858211 0 -0.866025403784439 0.5 0 0.5 0.866025403784439 -1 0 0
+1 8.5 -1.36602540378444 4.10752649344435 0 -0.866025403784439 0.5 0 0.5 0.866025403784439 -1 0 0
+1 8.5 1.36602540378444 5.83957730101323 0 -0.866025403784439 -0.5 0 -0.5 0.866025403784439 -1 -0 0
+2 8.5 -0.5 3.60752649344435 -1 0 0 0 -1 0 -0 -0 -1 1
+2 8.5 0.5 5.33957730101323 -1 0 0 0 -1 0 -0 -0 -1 1
+1 8.5 -0.366025403784439 1.37547568587548 0 -0.866025403784439 -0.5 0 -0.5 0.866025403784439 -1 -0 0
+1 8.5 0.654700538379251 3.60752649344435 0 -0.866025403784439 0.5 0 0.5 0.866025403784439 -1 0 0
+2 8.5 0.5 1.87547568587548 -1 0 0 0 -1 0 -0 -0 -1 1
+1 8.5 1.36602540378444 2.37547568587548 0 -0.866025403784439 -0.5 0 -0.5 0.866025403784439 -1 -0 0
+1 0 0 37 0 0 1 1 0 -0 -0 1 0
+1 13 0 0.166666666666667 -1.11022302462516e-16 0 1 0.984807759068988 -0.173648143317221 1.09335624894789e-16 0.173648143317221 0.984807759068988 1.92788166894188e-17
+1 -5.86749458312988 11 -3.5 0 1 0 1 0 0 0 0 -1
+2 0 0 0 0 0 1 1 0 -0 -0 1 0 8.5
+1 5 20 5.91961097717285 1 0 0 0 0 -1 -0 1 0
+1 5 20 4.10471725463867 0 0 -1 -1 0 0 0 1 0
+1 -5 20 5.91961097717285 0 0 1 1 0 -0 -0 1 0
+1 -5 20 4.10471725463867 -1 0 0 0 0 1 0 1 -0
+1 5 20 30.9196109771729 1 0 0 0 0 -1 -0 1 0
+1 5 20 29.1047172546387 0 0 -1 -1 0 0 0 1 0
+1 -5 20 30.9196109771729 0 0 1 1 0 -0 -0 1 0
+1 -5 20 29.1047172546387 -1 0 0 0 0 1 0 1 -0
+1 5 20 10.9196109771729 1 0 0 0 0 -1 -0 1 0
+1 5 20 9.10471725463867 0 0 -1 -1 0 0 0 1 0
+1 -5 20 10.9196109771729 0 0 1 1 0 -0 -0 1 0
+1 -5 20 9.10471725463867 -1 0 0 0 0 1 0 1 -0
+1 5 20 25.9196109771729 1 0 0 0 0 -1 -0 1 0
+1 5 20 24.1047172546387 0 0 -1 -1 0 0 0 1 0
+1 -5 20 25.9196109771729 0 0 1 1 0 -0 -0 1 0
+1 -5 20 24.1047172546387 -1 0 0 0 0 1 0 1 -0
+1 5 20 15.9196109771729 1 0 0 0 0 -1 -0 1 0
+1 5 20 14.1047172546387 0 0 -1 -1 0 0 0 1 0
+1 -5 20 15.9196109771729 0 0 1 1 0 -0 -0 1 0
+1 -5 20 14.1047172546387 -1 0 0 0 0 1 0 1 -0
+1 5 20 20.9196109771729 1 0 0 0 0 -1 -0 1 0
+1 5 20 19.1047172546387 0 0 -1 -1 0 0 0 1 0
+1 -5 20 20.9196109771729 0 0 1 1 0 -0 -0 1 0
+1 -5 20 19.1047172546387 -1 0 0 0 0 1 0 1 -0
+1 -5.86749458312988 -11 -3.5 0 1 0 1 0 0 0 0 -1
+1 5 -20 5.91705513000488 -1 0 0 0 0 -1 -0 -1 -0
+1 5 -20 4.05049705505371 0 0 1 -1 0 0 0 -1 0
+1 -5 -20 5.91705513000488 0 0 -1 1 0 0 0 -1 0
+1 -5 -20 4.05049705505371 1 0 0 0 0 1 0 -1 0
+1 5 -20 30.9170551300049 -1 0 0 0 0 -1 -0 -1 -0
+1 5 -20 29.0504970550537 0 0 1 -1 0 0 0 -1 0
+1 -5 -20 30.9170551300049 0 0 -1 1 0 0 0 -1 0
+1 -5 -20 29.0504970550537 1 0 0 0 0 1 0 -1 0
+1 5 -20 10.9170551300049 -1 0 0 0 0 -1 -0 -1 -0
+1 5 -20 9.05049705505371 0 0 1 -1 0 0 0 -1 0
+1 -5 -20 10.9170551300049 0 0 -1 1 0 0 0 -1 0
+1 -5 -20 9.05049705505371 1 0 0 0 0 1 0 -1 0
+1 5 -20 25.9170551300049 -1 0 0 0 0 -1 -0 -1 -0
+1 5 -20 24.0504970550537 0 0 1 -1 0 0 0 -1 0
+1 -5 -20 25.9170551300049 0 0 -1 1 0 0 0 -1 0
+1 -5 -20 24.0504970550537 1 0 0 0 0 1 0 -1 0
+1 5 -20 15.9170551300049 -1 0 0 0 0 -1 -0 -1 -0
+1 5 -20 14.0504970550537 0 0 1 -1 0 0 0 -1 0
+1 -5 -20 15.9170551300049 0 0 -1 1 0 0 0 -1 0
+1 -5 -20 14.0504970550537 1 0 0 0 0 1 0 -1 0
+1 5 -20 20.9170551300049 -1 0 0 0 0 -1 -0 -1 -0
+1 5 -20 19.0504970550537 0 0 1 -1 0 0 0 -1 0
+1 -5 -20 20.9170551300049 0 0 -1 1 0 0 0 -1 0
+1 -5 -20 19.0504970550537 1 0 0 0 0 1 0 -1 0
+1 0 0 34 0 0 1 1 0 -0 -0 1 0
+2 0 0 37 0 0 -1 1 0 0 -0 1 -0 4.5
+2 0 0 36.5 0 0 -1 1 0 0 -0 1 -0 4.5
+2 0 0 36 0 0 -1 1 0 0 -0 1 -0 4.5
+2 0 0 37 0 0 -1 1 0 0 -0 1 -0 7.75
+2 0 0 36.5 0 0 -1 1 0 0 -0 1 -0 7.75
+2 0 0 36 0 0 -1 1 0 0 -0 1 -0 7.75
+2 0 0 36 0 0 -1 1 0 0 0 -1 0 4.5
+2 0 0 36 0 0 -1 1 0 0 0 -1 0 7.75
+3 0 0 -3 0 0 -1 1 0 0 -0 1 -0 8.5
+-0.785398163397449
+1 -10 0 17 -1 0 0 0 -1 0 -0 -0 -1
+1 10 0 17 1 0 0 0 -1 0 0 0 -1
+1 -2.06109145955419 4.00023774235392 36 -0.888941720523094 -0.458020324345375 0 -0.458020324345375 0.888941720523094 0 -0 0 -1
+1 2.05294383083092 4.0044252555708 36 -0.889872279015733 0.456209740184649 0 0.456209740184649 0.889872279015733 0 0 0 -1
+1 -2.06109145955419 -4.00023774235392 36 0.888941720523094 -0.458020324345375 0 -0.458020324345375 -0.888941720523094 0 0 -0 -1
+1 2.05294383083092 -4.0044252555708 36 0.889872279015733 0.456209740184649 0 0.456209740184649 -0.889872279015733 0 0 0 -1
+2 13 0 0.166666666666667 -1.11022302462516e-16 0 1 0.984807759068988 -0.173648143317221 1.09335624894789e-16 0.173648143317221 0.984807759068988 1.92788166894188e-17 2
+1 0 20 0 0 -1 0 1 0 0 -0 0 1
+1 0 -20 0 0 -1 0 1 0 0 -0 0 1
+3 0 0 56 0 0 1 1 0 -0 -0 1 0 1.5
+-0.785398163397449
+1 0 0 -3.5 0 0 1 1 0 -0 -0 1 0
+3 0 0 -7 0 0 -1 1 0 0 -0 1 -0 1.5
+-0.785398163397449
+2 0 1.90744535234441 -1.725 -1 0 0 0 -0.981217359419556 0.192905400582032 -0 -0.192905400582032 -0.981217359419556 1.94395801708275
+2 0 0 0 -1 0 0 0 0 1 -0 -1 0 1.35
+2 0 -2.46699832966526 -0.726561775494072 -1 0 0 0 0.579396446870187 -0.815045862117097 0 0.815045862117097 0.579396446870187 1.94395801708275
+2 0 -0.15938658246777 -2.5668207357565 -1 0 0 0 -0.46095950169171 0.887421172724727 -0 -0.887421172724727 -0.46095950169171 1.94395801708275
+2 0 -2.10619716978796 1.47577310388742 -1 0 0 -0 -0.275980738801696 -0.961163166070397 -0 0.961163166070397 -0.275980738801696 1.94395801708275
+2 0 -2.10619716978795 -1.4757731038874 -1 0 0 0 0.406410262670229 0.913690701712738 -0 -0.913690701712738 0.406410262670229 1.94395801708273
+2 0 -0.15938658246777 2.5668207357565 -1 0 0 -0 -0.92353879917478 -0.383505001817193 -0 0.383505001817193 -0.92353879917478 1.94395801708275
+2 0 -2.46699832966526 0.726561775494073 -1 0 0 0 0.967744809982941 0.251932496417358 -0 -0.251932496417358 0.967744809982941 1.94395801708275
+2 0 1.90744535234441 1.725 -1 0 0 0 -0.875653307010976 0.482940250880728 -0 -0.482940250880728 -0.875653307010976 1.94395801708275
+2 0 -0.970099429709683 2.38178081876927 -1 0 0 0 0.800347776981936 -0.59953601716667 0 0.59953601716667 0.800347776981936 1.94395801708275
+2 0 2.53793203204693 -0.415780919343873 -1 0 0 0 -0.168383014595658 0.985721644479657 -0 -0.985721644479657 -0.168383014595658 1.94395801708275
+2 0 1.25730412723934 2.2434703260367 -1 0 0 0 0.030272543794149 -0.9995416815182 0 0.9995416815182 0.030272543794149 1.94395801708275
+2 0 1.25730412723934 -2.2434703260367 -1 0 0 0 0.665683122197733 0.746234534728244 -0 -0.746234534728244 0.665683122197733 1.94395801708275
+2 0 2.53793203204693 0.415780919343874 -1 0 0 -0 -0.762598532317987 -0.646872072751987 -0 0.646872072751987 -0.762598532317987 1.94395801708276
+2 0 -0.970099429709683 -2.38178081876927 -1 0 0 0 0.998476290515191 -0.055182400083943 0 0.055182400083943 0.998476290515191 1.94395801708275
+1 0 -1.95470723521056 -1.82130311288263 0 0.623489801858733 0.78183148246803 0 0.78183148246803 -0.623489801858733 -1 0 0
+1 0 -2.64269213954193 0.392687738519768 0 1 -5.65448276439762e-16 0 -5.65448276439762e-16 -1 -1 0 -0
+1 0 -1.3406759617027 2.31097671344672 0 0.623489801858733 -0.78183148246803 0 -0.78183148246803 -0.623489801858733 -1 0 -0
+1 0 0.970896560104362 2.48905308781432 0 -0.222520933956314 -0.974927912181824 0 -0.974927912181824 0.222520933956314 -1 -0 0
+1 0 2.55136416947229 0.792821719627716 0 -0.900968867902419 -0.433883739117558 0 -0.433883739117558 0.900968867902419 -1 -0 0
+1 0 2.21060252088314 -1.50042057405435 0 -0.900968867902419 0.433883739117558 0 0.433883739117558 0.900968867902419 -1 0 0
+1 0 0.205212085995401 -2.66381557247155 0 -0.222520933956314 0.974927912181824 0 0.974927912181824 0.222520933956314 -1 0 0
+Triangulations 0
+TShapes 4576
+Ve
+1e-07
+25.9999998448251 -4.25474520993063e-06 -6.5
+0 0
+0101101
+Ve
+1e-07
+25.9999998448251 -4.25474520993063e-06 -13.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1 0 0 6.75
+3 1 2CN 1 0 0 6.75
+0
+0101000
+-4576 0 +4575 0 *
+Ed
+ 1e-07 1 1 0
+1 2 0 0 6.28318530717959
+2 3 2 0 0 6.28318530717959
+2 4 1 0 0 6.28318530717959
+4 C0 2 0 1 0
+0
+0101100
++4576 0 -4576 0 *
+Ed
+ 1e-07 1 1 0
+1 3 0 0 6.28318530717959
+2 5 1 0 0 6.28318530717959
+2 6 1 2 0 6.28318530717959
+4 CN 3 3 3 3
+0
+0101100
++4575 0 -4575 0 *
+Wi
+0101100
++4574 0 +4573 0 -4572 0 -4574 0 *
+Fa
+0 1e-07 1 0
+0101000
++4571 0 *
+Ve
+1e-07
+25.7499998448251 -4.25474520993063e-06 -6.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 4 0 0 0.353553390593274
+3 7 8C0 2 0 0 0.353553390593274
+0
+0101000
++4576 0 -4569 0 *
+Ed
+ 1e-07 1 1 0
+1 5 0 0 6.28318530717959
+2 9 2 0 0 6.28318530717959
+2 10 4 1 0 6.28318530717959
+4 C0 2 0 4 1
+0
+0101100
++4569 0 -4569 0 *
+Wi
+0101100
+-4568 0 +4573 0 -4567 0 +4568 0 *
+Fa
+0 0 2 0
+0101000
++4566 0 *
+Wi
+0101100
++4567 0 *
+Fa
+0 1e-07 4 0
+0101000
++4564 2 *
+Ve
+1e-07
+29.9999998448251 -4.25474520993063e-06 -16.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 6 0 0 6.28318530717959
+2 11 5 0 0 6.28318530717959
+2 12 5 4 0 6.28318530717959
+4 CN 6 5 6 5
+0
+0101100
++4562 0 -4562 0 *
+Wi
+0101100
++4561 0 *
+Wi
+0101100
++4572 0 *
+Fa
+0 1e-07 3 0
+0101000
++4560 0 -4559 4 *
+Ed
+ 1e-07 1 1 0
+1 7 0 0 3
+3 13 14CN 5 0 0 3
+0
+0101000
++4562 0 -4562 3 *
+Wi
+0101000
++4557 0 -4557 0 -4561 0 +4561 3 *
+Fa
+0 1e-07 5 0
+0101000
++4556 0 *
+Ve
+1e-07
+37.7499998448251 -4.25474520993063e-06 -16.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 8 0 0 6.28318530717959
+2 15 7 0 0 6.28318530717959
+2 16 6 5 0 6.28318530717959
+4 G1 7 0 6 5
+0
+0101100
++4554 0 -4554 0 *
+Wi
+0101100
++4553 0 *
+Ve
+1e-07
+25.9999998448251 7.99999574525479 -16.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 9 0 0 6.28318530717959
+2 17 8 0 0 6.28318530717959
+2 18 8 8 0 6.28318530717959
+4 CN 6 5 6 5
+0
+0101100
++4551 0 -4551 0 *
+Wi
+0101100
++4550 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 10 0 0 6.28318530717959
+2 19 9 10 0 6.28318530717959
+2 20 9 12 0 6.28318530717959
+4 CN 6 13 6 13
+0
+0101100
++4548 0 -4548 0 *
+Wi
+0101100
++4547 9 *
+Wi
+0101100
++4561 0 *
+Ve
+1e-07
+29.2521460647203 -9.05092976126831 -16.25
+0 0
+0101101
+Ve
+1e-07
+27.9765021987518 -6.33565210931138 -16.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 11 0 1.13159732727015 4.27318998085994
+2 21 10 0 1.13159732727015 4.27318998085994
+2 22 10 15 1.13159732727015 4.27318998085994
+4 CN 6 5 6 5
+0
+0101000
++4544 0 -4543 0 *
+Ve
+1e-07
+31.3356476993913 -2.97650660867189 -16.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 12 0 0.439198999524751 1.13159732727015
+2 23 11 0 0.439198999524751 1.13159732727015
+2 24 11 15 0.439198999524751 1.13159732727015
+4 CN 6 5 6 5
+0
+0101000
++4541 0 -4543 0 *
+Ve
+1e-07
+34.0509253513482 -4.25215047464047 -16.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 13 0 3.58079165311454 6.72238430670434
+2 25 12 0 3.58079165311454 6.72238430670434
+2 26 12 15 3.58079165311454 6.72238430670434
+4 CN 6 5 6 5
+0
+0101000
++4541 0 -4539 0 *
+Ed
+ 1e-07 1 1 0
+1 14 0 0.439198999524751 1.13159732727015
+2 27 13 0 0.439198999524751 1.13159732727015
+2 28 13 15 0.439198999524751 1.13159732727015
+4 CN 6 5 6 5
+0
+0101000
++4539 0 -4544 0 *
+Wi
+0101100
++4542 0 -4540 0 +4538 0 +4537 0 *
+Ve
+1e-07
+29.2521460647203 9.05092976126831 -16.25
+0 0
+0101101
+Ve
+1e-07
+27.9765021987518 6.33565210931138 -16.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 15 0 1.13159732727015 4.27318998085994
+2 29 14 0 1.13159732727015 4.27318998085994
+2 30 14 17 1.13159732727015 4.27318998085994
+4 CN 6 5 6 5
+0
+0101000
++4535 0 -4534 0 *
+Ve
+1e-07
+31.3356476993913 2.97650660867189 -16.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 16 0 0.439198999524751 1.13159732727015
+2 31 15 0 0.439198999524751 1.13159732727015
+2 32 15 17 0.439198999524751 1.13159732727015
+4 CN 6 5 6 5
+0
+0101000
++4532 0 -4534 0 *
+Ve
+1e-07
+34.0509253513482 4.25215047464047 -16.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 17 0 3.58079165311454 6.72238430670434
+2 33 16 0 3.58079165311454 6.72238430670434
+2 34 16 17 3.58079165311454 6.72238430670434
+4 CN 6 5 6 5
+0
+0101000
++4532 0 -4530 0 *
+Ed
+ 1e-07 1 1 0
+1 18 0 0.439198999524751 1.13159732727015
+2 35 17 0 0.439198999524751 1.13159732727015
+2 36 17 17 0.439198999524751 1.13159732727015
+4 CN 6 5 6 5
+0
+0101000
++4530 0 -4535 0 *
+Wi
+0101100
++4533 0 -4531 0 +4529 0 +4528 0 *
+Ve
+1e-07
+20.7478536249298 -9.05092976126831 -16.25
+0 0
+0101101
+Ve
+1e-07
+22.0234974908984 -6.33565210931138 -16.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 19 0 1.13159732727015 4.27318998085994
+2 37 18 0 1.13159732727015 4.27318998085994
+2 38 18 19 1.13159732727015 4.27318998085994
+0
+0101000
++4526 0 -4525 0 *
+Ve
+1e-07
+15.949074338302 -4.25215047464047 -16.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 20 0 0.439198999524751 1.13159732727015
+2 39 19 0 0.439198999524751 1.13159732727015
+2 40 19 19 0.439198999524751 1.13159732727015
+0
+0101000
++4523 0 -4526 0 *
+Ve
+1e-07
+18.6643519902589 -2.97650660867189 -16.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 21 0 3.58079165311454 6.72238430670434
+2 41 20 0 3.58079165311454 6.72238430670434
+2 42 20 19 3.58079165311454 6.72238430670434
+0
+0101000
++4521 0 -4523 0 *
+Ed
+ 1e-07 1 1 0
+1 22 0 0.439198999524751 1.13159732727015
+2 43 21 0 0.439198999524751 1.13159732727015
+2 44 21 19 0.439198999524751 1.13159732727015
+0
+0101000
++4521 0 -4525 0 *
+Wi
+0101100
+-4524 0 -4522 0 -4520 0 +4519 0 *
+Ve
+1e-07
+15.9490740172739 4.25214128182417 -16.25
+0 0
+0101101
+Ve
+1e-07
+18.6643517655393 2.97649762085335 -16.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 23 0 1.13159732727015 4.27318998085994
+2 45 22 0 1.13159732727015 4.27318998085994
+2 46 22 21 1.13159732727015 4.27318998085994
+0
+0101000
++4517 0 -4516 0 *
+Ve
+1e-07
+20.747852941604 9.05092093074975 -16.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 24 0 0.439198999524751 1.13159732727015
+2 47 23 0 0.439198999524751 1.13159732727015
+2 48 23 21 0.439198999524751 1.13159732727015
+0
+0101000
++4514 0 -4517 0 *
+Ve
+1e-07
+22.0234970125703 6.33564337510126 -16.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 25 0 3.58079165311454 6.72238430670434
+2 49 24 0 3.58079165311454 6.72238430670434
+2 50 24 21 3.58079165311454 6.72238430670434
+0
+0101000
++4512 0 -4514 0 *
+Ed
+ 1e-07 1 1 0
+1 26 0 0.439198999524751 1.13159732727015
+2 51 25 0 0.439198999524751 1.13159732727015
+2 52 25 21 0.439198999524751 1.13159732727015
+0
+0101000
++4512 0 -4516 0 *
+Wi
+0101100
+-4515 0 -4513 0 -4511 0 +4510 0 *
+Ve
+1e-07
+16.4999998448251 -4.25474520993063e-06 -16.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 27 0 0 6.28318530717959
+2 53 26 0 0 6.28318530717959
+2 54 26 23 0 6.28318530717959
+0
+0101100
++4508 0 -4508 0 *
+Wi
+0101000
++4507 0 *
+Fa
+0 1e-07 6 0
+0101000
++4552 6 -4549 6 -4546 6 -4545 6 -4536 6 +4527 6 -4518 6 -4509 6 -4506 6 *
+Ve
+1e-07
+38.7499998448251 -4.25474520993063e-06 -17.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 28 0 4.71238898038469 6.28318530717959
+3 55 56G1 7 0 4.71238898038469 6.28318530717959
+0
+0101000
++4554 0 -4504 0 *
+Ed
+ 1e-07 1 1 0
+1 29 0 0 6.28318530717959
+2 57 7 0 0 6.28318530717959
+2 58 27 0 0 6.28318530717959
+4 G1 7 0 27 0
+0
+0101100
++4504 0 -4504 0 *
+Wi
+0101100
+-4503 0 +4553 0 -4502 0 +4503 0 *
+Fa
+0 0 7 0
+0101000
++4501 0 *
+Ve
+1e-07
+46.7499998448251 -4.25474520993063e-06 -16.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 30 0 1 32
+3 59 60CN 27 0 1 32
+0
+0101000
++4504 0 -4499 25 *
+Ed
+ 1e-07 1 1 0
+1 31 0 0 6.28318530717959
+2 61 27 6 0 6.28318530717959
+2 62 27 26 0 6.28318530717959
+0
+0101100
++4499 0 -4499 0 *
+Wi
+0101100
++4498 0 -4502 0 +4497 25 -4498 0 *
+Fa
+0 1e-07 27 0
+0101000
++4496 0 *
+Wi
+0101100
++4497 0 *
+Ve
+1e-07
+29.9999998448251 -4.25474520993063e-06 -48.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 32 0 0 6.28318530717959
+2 63 28 0 0 6.28318530717959
+2 64 28 28 0 6.28318530717959
+4 CN 6 25 6 25
+0
+0101100
++4493 0 -4493 0 *
+Wi
+0101100
++4492 0 *
+Ve
+1e-07
+25.3456745147705 -12.25 -48.25
+0 0
+0101101
+Ve
+1e-07
+25.3456745147705 -12 -48.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 33 0 -1.21347904205322 -0.963479042053223
+4 CN 6 25 6 25
+0
+0101000
++4490 0 -4489 0 *
+Ve
+1e-07
+22.3456745147705 -12 -48.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 34 0 2.22383117675781 5.22383117675781
+4 CN 6 25 6 25
+0
+0101000
++4489 0 -4487 0 *
+Ve
+1e-07
+22.3456745147705 -12.25 -48.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 35 0 1.63729000091553 1.88729000091553
+4 CN 6 25 6 25
+0
+0101000
++4487 0 -4485 0 *
+Ed
+ 1e-07 1 1 0
+1 36 0 0 3
+4 CN 6 25 6 25
+0
+0101000
++4485 0 -4490 0 *
+Wi
+0101100
++4488 0 +4486 0 +4484 0 +4483 0 *
+Ve
+1e-07
+25.3456745147705 12.25 -48.25
+0 0
+0101101
+Ve
+1e-07
+25.3456745147705 12 -48.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 37 0 -1.21347904205322 -0.963479042053223
+4 CN 6 25 6 25
+0
+0101000
++4481 0 -4480 0 *
+Ve
+1e-07
+22.3456745147705 12 -48.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 38 0 2.22383117675781 5.22383117675781
+4 CN 6 25 6 25
+0
+0101000
++4480 0 -4478 0 *
+Ve
+1e-07
+22.3456745147705 12.25 -48.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 39 0 1.63729000091553 1.88729000091553
+4 CN 6 25 6 25
+0
+0101000
++4478 0 -4476 0 *
+Ed
+ 1e-07 1 1 0
+1 40 0 0 3
+4 CN 6 25 6 25
+0
+0101000
++4476 0 -4481 0 *
+Wi
+0101100
++4479 0 +4477 0 +4475 0 +4474 0 *
+Fa
+0 1e-07 6 0
+0101000
++4494 0 -4491 26 +4482 26 -4473 26 *
+Ed
+ 1e-07 1 1 0
+1 41 0 0 3
+3 65 66CN 28 0 0 3
+0
+0101000
++4493 0 -4493 27 *
+Wi
+0101000
++4471 0 -4471 0 -4492 0 +4492 27 *
+Fa
+0 1e-07 28 0
+0101000
++4470 0 *
+Wi
+0101100
++4492 0 *
+Fa
+0 1e-07 29 0
+0101000
++4468 0 *
+Ed
+ 1e-07 1 1 0
+1 42 0 0 7.5
+0
+0101000
++4490 0 -4490 29 *
+Ed
+ 1e-07 1 1 0
+1 43 0 0 7.5
+0
+0101000
++4489 0 -4489 29 *
+Wi
+0101000
++4466 0 -4465 0 -4488 0 +4488 29 *
+Fa
+0 1e-07 30 0
+0101000
++4464 0 *
+Ed
+ 1e-07 1 1 0
+1 44 0 0 7.5
+0
+0101000
++4485 0 -4485 29 *
+Wi
+0101000
++4462 0 -4466 0 -4483 0 +4483 29 *
+Fa
+0 1e-07 31 0
+0101000
++4461 0 *
+Ed
+ 1e-07 1 1 0
+1 45 0 0 7.5
+0
+0101000
++4487 0 -4487 29 *
+Wi
+0101000
++4459 0 -4462 0 -4484 0 +4484 29 *
+Fa
+0 1e-07 32 0
+0101000
++4458 0 *
+Wi
+0101000
++4465 0 -4459 0 -4486 0 +4486 29 *
+Fa
+0 1e-07 33 0
+0101000
++4456 0 *
+Wi
+0101000
+Fa
+0 1e-07 34 0
+0101000
+-4454 0 *
+Ed
+ 1e-07 1 1 0
+1 46 0 0 7.5
+0
+0101000
++4481 0 -4481 30 *
+Ed
+ 1e-07 1 1 0
+1 47 0 0 7.5
+0
+0101000
++4480 0 -4480 30 *
+Wi
+0101000
++4452 0 -4451 0 -4479 0 +4479 30 *
+Fa
+0 1e-07 35 0
+0101000
++4450 0 *
+Ed
+ 1e-07 1 1 0
+1 48 0 0 7.5
+0
+0101000
++4476 0 -4476 30 *
+Wi
+0101000
++4448 0 -4452 0 -4474 0 +4474 30 *
+Fa
+0 1e-07 36 0
+0101000
++4447 0 *
+Ed
+ 1e-07 1 1 0
+1 49 0 0 7.5
+0
+0101000
++4478 0 -4478 30 *
+Wi
+0101000
++4445 0 -4448 0 -4475 0 +4475 30 *
+Fa
+0 1e-07 37 0
+0101000
++4444 0 *
+Wi
+0101000
++4451 0 -4445 0 -4477 0 +4477 30 *
+Fa
+0 1e-07 38 0
+0101000
++4442 0 *
+Wi
+0101000
+Fa
+0 1e-07 39 0
+0101000
++4440 0 *
+Ed
+ 1e-07 1 1 0
+1 50 0 0 5
+3 67 68CN 8 0 0 5
+0
+0101000
++4551 0 -4551 7 *
+Wi
+0101000
++4438 0 -4438 0 -4550 0 +4550 7 *
+Fa
+0 1e-07 8 0
+0101000
++4437 0 *
+Wi
+0101000
++4550 0 *
+Fa
+0 1e-07 40 0
+0101000
++4435 0 *
+Ed
+ 1e-07 1 1 0
+1 51 0 0 5
+3 69 70CN 9 0 0 5
+0
+0101000
++4548 9 -4548 31 *
+Wi
+0101000
++4433 0 -4433 0 -4547 9 +4547 31 *
+Fa
+0 1e-07 9 0
+0101000
++4432 0 *
+Wi
+0101000
++4547 0 *
+Fa
+0 1e-07 41 0
+0101000
++4430 9 *
+Ed
+ 1e-07 1 1 0
+1 52 0 0 10
+2 71 10 0 0 10
+2 72 13 0 0 10
+4 G1 10 0 13 0
+0
+0101000
++4544 0 -4544 14 *
+Ed
+ 1e-07 1 1 0
+1 53 0 0 10
+2 73 10 0 0 10
+2 74 11 0 0 10
+4 G1 10 0 11 0
+0
+0101000
++4543 0 -4543 14 *
+Wi
+0101000
++4428 0 -4427 0 -4542 0 +4542 14 *
+Fa
+0 1e-07 10 0
+0101000
++4426 0 *
+Ed
+ 1e-07 1 1 0
+1 54 0 0 10
+2 75 13 0 0 10
+2 76 12 0 0 10
+4 G1 13 0 12 0
+0
+0101000
++4539 0 -4539 14 *
+Wi
+0101000
++4424 0 -4428 0 -4537 0 +4537 14 *
+Fa
+0 1e-07 13 0
+0101000
++4423 0 *
+Ed
+ 1e-07 1 1 0
+1 55 0 0 10
+2 77 12 0 0 10
+2 78 11 0 0 10
+4 G1 12 0 11 0
+0
+0101000
++4541 0 -4541 14 *
+Wi
+0101000
++4421 0 -4424 0 -4538 0 +4538 14 *
+Fa
+0 1e-07 12 0
+0101000
++4420 0 *
+Wi
+0101000
++4421 0 -4427 0 -4540 0 +4540 14 *
+Fa
+0 1e-07 11 0
+0101000
++4418 0 *
+Wi
+0101100
+-4542 0 -4537 0 -4538 0 +4540 0 *
+Fa
+0 1e-07 42 0
+0101000
+-4416 0 *
+Ed
+ 1e-07 1 1 0
+1 56 0 0 10
+2 79 14 0 0 10
+2 80 17 0 0 10
+4 G1 14 0 17 0
+0
+0101000
++4535 0 -4535 16 *
+Ed
+ 1e-07 1 1 0
+1 57 0 0 10
+2 81 14 0 0 10
+2 82 15 0 0 10
+4 G1 14 0 15 0
+0
+0101000
++4534 0 -4534 16 *
+Wi
+0101000
++4414 0 -4413 0 -4533 0 +4533 16 *
+Fa
+0 1e-07 14 0
+0101000
++4412 0 *
+Ed
+ 1e-07 1 1 0
+1 58 0 0 10
+2 83 17 0 0 10
+2 84 16 0 0 10
+4 G1 17 0 16 0
+0
+0101000
++4530 0 -4530 16 *
+Wi
+0101000
++4410 0 -4414 0 -4528 0 +4528 16 *
+Fa
+0 1e-07 17 0
+0101000
++4409 0 *
+Ed
+ 1e-07 1 1 0
+1 59 0 0 10
+2 85 16 0 0 10
+2 86 15 0 0 10
+4 G1 16 0 15 0
+0
+0101000
++4532 0 -4532 16 *
+Wi
+0101000
++4407 0 -4410 0 -4529 0 +4529 16 *
+Fa
+0 1e-07 16 0
+0101000
++4406 0 *
+Wi
+0101000
++4407 0 -4413 0 -4531 0 +4531 16 *
+Fa
+0 1e-07 15 0
+0101000
++4404 0 *
+Wi
+0101100
+-4533 0 -4528 0 -4529 0 +4531 0 *
+Fa
+0 1e-07 43 0
+0101000
++4402 0 *
+Ed
+ 1e-07 1 1 0
+1 60 0 0 10
+2 87 18 0 0 10
+2 88 19 0 0 10
+4 G1 18 0 19 0
+0
+0101000
++4526 0 -4526 18 *
+Ed
+ 1e-07 1 1 0
+1 61 0 0 10
+2 89 18 0 0 10
+2 90 21 0 0 10
+4 G1 18 0 21 0
+0
+0101000
++4525 0 -4525 18 *
+Wi
+0101000
++4400 0 -4399 0 -4524 0 +4524 18 *
+Fa
+0 1e-07 18 0
+0101000
++4398 0 *
+Ed
+ 1e-07 1 1 0
+1 62 0 0 10
+2 91 19 0 0 10
+2 92 20 0 0 10
+4 G1 19 0 20 0
+0
+0101000
++4523 0 -4523 18 *
+Wi
+0101000
++4396 0 -4400 0 -4522 0 +4522 18 *
+Fa
+0 1e-07 19 0
+0101000
++4395 0 *
+Ed
+ 1e-07 1 1 0
+1 63 0 0 10
+2 93 20 0 0 10
+2 94 21 0 0 10
+4 G1 20 0 21 0
+0
+0101000
++4521 0 -4521 18 *
+Wi
+0101000
++4393 0 -4396 0 -4520 0 +4520 18 *
+Fa
+0 1e-07 20 0
+0101000
++4392 0 *
+Wi
+0101000
++4393 0 -4399 0 -4519 0 +4519 18 *
+Fa
+0 1e-07 21 0
+0101000
++4390 0 *
+Fa
+0 1e-07 44 0
+0101000
++4518 0 *
+Ed
+ 1e-07 1 1 0
+1 64 0 0 10
+2 95 22 0 0 10
+2 96 23 0 0 10
+4 G1 22 0 23 0
+0
+0101000
++4517 0 -4517 20 *
+Ed
+ 1e-07 1 1 0
+1 65 0 0 10
+2 97 22 0 0 10
+2 98 25 0 0 10
+4 G1 22 0 25 0
+0
+0101000
++4516 0 -4516 20 *
+Wi
+0101000
++4387 0 -4386 0 -4515 0 +4515 20 *
+Fa
+0 1e-07 22 0
+0101000
++4385 0 *
+Ed
+ 1e-07 1 1 0
+1 66 0 0 10
+2 99 23 0 0 10
+2 100 24 0 0 10
+4 G1 23 0 24 0
+0
+0101000
++4514 0 -4514 20 *
+Wi
+0101000
++4383 0 -4387 0 -4513 0 +4513 20 *
+Fa
+0 1e-07 23 0
+0101000
++4382 0 *
+Ed
+ 1e-07 1 1 0
+1 67 0 0 10
+2 101 24 0 0 10
+2 102 25 0 0 10
+4 G1 24 0 25 0
+0
+0101000
++4512 0 -4512 20 *
+Wi
+0101000
++4380 0 -4383 0 -4511 0 +4511 20 *
+Fa
+0 1e-07 24 0
+0101000
++4379 0 *
+Wi
+0101000
++4380 0 -4386 0 -4510 0 +4510 20 *
+Fa
+0 1e-07 25 0
+0101000
++4377 0 *
+Fa
+0 1e-07 45 0
+0101000
++4509 0 *
+Ed
+ 1e-07 1 1 0
+1 68 0 0 10
+3 103 104CN 26 0 0 10
+0
+0101000
++4508 0 -4508 22 *
+Wi
+0101000
++4374 0 -4374 0 -4507 0 +4507 22 *
+Fa
+0 1e-07 26 0
+0101000
++4373 0 *
+Fa
+0 1e-07 46 0
+0101000
++4506 0 *
+Sh
+0101000
++4570 0 -4565 0 -4563 1 -4558 3 +4555 0 -4505 5 +4500 0 -4495 0 +4472 25 -4469 0
++4467 27 +4463 0 +4460 0 +4457 0 +4455 0 +4453 29 -4449 0 -4446 0 -4443 0 -4441 0
++4439 30 +4436 0 -4434 7 +4431 0 -4429 11 +4425 0 +4422 0 +4419 0 -4417 0 -4415 14
+-4411 0 -4408 0 -4405 0 +4403 0 -4401 16 -4397 0 -4394 0 -4391 0 +4389 0 -4388 18
+-4384 0 -4381 0 -4378 0 +4376 0 -4375 20 +4372 0 -4371 22 *
+So
+0100000
++4370 0 *
+Ve
+1e-07
+2.91666666666667 0 6.875
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 69 0 0 6.28318530717959
+2 105 48 0 0 6.28318530717959
+2 106 47 0 0 6.28318530717959
+0
+0101100
++4368 0 -4368 0 *
+Wi
+0101000
+-4367 0 *
+Ve
+2.25120000016e-06
+1.5 -1.13706614149958e-14 0.166666666666664
+0 0
+0101101
+Ed
+ 4.07921986653155e-16 1 1 0
+1 70 0 1.5707963267949 7.85398163397448
+2 107 47 37 1.5707963267949 7.85398163397448
+2 108 49 42 1.5707963267949 7.85398163397448
+0
+0101100
++4365 0 -4365 0 *
+Wi
+0101100
++4364 0 *
+Fa
+0 1e-07 47 0
+0101000
+-4366 0 +4363 38 *
+Ve
+1.92823335063125e-06
+3.5 0 6.875
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 71 0 0 0.583333333333334
+3 109 110CN 48 0 0 0.583333333333334
+0
+0101000
+-4361 0 +4368 0 *
+Ed
+ 6.87499999999939e-08 1 1 0
+1 72 0 0 6.28318530717959
+2 111 50 43 0 6.28318530717959
+2 112 48 0 0 6.28318530717959
+0
+0101100
++4361 0 -4361 0 *
+Wi
+0101100
++4360 0 -4359 0 +4367 0 -4360 0 *
+Fa
+0 1e-07 48 0
+0101000
++4358 0 *
+Ve
+6.40000002e-06
+1.5 0 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 73 0 4.16666666666667 22.5
+3 113 114CN 49 0 4.16666666666667 22.5
+0
+0101000
++4365 44 -4356 0 *
+Ed
+ 0 1 1 0
+1 74 0 1.5707963267949 7.85398163397448
+2 115 51 45 1.5707963267949 7.85398163397448
+2 116 49 0 1.5707963267949 7.85398163397448
+0
+0101100
++4356 0 -4356 0 *
+Wi
+0101100
++4355 42 -4364 0 +4354 42 -4355 42 *
+Fa
+0 1e-07 49 0
+0101000
++4353 44 *
+Wi
+0101100
+-4359 0 *
+Ve
+8.48233350631248e-07
+0 0 2.375
+0 0
+0101101
+Ed
+ 2.37499999999825e-08 1 1 0
+1 75 0 3.14159265358979 9.42477796076938
+2 117 52 0 3.14159265358979 9.42477796076938
+2 118 53 0 3.14159265358979 9.42477796076938
+0
+0101100
++4350 0 -4350 0 *
+Wi
+0101100
++4349 0 *
+Ve
+1e-07
+9.55759993925662 -0.323813432970059 0.749999999999997
+0 0
+0101101
+Ve
+1e-07
+0 0.795603032049121 9.53287449408005
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 76 0 0 0.472437057647217
+0
+0101000
+-4347 54 +4346 0 *
+Ve
+1e-07
+0 -0.737634278542183 -2.75288860492384
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 77 0 0 0.314022504840775
+2 119 54 0 0 0.314022504840775
+2 120 54 58 0 0.314022504840775
+0
+0101000
+-4347 59 +4344 0 *
+Ve
+1e-07
+0 0.862359821958175 8.20480563678825
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 78 0 0 0.698131700797731
+2 121 55 0 0 0.698131700797731
+2 122 55 47 0 0.698131700797731
+0
+0101000
++4342 0 -4346 0 *
+Ve
+1e-07
+0 -1.425 -2.46817240078565
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 79 0 2.61799387799149 2.87979326579064
+2 123 56 0 2.61799387799149 2.87979326579064
+2 124 56 58 2.61799387799149 2.87979326579064
+0
+0101000
++4340 0 -4344 0 *
+Ve
+1e-07
+0 1.71527144924655 8.06971770605389
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 6.07374579694026 6.17846555205992
+2 125 57 0 6.07374579694026 6.17846555205992
+2 126 57 47 6.07374579694026 6.17846555205992
+0
+0101000
++4338 0 -4342 0 *
+Ve
+1e-07
+0 -2.25962666587139 -3.5033640194359
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 81 0 0 0.698131700797732
+2 127 58 0 0 0.698131700797732
+2 128 58 58 0 0.698131700797732
+0
+0101000
++4336 0 -4340 0 *
+Ve
+1e-07
+0 2.18915677589979 9.3121572642981
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 82 0 0 0.698131700797731
+2 129 59 0 0 0.698131700797731
+2 130 59 47 0 0.698131700797731
+0
+0101000
++4334 0 -4338 0 *
+Ve
+1e-07
+0 -2.79915536931599 -3.08936908449356
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 83 0 0 0.680061047258648
+0
+0101000
++4332 0 -4336 0 *
+Ve
+1e-07
+0 2.76021325135306 9.15914314286783
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 84 0 0 0.591201166705703
+0
+0101000
++4330 0 -4334 0 *
+Ve
+1e-07
+0 -2.01525432638166 -2.01525432638166
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 85 0 0 0.698131700797732
+2 131 60 0 0 0.698131700797732
+2 132 60 58 0 0.698131700797732
+0
+0101000
++4328 0 -4332 0 *
+Ve
+1e-07
+0 2.54939020359334 7.84621625943501
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 86 0 0 0.698131700797731
+2 133 61 0 0 0.698131700797731
+2 134 61 47 0 0.698131700797731
+0
+0101000
++4326 0 -4330 0 *
+Ve
+1e-07
+0 -2.46817240078565 -1.425
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 79 0 2.0943951023932 2.35619449019234
+2 135 62 0 2.0943951023932 2.35619449019234
+2 136 62 58 2.0943951023932 2.35619449019234
+0
+0101000
++4324 0 -4328 0 *
+Ve
+1e-07
+0 3.35557730537538 7.53675002555145
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 5.86430628670094 5.9690260418206
+2 137 63 0 5.86430628670094 5.9690260418206
+2 138 63 47 5.86430628670094 5.9690260418206
+0
+0101000
++4322 0 -4326 0 *
+Ve
+1e-07
+0 -3.7085761054313 -1.90418890660016
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 87 0 0 0.698131700797731
+2 139 64 0 0 0.698131700797731
+2 140 64 58 0 0.698131700797731
+0
+0101000
++4320 0 -4324 0 *
+Ve
+1e-07
+0 4.07742480995763 8.65351299898659
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 88 0 0 0.698131700797733
+2 141 65 0 0 0.698131700797733
+2 142 65 47 0 0.698131700797733
+0
+0101000
++4318 0 -4322 0 *
+Ve
+1e-07
+0 -3.96882420121404 -1.2758944241797
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 89 0 0 0.680061047258648
+0
+0101000
++4316 0 -4320 0 *
+Ve
+1e-07
+0 4.60418890660018 8.38511328586726
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 90 0 0 0.591201166705702
+0
+0101000
++4314 0 -4318 0 *
+Ve
+1e-07
+0 -2.75288860492384 -0.737634278542183
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 91 0 0 0.698131700797733
+2 143 66 0 0 0.698131700797733
+2 144 66 58 0 0.698131700797733
+0
+0101000
++4312 0 -4316 0 *
+Ve
+1e-07
+0 4.12500000000002 7.14470958122161
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 92 0 0 0.698131700797727
+2 145 67 0 0 0.698131700797727
+2 146 67 47 0 0.698131700797727
+0
+0101000
++4310 0 -4314 0 *
+Ve
+1e-07
+0 -2.85 -6.32827124036339e-16
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 79 0 1.5707963267949 1.83259571459405
+2 147 68 0 1.5707963267949 1.83259571459405
+2 148 68 58 1.5707963267949 1.83259571459405
+0
+0101000
++4308 0 -4312 0 *
+Ve
+1e-07
+0 4.84922833141292 6.6743902035933
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 5.65486677646162 5.75958653158128
+2 149 69 0 5.65486677646162 5.75958653158128
+2 150 69 47 5.65486677646162 5.75958653158128
+0
+0101000
++4306 0 -4310 0 *
+Ve
+1e-07
+0 -4.16381557247155 0.205212085995401
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 93 0 0 0.698131700797722
+2 151 70 0 0 0.698131700797722
+2 152 70 58 0 0.698131700797722
+0
+0101000
++4304 0 -4308 0 *
+Ve
+1e-07
+0 5.7874898141653 7.61666869145696
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 94 0 0 0.698131700797732
+2 153 71 0 0 0.698131700797732
+2 154 71 47 0 0.698131700797732
+0
+0101000
++4302 0 -4306 0 *
+Ve
+1e-07
+0 -4.07504979349569 0.87945511672048
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 95 0 0 0.680061047258649
+0
+0101000
++4300 0 -4304 0 *
+Ve
+1e-07
+0 6.24693941327929 7.24461374203661
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 96 0 0 0.591201166705703
+0
+0101000
++4298 0 -4302 0 *
+Ve
+1e-07
+0 -2.75288860492384 0.737634278542184
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 97 0 0 0.698131700797732
+2 155 72 0 0 0.698131700797732
+2 156 72 58 0 0.698131700797732
+0
+0101000
++4296 0 -4300 0 *
+Ve
+1e-07
+0 5.52032750246059 6.13094481018849
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 98 0 0 0.698131700797733
+2 157 73 0 0 0.698131700797733
+2 158 73 47 0 0.698131700797733
+0
+0101000
++4294 0 -4298 0 *
+Ve
+1e-07
+0 -2.46817240078565 1.425
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 79 0 1.0471975511966 1.30899693899575
+2 159 74 0 1.0471975511966 1.30899693899575
+2 160 74 58 1.0471975511966 1.30899693899575
+0
+0101000
++4292 0 -4296 0 *
+Ve
+1e-07
+0 6.13094481018851 5.52032750246057
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 5.44542726622231 5.55014702134197
+2 161 75 0 5.44542726622231 5.55014702134197
+2 162 75 47 5.44542726622231 5.55014702134197
+0
+0101000
++4290 0 -4294 0 *
+Ve
+1e-07
+0 -3.5033640194359 2.25962666587139
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 99 0 0 0.698131700797727
+2 163 76 0 0 0.698131700797727
+2 164 76 58 0 0.698131700797727
+0
+0101000
++4288 0 -4292 0 *
+Ve
+1e-07
+0 7.24461374203663 6.24693941327926
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 100 0 0 0.698131700797726
+2 165 77 0 0 0.698131700797726
+2 166 77 47 0 0.698131700797726
+0
+0101000
++4286 0 -4290 0 *
+Ve
+1e-07
+0 -3.08936908449356 2.79915536931599
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 101 0 0 0.680061047258647
+0
+0101000
++4284 0 -4288 0 *
+Ve
+1e-07
+0 7.61666869145698 5.78748981416527
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 102 0 0 0.591201166705704
+0
+0101000
++4282 0 -4286 0 *
+Ve
+1e-07
+0 -2.01525432638166 2.01525432638166
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 103 0 0 0.698131700797732
+2 167 78 0 0 0.698131700797732
+2 168 78 58 0 0.698131700797732
+0
+0101000
++4280 0 -4284 0 *
+Ve
+1e-07
+0 6.67439020359333 4.84922833141289
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 104 0 0 0.698131700797732
+2 169 79 0 0 0.698131700797732
+2 170 79 47 0 0.698131700797732
+0
+0101000
++4278 0 -4282 0 *
+Ve
+1e-07
+0 -1.425 2.46817240078565
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 79 0 0.523598775598299 0.785398163397448
+2 171 80 0 0.523598775598299 0.785398163397448
+2 172 80 58 0.523598775598299 0.785398163397448
+0
+0101000
++4276 0 -4280 0 *
+Ve
+1e-07
+0 7.14470958122163 4.12499999999999
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 5.23598775598299 5.34070751110265
+2 173 81 0 5.23598775598299 5.34070751110265
+2 174 81 47 5.23598775598299 5.34070751110265
+0
+0101000
++4274 0 -4278 0 *
+Ve
+1e-07
+0 -1.90418890660016 3.7085761054313
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 105 0 0 0.698131700797731
+2 175 82 0 0 0.698131700797731
+2 176 82 58 0 0.698131700797731
+0
+0101000
++4272 0 -4276 0 *
+Ve
+1e-07
+0 8.38511328586728 4.60418890660014
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 106 0 0 0.698131700797736
+2 177 83 0 0 0.698131700797736
+2 178 83 47 0 0.698131700797736
+0
+0101000
++4270 0 -4274 0 *
+Ve
+1e-07
+0 -1.2758944241797 3.96882420121404
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 107 0 0 0.680061047258648
+0
+0101000
++4268 0 -4272 0 *
+Ve
+1e-07
+0 8.6535129989866 4.07742480995759
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 108 0 0 0.591201166705693
+0
+0101000
++4266 0 -4270 0 *
+Ve
+1e-07
+0 -0.737634278542184 2.75288860492384
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 109 0 0 0.698131700797732
+2 179 84 0 0 0.698131700797732
+2 180 84 58 0 0.698131700797732
+0
+0101000
++4264 0 -4268 0 *
+Ve
+1e-07
+0 7.53675002555146 3.35557730537535
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 110 0 0 0.698131700797783
+2 181 85 0 0 0.698131700797783
+2 182 85 47 0 0.698131700797783
+0
+0101000
++4262 0 -4266 0 *
+Ve
+1e-07
+0 0 2.85
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 79 0 0 0.261799387799149
+2 183 86 0 0 0.261799387799149
+2 184 86 58 0 0.261799387799149
+0
+0101000
++4260 0 -4264 0 *
+Ve
+1e-07
+0 7.84621625943502 2.54939020359331
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 5.02654824574367 5.13126800086333
+2 185 87 0 5.02654824574367 5.13126800086333
+2 186 87 47 5.02654824574367 5.13126800086333
+0
+0101000
++4258 0 -4262 0 *
+Ve
+1e-07
+0 0.205212085995409 4.16381557247154
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 111 0 0 0.698131700797732
+2 187 88 0 0 0.698131700797732
+2 188 88 58 0 0.698131700797732
+0
+0101000
++4256 0 -4260 0 *
+Ve
+1e-07
+0 9.15914314286784 2.76021325135302
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 112 0 0 0.69813170079773
+2 189 89 0 0 0.69813170079773
+2 190 89 47 0 0.69813170079773
+0
+0101000
++4254 0 -4258 0 *
+Ve
+1e-07
+0 0.879455116720486 4.07504979349569
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 113 0 0 0.680061047258646
+0
+0101000
++4252 0 -4256 0 *
+Ve
+1e-07
+0 9.31215726429811 2.18915677589975
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 114 0 0 0.591201166705702
+0
+0101000
++4250 0 -4254 0 *
+Ve
+1e-07
+0 0.737634278542188 2.75288860492384
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 115 0 0 0.698131700797732
+2 191 90 0 0 0.698131700797732
+2 192 90 58 0 0.698131700797732
+0
+0101000
++4248 0 -4252 0 *
+Ve
+1e-07
+0 8.0697177060539 1.71527144924651
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 116 0 0 0.698131700797734
+2 193 91 0 0 0.698131700797734
+2 194 91 47 0 0.698131700797734
+0
+0101000
++4246 0 -4250 0 *
+Ve
+1e-07
+0 1.425 2.46817240078565
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 79 0 5.75958653158129 6.02138591938044
+2 195 92 0 5.75958653158129 6.02138591938044
+2 196 92 58 5.75958653158129 6.02138591938044
+0
+0101000
++4244 0 -4248 0 *
+Ve
+1e-07
+0 8.20480563678826 0.862359821958139
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 4.81710873550435 4.92182849062401
+2 197 93 0 4.81710873550435 4.92182849062401
+2 198 93 47 4.81710873550435 4.92182849062401
+0
+0101000
++4242 0 -4246 0 *
+Ve
+1e-07
+0 2.25962666587139 3.5033640194359
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 117 0 0 0.698131700797731
+2 199 94 0 0 0.698131700797731
+2 200 94 58 0 0.698131700797731
+0
+0101000
++4240 0 -4244 0 *
+Ve
+1e-07
+0 9.53287449408006 0.795603032049078
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 118 0 0 0.698131700797732
+2 201 95 0 0 0.698131700797732
+2 202 95 47 0 0.698131700797732
+0
+0101000
++4238 0 -4242 0 *
+Ve
+1e-07
+0 2.79915536931599 3.08936908449356
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 119 0 0 0.680061047258647
+0
+0101000
++4236 0 -4240 0 *
+Ve
+1e-07
+0 9.56381557247154 0.205212085995401
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 120 0 0 0.591201166705702
+0
+0101000
++4234 0 -4238 0 *
+Ve
+1e-07
+0 2.01525432638166 2.01525432638166
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 121 0 0 0.698131700797731
+2 203 96 0 0 0.698131700797731
+2 204 96 58 0 0.698131700797731
+0
+0101000
++4232 0 -4236 0 *
+Ve
+1e-07
+0 8.25 0
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 122 0 0 0.698131700797732
+2 205 97 0 0 0.698131700797732
+2 206 97 47 0 0.698131700797732
+0
+0101000
++4230 0 -4234 0 *
+Ve
+1e-07
+0 2.46817240078565 1.425
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 79 0 5.23598775598299 5.49778714378214
+2 207 98 0 5.23598775598299 5.49778714378214
+2 208 98 58 5.23598775598299 5.49778714378214
+0
+0101000
++4228 0 -4232 0 *
+Ve
+1e-07
+0 8.20480563678826 -0.862359821958139
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 4.60766922526503 4.71238898038469
+2 209 99 0 4.60766922526503 4.71238898038469
+2 210 99 47 4.60766922526503 4.71238898038469
+0
+0101000
++4226 0 -4230 0 *
+Ve
+1e-07
+0 3.7085761054313 1.90418890660016
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 123 0 0 0.698131700797729
+2 211 100 0 0 0.698131700797729
+2 212 100 58 0 0.698131700797729
+0
+0101000
++4224 0 -4228 0 *
+Ve
+1e-07
+0 9.48997348609396 -1.20377885748232
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 124 0 0 0.698131700797733
+2 213 101 0 0 0.698131700797733
+2 214 101 47 0 0.698131700797733
+0
+0101000
++4222 0 -4226 0 *
+Ve
+1e-07
+0 3.96882420121404 1.2758944241797
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 125 0 0 0.680061047258647
+0
+0101000
++4220 0 -4224 0 *
+Ve
+1e-07
+0 9.39748924784919 -1.78770135678379
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 126 0 0 0.591201166705703
+0
+0101000
++4218 0 -4222 0 *
+Ve
+1e-07
+0 2.75288860492384 0.737634278542183
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 127 0 0 0.698131700797733
+2 215 102 0 0 0.698131700797733
+2 216 102 58 0 0.698131700797733
+0
+0101000
++4216 0 -4220 0 *
+Ve
+1e-07
+0 8.0697177060539 -1.71527144924651
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 128 0 0 0.698131700797732
+2 217 103 0 0 0.698131700797732
+2 218 103 47 0 0.698131700797732
+0
+0101000
++4214 0 -4218 0 *
+Ve
+1e-07
+0 2.85 0
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 79 0 4.71238898038469 4.97418836818384
+2 219 104 0 4.71238898038469 4.97418836818384
+2 220 104 58 4.71238898038469 4.97418836818384
+0
+0101000
++4212 0 -4216 0 *
+Ve
+1e-07
+0 7.84621625943502 -2.54939020359331
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 4.39822971502571 4.50294947014537
+2 221 105 0 4.39822971502571 4.50294947014537
+2 222 105 47 4.39822971502571 4.50294947014537
+0
+0101000
++4210 0 -4214 0 *
+Ve
+1e-07
+0 4.16381557247154 -0.205212085995401
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 129 0 0 0.698131700797731
+2 223 106 0 0 0.698131700797731
+2 224 106 58 0 0.698131700797731
+0
+0101000
++4208 0 -4212 0 *
+Ve
+1e-07
+0 9.03231509882042 -3.15054983456991
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 130 0 0 0.698131700797732
+2 225 107 0 0 0.698131700797732
+2 226 107 47 0 0.698131700797732
+0
+0101000
++4206 0 -4210 0 *
+Ve
+1e-07
+0 4.07504979349569 -0.879455116720479
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 131 0 0 0.680061047258647
+0
+0101000
++4204 0 -4208 0 *
+Ve
+1e-07
+0 8.8204475489393 -3.70248367192868
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 132 0 0 0.591201166705711
+0
+0101000
++4202 0 -4206 0 *
+Ve
+1e-07
+0 2.75288860492384 -0.737634278542183
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 133 0 0 0.698131700797729
+2 227 108 0 0 0.698131700797729
+2 228 108 58 0 0.698131700797729
+0
+0101000
++4200 0 -4204 0 *
+Ve
+1e-07
+0 7.53675002555146 -3.35557730537535
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 134 0 0 0.698131700797678
+2 229 109 0 0 0.698131700797678
+2 230 109 47 0 0.698131700797678
+0
+0101000
++4198 0 -4202 0 *
+Ve
+1e-07
+0 2.46817240078565 -1.425
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 79 0 4.18879020478639 4.45058959258554
+2 231 110 0 4.18879020478639 4.45058959258554
+2 232 110 58 4.18879020478639 4.45058959258554
+0
+0101000
++4196 0 -4200 0 *
+Ve
+1e-07
+0 7.14470958122163 -4.12499999999999
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 4.18879020478639 4.29350995990605
+2 233 111 0 4.18879020478639 4.29350995990605
+2 234 111 47 4.18879020478639 4.29350995990605
+0
+0101000
++4194 0 -4198 0 *
+Ve
+1e-07
+0 3.5033640194359 -2.25962666587138
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 135 0 0 0.69813170079773
+2 235 112 0 0 0.69813170079773
+2 236 112 58 0 0.69813170079773
+0
+0101000
++4192 0 -4196 0 *
+Ve
+1e-07
+0 8.17990119987188 -4.95962666587137
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 136 0 0 0.69813170079773
+2 237 113 0 0 0.69813170079773
+2 238 113 47 0 0.69813170079773
+0
+0101000
++4190 0 -4194 0 *
+Ve
+1e-07
+0 3.08936908449356 -2.79915536931599
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 137 0 0 0.680061047258647
+0
+0101000
++4188 0 -4192 0 *
+Ve
+1e-07
+0 7.85790996693753 -5.45544968412244
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 138 0 0 0.591201166705703
+0
+0101000
++4186 0 -4190 0 *
+Ve
+1e-07
+0 2.01525432638166 -2.01525432638166
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 139 0 0 0.698131700797731
+2 239 114 0 0 0.698131700797731
+2 240 114 58 0 0.698131700797731
+0
+0101000
++4184 0 -4188 0 *
+Ve
+1e-07
+0 6.67439020359333 -4.84922833141289
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 140 0 0 0.69813170079773
+2 241 115 0 0 0.69813170079773
+2 242 115 47 0 0.69813170079773
+0
+0101000
++4182 0 -4186 0 *
+Ve
+1e-07
+0 1.425 -2.46817240078565
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 79 0 3.66519142918809 3.92699081698724
+2 243 116 0 3.66519142918809 3.92699081698724
+2 244 116 58 3.66519142918809 3.92699081698724
+0
+0101000
++4180 0 -4184 0 *
+Ve
+1e-07
+0 6.13094481018851 -5.52032750246057
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 3.97935069454707 4.08407044966673
+2 245 117 0 3.97935069454707 4.08407044966673
+2 246 117 47 3.97935069454707 4.08407044966673
+0
+0101000
++4178 0 -4182 0 *
+Ve
+1e-07
+0 1.90418890660016 -3.7085761054313
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 141 0 0 0.698131700797731
+2 247 118 0 0 0.698131700797731
+2 248 118 58 0 0.698131700797731
+0
+0101000
++4176 0 -4180 0 *
+Ve
+1e-07
+0 6.9699863669681 -6.55194401294507
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 142 0 0 0.698131700797735
+2 249 119 0 0 0.698131700797735
+2 250 119 47 0 0.698131700797735
+0
+0101000
++4174 0 -4178 0 *
+Ve
+1e-07
+0 1.2758944241797 -3.96882420121404
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 143 0 0 0.680061047258648
+0
+0101000
++4172 0 -4176 0 *
+Ve
+1e-07
+0 6.55194401294509 -6.96998636696807
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 144 0 0 0.591201166705705
+0
+0101000
++4170 0 -4174 0 *
+Ve
+1e-07
+0 0.737634278542186 -2.75288860492384
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 145 0 0 0.698131700797731
+2 251 120 0 0 0.698131700797731
+2 252 120 58 0 0.698131700797731
+0
+0101000
++4168 0 -4172 0 *
+Ve
+1e-07
+0 5.52032750246059 -6.13094481018849
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 146 0 0 0.69813170079773
+2 253 121 0 0 0.69813170079773
+2 254 121 47 0 0.69813170079773
+0
+0101000
++4166 0 -4170 0 *
+Ve
+1e-07
+0 1.26565424807268e-15 -2.85
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 79 0 3.14159265358979 3.40339204138894
+2 255 122 0 3.14159265358979 3.40339204138894
+2 256 122 58 3.14159265358979 3.40339204138894
+0
+0101000
++4164 0 -4168 0 *
+Ve
+1e-07
+0 4.84922833141291 -6.67439020359331
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 3.76991118430775 3.87463093942741
+2 257 123 0 3.76991118430775 3.87463093942741
+2 258 123 47 3.76991118430775 3.87463093942741
+0
+0101000
++4162 0 -4166 0 *
+Ve
+1e-07
+0 -0.205212085995399 -4.16381557247154
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 147 0 0 0.698131700797731
+2 259 124 0 0 0.698131700797731
+2 260 124 58 0 0.698131700797731
+0
+0101000
++4160 0 -4164 0 *
+Ve
+1e-07
+0 5.45544968412247 -7.85790996693751
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 148 0 0 0.698131700797729
+2 261 125 0 0 0.698131700797729
+2 262 125 47 0 0.698131700797729
+0
+0101000
++4158 0 -4162 0 *
+Ve
+1e-07
+8.84212561159607 0.0243489537268066 0.749999999999997
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 149 0 0.182992513907313 0.680061047258649
+0
+0101000
++4156 59 -4160 0 *
+Ve
+1e-07
+0 4.9596266658714 -8.17990119987186
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 150 0 0 0.591201166705707
+0
+0101000
++4154 0 -4158 0 *
+Ve
+1e-07
+0 0 8.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 151 0 0.39208330840124 0.69813170079773
+2 263 126 0 0.39208330840124 0.69813170079773
+2 264 126 47 0.39208330840124 0.69813170079773
+0
+0101000
++4156 54 -4152 0 *
+Ve
+1e-07
+0 4.12500000000001 -7.14470958122161
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 152 0 0 0.698131700797723
+2 265 127 0 0 0.698131700797723
+2 266 127 47 0 0.698131700797723
+0
+0101000
++4150 0 -4154 0 *
+Ve
+1e-07
+0 -0.862359821958141 8.20480563678825
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 0 0.10471975511966
+2 267 128 0 0 0.10471975511966
+2 268 128 47 0 0.10471975511966
+0
+0101000
++4152 0 -4148 0 *
+Ve
+1e-07
+0 3.35557730537536 -7.53675002555145
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 3.56047167406843 3.66519142918809
+2 269 129 0 3.56047167406843 3.66519142918809
+2 270 129 47 3.56047167406843 3.66519142918809
+0
+0101000
++4146 0 -4150 0 *
+Ve
+1e-07
+0 -1.20377885748233 9.48997348609396
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 153 0 0 0.698131700797727
+2 271 130 0 0 0.698131700797727
+2 272 130 47 0 0.698131700797727
+0
+0101000
++4148 0 -4144 0 *
+Ve
+1e-07
+0 3.70248367192869 -8.8204475489393
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 154 0 0 0.698131700797733
+2 273 131 0 0 0.698131700797733
+2 274 131 47 0 0.698131700797733
+0
+0101000
++4142 0 -4146 0 *
+Ve
+1e-07
+0 -1.78770135678379 9.39748924784919
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 155 0 0 0.591201166705705
+0
+0101000
++4144 0 -4140 0 *
+Ve
+1e-07
+0 3.15054983456993 -9.03231509882041
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 156 0 0 0.591201166705706
+0
+0101000
++4138 0 -4142 0 *
+Ve
+1e-07
+0 -1.71527144924651 8.0697177060539
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 157 0 0 0.698131700797732
+2 275 132 0 0 0.698131700797732
+2 276 132 47 0 0.698131700797732
+0
+0101000
++4140 0 -4136 0 *
+Ve
+1e-07
+0 2.54939020359333 -7.84621625943501
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 158 0 0 0.698131700797731
+2 277 133 0 0 0.698131700797731
+2 278 133 47 0 0.698131700797731
+0
+0101000
++4134 0 -4138 0 *
+Ve
+1e-07
+0 -2.54939020359332 7.84621625943502
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 0.20943951023932 0.31415926535898
+2 279 134 0 0.20943951023932 0.31415926535898
+2 280 134 47 0.20943951023932 0.31415926535898
+0
+0101000
++4136 0 -4132 0 *
+Ve
+1e-07
+0 1.71527144924652 -8.06971770605389
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 3.35103216382911 3.45575191894877
+2 281 135 0 3.35103216382911 3.45575191894877
+2 282 135 47 3.35103216382911 3.45575191894877
+0
+0101000
++4130 0 -4134 0 *
+Ve
+1e-07
+0 -3.15054983456992 9.03231509882041
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 159 0 0 0.698131700797731
+2 283 136 0 0 0.698131700797731
+2 284 136 47 0 0.698131700797731
+0
+0101000
++4132 0 -4128 0 *
+Ve
+1e-07
+0 1.78770135678381 -9.39748924784919
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 160 0 0 0.698131700797732
+2 285 137 0 0 0.698131700797732
+2 286 137 47 0 0.698131700797732
+0
+0101000
++4126 0 -4130 0 *
+Ve
+1e-07
+0 -3.70248367192868 8.8204475489393
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 161 0 0 0.591201166705705
+0
+0101000
++4128 0 -4124 0 *
+Ve
+1e-07
+0 1.20377885748234 -9.48997348609396
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 162 0 0 0.591201166705707
+0
+0101000
++4122 0 -4126 0 *
+Ve
+1e-07
+0 -3.35557730537535 7.53675002555146
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 163 0 0 0.698131700797728
+2 287 138 0 0 0.698131700797728
+2 288 138 47 0 0.698131700797728
+0
+0101000
++4124 0 -4120 0 *
+Ve
+1e-07
+0 0.86235982195815 -8.20480563678825
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 164 0 0 0.698131700797733
+2 289 139 0 0 0.698131700797733
+2 290 139 47 0 0.698131700797733
+0
+0101000
++4118 0 -4122 0 *
+Ve
+1e-07
+0 -4.125 7.14470958122162
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 0.418879020478639 0.523598775598299
+2 291 140 0 0.418879020478639 0.523598775598299
+2 292 140 47 0.418879020478639 0.523598775598299
+0
+0101000
++4120 0 -4116 0 *
+Ve
+1e-07
+0 7.32747196252603e-15 -8.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 3.14159265358979 3.24631240870945
+2 293 141 0 3.14159265358979 3.24631240870945
+2 294 141 47 3.14159265358979 3.24631240870945
+0
+0101000
++4114 0 -4118 0 *
+Ve
+1e-07
+0 -4.95962666587139 8.17990119987187
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 165 0 0 0.698131700797727
+2 295 142 0 0 0.698131700797727
+2 296 142 47 0 0.698131700797727
+0
+0101000
++4116 0 -4112 0 *
+Ve
+1e-07
+0 -0.205212085995393 -9.56381557247154
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 166 0 0 0.698131700797732
+2 297 143 0 0 0.698131700797732
+2 298 143 47 0 0.698131700797732
+0
+0101000
++4110 0 -4114 0 *
+Ve
+1e-07
+0 -5.45544968412246 7.85790996693752
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 167 0 0 0.591201166705705
+0
+0101000
++4112 0 -4108 0 *
+Ve
+1e-07
+0 -0.795603032049074 -9.53287449408006
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 168 0 0 0.591201166705707
+0
+0101000
++4106 0 -4110 0 *
+Ve
+1e-07
+0 -4.8492283314129 6.67439020359332
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 169 0 0 0.698131700797731
+2 299 144 0 0 0.698131700797731
+2 300 144 47 0 0.698131700797731
+0
+0101000
++4108 0 -4104 0 *
+Ve
+1e-07
+0 -0.862359821958135 -8.20480563678826
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 170 0 0 0.698131700797731
+2 301 145 0 0 0.698131700797731
+2 302 145 47 0 0.698131700797731
+0
+0101000
++4102 0 -4106 0 *
+Ve
+1e-07
+0 -5.52032750246058 6.1309448101885
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 0.628318530717959 0.733038285837618
+2 303 146 0 0.628318530717959 0.733038285837618
+2 304 146 47 0.628318530717959 0.733038285837618
+0
+0101000
++4104 0 -4100 0 *
+Ve
+1e-07
+0 -1.71527144924651 -8.0697177060539
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 2.93215314335047 3.03687289847013
+2 305 147 0 2.93215314335047 3.03687289847013
+2 306 147 47 2.93215314335047 3.03687289847013
+0
+0101000
++4098 0 -4102 0 *
+Ve
+1e-07
+0 -6.55194401294508 6.96998636696808
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 171 0 0 0.698131700797731
+2 307 148 0 0 0.698131700797731
+2 308 148 47 0 0.698131700797731
+0
+0101000
++4100 0 -4096 0 *
+Ve
+1e-07
+0 -2.18915677589975 -9.31215726429811
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 172 0 0 0.698131700797734
+2 309 149 0 0 0.698131700797734
+2 310 149 47 0 0.698131700797734
+0
+0101000
++4094 0 -4098 0 *
+Ve
+1e-07
+0 -6.96998636696808 6.55194401294508
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 173 0 0 0.591201166705705
+0
+0101000
++4096 0 -4092 0 *
+Ve
+1e-07
+0 -2.76021325135302 -9.15914314286784
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 174 0 0 0.591201166705706
+0
+0101000
++4090 0 -4094 0 *
+Ve
+1e-07
+0 -6.1309448101885 5.52032750246058
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 175 0 0 0.698131700797732
+2 311 150 0 0 0.698131700797732
+2 312 150 47 0 0.698131700797732
+0
+0101000
++4092 0 -4088 0 *
+Ve
+1e-07
+0 -2.54939020359331 -7.84621625943502
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 176 0 0 0.698131700797732
+2 313 151 0 0 0.698131700797732
+2 314 151 47 0 0.698131700797732
+0
+0101000
++4086 0 -4090 0 *
+Ve
+1e-07
+0 -6.67439020359332 4.8492283314129
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 0.837758040957278 0.942477796076938
+2 315 152 0 0.837758040957278 0.942477796076938
+2 316 152 47 0.837758040957278 0.942477796076938
+0
+0101000
++4088 0 -4084 0 *
+Ve
+1e-07
+0 -3.35557730537535 -7.53675002555146
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 2.72271363311115 2.82743338823081
+2 317 153 0 2.72271363311115 2.82743338823081
+2 318 153 47 2.72271363311115 2.82743338823081
+0
+0101000
++4082 0 -4086 0 *
+Ve
+1e-07
+0 -7.85790996693752 5.45544968412246
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 177 0 0 0.698131700797731
+2 319 154 0 0 0.698131700797731
+2 320 154 47 0 0.698131700797731
+0
+0101000
++4084 0 -4080 0 *
+Ve
+1e-07
+0 -4.0774248099576 -8.6535129989866
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 178 0 0 0.698131700797728
+2 321 155 0 0 0.698131700797728
+2 322 155 47 0 0.698131700797728
+0
+0101000
++4078 0 -4082 0 *
+Ve
+1e-07
+0 -8.17990120004263 4.9596266657281
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 179 0 0 0.591201166918879
+0
+0101000
++4080 0 -4076 0 *
+Ve
+1e-07
+0 -4.60418890660016 -8.38511328586728
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 180 0 0 0.591201166705705
+0
+0101000
++4074 0 -4078 0 *
+Ve
+1e-07
+0 -7.144709581326 4.1249999998192
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 181 0 0 0.698131699497974
+2 323 156 0 0 0.698131699497974
+2 324 156 47 0 0.698131699497974
+0
+0101000
++4076 0 -4072 0 *
+Ve
+1e-07
+0 -4.125 -7.14470958122162
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 182 0 0 0.698131700797734
+2 325 157 0 0 0.698131700797734
+2 326 157 47 0 0.698131700797734
+0
+0101000
++4070 0 -4074 0 *
+Ve
+1e-07
+0 -7.53674688209901 3.35558436567625
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 1.0471975512219 1.15191636953285
+2 327 158 0 1.0471975512219 1.15191636953285
+2 328 158 47 1.0471975512219 1.15191636953285
+0
+0101000
++4072 0 -4068 0 *
+Ve
+1e-07
+0 -4.8492283314129 -6.67439020359332
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 2.51327412287183 2.61799387799149
+2 329 159 0 2.51327412287183 2.61799387799149
+2 330 159 47 2.51327412287183 2.61799387799149
+0
+0101000
++4066 0 -4070 0 *
+Ve
+1e-07
+0 -8.8204475489393 3.70248367192868
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 183 0 0 0.698111091562759
+2 331 160 0 0 0.698111091562759
+2 332 160 47 0 0.698111091562759
+0
+0101000
++4068 0 -4064 0 *
+Ve
+1e-07
+0 -5.78748981416528 -7.61666869145697
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 184 0 0 0.698131700797732
+2 333 161 0 0 0.698131700797732
+2 334 161 47 0 0.698131700797732
+0
+0101000
++4062 0 -4066 0 *
+Ve
+1e-07
+0 -9.03231509882041 3.15054983456992
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 185 0 0 0.591201166705705
+0
+0101000
++4064 0 -4060 0 *
+Ve
+1e-07
+0 -6.24693941327927 -7.24461374203662
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 186 0 0 0.591201166705706
+0
+0101000
++4058 0 -4062 0 *
+Ve
+1e-07
+0 -7.84621625943502 2.54939020359331
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 187 0 0 0.698131700797724
+2 335 162 0 0 0.698131700797724
+2 336 162 47 0 0.698131700797724
+0
+0101000
++4060 0 -4056 0 *
+Ve
+1e-07
+0 -5.52032750246058 -6.1309448101885
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 188 0 0 0.698131700797729
+2 337 163 0 0 0.698131700797729
+2 338 163 47 0 0.698131700797729
+0
+0101000
++4054 0 -4058 0 *
+Ve
+1e-07
+0 -8.0697177060539 1.71527144924652
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 1.25663706143592 1.36135681655558
+2 339 164 0 1.25663706143592 1.36135681655558
+2 340 164 47 1.25663706143592 1.36135681655558
+0
+0101000
++4056 0 -4052 0 *
+Ve
+1e-07
+0 -6.1309448101885 -5.52032750246058
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 2.30383461263251 2.40855436775217
+2 341 165 0 2.30383461263251 2.40855436775217
+2 342 165 47 2.30383461263251 2.40855436775217
+0
+0101000
++4050 0 -4054 0 *
+Ve
+1e-07
+0 -9.39748924784919 1.78770135678379
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 189 0 0 0.698131700797733
+2 343 166 0 0 0.698131700797733
+2 344 166 47 0 0.698131700797733
+0
+0101000
++4052 0 -4048 0 *
+Ve
+1e-07
+0 -7.24461374203662 -6.24693941327927
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 190 0 0 0.698131700797731
+2 345 167 0 0 0.698131700797731
+2 346 167 47 0 0.698131700797731
+0
+0101000
++4046 0 -4050 0 *
+Ve
+1e-07
+0 -9.48997348609396 1.20377885748233
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 191 0 0 0.591201166705703
+0
+0101000
++4048 0 -4044 0 *
+Ve
+1e-07
+0 -7.61666869145698 -5.78748981416528
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 192 0 0 0.591201166705706
+0
+0101000
++4042 0 -4046 0 *
+Ve
+1e-07
+0 -8.20480563678825 0.862359821958142
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 193 0 0 0.69813170079773
+2 347 168 0 0 0.69813170079773
+2 348 168 47 0 0.69813170079773
+0
+0101000
++4044 0 -4040 0 *
+Ve
+1e-07
+0 -6.67439020359332 -4.8492283314129
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 194 0 0 0.698131700797734
+2 349 169 0 0 0.698131700797734
+2 350 169 47 0 0.698131700797734
+0
+0101000
++4038 0 -4042 0 *
+Ve
+1e-07
+0 -8.25 -1.83186799063151e-15
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 1.46607657167524 1.5707963267949
+2 351 170 0 1.46607657167524 1.5707963267949
+2 352 170 47 1.46607657167524 1.5707963267949
+0
+0101000
++4040 0 -4036 0 *
+Ve
+1e-07
+0 -7.14470958122162 -4.125
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 2.09439510239319 2.19911485751285
+2 353 171 0 2.09439510239319 2.19911485751285
+2 354 171 47 2.09439510239319 2.19911485751285
+0
+0101000
++4034 0 -4038 0 *
+Ve
+1e-07
+0 -9.56381557247154 -0.205212085995403
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 195 0 0 0.698131700797755
+2 355 172 0 0 0.698131700797755
+2 356 172 47 0 0.698131700797755
+0
+0101000
++4036 0 -4032 0 *
+Ve
+1e-07
+0 -8.38511328586728 -4.60418890660016
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 196 0 0 0.698131700797718
+2 357 173 0 0 0.698131700797718
+2 358 173 47 0 0.698131700797718
+0
+0101000
++4030 0 -4034 0 *
+Ve
+1e-07
+0 -9.53287449408006 -0.795603032049078
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 197 0 0 0.5912011667057
+0
+0101000
++4032 0 -4028 0 *
+Ve
+1e-07
+0 -8.65351299898661 -4.07742480995759
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 198 0 0 0.591201166705714
+0
+0101000
++4026 0 -4030 0 *
+Ve
+1e-07
+0 -8.20480563678826 -0.862359821958139
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 199 0 0 0.698131700797732
+2 359 174 0 0 0.698131700797732
+2 360 174 47 0 0.698131700797732
+0
+0101000
++4028 0 -4024 0 *
+Ve
+1e-07
+0 -7.53675002555146 -3.35557730537534
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 200 0 0 0.698131700797701
+2 361 175 0 0 0.698131700797701
+2 362 175 47 0 0.698131700797701
+0
+0101000
++4022 0 -4026 0 *
+Ve
+1e-07
+0 -8.0697177060539 -1.71527144924651
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 1.67551608191456 1.78023583703422
+2 363 176 0 1.67551608191456 1.78023583703422
+2 364 176 47 1.67551608191456 1.78023583703422
+0
+0101000
++4024 0 -4020 0 *
+Ve
+1e-07
+0 -7.84621625943502 -2.54939020359331
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 80 0 1.88495559215388 1.98967534727353
+2 365 177 0 1.88495559215388 1.98967534727353
+2 366 177 47 1.88495559215388 1.98967534727353
+0
+0101000
++4018 0 -4022 0 *
+Ve
+1e-07
+0 -9.3121572642981 -2.18915677589976
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 201 0 0 0.698131700797743
+2 367 178 0 0 0.698131700797743
+2 368 178 47 0 0.698131700797743
+0
+0101000
++4020 0 -4016 0 *
+Ve
+1e-07
+0 -9.15914314286784 -2.76021325135302
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 202 0 0 0.698131700797722
+2 369 179 0 0 0.698131700797722
+2 370 179 47 0 0.698131700797722
+0
+0101000
++4014 0 -4018 0 *
+Ed
+ 1e-07 1 1 0
+1 203 0 0 0.591201166705703
+0
+0101000
++4016 0 -4014 0 *
+Wi
+0101100
++4345 55 -4343 56 +4341 55 -4339 56 +4337 55 -4335 56 +4333 55 -4331 56 +4329 55 -4327 56
++4325 55 -4323 56 +4321 55 -4319 56 +4317 55 -4315 56 +4313 55 -4311 56 +4309 55 -4307 56
++4305 55 -4303 56 +4301 55 -4299 56 +4297 55 -4295 56 +4293 55 -4291 56 +4289 55 -4287 56
++4285 55 -4283 56 +4281 55 -4279 56 +4277 55 -4275 56 +4273 55 -4271 56 +4269 55 -4267 56
++4265 55 -4263 56 +4261 55 -4259 56 +4257 55 -4255 56 +4253 55 -4251 56 +4249 55 -4247 56
++4245 55 -4243 56 +4241 55 -4239 56 +4237 55 -4235 56 +4233 55 -4231 56 +4229 55 -4227 56
++4225 55 -4223 56 +4221 55 -4219 56 +4217 55 -4215 56 +4213 55 -4211 56 +4209 55 -4207 56
++4205 55 -4203 56 +4201 55 -4199 56 +4197 55 -4195 56 +4193 55 -4191 56 +4189 55 -4187 56
++4185 55 -4183 56 +4181 55 -4179 56 +4177 55 -4175 56 +4173 55 -4171 56 +4169 55 -4167 56
++4165 55 -4163 56 +4161 55 -4159 56 +4157 55 -4155 56 +4153 55 +4151 55 +4149 55 +4147 55
++4145 55 +4143 55 +4141 55 +4139 55 +4137 55 +4135 55 +4133 55 +4131 55 +4129 55 +4127 55
++4125 55 +4123 55 +4121 55 +4119 55 +4117 55 +4115 55 +4113 55 +4111 55 +4109 55 +4107 55
++4105 55 +4103 55 +4101 55 +4099 55 +4097 55 +4095 55 +4093 55 +4091 55 +4089 55 +4087 55
++4085 55 +4083 55 +4081 55 +4079 55 +4077 55 +4075 55 +4073 55 +4071 55 +4069 55 +4067 55
++4065 55 +4063 55 +4061 55 +4059 55 +4057 55 +4055 55 +4053 55 +4051 55 +4049 55 +4047 55
++4045 55 +4043 55 +4041 55 +4039 55 +4037 55 +4035 55 +4033 55 +4031 55 +4029 55 +4027 55
++4025 55 +4023 55 +4021 55 +4019 55 +4017 55 +4015 55 +4013 55 +4012 55 *
+Fa
+0 1e-07 50 0
+0101000
++4351 47 -4348 53 +4011 54 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 34
+0 0
+0101101
+Ve
+1.820000002e-05
+9.01387818865997 3 34
+0 0
+0101101
+Ed
+ 7.53644380168212e-15 1 1 0
+1 204 0 1.89208491605971 4.39110039111988
+2 371 51 45 1.89208491605971 4.39110039111988
+2 372 180 0 1.89208491605971 4.39110039111988
+0
+0101000
+-4009 0 +4008 0 *
+Ve
+1.860000002e-05
+-9 3 34
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 205 0 2.84981632232666 2.86369451098663
+2 373 51 45 2.84981632232666 2.86369451098663
+2 374 181 0 2.84981632232666 2.86369451098663
+0
+0101000
++4006 0 -4009 0 *
+Ve
+1.820000002e-05
+9 3 34
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 206 0 2.84981632232666 2.86369451098663
+2 375 51 45 2.84981632232666 2.86369451098663
+2 376 182 0 2.84981632232666 2.86369451098663
+0
+0101000
++4004 0 -4008 0 *
+Ve
+1.860000002e-05
+-9 -3 34
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 207 0 -4.5 1.5
+2 377 51 45 -4.5 1.5
+2 378 183 0 -4.5 1.5
+0
+0101000
++4002 0 -4006 0 *
+Ve
+1.820000002e-05
+9 -3 34
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 208 0 -4.5 1.5
+2 379 51 45 -4.5 1.5
+2 380 184 0 -4.5 1.5
+0
+0101000
++4000 0 -4004 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 34
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 209 0 -4.51387818865997 -4.5
+2 381 51 45 -4.51387818865997 -4.5
+2 382 185 0 -4.51387818865997 -4.5
+0
+0101000
++3998 0 -4002 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 34
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 210 0 -4.51387818865997 -4.5
+2 383 51 45 -4.51387818865997 -4.5
+2 384 186 0 -4.51387818865997 -4.5
+0
+0101000
++3996 0 -4000 0 *
+Ed
+1 204 0 5.0336775696495 7.53269304470967
+2 371 51 45 5.0336775696495 7.53269304470967
+2 372 180 0 5.0336775696495 7.53269304470967
+0
+0101000
++3998 0 -3996 0 *
+Wi
+0101100
++4007 0 -4005 0 +4003 0 -4001 0 +3999 0 -3997 0 +3995 0 +3994 0 *
+Wi
+0101100
+-4354 0 *
+Ve
+1.93291820700634e-06
+-8.28533533832021 -3.75150004318693 34
+0 0
+0101101
+Ve
+-8.89749336242676 -3.08288931846619 34
+0 0
+0101101
+Ed
+ 2.66453525910038e-15 1 1 0
+1 211 0 0.960742403776357 1.86726198309587
+2 385 51 45 0.960742403776357 1.86726198309587
+2 386 187 0 0.960742403776357 1.86726198309587
+0
+0101000
++3991 0 -3990 0 *
+Ve
+-7.77440595626831 -3.54477834701538 34
+0 0
+0101101
+Ed
+ 2.74654007911334e-15 1 1 0
+1 212 0 3.99260976224734 4.54377461336901
+2 387 51 45 3.99260976224734 4.54377461336901
+2 388 188 0 3.99260976224734 4.54377461336901
+0
+0101000
++3988 0 -3991 0 *
+Ve
+-8.89749336242676 3.0519425868988 34
+0 0
+0101101
+Ed
+ 6.66133814775094e-16 1 1 0
+1 213 0 -4.60886061191559 1.5259712934494
+2 389 51 45 -4.60886061191559 1.5259712934494
+2 390 189 0 -4.60886061191559 1.5259712934494
+0
+0101000
++3990 0 -3986 0 *
+Ve
+-7.27440595626831 -3.54477834701538 34
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 214 0 3.38720297813416 3.88720297813416
+2 391 51 45 3.38720297813416 3.88720297813416
+2 392 190 0 3.38720297813416 3.88720297813416
+0
+0101000
++3984 0 -3988 0 *
+Ve
+-8.1806824381779 3.86953123903098 34
+0 0
+0101101
+Ed
+ 2.97904098389673e-15 1 1 0
+1 215 0 -2.32905062921582 -1.24172864138617
+2 393 51 45 -2.32905062921582 -1.24172864138617
+2 394 191 0 -2.32905062921582 -1.24172864138617
+0
+0101000
++3986 0 -3982 0 *
+Ve
+-7.27440595626831 -2.80323314666748 34
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 216 0 1.03084397315979 1.77238917350769
+2 395 51 45 1.03084397315979 1.77238917350769
+2 396 192 0 1.03084397315979 1.77238917350769
+0
+0101000
++3980 0 -3984 0 *
+Ve
+-7.77440595626831 3.54477834701538 34
+0 0
+0101101
+Ed
+ 1.88411095042053e-15 1 1 0
+1 217 0 -4.66313880732698 -4.14301860907919
+2 397 51 45 -4.66313880732698 -4.14301860907919
+2 398 193 0 -4.66313880732698 -4.14301860907919
+0
+0101000
++3982 0 -3978 0 *
+Ve
+-6.96637487411499 -2.80323314666748 34
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 218 0 3.32917189598083 3.63720297813416
+2 399 51 45 3.32917189598083 3.63720297813416
+2 400 194 0 3.32917189598083 3.63720297813416
+0
+0101000
++3976 0 -3980 0 *
+Ve
+-7.27440595626831 3.54477834701538 34
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 219 0 -4.13720297813416 -3.63720297813416
+2 401 51 45 -4.13720297813416 -3.63720297813416
+2 402 195 0 -4.13720297813416 -3.63720297813416
+0
+0101000
++3978 0 -3974 0 *
+Ve
+-6.96637487411499 2.80323314666748 34
+0 0
+0101101
+Ed
+1 220 0 -4.20484972000122 1.40161657333374
+2 403 51 45 -4.20484972000122 1.40161657333374
+2 404 196 0 -4.20484972000122 1.40161657333374
+0
+0101000
++3972 0 -3976 0 *
+Ve
+-7.27440595626831 2.80323314666748 34
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 221 0 -2.14316177368164 -1.40161657333374
+2 405 51 45 -2.14316177368164 -1.40161657333374
+2 406 197 0 -2.14316177368164 -1.40161657333374
+0
+0101000
++3974 0 -3970 0 *
+Ed
+ 0 1 1 0
+1 222 0 -3.79121851921082 -3.4831874370575
+2 407 51 45 -3.79121851921082 -3.4831874370575
+2 408 198 0 -3.79121851921082 -3.4831874370575
+0
+0101000
++3970 0 -3972 0 *
+Wi
+0101100
++3989 0 +3987 0 +3985 0 +3983 0 +3981 0 +3979 0 +3977 0 +3975 0 +3973 0 +3971 0
++3969 0 +3968 0 *
+Ve
+2.05654520055555e-06
+8.28533533832021 -3.75150004318693 34
+0 0
+0101101
+Ve
+8.89749336242676 -3.08288931846619 34
+0 0
+0101101
+Ed
+1 223 0 0.960742403776357 1.86726198309587
+2 409 51 45 0.960742403776357 1.86726198309587
+2 410 199 0 0.960742403776357 1.86726198309587
+0
+0101000
++3966 0 -3965 0 *
+Ve
+7.77440595626831 -3.54477834701538 34
+0 0
+0101101
+Ed
+1 224 0 3.99260976224734 4.54377461336901
+2 411 51 45 3.99260976224734 4.54377461336901
+2 412 200 0 3.99260976224734 4.54377461336901
+0
+0101000
++3963 0 -3966 0 *
+Ve
+8.89749336242676 3.0519425868988 34
+0 0
+0101101
+Ed
+1 225 0 -4.60886061191559 1.5259712934494
+2 413 51 45 -4.60886061191559 1.5259712934494
+2 414 201 0 -4.60886061191559 1.5259712934494
+0
+0101000
++3965 0 -3961 0 *
+Ve
+7.27440595626831 -3.54477834701538 34
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 226 0 3.38720297813416 3.88720297813416
+2 415 51 45 3.38720297813416 3.88720297813416
+2 416 202 0 3.38720297813416 3.88720297813416
+0
+0101000
++3959 0 -3963 0 *
+Ve
+8.1806824381779 3.86953123903098 34
+0 0
+0101101
+Ed
+1 227 0 -2.32905062921582 -1.24172864138617
+2 417 51 45 -2.32905062921582 -1.24172864138617
+2 418 203 0 -2.32905062921582 -1.24172864138617
+0
+0101000
++3961 0 -3957 0 *
+Ve
+7.27440595626831 -2.80323314666748 34
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 228 0 1.03084397315979 1.77238917350769
+2 419 51 45 1.03084397315979 1.77238917350769
+2 420 204 0 1.03084397315979 1.77238917350769
+0
+0101000
++3955 0 -3959 0 *
+Ve
+7.77440595626831 3.54477834701538 34
+0 0
+0101101
+Ed
+1 229 0 -4.66313880732698 -4.14301860907919
+2 421 51 45 -4.66313880732698 -4.14301860907919
+2 422 205 0 -4.66313880732698 -4.14301860907919
+0
+0101000
++3957 0 -3953 0 *
+Ve
+6.96637487411499 -2.80323314666748 34
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 230 0 3.32917189598083 3.63720297813416
+2 423 51 45 3.32917189598083 3.63720297813416
+2 424 206 0 3.32917189598083 3.63720297813416
+0
+0101000
++3951 0 -3955 0 *
+Ve
+7.27440595626831 3.54477834701538 34
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 231 0 -4.13720297813416 -3.63720297813416
+2 425 51 45 -4.13720297813416 -3.63720297813416
+2 426 207 0 -4.13720297813416 -3.63720297813416
+0
+0101000
++3953 0 -3949 0 *
+Ve
+6.96637487411499 2.80323314666748 34
+0 0
+0101101
+Ed
+1 232 0 -4.20484972000122 1.40161657333374
+2 427 51 45 -4.20484972000122 1.40161657333374
+2 428 208 0 -4.20484972000122 1.40161657333374
+0
+0101000
++3947 0 -3951 0 *
+Ve
+7.27440595626831 2.80323314666748 34
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 233 0 -2.14316177368164 -1.40161657333374
+2 429 51 45 -2.14316177368164 -1.40161657333374
+2 430 209 0 -2.14316177368164 -1.40161657333374
+0
+0101000
++3949 0 -3945 0 *
+Ed
+ 0 1 1 0
+1 234 0 -3.79121851921082 -3.4831874370575
+2 431 51 45 -3.79121851921082 -3.4831874370575
+2 432 210 0 -3.79121851921082 -3.4831874370575
+0
+0101000
++3945 0 -3947 0 *
+Wi
+0101100
+-3964 0 -3962 0 -3960 0 -3958 0 -3956 0 -3954 0 -3952 0 -3950 0 -3948 0 -3946 0
+-3944 0 -3943 0 *
+Ve
+-2 4.75 34
+0 0
+0101101
+Ve
+-2 6.75 34
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 235 0 1.375 3.375
+2 433 51 45 1.375 3.375
+2 434 211 0 1.375 3.375
+0
+0101000
++3941 0 -3940 0 *
+Ve
+2 4.75 34
+0 0
+0101101
+Ed
+ 3.33066907387547e-16 1 1 0
+1 236 0 -3 1
+2 435 51 45 -3 1
+2 436 212 0 -3 1
+0
+0101000
++3938 0 -3941 0 *
+Ve
+2 6.75 34
+0 0
+0101101
+Ed
+1 237 0 -3 1
+2 437 51 45 -3 1
+2 438 213 0 -3 1
+0
+0101000
++3940 0 -3936 0 *
+Ed
+ 0 1 1 0
+1 238 0 -4.375 -2.375
+2 439 51 45 -4.375 -2.375
+2 440 214 0 -4.375 -2.375
+0
+0101000
++3936 0 -3938 0 *
+Wi
+0101100
++3939 0 +3937 0 +3935 0 +3934 0 *
+Ve
+1.91491871856074e-06
+-2 -4.75 34
+0 0
+0101101
+Ve
+-2 -6.75 34
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 239 0 1.375 3.375
+2 441 51 45 1.375 3.375
+2 442 215 0 1.375 3.375
+0
+0101000
++3932 0 -3931 0 *
+Ve
+2 -4.75 34
+0 0
+0101101
+Ed
+1 240 0 -3 1
+2 443 51 45 -3 1
+2 444 216 0 -3 1
+0
+0101000
++3929 0 -3932 0 *
+Ve
+2 -6.75 34
+0 0
+0101101
+Ed
+1 241 0 -3 1
+2 445 51 45 -3 1
+2 446 217 0 -3 1
+0
+0101000
++3931 0 -3927 0 *
+Ed
+ 0 1 1 0
+1 242 0 -4.375 -2.375
+2 447 51 45 -4.375 -2.375
+2 448 218 0 -4.375 -2.375
+0
+0101000
++3927 0 -3929 0 *
+Wi
+0101100
+-3930 0 -3928 0 -3926 0 -3925 0 *
+Fa
+0 1e-07 51 0
+0101000
++3993 61 +3992 61 +3967 61 +3942 61 +3933 61 +3924 61 *
+Ve
+1e-07
+0.583333333333333 0 2.375
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 243 0 0 0.583333333333333
+3 449 450CN 53 0 0 0.583333333333333
+0
+0101000
+-4350 0 +3922 0 *
+Ed
+ 1e-07 1 1 0
+1 244 0 0 6.28318530717959
+2 451 53 0 0 6.28318530717959
+2 452 219 0 0 6.28318530717959
+0
+0101100
++3922 0 -3922 0 *
+Wi
+0101100
++3921 0 -4349 0 +3920 0 -3921 0 *
+Fa
+0 1e-07 53 0
+0101000
++3919 0 *
+Ve
+3.6542586680505e-07
+9.55759993925662 -0.32381343297006 -2.75
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 76 0 0 0.472437057647218
+0
+0101000
+-3917 63 +4346 0 *
+Ed
+ 2.68656194039624e-15 1 1 0
+1 245 0 -3.5 -2.77555756156289e-15
+2 453 220 64 -3.5 -2.77555756156289e-15
+2 454 54 56 -3.5 -2.77555756156289e-15
+0
+0101000
++3917 0 -4347 0 *
+Ed
+ 1e-07 1 1 0
+1 246 0 0 3.5
+2 455 55 0 0 3.5
+0
+0101000
++4346 0 -4346 43 *
+Wi
+0101100
+-3916 64 -3915 0 +3914 64 +4345 55 *
+Fa
+0 1e-07 220 0
+0101000
++3913 63 *
+Ed
+ 1e-07 1 1 0
+1 247 0 0 3.5
+2 456 56 0 0 3.5
+2 457 54 0 0 3.5
+0
+0101000
++4344 0 -4344 57 *
+Ed
+ 1e-07 1 1 0
+0
+0101000
+-3917 66 +4344 0 *
+Wi
+0101100
+-4343 56 +3915 0 +3911 56 +3910 65 *
+Fa
+0 1e-07 54 0
+0101000
++3909 59 *
+Ed
+ 1e-07 1 1 0
+1 248 0 0 3.5
+2 458 57 0 0 3.5
+2 459 55 0 0 3.5
+0
+0101000
++4342 0 -4342 43 *
+Wi
+0101000
++3907 0 -3914 0 -4341 0 +4341 43 *
+Fa
+0 1e-07 55 0
+0101000
++3906 0 *
+Ed
+ 1e-07 1 1 0
+1 249 0 0 3.5
+2 460 58 0 0 3.5
+2 461 56 0 0 3.5
+0
+0101000
++4340 0 -4340 57 *
+Wi
+0101000
++3904 0 -3911 0 -4339 0 +4339 57 *
+Fa
+0 1e-07 56 0
+0101000
++3903 0 *
+Ed
+ 1e-07 1 1 0
+1 250 0 0 3.5
+2 462 59 0 0 3.5
+2 463 57 0 0 3.5
+0
+0101000
++4338 0 -4338 43 *
+Wi
+0101000
++3901 0 -3907 0 -4337 0 +4337 43 *
+Fa
+0 1e-07 57 0
+0101000
++3900 0 *
+Ed
+ 1e-07 1 1 0
+1 251 0 0 3.5
+2 464 58 0 0 3.5
+0
+0101000
++4336 0 -4336 57 *
+Wi
+0101000
++3898 0 -3904 0 -4335 0 +4335 57 *
+Fa
+0 1e-07 58 0
+0101000
++3897 0 *
+Ed
+ 1e-07 1 1 0
+1 252 0 0 3.5
+2 465 59 0 0 3.5
+0
+0101000
++4334 0 -4334 43 *
+Wi
+0101000
++3895 0 -3901 0 -4333 0 +4333 43 *
+Fa
+0 1e-07 59 0
+0101000
++3894 0 *
+Ed
+ 1e-07 1 1 0
+1 253 0 0 3.5
+2 466 60 0 0 3.5
+0
+0101000
++4332 0 -4332 57 *
+Wi
+0101000
++3892 0 -3898 0 -4331 0 +4331 57 *
+Fa
+0 1e-07 221 0
+0101000
++3891 0 *
+Ed
+ 1e-07 1 1 0
+1 254 0 0 3.5
+2 467 61 0 0 3.5
+0
+0101000
++4330 0 -4330 43 *
+Wi
+0101000
++3889 0 -3895 0 -4329 0 +4329 43 *
+Fa
+0 1e-07 222 0
+0101000
++3888 0 *
+Ed
+ 1e-07 1 1 0
+1 255 0 0 3.5
+2 468 62 0 0 3.5
+2 469 60 0 0 3.5
+0
+0101000
++4328 0 -4328 57 *
+Wi
+0101000
++3886 0 -3892 0 -4327 0 +4327 57 *
+Fa
+0 1e-07 60 0
+0101000
++3885 0 *
+Ed
+ 1e-07 1 1 0
+1 256 0 0 3.5
+2 470 63 0 0 3.5
+2 471 61 0 0 3.5
+0
+0101000
++4326 0 -4326 43 *
+Wi
+0101000
++3883 0 -3889 0 -4325 0 +4325 43 *
+Fa
+0 1e-07 61 0
+0101000
++3882 0 *
+Ed
+ 1e-07 1 1 0
+1 257 0 0 3.5
+2 472 64 0 0 3.5
+2 473 62 0 0 3.5
+0
+0101000
++4324 0 -4324 57 *
+Wi
+0101000
++3880 0 -3886 0 -4323 0 +4323 57 *
+Fa
+0 1e-07 62 0
+0101000
++3879 0 *
+Ed
+ 1e-07 1 1 0
+1 258 0 0 3.5
+2 474 65 0 0 3.5
+2 475 63 0 0 3.5
+0
+0101000
++4322 0 -4322 43 *
+Wi
+0101000
++3877 0 -3883 0 -4321 0 +4321 43 *
+Fa
+0 1e-07 63 0
+0101000
++3876 0 *
+Ed
+ 1e-07 1 1 0
+1 259 0 0 3.5
+2 476 64 0 0 3.5
+0
+0101000
++4320 0 -4320 57 *
+Wi
+0101000
++3874 0 -3880 0 -4319 0 +4319 57 *
+Fa
+0 1e-07 64 0
+0101000
++3873 0 *
+Ed
+ 1e-07 1 1 0
+1 260 0 0 3.5
+2 477 65 0 0 3.5
+0
+0101000
++4318 0 -4318 43 *
+Wi
+0101000
++3871 0 -3877 0 -4317 0 +4317 43 *
+Fa
+0 1e-07 65 0
+0101000
++3870 0 *
+Ed
+ 1e-07 1 1 0
+1 261 0 0 3.5
+2 478 66 0 0 3.5
+0
+0101000
++4316 0 -4316 57 *
+Wi
+0101000
++3868 0 -3874 0 -4315 0 +4315 57 *
+Fa
+0 1e-07 223 0
+0101000
++3867 0 *
+Ed
+ 1e-07 1 1 0
+1 262 0 0 3.5
+2 479 67 0 0 3.5
+0
+0101000
++4314 0 -4314 43 *
+Wi
+0101000
++3865 0 -3871 0 -4313 0 +4313 43 *
+Fa
+0 1e-07 224 0
+0101000
++3864 0 *
+Ed
+ 1e-07 1 1 0
+1 263 0 0 3.5
+2 480 68 0 0 3.5
+2 481 66 0 0 3.5
+0
+0101000
++4312 0 -4312 57 *
+Wi
+0101000
++3862 0 -3868 0 -4311 0 +4311 57 *
+Fa
+0 1e-07 66 0
+0101000
++3861 0 *
+Ed
+ 1e-07 1 1 0
+1 264 0 0 3.5
+2 482 69 0 0 3.5
+2 483 67 0 0 3.5
+0
+0101000
++4310 0 -4310 43 *
+Wi
+0101000
++3859 0 -3865 0 -4309 0 +4309 43 *
+Fa
+0 1e-07 67 0
+0101000
++3858 0 *
+Ed
+ 1e-07 1 1 0
+1 265 0 0 3.5
+2 484 70 0 0 3.5
+2 485 68 0 0 3.5
+0
+0101000
++4308 0 -4308 57 *
+Wi
+0101000
++3856 0 -3862 0 -4307 0 +4307 57 *
+Fa
+0 1e-07 68 0
+0101000
++3855 0 *
+Ed
+ 1e-07 1 1 0
+1 266 0 0 3.5
+2 486 71 0 0 3.5
+2 487 69 0 0 3.5
+0
+0101000
++4306 0 -4306 43 *
+Wi
+0101000
++3853 0 -3859 0 -4305 0 +4305 43 *
+Fa
+0 1e-07 69 0
+0101000
++3852 0 *
+Ed
+ 1e-07 1 1 0
+1 267 0 0 3.5
+2 488 70 0 0 3.5
+0
+0101000
++4304 0 -4304 57 *
+Wi
+0101000
++3850 0 -3856 0 -4303 0 +4303 57 *
+Fa
+0 1e-07 70 0
+0101000
++3849 0 *
+Ed
+ 1e-07 1 1 0
+1 268 0 0 3.5
+2 489 71 0 0 3.5
+0
+0101000
++4302 0 -4302 43 *
+Wi
+0101000
++3847 0 -3853 0 -4301 0 +4301 43 *
+Fa
+0 1e-07 71 0
+0101000
++3846 0 *
+Ed
+ 1e-07 1 1 0
+1 269 0 0 3.5
+2 490 72 0 0 3.5
+0
+0101000
++4300 0 -4300 57 *
+Wi
+0101000
++3844 0 -3850 0 -4299 0 +4299 57 *
+Fa
+0 1e-07 225 0
+0101000
++3843 0 *
+Ed
+ 1e-07 1 1 0
+1 270 0 0 3.5
+2 491 73 0 0 3.5
+0
+0101000
++4298 0 -4298 43 *
+Wi
+0101000
++3841 0 -3847 0 -4297 0 +4297 43 *
+Fa
+0 1e-07 226 0
+0101000
++3840 0 *
+Ed
+ 1e-07 1 1 0
+1 271 0 0 3.5
+2 492 74 0 0 3.5
+2 493 72 0 0 3.5
+0
+0101000
++4296 0 -4296 57 *
+Wi
+0101000
++3838 0 -3844 0 -4295 0 +4295 57 *
+Fa
+0 1e-07 72 0
+0101000
++3837 0 *
+Ed
+ 1e-07 1 1 0
+1 272 0 0 3.5
+2 494 75 0 0 3.5
+2 495 73 0 0 3.5
+0
+0101000
++4294 0 -4294 43 *
+Wi
+0101000
++3835 0 -3841 0 -4293 0 +4293 43 *
+Fa
+0 1e-07 73 0
+0101000
++3834 0 *
+Ed
+ 1e-07 1 1 0
+1 273 0 0 3.5
+2 496 76 0 0 3.5
+2 497 74 0 0 3.5
+0
+0101000
++4292 0 -4292 57 *
+Wi
+0101000
++3832 0 -3838 0 -4291 0 +4291 57 *
+Fa
+0 1e-07 74 0
+0101000
++3831 0 *
+Ed
+ 1e-07 1 1 0
+1 274 0 0 3.5
+2 498 77 0 0 3.5
+2 499 75 0 0 3.5
+0
+0101000
++4290 0 -4290 43 *
+Wi
+0101000
++3829 0 -3835 0 -4289 0 +4289 43 *
+Fa
+0 1e-07 75 0
+0101000
++3828 0 *
+Ed
+ 1e-07 1 1 0
+1 275 0 0 3.5
+2 500 76 0 0 3.5
+0
+0101000
++4288 0 -4288 57 *
+Wi
+0101000
++3826 0 -3832 0 -4287 0 +4287 57 *
+Fa
+0 1e-07 76 0
+0101000
++3825 0 *
+Ed
+ 1e-07 1 1 0
+1 276 0 0 3.5
+2 501 77 0 0 3.5
+0
+0101000
++4286 0 -4286 43 *
+Wi
+0101000
++3823 0 -3829 0 -4285 0 +4285 43 *
+Fa
+0 1e-07 77 0
+0101000
++3822 0 *
+Ed
+ 1e-07 1 1 0
+1 277 0 0 3.5
+2 502 78 0 0 3.5
+0
+0101000
++4284 0 -4284 57 *
+Wi
+0101000
++3820 0 -3826 0 -4283 0 +4283 57 *
+Fa
+0 1e-07 227 0
+0101000
++3819 0 *
+Ed
+ 1e-07 1 1 0
+1 278 0 0 3.5
+2 503 79 0 0 3.5
+0
+0101000
++4282 0 -4282 43 *
+Wi
+0101000
++3817 0 -3823 0 -4281 0 +4281 43 *
+Fa
+0 1e-07 228 0
+0101000
++3816 0 *
+Ed
+ 1e-07 1 1 0
+1 279 0 0 3.5
+2 504 80 0 0 3.5
+2 505 78 0 0 3.5
+0
+0101000
++4280 0 -4280 57 *
+Wi
+0101000
++3814 0 -3820 0 -4279 0 +4279 57 *
+Fa
+0 1e-07 78 0
+0101000
++3813 0 *
+Ed
+ 1e-07 1 1 0
+1 280 0 0 3.5
+2 506 81 0 0 3.5
+2 507 79 0 0 3.5
+0
+0101000
++4278 0 -4278 43 *
+Wi
+0101000
++3811 0 -3817 0 -4277 0 +4277 43 *
+Fa
+0 1e-07 79 0
+0101000
++3810 0 *
+Ed
+ 1e-07 1 1 0
+1 281 0 0 3.5
+2 508 82 0 0 3.5
+2 509 80 0 0 3.5
+0
+0101000
++4276 0 -4276 57 *
+Wi
+0101000
++3808 0 -3814 0 -4275 0 +4275 57 *
+Fa
+0 1e-07 80 0
+0101000
++3807 0 *
+Ed
+ 1e-07 1 1 0
+1 282 0 0 3.5
+2 510 83 0 0 3.5
+2 511 81 0 0 3.5
+0
+0101000
++4274 0 -4274 43 *
+Wi
+0101000
++3805 0 -3811 0 -4273 0 +4273 43 *
+Fa
+0 1e-07 81 0
+0101000
++3804 0 *
+Ed
+ 1e-07 1 1 0
+1 283 0 0 3.5
+2 512 82 0 0 3.5
+0
+0101000
++4272 0 -4272 57 *
+Wi
+0101000
++3802 0 -3808 0 -4271 0 +4271 57 *
+Fa
+0 1e-07 82 0
+0101000
++3801 0 *
+Ed
+ 1e-07 1 1 0
+1 284 0 0 3.5
+2 513 83 0 0 3.5
+0
+0101000
++4270 0 -4270 43 *
+Wi
+0101000
++3799 0 -3805 0 -4269 0 +4269 43 *
+Fa
+0 1e-07 83 0
+0101000
++3798 0 *
+Ed
+ 1e-07 1 1 0
+1 285 0 0 3.5
+2 514 84 0 0 3.5
+0
+0101000
++4268 0 -4268 57 *
+Wi
+0101000
++3796 0 -3802 0 -4267 0 +4267 57 *
+Fa
+0 1e-07 229 0
+0101000
++3795 0 *
+Ed
+ 1e-07 1 1 0
+1 286 0 0 3.5
+2 515 85 0 0 3.5
+0
+0101000
++4266 0 -4266 43 *
+Wi
+0101000
++3793 0 -3799 0 -4265 0 +4265 43 *
+Fa
+0 1e-07 230 0
+0101000
++3792 0 *
+Ed
+ 1e-07 1 1 0
+1 287 0 0 3.5
+2 516 86 0 0 3.5
+2 517 84 0 0 3.5
+0
+0101000
++4264 0 -4264 57 *
+Wi
+0101000
++3790 0 -3796 0 -4263 0 +4263 57 *
+Fa
+0 1e-07 84 0
+0101000
++3789 0 *
+Ed
+ 1e-07 1 1 0
+1 288 0 0 3.5
+2 518 87 0 0 3.5
+2 519 85 0 0 3.5
+0
+0101000
++4262 0 -4262 43 *
+Wi
+0101000
++3787 0 -3793 0 -4261 0 +4261 43 *
+Fa
+0 1e-07 85 0
+0101000
++3786 0 *
+Ed
+ 1e-07 1 1 0
+1 289 0 0 3.5
+2 520 86 0 0 3.5
+2 521 88 0 0 3.5
+0
+0101000
++4260 0 -4260 57 *
+Wi
+0101000
++3784 0 -3790 0 -4259 0 +4259 57 *
+Fa
+0 1e-07 86 0
+0101000
++3783 0 *
+Ed
+ 1e-07 1 1 0
+1 290 0 0 3.5
+2 522 89 0 0 3.5
+2 523 87 0 0 3.5
+0
+0101000
++4258 0 -4258 43 *
+Wi
+0101000
++3781 0 -3787 0 -4257 0 +4257 43 *
+Fa
+0 1e-07 87 0
+0101000
++3780 0 *
+Ed
+ 1e-07 1 1 0
+1 291 0 0 3.5
+2 524 88 0 0 3.5
+0
+0101000
++4256 0 -4256 57 *
+Wi
+0101000
++3778 0 -3784 0 -4255 0 +4255 57 *
+Fa
+0 1e-07 88 0
+0101000
++3777 0 *
+Ed
+ 1e-07 1 1 0
+1 292 0 0 3.5
+2 525 89 0 0 3.5
+0
+0101000
++4254 0 -4254 43 *
+Wi
+0101000
++3775 0 -3781 0 -4253 0 +4253 43 *
+Fa
+0 1e-07 89 0
+0101000
++3774 0 *
+Ed
+ 1e-07 1 1 0
+1 293 0 0 3.5
+2 526 90 0 0 3.5
+0
+0101000
++4252 0 -4252 57 *
+Wi
+0101000
++3772 0 -3778 0 -4251 0 +4251 57 *
+Fa
+0 1e-07 231 0
+0101000
++3771 0 *
+Ed
+ 1e-07 1 1 0
+1 294 0 0 3.5
+2 527 91 0 0 3.5
+0
+0101000
++4250 0 -4250 43 *
+Wi
+0101000
++3769 0 -3775 0 -4249 0 +4249 43 *
+Fa
+0 1e-07 232 0
+0101000
++3768 0 *
+Ed
+ 1e-07 1 1 0
+1 295 0 0 3.5
+2 528 92 0 0 3.5
+2 529 90 0 0 3.5
+0
+0101000
++4248 0 -4248 57 *
+Wi
+0101000
++3766 0 -3772 0 -4247 0 +4247 57 *
+Fa
+0 1e-07 90 0
+0101000
++3765 0 *
+Ed
+ 1e-07 1 1 0
+1 296 0 0 3.5
+2 530 93 0 0 3.5
+2 531 91 0 0 3.5
+0
+0101000
++4246 0 -4246 43 *
+Wi
+0101000
++3763 0 -3769 0 -4245 0 +4245 43 *
+Fa
+0 1e-07 91 0
+0101000
++3762 0 *
+Ed
+ 1e-07 1 1 0
+1 297 0 0 3.5
+2 532 94 0 0 3.5
+2 533 92 0 0 3.5
+0
+0101000
++4244 0 -4244 57 *
+Wi
+0101000
++3760 0 -3766 0 -4243 0 +4243 57 *
+Fa
+0 1e-07 92 0
+0101000
++3759 0 *
+Ed
+ 1e-07 1 1 0
+1 298 0 0 3.5
+2 534 95 0 0 3.5
+2 535 93 0 0 3.5
+0
+0101000
++4242 0 -4242 43 *
+Wi
+0101000
++3757 0 -3763 0 -4241 0 +4241 43 *
+Fa
+0 1e-07 93 0
+0101000
++3756 0 *
+Ed
+ 1e-07 1 1 0
+1 299 0 0 3.5
+2 536 94 0 0 3.5
+0
+0101000
++4240 0 -4240 57 *
+Wi
+0101000
++3754 0 -3760 0 -4239 0 +4239 57 *
+Fa
+0 1e-07 94 0
+0101000
++3753 0 *
+Ed
+ 1e-07 1 1 0
+1 300 0 0 3.5
+2 537 95 0 0 3.5
+0
+0101000
++4238 0 -4238 43 *
+Wi
+0101000
++3751 0 -3757 0 -4237 0 +4237 43 *
+Fa
+0 1e-07 95 0
+0101000
++3750 0 *
+Ed
+ 1e-07 1 1 0
+1 301 0 0 3.5
+2 538 96 0 0 3.5
+0
+0101000
++4236 0 -4236 57 *
+Wi
+0101000
++3748 0 -3754 0 -4235 0 +4235 57 *
+Fa
+0 1e-07 233 0
+0101000
++3747 0 *
+Ed
+ 1e-07 1 1 0
+1 302 0 0 3.5
+2 539 97 0 0 3.5
+0
+0101000
++4234 0 -4234 43 *
+Wi
+0101000
++3745 0 -3751 0 -4233 0 +4233 43 *
+Fa
+0 1e-07 234 0
+0101000
++3744 0 *
+Ed
+ 1e-07 1 1 0
+1 303 0 0 3.5
+2 540 98 0 0 3.5
+2 541 96 0 0 3.5
+0
+0101000
++4232 0 -4232 57 *
+Wi
+0101000
++3742 0 -3748 0 -4231 0 +4231 57 *
+Fa
+0 1e-07 96 0
+0101000
++3741 0 *
+Ed
+ 1e-07 1 1 0
+1 304 0 0 3.5
+2 542 99 0 0 3.5
+2 543 97 0 0 3.5
+0
+0101000
++4230 0 -4230 43 *
+Wi
+0101000
++3739 0 -3745 0 -4229 0 +4229 43 *
+Fa
+0 1e-07 97 0
+0101000
++3738 0 *
+Ed
+ 1e-07 1 1 0
+1 305 0 0 3.5
+2 544 100 0 0 3.5
+2 545 98 0 0 3.5
+0
+0101000
++4228 0 -4228 57 *
+Wi
+0101000
++3736 0 -3742 0 -4227 0 +4227 57 *
+Fa
+0 1e-07 98 0
+0101000
++3735 0 *
+Ed
+ 1e-07 1 1 0
+1 306 0 0 3.5
+2 546 101 0 0 3.5
+2 547 99 0 0 3.5
+0
+0101000
++4226 0 -4226 43 *
+Wi
+0101000
++3733 0 -3739 0 -4225 0 +4225 43 *
+Fa
+0 1e-07 99 0
+0101000
++3732 0 *
+Ed
+ 1e-07 1 1 0
+1 307 0 0 3.5
+2 548 100 0 0 3.5
+0
+0101000
++4224 0 -4224 57 *
+Wi
+0101000
++3730 0 -3736 0 -4223 0 +4223 57 *
+Fa
+0 1e-07 100 0
+0101000
++3729 0 *
+Ed
+ 1e-07 1 1 0
+1 308 0 0 3.5
+2 549 101 0 0 3.5
+0
+0101000
++4222 0 -4222 43 *
+Wi
+0101000
++3727 0 -3733 0 -4221 0 +4221 43 *
+Fa
+0 1e-07 101 0
+0101000
++3726 0 *
+Ed
+ 1e-07 1 1 0
+1 309 0 0 3.5
+2 550 102 0 0 3.5
+0
+0101000
++4220 0 -4220 57 *
+Wi
+0101000
++3724 0 -3730 0 -4219 0 +4219 57 *
+Fa
+0 1e-07 235 0
+0101000
++3723 0 *
+Ed
+ 1e-07 1 1 0
+1 310 0 0 3.5
+2 551 103 0 0 3.5
+0
+0101000
++4218 0 -4218 43 *
+Wi
+0101000
++3721 0 -3727 0 -4217 0 +4217 43 *
+Fa
+0 1e-07 236 0
+0101000
++3720 0 *
+Ed
+ 1e-07 1 1 0
+1 311 0 0 3.5
+2 552 104 0 0 3.5
+2 553 102 0 0 3.5
+0
+0101000
++4216 0 -4216 57 *
+Wi
+0101000
++3718 0 -3724 0 -4215 0 +4215 57 *
+Fa
+0 1e-07 102 0
+0101000
++3717 0 *
+Ed
+ 1e-07 1 1 0
+1 312 0 0 3.5
+2 554 105 0 0 3.5
+2 555 103 0 0 3.5
+0
+0101000
++4214 0 -4214 43 *
+Wi
+0101000
++3715 0 -3721 0 -4213 0 +4213 43 *
+Fa
+0 1e-07 103 0
+0101000
++3714 0 *
+Ed
+ 1e-07 1 1 0
+1 313 0 0 3.5
+2 556 106 0 0 3.5
+2 557 104 0 0 3.5
+0
+0101000
++4212 0 -4212 57 *
+Wi
+0101000
++3712 0 -3718 0 -4211 0 +4211 57 *
+Fa
+0 1e-07 104 0
+0101000
++3711 0 *
+Ed
+ 1e-07 1 1 0
+1 314 0 0 3.5
+2 558 107 0 0 3.5
+2 559 105 0 0 3.5
+0
+0101000
++4210 0 -4210 43 *
+Wi
+0101000
++3709 0 -3715 0 -4209 0 +4209 43 *
+Fa
+0 1e-07 105 0
+0101000
++3708 0 *
+Ed
+ 1e-07 1 1 0
+1 315 0 0 3.5
+2 560 106 0 0 3.5
+0
+0101000
++4208 0 -4208 57 *
+Wi
+0101000
++3706 0 -3712 0 -4207 0 +4207 57 *
+Fa
+0 1e-07 106 0
+0101000
++3705 0 *
+Ed
+ 1e-07 1 1 0
+1 316 0 0 3.5
+2 561 107 0 0 3.5
+0
+0101000
++4206 0 -4206 43 *
+Wi
+0101000
++3703 0 -3709 0 -4205 0 +4205 43 *
+Fa
+0 1e-07 107 0
+0101000
++3702 0 *
+Ed
+ 1e-07 1 1 0
+1 317 0 0 3.5
+2 562 108 0 0 3.5
+0
+0101000
++4204 0 -4204 57 *
+Wi
+0101000
++3700 0 -3706 0 -4203 0 +4203 57 *
+Fa
+0 1e-07 237 0
+0101000
++3699 0 *
+Ed
+ 1e-07 1 1 0
+1 318 0 0 3.5
+2 563 109 0 0 3.5
+0
+0101000
++4202 0 -4202 43 *
+Wi
+0101000
++3697 0 -3703 0 -4201 0 +4201 43 *
+Fa
+0 1e-07 238 0
+0101000
++3696 0 *
+Ed
+ 1e-07 1 1 0
+1 319 0 0 3.5
+2 564 110 0 0 3.5
+2 565 108 0 0 3.5
+0
+0101000
++4200 0 -4200 57 *
+Wi
+0101000
++3694 0 -3700 0 -4199 0 +4199 57 *
+Fa
+0 1e-07 108 0
+0101000
++3693 0 *
+Ed
+ 1e-07 1 1 0
+1 320 0 0 3.5
+2 566 111 0 0 3.5
+2 567 109 0 0 3.5
+0
+0101000
++4198 0 -4198 43 *
+Wi
+0101000
++3691 0 -3697 0 -4197 0 +4197 43 *
+Fa
+0 1e-07 109 0
+0101000
++3690 0 *
+Ed
+ 1e-07 1 1 0
+1 321 0 0 3.5
+2 568 112 0 0 3.5
+2 569 110 0 0 3.5
+0
+0101000
++4196 0 -4196 57 *
+Wi
+0101000
++3688 0 -3694 0 -4195 0 +4195 57 *
+Fa
+0 1e-07 110 0
+0101000
++3687 0 *
+Ed
+ 1e-07 1 1 0
+1 322 0 0 3.5
+2 570 113 0 0 3.5
+2 571 111 0 0 3.5
+0
+0101000
++4194 0 -4194 43 *
+Wi
+0101000
++3685 0 -3691 0 -4193 0 +4193 43 *
+Fa
+0 1e-07 111 0
+0101000
++3684 0 *
+Ed
+ 1e-07 1 1 0
+1 323 0 0 3.5
+2 572 112 0 0 3.5
+0
+0101000
++4192 0 -4192 57 *
+Wi
+0101000
++3682 0 -3688 0 -4191 0 +4191 57 *
+Fa
+0 1e-07 112 0
+0101000
++3681 0 *
+Ed
+ 1e-07 1 1 0
+1 324 0 0 3.5
+2 573 113 0 0 3.5
+0
+0101000
++4190 0 -4190 43 *
+Wi
+0101000
++3679 0 -3685 0 -4189 0 +4189 43 *
+Fa
+0 1e-07 113 0
+0101000
++3678 0 *
+Ed
+ 1e-07 1 1 0
+1 325 0 0 3.5
+2 574 114 0 0 3.5
+0
+0101000
++4188 0 -4188 57 *
+Wi
+0101000
++3676 0 -3682 0 -4187 0 +4187 57 *
+Fa
+0 1e-07 239 0
+0101000
++3675 0 *
+Ed
+ 1e-07 1 1 0
+1 326 0 0 3.5
+2 575 115 0 0 3.5
+0
+0101000
++4186 0 -4186 43 *
+Wi
+0101000
++3673 0 -3679 0 -4185 0 +4185 43 *
+Fa
+0 1e-07 240 0
+0101000
++3672 0 *
+Ed
+ 1e-07 1 1 0
+1 327 0 0 3.5
+2 576 116 0 0 3.5
+2 577 114 0 0 3.5
+0
+0101000
++4184 0 -4184 57 *
+Wi
+0101000
++3670 0 -3676 0 -4183 0 +4183 57 *
+Fa
+0 1e-07 114 0
+0101000
++3669 0 *
+Ed
+ 1e-07 1 1 0
+1 328 0 0 3.5
+2 578 117 0 0 3.5
+2 579 115 0 0 3.5
+0
+0101000
++4182 0 -4182 43 *
+Wi
+0101000
++3667 0 -3673 0 -4181 0 +4181 43 *
+Fa
+0 1e-07 115 0
+0101000
++3666 0 *
+Ed
+ 1e-07 1 1 0
+1 329 0 0 3.5
+2 580 118 0 0 3.5
+2 581 116 0 0 3.5
+0
+0101000
++4180 0 -4180 57 *
+Wi
+0101000
++3664 0 -3670 0 -4179 0 +4179 57 *
+Fa
+0 1e-07 116 0
+0101000
++3663 0 *
+Ed
+ 1e-07 1 1 0
+1 330 0 0 3.5
+2 582 119 0 0 3.5
+2 583 117 0 0 3.5
+0
+0101000
++4178 0 -4178 43 *
+Wi
+0101000
++3661 0 -3667 0 -4177 0 +4177 43 *
+Fa
+0 1e-07 117 0
+0101000
++3660 0 *
+Ed
+ 1e-07 1 1 0
+1 331 0 0 3.5
+2 584 118 0 0 3.5
+0
+0101000
++4176 0 -4176 57 *
+Wi
+0101000
++3658 0 -3664 0 -4175 0 +4175 57 *
+Fa
+0 1e-07 118 0
+0101000
++3657 0 *
+Ed
+ 1e-07 1 1 0
+1 332 0 0 3.5
+2 585 119 0 0 3.5
+0
+0101000
++4174 0 -4174 43 *
+Wi
+0101000
++3655 0 -3661 0 -4173 0 +4173 43 *
+Fa
+0 1e-07 119 0
+0101000
++3654 0 *
+Ed
+ 1e-07 1 1 0
+1 333 0 0 3.5
+2 586 120 0 0 3.5
+0
+0101000
++4172 0 -4172 57 *
+Wi
+0101000
++3652 0 -3658 0 -4171 0 +4171 57 *
+Fa
+0 1e-07 241 0
+0101000
++3651 0 *
+Ed
+ 1e-07 1 1 0
+1 334 0 0 3.5
+2 587 121 0 0 3.5
+0
+0101000
++4170 0 -4170 43 *
+Wi
+0101000
++3649 0 -3655 0 -4169 0 +4169 43 *
+Fa
+0 1e-07 242 0
+0101000
++3648 0 *
+Ed
+ 1e-07 1 1 0
+1 335 0 0 3.5
+2 588 122 0 0 3.5
+2 589 120 0 0 3.5
+0
+0101000
++4168 0 -4168 57 *
+Wi
+0101000
++3646 0 -3652 0 -4167 0 +4167 57 *
+Fa
+0 1e-07 120 0
+0101000
++3645 0 *
+Ed
+ 1e-07 1 1 0
+1 336 0 0 3.5
+2 590 123 0 0 3.5
+2 591 121 0 0 3.5
+0
+0101000
++4166 0 -4166 43 *
+Wi
+0101000
++3643 0 -3649 0 -4165 0 +4165 43 *
+Fa
+0 1e-07 121 0
+0101000
++3642 0 *
+Ed
+ 1e-07 1 1 0
+1 337 0 0 3.5
+2 592 124 0 0 3.5
+2 593 122 0 0 3.5
+0
+0101000
++4164 0 -4164 57 *
+Wi
+0101000
++3640 0 -3646 0 -4163 0 +4163 57 *
+Fa
+0 1e-07 122 0
+0101000
++3639 0 *
+Ed
+ 1e-07 1 1 0
+1 338 0 0 3.5
+2 594 125 0 0 3.5
+2 595 123 0 0 3.5
+0
+0101000
++4162 0 -4162 43 *
+Wi
+0101000
++3637 0 -3643 0 -4161 0 +4161 43 *
+Fa
+0 1e-07 123 0
+0101000
++3636 0 *
+Ed
+ 1e-07 1 1 0
+1 339 0 0 3.5
+2 596 124 0 0 3.5
+0
+0101000
++4160 0 -4160 57 *
+Wi
+0101000
++3634 0 -3640 0 -4159 0 +4159 57 *
+Fa
+0 1e-07 124 0
+0101000
++3633 0 *
+Ed
+ 1e-07 1 1 0
+1 340 0 0 3.5
+2 597 125 0 0 3.5
+0
+0101000
++4158 0 -4158 43 *
+Wi
+0101000
++3631 0 -3637 0 -4157 0 +4157 43 *
+Fa
+0 1e-07 125 0
+0101000
++3630 0 *
+Ve
+8.84212561159607 0.0243489537268056 -2.75
+0 0
+0101101
+Ed
+ 2.67111366666145e-15 1 1 0
+1 341 0 -3.5 -0
+2 598 126 64 -3.5 -0
+2 599 243 56 -3.5 -0
+0
+0101000
++4156 0 -3628 0 *
+Ed
+ 1e-07 1 1 0
+0
+0101000
++3628 66 -4160 0 *
+Wi
+0101100
+-4155 56 +3627 0 -3634 56 +3626 65 *
+Fa
+0 1e-07 243 0
+0101000
++3625 59 *
+Ed
+ 1e-07 1 1 0
+1 342 0 0 3.5
+2 600 127 0 0 3.5
+0
+0101000
++4154 0 -4154 43 *
+Wi
+0101000
++3623 0 -3631 0 -4153 0 +4153 43 *
+Fa
+0 1e-07 244 0
+0101000
++3622 0 *
+Ed
+ 1e-07 1 1 0
+0
+0101000
++3628 63 -4152 0 *
+Ed
+ 1e-07 1 1 0
+1 343 0 0 3.5
+2 601 128 0 0 3.5
+2 602 126 0 0 3.5
+0
+0101000
++4152 0 -4152 43 *
+Wi
+0101100
+-3620 64 -3627 0 -3619 64 +4151 55 *
+Fa
+0 1e-07 126 0
+0101000
++3618 63 *
+Ed
+ 1e-07 1 1 0
+1 344 0 0 3.5
+2 603 129 0 0 3.5
+2 604 127 0 0 3.5
+0
+0101000
++4150 0 -4150 43 *
+Wi
+0101000
++3616 0 -3623 0 -4149 0 +4149 43 *
+Fa
+0 1e-07 127 0
+0101000
++3615 0 *
+Ed
+ 1e-07 1 1 0
+1 345 0 0 3.5
+2 605 128 0 0 3.5
+2 606 130 0 0 3.5
+0
+0101000
++4148 0 -4148 43 *
+Wi
+0101000
++3619 0 -3613 0 -4147 0 +4147 43 *
+Fa
+0 1e-07 128 0
+0101000
++3612 0 *
+Ed
+ 1e-07 1 1 0
+1 346 0 0 3.5
+2 607 131 0 0 3.5
+2 608 129 0 0 3.5
+0
+0101000
++4146 0 -4146 43 *
+Wi
+0101000
++3610 0 -3616 0 -4145 0 +4145 43 *
+Fa
+0 1e-07 129 0
+0101000
++3609 0 *
+Ed
+ 1e-07 1 1 0
+1 347 0 0 3.5
+2 609 130 0 0 3.5
+0
+0101000
++4144 0 -4144 43 *
+Wi
+0101000
++3613 0 -3607 0 -4143 0 +4143 43 *
+Fa
+0 1e-07 130 0
+0101000
++3606 0 *
+Ed
+ 1e-07 1 1 0
+1 348 0 0 3.5
+2 610 131 0 0 3.5
+0
+0101000
++4142 0 -4142 43 *
+Wi
+0101000
++3604 0 -3610 0 -4141 0 +4141 43 *
+Fa
+0 1e-07 131 0
+0101000
++3603 0 *
+Ed
+ 1e-07 1 1 0
+1 349 0 0 3.5
+2 611 132 0 0 3.5
+0
+0101000
++4140 0 -4140 43 *
+Wi
+0101000
++3607 0 -3601 0 -4139 0 +4139 43 *
+Fa
+0 1e-07 245 0
+0101000
++3600 0 *
+Ed
+ 1e-07 1 1 0
+1 350 0 0 3.5
+2 612 133 0 0 3.5
+0
+0101000
++4138 0 -4138 43 *
+Wi
+0101000
++3598 0 -3604 0 -4137 0 +4137 43 *
+Fa
+0 1e-07 246 0
+0101000
++3597 0 *
+Ed
+ 1e-07 1 1 0
+1 351 0 0 3.5
+2 613 132 0 0 3.5
+2 614 134 0 0 3.5
+0
+0101000
++4136 0 -4136 43 *
+Wi
+0101000
++3601 0 -3595 0 -4135 0 +4135 43 *
+Fa
+0 1e-07 132 0
+0101000
++3594 0 *
+Ed
+ 1e-07 1 1 0
+1 352 0 0 3.5
+2 615 135 0 0 3.5
+2 616 133 0 0 3.5
+0
+0101000
++4134 0 -4134 43 *
+Wi
+0101000
++3592 0 -3598 0 -4133 0 +4133 43 *
+Fa
+0 1e-07 133 0
+0101000
++3591 0 *
+Ed
+ 1e-07 1 1 0
+1 353 0 0 3.5
+2 617 134 0 0 3.5
+2 618 136 0 0 3.5
+0
+0101000
++4132 0 -4132 43 *
+Wi
+0101000
++3595 0 -3589 0 -4131 0 +4131 43 *
+Fa
+0 1e-07 134 0
+0101000
++3588 0 *
+Ed
+ 1e-07 1 1 0
+1 354 0 0 3.5
+2 619 137 0 0 3.5
+2 620 135 0 0 3.5
+0
+0101000
++4130 0 -4130 43 *
+Wi
+0101000
++3586 0 -3592 0 -4129 0 +4129 43 *
+Fa
+0 1e-07 135 0
+0101000
++3585 0 *
+Ed
+ 1e-07 1 1 0
+1 355 0 0 3.5
+2 621 136 0 0 3.5
+0
+0101000
++4128 0 -4128 43 *
+Wi
+0101000
++3589 0 -3583 0 -4127 0 +4127 43 *
+Fa
+0 1e-07 136 0
+0101000
++3582 0 *
+Ed
+ 1e-07 1 1 0
+1 356 0 0 3.5
+2 622 137 0 0 3.5
+0
+0101000
++4126 0 -4126 43 *
+Wi
+0101000
++3580 0 -3586 0 -4125 0 +4125 43 *
+Fa
+0 1e-07 137 0
+0101000
++3579 0 *
+Ed
+ 1e-07 1 1 0
+1 357 0 0 3.5
+2 623 138 0 0 3.5
+0
+0101000
++4124 0 -4124 43 *
+Wi
+0101000
++3583 0 -3577 0 -4123 0 +4123 43 *
+Fa
+0 1e-07 247 0
+0101000
++3576 0 *
+Ed
+ 1e-07 1 1 0
+1 358 0 0 3.5
+2 624 139 0 0 3.5
+0
+0101000
++4122 0 -4122 43 *
+Wi
+0101000
++3574 0 -3580 0 -4121 0 +4121 43 *
+Fa
+0 1e-07 248 0
+0101000
++3573 0 *
+Ed
+ 1e-07 1 1 0
+1 359 0 0 3.5
+2 625 138 0 0 3.5
+2 626 140 0 0 3.5
+0
+0101000
++4120 0 -4120 43 *
+Wi
+0101000
++3577 0 -3571 0 -4119 0 +4119 43 *
+Fa
+0 1e-07 138 0
+0101000
++3570 0 *
+Ed
+ 1e-07 1 1 0
+1 360 0 0 3.5
+2 627 141 0 0 3.5
+2 628 139 0 0 3.5
+0
+0101000
++4118 0 -4118 43 *
+Wi
+0101000
++3568 0 -3574 0 -4117 0 +4117 43 *
+Fa
+0 1e-07 139 0
+0101000
++3567 0 *
+Ed
+ 1e-07 1 1 0
+1 361 0 0 3.5
+2 629 140 0 0 3.5
+2 630 142 0 0 3.5
+0
+0101000
++4116 0 -4116 43 *
+Wi
+0101000
++3571 0 -3565 0 -4115 0 +4115 43 *
+Fa
+0 1e-07 140 0
+0101000
++3564 0 *
+Ed
+ 1e-07 1 1 0
+1 362 0 0 3.5
+2 631 143 0 0 3.5
+2 632 141 0 0 3.5
+0
+0101000
++4114 0 -4114 43 *
+Wi
+0101000
++3562 0 -3568 0 -4113 0 +4113 43 *
+Fa
+0 1e-07 141 0
+0101000
++3561 0 *
+Ed
+ 1e-07 1 1 0
+1 363 0 0 3.5
+2 633 142 0 0 3.5
+0
+0101000
++4112 0 -4112 43 *
+Wi
+0101000
++3565 0 -3559 0 -4111 0 +4111 43 *
+Fa
+0 1e-07 142 0
+0101000
++3558 0 *
+Ed
+ 1e-07 1 1 0
+1 364 0 0 3.5
+2 634 143 0 0 3.5
+0
+0101000
++4110 0 -4110 43 *
+Wi
+0101000
++3556 0 -3562 0 -4109 0 +4109 43 *
+Fa
+0 1e-07 143 0
+0101000
++3555 0 *
+Ed
+ 1e-07 1 1 0
+1 365 0 0 3.5
+2 635 144 0 0 3.5
+0
+0101000
++4108 0 -4108 43 *
+Wi
+0101000
++3559 0 -3553 0 -4107 0 +4107 43 *
+Fa
+0 1e-07 249 0
+0101000
++3552 0 *
+Ed
+ 1e-07 1 1 0
+1 366 0 0 3.5
+2 636 145 0 0 3.5
+0
+0101000
++4106 0 -4106 43 *
+Wi
+0101000
++3550 0 -3556 0 -4105 0 +4105 43 *
+Fa
+0 1e-07 250 0
+0101000
++3549 0 *
+Ed
+ 1e-07 1 1 0
+1 367 0 0 3.5
+2 637 144 0 0 3.5
+2 638 146 0 0 3.5
+0
+0101000
++4104 0 -4104 43 *
+Wi
+0101000
++3553 0 -3547 0 -4103 0 +4103 43 *
+Fa
+0 1e-07 144 0
+0101000
++3546 0 *
+Ed
+ 1e-07 1 1 0
+1 368 0 0 3.5
+2 639 147 0 0 3.5
+2 640 145 0 0 3.5
+0
+0101000
++4102 0 -4102 43 *
+Wi
+0101000
++3544 0 -3550 0 -4101 0 +4101 43 *
+Fa
+0 1e-07 145 0
+0101000
++3543 0 *
+Ed
+ 1e-07 1 1 0
+1 369 0 0 3.5
+2 641 146 0 0 3.5
+2 642 148 0 0 3.5
+0
+0101000
++4100 0 -4100 43 *
+Wi
+0101000
++3547 0 -3541 0 -4099 0 +4099 43 *
+Fa
+0 1e-07 146 0
+0101000
++3540 0 *
+Ed
+ 1e-07 1 1 0
+1 370 0 0 3.5
+2 643 149 0 0 3.5
+2 644 147 0 0 3.5
+0
+0101000
++4098 0 -4098 43 *
+Wi
+0101000
++3538 0 -3544 0 -4097 0 +4097 43 *
+Fa
+0 1e-07 147 0
+0101000
++3537 0 *
+Ed
+ 1e-07 1 1 0
+1 371 0 0 3.5
+2 645 148 0 0 3.5
+0
+0101000
++4096 0 -4096 43 *
+Wi
+0101000
++3541 0 -3535 0 -4095 0 +4095 43 *
+Fa
+0 1e-07 148 0
+0101000
++3534 0 *
+Ed
+ 1e-07 1 1 0
+1 372 0 0 3.5
+2 646 149 0 0 3.5
+0
+0101000
++4094 0 -4094 43 *
+Wi
+0101000
++3532 0 -3538 0 -4093 0 +4093 43 *
+Fa
+0 1e-07 149 0
+0101000
++3531 0 *
+Ed
+ 1e-07 1 1 0
+1 373 0 0 3.5
+2 647 150 0 0 3.5
+0
+0101000
++4092 0 -4092 43 *
+Wi
+0101000
++3535 0 -3529 0 -4091 0 +4091 43 *
+Fa
+0 1e-07 251 0
+0101000
++3528 0 *
+Ed
+ 1e-07 1 1 0
+1 374 0 0 3.5
+2 648 151 0 0 3.5
+0
+0101000
++4090 0 -4090 43 *
+Wi
+0101000
++3526 0 -3532 0 -4089 0 +4089 43 *
+Fa
+0 1e-07 252 0
+0101000
++3525 0 *
+Ed
+ 1e-07 1 1 0
+1 375 0 0 3.5
+2 649 150 0 0 3.5
+2 650 152 0 0 3.5
+0
+0101000
++4088 0 -4088 43 *
+Wi
+0101000
++3529 0 -3523 0 -4087 0 +4087 43 *
+Fa
+0 1e-07 150 0
+0101000
++3522 0 *
+Ed
+ 1e-07 1 1 0
+1 376 0 0 3.5
+2 651 153 0 0 3.5
+2 652 151 0 0 3.5
+0
+0101000
++4086 0 -4086 43 *
+Wi
+0101000
++3520 0 -3526 0 -4085 0 +4085 43 *
+Fa
+0 1e-07 151 0
+0101000
++3519 0 *
+Ed
+ 1e-07 1 1 0
+1 377 0 0 3.5
+2 653 152 0 0 3.5
+2 654 154 0 0 3.5
+0
+0101000
++4084 0 -4084 43 *
+Wi
+0101000
++3523 0 -3517 0 -4083 0 +4083 43 *
+Fa
+0 1e-07 152 0
+0101000
++3516 0 *
+Ed
+ 1e-07 1 1 0
+1 378 0 0 3.5
+2 655 155 0 0 3.5
+2 656 153 0 0 3.5
+0
+0101000
++4082 0 -4082 43 *
+Wi
+0101000
++3514 0 -3520 0 -4081 0 +4081 43 *
+Fa
+0 1e-07 153 0
+0101000
++3513 0 *
+Ed
+ 1e-07 1 1 0
+1 379 0 0 3.5
+2 657 154 0 0 3.5
+0
+0101000
++4080 0 -4080 43 *
+Wi
+0101000
++3517 0 -3511 0 -4079 0 +4079 43 *
+Fa
+0 1e-07 154 0
+0101000
++3510 0 *
+Ed
+ 1e-07 1 1 0
+1 380 0 0 3.5
+2 658 155 0 0 3.5
+0
+0101000
++4078 0 -4078 43 *
+Wi
+0101000
++3508 0 -3514 0 -4077 0 +4077 43 *
+Fa
+0 1e-07 155 0
+0101000
++3507 0 *
+Ed
+ 1e-07 1 1 0
+1 381 0 0 3.5
+2 659 156 0 0 3.5
+0
+0101000
++4076 0 -4076 43 *
+Wi
+0101000
++3511 0 -3505 0 -4075 0 +4075 43 *
+Fa
+0 1e-07 253 0
+0101000
++3504 0 *
+Ed
+ 1e-07 1 1 0
+1 382 0 0 3.5
+2 660 157 0 0 3.5
+0
+0101000
++4074 0 -4074 43 *
+Wi
+0101000
++3502 0 -3508 0 -4073 0 +4073 43 *
+Fa
+0 1e-07 254 0
+0101000
++3501 0 *
+Ed
+ 1e-07 1 1 0
+1 383 0 0 3.5
+2 661 156 0 0 3.5
+2 662 158 0 0 3.5
+0
+0101000
++4072 0 -4072 43 *
+Wi
+0101000
++3505 0 -3499 0 -4071 0 +4071 43 *
+Fa
+0 1e-07 156 0
+0101000
++3498 0 *
+Ed
+ 1e-07 1 1 0
+1 384 0 0 3.5
+2 663 159 0 0 3.5
+2 664 157 0 0 3.5
+0
+0101000
++4070 0 -4070 43 *
+Wi
+0101000
++3496 0 -3502 0 -4069 0 +4069 43 *
+Fa
+0 1e-07 157 0
+0101000
++3495 0 *
+Ed
+ 1e-07 1 1 0
+1 385 0 0 3.5
+2 665 158 0 0 3.5
+2 666 160 0 0 3.5
+0
+0101000
++4068 0 -4068 43 *
+Wi
+0101000
++3499 0 -3493 0 -4067 0 +4067 43 *
+Fa
+0 1e-07 158 0
+0101000
++3492 0 *
+Ed
+ 1e-07 1 1 0
+1 386 0 0 3.5
+2 667 161 0 0 3.5
+2 668 159 0 0 3.5
+0
+0101000
++4066 0 -4066 43 *
+Wi
+0101000
++3490 0 -3496 0 -4065 0 +4065 43 *
+Fa
+0 1e-07 159 0
+0101000
++3489 0 *
+Ed
+ 1e-07 1 1 0
+1 387 0 0 3.5
+2 669 160 0 0 3.5
+0
+0101000
++4064 0 -4064 43 *
+Wi
+0101000
++3493 0 -3487 0 -4063 0 +4063 43 *
+Fa
+0 1e-07 160 0
+0101000
++3486 0 *
+Ed
+ 1e-07 1 1 0
+1 388 0 0 3.5
+2 670 161 0 0 3.5
+0
+0101000
++4062 0 -4062 43 *
+Wi
+0101000
++3484 0 -3490 0 -4061 0 +4061 43 *
+Fa
+0 1e-07 161 0
+0101000
++3483 0 *
+Ed
+ 1e-07 1 1 0
+1 389 0 0 3.5
+2 671 162 0 0 3.5
+0
+0101000
++4060 0 -4060 43 *
+Wi
+0101000
++3487 0 -3481 0 -4059 0 +4059 43 *
+Fa
+0 1e-07 255 0
+0101000
++3480 0 *
+Ed
+ 1e-07 1 1 0
+1 390 0 0 3.5
+2 672 163 0 0 3.5
+0
+0101000
++4058 0 -4058 43 *
+Wi
+0101000
++3478 0 -3484 0 -4057 0 +4057 43 *
+Fa
+0 1e-07 256 0
+0101000
++3477 0 *
+Ed
+ 1e-07 1 1 0
+1 391 0 0 3.5
+2 673 162 0 0 3.5
+2 674 164 0 0 3.5
+0
+0101000
++4056 0 -4056 43 *
+Wi
+0101000
++3481 0 -3475 0 -4055 0 +4055 43 *
+Fa
+0 1e-07 162 0
+0101000
++3474 0 *
+Ed
+ 1e-07 1 1 0
+1 392 0 0 3.5
+2 675 165 0 0 3.5
+2 676 163 0 0 3.5
+0
+0101000
++4054 0 -4054 43 *
+Wi
+0101000
++3472 0 -3478 0 -4053 0 +4053 43 *
+Fa
+0 1e-07 163 0
+0101000
++3471 0 *
+Ed
+ 1e-07 1 1 0
+1 393 0 0 3.5
+2 677 164 0 0 3.5
+2 678 166 0 0 3.5
+0
+0101000
++4052 0 -4052 43 *
+Wi
+0101000
++3475 0 -3469 0 -4051 0 +4051 43 *
+Fa
+0 1e-07 164 0
+0101000
++3468 0 *
+Ed
+ 1e-07 1 1 0
+1 394 0 0 3.5
+2 679 167 0 0 3.5
+2 680 165 0 0 3.5
+0
+0101000
++4050 0 -4050 43 *
+Wi
+0101000
++3466 0 -3472 0 -4049 0 +4049 43 *
+Fa
+0 1e-07 165 0
+0101000
++3465 0 *
+Ed
+ 1e-07 1 1 0
+1 395 0 0 3.5
+2 681 166 0 0 3.5
+0
+0101000
++4048 0 -4048 43 *
+Wi
+0101000
++3469 0 -3463 0 -4047 0 +4047 43 *
+Fa
+0 1e-07 166 0
+0101000
++3462 0 *
+Ed
+ 1e-07 1 1 0
+1 396 0 0 3.5
+2 682 167 0 0 3.5
+0
+0101000
++4046 0 -4046 43 *
+Wi
+0101000
++3460 0 -3466 0 -4045 0 +4045 43 *
+Fa
+0 1e-07 167 0
+0101000
++3459 0 *
+Ed
+ 1e-07 1 1 0
+1 397 0 0 3.5
+2 683 168 0 0 3.5
+0
+0101000
++4044 0 -4044 43 *
+Wi
+0101000
++3463 0 -3457 0 -4043 0 +4043 43 *
+Fa
+0 1e-07 257 0
+0101000
++3456 0 *
+Ed
+ 1e-07 1 1 0
+1 398 0 0 3.5
+2 684 169 0 0 3.5
+0
+0101000
++4042 0 -4042 43 *
+Wi
+0101000
++3454 0 -3460 0 -4041 0 +4041 43 *
+Fa
+0 1e-07 258 0
+0101000
++3453 0 *
+Ed
+ 1e-07 1 1 0
+1 399 0 0 3.5
+2 685 168 0 0 3.5
+2 686 170 0 0 3.5
+0
+0101000
++4040 0 -4040 43 *
+Wi
+0101000
++3457 0 -3451 0 -4039 0 +4039 43 *
+Fa
+0 1e-07 168 0
+0101000
++3450 0 *
+Ed
+ 1e-07 1 1 0
+1 400 0 0 3.5
+2 687 171 0 0 3.5
+2 688 169 0 0 3.5
+0
+0101000
++4038 0 -4038 43 *
+Wi
+0101000
++3448 0 -3454 0 -4037 0 +4037 43 *
+Fa
+0 1e-07 169 0
+0101000
++3447 0 *
+Ed
+ 1e-07 1 1 0
+1 401 0 0 3.5
+2 689 170 0 0 3.5
+2 690 172 0 0 3.5
+0
+0101000
++4036 0 -4036 43 *
+Wi
+0101000
++3451 0 -3445 0 -4035 0 +4035 43 *
+Fa
+0 1e-07 170 0
+0101000
++3444 0 *
+Ed
+ 1e-07 1 1 0
+1 402 0 0 3.5
+2 691 173 0 0 3.5
+2 692 171 0 0 3.5
+0
+0101000
++4034 0 -4034 43 *
+Wi
+0101000
++3442 0 -3448 0 -4033 0 +4033 43 *
+Fa
+0 1e-07 171 0
+0101000
++3441 0 *
+Ed
+ 1e-07 1 1 0
+1 403 0 0 3.5
+2 693 172 0 0 3.5
+0
+0101000
++4032 0 -4032 43 *
+Wi
+0101000
++3445 0 -3439 0 -4031 0 +4031 43 *
+Fa
+0 1e-07 172 0
+0101000
++3438 0 *
+Ed
+ 1e-07 1 1 0
+1 404 0 0 3.5
+2 694 173 0 0 3.5
+0
+0101000
++4030 0 -4030 43 *
+Wi
+0101000
++3436 0 -3442 0 -4029 0 +4029 43 *
+Fa
+0 1e-07 173 0
+0101000
++3435 0 *
+Ed
+ 1e-07 1 1 0
+1 405 0 0 3.5
+2 695 174 0 0 3.5
+0
+0101000
++4028 0 -4028 43 *
+Wi
+0101000
++3439 0 -3433 0 -4027 0 +4027 43 *
+Fa
+0 1e-07 259 0
+0101000
++3432 0 *
+Ed
+ 1e-07 1 1 0
+1 406 0 0 3.5
+2 696 175 0 0 3.5
+0
+0101000
++4026 0 -4026 43 *
+Wi
+0101000
++3430 0 -3436 0 -4025 0 +4025 43 *
+Fa
+0 1e-07 260 0
+0101000
++3429 0 *
+Ed
+ 1e-07 1 1 0
+1 407 0 0 3.5
+2 697 174 0 0 3.5
+2 698 176 0 0 3.5
+0
+0101000
++4024 0 -4024 43 *
+Wi
+0101000
++3433 0 -3427 0 -4023 0 +4023 43 *
+Fa
+0 1e-07 174 0
+0101000
++3426 0 *
+Ed
+ 1e-07 1 1 0
+1 408 0 0 3.5
+2 699 177 0 0 3.5
+2 700 175 0 0 3.5
+0
+0101000
++4022 0 -4022 43 *
+Wi
+0101000
++3424 0 -3430 0 -4021 0 +4021 43 *
+Fa
+0 1e-07 175 0
+0101000
++3423 0 *
+Ed
+ 1e-07 1 1 0
+1 409 0 0 3.5
+2 701 176 0 0 3.5
+2 702 178 0 0 3.5
+0
+0101000
++4020 0 -4020 43 *
+Wi
+0101000
++3427 0 -3421 0 -4019 0 +4019 43 *
+Fa
+0 1e-07 176 0
+0101000
++3420 0 *
+Ed
+ 1e-07 1 1 0
+1 410 0 0 3.5
+2 703 179 0 0 3.5
+2 704 177 0 0 3.5
+0
+0101000
++4018 0 -4018 43 *
+Wi
+0101000
++3418 0 -3424 0 -4017 0 +4017 43 *
+Fa
+0 1e-07 177 0
+0101000
++3417 0 *
+Ed
+ 1e-07 1 1 0
+1 411 0 0 3.5
+2 705 178 0 0 3.5
+0
+0101000
++4016 0 -4016 43 *
+Wi
+0101000
++3421 0 -3415 0 -4015 0 +4015 43 *
+Fa
+0 1e-07 178 0
+0101000
++3414 0 *
+Ed
+ 1e-07 1 1 0
+1 412 0 0 3.5
+2 706 179 0 0 3.5
+0
+0101000
++4014 0 -4014 43 *
+Wi
+0101000
++3412 0 -3418 0 -4013 0 +4013 43 *
+Fa
+0 1e-07 179 0
+0101000
++3411 0 *
+Wi
+0101000
++3415 0 -3412 0 -4012 0 +4012 43 *
+Fa
+0 1e-07 261 0
+0101000
++3409 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 33.9900000002235
+0 0
+0101101
+Ed
+ 9.49999999999956e-08 1 1 0
+1 413 0 31 31.0099999997765
+2 707 180 0 31 31.0099999997765
+2 708 181 0 31 31.0099999997765
+0
+0101000
++3407 0 -4009 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 33.9900000002235
+0 0
+0101101
+Ed
+1 414 0 31 31.0099999997765
+2 709 180 0 31 31.0099999997765
+2 710 182 0 31 31.0099999997765
+0
+0101000
++3405 0 -4008 0 *
+Ed
+ 1e-07 1 1 0
+1 415 0 3.55014770291568 6.04916317797585
+2 711 180 0 3.55014770291568 6.04916317797585
+2 712 262 0 3.55014770291568 6.04916317797585
+0
+0101000
++3407 0 -3405 0 *
+Wi
+0101100
++4007 0 -3406 0 +3404 0 +3403 0 *
+Fa
+0 1e-07 180 0
+0101000
++3402 0 *
+Ve
+1.860000002e-05
+-9 3 0
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 416 0 3.5 37.5
+0
+0101000
++3400 0 -4006 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 0
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 417 0 2.84981632232666 2.86369451098663
+2 713 51 0 2.84981632232666 2.86369451098663
+2 714 181 0 2.84981632232666 2.86369451098663
+0
+0101000
++3400 0 -3398 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 0.990000000223517
+0 0
+0101101
+Ed
+1 418 0 -2.99000000022352 -2
+2 715 263 0 -2.99000000022352 -2
+2 716 181 0 -2.99000000022352 -2
+0
+0101000
++3398 0 -3396 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 0.990000000223517
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 419 0 2.86369451098663 4.95161797791392
+2 717 264 0 2.86369451098663 4.95161797791392
+2 718 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3396 0 -3394 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 33.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 420 0 2.86369451098663 4.95161797791392
+2 719 262 0 2.86369451098663 4.95161797791392
+2 720 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3407 0 -3392 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 1.99000000022352
+0 0
+0101101
+Ed
+ 1.14999999999996e-07 1 1 0
+1 421 0 -1.99000000022352 -0.990000000223517
+2 721 265 0 -1.99000000022352 -0.990000000223517
+2 722 181 0 -1.99000000022352 -0.990000000223517
+0
+0101000
++3390 0 -3394 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 32.9900000002235
+0 0
+0101101
+Ed
+1 422 0 -33.9900000002235 -32.9900000002235
+2 723 265 0 -33.9900000002235 -32.9900000002235
+2 724 181 0 -33.9900000002235 -32.9900000002235
+0
+0101000
++3392 0 -3388 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 1.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 423 0 2.86369451098663 4.95161797791392
+2 725 266 0 2.86369451098663 4.95161797791392
+2 726 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3386 0 -3390 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 32.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 424 0 2.86369451098663 4.95161797791392
+2 727 267 0 2.86369451098663 4.95161797791392
+2 728 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3384 0 -3388 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 2.99000000022352
+0 0
+0101101
+Ed
+1 425 0 -1 0
+2 729 268 0 -1 0
+2 730 181 0 -1 0
+0
+0101000
++3386 0 -3382 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 31.9900000002235
+0 0
+0101101
+Ed
+1 426 0 29 30
+2 731 269 0 29 30
+2 732 181 0 29 30
+0
+0101000
++3380 0 -3384 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 2.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 427 0 2.86369451098663 4.95161797791392
+2 733 270 0 2.86369451098663 4.95161797791392
+2 734 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3382 0 -3378 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 31.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 428 0 2.86369451098663 4.95161797791392
+2 735 271 0 2.86369451098663 4.95161797791392
+2 736 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3380 0 -3376 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 3.99000000022352
+0 0
+0101101
+Ed
+1 429 0 -3.99000000022352 -2.99000000022352
+2 737 265 0 -3.99000000022352 -2.99000000022352
+2 738 181 0 -3.99000000022352 -2.99000000022352
+0
+0101000
++3374 0 -3378 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 30.9900000002235
+0 0
+0101101
+Ed
+1 430 0 -31.9900000002235 -30.9900000002235
+2 739 265 0 -31.9900000002235 -30.9900000002235
+2 740 181 0 -31.9900000002235 -30.9900000002235
+0
+0101000
++3376 0 -3372 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 3.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 431 0 2.86369451098663 4.95161797791392
+2 741 272 0 2.86369451098663 4.95161797791392
+2 742 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3370 0 -3374 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 30.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 432 0 2.86369451098663 4.95161797791392
+2 743 273 0 2.86369451098663 4.95161797791392
+2 744 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3368 0 -3372 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 5.99000000022352
+0 0
+0101101
+Ed
+1 433 0 1 3
+2 745 274 0 1 3
+2 746 181 0 1 3
+0
+0101000
++3370 0 -3366 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 28.9900000002235
+0 0
+0101101
+Ed
+1 434 0 26 28
+2 747 275 0 26 28
+2 748 181 0 26 28
+0
+0101000
++3364 0 -3368 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 5.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 435 0 2.86369451098663 4.95161797791392
+2 749 276 0 2.86369451098663 4.95161797791392
+2 750 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3366 0 -3362 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 28.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 436 0 2.86369451098663 4.95161797791392
+2 751 277 0 2.86369451098663 4.95161797791392
+2 752 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3364 0 -3360 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 6.99000000022352
+0 0
+0101101
+Ed
+1 437 0 -6.99000000022352 -5.99000000022352
+2 753 265 0 -6.99000000022352 -5.99000000022352
+2 754 181 0 -6.99000000022352 -5.99000000022352
+0
+0101000
++3358 0 -3362 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 27.9900000002235
+0 0
+0101101
+Ed
+1 438 0 -28.9900000002235 -27.9900000002235
+2 755 265 0 -28.9900000002235 -27.9900000002235
+2 756 181 0 -28.9900000002235 -27.9900000002235
+0
+0101000
++3360 0 -3356 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 6.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 439 0 2.86369451098663 4.95161797791392
+2 757 278 0 2.86369451098663 4.95161797791392
+2 758 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3354 0 -3358 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 27.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 440 0 2.86369451098663 4.95161797791392
+2 759 279 0 2.86369451098663 4.95161797791392
+2 760 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3352 0 -3356 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 7.99000000022352
+0 0
+0101101
+Ed
+1 441 0 4 5
+2 761 280 0 4 5
+2 762 181 0 4 5
+0
+0101000
++3354 0 -3350 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 26.9900000002235
+0 0
+0101101
+Ed
+1 442 0 24 25
+2 763 281 0 24 25
+2 764 181 0 24 25
+0
+0101000
++3348 0 -3352 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 7.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 443 0 2.86369451098663 4.95161797791392
+2 765 282 0 2.86369451098663 4.95161797791392
+2 766 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3350 0 -3346 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 26.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 444 0 2.86369451098663 4.95161797791392
+2 767 283 0 2.86369451098663 4.95161797791392
+2 768 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3348 0 -3344 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 8.99000000022352
+0 0
+0101101
+Ed
+1 445 0 -8.99000000022352 -7.99000000022352
+2 769 265 0 -8.99000000022352 -7.99000000022352
+2 770 181 0 -8.99000000022352 -7.99000000022352
+0
+0101000
++3342 0 -3346 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 25.9900000002235
+0 0
+0101101
+Ed
+1 446 0 -26.9900000002235 -25.9900000002235
+2 771 265 0 -26.9900000002235 -25.9900000002235
+2 772 181 0 -26.9900000002235 -25.9900000002235
+0
+0101000
++3344 0 -3340 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 8.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 447 0 2.86369451098663 4.95161797791392
+2 773 284 0 2.86369451098663 4.95161797791392
+2 774 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3338 0 -3342 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 25.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 448 0 2.86369451098663 4.95161797791392
+2 775 285 0 2.86369451098663 4.95161797791392
+2 776 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3336 0 -3340 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 10.9900000002235
+0 0
+0101101
+Ed
+1 449 0 6 8
+2 777 286 0 6 8
+2 778 181 0 6 8
+0
+0101000
++3338 0 -3334 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 23.9900000002235
+0 0
+0101101
+Ed
+1 450 0 21 23
+2 779 287 0 21 23
+2 780 181 0 21 23
+0
+0101000
++3332 0 -3336 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 10.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 451 0 2.86369451098663 4.95161797791392
+2 781 288 0 2.86369451098663 4.95161797791392
+2 782 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3334 0 -3330 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 23.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 452 0 2.86369451098663 4.95161797791392
+2 783 289 0 2.86369451098663 4.95161797791392
+2 784 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3332 0 -3328 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 11.9900000002235
+0 0
+0101101
+Ed
+1 453 0 -11.9900000002235 -10.9900000002235
+2 785 265 0 -11.9900000002235 -10.9900000002235
+2 786 181 0 -11.9900000002235 -10.9900000002235
+0
+0101000
++3326 0 -3330 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 22.9900000002235
+0 0
+0101101
+Ed
+1 454 0 -23.9900000002235 -22.9900000002235
+2 787 265 0 -23.9900000002235 -22.9900000002235
+2 788 181 0 -23.9900000002235 -22.9900000002235
+0
+0101000
++3328 0 -3324 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 11.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 455 0 2.86369451098663 4.95161797791392
+2 789 290 0 2.86369451098663 4.95161797791392
+2 790 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3322 0 -3326 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 22.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 456 0 2.86369451098663 4.95161797791392
+2 791 291 0 2.86369451098663 4.95161797791392
+2 792 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3320 0 -3324 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 12.9900000002235
+0 0
+0101101
+Ed
+1 457 0 9 10
+2 793 292 0 9 10
+2 794 181 0 9 10
+0
+0101000
++3322 0 -3318 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 21.9900000002235
+0 0
+0101101
+Ed
+1 458 0 19 20
+2 795 293 0 19 20
+2 796 181 0 19 20
+0
+0101000
++3316 0 -3320 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 12.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 459 0 2.86369451098663 4.95161797791392
+2 797 294 0 2.86369451098663 4.95161797791392
+2 798 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3318 0 -3314 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 21.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 460 0 2.86369451098663 4.95161797791392
+2 799 295 0 2.86369451098663 4.95161797791392
+2 800 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3316 0 -3312 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 13.9900000002235
+0 0
+0101101
+Ed
+1 461 0 -13.9900000002235 -12.9900000002235
+2 801 265 0 -13.9900000002235 -12.9900000002235
+2 802 181 0 -13.9900000002235 -12.9900000002235
+0
+0101000
++3310 0 -3314 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 20.9900000002235
+0 0
+0101101
+Ed
+1 462 0 -21.9900000002235 -20.9900000002235
+2 803 265 0 -21.9900000002235 -20.9900000002235
+2 804 181 0 -21.9900000002235 -20.9900000002235
+0
+0101000
++3312 0 -3308 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 13.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 463 0 2.86369451098663 4.95161797791392
+2 805 296 0 2.86369451098663 4.95161797791392
+2 806 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3306 0 -3310 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 20.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 464 0 2.86369451098663 4.95161797791392
+2 807 297 0 2.86369451098663 4.95161797791392
+2 808 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3304 0 -3308 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 15.9900000002235
+0 0
+0101101
+Ed
+1 465 0 11 13
+2 809 298 0 11 13
+2 810 181 0 11 13
+0
+0101000
++3306 0 -3302 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 18.9900000002235
+0 0
+0101101
+Ed
+1 466 0 16 18
+2 811 299 0 16 18
+2 812 181 0 16 18
+0
+0101000
++3300 0 -3304 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 15.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 467 0 2.86369451098663 4.95161797791392
+2 813 300 0 2.86369451098663 4.95161797791392
+2 814 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3302 0 -3298 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 18.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 468 0 2.86369451098663 4.95161797791392
+2 815 301 0 2.86369451098663 4.95161797791392
+2 816 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3300 0 -3296 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 16.9900000002235
+0 0
+0101101
+Ed
+1 469 0 -16.9900000002235 -15.9900000002235
+2 817 265 0 -16.9900000002235 -15.9900000002235
+2 818 181 0 -16.9900000002235 -15.9900000002235
+0
+0101000
++3294 0 -3298 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 3 17.9900000002235
+0 0
+0101101
+Ed
+1 470 0 -18.9900000002235 -17.9900000002235
+2 819 265 0 -18.9900000002235 -17.9900000002235
+2 820 181 0 -18.9900000002235 -17.9900000002235
+0
+0101000
++3296 0 -3292 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 16.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 471 0 2.86369451098663 4.95161797791392
+2 821 302 0 2.86369451098663 4.95161797791392
+2 822 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3290 0 -3294 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 3 17.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 472 0 2.86369451098663 4.95161797791392
+2 823 303 0 2.86369451098663 4.95161797791392
+2 824 181 0 2.86369451098663 4.95161797791392
+0
+0101000
++3288 0 -3292 0 *
+Ed
+1 473 0 14 15
+2 825 304 0 14 15
+2 826 181 0 14 15
+0
+0101000
++3290 0 -3288 0 *
+Wi
+0101100
+-3399 0 +3397 0 -4005 0 +3395 0 +3406 0 +3393 0 -3391 0 -3389 0 -3387 0 -3385 0
++3383 0 +3381 0 +3379 0 +3377 0 -3375 0 -3373 0 -3371 0 -3369 0 +3367 0 +3365 0
++3363 0 +3361 0 -3359 0 -3357 0 -3355 0 -3353 0 +3351 0 +3349 0 +3347 0 +3345 0
+-3343 0 -3341 0 -3339 0 -3337 0 +3335 0 +3333 0 +3331 0 +3329 0 -3327 0 -3325 0
+-3323 0 -3321 0 +3319 0 +3317 0 +3315 0 +3313 0 -3311 0 -3309 0 -3307 0 -3305 0
++3303 0 +3301 0 +3299 0 +3297 0 -3295 0 -3293 0 -3291 0 -3289 0 +3287 0 +3286 0
+Fa
+0 1e-07 181 0
+0101000
++3285 0 *
+Ve
+1.820000002e-05
+9 3 0
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 474 0 3.5 37.5
+0
+0101000
++3283 0 -4004 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 0
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 475 0 2.84981632232666 2.86369451098663
+2 827 51 0 2.84981632232666 2.86369451098663
+2 828 182 0 2.84981632232666 2.86369451098663
+0
+0101000
++3283 0 -3281 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 0.990000000223517
+0 0
+0101101
+Ed
+1 476 0 -2.99000000022352 -2
+2 829 263 0 -2.99000000022352 -2
+2 830 182 0 -2.99000000022352 -2
+0
+0101000
++3281 0 -3279 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 0.990000000223517
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 477 0 2.86369451098663 4.95161797791392
+2 831 264 0 2.86369451098663 4.95161797791392
+2 832 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3279 0 -3277 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 33.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 478 0 2.86369451098663 4.95161797791392
+2 833 262 0 2.86369451098663 4.95161797791392
+2 834 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3405 0 -3275 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 1.99000000022352
+0 0
+0101101
+Ed
+1 479 0 -1.99000000022352 -0.990000000223517
+2 835 265 0 -1.99000000022352 -0.990000000223517
+2 836 182 0 -1.99000000022352 -0.990000000223517
+0
+0101000
++3273 0 -3277 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 32.9900000002235
+0 0
+0101101
+Ed
+1 480 0 -33.9900000002235 -32.9900000002235
+2 837 265 0 -33.9900000002235 -32.9900000002235
+2 838 182 0 -33.9900000002235 -32.9900000002235
+0
+0101000
++3275 0 -3271 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 1.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 481 0 2.86369451098663 4.95161797791392
+2 839 266 0 2.86369451098663 4.95161797791392
+2 840 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3269 0 -3273 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 32.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 482 0 2.86369451098663 4.95161797791392
+2 841 267 0 2.86369451098663 4.95161797791392
+2 842 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3267 0 -3271 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 2.99000000022352
+0 0
+0101101
+Ed
+1 483 0 -1 0
+2 843 268 0 -1 0
+2 844 182 0 -1 0
+0
+0101000
++3269 0 -3265 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 31.9900000002235
+0 0
+0101101
+Ed
+1 484 0 29 30
+2 845 269 0 29 30
+2 846 182 0 29 30
+0
+0101000
++3263 0 -3267 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 2.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 485 0 2.86369451098663 4.95161797791392
+2 847 270 0 2.86369451098663 4.95161797791392
+2 848 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3265 0 -3261 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 31.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 486 0 2.86369451098663 4.95161797791392
+2 849 271 0 2.86369451098663 4.95161797791392
+2 850 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3263 0 -3259 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 3.99000000022352
+0 0
+0101101
+Ed
+1 487 0 -3.99000000022352 -2.99000000022352
+2 851 265 0 -3.99000000022352 -2.99000000022352
+2 852 182 0 -3.99000000022352 -2.99000000022352
+0
+0101000
++3257 0 -3261 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 30.9900000002235
+0 0
+0101101
+Ed
+1 488 0 -31.9900000002235 -30.9900000002235
+2 853 265 0 -31.9900000002235 -30.9900000002235
+2 854 182 0 -31.9900000002235 -30.9900000002235
+0
+0101000
++3259 0 -3255 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 3.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 489 0 2.86369451098663 4.95161797791392
+2 855 272 0 2.86369451098663 4.95161797791392
+2 856 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3253 0 -3257 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 30.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 490 0 2.86369451098663 4.95161797791392
+2 857 273 0 2.86369451098663 4.95161797791392
+2 858 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3251 0 -3255 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 5.99000000022352
+0 0
+0101101
+Ed
+1 491 0 1 3
+2 859 274 0 1 3
+2 860 182 0 1 3
+0
+0101000
++3253 0 -3249 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 28.9900000002235
+0 0
+0101101
+Ed
+1 492 0 26 28
+2 861 275 0 26 28
+2 862 182 0 26 28
+0
+0101000
++3247 0 -3251 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 5.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 493 0 2.86369451098663 4.95161797791392
+2 863 276 0 2.86369451098663 4.95161797791392
+2 864 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3249 0 -3245 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 28.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 494 0 2.86369451098663 4.95161797791392
+2 865 277 0 2.86369451098663 4.95161797791392
+2 866 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3247 0 -3243 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 6.99000000022352
+0 0
+0101101
+Ed
+1 495 0 -6.99000000022352 -5.99000000022352
+2 867 265 0 -6.99000000022352 -5.99000000022352
+2 868 182 0 -6.99000000022352 -5.99000000022352
+0
+0101000
++3241 0 -3245 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 27.9900000002235
+0 0
+0101101
+Ed
+1 496 0 -28.9900000002235 -27.9900000002235
+2 869 265 0 -28.9900000002235 -27.9900000002235
+2 870 182 0 -28.9900000002235 -27.9900000002235
+0
+0101000
++3243 0 -3239 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 6.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 497 0 2.86369451098663 4.95161797791392
+2 871 278 0 2.86369451098663 4.95161797791392
+2 872 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3237 0 -3241 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 27.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 498 0 2.86369451098663 4.95161797791392
+2 873 279 0 2.86369451098663 4.95161797791392
+2 874 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3235 0 -3239 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 7.99000000022352
+0 0
+0101101
+Ed
+1 499 0 4 5
+2 875 280 0 4 5
+2 876 182 0 4 5
+0
+0101000
++3237 0 -3233 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 26.9900000002235
+0 0
+0101101
+Ed
+1 500 0 24 25
+2 877 281 0 24 25
+2 878 182 0 24 25
+0
+0101000
++3231 0 -3235 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 7.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 501 0 2.86369451098663 4.95161797791392
+2 879 282 0 2.86369451098663 4.95161797791392
+2 880 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3233 0 -3229 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 26.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 502 0 2.86369451098663 4.95161797791392
+2 881 283 0 2.86369451098663 4.95161797791392
+2 882 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3231 0 -3227 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 8.99000000022352
+0 0
+0101101
+Ed
+1 503 0 -8.99000000022352 -7.99000000022352
+2 883 265 0 -8.99000000022352 -7.99000000022352
+2 884 182 0 -8.99000000022352 -7.99000000022352
+0
+0101000
++3225 0 -3229 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 25.9900000002235
+0 0
+0101101
+Ed
+1 504 0 -26.9900000002235 -25.9900000002235
+2 885 265 0 -26.9900000002235 -25.9900000002235
+2 886 182 0 -26.9900000002235 -25.9900000002235
+0
+0101000
++3227 0 -3223 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 8.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 505 0 2.86369451098663 4.95161797791392
+2 887 284 0 2.86369451098663 4.95161797791392
+2 888 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3221 0 -3225 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 25.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 506 0 2.86369451098663 4.95161797791392
+2 889 285 0 2.86369451098663 4.95161797791392
+2 890 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3219 0 -3223 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 10.9900000002235
+0 0
+0101101
+Ed
+1 507 0 6 8
+2 891 286 0 6 8
+2 892 182 0 6 8
+0
+0101000
++3221 0 -3217 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 23.9900000002235
+0 0
+0101101
+Ed
+1 508 0 21 23
+2 893 287 0 21 23
+2 894 182 0 21 23
+0
+0101000
++3215 0 -3219 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 10.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 509 0 2.86369451098663 4.95161797791392
+2 895 288 0 2.86369451098663 4.95161797791392
+2 896 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3217 0 -3213 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 23.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 510 0 2.86369451098663 4.95161797791392
+2 897 289 0 2.86369451098663 4.95161797791392
+2 898 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3215 0 -3211 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 11.9900000002235
+0 0
+0101101
+Ed
+1 511 0 -11.9900000002235 -10.9900000002235
+2 899 265 0 -11.9900000002235 -10.9900000002235
+2 900 182 0 -11.9900000002235 -10.9900000002235
+0
+0101000
++3209 0 -3213 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 22.9900000002235
+0 0
+0101101
+Ed
+1 512 0 -23.9900000002235 -22.9900000002235
+2 901 265 0 -23.9900000002235 -22.9900000002235
+2 902 182 0 -23.9900000002235 -22.9900000002235
+0
+0101000
++3211 0 -3207 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 11.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 513 0 2.86369451098663 4.95161797791392
+2 903 290 0 2.86369451098663 4.95161797791392
+2 904 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3205 0 -3209 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 22.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 514 0 2.86369451098663 4.95161797791392
+2 905 291 0 2.86369451098663 4.95161797791392
+2 906 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3203 0 -3207 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 12.9900000002235
+0 0
+0101101
+Ed
+1 515 0 9 10
+2 907 292 0 9 10
+2 908 182 0 9 10
+0
+0101000
++3205 0 -3201 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 21.9900000002235
+0 0
+0101101
+Ed
+1 516 0 19 20
+2 909 293 0 19 20
+2 910 182 0 19 20
+0
+0101000
++3199 0 -3203 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 12.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 517 0 2.86369451098663 4.95161797791392
+2 911 294 0 2.86369451098663 4.95161797791392
+2 912 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3201 0 -3197 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 21.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 518 0 2.86369451098663 4.95161797791392
+2 913 295 0 2.86369451098663 4.95161797791392
+2 914 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3199 0 -3195 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 13.9900000002235
+0 0
+0101101
+Ed
+1 519 0 -13.9900000002235 -12.9900000002235
+2 915 265 0 -13.9900000002235 -12.9900000002235
+2 916 182 0 -13.9900000002235 -12.9900000002235
+0
+0101000
++3193 0 -3197 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 20.9900000002235
+0 0
+0101101
+Ed
+1 520 0 -21.9900000002235 -20.9900000002235
+2 917 265 0 -21.9900000002235 -20.9900000002235
+2 918 182 0 -21.9900000002235 -20.9900000002235
+0
+0101000
++3195 0 -3191 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 13.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 521 0 2.86369451098663 4.95161797791392
+2 919 296 0 2.86369451098663 4.95161797791392
+2 920 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3189 0 -3193 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 20.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 522 0 2.86369451098663 4.95161797791392
+2 921 297 0 2.86369451098663 4.95161797791392
+2 922 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3187 0 -3191 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 15.9900000002235
+0 0
+0101101
+Ed
+1 523 0 11 13
+2 923 298 0 11 13
+2 924 182 0 11 13
+0
+0101000
++3189 0 -3185 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 18.9900000002235
+0 0
+0101101
+Ed
+1 524 0 16 18
+2 925 299 0 16 18
+2 926 182 0 16 18
+0
+0101000
++3183 0 -3187 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 15.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 525 0 2.86369451098663 4.95161797791392
+2 927 300 0 2.86369451098663 4.95161797791392
+2 928 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3185 0 -3181 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 18.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 526 0 2.86369451098663 4.95161797791392
+2 929 301 0 2.86369451098663 4.95161797791392
+2 930 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3183 0 -3179 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 16.9900000002235
+0 0
+0101101
+Ed
+1 527 0 -16.9900000002235 -15.9900000002235
+2 931 265 0 -16.9900000002235 -15.9900000002235
+2 932 182 0 -16.9900000002235 -15.9900000002235
+0
+0101000
++3177 0 -3181 0 *
+Ve
+1.820000002e-05
+11.1018016555873 3 17.9900000002235
+0 0
+0101101
+Ed
+1 528 0 -18.9900000002235 -17.9900000002235
+2 933 265 0 -18.9900000002235 -17.9900000002235
+2 934 182 0 -18.9900000002235 -17.9900000002235
+0
+0101000
++3179 0 -3175 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 16.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 529 0 2.86369451098663 4.95161797791392
+2 935 302 0 2.86369451098663 4.95161797791392
+2 936 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3173 0 -3177 0 *
+Ve
+1.820000002e-05
+9.01387818865997 3 17.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 530 0 2.86369451098663 4.95161797791392
+2 937 303 0 2.86369451098663 4.95161797791392
+2 938 182 0 2.86369451098663 4.95161797791392
+0
+0101000
++3171 0 -3175 0 *
+Ed
+1 531 0 14 15
+2 939 304 0 14 15
+2 940 182 0 14 15
+0
+0101000
++3173 0 -3171 0 *
+Wi
+0101100
+-3282 0 +3280 0 -4003 0 +3278 0 +3404 0 +3276 0 -3274 0 -3272 0 -3270 0 -3268 0
++3266 0 +3264 0 +3262 0 +3260 0 -3258 0 -3256 0 -3254 0 -3252 0 +3250 0 +3248 0
++3246 0 +3244 0 -3242 0 -3240 0 -3238 0 -3236 0 +3234 0 +3232 0 +3230 0 +3228 0
+-3226 0 -3224 0 -3222 0 -3220 0 +3218 0 +3216 0 +3214 0 +3212 0 -3210 0 -3208 0
+-3206 0 -3204 0 +3202 0 +3200 0 +3198 0 +3196 0 -3194 0 -3192 0 -3190 0 -3188 0
++3186 0 +3184 0 +3182 0 +3180 0 -3178 0 -3176 0 -3174 0 -3172 0 +3170 0 +3169 0
+Fa
+0 1e-07 182 0
+0101000
++3168 0 *
+Ve
+1.860000002e-05
+-9 -3 0
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 532 0 -4.5 1.5
+2 941 51 0 -4.5 1.5
+2 942 183 0 -4.5 1.5
+0
+0101000
++3166 0 -3400 0 *
+Ed
+ 1e-07 1 1 0
+1 533 0 3.5 37.5
+0
+0101000
++3166 0 -4002 0 *
+Wi
+0101100
++3399 0 +3165 0 -4001 0 -3164 0 *
+Ve
+3.43024091694144e-06
+-9 -0.654700538379252 29.5882886069775
+0 0
+0101101
+Ve
+-9 -1.36602540378444 30.8203394145464
+0 0
+0101101
+Ed
+ 5.81676346974801e-15 1 1 0
+1 534 0 15.2413243852917 16.6639741161021
+2 943 183 0 15.2413243852917 16.6639741161021
+2 944 305 0 15.2413243852917 16.6639741161021
+0
+0101000
++3162 0 -3161 0 *
+Ve
+-9 -1.36602540378444 28.3562377994086
+0 0
+0101101
+Ed
+ 5.63513379815038e-15 1 1 0
+1 535 0 12.7026492506969 14.1252989815072
+2 945 183 0 12.7026492506969 14.1252989815072
+2 946 306 0 12.7026492506969 14.1252989815072
+0
+0101000
++3159 0 -3162 0 *
+Ve
+-9 0.366025403784438 31.8203394145464
+0 0
+0101101
+Ed
+ 5.37054250957417e-15 1 1 0
+1 536 0 5.23598775598299 8.37758040957278
+2 947 183 0 5.23598775598299 8.37758040957278
+2 948 307 0 5.23598775598299 8.37758040957278
+0
+0101000
++3157 0 -3161 0 *
+Ve
+-9 -1.36602540378444 27.3562377994086
+0 0
+0101101
+Ed
+ 6.66133814775094e-16 1 1 0
+1 537 0 1.0471975511966 2.0943951023932
+2 949 183 0 1.0471975511966 2.0943951023932
+2 950 308 0 1.0471975511966 2.0943951023932
+0
+0101000
++3159 0 -3155 0 *
+Ve
+-9 1.36602540378444 30.0882886069775
+0 0
+0101101
+Ed
+ 6.11429565334303e-15 1 1 0
+1 538 0 14.9526492506969 16.9526492506969
+2 951 183 0 14.9526492506969 16.9526492506969
+2 952 309 0 14.9526492506969 16.9526492506969
+0
+0101000
++3153 0 -3157 0 *
+Ve
+-9 -0.654700538379252 26.1241869918398
+0 0
+0101101
+Ed
+ 5.69144980832106e-15 1 1 0
+1 539 0 -14.4526492506969 -13.0299995198865
+2 953 183 0 -14.4526492506969 -13.0299995198865
+2 954 310 0 -14.4526492506969 -13.0299995198865
+0
+0101000
++3155 0 -3151 0 *
+Ve
+-9 1.36602540378444 29.0882886069775
+0 0
+0101101
+Ed
+ 5.32907051820075e-15 1 1 0
+1 540 0 4.18879020478639 5.23598775598299
+2 955 183 0 4.18879020478639 5.23598775598299
+2 956 311 0 4.18879020478639 5.23598775598299
+0
+0101000
++3149 0 -3153 0 *
+Ve
+-9 -1.36602540378444 24.8921361842709
+0 0
+0101101
+Ed
+1 541 0 11.2026492506969 12.6252989815072
+2 957 183 0 11.2026492506969 12.6252989815072
+2 958 312 0 11.2026492506969 12.6252989815072
+0
+0101000
++3147 0 -3151 0 *
+Ve
+-9 0.654700538379251 27.8562377994086
+0 0
+0101101
+Ed
+ 6.37412096737998e-15 1 1 0
+1 542 0 12.9913243852917 14.4139741161021
+2 959 183 0 12.9913243852917 14.4139741161021
+2 960 313 0 12.9913243852917 14.4139741161021
+0
+0101000
++3145 0 -3149 0 *
+Ve
+-9 -1.36602540378444 23.8921361842709
+0 0
+0101101
+Ed
+1 543 0 1.0471975511966 2.0943951023932
+2 961 183 0 1.0471975511966 2.0943951023932
+2 962 314 0 1.0471975511966 2.0943951023932
+0
+0101000
++3147 0 -3143 0 *
+Ve
+-9 1.36602540378444 26.6241869918398
+0 0
+0101101
+Ed
+ 1.06633439369e-14 1 1 0
+1 544 0 -14.1639741161021 -12.7413243852917
+2 963 183 0 -14.1639741161021 -12.7413243852917
+2 964 315 0 -14.1639741161021 -12.7413243852917
+0
+0101000
++3145 0 -3141 0 *
+Ve
+-9 -0.654700538379252 22.660085376702
+0 0
+0101101
+Ed
+ 5.42193643185963e-15 1 1 0
+1 545 0 12.2413243852917 13.6639741161021
+2 965 183 0 12.2413243852917 13.6639741161021
+2 966 316 0 12.2413243852917 13.6639741161021
+0
+0101000
++3139 0 -3143 0 *
+Ve
+-9 1.36602540378444 25.6241869918398
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 546 0 4.18879020478639 5.23598775598299
+2 967 183 0 4.18879020478639 5.23598775598299
+2 968 317 0 4.18879020478639 5.23598775598299
+0
+0101000
++3137 0 -3141 0 *
+Ve
+-9 -1.36602540378444 21.4280345691331
+0 0
+0101101
+Ed
+ 1.07410850191483e-14 1 1 0
+1 547 0 9.70264925069688 11.1252989815073
+2 969 183 0 9.70264925069688 11.1252989815073
+2 970 318 0 9.70264925069688 11.1252989815073
+0
+0101000
++3135 0 -3139 0 *
+Ve
+-9 0.654700538379251 24.3921361842709
+0 0
+0101101
+Ed
+1 548 0 11.4913243852917 12.9139741161021
+2 971 183 0 11.4913243852917 12.9139741161021
+2 972 319 0 11.4913243852917 12.9139741161021
+0
+0101000
++3133 0 -3137 0 *
+Ve
+-9 -1.36602540378444 20.4280345691331
+0 0
+0101101
+Ed
+1 549 0 1.0471975511966 2.0943951023932
+2 973 183 0 1.0471975511966 2.0943951023932
+2 974 320 0 1.0471975511966 2.0943951023932
+0
+0101000
++3135 0 -3131 0 *
+Ve
+-9 1.36602540378444 23.160085376702
+0 0
+0101101
+Ed
+1 550 0 11.9526492506969 13.3752989815072
+2 975 183 0 11.9526492506969 13.3752989815072
+2 976 321 0 11.9526492506969 13.3752989815072
+0
+0101000
++3129 0 -3133 0 *
+Ve
+-9 -0.654700538379252 19.1959837615642
+0 0
+0101101
+Ed
+ 5.53582850846101e-15 1 1 0
+1 551 0 10.7413243852917 12.1639741161021
+2 977 183 0 10.7413243852917 12.1639741161021
+2 978 322 0 10.7413243852917 12.1639741161021
+0
+0101000
++3127 0 -3131 0 *
+Ve
+-9 1.36602540378444 22.160085376702
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 552 0 4.18879020478639 5.23598775598299
+2 979 183 0 4.18879020478639 5.23598775598299
+2 980 323 0 4.18879020478639 5.23598775598299
+0
+0101000
++3125 0 -3129 0 *
+Ve
+-9 -1.36602540378444 17.9639329539954
+0 0
+0101101
+Ed
+1 553 0 8.20264925069688 9.62529898150725
+2 981 183 0 8.20264925069688 9.62529898150725
+2 982 324 0 8.20264925069688 9.62529898150725
+0
+0101000
++3123 0 -3127 0 *
+Ve
+-9 0.654700538379252 20.9280345691331
+0 0
+0101101
+Ed
+1 554 0 9.99132438529169 11.4139741161021
+2 983 183 0 9.99132438529169 11.4139741161021
+2 984 325 0 9.99132438529169 11.4139741161021
+0
+0101000
++3121 0 -3125 0 *
+Ve
+-9 -1.36602540378444 16.9639329539954
+0 0
+0101101
+Ed
+1 555 0 1.0471975511966 2.0943951023932
+2 985 183 0 1.0471975511966 2.0943951023932
+2 986 326 0 1.0471975511966 2.0943951023932
+0
+0101000
++3123 0 -3119 0 *
+Ve
+-9 1.36602540378444 19.6959837615642
+0 0
+0101101
+Ed
+ 6.28429384001312e-15 1 1 0
+1 556 0 10.4526492506969 11.8752989815073
+2 987 183 0 10.4526492506969 11.8752989815073
+2 988 327 0 10.4526492506969 11.8752989815073
+0
+0101000
++3117 0 -3121 0 *
+Ve
+-9 -0.654700538379252 15.7318821464265
+0 0
+0101101
+Ed
+1 557 0 9.24132438529168 10.6639741161021
+2 989 183 0 9.24132438529168 10.6639741161021
+2 990 328 0 9.24132438529168 10.6639741161021
+0
+0101000
++3115 0 -3119 0 *
+Ve
+-9 1.36602540378444 18.6959837615642
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 558 0 4.18879020478639 5.23598775598299
+2 991 183 0 4.18879020478639 5.23598775598299
+2 992 329 0 4.18879020478639 5.23598775598299
+0
+0101000
++3113 0 -3117 0 *
+Ve
+-9 -1.36602540378444 14.4998313388576
+0 0
+0101101
+Ed
+ 2.68527125478709e-15 1 1 0
+1 559 0 6.70264925069687 8.12529898150724
+2 993 183 0 6.70264925069687 8.12529898150724
+2 994 330 0 6.70264925069687 8.12529898150724
+0
+0101000
++3111 0 -3115 0 *
+Ve
+-9 0.654700538379252 17.4639329539954
+0 0
+0101101
+Ed
+1 560 0 8.49132438529169 9.91397411610206
+2 995 183 0 8.49132438529169 9.91397411610206
+2 996 331 0 8.49132438529169 9.91397411610206
+0
+0101000
++3109 0 -3113 0 *
+Ve
+-9 -1.36602540378444 13.4998313388576
+0 0
+0101101
+Ed
+1 561 0 1.0471975511966 2.0943951023932
+2 997 183 0 1.0471975511966 2.0943951023932
+2 998 332 0 1.0471975511966 2.0943951023932
+0
+0101000
++3111 0 -3107 0 *
+Ve
+-9 1.36602540378444 16.2318821464265
+0 0
+0101101
+Ed
+ 5.49308015822668e-15 1 1 0
+1 562 0 8.95264925069687 10.3752989815072
+2 999 183 0 8.95264925069687 10.3752989815072
+2 1000 333 0 8.95264925069687 10.3752989815072
+0
+0101000
++3105 0 -3109 0 *
+Ve
+-9 -0.654700538379252 12.2677805312887
+0 0
+0101101
+Ed
+1 563 0 7.74132438529168 9.16397411610206
+2 1001 183 0 7.74132438529168 9.16397411610206
+2 1002 334 0 7.74132438529168 9.16397411610206
+0
+0101000
++3103 0 -3107 0 *
+Ve
+-9 1.36602540378444 15.2318821464265
+0 0
+0101101
+Ed
+ 2.66453525910038e-15 1 1 0
+1 564 0 4.18879020478639 5.23598775598299
+2 1003 183 0 4.18879020478639 5.23598775598299
+2 1004 335 0 4.18879020478639 5.23598775598299
+0
+0101000
++3101 0 -3105 0 *
+Ve
+-9 -1.36602540378444 11.0357297237199
+0 0
+0101101
+Ed
+1 565 0 5.20264925069687 6.62529898150724
+2 1005 183 0 5.20264925069687 6.62529898150724
+2 1006 336 0 5.20264925069687 6.62529898150724
+0
+0101000
++3099 0 -3103 0 *
+Ve
+-9 0.654700538379252 13.9998313388576
+0 0
+0101101
+Ed
+ 2.74654007911334e-15 1 1 0
+1 566 0 6.99132438529168 8.41397411610206
+2 1007 183 0 6.99132438529168 8.41397411610206
+2 1008 337 0 6.99132438529168 8.41397411610206
+0
+0101000
++3097 0 -3101 0 *
+Ve
+-9 -1.36602540378444 10.0357297237199
+0 0
+0101101
+Ed
+1 567 0 1.0471975511966 2.0943951023932
+2 1009 183 0 1.0471975511966 2.0943951023932
+2 1010 338 0 1.0471975511966 2.0943951023932
+0
+0101000
++3099 0 -3095 0 *
+Ve
+-9 1.36602540378444 12.7677805312887
+0 0
+0101101
+Ed
+1 568 0 7.45264925069687 8.87529898150724
+2 1011 183 0 7.45264925069687 8.87529898150724
+2 1012 339 0 7.45264925069687 8.87529898150724
+0
+0101000
++3093 0 -3097 0 *
+Ve
+-9 -0.654700538379252 8.80367891615099
+0 0
+0101101
+Ed
+ 2.90838173487401e-15 1 1 0
+1 569 0 6.24132438529168 7.66397411610206
+2 1013 183 0 6.24132438529168 7.66397411610206
+2 1014 340 0 6.24132438529168 7.66397411610206
+0
+0101000
++3091 0 -3095 0 *
+Ve
+-9 1.36602540378444 11.7677805312887
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 570 0 4.18879020478639 5.23598775598299
+2 1015 183 0 4.18879020478639 5.23598775598299
+2 1016 341 0 4.18879020478639 5.23598775598299
+0
+0101000
++3089 0 -3093 0 *
+Ve
+-9 -1.36602540378444 7.57162810858211
+0 0
+0101101
+Ed
+ 2.71096821592982e-15 1 1 0
+1 571 0 3.70264925069687 5.12529898150724
+2 1017 183 0 3.70264925069687 5.12529898150724
+2 1018 342 0 3.70264925069687 5.12529898150724
+0
+0101000
++3087 0 -3091 0 *
+Ve
+-9 0.654700538379252 10.5357297237199
+0 0
+0101101
+Ed
+1 572 0 5.49132438529168 6.91397411610206
+2 1019 183 0 5.49132438529168 6.91397411610206
+2 1020 343 0 5.49132438529168 6.91397411610206
+0
+0101000
++3085 0 -3089 0 *
+Ve
+-9 -1.36602540378444 6.57162810858211
+0 0
+0101101
+Ed
+ 1.48952049194836e-15 1 1 0
+1 573 0 1.0471975511966 2.09439510239319
+2 1021 183 0 1.0471975511966 2.09439510239319
+2 1022 344 0 1.0471975511966 2.09439510239319
+0
+0101000
++3087 0 -3083 0 *
+Ve
+-9 1.36602540378444 9.30367891615099
+0 0
+0101101
+Ed
+1 574 0 5.95264925069687 7.37529898150724
+2 1023 183 0 5.95264925069687 7.37529898150724
+2 1024 345 0 5.95264925069687 7.37529898150724
+0
+0101000
++3081 0 -3085 0 *
+Ve
+-9 -0.654700538379252 5.33957730101323
+0 0
+0101101
+Ed
+1 575 0 4.74132438529168 6.16397411610206
+2 1025 183 0 4.74132438529168 6.16397411610206
+2 1026 346 0 4.74132438529168 6.16397411610206
+0
+0101000
++3079 0 -3083 0 *
+Ve
+-9 1.36602540378444 8.30367891615099
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 576 0 4.18879020478639 5.23598775598299
+2 1027 183 0 4.18879020478639 5.23598775598299
+2 1028 347 0 4.18879020478639 5.23598775598299
+0
+0101000
++3077 0 -3081 0 *
+Ve
+-9 -1.36602540378444 4.10752649344435
+0 0
+0101101
+Ed
+ 1.66533453693773e-15 1 1 0
+1 577 0 2.20264925069687 3.62529898150724
+2 1029 183 0 2.20264925069687 3.62529898150724
+2 1030 348 0 2.20264925069687 3.62529898150724
+0
+0101000
++3075 0 -3079 0 *
+Ve
+-9 0.654700538379251 7.07162810858211
+0 0
+0101101
+Ed
+1 578 0 3.99132438529168 5.41397411610206
+2 1031 183 0 3.99132438529168 5.41397411610206
+2 1032 349 0 3.99132438529168 5.41397411610206
+0
+0101000
++3073 0 -3077 0 *
+Ve
+-9 -1.36602540378444 3.10752649344435
+0 0
+0101101
+Ed
+ 9.42055475210265e-16 1 1 0
+1 579 0 1.0471975511966 2.0943951023932
+2 1033 183 0 1.0471975511966 2.0943951023932
+2 1034 350 0 1.0471975511966 2.0943951023932
+0
+0101000
++3075 0 -3071 0 *
+Ve
+-9 1.36602540378444 5.83957730101323
+0 0
+0101101
+Ed
+1 580 0 4.45264925069687 5.87529898150725
+2 1035 183 0 4.45264925069687 5.87529898150725
+2 1036 351 0 4.45264925069687 5.87529898150725
+0
+0101000
++3069 0 -3073 0 *
+Ve
+-9 -0.366025403784439 1.37547568587548
+0 0
+0101101
+Ed
+1 581 0 2.95264925069687 4.95264925069687
+2 1037 183 0 2.95264925069687 4.95264925069687
+2 1038 352 0 2.95264925069687 4.95264925069687
+0
+0101000
++3067 0 -3071 0 *
+Ve
+-9 1.36602540378444 4.83957730101323
+0 0
+0101101
+Ed
+ 1.33226762955019e-15 1 1 0
+1 582 0 4.18879020478639 5.23598775598299
+2 1039 183 0 4.18879020478639 5.23598775598299
+2 1040 353 0 4.18879020478639 5.23598775598299
+0
+0101000
++3065 0 -3069 0 *
+Ve
+-9 1.36602540378444 2.37547568587548
+0 0
+0101101
+Ed
+1 583 0 2.0943951023932 5.23598775598299
+2 1041 183 0 2.0943951023932 5.23598775598299
+2 1042 354 0 2.0943951023932 5.23598775598299
+0
+0101000
++3067 0 -3063 0 *
+Ve
+-9 0.654700538379252 3.60752649344435
+0 0
+0101101
+Ed
+1 584 0 2.49132438529168 3.91397411610206
+2 1043 183 0 2.49132438529168 3.91397411610206
+2 1044 355 0 2.49132438529168 3.91397411610206
+0
+0101000
++3061 0 -3065 0 *
+Ed
+ 1.37327003955667e-15 1 1 0
+1 585 0 2.95264925069687 4.37529898150724
+2 1045 183 0 2.95264925069687 4.37529898150724
+2 1046 356 0 2.95264925069687 4.37529898150724
+0
+0101000
++3063 0 -3061 0 *
+Wi
+0101100
++3160 0 +3158 0 -3156 0 -3154 0 -3152 0 -3150 0 -3148 0 +3146 0 -3144 0 -3142 0
++3140 0 +3138 0 -3136 0 +3134 0 -3132 0 -3130 0 -3128 0 +3126 0 -3124 0 +3122 0
+-3120 0 -3118 0 -3116 0 +3114 0 -3112 0 +3110 0 -3108 0 -3106 0 -3104 0 +3102 0
+-3100 0 +3098 0 -3096 0 -3094 0 -3092 0 +3090 0 -3088 0 +3086 0 -3084 0 -3082 0
+-3080 0 +3078 0 -3076 0 +3074 0 -3072 0 -3070 0 -3068 0 +3066 0 -3064 0 -3062 0
+-3060 0 -3059 0 *
+Fa
+0 1e-07 183 0
+0101000
++3163 0 +3058 0 *
+Ve
+1.820000002e-05
+9 -3 0
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 586 0 -4.5 1.5
+2 1047 51 0 -4.5 1.5
+2 1048 184 0 -4.5 1.5
+0
+0101000
++3056 0 -3283 0 *
+Ed
+ 1e-07 1 1 0
+1 587 0 3.5 37.5
+0
+0101000
++3056 0 -4000 0 *
+Wi
+0101100
++3282 0 +3055 0 -3999 0 -3054 0 *
+Ve
+3.43012043528032e-06
+9 -1.36602540378444 30.8203394145464
+0 0
+0101101
+Ve
+9 -0.654700538379252 29.5882886069775
+0 0
+0101101
+Ed
+ 5.75203752600913e-15 1 1 0
+1 588 0 -16.6639741161021 -15.2413243852917
+2 1049 184 0 -16.6639741161021 -15.2413243852917
+2 1050 357 0 -16.6639741161021 -15.2413243852917
+0
+0101000
++3052 0 -3051 0 *
+Ve
+9 0.366025403784438 31.8203394145464
+0 0
+0101101
+Ed
+ 1.08144214217371e-14 1 1 0
+1 589 0 1.0471975511966 4.18879020478639
+2 1051 184 0 1.0471975511966 4.18879020478639
+2 1052 358 0 1.0471975511966 4.18879020478639
+0
+0101000
++3052 0 -3049 0 *
+Ve
+9 -1.36602540378444 28.3562377994086
+0 0
+0101101
+Ed
+ 5.58321875873354e-15 1 1 0
+1 590 0 -14.1252989815072 -12.7026492506969
+2 1053 184 0 -14.1252989815072 -12.7026492506969
+2 1054 359 0 -14.1252989815072 -12.7026492506969
+0
+0101000
++3051 0 -3047 0 *
+Ve
+9 1.36602540378444 30.0882886069775
+0 0
+0101101
+Ed
+1 591 0 -16.9526492506969 -14.9526492506969
+2 1055 184 0 -16.9526492506969 -14.9526492506969
+2 1056 360 0 -16.9526492506969 -14.9526492506969
+0
+0101000
++3049 0 -3045 0 *
+Ve
+9 -1.36602540378444 27.3562377994086
+0 0
+0101101
+Ed
+ 9.99200722162641e-16 1 1 0
+1 592 0 1.0471975511966 2.0943951023932
+2 1057 184 0 1.0471975511966 2.0943951023932
+2 1058 361 0 1.0471975511966 2.0943951023932
+0
+0101000
++3043 0 -3047 0 *
+Ve
+9 1.36602540378444 29.0882886069775
+0 0
+0101101
+Ed
+1 593 0 4.18879020478639 5.23598775598299
+2 1059 184 0 4.18879020478639 5.23598775598299
+2 1060 362 0 4.18879020478639 5.23598775598299
+0
+0101000
++3045 0 -3041 0 *
+Ve
+9 -0.654700538379252 26.1241869918398
+0 0
+0101101
+Ed
+1 594 0 13.0299995198865 14.4526492506969
+2 1061 184 0 13.0299995198865 14.4526492506969
+2 1062 363 0 13.0299995198865 14.4526492506969
+0
+0101000
++3039 0 -3043 0 *
+Ve
+9 0.654700538379251 27.8562377994086
+0 0
+0101101
+Ed
+1 595 0 -14.4139741161021 -12.9913243852917
+2 1063 184 0 -14.4139741161021 -12.9913243852917
+2 1064 364 0 -14.4139741161021 -12.9913243852917
+0
+0101000
++3041 0 -3037 0 *
+Ve
+9 -1.36602540378444 24.8921361842709
+0 0
+0101101
+Ed
+1 596 0 -12.6252989815072 -11.2026492506969
+2 1065 184 0 -12.6252989815072 -11.2026492506969
+2 1066 365 0 -12.6252989815072 -11.2026492506969
+0
+0101000
++3039 0 -3035 0 *
+Ve
+9 1.36602540378444 26.6241869918398
+0 0
+0101101
+Ed
+ 1.06789374289305e-14 1 1 0
+1 597 0 12.7413243852917 14.1639741161021
+2 1067 184 0 12.7413243852917 14.1639741161021
+2 1068 366 0 12.7413243852917 14.1639741161021
+0
+0101000
++3033 0 -3037 0 *
+Ve
+9 -1.36602540378444 23.8921361842709
+0 0
+0101101
+Ed
+1 598 0 1.0471975511966 2.0943951023932
+2 1069 184 0 1.0471975511966 2.0943951023932
+2 1070 367 0 1.0471975511966 2.0943951023932
+0
+0101000
++3031 0 -3035 0 *
+Ve
+9 1.36602540378444 25.6241869918398
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 599 0 4.18879020478639 5.23598775598299
+2 1071 184 0 4.18879020478639 5.23598775598299
+2 1072 368 0 4.18879020478639 5.23598775598299
+0
+0101000
++3033 0 -3029 0 *
+Ve
+9 -0.654700538379252 22.660085376702
+0 0
+0101101
+Ed
+1 600 0 -13.6639741161021 -12.2413243852917
+2 1073 184 0 -13.6639741161021 -12.2413243852917
+2 1074 369 0 -13.6639741161021 -12.2413243852917
+0
+0101000
++3031 0 -3027 0 *
+Ve
+9 0.654700538379251 24.3921361842709
+0 0
+0101101
+Ed
+ 5.39373037590273e-15 1 1 0
+1 601 0 -12.9139741161021 -11.4913243852917
+2 1075 184 0 -12.9139741161021 -11.4913243852917
+2 1076 370 0 -12.9139741161021 -11.4913243852917
+0
+0101000
++3029 0 -3025 0 *
+Ve
+9 -1.36602540378444 21.4280345691331
+0 0
+0101101
+Ed
+1 602 0 -11.1252989815073 -9.70264925069688
+2 1077 184 0 -11.1252989815073 -9.70264925069688
+2 1078 371 0 -11.1252989815073 -9.70264925069688
+0
+0101000
++3027 0 -3023 0 *
+Ve
+9 1.36602540378444 23.160085376702
+0 0
+0101101
+Ed
+1 603 0 -13.3752989815072 -11.9526492506969
+2 1079 184 0 -13.3752989815072 -11.9526492506969
+2 1080 372 0 -13.3752989815072 -11.9526492506969
+0
+0101000
++3025 0 -3021 0 *
+Ve
+9 -1.36602540378444 20.4280345691331
+0 0
+0101101
+Ed
+1 604 0 1.0471975511966 2.0943951023932
+2 1081 184 0 1.0471975511966 2.0943951023932
+2 1082 373 0 1.0471975511966 2.0943951023932
+0
+0101000
++3019 0 -3023 0 *
+Ve
+9 1.36602540378444 22.160085376702
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 605 0 4.18879020478639 5.23598775598299
+2 1083 184 0 4.18879020478639 5.23598775598299
+2 1084 374 0 4.18879020478639 5.23598775598299
+0
+0101000
++3021 0 -3017 0 *
+Ve
+9 -0.654700538379252 19.1959837615642
+0 0
+0101101
+Ed
+1 606 0 -12.1639741161021 -10.7413243852917
+2 1085 184 0 -12.1639741161021 -10.7413243852917
+2 1086 375 0 -12.1639741161021 -10.7413243852917
+0
+0101000
++3019 0 -3015 0 *
+Ve
+9 0.654700538379252 20.9280345691331
+0 0
+0101101
+Ed
+1 607 0 -11.4139741161021 -9.99132438529169
+2 1087 184 0 -11.4139741161021 -9.99132438529169
+2 1088 376 0 -11.4139741161021 -9.99132438529169
+0
+0101000
++3017 0 -3013 0 *
+Ve
+9 -1.36602540378444 17.9639329539954
+0 0
+0101101
+Ed
+1 608 0 -9.62529898150725 -8.20264925069688
+2 1089 184 0 -9.62529898150725 -8.20264925069688
+2 1090 377 0 -9.62529898150725 -8.20264925069688
+0
+0101000
++3015 0 -3011 0 *
+Ve
+9 1.36602540378444 19.6959837615642
+0 0
+0101101
+Ed
+1 609 0 -11.8752989815073 -10.4526492506969
+2 1091 184 0 -11.8752989815073 -10.4526492506969
+2 1092 378 0 -11.8752989815073 -10.4526492506969
+0
+0101000
++3013 0 -3009 0 *
+Ve
+9 -1.36602540378444 16.9639329539954
+0 0
+0101101
+Ed
+1 610 0 1.0471975511966 2.0943951023932
+2 1093 184 0 1.0471975511966 2.0943951023932
+2 1094 379 0 1.0471975511966 2.0943951023932
+0
+0101000
++3007 0 -3011 0 *
+Ve
+9 1.36602540378444 18.6959837615642
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 611 0 4.18879020478639 5.23598775598299
+2 1095 184 0 4.18879020478639 5.23598775598299
+2 1096 380 0 4.18879020478639 5.23598775598299
+0
+0101000
++3009 0 -3005 0 *
+Ve
+9 -0.654700538379252 15.7318821464265
+0 0
+0101101
+Ed
+1 612 0 -10.6639741161021 -9.24132438529168
+2 1097 184 0 -10.6639741161021 -9.24132438529168
+2 1098 381 0 -10.6639741161021 -9.24132438529168
+0
+0101000
++3007 0 -3003 0 *
+Ve
+9 0.654700538379252 17.4639329539954
+0 0
+0101101
+Ed
+1 613 0 -9.91397411610206 -8.49132438529169
+2 1099 184 0 -9.91397411610206 -8.49132438529169
+2 1100 382 0 -9.91397411610206 -8.49132438529169
+0
+0101000
++3005 0 -3001 0 *
+Ve
+9 -1.36602540378444 14.4998313388576
+0 0
+0101101
+Ed
+1 614 0 -8.12529898150724 -6.70264925069687
+2 1101 184 0 -8.12529898150724 -6.70264925069687
+2 1102 383 0 -8.12529898150724 -6.70264925069687
+0
+0101000
++3003 0 -2999 0 *
+Ve
+9 1.36602540378444 16.2318821464265
+0 0
+0101101
+Ed
+1 615 0 -10.3752989815072 -8.95264925069687
+2 1103 184 0 -10.3752989815072 -8.95264925069687
+2 1104 384 0 -10.3752989815072 -8.95264925069687
+0
+0101000
++3001 0 -2997 0 *
+Ve
+9 -1.36602540378444 13.4998313388576
+0 0
+0101101
+Ed
+ 2.84572490416053e-15 1 1 0
+1 616 0 1.0471975511966 2.0943951023932
+2 1105 184 0 1.0471975511966 2.0943951023932
+2 1106 385 0 1.0471975511966 2.0943951023932
+0
+0101000
++2995 0 -2999 0 *
+Ve
+9 1.36602540378444 15.2318821464265
+0 0
+0101101
+Ed
+1 617 0 4.18879020478639 5.23598775598299
+2 1107 184 0 4.18879020478639 5.23598775598299
+2 1108 386 0 4.18879020478639 5.23598775598299
+0
+0101000
++2997 0 -2993 0 *
+Ve
+9 -0.654700538379252 12.2677805312887
+0 0
+0101101
+Ed
+1 618 0 -9.16397411610206 -7.74132438529168
+2 1109 184 0 -9.16397411610206 -7.74132438529168
+2 1110 387 0 -9.16397411610206 -7.74132438529168
+0
+0101000
++2995 0 -2991 0 *
+Ve
+9 0.654700538379252 13.9998313388576
+0 0
+0101101
+Ed
+1 619 0 -8.41397411610206 -6.99132438529168
+2 1111 184 0 -8.41397411610206 -6.99132438529168
+2 1112 388 0 -8.41397411610206 -6.99132438529168
+0
+0101000
++2993 0 -2989 0 *
+Ve
+9 -1.36602540378444 11.0357297237199
+0 0
+0101101
+Ed
+1 620 0 -6.62529898150724 -5.20264925069687
+2 1113 184 0 -6.62529898150724 -5.20264925069687
+2 1114 389 0 -6.62529898150724 -5.20264925069687
+0
+0101000
++2991 0 -2987 0 *
+Ve
+9 1.36602540378444 12.7677805312887
+0 0
+0101101
+Ed
+1 621 0 -8.87529898150724 -7.45264925069687
+2 1115 184 0 -8.87529898150724 -7.45264925069687
+2 1116 390 0 -8.87529898150724 -7.45264925069687
+0
+0101000
++2989 0 -2985 0 *
+Ve
+9 -1.36602540378444 10.0357297237199
+0 0
+0101101
+Ed
+1 622 0 1.0471975511966 2.0943951023932
+2 1117 184 0 1.0471975511966 2.0943951023932
+2 1118 391 0 1.0471975511966 2.0943951023932
+0
+0101000
++2983 0 -2987 0 *
+Ve
+9 1.36602540378444 11.7677805312887
+0 0
+0101101
+Ed
+1 623 0 4.18879020478639 5.23598775598299
+2 1119 184 0 4.18879020478639 5.23598775598299
+2 1120 392 0 4.18879020478639 5.23598775598299
+0
+0101000
++2985 0 -2981 0 *
+Ve
+9 -0.654700538379252 8.80367891615099
+0 0
+0101101
+Ed
+1 624 0 -7.66397411610206 -6.24132438529168
+2 1121 184 0 -7.66397411610206 -6.24132438529168
+2 1122 393 0 -7.66397411610206 -6.24132438529168
+0
+0101000
++2983 0 -2979 0 *
+Ve
+9 0.654700538379252 10.5357297237199
+0 0
+0101101
+Ed
+1 625 0 -6.91397411610206 -5.49132438529168
+2 1123 184 0 -6.91397411610206 -5.49132438529168
+2 1124 394 0 -6.91397411610206 -5.49132438529168
+0
+0101000
++2981 0 -2977 0 *
+Ve
+9 -1.36602540378444 7.57162810858211
+0 0
+0101101
+Ed
+1 626 0 -5.12529898150724 -3.70264925069687
+2 1125 184 0 -5.12529898150724 -3.70264925069687
+2 1126 395 0 -5.12529898150724 -3.70264925069687
+0
+0101000
++2979 0 -2975 0 *
+Ve
+9 1.36602540378444 9.30367891615099
+0 0
+0101101
+Ed
+1 627 0 -7.37529898150724 -5.95264925069687
+2 1127 184 0 -7.37529898150724 -5.95264925069687
+2 1128 396 0 -7.37529898150724 -5.95264925069687
+0
+0101000
++2977 0 -2973 0 *
+Ve
+9 -1.36602540378444 6.57162810858211
+0 0
+0101101
+Ed
+1 628 0 1.0471975511966 2.0943951023932
+2 1129 184 0 1.0471975511966 2.0943951023932
+2 1130 397 0 1.0471975511966 2.0943951023932
+0
+0101000
++2971 0 -2975 0 *
+Ve
+9 1.36602540378444 8.30367891615099
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 629 0 4.18879020478639 5.23598775598299
+2 1131 184 0 4.18879020478639 5.23598775598299
+2 1132 398 0 4.18879020478639 5.23598775598299
+0
+0101000
++2973 0 -2969 0 *
+Ve
+9 -0.654700538379252 5.33957730101323
+0 0
+0101101
+Ed
+1 630 0 -6.16397411610206 -4.74132438529168
+2 1133 184 0 -6.16397411610206 -4.74132438529168
+2 1134 399 0 -6.16397411610206 -4.74132438529168
+0
+0101000
++2971 0 -2967 0 *
+Ve
+9 0.654700538379251 7.07162810858211
+0 0
+0101101
+Ed
+1 631 0 -5.41397411610206 -3.99132438529168
+2 1135 184 0 -5.41397411610206 -3.99132438529168
+2 1136 400 0 -5.41397411610206 -3.99132438529168
+0
+0101000
++2969 0 -2965 0 *
+Ve
+9 -1.36602540378444 4.10752649344435
+0 0
+0101101
+Ed
+1 632 0 -3.62529898150724 -2.20264925069687
+2 1137 184 0 -3.62529898150724 -2.20264925069687
+2 1138 401 0 -3.62529898150724 -2.20264925069687
+0
+0101000
++2967 0 -2963 0 *
+Ve
+9 1.36602540378444 5.83957730101323
+0 0
+0101101
+Ed
+1 633 0 -5.87529898150725 -4.45264925069687
+2 1139 184 0 -5.87529898150725 -4.45264925069687
+2 1140 402 0 -5.87529898150725 -4.45264925069687
+0
+0101000
++2965 0 -2961 0 *
+Ve
+9 -1.36602540378444 3.10752649344435
+0 0
+0101101
+Ed
+ 2.10650008114602e-15 1 1 0
+1 634 0 1.0471975511966 2.0943951023932
+2 1141 184 0 1.0471975511966 2.0943951023932
+2 1142 403 0 1.0471975511966 2.0943951023932
+0
+0101000
++2959 0 -2963 0 *
+Ve
+9 1.36602540378444 4.83957730101323
+0 0
+0101101
+Ed
+1 635 0 4.18879020478639 5.23598775598299
+2 1143 184 0 4.18879020478639 5.23598775598299
+2 1144 404 0 4.18879020478639 5.23598775598299
+0
+0101000
++2961 0 -2957 0 *
+Ve
+9 -0.366025403784439 1.37547568587548
+0 0
+0101101
+Ed
+1 636 0 -4.95264925069687 -2.95264925069687
+2 1145 184 0 -4.95264925069687 -2.95264925069687
+2 1146 405 0 -4.95264925069687 -2.95264925069687
+0
+0101000
++2959 0 -2955 0 *
+Ve
+9 0.654700538379252 3.60752649344435
+0 0
+0101101
+Ed
+1 637 0 -3.91397411610206 -2.49132438529168
+2 1147 184 0 -3.91397411610206 -2.49132438529168
+2 1148 406 0 -3.91397411610206 -2.49132438529168
+0
+0101000
++2957 0 -2953 0 *
+Ve
+9 1.36602540378444 2.37547568587548
+0 0
+0101101
+Ed
+ 7.44760245974182e-16 1 1 0
+1 638 0 4.18879020478639 7.33038285837618
+2 1149 184 0 4.18879020478639 7.33038285837618
+2 1150 407 0 4.18879020478639 7.33038285837618
+0
+0101000
++2951 0 -2955 0 *
+Ed
+1 639 0 -4.37529898150724 -2.95264925069687
+2 1151 184 0 -4.37529898150724 -2.95264925069687
+2 1152 408 0 -4.37529898150724 -2.95264925069687
+0
+0101000
++2953 0 -2951 0 *
+Wi
+0101100
+-3050 0 +3048 0 -3046 0 +3044 0 +3042 0 +3040 0 +3038 0 +3036 0 -3034 0 -3032 0
++3030 0 +3028 0 -3026 0 +3024 0 -3022 0 +3020 0 +3018 0 +3016 0 -3014 0 +3012 0
+-3010 0 +3008 0 +3006 0 +3004 0 -3002 0 +3000 0 -2998 0 +2996 0 +2994 0 +2992 0
+-2990 0 +2988 0 -2986 0 +2984 0 +2982 0 +2980 0 -2978 0 +2976 0 -2974 0 +2972 0
++2970 0 +2968 0 -2966 0 +2964 0 -2962 0 +2960 0 +2958 0 +2956 0 -2954 0 +2952 0
++2950 0 +2949 0 *
+Fa
+0 1e-07 184 0
+0101000
++3053 0 +2948 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 0
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 640 0 -4.51387818865997 -4.5
+2 1153 51 0 -4.51387818865997 -4.5
+2 1154 185 0 -4.51387818865997 -4.5
+0
+0101000
++2946 0 -3166 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 0.990000000223517
+0 0
+0101101
+Ed
+1 641 0 -2.99000000022352 -2
+2 1155 263 0 -2.99000000022352 -2
+2 1156 185 0 -2.99000000022352 -2
+0
+0101000
++2946 0 -2944 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 33.9900000002235
+0 0
+0101101
+Ed
+1 642 0 31 31.0099999997765
+2 1157 180 0 31 31.0099999997765
+2 1158 185 0 31 31.0099999997765
+0
+0101000
++2942 0 -3998 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 0.990000000223517
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 643 0 -6.60180165558726 -4.51387818865997
+2 1159 264 0 -6.60180165558726 -4.51387818865997
+2 1160 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2940 0 -2944 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 33.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 644 0 -6.60180165558726 -4.51387818865997
+2 1161 262 0 -6.60180165558726 -4.51387818865997
+2 1162 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2938 0 -2942 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 1.99000000022352
+0 0
+0101101
+Ed
+1 645 0 -1.99000000022352 -0.990000000223517
+2 1163 265 0 -1.99000000022352 -0.990000000223517
+2 1164 185 0 -1.99000000022352 -0.990000000223517
+0
+0101000
++2936 0 -2940 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 32.9900000002235
+0 0
+0101101
+Ed
+1 646 0 -33.9900000002235 -32.9900000002235
+2 1165 265 0 -33.9900000002235 -32.9900000002235
+2 1166 185 0 -33.9900000002235 -32.9900000002235
+0
+0101000
++2938 0 -2934 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 1.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 647 0 -6.60180165558726 -4.51387818865997
+2 1167 266 0 -6.60180165558726 -4.51387818865997
+2 1168 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2936 0 -2932 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 32.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 648 0 -6.60180165558726 -4.51387818865997
+2 1169 267 0 -6.60180165558726 -4.51387818865997
+2 1170 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2934 0 -2930 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 2.99000000022352
+0 0
+0101101
+Ed
+1 649 0 -1 0
+2 1171 268 0 -1 0
+2 1172 185 0 -1 0
+0
+0101000
++2932 0 -2928 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 31.9900000002235
+0 0
+0101101
+Ed
+1 650 0 29 30
+2 1173 269 0 29 30
+2 1174 185 0 29 30
+0
+0101000
++2926 0 -2930 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 2.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 651 0 -6.60180165558726 -4.51387818865997
+2 1175 270 0 -6.60180165558726 -4.51387818865997
+2 1176 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2924 0 -2928 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 31.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 652 0 -6.60180165558726 -4.51387818865997
+2 1177 271 0 -6.60180165558726 -4.51387818865997
+2 1178 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2922 0 -2926 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 3.99000000022352
+0 0
+0101101
+Ed
+1 653 0 -3.99000000022352 -2.99000000022352
+2 1179 265 0 -3.99000000022352 -2.99000000022352
+2 1180 185 0 -3.99000000022352 -2.99000000022352
+0
+0101000
++2920 0 -2924 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 30.9900000002235
+0 0
+0101101
+Ed
+1 654 0 -31.9900000002235 -30.9900000002235
+2 1181 265 0 -31.9900000002235 -30.9900000002235
+2 1182 185 0 -31.9900000002235 -30.9900000002235
+0
+0101000
++2922 0 -2918 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 3.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 655 0 -6.60180165558726 -4.51387818865997
+2 1183 272 0 -6.60180165558726 -4.51387818865997
+2 1184 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2920 0 -2916 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 30.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 656 0 -6.60180165558726 -4.51387818865997
+2 1185 273 0 -6.60180165558726 -4.51387818865997
+2 1186 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2918 0 -2914 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 5.99000000022352
+0 0
+0101101
+Ed
+1 657 0 1 3
+2 1187 274 0 1 3
+2 1188 185 0 1 3
+0
+0101000
++2916 0 -2912 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 28.9900000002235
+0 0
+0101101
+Ed
+1 658 0 26 28
+2 1189 275 0 26 28
+2 1190 185 0 26 28
+0
+0101000
++2910 0 -2914 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 5.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 659 0 -6.60180165558726 -4.51387818865997
+2 1191 276 0 -6.60180165558726 -4.51387818865997
+2 1192 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2908 0 -2912 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 28.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 660 0 -6.60180165558726 -4.51387818865997
+2 1193 277 0 -6.60180165558726 -4.51387818865997
+2 1194 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2906 0 -2910 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 6.99000000022352
+0 0
+0101101
+Ed
+1 661 0 -6.99000000022352 -5.99000000022352
+2 1195 265 0 -6.99000000022352 -5.99000000022352
+2 1196 185 0 -6.99000000022352 -5.99000000022352
+0
+0101000
++2904 0 -2908 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 27.9900000002235
+0 0
+0101101
+Ed
+1 662 0 -28.9900000002235 -27.9900000002235
+2 1197 265 0 -28.9900000002235 -27.9900000002235
+2 1198 185 0 -28.9900000002235 -27.9900000002235
+0
+0101000
++2906 0 -2902 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 6.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 663 0 -6.60180165558726 -4.51387818865997
+2 1199 278 0 -6.60180165558726 -4.51387818865997
+2 1200 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2904 0 -2900 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 27.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 664 0 -6.60180165558726 -4.51387818865997
+2 1201 279 0 -6.60180165558726 -4.51387818865997
+2 1202 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2902 0 -2898 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 7.99000000022352
+0 0
+0101101
+Ed
+ 9.49999999999956e-08 1 1 0
+1 665 0 4 5
+2 1203 280 0 4 5
+2 1204 185 0 4 5
+0
+0101000
++2900 0 -2896 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 26.9900000002235
+0 0
+0101101
+Ed
+1 666 0 24 25
+2 1205 281 0 24 25
+2 1206 185 0 24 25
+0
+0101000
++2894 0 -2898 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 7.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 667 0 -6.60180165558726 -4.51387818865997
+2 1207 282 0 -6.60180165558726 -4.51387818865997
+2 1208 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2892 0 -2896 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 26.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 668 0 -6.60180165558726 -4.51387818865997
+2 1209 283 0 -6.60180165558726 -4.51387818865997
+2 1210 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2890 0 -2894 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 8.99000000022352
+0 0
+0101101
+Ed
+ 1.14999999999996e-07 1 1 0
+1 669 0 -8.99000000022352 -7.99000000022352
+2 1211 265 0 -8.99000000022352 -7.99000000022352
+2 1212 185 0 -8.99000000022352 -7.99000000022352
+0
+0101000
++2888 0 -2892 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 25.9900000002235
+0 0
+0101101
+Ed
+1 670 0 -26.9900000002235 -25.9900000002235
+2 1213 265 0 -26.9900000002235 -25.9900000002235
+2 1214 185 0 -26.9900000002235 -25.9900000002235
+0
+0101000
++2890 0 -2886 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 8.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 671 0 -6.60180165558726 -4.51387818865997
+2 1215 284 0 -6.60180165558726 -4.51387818865997
+2 1216 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2888 0 -2884 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 25.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 672 0 -6.60180165558726 -4.51387818865997
+2 1217 285 0 -6.60180165558726 -4.51387818865997
+2 1218 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2886 0 -2882 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 10.9900000002235
+0 0
+0101101
+Ed
+1 673 0 6 8
+2 1219 286 0 6 8
+2 1220 185 0 6 8
+0
+0101000
++2884 0 -2880 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 23.9900000002235
+0 0
+0101101
+Ed
+1 674 0 21 23
+2 1221 287 0 21 23
+2 1222 185 0 21 23
+0
+0101000
++2878 0 -2882 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 10.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 675 0 -6.60180165558726 -4.51387818865997
+2 1223 288 0 -6.60180165558726 -4.51387818865997
+2 1224 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2876 0 -2880 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 23.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 676 0 -6.60180165558726 -4.51387818865997
+2 1225 289 0 -6.60180165558726 -4.51387818865997
+2 1226 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2874 0 -2878 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 11.9900000002235
+0 0
+0101101
+Ed
+1 677 0 -11.9900000002235 -10.9900000002235
+2 1227 265 0 -11.9900000002235 -10.9900000002235
+2 1228 185 0 -11.9900000002235 -10.9900000002235
+0
+0101000
++2872 0 -2876 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 22.9900000002235
+0 0
+0101101
+Ed
+1 678 0 -23.9900000002235 -22.9900000002235
+2 1229 265 0 -23.9900000002235 -22.9900000002235
+2 1230 185 0 -23.9900000002235 -22.9900000002235
+0
+0101000
++2874 0 -2870 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 11.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 679 0 -6.60180165558726 -4.51387818865997
+2 1231 290 0 -6.60180165558726 -4.51387818865997
+2 1232 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2872 0 -2868 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 22.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 680 0 -6.60180165558726 -4.51387818865997
+2 1233 291 0 -6.60180165558726 -4.51387818865997
+2 1234 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2870 0 -2866 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 12.9900000002235
+0 0
+0101101
+Ed
+1 681 0 9 10
+2 1235 292 0 9 10
+2 1236 185 0 9 10
+0
+0101000
++2868 0 -2864 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 21.9900000002235
+0 0
+0101101
+Ed
+1 682 0 19 20
+2 1237 293 0 19 20
+2 1238 185 0 19 20
+0
+0101000
++2862 0 -2866 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 12.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 683 0 -6.60180165558726 -4.51387818865997
+2 1239 294 0 -6.60180165558726 -4.51387818865997
+2 1240 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2860 0 -2864 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 21.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 684 0 -6.60180165558726 -4.51387818865997
+2 1241 295 0 -6.60180165558726 -4.51387818865997
+2 1242 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2858 0 -2862 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 13.9900000002235
+0 0
+0101101
+Ed
+1 685 0 -13.9900000002235 -12.9900000002235
+2 1243 265 0 -13.9900000002235 -12.9900000002235
+2 1244 185 0 -13.9900000002235 -12.9900000002235
+0
+0101000
++2856 0 -2860 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 20.9900000002235
+0 0
+0101101
+Ed
+1 686 0 -21.9900000002235 -20.9900000002235
+2 1245 265 0 -21.9900000002235 -20.9900000002235
+2 1246 185 0 -21.9900000002235 -20.9900000002235
+0
+0101000
++2858 0 -2854 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 13.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 687 0 -6.60180165558726 -4.51387818865997
+2 1247 296 0 -6.60180165558726 -4.51387818865997
+2 1248 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2856 0 -2852 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 20.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 688 0 -6.60180165558726 -4.51387818865997
+2 1249 297 0 -6.60180165558726 -4.51387818865997
+2 1250 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2854 0 -2850 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 15.9900000002235
+0 0
+0101101
+Ed
+1 689 0 11 13
+2 1251 298 0 11 13
+2 1252 185 0 11 13
+0
+0101000
++2852 0 -2848 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 18.9900000002235
+0 0
+0101101
+Ed
+1 690 0 16 18
+2 1253 299 0 16 18
+2 1254 185 0 16 18
+0
+0101000
++2846 0 -2850 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 15.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 691 0 -6.60180165558726 -4.51387818865997
+2 1255 300 0 -6.60180165558726 -4.51387818865997
+2 1256 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2844 0 -2848 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 18.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 692 0 -6.60180165558726 -4.51387818865997
+2 1257 301 0 -6.60180165558726 -4.51387818865997
+2 1258 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2842 0 -2846 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 16.9900000002235
+0 0
+0101101
+Ed
+1 693 0 -16.9900000002235 -15.9900000002235
+2 1259 265 0 -16.9900000002235 -15.9900000002235
+2 1260 185 0 -16.9900000002235 -15.9900000002235
+0
+0101000
++2840 0 -2844 0 *
+Ve
+1.860000002e-05
+-11.1018016555873 -3 17.9900000002235
+0 0
+0101101
+Ed
+1 694 0 -18.9900000002235 -17.9900000002235
+2 1261 265 0 -18.9900000002235 -17.9900000002235
+2 1262 185 0 -18.9900000002235 -17.9900000002235
+0
+0101000
++2842 0 -2838 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 16.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 695 0 -6.60180165558726 -4.51387818865997
+2 1263 302 0 -6.60180165558726 -4.51387818865997
+2 1264 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2840 0 -2836 0 *
+Ve
+1.860000002e-05
+-9.01387818865997 -3 17.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 696 0 -6.60180165558726 -4.51387818865997
+2 1265 303 0 -6.60180165558726 -4.51387818865997
+2 1266 185 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2838 0 -2834 0 *
+Ed
+1 697 0 14 15
+2 1267 304 0 14 15
+2 1268 185 0 14 15
+0
+0101000
++2836 0 -2834 0 *
+Wi
+0101100
++3164 0 +2945 0 -3997 0 -2943 0 -2941 0 +2939 0 -2937 0 +2935 0 +2933 0 -2931 0
++2929 0 -2927 0 -2925 0 +2923 0 -2921 0 +2919 0 +2917 0 -2915 0 +2913 0 -2911 0
+-2909 0 +2907 0 -2905 0 +2903 0 +2901 0 -2899 0 +2897 0 -2895 0 -2893 0 +2891 0
+-2889 0 +2887 0 +2885 0 -2883 0 +2881 0 -2879 0 -2877 0 +2875 0 -2873 0 +2871 0
++2869 0 -2867 0 +2865 0 -2863 0 -2861 0 +2859 0 -2857 0 +2855 0 +2853 0 -2851 0
++2849 0 -2847 0 -2845 0 +2843 0 -2841 0 +2839 0 +2837 0 -2835 0 +2833 0 -2832 0
+Fa
+0 1e-07 185 0
+0101000
++2831 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 0
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 698 0 -4.51387818865997 -4.5
+2 1269 51 0 -4.51387818865997 -4.5
+2 1270 186 0 -4.51387818865997 -4.5
+0
+0101000
++2829 0 -3056 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 0.990000000223517
+0 0
+0101101
+Ed
+1 699 0 -2.99000000022352 -2
+2 1271 263 0 -2.99000000022352 -2
+2 1272 186 0 -2.99000000022352 -2
+0
+0101000
++2829 0 -2827 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 33.9900000002235
+0 0
+0101101
+Ed
+1 700 0 31 31.0099999997765
+2 1273 180 0 31 31.0099999997765
+2 1274 186 0 31 31.0099999997765
+0
+0101000
++2825 0 -3996 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 0.990000000223517
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 701 0 -6.60180165558726 -4.51387818865997
+2 1275 264 0 -6.60180165558726 -4.51387818865997
+2 1276 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2823 0 -2827 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 33.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 702 0 -6.60180165558726 -4.51387818865997
+2 1277 262 0 -6.60180165558726 -4.51387818865997
+2 1278 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2821 0 -2825 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 1.99000000022352
+0 0
+0101101
+Ed
+1 703 0 -1.99000000022352 -0.990000000223517
+2 1279 265 0 -1.99000000022352 -0.990000000223517
+2 1280 186 0 -1.99000000022352 -0.990000000223517
+0
+0101000
++2819 0 -2823 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 32.9900000002235
+0 0
+0101101
+Ed
+1 704 0 -33.9900000002235 -32.9900000002235
+2 1281 265 0 -33.9900000002235 -32.9900000002235
+2 1282 186 0 -33.9900000002235 -32.9900000002235
+0
+0101000
++2821 0 -2817 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 1.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 705 0 -6.60180165558726 -4.51387818865997
+2 1283 266 0 -6.60180165558726 -4.51387818865997
+2 1284 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2819 0 -2815 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 32.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 706 0 -6.60180165558726 -4.51387818865997
+2 1285 267 0 -6.60180165558726 -4.51387818865997
+2 1286 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2817 0 -2813 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 2.99000000022352
+0 0
+0101101
+Ed
+1 707 0 -1 0
+2 1287 268 0 -1 0
+2 1288 186 0 -1 0
+0
+0101000
++2815 0 -2811 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 31.9900000002235
+0 0
+0101101
+Ed
+1 708 0 29 30
+2 1289 269 0 29 30
+2 1290 186 0 29 30
+0
+0101000
++2809 0 -2813 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 2.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 709 0 -6.60180165558726 -4.51387818865997
+2 1291 270 0 -6.60180165558726 -4.51387818865997
+2 1292 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2807 0 -2811 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 31.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 710 0 -6.60180165558726 -4.51387818865997
+2 1293 271 0 -6.60180165558726 -4.51387818865997
+2 1294 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2805 0 -2809 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 3.99000000022352
+0 0
+0101101
+Ed
+1 711 0 -3.99000000022352 -2.99000000022352
+2 1295 265 0 -3.99000000022352 -2.99000000022352
+2 1296 186 0 -3.99000000022352 -2.99000000022352
+0
+0101000
++2803 0 -2807 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 30.9900000002235
+0 0
+0101101
+Ed
+1 712 0 -31.9900000002235 -30.9900000002235
+2 1297 265 0 -31.9900000002235 -30.9900000002235
+2 1298 186 0 -31.9900000002235 -30.9900000002235
+0
+0101000
++2805 0 -2801 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 3.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 713 0 -6.60180165558726 -4.51387818865997
+2 1299 272 0 -6.60180165558726 -4.51387818865997
+2 1300 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2803 0 -2799 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 30.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 714 0 -6.60180165558726 -4.51387818865997
+2 1301 273 0 -6.60180165558726 -4.51387818865997
+2 1302 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2801 0 -2797 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 5.99000000022352
+0 0
+0101101
+Ed
+1 715 0 1 3
+2 1303 274 0 1 3
+2 1304 186 0 1 3
+0
+0101000
++2799 0 -2795 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 28.9900000002235
+0 0
+0101101
+Ed
+1 716 0 26 28
+2 1305 275 0 26 28
+2 1306 186 0 26 28
+0
+0101000
++2793 0 -2797 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 5.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 717 0 -6.60180165558726 -4.51387818865997
+2 1307 276 0 -6.60180165558726 -4.51387818865997
+2 1308 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2791 0 -2795 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 28.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 718 0 -6.60180165558726 -4.51387818865997
+2 1309 277 0 -6.60180165558726 -4.51387818865997
+2 1310 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2789 0 -2793 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 6.99000000022352
+0 0
+0101101
+Ed
+1 719 0 -6.99000000022352 -5.99000000022352
+2 1311 265 0 -6.99000000022352 -5.99000000022352
+2 1312 186 0 -6.99000000022352 -5.99000000022352
+0
+0101000
++2787 0 -2791 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 27.9900000002235
+0 0
+0101101
+Ed
+1 720 0 -28.9900000002235 -27.9900000002235
+2 1313 265 0 -28.9900000002235 -27.9900000002235
+2 1314 186 0 -28.9900000002235 -27.9900000002235
+0
+0101000
++2789 0 -2785 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 6.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 721 0 -6.60180165558726 -4.51387818865997
+2 1315 278 0 -6.60180165558726 -4.51387818865997
+2 1316 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2787 0 -2783 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 27.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 722 0 -6.60180165558726 -4.51387818865997
+2 1317 279 0 -6.60180165558726 -4.51387818865997
+2 1318 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2785 0 -2781 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 7.99000000022352
+0 0
+0101101
+Ed
+1 723 0 4 5
+2 1319 280 0 4 5
+2 1320 186 0 4 5
+0
+0101000
++2783 0 -2779 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 26.9900000002235
+0 0
+0101101
+Ed
+1 724 0 24 25
+2 1321 281 0 24 25
+2 1322 186 0 24 25
+0
+0101000
++2777 0 -2781 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 7.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 725 0 -6.60180165558726 -4.51387818865997
+2 1323 282 0 -6.60180165558726 -4.51387818865997
+2 1324 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2775 0 -2779 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 26.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 726 0 -6.60180165558726 -4.51387818865997
+2 1325 283 0 -6.60180165558726 -4.51387818865997
+2 1326 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2773 0 -2777 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 8.99000000022352
+0 0
+0101101
+Ed
+1 727 0 -8.99000000022352 -7.99000000022352
+2 1327 265 0 -8.99000000022352 -7.99000000022352
+2 1328 186 0 -8.99000000022352 -7.99000000022352
+0
+0101000
++2771 0 -2775 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 25.9900000002235
+0 0
+0101101
+Ed
+1 728 0 -26.9900000002235 -25.9900000002235
+2 1329 265 0 -26.9900000002235 -25.9900000002235
+2 1330 186 0 -26.9900000002235 -25.9900000002235
+0
+0101000
++2773 0 -2769 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 8.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 729 0 -6.60180165558726 -4.51387818865997
+2 1331 284 0 -6.60180165558726 -4.51387818865997
+2 1332 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2771 0 -2767 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 25.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 730 0 -6.60180165558726 -4.51387818865997
+2 1333 285 0 -6.60180165558726 -4.51387818865997
+2 1334 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2769 0 -2765 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 10.9900000002235
+0 0
+0101101
+Ed
+1 731 0 6 8
+2 1335 286 0 6 8
+2 1336 186 0 6 8
+0
+0101000
++2767 0 -2763 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 23.9900000002235
+0 0
+0101101
+Ed
+1 732 0 21 23
+2 1337 287 0 21 23
+2 1338 186 0 21 23
+0
+0101000
++2761 0 -2765 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 10.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 733 0 -6.60180165558726 -4.51387818865997
+2 1339 288 0 -6.60180165558726 -4.51387818865997
+2 1340 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2759 0 -2763 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 23.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 734 0 -6.60180165558726 -4.51387818865997
+2 1341 289 0 -6.60180165558726 -4.51387818865997
+2 1342 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2757 0 -2761 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 11.9900000002235
+0 0
+0101101
+Ed
+1 735 0 -11.9900000002235 -10.9900000002235
+2 1343 265 0 -11.9900000002235 -10.9900000002235
+2 1344 186 0 -11.9900000002235 -10.9900000002235
+0
+0101000
++2755 0 -2759 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 22.9900000002235
+0 0
+0101101
+Ed
+1 736 0 -23.9900000002235 -22.9900000002235
+2 1345 265 0 -23.9900000002235 -22.9900000002235
+2 1346 186 0 -23.9900000002235 -22.9900000002235
+0
+0101000
++2757 0 -2753 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 11.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 737 0 -6.60180165558726 -4.51387818865997
+2 1347 290 0 -6.60180165558726 -4.51387818865997
+2 1348 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2755 0 -2751 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 22.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 738 0 -6.60180165558726 -4.51387818865997
+2 1349 291 0 -6.60180165558726 -4.51387818865997
+2 1350 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2753 0 -2749 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 12.9900000002235
+0 0
+0101101
+Ed
+1 739 0 9 10
+2 1351 292 0 9 10
+2 1352 186 0 9 10
+0
+0101000
++2751 0 -2747 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 21.9900000002235
+0 0
+0101101
+Ed
+1 740 0 19 20
+2 1353 293 0 19 20
+2 1354 186 0 19 20
+0
+0101000
++2745 0 -2749 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 12.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 741 0 -6.60180165558726 -4.51387818865997
+2 1355 294 0 -6.60180165558726 -4.51387818865997
+2 1356 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2743 0 -2747 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 21.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 742 0 -6.60180165558726 -4.51387818865997
+2 1357 295 0 -6.60180165558726 -4.51387818865997
+2 1358 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2741 0 -2745 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 13.9900000002235
+0 0
+0101101
+Ed
+1 743 0 -13.9900000002235 -12.9900000002235
+2 1359 265 0 -13.9900000002235 -12.9900000002235
+2 1360 186 0 -13.9900000002235 -12.9900000002235
+0
+0101000
++2739 0 -2743 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 20.9900000002235
+0 0
+0101101
+Ed
+1 744 0 -21.9900000002235 -20.9900000002235
+2 1361 265 0 -21.9900000002235 -20.9900000002235
+2 1362 186 0 -21.9900000002235 -20.9900000002235
+0
+0101000
++2741 0 -2737 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 13.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 745 0 -6.60180165558726 -4.51387818865997
+2 1363 296 0 -6.60180165558726 -4.51387818865997
+2 1364 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2739 0 -2735 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 20.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 746 0 -6.60180165558726 -4.51387818865997
+2 1365 297 0 -6.60180165558726 -4.51387818865997
+2 1366 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2737 0 -2733 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 15.9900000002235
+0 0
+0101101
+Ed
+1 747 0 11 13
+2 1367 298 0 11 13
+2 1368 186 0 11 13
+0
+0101000
++2735 0 -2731 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 18.9900000002235
+0 0
+0101101
+Ed
+1 748 0 16 18
+2 1369 299 0 16 18
+2 1370 186 0 16 18
+0
+0101000
++2729 0 -2733 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 15.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 749 0 -6.60180165558726 -4.51387818865997
+2 1371 300 0 -6.60180165558726 -4.51387818865997
+2 1372 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2727 0 -2731 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 18.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 750 0 -6.60180165558726 -4.51387818865997
+2 1373 301 0 -6.60180165558726 -4.51387818865997
+2 1374 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2725 0 -2729 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 16.9900000002235
+0 0
+0101101
+Ed
+1 751 0 -16.9900000002235 -15.9900000002235
+2 1375 265 0 -16.9900000002235 -15.9900000002235
+2 1376 186 0 -16.9900000002235 -15.9900000002235
+0
+0101000
++2723 0 -2727 0 *
+Ve
+1.820000002e-05
+11.1018016555873 -3 17.9900000002235
+0 0
+0101101
+Ed
+1 752 0 -18.9900000002235 -17.9900000002235
+2 1377 265 0 -18.9900000002235 -17.9900000002235
+2 1378 186 0 -18.9900000002235 -17.9900000002235
+0
+0101000
++2725 0 -2721 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 16.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 753 0 -6.60180165558726 -4.51387818865997
+2 1379 302 0 -6.60180165558726 -4.51387818865997
+2 1380 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2723 0 -2719 0 *
+Ve
+1.820000002e-05
+9.01387818865997 -3 17.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 754 0 -6.60180165558726 -4.51387818865997
+2 1381 303 0 -6.60180165558726 -4.51387818865997
+2 1382 186 0 -6.60180165558726 -4.51387818865997
+0
+0101000
++2721 0 -2717 0 *
+Ed
+1 755 0 14 15
+2 1383 304 0 14 15
+2 1384 186 0 14 15
+0
+0101000
++2719 0 -2717 0 *
+Wi
+0101100
++3054 0 +2828 0 -3995 0 -2826 0 -2824 0 +2822 0 -2820 0 +2818 0 +2816 0 -2814 0
++2812 0 -2810 0 -2808 0 +2806 0 -2804 0 +2802 0 +2800 0 -2798 0 +2796 0 -2794 0
+-2792 0 +2790 0 -2788 0 +2786 0 +2784 0 -2782 0 +2780 0 -2778 0 -2776 0 +2774 0
+-2772 0 +2770 0 +2768 0 -2766 0 +2764 0 -2762 0 -2760 0 +2758 0 -2756 0 +2754 0
++2752 0 -2750 0 +2748 0 -2746 0 -2744 0 +2742 0 -2740 0 +2738 0 +2736 0 -2734 0
++2732 0 -2730 0 -2728 0 +2726 0 -2724 0 +2722 0 +2720 0 -2718 0 +2716 0 -2715 0
+Fa
+0 1e-07 186 0
+0101000
++2714 0 *
+Ed
+ 1e-07 1 1 0
+1 415 0 0.408555049325884 2.90757052438606
+2 711 180 0 0.408555049325884 2.90757052438606
+2 712 262 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2942 0 +2825 0 *
+Wi
+0101100
++3994 0 +2941 0 -2824 0 +2712 0 *
+Fa
+0 1e-07 180 0
+0101000
++2711 0 *
+Ve
+1e-07
+-8.89749336242676 -3.08288931846619 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 756 0 1 2
+0
+0101000
++3990 0 -2709 69 *
+Ve
+1e-07
+-8.28533533832021 -3.75150004318693 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 757 0 0 0.906519579319517
+0
+0101000
++2709 0 -2707 0 *
+Ed
+ 1e-07 1 1 0
+1 758 0 1 2
+0
+0101000
++3991 0 -2707 69 *
+Wi
+0101100
++2708 0 +3989 0 +2706 69 -2705 0 *
+Fa
+0 1e-07 187 0
+0101000
++2704 0 *
+Ve
+1e-07
+-7.77440595626831 -3.54477834701538 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 759 0 -0.0112151003219081 0.539949750799764
+0
+0101000
++2707 0 -2702 0 *
+Ed
+ 1e-07 1 1 0
+1 760 0 1 2
+0
+0101000
++3988 0 -2702 69 *
+Wi
+0101100
++2705 0 +3987 0 +2701 69 -2700 0 *
+Fa
+0 1e-07 188 0
+0101000
++2699 0 *
+Ve
+1e-07
+-8.89749336242676 3.0519425868988 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 761 0 1 2
+0
+0101000
++3986 0 -2697 69 *
+Ed
+ 1e-07 1 1 0
+1 762 0 0 6.13483190536499
+0
+0101000
++2697 0 -2709 0 *
+Wi
+0101100
++2696 0 +3985 0 +2695 69 -2708 0 *
+Fa
+0 1e-07 189 0
+0101000
++2694 0 *
+Ve
+1e-07
+-7.27440595626831 -3.54477834701538 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 763 0 0.0449786186218262 0.544978618621826
+0
+0101000
++2702 0 -2692 0 *
+Ed
+ 1e-07 1 1 0
+1 764 0 1 2
+0
+0101000
++3984 0 -2692 69 *
+Wi
+0101100
++2700 0 +3983 0 +2691 69 -2690 0 *
+Fa
+0 1e-07 190 0
+0101000
++2689 0 *
+Ve
+1e-07
+-8.1806824381779 3.86953123903098 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 765 0 1 2
+0
+0101000
++3982 0 -2687 69 *
+Ed
+ 1e-07 1 1 0
+1 766 0 -0.351334512345238 0.73598747548441
+0
+0101000
++2687 0 -2697 0 *
+Wi
+0101100
++2686 0 +3981 0 +2685 69 -2696 0 *
+Fa
+0 1e-07 191 0
+0101000
++2684 0 *
+Ve
+1e-07
+-7.27440595626831 -2.80323314666748 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 767 0 0 0.7415452003479
+0
+0101000
++2692 0 -2682 0 *
+Ed
+ 1e-07 1 1 0
+1 768 0 1 2
+0
+0101000
++3980 0 -2682 69 *
+Wi
+0101100
++2690 0 +3979 0 +2681 69 -2680 0 *
+Fa
+0 1e-07 192 0
+0101000
++2679 0 *
+Ve
+1e-07
+-7.77440595626831 3.54477834701538 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 769 0 1 2
+0
+0101000
++3978 0 -2677 69 *
+Ed
+ 1e-07 1 1 0
+1 770 0 0.221926981256942 0.742047179504738
+0
+0101000
++2677 0 -2687 0 *
+Wi
+0101100
++2676 0 +3977 0 +2675 69 -2686 0 *
+Fa
+0 1e-07 193 0
+0101000
++2674 0 *
+Ve
+1e-07
+-6.96637487411499 -2.80323314666748 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 771 0 0.0710844993591309 0.379115581512451
+0
+0101000
++2682 0 -2672 0 *
+Ed
+ 1e-07 1 1 0
+1 772 0 1 2
+0
+0101000
++3976 0 -2672 69 *
+Wi
+0101100
++2680 0 +3975 0 +2671 69 -2670 0 *
+Fa
+0 1e-07 194 0
+0101000
++2669 0 *
+Ve
+1e-07
+-7.27440595626831 3.54477834701538 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 773 0 1 2
+0
+0101000
++3974 0 -2667 69 *
+Ed
+ 1e-07 1 1 0
+1 774 0 8.88178419700125e-16 0.500000000000001
+0
+0101000
++2667 0 -2677 0 *
+Wi
+0101100
++2666 0 +3973 0 +2665 69 -2676 0 *
+Fa
+0 1e-07 195 0
+0101000
++2664 0 *
+Ve
+1e-07
+-6.96637487411499 2.80323314666748 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 775 0 0.409932613372803 6.01639890670776
+0
+0101000
++2672 0 -2662 0 *
+Ed
+ 1e-07 1 1 0
+1 776 0 1 2
+0
+0101000
++3972 0 -2662 69 *
+Wi
+0101100
++2670 0 +3971 0 +2661 69 -2660 0 *
+Fa
+0 1e-07 196 0
+0101000
++2659 0 *
+Ve
+1e-07
+-7.27440595626831 2.80323314666748 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 777 0 1 2
+0
+0101000
++3970 0 -2657 69 *
+Ed
+ 1e-07 1 1 0
+1 778 0 0 0.7415452003479
+0
+0101000
++2657 0 -2667 0 *
+Wi
+0101100
++2656 0 +3969 0 +2655 69 -2666 0 *
+Fa
+0 1e-07 197 0
+0101000
++2654 0 *
+Ed
+ 1e-07 1 1 0
+1 779 0 0 0.30803108215332
+0
+0101000
++2662 0 -2657 0 *
+Wi
+0101100
++2660 0 +3968 0 +2652 69 -2656 0 *
+Fa
+0 1e-07 198 0
+0101000
++2651 0 *
+Ve
+1e-07
+8.89749336242676 -3.08288931846619 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 780 0 1 2
+0
+0101000
++3965 0 -2649 72 *
+Ve
+1e-07
+8.28533533832021 -3.75150004318693 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 781 0 0 0.906519579319517
+0
+0101000
++2649 0 -2647 0 *
+Ed
+ 1e-07 1 1 0
+1 782 0 1 2
+0
+0101000
++3966 0 -2647 72 *
+Wi
+0101100
++2648 0 +3964 0 +2646 72 -2645 0 *
+Fa
+0 1e-07 199 0
+0101000
++2644 0 *
+Ve
+1e-07
+7.77440595626831 -3.54477834701538 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 783 0 -0.0112151003219081 0.539949750799764
+0
+0101000
++2647 0 -2642 0 *
+Ed
+ 1e-07 1 1 0
+1 784 0 1 2
+0
+0101000
++3963 0 -2642 72 *
+Wi
+0101100
++2645 0 +3962 0 +2641 72 -2640 0 *
+Fa
+0 1e-07 200 0
+0101000
++2639 0 *
+Ve
+1e-07
+8.89749336242676 3.0519425868988 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 785 0 1 2
+0
+0101000
++3961 0 -2637 72 *
+Ed
+ 1e-07 1 1 0
+1 786 0 0 6.13483190536499
+0
+0101000
++2637 0 -2649 0 *
+Wi
+0101100
++2636 0 +3960 0 +2635 72 -2648 0 *
+Fa
+0 1e-07 201 0
+0101000
++2634 0 *
+Ve
+1e-07
+7.27440595626831 -3.54477834701538 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 787 0 0.0449786186218262 0.544978618621826
+0
+0101000
++2642 0 -2632 0 *
+Ed
+ 1e-07 1 1 0
+1 788 0 1 2
+0
+0101000
++3959 0 -2632 72 *
+Wi
+0101100
++2640 0 +3958 0 +2631 72 -2630 0 *
+Fa
+0 1e-07 202 0
+0101000
++2629 0 *
+Ve
+1e-07
+8.1806824381779 3.86953123903098 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 789 0 1 2
+0
+0101000
++3957 0 -2627 72 *
+Ed
+ 1e-07 1 1 0
+1 790 0 -0.351334512345238 0.73598747548441
+0
+0101000
++2627 0 -2637 0 *
+Wi
+0101100
++2626 0 +3956 0 +2625 72 -2636 0 *
+Fa
+0 1e-07 203 0
+0101000
++2624 0 *
+Ve
+1e-07
+7.27440595626831 -2.80323314666748 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 791 0 0 0.7415452003479
+0
+0101000
++2632 0 -2622 0 *
+Ed
+ 1e-07 1 1 0
+1 792 0 1 2
+0
+0101000
++3955 0 -2622 72 *
+Wi
+0101100
++2630 0 +3954 0 +2621 72 -2620 0 *
+Fa
+0 1e-07 204 0
+0101000
++2619 0 *
+Ve
+1e-07
+7.77440595626831 3.54477834701538 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 793 0 1 2
+0
+0101000
++3953 0 -2617 72 *
+Ed
+ 1e-07 1 1 0
+1 794 0 0.221926981256942 0.742047179504738
+0
+0101000
++2617 0 -2627 0 *
+Wi
+0101100
++2616 0 +3952 0 +2615 72 -2626 0 *
+Fa
+0 1e-07 205 0
+0101000
++2614 0 *
+Ve
+1e-07
+6.96637487411499 -2.80323314666748 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 795 0 0.0710844993591309 0.379115581512451
+0
+0101000
++2622 0 -2612 0 *
+Ed
+ 1e-07 1 1 0
+1 796 0 1 2
+0
+0101000
++3951 0 -2612 72 *
+Wi
+0101100
++2620 0 +3950 0 +2611 72 -2610 0 *
+Fa
+0 1e-07 206 0
+0101000
++2609 0 *
+Ve
+1e-07
+7.27440595626831 3.54477834701538 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 797 0 1 2
+0
+0101000
++3949 0 -2607 72 *
+Ed
+ 1e-07 1 1 0
+1 798 0 8.88178419700125e-16 0.500000000000001
+0
+0101000
++2607 0 -2617 0 *
+Wi
+0101100
++2606 0 +3948 0 +2605 72 -2616 0 *
+Fa
+0 1e-07 207 0
+0101000
++2604 0 *
+Ve
+1e-07
+6.96637487411499 2.80323314666748 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 799 0 0.409932613372803 6.01639890670776
+0
+0101000
++2612 0 -2602 0 *
+Ed
+ 1e-07 1 1 0
+1 800 0 1 2
+0
+0101000
++3947 0 -2602 72 *
+Wi
+0101100
++2610 0 +3946 0 +2601 72 -2600 0 *
+Fa
+0 1e-07 208 0
+0101000
++2599 0 *
+Ve
+1e-07
+7.27440595626831 2.80323314666748 34
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 801 0 1 2
+0
+0101000
++3945 0 -2597 72 *
+Ed
+ 1e-07 1 1 0
+1 802 0 0 0.7415452003479
+0
+0101000
++2597 0 -2607 0 *
+Wi
+0101100
++2596 0 +3944 0 +2595 72 -2606 0 *
+Fa
+0 1e-07 209 0
+0101000
++2594 0 *
+Ed
+ 1e-07 1 1 0
+1 803 0 0 0.30803108215332
+0
+0101000
++2602 0 -2597 0 *
+Wi
+0101100
++2600 0 +3943 0 +2592 72 -2596 0 *
+Fa
+0 1e-07 210 0
+0101000
++2591 0 *
+Ve
+7.66905525618085e-07
+-2 6.75 36
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 804 0 1 3
+0
+0101000
+-2589 0 +3940 0 *
+Ve
+-2 4.75 36
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 805 0 -3.375 -1.375
+2 1385 211 0 -3.375 -1.375
+2 1386 409 73 -3.375 -1.375
+0
+0101000
++2589 0 -2587 0 *
+Ed
+ 1e-07 1 1 0
+1 806 0 1 3
+0
+0101000
+-2587 0 +3941 0 *
+Wi
+0101100
++2588 0 +2586 0 +3939 0 -2585 0 *
+Fa
+0 1e-07 211 0
+0101000
++2584 0 *
+Ve
+2 4.75 36
+0 0
+0101101
+Ed
+ 3.33066907387547e-16 1 1 0
+1 807 0 -1 3
+2 1387 212 0 -1 3
+2 1388 409 73 -1 3
+0
+0101000
++2587 0 -2582 0 *
+Ed
+ 1e-07 1 1 0
+1 808 0 1 3
+0
+0101000
+-2582 0 +3938 0 *
+Wi
+0101100
++2585 0 +2581 0 +3937 0 -2580 0 *
+Fa
+0 1e-07 212 0
+0101000
++2579 0 *
+Ve
+2 6.75 36
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 809 0 1 3
+0
+0101000
+-2577 0 +3936 0 *
+Ed
+1 810 0 -1 3
+2 1389 213 0 -1 3
+2 1390 409 73 -1 3
+0
+0101000
++2577 0 -2589 0 *
+Wi
+0101100
++2576 0 +2575 0 +3935 0 -2588 0 *
+Fa
+0 1e-07 213 0
+0101000
++2574 0 *
+Ed
+ 0 1 1 0
+1 811 0 2.375 4.375
+2 1391 214 0 2.375 4.375
+2 1392 409 73 2.375 4.375
+0
+0101000
++2582 0 -2577 0 *
+Wi
+0101100
++2580 0 +2572 0 +3934 0 -2576 0 *
+Fa
+0 1e-07 214 0
+0101000
++2571 0 *
+Ve
+7.63064528704733e-07
+-2 -6.75 36
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 812 0 1 3
+0
+0101000
++3931 0 -2569 0 *
+Ve
+-2 -4.75 36
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 813 0 1.375 3.375
+2 1393 410 74 1.375 3.375
+2 1394 215 0 1.375 3.375
+0
+0101000
++2567 0 -2569 0 *
+Ed
+ 1e-07 1 1 0
+1 814 0 1 3
+0
+0101000
++3932 0 -2567 0 *
+Wi
+0101100
++2568 0 +3930 0 -2566 0 -2565 0 *
+Fa
+0 1e-07 215 0
+0101000
++2564 0 *
+Ve
+2 -4.75 36
+0 0
+0101101
+Ed
+1 815 0 -3 1
+2 1395 410 74 -3 1
+2 1396 216 0 -3 1
+0
+0101000
++2562 0 -2567 0 *
+Ed
+ 1e-07 1 1 0
+1 816 0 1 3
+0
+0101000
++3929 0 -2562 0 *
+Wi
+0101100
++2565 0 +3928 0 -2561 0 -2560 0 *
+Fa
+0 1e-07 216 0
+0101000
++2559 0 *
+Ve
+2 -6.75 36
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 817 0 1 3
+0
+0101000
++3927 0 -2557 0 *
+Ed
+1 818 0 -3 1
+2 1397 410 74 -3 1
+2 1398 217 0 -3 1
+0
+0101000
++2569 0 -2557 0 *
+Wi
+0101100
++2556 0 +3926 0 -2555 0 -2568 0 *
+Fa
+0 1e-07 217 0
+0101000
++2554 0 *
+Ed
+ 0 1 1 0
+1 819 0 -4.375 -2.375
+2 1399 410 74 -4.375 -2.375
+2 1400 218 0 -4.375 -2.375
+0
+0101000
++2557 0 -2562 0 *
+Wi
+0101100
++2560 0 +3925 0 -2552 0 -2556 0 *
+Fa
+0 1e-07 218 0
+0101000
++2551 0 *
+Wi
+0101000
+-3920 0 *
+Fa
+0 1e-07 411 0
+0101000
+-2549 76 *
+Ve
+1.92823335063125e-06
+0 0 6.875
+0 0
+0101101
+Ed
+ 6.87499999999939e-08 1 1 0
+1 820 0 3.14159265358979 9.42477796076938
+2 1401 50 0 3.14159265358979 9.42477796076938
+2 1402 412 0 3.14159265358979 9.42477796076938
+0
+0101100
++2547 0 -2547 0 *
+Wi
+0101100
++2546 0 *
+Ve
+8.48233350631248e-07
+3.5 0 2.375
+0 0
+0101101
+Ed
+ 2.37499999999825e-08 1 1 0
+1 821 0 0 6.28318530717959
+2 1403 52 57 0 6.28318530717959
+2 1404 413 0 0 6.28318530717959
+0
+0101100
++2544 0 -2544 0 *
+Wi
+0101100
+-2543 0 *
+Wi
+0101100
++3916 64 -3910 65 +4341 64 -4339 65 +4337 64 -4335 65 +4333 64 -4331 65 +4329 64 -4327 65
++4325 64 -4323 65 +4321 64 -4319 65 +4317 64 -4315 65 +4313 64 -4311 65 +4309 64 -4307 65
++4305 64 -4303 65 +4301 64 -4299 65 +4297 64 -4295 65 +4293 64 -4291 65 +4289 64 -4287 65
++4285 64 -4283 65 +4281 64 -4279 65 +4277 64 -4275 65 +4273 64 -4271 65 +4269 64 -4267 65
++4265 64 -4263 65 +4261 64 -4259 65 +4257 64 -4255 65 +4253 64 -4251 65 +4249 64 -4247 65
++4245 64 -4243 65 +4241 64 -4239 65 +4237 64 -4235 65 +4233 64 -4231 65 +4229 64 -4227 65
++4225 64 -4223 65 +4221 64 -4219 65 +4217 64 -4215 65 +4213 64 -4211 65 +4209 64 -4207 65
++4205 64 -4203 65 +4201 64 -4199 65 +4197 64 -4195 65 +4193 64 -4191 65 +4189 64 -4187 65
++4185 64 -4183 65 +4181 64 -4179 65 +4177 64 -4175 65 +4173 64 -4171 65 +4169 64 -4167 65
++4165 64 -4163 65 +4161 64 -4159 65 +4157 64 -3626 65 +4153 64 +3620 64 +4149 64 +4147 64
++4145 64 +4143 64 +4141 64 +4139 64 +4137 64 +4135 64 +4133 64 +4131 64 +4129 64 +4127 64
++4125 64 +4123 64 +4121 64 +4119 64 +4117 64 +4115 64 +4113 64 +4111 64 +4109 64 +4107 64
++4105 64 +4103 64 +4101 64 +4099 64 +4097 64 +4095 64 +4093 64 +4091 64 +4089 64 +4087 64
++4085 64 +4083 64 +4081 64 +4079 64 +4077 64 +4075 64 +4073 64 +4071 64 +4069 64 +4067 64
++4065 64 +4063 64 +4061 64 +4059 64 +4057 64 +4055 64 +4053 64 +4051 64 +4049 64 +4047 64
++4045 64 +4043 64 +4041 64 +4039 64 +4037 64 +4035 64 +4033 64 +4031 64 +4029 64 +4027 64
++4025 64 +4023 64 +4021 64 +4019 64 +4017 64 +4015 64 +4013 64 +4012 64 *
+Fa
+0 1e-07 50 0
+0101000
++2545 0 -2542 77 +2541 63 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 33.9900000002235
+0 0
+0101101
+Ed
+ 8.53067514952002e-15 1 1 0
+1 822 0 4.97631182851448 5.98722238568202
+2 1405 265 0 4.97631182851448 5.98722238568202
+2 1406 262 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2539 0 +3392 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 33.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 823 0 -6.28784925781463 0.420354674684743
+2 1407 262 0 -6.28784925781463 0.420354674684743
+2 1408 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2537 0 -2539 0 *
+Ed
+1 822 0 6.57914822867715 7.5900587858447
+2 1405 265 0 6.57914822867715 7.5900587858447
+2 1406 262 0 6.57914822867715 7.5900587858447
+0
+0101000
++2537 0 -3275 0 *
+Wi
+0101100
+-2538 0 +2536 0 -3391 0 -2535 0 +3403 0 +3274 0 *
+Fa
+0 1e-07 262 0
+0101000
++2534 0 *
+Ve
+1e-07
+8.5 0 0
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 824 0 0 6.28318530717959
+2 1409 415 0 0 6.28318530717959
+2 1410 415 79 0 6.28318530717959
+4 CN 51 0 51 0
+0
+0101100
++2532 0 -2532 0 *
+Wi
+0101100
++2531 0 *
+Ed
+ 7.53644380168212e-15 1 1 0
+1 825 0 1.89208491605971 4.39110039111988
+2 1411 51 0 1.89208491605971 4.39110039111988
+2 1412 263 0 1.89208491605971 4.39110039111988
+0
+0101000
+-3398 0 +3281 0 *
+Ed
+1 825 0 5.0336775696495 7.53269304470967
+2 1411 51 0 5.0336775696495 7.53269304470967
+2 1412 263 0 5.0336775696495 7.53269304470967
+0
+0101000
++2946 0 -2829 0 *
+Wi
+0101100
++2529 0 -3397 0 +3280 0 -3165 0 +3055 0 -2945 0 +2828 0 +2528 0 *
+Fa
+0 1e-07 51 0
+0101000
+-2530 0 +2527 0 *
+Ed
+ 1e-07 1 1 0
+1 826 0 3.55014770291568 6.04916317797585
+2 1413 264 0 3.55014770291568 6.04916317797585
+2 1414 263 0 3.55014770291568 6.04916317797585
+0
+0101000
++3396 0 -3279 0 *
+Wi
+0101100
+-2529 0 -3395 0 +3278 0 -2525 0 *
+Fa
+0 1e-07 263 0
+0101000
++2524 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 0.990000000223517
+0 0
+0101101
+Ed
+1 827 0 4.97631182851448 5.98722238568202
+2 1415 265 0 4.97631182851448 5.98722238568202
+2 1416 264 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2522 0 +3394 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 0.990000000223517
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 828 0 -6.28784925781463 0.420354674684743
+2 1417 264 0 -6.28784925781463 0.420354674684743
+2 1418 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2520 0 -2522 0 *
+Ed
+1 827 0 6.57914822867715 7.5900587858447
+2 1415 265 0 6.57914822867715 7.5900587858447
+2 1416 264 0 6.57914822867715 7.5900587858447
+0
+0101000
++2520 0 -3277 0 *
+Wi
+0101100
+-2521 0 +2519 0 -3393 0 -2518 0 +2525 0 +3276 0 *
+Fa
+0 1e-07 264 0
+0101000
++2517 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 1.99000000022352
+0 0
+0101101
+Ed
+1 829 0 -1.99000000022352 -0.990000000223517
+2 1419 265 0 -1.99000000022352 -0.990000000223517
+2 1420 414 0 -1.99000000022352 -0.990000000223517
+0
+0101000
++2515 0 -2522 0 *
+Ed
+1 830 0 4.97631182851448 5.98722238568202
+2 1421 265 0 4.97631182851448 5.98722238568202
+2 1422 266 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2515 0 +3390 0 *
+Wi
+0101100
++2521 0 -2514 0 +3389 0 -2513 0 *
+Fa
+0 1e-07 265 0
+0101000
++2512 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 32.9900000002235
+0 0
+0101101
+Ed
+1 831 0 4.97631182851448 5.98722238568202
+2 1423 265 0 4.97631182851448 5.98722238568202
+2 1424 267 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2510 0 +3388 0 *
+Ed
+1 832 0 -33.9900000002235 -32.9900000002235
+2 1425 265 0 -33.9900000002235 -32.9900000002235
+2 1426 414 0 -33.9900000002235 -32.9900000002235
+0
+0101000
++2539 0 -2510 0 *
+Wi
+0101100
++2509 0 -2508 0 +3387 0 -2538 0 *
+Fa
+0 1e-07 265 0
+0101000
++2507 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 1.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 833 0 -6.28784925781463 0.420354674684743
+2 1427 266 0 -6.28784925781463 0.420354674684743
+2 1428 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2505 0 -2515 0 *
+Ed
+1 830 0 6.57914822867715 7.5900587858447
+2 1421 265 0 6.57914822867715 7.5900587858447
+2 1422 266 0 6.57914822867715 7.5900587858447
+0
+0101000
++2505 0 -3273 0 *
+Ed
+ 1e-07 1 1 0
+1 834 0 3.55014770291568 6.04916317797585
+2 1429 268 0 3.55014770291568 6.04916317797585
+2 1430 266 0 3.55014770291568 6.04916317797585
+0
+0101000
++3386 0 -3269 0 *
+Wi
+0101100
+-2513 0 +2504 0 -3385 0 -2503 0 +2502 0 +3268 0 *
+Fa
+0 1e-07 266 0
+0101000
++2501 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 32.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 835 0 -6.28784925781463 0.420354674684743
+2 1431 267 0 -6.28784925781463 0.420354674684743
+2 1432 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2499 0 -2510 0 *
+Ed
+1 831 0 6.57914822867715 7.5900587858447
+2 1423 265 0 6.57914822867715 7.5900587858447
+2 1424 267 0 6.57914822867715 7.5900587858447
+0
+0101000
++2499 0 -3271 0 *
+Ed
+ 1e-07 1 1 0
+1 836 0 3.55014770291568 6.04916317797585
+2 1433 267 0 3.55014770291568 6.04916317797585
+2 1434 269 0 3.55014770291568 6.04916317797585
+0
+0101000
++3384 0 -3267 0 *
+Wi
+0101100
+-2509 0 +2498 0 -3383 0 -2497 0 +2496 0 +3266 0 *
+Fa
+0 1e-07 267 0
+0101000
++2495 0 *
+Ed
+ 1e-07 1 1 0
+1 837 0 3.55014770291568 6.04916317797585
+2 1435 270 0 3.55014770291568 6.04916317797585
+2 1436 268 0 3.55014770291568 6.04916317797585
+0
+0101000
++3382 0 -3265 0 *
+Wi
+0101100
++2502 0 -3381 0 +3264 0 -2493 0 *
+Fa
+0 1e-07 268 0
+0101000
++2492 0 *
+Ed
+ 1e-07 1 1 0
+1 838 0 3.55014770291568 6.04916317797585
+2 1437 269 0 3.55014770291568 6.04916317797585
+2 1438 271 0 3.55014770291568 6.04916317797585
+0
+0101000
++3380 0 -3263 0 *
+Wi
+0101100
++2490 0 -3379 0 +3262 0 -2496 0 *
+Fa
+0 1e-07 269 0
+0101000
++2489 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 2.99000000022352
+0 0
+0101101
+Ed
+1 839 0 4.97631182851448 5.98722238568202
+2 1439 265 0 4.97631182851448 5.98722238568202
+2 1440 270 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2487 0 +3378 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 2.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 840 0 -6.28784925781463 0.420354674684743
+2 1441 270 0 -6.28784925781463 0.420354674684743
+2 1442 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2485 0 -2487 0 *
+Ed
+1 839 0 6.57914822867715 7.5900587858447
+2 1439 265 0 6.57914822867715 7.5900587858447
+2 1440 270 0 6.57914822867715 7.5900587858447
+0
+0101000
++2485 0 -3261 0 *
+Wi
+0101100
+-2486 0 +2484 0 -3377 0 -2483 0 +2493 0 +3260 0 *
+Fa
+0 1e-07 270 0
+0101000
++2482 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 31.9900000002235
+0 0
+0101101
+Ed
+1 841 0 4.97631182851448 5.98722238568202
+2 1443 265 0 4.97631182851448 5.98722238568202
+2 1444 271 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2480 0 +3376 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 31.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 842 0 -6.28784925781463 0.420354674684743
+2 1445 271 0 -6.28784925781463 0.420354674684743
+2 1446 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2478 0 -2480 0 *
+Ed
+1 841 0 6.57914822867715 7.5900587858447
+2 1443 265 0 6.57914822867715 7.5900587858447
+2 1444 271 0 6.57914822867715 7.5900587858447
+0
+0101000
++2478 0 -3259 0 *
+Wi
+0101100
+-2479 0 +2477 0 -3375 0 -2476 0 +2490 0 +3258 0 *
+Fa
+0 1e-07 271 0
+0101000
++2475 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 3.99000000022352
+0 0
+0101101
+Ed
+1 843 0 -3.99000000022352 -2.99000000022352
+2 1447 265 0 -3.99000000022352 -2.99000000022352
+2 1448 414 0 -3.99000000022352 -2.99000000022352
+0
+0101000
++2473 0 -2487 0 *
+Ed
+1 844 0 4.97631182851448 5.98722238568202
+2 1449 265 0 4.97631182851448 5.98722238568202
+2 1450 272 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2473 0 +3374 0 *
+Wi
+0101100
++2486 0 -2472 0 +3373 0 -2471 0 *
+Fa
+0 1e-07 265 0
+0101000
++2470 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 30.9900000002235
+0 0
+0101101
+Ed
+1 845 0 4.97631182851448 5.98722238568202
+2 1451 265 0 4.97631182851448 5.98722238568202
+2 1452 273 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2468 0 +3372 0 *
+Ed
+1 846 0 -31.9900000002235 -30.9900000002235
+2 1453 265 0 -31.9900000002235 -30.9900000002235
+2 1454 414 0 -31.9900000002235 -30.9900000002235
+0
+0101000
++2480 0 -2468 0 *
+Wi
+0101100
++2467 0 -2466 0 +3371 0 -2479 0 *
+Fa
+0 1e-07 265 0
+0101000
++2465 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 3.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 847 0 -6.28784925781463 0.420354674684743
+2 1455 272 0 -6.28784925781463 0.420354674684743
+2 1456 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2463 0 -2473 0 *
+Ed
+1 844 0 6.57914822867715 7.5900587858447
+2 1449 265 0 6.57914822867715 7.5900587858447
+2 1450 272 0 6.57914822867715 7.5900587858447
+0
+0101000
++2463 0 -3257 0 *
+Ed
+ 1e-07 1 1 0
+1 848 0 3.55014770291568 6.04916317797585
+2 1457 274 0 3.55014770291568 6.04916317797585
+2 1458 272 0 3.55014770291568 6.04916317797585
+0
+0101000
++3370 0 -3253 0 *
+Wi
+0101100
+-2471 0 +2462 0 -3369 0 -2461 0 +2460 0 +3252 0 *
+Fa
+0 1e-07 272 0
+0101000
++2459 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 30.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 849 0 -6.28784925781463 0.420354674684743
+2 1459 273 0 -6.28784925781463 0.420354674684743
+2 1460 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2457 0 -2468 0 *
+Ed
+1 845 0 6.57914822867715 7.5900587858447
+2 1451 265 0 6.57914822867715 7.5900587858447
+2 1452 273 0 6.57914822867715 7.5900587858447
+0
+0101000
++2457 0 -3255 0 *
+Ed
+ 1e-07 1 1 0
+1 850 0 3.55014770291568 6.04916317797585
+2 1461 273 0 3.55014770291568 6.04916317797585
+2 1462 275 0 3.55014770291568 6.04916317797585
+0
+0101000
++3368 0 -3251 0 *
+Wi
+0101100
+-2467 0 +2456 0 -3367 0 -2455 0 +2454 0 +3250 0 *
+Fa
+0 1e-07 273 0
+0101000
++2453 0 *
+Ed
+ 1e-07 1 1 0
+1 851 0 3.55014770291568 6.04916317797585
+2 1463 276 0 3.55014770291568 6.04916317797585
+2 1464 274 0 3.55014770291568 6.04916317797585
+0
+0101000
++3366 0 -3249 0 *
+Wi
+0101100
++2460 0 -3365 0 +3248 0 -2451 0 *
+Ve
+1.92612988393822e-06
+5 8.07774721070175 4.10471725463867
+0 0
+0101101
+Ve
+5 8.07774721070175 5.91961097717285
+0 0
+0101101
+Ed
+ 2.66453525910038e-15 1 1 0
+1 852 0 1.11471725441515 2.92961097694933
+2 1465 274 0 1.11471725441515 2.92961097694933
+2 1466 416 0 1.11471725441515 2.92961097694933
+0
+0101000
++2449 0 -2448 0 *
+Ve
+-5 8.07774721070175 4.10471725463867
+0 0
+0101101
+Ed
+ 5.49308015822668e-15 1 1 0
+1 853 0 2.58733081913747 3.69585448804212
+2 1467 274 0 2.58733081913747 3.69585448804212
+2 1468 417 0 2.58733081913747 3.69585448804212
+0
+0101000
++2449 0 -2446 0 *
+Ve
+-5 8.07774721070175 5.91961097717285
+0 0
+0101101
+Ed
+1 854 0 2.58733081913747 3.69585448804212
+2 1469 274 0 2.58733081913747 3.69585448804212
+2 1470 418 0 2.58733081913747 3.69585448804212
+0
+0101000
++2448 0 -2444 0 *
+Ed
+ 3.99680288865056e-15 1 1 0
+1 855 0 1.11471725441515 2.92961097694933
+2 1471 274 0 1.11471725441515 2.92961097694933
+2 1472 419 0 1.11471725441515 2.92961097694933
+0
+0101000
++2446 0 -2444 0 *
+Wi
+0101100
+-2447 0 +2445 0 -2443 0 +2442 0 *
+Fa
+0 1e-07 274 0
+0101000
++2450 0 +2441 0 *
+Ed
+ 1e-07 1 1 0
+1 856 0 3.55014770291568 6.04916317797585
+2 1473 275 0 3.55014770291568 6.04916317797585
+2 1474 277 0 3.55014770291568 6.04916317797585
+0
+0101000
++3364 0 -3247 0 *
+Wi
+0101100
++2439 0 -3363 0 +3246 0 -2454 0 *
+Ve
+5 8.07774721070175 29.1047172546387
+0 0
+0101101
+Ve
+5 8.07774721070175 30.9196109771729
+0 0
+0101101
+Ed
+1 857 0 26.1147172544152 27.9296109769493
+2 1475 275 0 26.1147172544152 27.9296109769493
+2 1476 420 0 26.1147172544152 27.9296109769493
+0
+0101000
++2437 0 -2436 0 *
+Ve
+-5 8.07774721070175 29.1047172546387
+0 0
+0101101
+Ed
+1 858 0 2.58733081913747 3.69585448804212
+2 1477 275 0 2.58733081913747 3.69585448804212
+2 1478 421 0 2.58733081913747 3.69585448804212
+0
+0101000
++2437 0 -2434 0 *
+Ve
+-5 8.07774721070175 30.9196109771729
+0 0
+0101101
+Ed
+1 859 0 2.58733081913747 3.69585448804212
+2 1479 275 0 2.58733081913747 3.69585448804212
+2 1480 422 0 2.58733081913747 3.69585448804212
+0
+0101000
++2436 0 -2432 0 *
+Ed
+1 860 0 26.1147172544152 27.9296109769493
+2 1481 275 0 26.1147172544152 27.9296109769493
+2 1482 423 0 26.1147172544152 27.9296109769493
+0
+0101000
++2434 0 -2432 0 *
+Wi
+0101100
+-2435 0 +2433 0 -2431 0 +2430 0 *
+Fa
+0 1e-07 275 0
+0101000
++2438 0 +2429 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 5.99000000022352
+0 0
+0101101
+Ed
+1 861 0 4.97631182851448 5.98722238568202
+2 1483 265 0 4.97631182851448 5.98722238568202
+2 1484 276 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2427 0 +3362 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 5.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 862 0 -6.28784925781463 0.420354674684743
+2 1485 276 0 -6.28784925781463 0.420354674684743
+2 1486 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2425 0 -2427 0 *
+Ed
+1 861 0 6.57914822867715 7.5900587858447
+2 1483 265 0 6.57914822867715 7.5900587858447
+2 1484 276 0 6.57914822867715 7.5900587858447
+0
+0101000
++2425 0 -3245 0 *
+Wi
+0101100
+-2426 0 +2424 0 -3361 0 -2423 0 +2451 0 +3244 0 *
+Fa
+0 1e-07 276 0
+0101000
++2422 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 28.9900000002235
+0 0
+0101101
+Ed
+1 863 0 4.97631182851448 5.98722238568202
+2 1487 265 0 4.97631182851448 5.98722238568202
+2 1488 277 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2420 0 +3360 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 28.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 864 0 -6.28784925781463 0.420354674684743
+2 1489 277 0 -6.28784925781463 0.420354674684743
+2 1490 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2418 0 -2420 0 *
+Ed
+1 863 0 6.57914822867715 7.5900587858447
+2 1487 265 0 6.57914822867715 7.5900587858447
+2 1488 277 0 6.57914822867715 7.5900587858447
+0
+0101000
++2418 0 -3243 0 *
+Wi
+0101100
+-2419 0 +2417 0 -3359 0 -2416 0 +2439 0 +3242 0 *
+Fa
+0 1e-07 277 0
+0101000
++2415 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 6.99000000022352
+0 0
+0101101
+Ed
+1 865 0 -6.99000000022352 -5.99000000022352
+2 1491 265 0 -6.99000000022352 -5.99000000022352
+2 1492 414 0 -6.99000000022352 -5.99000000022352
+0
+0101000
++2413 0 -2427 0 *
+Ed
+1 866 0 4.97631182851448 5.98722238568202
+2 1493 265 0 4.97631182851448 5.98722238568202
+2 1494 278 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2413 0 +3358 0 *
+Wi
+0101100
++2426 0 -2412 0 +3357 0 -2411 0 *
+Fa
+0 1e-07 265 0
+0101000
++2410 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 27.9900000002235
+0 0
+0101101
+Ed
+1 867 0 4.97631182851448 5.98722238568202
+2 1495 265 0 4.97631182851448 5.98722238568202
+2 1496 279 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2408 0 +3356 0 *
+Ed
+1 868 0 -28.9900000002235 -27.9900000002235
+2 1497 265 0 -28.9900000002235 -27.9900000002235
+2 1498 414 0 -28.9900000002235 -27.9900000002235
+0
+0101000
++2420 0 -2408 0 *
+Wi
+0101100
++2407 0 -2406 0 +3355 0 -2419 0 *
+Fa
+0 1e-07 265 0
+0101000
++2405 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 6.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 869 0 -6.28784925781463 0.420354674684743
+2 1499 278 0 -6.28784925781463 0.420354674684743
+2 1500 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2403 0 -2413 0 *
+Ed
+1 866 0 6.57914822867715 7.5900587858447
+2 1493 265 0 6.57914822867715 7.5900587858447
+2 1494 278 0 6.57914822867715 7.5900587858447
+0
+0101000
++2403 0 -3241 0 *
+Ed
+ 1e-07 1 1 0
+1 870 0 3.55014770291568 6.04916317797585
+2 1501 280 0 3.55014770291568 6.04916317797585
+2 1502 278 0 3.55014770291568 6.04916317797585
+0
+0101000
++3354 0 -3237 0 *
+Wi
+0101100
+-2411 0 +2402 0 -3353 0 -2401 0 +2400 0 +3236 0 *
+Fa
+0 1e-07 278 0
+0101000
++2399 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 27.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 871 0 -6.28784925781463 0.420354674684743
+2 1503 279 0 -6.28784925781463 0.420354674684743
+2 1504 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2397 0 -2408 0 *
+Ed
+1 867 0 6.57914822867715 7.5900587858447
+2 1495 265 0 6.57914822867715 7.5900587858447
+2 1496 279 0 6.57914822867715 7.5900587858447
+0
+0101000
++2397 0 -3239 0 *
+Ed
+ 1e-07 1 1 0
+1 872 0 3.55014770291568 6.04916317797585
+2 1505 279 0 3.55014770291568 6.04916317797585
+2 1506 281 0 3.55014770291568 6.04916317797585
+0
+0101000
++3352 0 -3235 0 *
+Wi
+0101100
+-2407 0 +2396 0 -3351 0 -2395 0 +2394 0 +3234 0 *
+Fa
+0 1e-07 279 0
+0101000
++2393 0 *
+Ed
+ 1e-07 1 1 0
+1 873 0 3.55014770291568 6.04916317797585
+2 1507 282 0 3.55014770291568 6.04916317797585
+2 1508 280 0 3.55014770291568 6.04916317797585
+0
+0101000
++3350 0 -3233 0 *
+Wi
+0101100
++2400 0 -3349 0 +3232 0 -2391 0 *
+Fa
+0 1e-07 280 0
+0101000
++2390 0 *
+Ed
+ 1e-07 1 1 0
+1 874 0 3.55014770291568 6.04916317797585
+2 1509 281 0 3.55014770291568 6.04916317797585
+2 1510 283 0 3.55014770291568 6.04916317797585
+0
+0101000
++3348 0 -3231 0 *
+Wi
+0101100
++2388 0 -3347 0 +3230 0 -2394 0 *
+Fa
+0 1e-07 281 0
+0101000
++2387 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 7.99000000022352
+0 0
+0101101
+Ed
+1 875 0 4.97631182851448 5.98722238568202
+2 1511 265 0 4.97631182851448 5.98722238568202
+2 1512 282 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2385 0 +3346 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 7.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 876 0 -6.28784925781463 0.420354674684743
+2 1513 282 0 -6.28784925781463 0.420354674684743
+2 1514 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2383 0 -2385 0 *
+Ed
+1 875 0 6.57914822867715 7.5900587858447
+2 1511 265 0 6.57914822867715 7.5900587858447
+2 1512 282 0 6.57914822867715 7.5900587858447
+0
+0101000
++2383 0 -3229 0 *
+Wi
+0101100
+-2384 0 +2382 0 -3345 0 -2381 0 +2391 0 +3228 0 *
+Fa
+0 1e-07 282 0
+0101000
++2380 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 26.9900000002235
+0 0
+0101101
+Ed
+1 877 0 4.97631182851448 5.98722238568202
+2 1515 265 0 4.97631182851448 5.98722238568202
+2 1516 283 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2378 0 +3344 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 26.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 878 0 -6.28784925781463 0.420354674684743
+2 1517 283 0 -6.28784925781463 0.420354674684743
+2 1518 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2376 0 -2378 0 *
+Ed
+1 877 0 6.57914822867715 7.5900587858447
+2 1515 265 0 6.57914822867715 7.5900587858447
+2 1516 283 0 6.57914822867715 7.5900587858447
+0
+0101000
++2376 0 -3227 0 *
+Wi
+0101100
+-2377 0 +2375 0 -3343 0 -2374 0 +2388 0 +3226 0 *
+Fa
+0 1e-07 283 0
+0101000
++2373 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 8.99000000022352
+0 0
+0101101
+Ed
+1 879 0 -8.99000000022352 -7.99000000022352
+2 1519 265 0 -8.99000000022352 -7.99000000022352
+2 1520 414 0 -8.99000000022352 -7.99000000022352
+0
+0101000
++2371 0 -2385 0 *
+Ed
+1 880 0 4.97631182851448 5.98722238568202
+2 1521 265 0 4.97631182851448 5.98722238568202
+2 1522 284 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2371 0 +3342 0 *
+Wi
+0101100
++2384 0 -2370 0 +3341 0 -2369 0 *
+Fa
+0 1e-07 265 0
+0101000
++2368 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 25.9900000002235
+0 0
+0101101
+Ed
+1 881 0 4.97631182851448 5.98722238568202
+2 1523 265 0 4.97631182851448 5.98722238568202
+2 1524 285 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2366 0 +3340 0 *
+Ed
+1 882 0 -26.9900000002235 -25.9900000002235
+2 1525 265 0 -26.9900000002235 -25.9900000002235
+2 1526 414 0 -26.9900000002235 -25.9900000002235
+0
+0101000
++2378 0 -2366 0 *
+Wi
+0101100
++2365 0 -2364 0 +3339 0 -2377 0 *
+Fa
+0 1e-07 265 0
+0101000
++2363 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 8.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 883 0 -6.28784925781463 0.420354674684743
+2 1527 284 0 -6.28784925781463 0.420354674684743
+2 1528 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2361 0 -2371 0 *
+Ed
+1 880 0 6.57914822867715 7.5900587858447
+2 1521 265 0 6.57914822867715 7.5900587858447
+2 1522 284 0 6.57914822867715 7.5900587858447
+0
+0101000
++2361 0 -3225 0 *
+Ed
+ 1e-07 1 1 0
+1 884 0 3.55014770291568 6.04916317797585
+2 1529 286 0 3.55014770291568 6.04916317797585
+2 1530 284 0 3.55014770291568 6.04916317797585
+0
+0101000
++3338 0 -3221 0 *
+Wi
+0101100
+-2369 0 +2360 0 -3337 0 -2359 0 +2358 0 +3220 0 *
+Fa
+0 1e-07 284 0
+0101000
++2357 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 25.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 885 0 -6.28784925781463 0.420354674684743
+2 1531 285 0 -6.28784925781463 0.420354674684743
+2 1532 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2355 0 -2366 0 *
+Ed
+1 881 0 6.57914822867715 7.5900587858447
+2 1523 265 0 6.57914822867715 7.5900587858447
+2 1524 285 0 6.57914822867715 7.5900587858447
+0
+0101000
++2355 0 -3223 0 *
+Ed
+ 1e-07 1 1 0
+1 886 0 3.55014770291568 6.04916317797585
+2 1533 285 0 3.55014770291568 6.04916317797585
+2 1534 287 0 3.55014770291568 6.04916317797585
+0
+0101000
++3336 0 -3219 0 *
+Wi
+0101100
+-2365 0 +2354 0 -3335 0 -2353 0 +2352 0 +3218 0 *
+Fa
+0 1e-07 285 0
+0101000
++2351 0 *
+Ed
+ 1e-07 1 1 0
+1 887 0 3.55014770291568 6.04916317797585
+2 1535 288 0 3.55014770291568 6.04916317797585
+2 1536 286 0 3.55014770291568 6.04916317797585
+0
+0101000
++3334 0 -3217 0 *
+Wi
+0101100
++2358 0 -3333 0 +3216 0 -2349 0 *
+Ve
+5 8.07774721070176 9.10471725463867
+0 0
+0101101
+Ve
+5 8.07774721070176 10.9196109771729
+0 0
+0101101
+Ed
+1 888 0 6.11471725441515 7.92961097694933
+2 1537 286 0 6.11471725441515 7.92961097694933
+2 1538 424 0 6.11471725441515 7.92961097694933
+0
+0101000
++2347 0 -2346 0 *
+Ve
+-5 8.07774721070176 9.10471725463867
+0 0
+0101101
+Ed
+ 2.74654007911334e-15 1 1 0
+1 889 0 2.58733081913747 3.69585448804212
+2 1539 286 0 2.58733081913747 3.69585448804212
+2 1540 425 0 2.58733081913747 3.69585448804212
+0
+0101000
++2347 0 -2344 0 *
+Ve
+-5 8.07774721070176 10.9196109771729
+0 0
+0101101
+Ed
+1 890 0 2.58733081913747 3.69585448804212
+2 1541 286 0 2.58733081913747 3.69585448804212
+2 1542 426 0 2.58733081913747 3.69585448804212
+0
+0101000
++2346 0 -2342 0 *
+Ed
+ 2.97904098389673e-15 1 1 0
+1 891 0 6.11471725441515 7.92961097694933
+2 1543 286 0 6.11471725441515 7.92961097694933
+2 1544 427 0 6.11471725441515 7.92961097694933
+0
+0101000
++2344 0 -2342 0 *
+Wi
+0101100
+-2345 0 +2343 0 -2341 0 +2340 0 *
+Fa
+0 1e-07 286 0
+0101000
++2348 0 +2339 0 *
+Ed
+ 1e-07 1 1 0
+1 892 0 3.55014770291568 6.04916317797585
+2 1545 287 0 3.55014770291568 6.04916317797585
+2 1546 289 0 3.55014770291568 6.04916317797585
+0
+0101000
++3332 0 -3215 0 *
+Wi
+0101100
++2337 0 -3331 0 +3214 0 -2352 0 *
+Ve
+5 8.07774721070176 24.1047172546387
+0 0
+0101101
+Ve
+5 8.07774721070176 25.9196109771729
+0 0
+0101101
+Ed
+1 893 0 21.1147172544152 22.9296109769493
+2 1547 287 0 21.1147172544152 22.9296109769493
+2 1548 428 0 21.1147172544152 22.9296109769493
+0
+0101000
++2335 0 -2334 0 *
+Ve
+-5 8.07774721070176 24.1047172546387
+0 0
+0101101
+Ed
+1 894 0 2.58733081913747 3.69585448804212
+2 1549 287 0 2.58733081913747 3.69585448804212
+2 1550 429 0 2.58733081913747 3.69585448804212
+0
+0101000
++2335 0 -2332 0 *
+Ve
+-5 8.07774721070176 25.9196109771729
+0 0
+0101101
+Ed
+1 895 0 2.58733081913747 3.69585448804212
+2 1551 287 0 2.58733081913747 3.69585448804212
+2 1552 430 0 2.58733081913747 3.69585448804212
+0
+0101000
++2334 0 -2330 0 *
+Ed
+1 896 0 21.1147172544152 22.9296109769493
+2 1553 287 0 21.1147172544152 22.9296109769493
+2 1554 431 0 21.1147172544152 22.9296109769493
+0
+0101000
++2332 0 -2330 0 *
+Wi
+0101100
+-2333 0 +2331 0 -2329 0 +2328 0 *
+Fa
+0 1e-07 287 0
+0101000
++2336 0 +2327 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 10.9900000002235
+0 0
+0101101
+Ed
+1 897 0 4.97631182851448 5.98722238568202
+2 1555 265 0 4.97631182851448 5.98722238568202
+2 1556 288 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2325 0 +3330 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 10.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 898 0 -6.28784925781463 0.420354674684743
+2 1557 288 0 -6.28784925781463 0.420354674684743
+2 1558 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2323 0 -2325 0 *
+Ed
+1 897 0 6.57914822867715 7.5900587858447
+2 1555 265 0 6.57914822867715 7.5900587858447
+2 1556 288 0 6.57914822867715 7.5900587858447
+0
+0101000
++2323 0 -3213 0 *
+Wi
+0101100
+-2324 0 +2322 0 -3329 0 -2321 0 +2349 0 +3212 0 *
+Fa
+0 1e-07 288 0
+0101000
++2320 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 23.9900000002235
+0 0
+0101101
+Ed
+1 899 0 4.97631182851448 5.98722238568202
+2 1559 265 0 4.97631182851448 5.98722238568202
+2 1560 289 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2318 0 +3328 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 23.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 900 0 -6.28784925781463 0.420354674684743
+2 1561 289 0 -6.28784925781463 0.420354674684743
+2 1562 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2316 0 -2318 0 *
+Ed
+1 899 0 6.57914822867715 7.5900587858447
+2 1559 265 0 6.57914822867715 7.5900587858447
+2 1560 289 0 6.57914822867715 7.5900587858447
+0
+0101000
++2316 0 -3211 0 *
+Wi
+0101100
+-2317 0 +2315 0 -3327 0 -2314 0 +2337 0 +3210 0 *
+Fa
+0 1e-07 289 0
+0101000
++2313 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 11.9900000002235
+0 0
+0101101
+Ed
+1 901 0 -11.9900000002235 -10.9900000002235
+2 1563 265 0 -11.9900000002235 -10.9900000002235
+2 1564 414 0 -11.9900000002235 -10.9900000002235
+0
+0101000
++2311 0 -2325 0 *
+Ed
+1 902 0 4.97631182851448 5.98722238568202
+2 1565 265 0 4.97631182851448 5.98722238568202
+2 1566 290 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2311 0 +3326 0 *
+Wi
+0101100
++2324 0 -2310 0 +3325 0 -2309 0 *
+Fa
+0 1e-07 265 0
+0101000
++2308 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 22.9900000002235
+0 0
+0101101
+Ed
+1 903 0 4.97631182851448 5.98722238568202
+2 1567 265 0 4.97631182851448 5.98722238568202
+2 1568 291 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2306 0 +3324 0 *
+Ed
+1 904 0 -23.9900000002235 -22.9900000002235
+2 1569 265 0 -23.9900000002235 -22.9900000002235
+2 1570 414 0 -23.9900000002235 -22.9900000002235
+0
+0101000
++2318 0 -2306 0 *
+Wi
+0101100
++2305 0 -2304 0 +3323 0 -2317 0 *
+Fa
+0 1e-07 265 0
+0101000
++2303 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 11.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 905 0 -6.28784925781463 0.420354674684743
+2 1571 290 0 -6.28784925781463 0.420354674684743
+2 1572 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2301 0 -2311 0 *
+Ed
+1 902 0 6.57914822867715 7.5900587858447
+2 1565 265 0 6.57914822867715 7.5900587858447
+2 1566 290 0 6.57914822867715 7.5900587858447
+0
+0101000
++2301 0 -3209 0 *
+Ed
+ 1e-07 1 1 0
+1 906 0 3.55014770291568 6.04916317797585
+2 1573 292 0 3.55014770291568 6.04916317797585
+2 1574 290 0 3.55014770291568 6.04916317797585
+0
+0101000
++3322 0 -3205 0 *
+Wi
+0101100
+-2309 0 +2300 0 -3321 0 -2299 0 +2298 0 +3204 0 *
+Fa
+0 1e-07 290 0
+0101000
++2297 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 22.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 907 0 -6.28784925781463 0.420354674684743
+2 1575 291 0 -6.28784925781463 0.420354674684743
+2 1576 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2295 0 -2306 0 *
+Ed
+1 903 0 6.57914822867715 7.5900587858447
+2 1567 265 0 6.57914822867715 7.5900587858447
+2 1568 291 0 6.57914822867715 7.5900587858447
+0
+0101000
++2295 0 -3207 0 *
+Ed
+ 1e-07 1 1 0
+1 908 0 3.55014770291568 6.04916317797585
+2 1577 291 0 3.55014770291568 6.04916317797585
+2 1578 293 0 3.55014770291568 6.04916317797585
+0
+0101000
++3320 0 -3203 0 *
+Wi
+0101100
+-2305 0 +2294 0 -3319 0 -2293 0 +2292 0 +3202 0 *
+Fa
+0 1e-07 291 0
+0101000
++2291 0 *
+Ed
+ 1e-07 1 1 0
+1 909 0 3.55014770291568 6.04916317797585
+2 1579 294 0 3.55014770291568 6.04916317797585
+2 1580 292 0 3.55014770291568 6.04916317797585
+0
+0101000
++3318 0 -3201 0 *
+Wi
+0101100
++2298 0 -3317 0 +3200 0 -2289 0 *
+Fa
+0 1e-07 292 0
+0101000
++2288 0 *
+Ed
+ 1e-07 1 1 0
+1 910 0 3.55014770291568 6.04916317797585
+2 1581 293 0 3.55014770291568 6.04916317797585
+2 1582 295 0 3.55014770291568 6.04916317797585
+0
+0101000
++3316 0 -3199 0 *
+Wi
+0101100
++2286 0 -3315 0 +3198 0 -2292 0 *
+Fa
+0 1e-07 293 0
+0101000
++2285 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 12.9900000002235
+0 0
+0101101
+Ed
+1 911 0 4.97631182851448 5.98722238568202
+2 1583 265 0 4.97631182851448 5.98722238568202
+2 1584 294 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2283 0 +3314 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 12.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 912 0 -6.28784925781463 0.420354674684743
+2 1585 294 0 -6.28784925781463 0.420354674684743
+2 1586 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2281 0 -2283 0 *
+Ed
+1 911 0 6.57914822867715 7.5900587858447
+2 1583 265 0 6.57914822867715 7.5900587858447
+2 1584 294 0 6.57914822867715 7.5900587858447
+0
+0101000
++2281 0 -3197 0 *
+Wi
+0101100
+-2282 0 +2280 0 -3313 0 -2279 0 +2289 0 +3196 0 *
+Fa
+0 1e-07 294 0
+0101000
++2278 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 21.9900000002235
+0 0
+0101101
+Ed
+1 913 0 4.97631182851448 5.98722238568202
+2 1587 265 0 4.97631182851448 5.98722238568202
+2 1588 295 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2276 0 +3312 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 21.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 914 0 -6.28784925781463 0.420354674684743
+2 1589 295 0 -6.28784925781463 0.420354674684743
+2 1590 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2274 0 -2276 0 *
+Ed
+1 913 0 6.57914822867715 7.5900587858447
+2 1587 265 0 6.57914822867715 7.5900587858447
+2 1588 295 0 6.57914822867715 7.5900587858447
+0
+0101000
++2274 0 -3195 0 *
+Wi
+0101100
+-2275 0 +2273 0 -3311 0 -2272 0 +2286 0 +3194 0 *
+Fa
+0 1e-07 295 0
+0101000
++2271 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 13.9900000002235
+0 0
+0101101
+Ed
+ 1.14999999999996e-07 1 1 0
+1 915 0 -13.9900000002235 -12.9900000002235
+2 1591 265 0 -13.9900000002235 -12.9900000002235
+2 1592 414 0 -13.9900000002235 -12.9900000002235
+0
+0101000
++2269 0 -2283 0 *
+Ed
+1 916 0 4.97631182851448 5.98722238568202
+2 1593 265 0 4.97631182851448 5.98722238568202
+2 1594 296 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2269 0 +3310 0 *
+Wi
+0101100
++2282 0 -2268 0 +3309 0 -2267 0 *
+Fa
+0 1e-07 265 0
+0101000
++2266 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 20.9900000002235
+0 0
+0101101
+Ed
+1 917 0 4.97631182851448 5.98722238568202
+2 1595 265 0 4.97631182851448 5.98722238568202
+2 1596 297 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2264 0 +3308 0 *
+Ed
+1 918 0 -21.9900000002235 -20.9900000002235
+2 1597 265 0 -21.9900000002235 -20.9900000002235
+2 1598 414 0 -21.9900000002235 -20.9900000002235
+0
+0101000
++2276 0 -2264 0 *
+Wi
+0101100
++2263 0 -2262 0 +3307 0 -2275 0 *
+Fa
+0 1e-07 265 0
+0101000
++2261 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 13.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 919 0 -6.28784925781463 0.420354674684743
+2 1599 296 0 -6.28784925781463 0.420354674684743
+2 1600 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2259 0 -2269 0 *
+Ed
+1 916 0 6.57914822867715 7.5900587858447
+2 1593 265 0 6.57914822867715 7.5900587858447
+2 1594 296 0 6.57914822867715 7.5900587858447
+0
+0101000
++2259 0 -3193 0 *
+Ed
+ 1e-07 1 1 0
+1 920 0 3.55014770291568 6.04916317797585
+2 1601 298 0 3.55014770291568 6.04916317797585
+2 1602 296 0 3.55014770291568 6.04916317797585
+0
+0101000
++3306 0 -3189 0 *
+Wi
+0101100
+-2267 0 +2258 0 -3305 0 -2257 0 +2256 0 +3188 0 *
+Fa
+0 1e-07 296 0
+0101000
++2255 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 20.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 921 0 -6.28784925781463 0.420354674684743
+2 1603 297 0 -6.28784925781463 0.420354674684743
+2 1604 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2253 0 -2264 0 *
+Ed
+1 917 0 6.57914822867715 7.5900587858447
+2 1595 265 0 6.57914822867715 7.5900587858447
+2 1596 297 0 6.57914822867715 7.5900587858447
+0
+0101000
++2253 0 -3191 0 *
+Ed
+ 1e-07 1 1 0
+1 922 0 3.55014770291568 6.04916317797585
+2 1605 297 0 3.55014770291568 6.04916317797585
+2 1606 299 0 3.55014770291568 6.04916317797585
+0
+0101000
++3304 0 -3187 0 *
+Wi
+0101100
+-2263 0 +2252 0 -3303 0 -2251 0 +2250 0 +3186 0 *
+Fa
+0 1e-07 297 0
+0101000
++2249 0 *
+Ed
+ 1e-07 1 1 0
+1 923 0 3.55014770291568 6.04916317797585
+2 1607 300 0 3.55014770291568 6.04916317797585
+2 1608 298 0 3.55014770291568 6.04916317797585
+0
+0101000
++3302 0 -3185 0 *
+Wi
+0101100
++2256 0 -3301 0 +3184 0 -2247 0 *
+Ve
+5 8.07774721070176 14.1047172546387
+0 0
+0101101
+Ve
+5 8.07774721070176 15.9196109771729
+0 0
+0101101
+Ed
+1 924 0 11.1147172544152 12.9296109769493
+2 1609 298 0 11.1147172544152 12.9296109769493
+2 1610 432 0 11.1147172544152 12.9296109769493
+0
+0101000
++2245 0 -2244 0 *
+Ve
+-5 8.07774721070176 14.1047172546387
+0 0
+0101101
+Ed
+1 925 0 2.58733081913747 3.69585448804212
+2 1611 298 0 2.58733081913747 3.69585448804212
+2 1612 433 0 2.58733081913747 3.69585448804212
+0
+0101000
++2245 0 -2242 0 *
+Ve
+-5 8.07774721070176 15.9196109771729
+0 0
+0101101
+Ed
+1 926 0 2.58733081913747 3.69585448804212
+2 1613 298 0 2.58733081913747 3.69585448804212
+2 1614 434 0 2.58733081913747 3.69585448804212
+0
+0101000
++2244 0 -2240 0 *
+Ed
+1 927 0 11.1147172544152 12.9296109769493
+2 1615 298 0 11.1147172544152 12.9296109769493
+2 1616 435 0 11.1147172544152 12.9296109769493
+0
+0101000
++2242 0 -2240 0 *
+Wi
+0101100
+-2243 0 +2241 0 -2239 0 +2238 0 *
+Fa
+0 1e-07 298 0
+0101000
++2246 0 +2237 0 *
+Ed
+ 1e-07 1 1 0
+1 928 0 3.55014770291568 6.04916317797585
+2 1617 299 0 3.55014770291568 6.04916317797585
+2 1618 301 0 3.55014770291568 6.04916317797585
+0
+0101000
++3300 0 -3183 0 *
+Wi
+0101100
++2235 0 -3299 0 +3182 0 -2250 0 *
+Ve
+5 8.07774721070175 19.1047172546387
+0 0
+0101101
+Ve
+5 8.07774721070175 20.9196109771729
+0 0
+0101101
+Ed
+1 929 0 16.1147172544152 17.9296109769493
+2 1619 299 0 16.1147172544152 17.9296109769493
+2 1620 436 0 16.1147172544152 17.9296109769493
+0
+0101000
++2233 0 -2232 0 *
+Ve
+-5 8.07774721070175 19.1047172546387
+0 0
+0101101
+Ed
+1 930 0 2.58733081913747 3.69585448804212
+2 1621 299 0 2.58733081913747 3.69585448804212
+2 1622 437 0 2.58733081913747 3.69585448804212
+0
+0101000
++2233 0 -2230 0 *
+Ve
+-5 8.07774721070175 20.9196109771729
+0 0
+0101101
+Ed
+1 931 0 2.58733081913747 3.69585448804212
+2 1623 299 0 2.58733081913747 3.69585448804212
+2 1624 438 0 2.58733081913747 3.69585448804212
+0
+0101000
++2232 0 -2228 0 *
+Ed
+1 932 0 16.1147172544152 17.9296109769493
+2 1625 299 0 16.1147172544152 17.9296109769493
+2 1626 439 0 16.1147172544152 17.9296109769493
+0
+0101000
++2230 0 -2228 0 *
+Wi
+0101100
+-2231 0 +2229 0 -2227 0 +2226 0 *
+Fa
+0 1e-07 299 0
+0101000
++2234 0 +2225 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 15.9900000002235
+0 0
+0101101
+Ed
+1 933 0 4.97631182851448 5.98722238568202
+2 1627 265 0 4.97631182851448 5.98722238568202
+2 1628 300 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2223 0 +3298 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 15.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 934 0 -6.28784925781463 0.420354674684743
+2 1629 300 0 -6.28784925781463 0.420354674684743
+2 1630 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2221 0 -2223 0 *
+Ed
+1 933 0 6.57914822867715 7.5900587858447
+2 1627 265 0 6.57914822867715 7.5900587858447
+2 1628 300 0 6.57914822867715 7.5900587858447
+0
+0101000
++2221 0 -3181 0 *
+Wi
+0101100
+-2222 0 +2220 0 -3297 0 -2219 0 +2247 0 +3180 0 *
+Fa
+0 1e-07 300 0
+0101000
++2218 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 18.9900000002235
+0 0
+0101101
+Ed
+1 935 0 4.97631182851448 5.98722238568202
+2 1631 265 0 4.97631182851448 5.98722238568202
+2 1632 301 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2216 0 +3296 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 18.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 936 0 -6.28784925781463 0.420354674684743
+2 1633 301 0 -6.28784925781463 0.420354674684743
+2 1634 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2214 0 -2216 0 *
+Ed
+1 935 0 6.57914822867715 7.5900587858447
+2 1631 265 0 6.57914822867715 7.5900587858447
+2 1632 301 0 6.57914822867715 7.5900587858447
+0
+0101000
++2214 0 -3179 0 *
+Wi
+0101100
+-2215 0 +2213 0 -3295 0 -2212 0 +2235 0 +3178 0 *
+Fa
+0 1e-07 301 0
+0101000
++2211 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 16.9900000002235
+0 0
+0101101
+Ed
+1 937 0 -16.9900000002235 -15.9900000002235
+2 1635 265 0 -16.9900000002235 -15.9900000002235
+2 1636 414 0 -16.9900000002235 -15.9900000002235
+0
+0101000
++2209 0 -2223 0 *
+Ed
+1 938 0 4.97631182851448 5.98722238568202
+2 1637 265 0 4.97631182851448 5.98722238568202
+2 1638 302 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2209 0 +3294 0 *
+Wi
+0101100
++2222 0 -2208 0 +3293 0 -2207 0 *
+Fa
+0 1e-07 265 0
+0101000
++2206 0 *
+Ve
+2.720000002e-05
+-3.35410196624968 11 17.9900000002235
+0 0
+0101101
+Ed
+1 939 0 4.97631182851448 5.98722238568202
+2 1639 265 0 4.97631182851448 5.98722238568202
+2 1640 303 0 4.97631182851448 5.98722238568202
+0
+0101000
+-2204 0 +3292 0 *
+Ed
+1 940 0 -18.9900000002235 -17.9900000002235
+2 1641 265 0 -18.9900000002235 -17.9900000002235
+2 1642 414 0 -18.9900000002235 -17.9900000002235
+0
+0101000
++2216 0 -2204 0 *
+Wi
+0101100
++2203 0 -2202 0 +3291 0 -2215 0 *
+Fa
+0 1e-07 265 0
+0101000
++2201 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 16.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 941 0 -6.28784925781463 0.420354674684743
+2 1643 302 0 -6.28784925781463 0.420354674684743
+2 1644 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2199 0 -2209 0 *
+Ed
+1 938 0 6.57914822867715 7.5900587858447
+2 1637 265 0 6.57914822867715 7.5900587858447
+2 1638 302 0 6.57914822867715 7.5900587858447
+0
+0101000
++2199 0 -3177 0 *
+Ed
+ 1e-07 1 1 0
+1 942 0 3.55014770291568 6.04916317797585
+2 1645 304 0 3.55014770291568 6.04916317797585
+2 1646 302 0 3.55014770291568 6.04916317797585
+0
+0101000
++3290 0 -3173 0 *
+Wi
+0101100
+-2207 0 +2198 0 -3289 0 -2197 0 +2196 0 +3172 0 *
+Fa
+0 1e-07 302 0
+0101000
++2195 0 *
+Ve
+2.720000002e-05
+3.35410196624968 11 17.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 943 0 -6.28784925781463 0.420354674684743
+2 1647 303 0 -6.28784925781463 0.420354674684743
+2 1648 414 0 -6.28784925781463 0.420354674684743
+0
+0101000
++2193 0 -2204 0 *
+Ed
+1 939 0 6.57914822867715 7.5900587858447
+2 1639 265 0 6.57914822867715 7.5900587858447
+2 1640 303 0 6.57914822867715 7.5900587858447
+0
+0101000
++2193 0 -3175 0 *
+Ed
+ 1e-07 1 1 0
+1 944 0 3.55014770291568 6.04916317797585
+2 1649 303 0 3.55014770291568 6.04916317797585
+2 1650 304 0 3.55014770291568 6.04916317797585
+0
+0101000
++3288 0 -3171 0 *
+Wi
+0101100
+-2203 0 +2192 0 -3287 0 -2191 0 +2190 0 +3170 0 *
+Fa
+0 1e-07 303 0
+0101000
++2189 0 *
+Wi
+0101100
++2196 0 -3286 0 +3169 0 -2190 0 *
+Fa
+0 1e-07 304 0
+0101000
++2187 0 *
+Ed
+1 945 0 -1.99000000022352 -0.990000000223517
+2 1651 265 0 -1.99000000022352 -0.990000000223517
+2 1652 414 0 -1.99000000022352 -0.990000000223517
+0
+0101000
++2505 0 -2520 0 *
+Wi
+0101100
++2518 0 +2185 0 -3272 0 -2503 0 *
+Fa
+0 1e-07 265 0
+0101000
++2184 0 *
+Ed
+1 946 0 -33.9900000002235 -32.9900000002235
+2 1653 265 0 -33.9900000002235 -32.9900000002235
+2 1654 414 0 -33.9900000002235 -32.9900000002235
+0
+0101000
++2537 0 -2499 0 *
+Wi
+0101100
++2497 0 +2182 0 -3270 0 -2535 0 *
+Fa
+0 1e-07 265 0
+0101000
++2181 0 *
+Ed
+1 947 0 -3.99000000022352 -2.99000000022352
+2 1655 265 0 -3.99000000022352 -2.99000000022352
+2 1656 414 0 -3.99000000022352 -2.99000000022352
+0
+0101000
++2463 0 -2485 0 *
+Wi
+0101100
++2483 0 +2179 0 -3256 0 -2461 0 *
+Fa
+0 1e-07 265 0
+0101000
++2178 0 *
+Ed
+1 948 0 -31.9900000002235 -30.9900000002235
+2 1657 265 0 -31.9900000002235 -30.9900000002235
+2 1658 414 0 -31.9900000002235 -30.9900000002235
+0
+0101000
++2478 0 -2457 0 *
+Wi
+0101100
++2455 0 +2176 0 -3254 0 -2476 0 *
+Fa
+0 1e-07 265 0
+0101000
++2175 0 *
+Ed
+1 949 0 -6.99000000022352 -5.99000000022352
+2 1659 265 0 -6.99000000022352 -5.99000000022352
+2 1660 414 0 -6.99000000022352 -5.99000000022352
+0
+0101000
++2403 0 -2425 0 *
+Wi
+0101100
++2423 0 +2173 0 -3240 0 -2401 0 *
+Fa
+0 1e-07 265 0
+0101000
++2172 0 *
+Ed
+1 950 0 -28.9900000002235 -27.9900000002235
+2 1661 265 0 -28.9900000002235 -27.9900000002235
+2 1662 414 0 -28.9900000002235 -27.9900000002235
+0
+0101000
++2418 0 -2397 0 *
+Wi
+0101100
++2395 0 +2170 0 -3238 0 -2416 0 *
+Fa
+0 1e-07 265 0
+0101000
++2169 0 *
+Ed
+1 951 0 -8.99000000022352 -7.99000000022352
+2 1663 265 0 -8.99000000022352 -7.99000000022352
+2 1664 414 0 -8.99000000022352 -7.99000000022352
+0
+0101000
++2361 0 -2383 0 *
+Wi
+0101100
++2381 0 +2167 0 -3224 0 -2359 0 *
+Fa
+0 1e-07 265 0
+0101000
++2166 0 *
+Ed
+1 952 0 -26.9900000002235 -25.9900000002235
+2 1665 265 0 -26.9900000002235 -25.9900000002235
+2 1666 414 0 -26.9900000002235 -25.9900000002235
+0
+0101000
++2376 0 -2355 0 *
+Wi
+0101100
++2353 0 +2164 0 -3222 0 -2374 0 *
+Fa
+0 1e-07 265 0
+0101000
++2163 0 *
+Ed
+1 953 0 -11.9900000002235 -10.9900000002235
+2 1667 265 0 -11.9900000002235 -10.9900000002235
+2 1668 414 0 -11.9900000002235 -10.9900000002235
+0
+0101000
++2301 0 -2323 0 *
+Wi
+0101100
++2321 0 +2161 0 -3208 0 -2299 0 *
+Fa
+0 1e-07 265 0
+0101000
++2160 0 *
+Ed
+1 954 0 -23.9900000002235 -22.9900000002235
+2 1669 265 0 -23.9900000002235 -22.9900000002235
+2 1670 414 0 -23.9900000002235 -22.9900000002235
+0
+0101000
++2316 0 -2295 0 *
+Wi
+0101100
++2293 0 +2158 0 -3206 0 -2314 0 *
+Fa
+0 1e-07 265 0
+0101000
++2157 0 *
+Ed
+1 955 0 -13.9900000002235 -12.9900000002235
+2 1671 265 0 -13.9900000002235 -12.9900000002235
+2 1672 414 0 -13.9900000002235 -12.9900000002235
+0
+0101000
++2259 0 -2281 0 *
+Wi
+0101100
++2279 0 +2155 0 -3192 0 -2257 0 *
+Fa
+0 1e-07 265 0
+0101000
++2154 0 *
+Ed
+1 956 0 -21.9900000002235 -20.9900000002235
+2 1673 265 0 -21.9900000002235 -20.9900000002235
+2 1674 414 0 -21.9900000002235 -20.9900000002235
+0
+0101000
++2274 0 -2253 0 *
+Wi
+0101100
++2251 0 +2152 0 -3190 0 -2272 0 *
+Fa
+0 1e-07 265 0
+0101000
++2151 0 *
+Ed
+1 957 0 -16.9900000002235 -15.9900000002235
+2 1675 265 0 -16.9900000002235 -15.9900000002235
+2 1676 414 0 -16.9900000002235 -15.9900000002235
+0
+0101000
++2199 0 -2221 0 *
+Wi
+0101100
++2219 0 +2149 0 -3176 0 -2197 0 *
+Fa
+0 1e-07 265 0
+0101000
++2148 0 *
+Ed
+1 958 0 -18.9900000002235 -17.9900000002235
+2 1677 265 0 -18.9900000002235 -17.9900000002235
+2 1678 414 0 -18.9900000002235 -17.9900000002235
+0
+0101000
++2214 0 -2193 0 *
+Wi
+0101100
++2191 0 +2146 0 -3174 0 -2212 0 *
+Fa
+0 1e-07 265 0
+0101000
++2145 0 *
+Ve
+1e-07
+-10 -0.654700538379252 29.5882886069775
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 959 0 0.5 3
+0
+0101000
++3162 0 -2143 82 *
+Ve
+1e-07
+-10 -1.36602540378444 30.8203394145464
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 960 0 0.577350269189626 2
+0
+0101000
++2143 0 -2141 0 *
+Ed
+ 1e-07 1 1 0
+1 961 0 0.5 3
+2 1679 307 0 0.5 3
+4 C1 305 0 307 0
+0
+0101000
++3161 0 -2141 82 *
+Wi
+0101100
++2142 0 -3160 0 +2140 82 -2139 0 *
+Fa
+0 1e-07 305 0
+0101000
++2138 0 *
+Ve
+1e-07
+-10 -1.36602540378444 28.3562377994086
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 962 0 0.5 3
+2 1680 308 0 0.5 3
+4 C1 306 0 308 0
+0
+0101000
++3159 0 -2136 82 *
+Ed
+ 1e-07 1 1 0
+1 963 0 0 1.42264973081037
+0
+0101000
++2136 0 -2143 0 *
+Wi
+0101100
++2135 0 -3158 0 +2134 82 -2142 0 *
+Fa
+0 1e-07 306 0
+0101000
++2133 0 *
+Ve
+1e-07
+-10 0.366025403784438 31.8203394145464
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 964 0 0.5 3
+2 1681 307 0 0.5 3
+4 C1 309 0 307 0
+0
+0101000
++3157 0 -2131 82 *
+Ed
+ 1e-07 1 1 0
+1 965 0 3.66519142918809 6.80678408277789
+2 1682 307 83 3.66519142918809 6.80678408277789
+2 1683 307 84 3.66519142918809 6.80678408277789
+0
+0101000
++2131 0 -2141 0 *
+Wi
+0101100
++2130 0 -3156 0 +2129 82 -2139 0 *
+Fa
+0 1e-07 307 0
+0101000
++2128 0 *
+Ve
+1e-07
+-10 -1.36602540378444 27.3562377994086
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 966 0 5.75958653158129 6.80678408277789
+2 1684 308 83 5.75958653158129 6.80678408277789
+2 1685 308 84 5.75958653158129 6.80678408277789
+0
+0101000
++2136 0 -2126 0 *
+Ed
+ 1e-07 1 1 0
+1 967 0 0.5 3
+2 1686 308 0 0.5 3
+4 C1 308 0 310 0
+0
+0101000
++3155 0 -2126 82 *
+Wi
+0101100
++2135 0 -3154 0 +2125 82 -2124 0 *
+Fa
+0 1e-07 308 0
+0101000
++2123 0 *
+Ve
+1e-07
+-10 1.36602540378444 30.0882886069775
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 968 0 0.5 3
+2 1687 311 0 0.5 3
+4 C1 311 0 309 0
+0
+0101000
++3153 0 -2121 82 *
+Ed
+ 1e-07 1 1 0
+1 969 0 0 2
+0
+0101000
++2121 0 -2131 0 *
+Wi
+0101100
++2120 0 -3152 0 +2119 82 -2130 0 *
+Fa
+0 1e-07 309 0
+0101000
++2118 0 *
+Ve
+1e-07
+-10 -0.654700538379252 26.1241869918398
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 970 0 0 1.42264973081037
+0
+0101000
++2126 0 -2116 0 *
+Ed
+ 1e-07 1 1 0
+1 971 0 0.5 3
+0
+0101000
++3151 0 -2116 82 *
+Wi
+0101100
++2124 0 -3150 0 +2115 82 -2114 0 *
+Fa
+0 1e-07 310 0
+0101000
++2113 0 *
+Ve
+1e-07
+-10 1.36602540378444 29.0882886069775
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 972 0 0.5 3
+2 1688 311 0 0.5 3
+4 C1 313 0 311 0
+0
+0101000
++3149 0 -2111 82 *
+Ed
+ 1e-07 1 1 0
+1 973 0 2.61799387799149 3.66519142918809
+2 1689 311 83 2.61799387799149 3.66519142918809
+2 1690 311 84 2.61799387799149 3.66519142918809
+0
+0101000
++2111 0 -2121 0 *
+Wi
+0101100
++2110 0 -3148 0 +2109 82 -2120 0 *
+Fa
+0 1e-07 311 0
+0101000
++2108 0 *
+Ve
+1e-07
+-10 -1.36602540378444 24.8921361842709
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 974 0 0.5 3
+2 1691 314 0 0.5 3
+4 C1 312 0 314 0
+0
+0101000
++3147 0 -2106 82 *
+Ed
+ 1e-07 1 1 0
+1 975 0 2.22044604925032e-16 1.42264973081037
+0
+0101000
++2106 0 -2116 0 *
+Wi
+0101100
++2105 0 -3146 0 +2104 82 -2114 0 *
+Fa
+0 1e-07 312 0
+0101000
++2103 0 *
+Ve
+1e-07
+-10 0.654700538379251 27.8562377994086
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 976 0 0.5 3
+0
+0101000
++3145 0 -2101 82 *
+Ed
+ 1e-07 1 1 0
+1 977 0 0.577350269189626 2
+0
+0101000
++2101 0 -2111 0 *
+Wi
+0101100
++2100 0 -3144 0 +2099 82 -2110 0 *
+Fa
+0 1e-07 313 0
+0101000
++2098 0 *
+Ve
+1e-07
+-10 -1.36602540378444 23.8921361842709
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 978 0 5.75958653158129 6.80678408277789
+2 1692 314 83 5.75958653158129 6.80678408277789
+2 1693 314 84 5.75958653158129 6.80678408277789
+0
+0101000
++2106 0 -2096 0 *
+Ed
+ 1e-07 1 1 0
+1 979 0 0.5 3
+2 1694 314 0 0.5 3
+4 C1 314 0 316 0
+0
+0101000
++3143 0 -2096 82 *
+Wi
+0101100
++2105 0 -3142 0 +2095 82 -2094 0 *
+Fa
+0 1e-07 314 0
+0101000
++2093 0 *
+Ve
+1e-07
+-10 1.36602540378444 26.6241869918398
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 980 0 0.577350269189626 2
+0
+0101000
++2101 0 -2091 0 *
+Ed
+ 1e-07 1 1 0
+1 981 0 0.5 3
+2 1695 317 0 0.5 3
+4 C1 317 0 315 0
+0
+0101000
++3141 0 -2091 82 *
+Wi
+0101100
++2100 0 -3140 0 +2090 82 -2089 0 *
+Fa
+0 1e-07 315 0
+0101000
++2088 0 *
+Ve
+1e-07
+-10 -0.654700538379251 22.660085376702
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 982 0 0.5 3
+0
+0101000
++3139 0 -2086 82 *
+Ed
+ 1e-07 1 1 0
+1 983 0 0.577350269189626 2
+0
+0101000
++2086 0 -2096 0 *
+Wi
+0101100
++2085 0 -3138 0 +2084 82 -2094 0 *
+Fa
+0 1e-07 316 0
+0101000
++2083 0 *
+Ve
+1e-07
+-10 1.36602540378444 25.6241869918398
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 984 0 0.5 3
+2 1696 317 0 0.5 3
+4 C1 319 0 317 0
+0
+0101000
++3137 0 -2081 82 *
+Ed
+ 1e-07 1 1 0
+1 985 0 2.61799387799149 3.66519142918809
+2 1697 317 83 2.61799387799149 3.66519142918809
+2 1698 317 84 2.61799387799149 3.66519142918809
+0
+0101000
++2081 0 -2091 0 *
+Wi
+0101100
++2080 0 -3136 0 +2079 82 -2089 0 *
+Fa
+0 1e-07 317 0
+0101000
++2078 0 *
+Ve
+1e-07
+-10 -1.36602540378444 21.4280345691331
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 986 0 0.5 3
+2 1699 320 0 0.5 3
+4 C1 318 0 320 0
+0
+0101000
++3135 0 -2076 82 *
+Ed
+ 1e-07 1 1 0
+1 987 0 0 1.42264973081038
+0
+0101000
++2076 0 -2086 0 *
+Wi
+0101100
++2075 0 -3134 0 +2074 82 -2085 0 *
+Fa
+0 1e-07 318 0
+0101000
++2073 0 *
+Ve
+1e-07
+-10 0.654700538379252 24.3921361842709
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 988 0 0.5 3
+0
+0101000
++3133 0 -2071 82 *
+Ed
+ 1e-07 1 1 0
+1 989 0 0.577350269189626 2
+0
+0101000
++2071 0 -2081 0 *
+Wi
+0101100
++2070 0 -3132 0 +2069 82 -2080 0 *
+Fa
+0 1e-07 319 0
+0101000
++2068 0 *
+Ve
+1e-07
+-10 -1.36602540378444 20.4280345691331
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 990 0 5.75958653158129 6.80678408277788
+2 1700 320 83 5.75958653158129 6.80678408277788
+2 1701 320 84 5.75958653158129 6.80678408277788
+0
+0101000
++2076 0 -2066 0 *
+Ed
+ 1e-07 1 1 0
+1 991 0 0.5 3
+2 1702 320 0 0.5 3
+4 C1 320 0 322 0
+0
+0101000
++3131 0 -2066 82 *
+Wi
+0101100
++2075 0 -3130 0 +2065 82 -2064 0 *
+Fa
+0 1e-07 320 0
+0101000
++2063 0 *
+Ve
+1e-07
+-10 1.36602540378444 23.160085376702
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 992 0 0.5 3
+2 1703 323 0 0.5 3
+4 C1 323 0 321 0
+0
+0101000
++3129 0 -2061 82 *
+Ed
+ 1e-07 1 1 0
+1 993 0 2.22044604925032e-16 1.42264973081037
+0
+0101000
++2061 0 -2071 0 *
+Wi
+0101100
++2060 0 -3128 0 +2059 82 -2070 0 *
+Fa
+0 1e-07 321 0
+0101000
++2058 0 *
+Ve
+1e-07
+-10 -0.654700538379251 19.1959837615642
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 994 0 0.5 3
+0
+0101000
++3127 0 -2056 82 *
+Ed
+ 1e-07 1 1 0
+1 995 0 0.577350269189626 2
+0
+0101000
++2056 0 -2066 0 *
+Wi
+0101100
++2055 0 -3126 0 +2054 82 -2064 0 *
+Fa
+0 1e-07 322 0
+0101000
++2053 0 *
+Ve
+1e-07
+-10 1.36602540378444 22.160085376702
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 996 0 0.5 3
+2 1704 323 0 0.5 3
+4 C1 325 0 323 0
+0
+0101000
++3125 0 -2051 82 *
+Ed
+ 1e-07 1 1 0
+1 997 0 2.61799387799149 3.66519142918809
+2 1705 323 83 2.61799387799149 3.66519142918809
+2 1706 323 84 2.61799387799149 3.66519142918809
+0
+0101000
++2051 0 -2061 0 *
+Wi
+0101100
++2050 0 -3124 0 +2049 82 -2060 0 *
+Fa
+0 1e-07 323 0
+0101000
++2048 0 *
+Ve
+1e-07
+-10 -1.36602540378444 17.9639329539954
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 998 0 0.5 3
+2 1707 326 0 0.5 3
+4 C1 324 0 326 0
+0
+0101000
++3123 0 -2046 82 *
+Ed
+ 1e-07 1 1 0
+1 999 0 0 1.42264973081038
+0
+0101000
++2046 0 -2056 0 *
+Wi
+0101100
++2045 0 -3122 0 +2044 82 -2055 0 *
+Fa
+0 1e-07 324 0
+0101000
++2043 0 *
+Ve
+1e-07
+-10 0.654700538379252 20.9280345691331
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1000 0 0.5 3
+0
+0101000
++3121 0 -2041 82 *
+Ed
+ 1e-07 1 1 0
+1 1001 0 0.577350269189626 2
+0
+0101000
++2041 0 -2051 0 *
+Wi
+0101100
++2040 0 -3120 0 +2039 82 -2050 0 *
+Fa
+0 1e-07 325 0
+0101000
++2038 0 *
+Ve
+1e-07
+-10 -1.36602540378444 16.9639329539954
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1002 0 5.75958653158129 6.80678408277788
+2 1708 326 83 5.75958653158129 6.80678408277788
+2 1709 326 84 5.75958653158129 6.80678408277788
+0
+0101000
++2046 0 -2036 0 *
+Ed
+ 1e-07 1 1 0
+1 1003 0 0.5 3
+2 1710 326 0 0.5 3
+4 C1 326 0 328 0
+0
+0101000
++3119 0 -2036 82 *
+Wi
+0101100
++2045 0 -3118 0 +2035 82 -2034 0 *
+Fa
+0 1e-07 326 0
+0101000
++2033 0 *
+Ve
+1e-07
+-10 1.36602540378444 19.6959837615642
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1004 0 0.5 3
+2 1711 329 0 0.5 3
+4 C1 329 0 327 0
+0
+0101000
++3117 0 -2031 82 *
+Ed
+ 1e-07 1 1 0
+1 1005 0 0 1.42264973081038
+0
+0101000
++2031 0 -2041 0 *
+Wi
+0101100
++2030 0 -3116 0 +2029 82 -2040 0 *
+Fa
+0 1e-07 327 0
+0101000
++2028 0 *
+Ve
+1e-07
+-10 -0.654700538379251 15.7318821464265
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1006 0 0.5 3
+0
+0101000
++3115 0 -2026 82 *
+Ed
+ 1e-07 1 1 0
+1 1007 0 0.577350269189626 2
+0
+0101000
++2026 0 -2036 0 *
+Wi
+0101100
++2025 0 -3114 0 +2024 82 -2034 0 *
+Fa
+0 1e-07 328 0
+0101000
++2023 0 *
+Ve
+1e-07
+-10 1.36602540378444 18.6959837615642
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1008 0 0.5 3
+2 1712 329 0 0.5 3
+4 C1 331 0 329 0
+0
+0101000
++3113 0 -2021 82 *
+Ed
+ 1e-07 1 1 0
+1 1009 0 2.61799387799149 3.66519142918809
+2 1713 329 83 2.61799387799149 3.66519142918809
+2 1714 329 84 2.61799387799149 3.66519142918809
+0
+0101000
++2021 0 -2031 0 *
+Wi
+0101100
++2020 0 -3112 0 +2019 82 -2030 0 *
+Fa
+0 1e-07 329 0
+0101000
++2018 0 *
+Ve
+1e-07
+-10 -1.36602540378444 14.4998313388576
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1010 0 0.5 3
+2 1715 332 0 0.5 3
+4 C1 330 0 332 0
+0
+0101000
++3111 0 -2016 82 *
+Ed
+ 1e-07 1 1 0
+1 1011 0 0 1.42264973081037
+0
+0101000
++2016 0 -2026 0 *
+Wi
+0101100
++2015 0 -3110 0 +2014 82 -2025 0 *
+Fa
+0 1e-07 330 0
+0101000
++2013 0 *
+Ve
+1e-07
+-10 0.654700538379252 17.4639329539954
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1012 0 0.5 3
+0
+0101000
++3109 0 -2011 82 *
+Ed
+ 1e-07 1 1 0
+1 1013 0 0.577350269189626 2
+0
+0101000
++2011 0 -2021 0 *
+Wi
+0101100
++2010 0 -3108 0 +2009 82 -2020 0 *
+Fa
+0 1e-07 331 0
+0101000
++2008 0 *
+Ve
+1e-07
+-10 -1.36602540378444 13.4998313388576
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1014 0 5.75958653158129 6.80678408277789
+2 1716 332 83 5.75958653158129 6.80678408277789
+2 1717 332 84 5.75958653158129 6.80678408277789
+0
+0101000
++2016 0 -2006 0 *
+Ed
+ 1e-07 1 1 0
+1 1015 0 0.5 3
+2 1718 332 0 0.5 3
+4 C1 332 0 334 0
+0
+0101000
++3107 0 -2006 82 *
+Wi
+0101100
++2015 0 -3106 0 +2005 82 -2004 0 *
+Fa
+0 1e-07 332 0
+0101000
++2003 0 *
+Ve
+1e-07
+-10 1.36602540378444 16.2318821464265
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1016 0 0.5 3
+2 1719 335 0 0.5 3
+4 C1 335 0 333 0
+0
+0101000
++3105 0 -2001 82 *
+Ed
+ 1e-07 1 1 0
+1 1017 0 0 1.42264973081038
+0
+0101000
++2001 0 -2011 0 *
+Wi
+0101100
++2000 0 -3104 0 +1999 82 -2010 0 *
+Fa
+0 1e-07 333 0
+0101000
++1998 0 *
+Ve
+1e-07
+-10 -0.654700538379252 12.2677805312887
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1018 0 0.5 3
+0
+0101000
++3103 0 -1996 82 *
+Ed
+ 1e-07 1 1 0
+1 1019 0 0.577350269189626 2
+0
+0101000
++1996 0 -2006 0 *
+Wi
+0101100
++1995 0 -3102 0 +1994 82 -2004 0 *
+Fa
+0 1e-07 334 0
+0101000
++1993 0 *
+Ve
+1e-07
+-10 1.36602540378444 15.2318821464265
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1020 0 0.5 3
+2 1720 335 0 0.5 3
+4 C1 337 0 335 0
+0
+0101000
++3101 0 -1991 82 *
+Ed
+ 1e-07 1 1 0
+1 1021 0 2.61799387799149 3.66519142918809
+2 1721 335 83 2.61799387799149 3.66519142918809
+2 1722 335 84 2.61799387799149 3.66519142918809
+0
+0101000
++1991 0 -2001 0 *
+Wi
+0101100
++1990 0 -3100 0 +1989 82 -2000 0 *
+Fa
+0 1e-07 335 0
+0101000
++1988 0 *
+Ve
+1e-07
+-10 -1.36602540378444 11.0357297237199
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1022 0 0.5 3
+2 1723 338 0 0.5 3
+4 C1 336 0 338 0
+0
+0101000
++3099 0 -1986 82 *
+Ed
+ 1e-07 1 1 0
+1 1023 0 0 1.42264973081037
+0
+0101000
++1986 0 -1996 0 *
+Wi
+0101100
++1985 0 -3098 0 +1984 82 -1995 0 *
+Fa
+0 1e-07 336 0
+0101000
++1983 0 *
+Ve
+1e-07
+-10 0.654700538379252 13.9998313388576
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1024 0 0.5 3
+0
+0101000
++3097 0 -1981 82 *
+Ed
+ 1e-07 1 1 0
+1 1025 0 0.577350269189626 2
+0
+0101000
++1981 0 -1991 0 *
+Wi
+0101100
++1980 0 -3096 0 +1979 82 -1990 0 *
+Fa
+0 1e-07 337 0
+0101000
++1978 0 *
+Ve
+1e-07
+-10 -1.36602540378444 10.0357297237199
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1026 0 5.75958653158129 6.80678408277789
+2 1724 338 83 5.75958653158129 6.80678408277789
+2 1725 338 84 5.75958653158129 6.80678408277789
+0
+0101000
++1986 0 -1976 0 *
+Ed
+ 1e-07 1 1 0
+1 1027 0 0.5 3
+2 1726 338 0 0.5 3
+4 C1 338 0 340 0
+0
+0101000
++3095 0 -1976 82 *
+Wi
+0101100
++1985 0 -3094 0 +1975 82 -1974 0 *
+Fa
+0 1e-07 338 0
+0101000
++1973 0 *
+Ve
+1e-07
+-10 1.36602540378444 12.7677805312887
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1028 0 0.5 3
+2 1727 341 0 0.5 3
+4 C1 341 0 339 0
+0
+0101000
++3093 0 -1971 82 *
+Ed
+ 1e-07 1 1 0
+1 1029 0 0 1.42264973081037
+0
+0101000
++1971 0 -1981 0 *
+Wi
+0101100
++1970 0 -3092 0 +1969 82 -1980 0 *
+Fa
+0 1e-07 339 0
+0101000
++1968 0 *
+Ve
+1e-07
+-10 -0.654700538379252 8.80367891615099
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1030 0 0.5 3
+0
+0101000
++3091 0 -1966 82 *
+Ed
+ 1e-07 1 1 0
+1 1031 0 0.577350269189626 2
+0
+0101000
++1966 0 -1976 0 *
+Wi
+0101100
++1965 0 -3090 0 +1964 82 -1974 0 *
+Fa
+0 1e-07 340 0
+0101000
++1963 0 *
+Ve
+1e-07
+-10 1.36602540378444 11.7677805312887
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1032 0 0.5 3
+2 1728 341 0 0.5 3
+4 C1 343 0 341 0
+0
+0101000
++3089 0 -1961 82 *
+Ed
+ 1e-07 1 1 0
+1 1033 0 2.61799387799149 3.66519142918809
+2 1729 341 83 2.61799387799149 3.66519142918809
+2 1730 341 84 2.61799387799149 3.66519142918809
+0
+0101000
++1961 0 -1971 0 *
+Wi
+0101100
++1960 0 -3088 0 +1959 82 -1970 0 *
+Fa
+0 1e-07 341 0
+0101000
++1958 0 *
+Ve
+1e-07
+-10 -1.36602540378444 7.57162810858211
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1034 0 0.5 3
+2 1731 344 0 0.5 3
+4 C1 342 0 344 0
+0
+0101000
++3087 0 -1956 82 *
+Ed
+ 1e-07 1 1 0
+1 1035 0 0 1.42264973081037
+0
+0101000
++1956 0 -1966 0 *
+Wi
+0101100
++1955 0 -3086 0 +1954 82 -1965 0 *
+Fa
+0 1e-07 342 0
+0101000
++1953 0 *
+Ve
+1e-07
+-10 0.654700538379252 10.5357297237199
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1036 0 0.5 3
+0
+0101000
++3085 0 -1951 82 *
+Ed
+ 1e-07 1 1 0
+1 1037 0 0.577350269189626 2
+0
+0101000
++1951 0 -1961 0 *
+Wi
+0101100
++1950 0 -3084 0 +1949 82 -1960 0 *
+Fa
+0 1e-07 343 0
+0101000
++1948 0 *
+Ve
+1e-07
+-10 -1.36602540378444 6.57162810858211
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1038 0 5.75958653158129 6.80678408277788
+2 1732 344 83 5.75958653158129 6.80678408277788
+2 1733 344 84 5.75958653158129 6.80678408277788
+0
+0101000
++1956 0 -1946 0 *
+Ed
+ 1e-07 1 1 0
+1 1039 0 0.5 3
+2 1734 344 0 0.5 3
+4 C1 344 0 346 0
+0
+0101000
++3083 0 -1946 82 *
+Wi
+0101100
++1955 0 -3082 0 +1945 82 -1944 0 *
+Fa
+0 1e-07 344 0
+0101000
++1943 0 *
+Ve
+1e-07
+-10 1.36602540378444 9.30367891615099
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1040 0 0.5 3
+2 1735 347 0 0.5 3
+4 C1 347 0 345 0
+0
+0101000
++3081 0 -1941 82 *
+Ed
+ 1e-07 1 1 0
+1 1041 0 0 1.42264973081037
+0
+0101000
++1941 0 -1951 0 *
+Wi
+0101100
++1940 0 -3080 0 +1939 82 -1950 0 *
+Fa
+0 1e-07 345 0
+0101000
++1938 0 *
+Ve
+1e-07
+-10 -0.654700538379252 5.33957730101323
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1042 0 0.5 3
+0
+0101000
++3079 0 -1936 82 *
+Ed
+ 1e-07 1 1 0
+1 1043 0 0.577350269189626 2
+0
+0101000
++1936 0 -1946 0 *
+Wi
+0101100
++1935 0 -3078 0 +1934 82 -1944 0 *
+Fa
+0 1e-07 346 0
+0101000
++1933 0 *
+Ve
+1e-07
+-10 1.36602540378444 8.30367891615099
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1044 0 0.5 3
+2 1736 347 0 0.5 3
+4 C1 349 0 347 0
+0
+0101000
++3077 0 -1931 82 *
+Ed
+ 1e-07 1 1 0
+1 1045 0 2.61799387799149 3.66519142918809
+2 1737 347 83 2.61799387799149 3.66519142918809
+2 1738 347 84 2.61799387799149 3.66519142918809
+0
+0101000
++1931 0 -1941 0 *
+Wi
+0101100
++1930 0 -3076 0 +1929 82 -1940 0 *
+Fa
+0 1e-07 347 0
+0101000
++1928 0 *
+Ve
+1e-07
+-10 -1.36602540378444 4.10752649344435
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1046 0 0.5 3
+2 1739 350 0 0.5 3
+4 C1 348 0 350 0
+0
+0101000
++3075 0 -1926 82 *
+Ed
+ 1e-07 1 1 0
+1 1047 0 0 1.42264973081037
+0
+0101000
++1926 0 -1936 0 *
+Wi
+0101100
++1925 0 -3074 0 +1924 82 -1935 0 *
+Fa
+0 1e-07 348 0
+0101000
++1923 0 *
+Ve
+1e-07
+-10 0.654700538379252 7.07162810858211
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1048 0 0.5 3
+0
+0101000
++3073 0 -1921 82 *
+Ed
+ 1e-07 1 1 0
+1 1049 0 0.577350269189628 2
+0
+0101000
++1921 0 -1931 0 *
+Wi
+0101100
++1920 0 -3072 0 +1919 82 -1930 0 *
+Fa
+0 1e-07 349 0
+0101000
++1918 0 *
+Ve
+1e-07
+-10 -1.36602540378444 3.10752649344435
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1050 0 5.75958653158129 6.80678408277789
+2 1740 350 83 5.75958653158129 6.80678408277789
+2 1741 350 84 5.75958653158129 6.80678408277789
+0
+0101000
++1926 0 -1916 0 *
+Ed
+ 1e-07 1 1 0
+1 1051 0 0.5 3
+2 1742 350 0 0.5 3
+4 C1 350 0 352 0
+0
+0101000
++3071 0 -1916 82 *
+Wi
+0101100
++1925 0 -3070 0 +1915 82 -1914 0 *
+Fa
+0 1e-07 350 0
+0101000
++1913 0 *
+Ve
+1e-07
+-10 1.36602540378444 5.83957730101323
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1052 0 0.5 3
+2 1743 353 0 0.5 3
+4 C1 353 0 351 0
+0
+0101000
++3069 0 -1911 82 *
+Ed
+ 1e-07 1 1 0
+1 1053 0 0 1.42264973081038
+0
+0101000
++1911 0 -1921 0 *
+Wi
+0101100
++1910 0 -3068 0 +1909 82 -1920 0 *
+Fa
+0 1e-07 351 0
+0101000
++1908 0 *
+Ve
+1e-07
+-10 -0.366025403784439 1.37547568587548
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1054 0 0.5 3
+2 1744 354 0 0.5 3
+4 C1 352 0 354 0
+0
+0101000
++3067 0 -1906 82 *
+Ed
+ 1e-07 1 1 0
+1 1055 0 0 2
+0
+0101000
++1906 0 -1916 0 *
+Wi
+0101100
++1905 0 -3066 0 +1904 82 -1914 0 *
+Fa
+0 1e-07 352 0
+0101000
++1903 0 *
+Ve
+1e-07
+-10 1.36602540378444 4.83957730101323
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1056 0 0.5 3
+2 1745 353 0 0.5 3
+4 C1 355 0 353 0
+0
+0101000
++3065 0 -1901 82 *
+Ed
+ 1e-07 1 1 0
+1 1057 0 2.61799387799149 3.66519142918809
+2 1746 353 83 2.61799387799149 3.66519142918809
+2 1747 353 84 2.61799387799149 3.66519142918809
+0
+0101000
++1901 0 -1911 0 *
+Wi
+0101100
++1900 0 -3064 0 +1899 82 -1910 0 *
+Fa
+0 1e-07 353 0
+0101000
++1898 0 *
+Ve
+1e-07
+-10 1.36602540378444 2.37547568587548
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1058 0 0.523598775598299 3.66519142918809
+2 1748 354 83 0.523598775598299 3.66519142918809
+2 1749 354 84 0.523598775598299 3.66519142918809
+0
+0101000
++1906 0 -1896 0 *
+Ed
+ 1e-07 1 1 0
+1 1059 0 0.5 3
+2 1750 354 0 0.5 3
+4 C1 354 0 356 0
+0
+0101000
++3063 0 -1896 82 *
+Wi
+0101100
++1905 0 -3062 0 +1895 82 -1894 0 *
+Fa
+0 1e-07 354 0
+0101000
++1893 0 *
+Ve
+1e-07
+-10 0.654700538379251 3.60752649344435
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1060 0 0.5 3
+0
+0101000
++3061 0 -1891 82 *
+Ed
+ 1e-07 1 1 0
+1 1061 0 0.577350269189626 2
+0
+0101000
++1891 0 -1901 0 *
+Wi
+0101100
++1890 0 -3060 0 +1889 82 -1900 0 *
+Fa
+0 1e-07 355 0
+0101000
++1888 0 *
+Ed
+ 1e-07 1 1 0
+1 1062 0 0 1.42264973081037
+0
+0101000
++1896 0 -1891 0 *
+Wi
+0101100
++1894 0 -3059 0 +1886 82 -1890 0 *
+Fa
+0 1e-07 356 0
+0101000
++1885 0 *
+Ve
+1e-07
+10 -0.654700538379252 29.5882886069775
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1063 0 0.5 3
+0
+0101000
++3051 0 -1883 87 *
+Ve
+1e-07
+10 -1.36602540378444 30.8203394145464
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1064 0 0.577350269189626 2
+0
+0101000
++1883 0 -1881 0 *
+Ed
+ 1e-07 1 1 0
+1 1065 0 0.5 3
+2 1751 358 0 0.5 3
+4 C1 357 0 358 0
+0
+0101000
++3052 0 -1881 87 *
+Wi
+0101100
++1882 0 +3050 0 +1880 87 -1879 0 *
+Fa
+0 1e-07 357 0
+0101000
++1878 0 *
+Ve
+1e-07
+10 0.366025403784438 31.8203394145464
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1066 0 0.5 3
+2 1752 358 0 0.5 3
+4 C1 360 0 358 0
+0
+0101000
++3049 0 -1876 87 *
+Ed
+ 1e-07 1 1 0
+1 1067 0 3.66519142918809 6.80678408277789
+2 1753 358 88 3.66519142918809 6.80678408277789
+2 1754 358 89 3.66519142918809 6.80678408277789
+0
+0101000
++1876 0 -1881 0 *
+Wi
+0101100
++1875 0 +3048 0 +1874 87 -1879 0 *
+Fa
+0 1e-07 358 0
+0101000
++1873 0 *
+Ve
+1e-07
+10 -1.36602540378444 28.3562377994086
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1068 0 0.5 3
+2 1755 361 0 0.5 3
+4 C1 359 0 361 0
+0
+0101000
++3047 0 -1871 87 *
+Ed
+ 1e-07 1 1 0
+1 1069 0 0 1.42264973081037
+0
+0101000
++1871 0 -1883 0 *
+Wi
+0101100
++1870 0 +3046 0 +1869 87 -1882 0 *
+Fa
+0 1e-07 359 0
+0101000
++1868 0 *
+Ve
+1e-07
+10 1.36602540378444 30.0882886069775
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1070 0 0.5 3
+2 1756 362 0 0.5 3
+4 C1 362 0 360 0
+0
+0101000
++3045 0 -1866 87 *
+Ed
+ 1e-07 1 1 0
+1 1071 0 0 2
+0
+0101000
++1866 0 -1876 0 *
+Wi
+0101100
++1865 0 +3044 0 +1864 87 -1875 0 *
+Fa
+0 1e-07 360 0
+0101000
++1863 0 *
+Ve
+1e-07
+10 -1.36602540378444 27.3562377994086
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1072 0 5.75958653158129 6.80678408277789
+2 1757 361 88 5.75958653158129 6.80678408277789
+2 1758 361 89 5.75958653158129 6.80678408277789
+0
+0101000
++1871 0 -1861 0 *
+Ed
+ 1e-07 1 1 0
+1 1073 0 0.5 3
+2 1759 361 0 0.5 3
+4 C1 361 0 363 0
+0
+0101000
++3043 0 -1861 87 *
+Wi
+0101100
++1870 0 +3042 0 +1860 87 -1859 0 *
+Fa
+0 1e-07 361 0
+0101000
++1858 0 *
+Ve
+1e-07
+10 1.36602540378444 29.0882886069775
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1074 0 0.5 3
+2 1760 362 0 0.5 3
+4 C1 364 0 362 0
+0
+0101000
++3041 0 -1856 87 *
+Ed
+ 1e-07 1 1 0
+1 1075 0 2.61799387799149 3.66519142918809
+2 1761 362 88 2.61799387799149 3.66519142918809
+2 1762 362 89 2.61799387799149 3.66519142918809
+0
+0101000
++1856 0 -1866 0 *
+Wi
+0101100
++1855 0 +3040 0 +1854 87 -1865 0 *
+Fa
+0 1e-07 362 0
+0101000
++1853 0 *
+Ve
+1e-07
+10 -0.654700538379252 26.1241869918398
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1076 0 0 1.42264973081037
+0
+0101000
++1861 0 -1851 0 *
+Ed
+ 1e-07 1 1 0
+1 1077 0 0.5 3
+0
+0101000
++3039 0 -1851 87 *
+Wi
+0101100
++1859 0 +3038 0 +1850 87 -1849 0 *
+Fa
+0 1e-07 363 0
+0101000
++1848 0 *
+Ve
+1e-07
+10 0.654700538379251 27.8562377994086
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1078 0 0.5 3
+0
+0101000
++3037 0 -1846 87 *
+Ed
+ 1e-07 1 1 0
+1 1079 0 0.577350269189626 2
+0
+0101000
++1846 0 -1856 0 *
+Wi
+0101100
++1845 0 +3036 0 +1844 87 -1855 0 *
+Fa
+0 1e-07 364 0
+0101000
++1843 0 *
+Ve
+1e-07
+10 -1.36602540378444 24.8921361842709
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1080 0 0.5 3
+2 1763 367 0 0.5 3
+4 C1 365 0 367 0
+0
+0101000
++3035 0 -1841 87 *
+Ed
+ 1e-07 1 1 0
+1 1081 0 2.22044604925032e-16 1.42264973081037
+0
+0101000
++1841 0 -1851 0 *
+Wi
+0101100
++1840 0 +3034 0 +1839 87 -1849 0 *
+Fa
+0 1e-07 365 0
+0101000
++1838 0 *
+Ve
+1e-07
+10 1.36602540378444 26.6241869918398
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1082 0 0.577350269189626 2
+0
+0101000
++1846 0 -1836 0 *
+Ed
+ 1e-07 1 1 0
+1 1083 0 0.5 3
+2 1764 368 0 0.5 3
+4 C1 368 0 366 0
+0
+0101000
++3033 0 -1836 87 *
+Wi
+0101100
++1845 0 +3032 0 +1835 87 -1834 0 *
+Fa
+0 1e-07 366 0
+0101000
++1833 0 *
+Ve
+1e-07
+10 -1.36602540378444 23.8921361842709
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1084 0 5.75958653158129 6.80678408277789
+2 1765 367 88 5.75958653158129 6.80678408277789
+2 1766 367 89 5.75958653158129 6.80678408277789
+0
+0101000
++1841 0 -1831 0 *
+Ed
+ 1e-07 1 1 0
+1 1085 0 0.5 3
+2 1767 367 0 0.5 3
+4 C1 367 0 369 0
+0
+0101000
++3031 0 -1831 87 *
+Wi
+0101100
++1840 0 +3030 0 +1830 87 -1829 0 *
+Fa
+0 1e-07 367 0
+0101000
++1828 0 *
+Ve
+1e-07
+10 1.36602540378444 25.6241869918398
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1086 0 0.5 3
+2 1768 368 0 0.5 3
+4 C1 370 0 368 0
+0
+0101000
++3029 0 -1826 87 *
+Ed
+ 1e-07 1 1 0
+1 1087 0 2.61799387799149 3.66519142918809
+2 1769 368 88 2.61799387799149 3.66519142918809
+2 1770 368 89 2.61799387799149 3.66519142918809
+0
+0101000
++1826 0 -1836 0 *
+Wi
+0101100
++1825 0 +3028 0 +1824 87 -1834 0 *
+Fa
+0 1e-07 368 0
+0101000
++1823 0 *
+Ve
+1e-07
+10 -0.654700538379251 22.660085376702
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1088 0 0.5 3
+0
+0101000
++3027 0 -1821 87 *
+Ed
+ 1e-07 1 1 0
+1 1089 0 0.577350269189626 2
+0
+0101000
++1821 0 -1831 0 *
+Wi
+0101100
++1820 0 +3026 0 +1819 87 -1829 0 *
+Fa
+0 1e-07 369 0
+0101000
++1818 0 *
+Ve
+1e-07
+10 0.654700538379252 24.3921361842709
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1090 0 0.5 3
+0
+0101000
++3025 0 -1816 87 *
+Ed
+ 1e-07 1 1 0
+1 1091 0 0.577350269189626 2
+0
+0101000
++1816 0 -1826 0 *
+Wi
+0101100
++1815 0 +3024 0 +1814 87 -1825 0 *
+Fa
+0 1e-07 370 0
+0101000
++1813 0 *
+Ve
+1e-07
+10 -1.36602540378444 21.4280345691331
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1092 0 0.5 3
+2 1771 373 0 0.5 3
+4 C1 371 0 373 0
+0
+0101000
++3023 0 -1811 87 *
+Ed
+ 1e-07 1 1 0
+1 1093 0 0 1.42264973081038
+0
+0101000
++1811 0 -1821 0 *
+Wi
+0101100
++1810 0 +3022 0 +1809 87 -1820 0 *
+Fa
+0 1e-07 371 0
+0101000
++1808 0 *
+Ve
+1e-07
+10 1.36602540378444 23.160085376702
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1094 0 0.5 3
+2 1772 374 0 0.5 3
+4 C1 374 0 372 0
+0
+0101000
++3021 0 -1806 87 *
+Ed
+ 1e-07 1 1 0
+1 1095 0 2.22044604925032e-16 1.42264973081037
+0
+0101000
++1806 0 -1816 0 *
+Wi
+0101100
++1805 0 +3020 0 +1804 87 -1815 0 *
+Fa
+0 1e-07 372 0
+0101000
++1803 0 *
+Ve
+1e-07
+10 -1.36602540378444 20.4280345691331
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1096 0 5.75958653158129 6.80678408277788
+2 1773 373 88 5.75958653158129 6.80678408277788
+2 1774 373 89 5.75958653158129 6.80678408277788
+0
+0101000
++1811 0 -1801 0 *
+Ed
+ 1e-07 1 1 0
+1 1097 0 0.5 3
+2 1775 373 0 0.5 3
+4 C1 373 0 375 0
+0
+0101000
++3019 0 -1801 87 *
+Wi
+0101100
++1810 0 +3018 0 +1800 87 -1799 0 *
+Fa
+0 1e-07 373 0
+0101000
++1798 0 *
+Ve
+1e-07
+10 1.36602540378444 22.160085376702
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1098 0 0.5 3
+2 1776 374 0 0.5 3
+4 C1 376 0 374 0
+0
+0101000
++3017 0 -1796 87 *
+Ed
+ 1e-07 1 1 0
+1 1099 0 2.61799387799149 3.66519142918809
+2 1777 374 88 2.61799387799149 3.66519142918809
+2 1778 374 89 2.61799387799149 3.66519142918809
+0
+0101000
++1796 0 -1806 0 *
+Wi
+0101100
++1795 0 +3016 0 +1794 87 -1805 0 *
+Fa
+0 1e-07 374 0
+0101000
++1793 0 *
+Ve
+1e-07
+10 -0.654700538379251 19.1959837615642
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1100 0 0.5 3
+0
+0101000
++3015 0 -1791 87 *
+Ed
+ 1e-07 1 1 0
+1 1101 0 0.577350269189626 2
+0
+0101000
++1791 0 -1801 0 *
+Wi
+0101100
++1790 0 +3014 0 +1789 87 -1799 0 *
+Fa
+0 1e-07 375 0
+0101000
++1788 0 *
+Ve
+1e-07
+10 0.654700538379252 20.9280345691331
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1102 0 0.5 3
+0
+0101000
++3013 0 -1786 87 *
+Ed
+ 1e-07 1 1 0
+1 1103 0 0.577350269189626 2
+0
+0101000
++1786 0 -1796 0 *
+Wi
+0101100
++1785 0 +3012 0 +1784 87 -1795 0 *
+Fa
+0 1e-07 376 0
+0101000
++1783 0 *
+Ve
+1e-07
+10 -1.36602540378444 17.9639329539954
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1104 0 0.5 3
+2 1779 379 0 0.5 3
+4 C1 377 0 379 0
+0
+0101000
++3011 0 -1781 87 *
+Ed
+ 1e-07 1 1 0
+1 1105 0 0 1.42264973081038
+0
+0101000
++1781 0 -1791 0 *
+Wi
+0101100
++1780 0 +3010 0 +1779 87 -1790 0 *
+Fa
+0 1e-07 377 0
+0101000
++1778 0 *
+Ve
+1e-07
+10 1.36602540378444 19.6959837615642
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1106 0 0.5 3
+2 1780 380 0 0.5 3
+4 C1 380 0 378 0
+0
+0101000
++3009 0 -1776 87 *
+Ed
+ 1e-07 1 1 0
+1 1107 0 0 1.42264973081038
+0
+0101000
++1776 0 -1786 0 *
+Wi
+0101100
++1775 0 +3008 0 +1774 87 -1785 0 *
+Fa
+0 1e-07 378 0
+0101000
++1773 0 *
+Ve
+1e-07
+10 -1.36602540378444 16.9639329539954
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1108 0 5.75958653158129 6.80678408277788
+2 1781 379 88 5.75958653158129 6.80678408277788
+2 1782 379 89 5.75958653158129 6.80678408277788
+0
+0101000
++1781 0 -1771 0 *
+Ed
+ 1e-07 1 1 0
+1 1109 0 0.5 3
+2 1783 379 0 0.5 3
+4 C1 379 0 381 0
+0
+0101000
++3007 0 -1771 87 *
+Wi
+0101100
++1780 0 +3006 0 +1770 87 -1769 0 *
+Fa
+0 1e-07 379 0
+0101000
++1768 0 *
+Ve
+1e-07
+10 1.36602540378444 18.6959837615642
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1110 0 0.5 3
+2 1784 380 0 0.5 3
+4 C1 382 0 380 0
+0
+0101000
++3005 0 -1766 87 *
+Ed
+ 1e-07 1 1 0
+1 1111 0 2.61799387799149 3.66519142918809
+2 1785 380 88 2.61799387799149 3.66519142918809
+2 1786 380 89 2.61799387799149 3.66519142918809
+0
+0101000
++1766 0 -1776 0 *
+Wi
+0101100
++1765 0 +3004 0 +1764 87 -1775 0 *
+Fa
+0 1e-07 380 0
+0101000
++1763 0 *
+Ve
+1e-07
+10 -0.654700538379251 15.7318821464265
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1112 0 0.5 3
+0
+0101000
++3003 0 -1761 87 *
+Ed
+ 1e-07 1 1 0
+1 1113 0 0.577350269189626 2
+0
+0101000
++1761 0 -1771 0 *
+Wi
+0101100
++1760 0 +3002 0 +1759 87 -1769 0 *
+Fa
+0 1e-07 381 0
+0101000
++1758 0 *
+Ve
+1e-07
+10 0.654700538379252 17.4639329539954
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1114 0 0.5 3
+0
+0101000
++3001 0 -1756 87 *
+Ed
+ 1e-07 1 1 0
+1 1115 0 0.577350269189626 2
+0
+0101000
++1756 0 -1766 0 *
+Wi
+0101100
++1755 0 +3000 0 +1754 87 -1765 0 *
+Fa
+0 1e-07 382 0
+0101000
++1753 0 *
+Ve
+1e-07
+10 -1.36602540378444 14.4998313388576
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1116 0 0.5 3
+2 1787 385 0 0.5 3
+4 C1 383 0 385 0
+0
+0101000
++2999 0 -1751 87 *
+Ed
+ 1e-07 1 1 0
+1 1117 0 0 1.42264973081037
+0
+0101000
++1751 0 -1761 0 *
+Wi
+0101100
++1750 0 +2998 0 +1749 87 -1760 0 *
+Fa
+0 1e-07 383 0
+0101000
++1748 0 *
+Ve
+1e-07
+10 1.36602540378444 16.2318821464265
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1118 0 0.5 3
+2 1788 386 0 0.5 3
+4 C1 386 0 384 0
+0
+0101000
++2997 0 -1746 87 *
+Ed
+ 1e-07 1 1 0
+1 1119 0 0 1.42264973081038
+0
+0101000
++1746 0 -1756 0 *
+Wi
+0101100
++1745 0 +2996 0 +1744 87 -1755 0 *
+Fa
+0 1e-07 384 0
+0101000
++1743 0 *
+Ve
+1e-07
+10 -1.36602540378444 13.4998313388576
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1120 0 5.75958653158129 6.80678408277789
+2 1789 385 88 5.75958653158129 6.80678408277789
+2 1790 385 89 5.75958653158129 6.80678408277789
+0
+0101000
++1751 0 -1741 0 *
+Ed
+ 1e-07 1 1 0
+1 1121 0 0.5 3
+2 1791 385 0 0.5 3
+4 C1 385 0 387 0
+0
+0101000
++2995 0 -1741 87 *
+Wi
+0101100
++1750 0 +2994 0 +1740 87 -1739 0 *
+Fa
+0 1e-07 385 0
+0101000
++1738 0 *
+Ve
+1e-07
+10 1.36602540378444 15.2318821464265
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1122 0 0.5 3
+2 1792 386 0 0.5 3
+4 C1 388 0 386 0
+0
+0101000
++2993 0 -1736 87 *
+Ed
+ 1e-07 1 1 0
+1 1123 0 2.61799387799149 3.66519142918809
+2 1793 386 88 2.61799387799149 3.66519142918809
+2 1794 386 89 2.61799387799149 3.66519142918809
+0
+0101000
++1736 0 -1746 0 *
+Wi
+0101100
++1735 0 +2992 0 +1734 87 -1745 0 *
+Fa
+0 1e-07 386 0
+0101000
++1733 0 *
+Ve
+1e-07
+10 -0.654700538379252 12.2677805312887
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1124 0 0.5 3
+0
+0101000
++2991 0 -1731 87 *
+Ed
+ 1e-07 1 1 0
+1 1125 0 0.577350269189626 2
+0
+0101000
++1731 0 -1741 0 *
+Wi
+0101100
++1730 0 +2990 0 +1729 87 -1739 0 *
+Fa
+0 1e-07 387 0
+0101000
++1728 0 *
+Ve
+1e-07
+10 0.654700538379252 13.9998313388576
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1126 0 0.5 3
+0
+0101000
++2989 0 -1726 87 *
+Ed
+ 1e-07 1 1 0
+1 1127 0 0.577350269189626 2
+0
+0101000
++1726 0 -1736 0 *
+Wi
+0101100
++1725 0 +2988 0 +1724 87 -1735 0 *
+Fa
+0 1e-07 388 0
+0101000
++1723 0 *
+Ve
+1e-07
+10 -1.36602540378444 11.0357297237199
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1128 0 0.5 3
+2 1795 391 0 0.5 3
+4 C1 389 0 391 0
+0
+0101000
++2987 0 -1721 87 *
+Ed
+ 1e-07 1 1 0
+1 1129 0 0 1.42264973081037
+0
+0101000
++1721 0 -1731 0 *
+Wi
+0101100
++1720 0 +2986 0 +1719 87 -1730 0 *
+Fa
+0 1e-07 389 0
+0101000
++1718 0 *
+Ve
+1e-07
+10 1.36602540378444 12.7677805312887
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1130 0 0.5 3
+2 1796 392 0 0.5 3
+4 C1 392 0 390 0
+0
+0101000
++2985 0 -1716 87 *
+Ed
+ 1e-07 1 1 0
+1 1131 0 0 1.42264973081037
+0
+0101000
++1716 0 -1726 0 *
+Wi
+0101100
++1715 0 +2984 0 +1714 87 -1725 0 *
+Fa
+0 1e-07 390 0
+0101000
++1713 0 *
+Ve
+1e-07
+10 -1.36602540378444 10.0357297237199
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1132 0 5.75958653158129 6.80678408277789
+2 1797 391 88 5.75958653158129 6.80678408277789
+2 1798 391 89 5.75958653158129 6.80678408277789
+0
+0101000
++1721 0 -1711 0 *
+Ed
+ 1e-07 1 1 0
+1 1133 0 0.5 3
+2 1799 391 0 0.5 3
+4 C1 391 0 393 0
+0
+0101000
++2983 0 -1711 87 *
+Wi
+0101100
++1720 0 +2982 0 +1710 87 -1709 0 *
+Fa
+0 1e-07 391 0
+0101000
++1708 0 *
+Ve
+1e-07
+10 1.36602540378444 11.7677805312887
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1134 0 0.5 3
+2 1800 392 0 0.5 3
+4 C1 394 0 392 0
+0
+0101000
++2981 0 -1706 87 *
+Ed
+ 1e-07 1 1 0
+1 1135 0 2.61799387799149 3.66519142918809
+2 1801 392 88 2.61799387799149 3.66519142918809
+2 1802 392 89 2.61799387799149 3.66519142918809
+0
+0101000
++1706 0 -1716 0 *
+Wi
+0101100
++1705 0 +2980 0 +1704 87 -1715 0 *
+Fa
+0 1e-07 392 0
+0101000
++1703 0 *
+Ve
+1e-07
+10 -0.654700538379252 8.80367891615099
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1136 0 0.5 3
+0
+0101000
++2979 0 -1701 87 *
+Ed
+ 1e-07 1 1 0
+1 1137 0 0.577350269189626 2
+0
+0101000
++1701 0 -1711 0 *
+Wi
+0101100
++1700 0 +2978 0 +1699 87 -1709 0 *
+Fa
+0 1e-07 393 0
+0101000
++1698 0 *
+Ve
+1e-07
+10 0.654700538379252 10.5357297237199
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1138 0 0.5 3
+0
+0101000
++2977 0 -1696 87 *
+Ed
+ 1e-07 1 1 0
+1 1139 0 0.577350269189626 2
+0
+0101000
++1696 0 -1706 0 *
+Wi
+0101100
++1695 0 +2976 0 +1694 87 -1705 0 *
+Fa
+0 1e-07 394 0
+0101000
++1693 0 *
+Ve
+1e-07
+10 -1.36602540378444 7.57162810858211
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1140 0 0.5 3
+2 1803 397 0 0.5 3
+4 C1 395 0 397 0
+0
+0101000
++2975 0 -1691 87 *
+Ed
+ 1e-07 1 1 0
+1 1141 0 0 1.42264973081037
+0
+0101000
++1691 0 -1701 0 *
+Wi
+0101100
++1690 0 +2974 0 +1689 87 -1700 0 *
+Fa
+0 1e-07 395 0
+0101000
++1688 0 *
+Ve
+1e-07
+10 1.36602540378444 9.30367891615099
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1142 0 0.5 3
+2 1804 398 0 0.5 3
+4 C1 398 0 396 0
+0
+0101000
++2973 0 -1686 87 *
+Ed
+ 1e-07 1 1 0
+1 1143 0 0 1.42264973081037
+0
+0101000
++1686 0 -1696 0 *
+Wi
+0101100
++1685 0 +2972 0 +1684 87 -1695 0 *
+Fa
+0 1e-07 396 0
+0101000
++1683 0 *
+Ve
+1e-07
+10 -1.36602540378444 6.57162810858211
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1144 0 5.75958653158129 6.80678408277788
+2 1805 397 88 5.75958653158129 6.80678408277788
+2 1806 397 89 5.75958653158129 6.80678408277788
+0
+0101000
++1691 0 -1681 0 *
+Ed
+ 1e-07 1 1 0
+1 1145 0 0.5 3
+2 1807 397 0 0.5 3
+4 C1 397 0 399 0
+0
+0101000
++2971 0 -1681 87 *
+Wi
+0101100
++1690 0 +2970 0 +1680 87 -1679 0 *
+Fa
+0 1e-07 397 0
+0101000
++1678 0 *
+Ve
+1e-07
+10 1.36602540378444 8.30367891615099
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1146 0 0.5 3
+2 1808 398 0 0.5 3
+4 C1 400 0 398 0
+0
+0101000
++2969 0 -1676 87 *
+Ed
+ 1e-07 1 1 0
+1 1147 0 2.61799387799149 3.66519142918809
+2 1809 398 88 2.61799387799149 3.66519142918809
+2 1810 398 89 2.61799387799149 3.66519142918809
+0
+0101000
++1676 0 -1686 0 *
+Wi
+0101100
++1675 0 +2968 0 +1674 87 -1685 0 *
+Fa
+0 1e-07 398 0
+0101000
++1673 0 *
+Ve
+1e-07
+10 -0.654700538379252 5.33957730101323
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1148 0 0.5 3
+0
+0101000
++2967 0 -1671 87 *
+Ed
+ 1e-07 1 1 0
+1 1149 0 0.577350269189626 2
+0
+0101000
++1671 0 -1681 0 *
+Wi
+0101100
++1670 0 +2966 0 +1669 87 -1679 0 *
+Fa
+0 1e-07 399 0
+0101000
++1668 0 *
+Ve
+1e-07
+10 0.654700538379252 7.07162810858211
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1150 0 0.5 3
+0
+0101000
++2965 0 -1666 87 *
+Ed
+ 1e-07 1 1 0
+1 1151 0 0.577350269189628 2
+0
+0101000
++1666 0 -1676 0 *
+Wi
+0101100
++1665 0 +2964 0 +1664 87 -1675 0 *
+Fa
+0 1e-07 400 0
+0101000
++1663 0 *
+Ve
+1e-07
+10 -1.36602540378444 4.10752649344435
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1152 0 0.5 3
+2 1811 403 0 0.5 3
+4 C1 401 0 403 0
+0
+0101000
++2963 0 -1661 87 *
+Ed
+ 1e-07 1 1 0
+1 1153 0 0 1.42264973081037
+0
+0101000
++1661 0 -1671 0 *
+Wi
+0101100
++1660 0 +2962 0 +1659 87 -1670 0 *
+Fa
+0 1e-07 401 0
+0101000
++1658 0 *
+Ve
+1e-07
+10 1.36602540378444 5.83957730101323
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1154 0 0.5 3
+2 1812 404 0 0.5 3
+4 C1 404 0 402 0
+0
+0101000
++2961 0 -1656 87 *
+Ed
+ 1e-07 1 1 0
+1 1155 0 0 1.42264973081038
+0
+0101000
++1656 0 -1666 0 *
+Wi
+0101100
++1655 0 +2960 0 +1654 87 -1665 0 *
+Fa
+0 1e-07 402 0
+0101000
++1653 0 *
+Ve
+1e-07
+10 -1.36602540378444 3.10752649344435
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1156 0 5.75958653158129 6.80678408277789
+2 1813 403 88 5.75958653158129 6.80678408277789
+2 1814 403 89 5.75958653158129 6.80678408277789
+0
+0101000
++1661 0 -1651 0 *
+Ed
+ 1e-07 1 1 0
+1 1157 0 0.5 3
+2 1815 403 0 0.5 3
+4 C1 403 0 405 0
+0
+0101000
++2959 0 -1651 87 *
+Wi
+0101100
++1660 0 +2958 0 +1650 87 -1649 0 *
+Fa
+0 1e-07 403 0
+0101000
++1648 0 *
+Ve
+1e-07
+10 1.36602540378444 4.83957730101323
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1158 0 0.5 3
+2 1816 404 0 0.5 3
+4 C1 406 0 404 0
+0
+0101000
++2957 0 -1646 87 *
+Ed
+ 1e-07 1 1 0
+1 1159 0 2.61799387799149 3.66519142918809
+2 1817 404 88 2.61799387799149 3.66519142918809
+2 1818 404 89 2.61799387799149 3.66519142918809
+0
+0101000
++1646 0 -1656 0 *
+Wi
+0101100
++1645 0 +2956 0 +1644 87 -1655 0 *
+Fa
+0 1e-07 404 0
+0101000
++1643 0 *
+Ve
+1e-07
+10 -0.366025403784439 1.37547568587548
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1160 0 0.5 3
+2 1819 407 0 0.5 3
+4 C1 405 0 407 0
+0
+0101000
++2955 0 -1641 87 *
+Ed
+ 1e-07 1 1 0
+1 1161 0 0 2
+0
+0101000
++1641 0 -1651 0 *
+Wi
+0101100
++1640 0 +2954 0 +1639 87 -1649 0 *
+Fa
+0 1e-07 405 0
+0101000
++1638 0 *
+Ve
+1e-07
+10 0.654700538379251 3.60752649344435
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1162 0 0.5 3
+0
+0101000
++2953 0 -1636 87 *
+Ed
+ 1e-07 1 1 0
+1 1163 0 0.577350269189626 2
+0
+0101000
++1636 0 -1646 0 *
+Wi
+0101100
++1635 0 +2952 0 +1634 87 -1645 0 *
+Fa
+0 1e-07 406 0
+0101000
++1633 0 *
+Ve
+1e-07
+10 1.36602540378444 2.37547568587548
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1164 0 0.523598775598299 3.66519142918809
+2 1820 407 88 0.523598775598299 3.66519142918809
+2 1821 407 89 0.523598775598299 3.66519142918809
+0
+0101000
++1641 0 -1631 0 *
+Ed
+ 1e-07 1 1 0
+1 1165 0 0.5 3
+2 1822 407 0 0.5 3
+4 C1 407 0 408 0
+0
+0101000
++2951 0 -1631 87 *
+Wi
+0101100
++1640 0 +2950 0 +1630 87 -1629 0 *
+Fa
+0 1e-07 407 0
+0101000
++1628 0 *
+Ed
+ 1e-07 1 1 0
+1 1166 0 0 1.42264973081037
+0
+0101000
++1631 0 -1636 0 *
+Wi
+0101100
++1629 0 +2949 0 +1626 87 -1635 0 *
+Fa
+0 1e-07 408 0
+0101000
++1625 0 *
+Ed
+ 1e-07 1 1 0
+1 826 0 0.408555049325884 2.90757052438606
+2 1413 264 0 0.408555049325884 2.90757052438606
+2 1414 263 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2944 0 +2827 0 *
+Wi
+0101100
+-2528 0 +2943 0 -2826 0 -1623 0 *
+Fa
+0 1e-07 263 0
+0101000
++1622 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 0.990000000223517
+0 0
+0101101
+Ed
+ 8.53067514952002e-15 1 1 0
+1 827 0 1.83471917492468 2.84562973209223
+2 1415 265 0 1.83471917492468 2.84562973209223
+2 1416 264 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1620 0 +2823 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 0.990000000223517
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 1167 0 -6.28784925781463 0.420354674684743
+2 1823 264 0 -6.28784925781463 0.420354674684743
+2 1824 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1620 0 -1618 0 *
+Ed
+1 827 0 3.43755557508736 4.4484661322549
+2 1415 265 0 3.43755557508736 4.4484661322549
+2 1416 264 0 3.43755557508736 4.4484661322549
+0
+0101000
++1618 0 -2940 0 *
+Wi
+0101100
+-1619 0 -1617 0 +2822 0 -1616 0 +1623 0 -2939 0 *
+Fa
+0 1e-07 264 0
+0101000
++1615 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 33.9900000002235
+0 0
+0101101
+Ed
+1 822 0 1.83471917492468 2.84562973209223
+2 1405 265 0 1.83471917492468 2.84562973209223
+2 1406 262 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1613 0 +2821 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 33.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 1168 0 -6.28784925781463 0.420354674684743
+2 1825 262 0 -6.28784925781463 0.420354674684743
+2 1826 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1613 0 -1611 0 *
+Ed
+1 822 0 3.43755557508736 4.4484661322549
+2 1405 265 0 3.43755557508736 4.4484661322549
+2 1406 262 0 3.43755557508736 4.4484661322549
+0
+0101000
++1611 0 -2938 0 *
+Wi
+0101100
+-1612 0 -1610 0 +2820 0 -1609 0 +2712 0 -2937 0 *
+Fa
+0 1e-07 262 0
+0101000
++1608 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 1.99000000022352
+0 0
+0101101
+Ed
+1 1169 0 -1.99000000022352 -0.990000000223517
+2 1827 265 0 -1.99000000022352 -0.990000000223517
+2 1828 440 0 -1.99000000022352 -0.990000000223517
+0
+0101000
++1606 0 -1618 0 *
+Ed
+1 830 0 3.43755557508736 4.4484661322549
+2 1421 265 0 3.43755557508736 4.4484661322549
+2 1422 266 0 3.43755557508736 4.4484661322549
+0
+0101000
++1606 0 -2936 0 *
+Wi
+0101100
++1616 0 +1605 0 -2935 0 -1604 0 *
+Fa
+0 1e-07 265 0
+0101000
++1603 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 32.9900000002235
+0 0
+0101101
+Ed
+1 831 0 3.43755557508736 4.4484661322549
+2 1423 265 0 3.43755557508736 4.4484661322549
+2 1424 267 0 3.43755557508736 4.4484661322549
+0
+0101000
++1601 0 -2934 0 *
+Ed
+1 1170 0 -33.9900000002235 -32.9900000002235
+2 1829 265 0 -33.9900000002235 -32.9900000002235
+2 1830 440 0 -33.9900000002235 -32.9900000002235
+0
+0101000
++1611 0 -1601 0 *
+Wi
+0101100
++1600 0 +1599 0 -2933 0 -1609 0 *
+Fa
+0 1e-07 265 0
+0101000
++1598 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 1.99000000022352
+0 0
+0101101
+Ed
+1 830 0 1.83471917492468 2.84562973209223
+2 1421 265 0 1.83471917492468 2.84562973209223
+2 1422 266 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1596 0 +2819 0 *
+Ed
+ 1e-08 1 1 0
+1 1171 0 -6.28784925781463 0.420354674684743
+2 1831 266 0 -6.28784925781463 0.420354674684743
+2 1832 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1596 0 -1606 0 *
+Ed
+ 1e-07 1 1 0
+1 834 0 0.408555049325884 2.90757052438606
+2 1429 268 0 0.408555049325884 2.90757052438606
+2 1430 266 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2932 0 +2815 0 *
+Wi
+0101100
+-1595 0 -1594 0 +2814 0 -1604 0 +1593 0 -2931 0 *
+Fa
+0 1e-07 266 0
+0101000
++1592 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 32.9900000002235
+0 0
+0101101
+Ed
+1 831 0 1.83471917492468 2.84562973209223
+2 1423 265 0 1.83471917492468 2.84562973209223
+2 1424 267 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1590 0 +2817 0 *
+Ed
+ 1e-08 1 1 0
+1 1172 0 -6.28784925781463 0.420354674684743
+2 1833 267 0 -6.28784925781463 0.420354674684743
+2 1834 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1590 0 -1601 0 *
+Ed
+ 1e-07 1 1 0
+1 836 0 0.408555049325884 2.90757052438606
+2 1433 267 0 0.408555049325884 2.90757052438606
+2 1434 269 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2930 0 +2813 0 *
+Wi
+0101100
+-1589 0 -1588 0 +2812 0 -1600 0 +1587 0 -2929 0 *
+Fa
+0 1e-07 267 0
+0101000
++1586 0 *
+Ed
+ 1e-07 1 1 0
+1 837 0 0.408555049325884 2.90757052438606
+2 1435 270 0 0.408555049325884 2.90757052438606
+2 1436 268 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2928 0 +2811 0 *
+Wi
+0101100
++1593 0 +2927 0 -2810 0 -1584 0 *
+Fa
+0 1e-07 268 0
+0101000
++1583 0 *
+Ed
+ 1e-07 1 1 0
+1 838 0 0.408555049325884 2.90757052438606
+2 1437 269 0 0.408555049325884 2.90757052438606
+2 1438 271 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2926 0 +2809 0 *
+Wi
+0101100
++1581 0 +2925 0 -2808 0 -1587 0 *
+Fa
+0 1e-07 269 0
+0101000
++1580 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 2.99000000022352
+0 0
+0101101
+Ed
+1 839 0 1.83471917492468 2.84562973209223
+2 1439 265 0 1.83471917492468 2.84562973209223
+2 1440 270 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1578 0 +2807 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 2.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 1173 0 -6.28784925781463 0.420354674684743
+2 1835 270 0 -6.28784925781463 0.420354674684743
+2 1836 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1578 0 -1576 0 *
+Ed
+1 839 0 3.43755557508736 4.4484661322549
+2 1439 265 0 3.43755557508736 4.4484661322549
+2 1440 270 0 3.43755557508736 4.4484661322549
+0
+0101000
++1576 0 -2924 0 *
+Wi
+0101100
+-1577 0 -1575 0 +2806 0 -1574 0 +1584 0 -2923 0 *
+Fa
+0 1e-07 270 0
+0101000
++1573 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 31.9900000002235
+0 0
+0101101
+Ed
+1 841 0 1.83471917492468 2.84562973209223
+2 1443 265 0 1.83471917492468 2.84562973209223
+2 1444 271 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1571 0 +2805 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 31.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 1174 0 -6.28784925781463 0.420354674684743
+2 1837 271 0 -6.28784925781463 0.420354674684743
+2 1838 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1571 0 -1569 0 *
+Ed
+1 841 0 3.43755557508736 4.4484661322549
+2 1443 265 0 3.43755557508736 4.4484661322549
+2 1444 271 0 3.43755557508736 4.4484661322549
+0
+0101000
++1569 0 -2922 0 *
+Wi
+0101100
+-1570 0 -1568 0 +2804 0 -1567 0 +1581 0 -2921 0 *
+Fa
+0 1e-07 271 0
+0101000
++1566 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 3.99000000022352
+0 0
+0101101
+Ed
+1 1175 0 -3.99000000022352 -2.99000000022352
+2 1839 265 0 -3.99000000022352 -2.99000000022352
+2 1840 440 0 -3.99000000022352 -2.99000000022352
+0
+0101000
++1564 0 -1576 0 *
+Ed
+1 844 0 3.43755557508736 4.4484661322549
+2 1449 265 0 3.43755557508736 4.4484661322549
+2 1450 272 0 3.43755557508736 4.4484661322549
+0
+0101000
++1564 0 -2920 0 *
+Wi
+0101100
++1574 0 +1563 0 -2919 0 -1562 0 *
+Fa
+0 1e-07 265 0
+0101000
++1561 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 30.9900000002235
+0 0
+0101101
+Ed
+1 845 0 3.43755557508736 4.4484661322549
+2 1451 265 0 3.43755557508736 4.4484661322549
+2 1452 273 0 3.43755557508736 4.4484661322549
+0
+0101000
++1559 0 -2918 0 *
+Ed
+1 1176 0 -31.9900000002235 -30.9900000002235
+2 1841 265 0 -31.9900000002235 -30.9900000002235
+2 1842 440 0 -31.9900000002235 -30.9900000002235
+0
+0101000
++1569 0 -1559 0 *
+Wi
+0101100
++1558 0 +1557 0 -2917 0 -1567 0 *
+Fa
+0 1e-07 265 0
+0101000
++1556 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 3.99000000022352
+0 0
+0101101
+Ed
+1 844 0 1.83471917492468 2.84562973209223
+2 1449 265 0 1.83471917492468 2.84562973209223
+2 1450 272 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1554 0 +2803 0 *
+Ed
+ 1e-08 1 1 0
+1 1177 0 -6.28784925781463 0.420354674684743
+2 1843 272 0 -6.28784925781463 0.420354674684743
+2 1844 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1554 0 -1564 0 *
+Ed
+ 1e-07 1 1 0
+1 848 0 0.408555049325884 2.90757052438606
+2 1457 274 0 0.408555049325884 2.90757052438606
+2 1458 272 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2916 0 +2799 0 *
+Wi
+0101100
+-1553 0 -1552 0 +2798 0 -1562 0 +1551 0 -2915 0 *
+Fa
+0 1e-07 272 0
+0101000
++1550 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 30.9900000002235
+0 0
+0101101
+Ed
+1 845 0 1.83471917492468 2.84562973209223
+2 1451 265 0 1.83471917492468 2.84562973209223
+2 1452 273 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1548 0 +2801 0 *
+Ed
+ 1e-08 1 1 0
+1 1178 0 -6.28784925781463 0.420354674684743
+2 1845 273 0 -6.28784925781463 0.420354674684743
+2 1846 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1548 0 -1559 0 *
+Ed
+ 1e-07 1 1 0
+1 850 0 0.408555049325884 2.90757052438606
+2 1461 273 0 0.408555049325884 2.90757052438606
+2 1462 275 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2914 0 +2797 0 *
+Wi
+0101100
+-1547 0 -1546 0 +2796 0 -1558 0 +1545 0 -2913 0 *
+Fa
+0 1e-07 273 0
+0101000
++1544 0 *
+Ve
+1.92688254189039e-06
+5 -8.07774721070175 4.05049705505371
+0 0
+0101101
+Ve
+5 -8.07774721070175 5.91705513000488
+0 0
+0101101
+Ed
+ 2.97904098389673e-15 1 1 0
+1 1179 0 1.06049705483019 2.92705512978137
+2 1847 274 0 1.06049705483019 2.92705512978137
+2 1848 441 0 1.06049705483019 2.92705512978137
+0
+0101000
++1542 0 -1541 0 *
+Ve
+-5 -8.07774721070175 4.05049705505371
+0 0
+0101101
+Ed
+ 5.49308015822668e-15 1 1 0
+1 1180 0 5.72892347272726 6.83744714163191
+2 1849 274 0 5.72892347272726 6.83744714163191
+2 1850 442 0 5.72892347272726 6.83744714163191
+0
+0101000
++1539 0 -1542 0 *
+Ve
+-5 -8.07774721070175 5.91705513000488
+0 0
+0101101
+Ed
+1 1181 0 5.72892347272726 6.83744714163191
+2 1851 274 0 5.72892347272726 6.83744714163191
+2 1852 443 0 5.72892347272726 6.83744714163191
+0
+0101000
++1537 0 -1541 0 *
+Ed
+ 2.66453525910038e-15 1 1 0
+1 1182 0 1.06049705483019 2.92705512978137
+2 1853 274 0 1.06049705483019 2.92705512978137
+2 1854 444 0 1.06049705483019 2.92705512978137
+0
+0101000
++1539 0 -1537 0 *
+Wi
+0101100
++1540 0 +1538 0 -1536 0 -1535 0 *
+Ed
+ 1e-07 1 1 0
+1 851 0 0.408555049325884 2.90757052438606
+2 1463 276 0 0.408555049325884 2.90757052438606
+2 1464 274 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2912 0 +2795 0 *
+Wi
+0101100
++1551 0 +2911 0 -2794 0 -1533 0 *
+Fa
+0 1e-07 274 0
+0101000
++1534 0 +1532 0 *
+Ve
+5 -8.07774721070175 29.0504970550537
+0 0
+0101101
+Ve
+5 -8.07774721070175 30.9170551300049
+0 0
+0101101
+Ed
+1 1183 0 26.0604970548302 27.9270551297814
+2 1855 275 0 26.0604970548302 27.9270551297814
+2 1856 445 0 26.0604970548302 27.9270551297814
+0
+0101000
++1530 0 -1529 0 *
+Ve
+-5 -8.07774721070175 29.0504970550537
+0 0
+0101101
+Ed
+1 1184 0 5.72892347272726 6.83744714163191
+2 1857 275 0 5.72892347272726 6.83744714163191
+2 1858 446 0 5.72892347272726 6.83744714163191
+0
+0101000
++1527 0 -1530 0 *
+Ve
+-5 -8.07774721070175 30.9170551300049
+0 0
+0101101
+Ed
+1 1185 0 5.72892347272726 6.83744714163191
+2 1859 275 0 5.72892347272726 6.83744714163191
+2 1860 447 0 5.72892347272726 6.83744714163191
+0
+0101000
++1525 0 -1529 0 *
+Ed
+1 1186 0 26.0604970548302 27.9270551297814
+2 1861 275 0 26.0604970548302 27.9270551297814
+2 1862 448 0 26.0604970548302 27.9270551297814
+0
+0101000
++1527 0 -1525 0 *
+Wi
+0101100
++1528 0 +1526 0 -1524 0 -1523 0 *
+Ed
+ 1e-07 1 1 0
+1 856 0 0.408555049325884 2.90757052438606
+2 1473 275 0 0.408555049325884 2.90757052438606
+2 1474 277 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2910 0 +2793 0 *
+Wi
+0101100
++1521 0 +2909 0 -2792 0 -1545 0 *
+Fa
+0 1e-07 275 0
+0101000
++1522 0 +1520 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 5.99000000022352
+0 0
+0101101
+Ed
+1 861 0 1.83471917492468 2.84562973209223
+2 1483 265 0 1.83471917492468 2.84562973209223
+2 1484 276 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1518 0 +2791 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 5.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 1187 0 -6.28784925781463 0.420354674684743
+2 1863 276 0 -6.28784925781463 0.420354674684743
+2 1864 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1518 0 -1516 0 *
+Ed
+1 861 0 3.43755557508736 4.4484661322549
+2 1483 265 0 3.43755557508736 4.4484661322549
+2 1484 276 0 3.43755557508736 4.4484661322549
+0
+0101000
++1516 0 -2908 0 *
+Wi
+0101100
+-1517 0 -1515 0 +2790 0 -1514 0 +1533 0 -2907 0 *
+Fa
+0 1e-07 276 0
+0101000
++1513 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 28.9900000002235
+0 0
+0101101
+Ed
+1 863 0 1.83471917492468 2.84562973209223
+2 1487 265 0 1.83471917492468 2.84562973209223
+2 1488 277 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1511 0 +2789 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 28.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 1188 0 -6.28784925781463 0.420354674684743
+2 1865 277 0 -6.28784925781463 0.420354674684743
+2 1866 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1511 0 -1509 0 *
+Ed
+1 863 0 3.43755557508736 4.4484661322549
+2 1487 265 0 3.43755557508736 4.4484661322549
+2 1488 277 0 3.43755557508736 4.4484661322549
+0
+0101000
++1509 0 -2906 0 *
+Wi
+0101100
+-1510 0 -1508 0 +2788 0 -1507 0 +1521 0 -2905 0 *
+Fa
+0 1e-07 277 0
+0101000
++1506 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 6.99000000022352
+0 0
+0101101
+Ed
+ 1.14999999999996e-07 1 1 0
+1 1189 0 -6.99000000022352 -5.99000000022352
+2 1867 265 0 -6.99000000022352 -5.99000000022352
+2 1868 440 0 -6.99000000022352 -5.99000000022352
+0
+0101000
++1504 0 -1516 0 *
+Ed
+1 866 0 3.43755557508736 4.4484661322549
+2 1493 265 0 3.43755557508736 4.4484661322549
+2 1494 278 0 3.43755557508736 4.4484661322549
+0
+0101000
++1504 0 -2904 0 *
+Wi
+0101100
++1514 0 +1503 0 -2903 0 -1502 0 *
+Fa
+0 1e-07 265 0
+0101000
++1501 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 27.9900000002235
+0 0
+0101101
+Ed
+1 867 0 3.43755557508736 4.4484661322549
+2 1495 265 0 3.43755557508736 4.4484661322549
+2 1496 279 0 3.43755557508736 4.4484661322549
+0
+0101000
++1499 0 -2902 0 *
+Ed
+1 1190 0 -28.9900000002235 -27.9900000002235
+2 1869 265 0 -28.9900000002235 -27.9900000002235
+2 1870 440 0 -28.9900000002235 -27.9900000002235
+0
+0101000
++1509 0 -1499 0 *
+Wi
+0101100
++1498 0 +1497 0 -2901 0 -1507 0 *
+Fa
+0 1e-07 265 0
+0101000
++1496 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 6.99000000022352
+0 0
+0101101
+Ed
+1 866 0 1.83471917492468 2.84562973209223
+2 1493 265 0 1.83471917492468 2.84562973209223
+2 1494 278 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1494 0 +2787 0 *
+Ed
+ 1e-08 1 1 0
+1 1191 0 -6.28784925781463 0.420354674684743
+2 1871 278 0 -6.28784925781463 0.420354674684743
+2 1872 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1494 0 -1504 0 *
+Ed
+ 1e-07 1 1 0
+1 870 0 0.408555049325884 2.90757052438606
+2 1501 280 0 0.408555049325884 2.90757052438606
+2 1502 278 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2900 0 +2783 0 *
+Wi
+0101100
+-1493 0 -1492 0 +2782 0 -1502 0 +1491 0 -2899 0 *
+Fa
+0 1e-07 278 0
+0101000
++1490 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 27.9900000002235
+0 0
+0101101
+Ed
+1 867 0 1.83471917492468 2.84562973209223
+2 1495 265 0 1.83471917492468 2.84562973209223
+2 1496 279 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1488 0 +2785 0 *
+Ed
+ 1e-08 1 1 0
+1 1192 0 -6.28784925781463 0.420354674684743
+2 1873 279 0 -6.28784925781463 0.420354674684743
+2 1874 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1488 0 -1499 0 *
+Ed
+ 1e-07 1 1 0
+1 872 0 0.408555049325884 2.90757052438606
+2 1505 279 0 0.408555049325884 2.90757052438606
+2 1506 281 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2898 0 +2781 0 *
+Wi
+0101100
+-1487 0 -1486 0 +2780 0 -1498 0 +1485 0 -2897 0 *
+Fa
+0 1e-07 279 0
+0101000
++1484 0 *
+Ed
+ 1e-07 1 1 0
+1 873 0 0.408555049325884 2.90757052438606
+2 1507 282 0 0.408555049325884 2.90757052438606
+2 1508 280 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2896 0 +2779 0 *
+Wi
+0101100
++1491 0 +2895 0 -2778 0 -1482 0 *
+Fa
+0 1e-07 280 0
+0101000
++1481 0 *
+Ed
+ 1e-07 1 1 0
+1 874 0 0.408555049325884 2.90757052438606
+2 1509 281 0 0.408555049325884 2.90757052438606
+2 1510 283 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2894 0 +2777 0 *
+Wi
+0101100
++1479 0 +2893 0 -2776 0 -1485 0 *
+Fa
+0 1e-07 281 0
+0101000
++1478 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 7.99000000022352
+0 0
+0101101
+Ed
+1 875 0 1.83471917492468 2.84562973209223
+2 1511 265 0 1.83471917492468 2.84562973209223
+2 1512 282 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1476 0 +2775 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 7.99000000022352
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 1193 0 -6.28784925781463 0.420354674684743
+2 1875 282 0 -6.28784925781463 0.420354674684743
+2 1876 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1476 0 -1474 0 *
+Ed
+1 875 0 3.43755557508736 4.4484661322549
+2 1511 265 0 3.43755557508736 4.4484661322549
+2 1512 282 0 3.43755557508736 4.4484661322549
+0
+0101000
++1474 0 -2892 0 *
+Wi
+0101100
+-1475 0 -1473 0 +2774 0 -1472 0 +1482 0 -2891 0 *
+Fa
+0 1e-07 282 0
+0101000
++1471 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 26.9900000002235
+0 0
+0101101
+Ed
+1 877 0 1.83471917492468 2.84562973209223
+2 1515 265 0 1.83471917492468 2.84562973209223
+2 1516 283 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1469 0 +2773 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 26.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 1194 0 -6.28784925781463 0.420354674684743
+2 1877 283 0 -6.28784925781463 0.420354674684743
+2 1878 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1469 0 -1467 0 *
+Ed
+1 877 0 3.43755557508736 4.4484661322549
+2 1515 265 0 3.43755557508736 4.4484661322549
+2 1516 283 0 3.43755557508736 4.4484661322549
+0
+0101000
++1467 0 -2890 0 *
+Wi
+0101100
+-1468 0 -1466 0 +2772 0 -1465 0 +1479 0 -2889 0 *
+Fa
+0 1e-07 283 0
+0101000
++1464 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 8.99000000022352
+0 0
+0101101
+Ed
+1 1195 0 -8.99000000022352 -7.99000000022352
+2 1879 265 0 -8.99000000022352 -7.99000000022352
+2 1880 440 0 -8.99000000022352 -7.99000000022352
+0
+0101000
++1462 0 -1474 0 *
+Ed
+1 880 0 3.43755557508736 4.4484661322549
+2 1521 265 0 3.43755557508736 4.4484661322549
+2 1522 284 0 3.43755557508736 4.4484661322549
+0
+0101000
++1462 0 -2888 0 *
+Wi
+0101100
++1472 0 +1461 0 -2887 0 -1460 0 *
+Fa
+0 1e-07 265 0
+0101000
++1459 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 25.9900000002235
+0 0
+0101101
+Ed
+1 881 0 3.43755557508736 4.4484661322549
+2 1523 265 0 3.43755557508736 4.4484661322549
+2 1524 285 0 3.43755557508736 4.4484661322549
+0
+0101000
++1457 0 -2886 0 *
+Ed
+1 1196 0 -26.9900000002235 -25.9900000002235
+2 1881 265 0 -26.9900000002235 -25.9900000002235
+2 1882 440 0 -26.9900000002235 -25.9900000002235
+0
+0101000
++1467 0 -1457 0 *
+Wi
+0101100
++1456 0 +1455 0 -2885 0 -1465 0 *
+Fa
+0 1e-07 265 0
+0101000
++1454 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 8.99000000022352
+0 0
+0101101
+Ed
+1 880 0 1.83471917492468 2.84562973209223
+2 1521 265 0 1.83471917492468 2.84562973209223
+2 1522 284 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1452 0 +2771 0 *
+Ed
+ 1e-08 1 1 0
+1 1197 0 -6.28784925781463 0.420354674684743
+2 1883 284 0 -6.28784925781463 0.420354674684743
+2 1884 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1452 0 -1462 0 *
+Ed
+ 1e-07 1 1 0
+1 884 0 0.408555049325884 2.90757052438606
+2 1529 286 0 0.408555049325884 2.90757052438606
+2 1530 284 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2884 0 +2767 0 *
+Wi
+0101100
+-1451 0 -1450 0 +2766 0 -1460 0 +1449 0 -2883 0 *
+Fa
+0 1e-07 284 0
+0101000
++1448 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 25.9900000002235
+0 0
+0101101
+Ed
+1 881 0 1.83471917492468 2.84562973209223
+2 1523 265 0 1.83471917492468 2.84562973209223
+2 1524 285 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1446 0 +2769 0 *
+Ed
+ 1e-08 1 1 0
+1 1198 0 -6.28784925781463 0.420354674684743
+2 1885 285 0 -6.28784925781463 0.420354674684743
+2 1886 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1446 0 -1457 0 *
+Ed
+ 1e-07 1 1 0
+1 886 0 0.408555049325884 2.90757052438606
+2 1533 285 0 0.408555049325884 2.90757052438606
+2 1534 287 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2882 0 +2765 0 *
+Wi
+0101100
+-1445 0 -1444 0 +2764 0 -1456 0 +1443 0 -2881 0 *
+Fa
+0 1e-07 285 0
+0101000
++1442 0 *
+Ve
+5 -8.07774721070176 9.05049705505371
+0 0
+0101101
+Ve
+5 -8.07774721070176 10.9170551300049
+0 0
+0101101
+Ed
+ 1.33226762955019e-15 1 1 0
+1 1199 0 6.06049705483019 7.92705512978137
+2 1887 286 0 6.06049705483019 7.92705512978137
+2 1888 449 0 6.06049705483019 7.92705512978137
+0
+0101000
++1440 0 -1439 0 *
+Ve
+-5 -8.07774721070176 9.05049705505371
+0 0
+0101101
+Ed
+ 2.74654007911334e-15 1 1 0
+1 1200 0 5.72892347272726 6.83744714163191
+2 1889 286 0 5.72892347272726 6.83744714163191
+2 1890 450 0 5.72892347272726 6.83744714163191
+0
+0101000
++1437 0 -1440 0 *
+Ve
+-5 -8.07774721070176 10.9170551300049
+0 0
+0101101
+Ed
+1 1201 0 5.72892347272726 6.83744714163191
+2 1891 286 0 5.72892347272726 6.83744714163191
+2 1892 451 0 5.72892347272726 6.83744714163191
+0
+0101000
++1435 0 -1439 0 *
+Ed
+1 1202 0 6.06049705483019 7.92705512978137
+2 1893 286 0 6.06049705483019 7.92705512978137
+2 1894 452 0 6.06049705483019 7.92705512978137
+0
+0101000
++1437 0 -1435 0 *
+Wi
+0101100
++1438 0 +1436 0 -1434 0 -1433 0 *
+Ed
+ 1e-07 1 1 0
+1 887 0 0.408555049325884 2.90757052438606
+2 1535 288 0 0.408555049325884 2.90757052438606
+2 1536 286 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2880 0 +2763 0 *
+Wi
+0101100
++1449 0 +2879 0 -2762 0 -1431 0 *
+Fa
+0 1e-07 286 0
+0101000
++1432 0 +1430 0 *
+Ve
+5 -8.07774721070176 24.0504970550537
+0 0
+0101101
+Ve
+5 -8.07774721070176 25.9170551300049
+0 0
+0101101
+Ed
+1 1203 0 21.0604970548302 22.9270551297814
+2 1895 287 0 21.0604970548302 22.9270551297814
+2 1896 453 0 21.0604970548302 22.9270551297814
+0
+0101000
++1428 0 -1427 0 *
+Ve
+-5 -8.07774721070176 24.0504970550537
+0 0
+0101101
+Ed
+1 1204 0 5.72892347272726 6.83744714163191
+2 1897 287 0 5.72892347272726 6.83744714163191
+2 1898 454 0 5.72892347272726 6.83744714163191
+0
+0101000
++1425 0 -1428 0 *
+Ve
+-5 -8.07774721070176 25.9170551300049
+0 0
+0101101
+Ed
+1 1205 0 5.72892347272726 6.83744714163191
+2 1899 287 0 5.72892347272726 6.83744714163191
+2 1900 455 0 5.72892347272726 6.83744714163191
+0
+0101000
++1423 0 -1427 0 *
+Ed
+1 1206 0 21.0604970548302 22.9270551297814
+2 1901 287 0 21.0604970548302 22.9270551297814
+2 1902 456 0 21.0604970548302 22.9270551297814
+0
+0101000
++1425 0 -1423 0 *
+Wi
+0101100
++1426 0 +1424 0 -1422 0 -1421 0 *
+Ed
+ 1e-07 1 1 0
+1 892 0 0.408555049325884 2.90757052438606
+2 1545 287 0 0.408555049325884 2.90757052438606
+2 1546 289 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2878 0 +2761 0 *
+Wi
+0101100
++1419 0 +2877 0 -2760 0 -1443 0 *
+Fa
+0 1e-07 287 0
+0101000
++1420 0 +1418 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 10.9900000002235
+0 0
+0101101
+Ed
+1 897 0 1.83471917492468 2.84562973209223
+2 1555 265 0 1.83471917492468 2.84562973209223
+2 1556 288 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1416 0 +2759 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 10.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 1207 0 -6.28784925781463 0.420354674684743
+2 1903 288 0 -6.28784925781463 0.420354674684743
+2 1904 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1416 0 -1414 0 *
+Ed
+1 897 0 3.43755557508736 4.4484661322549
+2 1555 265 0 3.43755557508736 4.4484661322549
+2 1556 288 0 3.43755557508736 4.4484661322549
+0
+0101000
++1414 0 -2876 0 *
+Wi
+0101100
+-1415 0 -1413 0 +2758 0 -1412 0 +1431 0 -2875 0 *
+Fa
+0 1e-07 288 0
+0101000
++1411 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 23.9900000002235
+0 0
+0101101
+Ed
+1 899 0 1.83471917492468 2.84562973209223
+2 1559 265 0 1.83471917492468 2.84562973209223
+2 1560 289 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1409 0 +2757 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 23.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 1208 0 -6.28784925781463 0.420354674684743
+2 1905 289 0 -6.28784925781463 0.420354674684743
+2 1906 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1409 0 -1407 0 *
+Ed
+1 899 0 3.43755557508736 4.4484661322549
+2 1559 265 0 3.43755557508736 4.4484661322549
+2 1560 289 0 3.43755557508736 4.4484661322549
+0
+0101000
++1407 0 -2874 0 *
+Wi
+0101100
+-1408 0 -1406 0 +2756 0 -1405 0 +1419 0 -2873 0 *
+Fa
+0 1e-07 289 0
+0101000
++1404 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 11.9900000002235
+0 0
+0101101
+Ed
+1 1209 0 -11.9900000002235 -10.9900000002235
+2 1907 265 0 -11.9900000002235 -10.9900000002235
+2 1908 440 0 -11.9900000002235 -10.9900000002235
+0
+0101000
++1402 0 -1414 0 *
+Ed
+1 902 0 3.43755557508736 4.4484661322549
+2 1565 265 0 3.43755557508736 4.4484661322549
+2 1566 290 0 3.43755557508736 4.4484661322549
+0
+0101000
++1402 0 -2872 0 *
+Wi
+0101100
++1412 0 +1401 0 -2871 0 -1400 0 *
+Fa
+0 1e-07 265 0
+0101000
++1399 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 22.9900000002235
+0 0
+0101101
+Ed
+1 903 0 3.43755557508736 4.4484661322549
+2 1567 265 0 3.43755557508736 4.4484661322549
+2 1568 291 0 3.43755557508736 4.4484661322549
+0
+0101000
++1397 0 -2870 0 *
+Ed
+1 1210 0 -23.9900000002235 -22.9900000002235
+2 1909 265 0 -23.9900000002235 -22.9900000002235
+2 1910 440 0 -23.9900000002235 -22.9900000002235
+0
+0101000
++1407 0 -1397 0 *
+Wi
+0101100
++1396 0 +1395 0 -2869 0 -1405 0 *
+Fa
+0 1e-07 265 0
+0101000
++1394 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 11.9900000002235
+0 0
+0101101
+Ed
+1 902 0 1.83471917492468 2.84562973209223
+2 1565 265 0 1.83471917492468 2.84562973209223
+2 1566 290 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1392 0 +2755 0 *
+Ed
+ 1e-08 1 1 0
+1 1211 0 -6.28784925781463 0.420354674684743
+2 1911 290 0 -6.28784925781463 0.420354674684743
+2 1912 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1392 0 -1402 0 *
+Ed
+ 1e-07 1 1 0
+1 906 0 0.408555049325884 2.90757052438606
+2 1573 292 0 0.408555049325884 2.90757052438606
+2 1574 290 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2868 0 +2751 0 *
+Wi
+0101100
+-1391 0 -1390 0 +2750 0 -1400 0 +1389 0 -2867 0 *
+Fa
+0 1e-07 290 0
+0101000
++1388 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 22.9900000002235
+0 0
+0101101
+Ed
+1 903 0 1.83471917492468 2.84562973209223
+2 1567 265 0 1.83471917492468 2.84562973209223
+2 1568 291 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1386 0 +2753 0 *
+Ed
+ 1e-08 1 1 0
+1 1212 0 -6.28784925781463 0.420354674684743
+2 1913 291 0 -6.28784925781463 0.420354674684743
+2 1914 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1386 0 -1397 0 *
+Ed
+ 1e-07 1 1 0
+1 908 0 0.408555049325884 2.90757052438606
+2 1577 291 0 0.408555049325884 2.90757052438606
+2 1578 293 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2866 0 +2749 0 *
+Wi
+0101100
+-1385 0 -1384 0 +2748 0 -1396 0 +1383 0 -2865 0 *
+Fa
+0 1e-07 291 0
+0101000
++1382 0 *
+Ed
+ 1e-07 1 1 0
+1 909 0 0.408555049325884 2.90757052438606
+2 1579 294 0 0.408555049325884 2.90757052438606
+2 1580 292 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2864 0 +2747 0 *
+Wi
+0101100
++1389 0 +2863 0 -2746 0 -1380 0 *
+Fa
+0 1e-07 292 0
+0101000
++1379 0 *
+Ed
+ 1e-07 1 1 0
+1 910 0 0.408555049325884 2.90757052438606
+2 1581 293 0 0.408555049325884 2.90757052438606
+2 1582 295 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2862 0 +2745 0 *
+Wi
+0101100
++1377 0 +2861 0 -2744 0 -1383 0 *
+Fa
+0 1e-07 293 0
+0101000
++1376 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 12.9900000002235
+0 0
+0101101
+Ed
+1 911 0 1.83471917492468 2.84562973209223
+2 1583 265 0 1.83471917492468 2.84562973209223
+2 1584 294 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1374 0 +2743 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 12.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 1213 0 -6.28784925781463 0.420354674684743
+2 1915 294 0 -6.28784925781463 0.420354674684743
+2 1916 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1374 0 -1372 0 *
+Ed
+1 911 0 3.43755557508736 4.4484661322549
+2 1583 265 0 3.43755557508736 4.4484661322549
+2 1584 294 0 3.43755557508736 4.4484661322549
+0
+0101000
++1372 0 -2860 0 *
+Wi
+0101100
+-1373 0 -1371 0 +2742 0 -1370 0 +1380 0 -2859 0 *
+Fa
+0 1e-07 294 0
+0101000
++1369 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 21.9900000002235
+0 0
+0101101
+Ed
+1 913 0 1.83471917492468 2.84562973209223
+2 1587 265 0 1.83471917492468 2.84562973209223
+2 1588 295 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1367 0 +2741 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 21.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 1214 0 -6.28784925781463 0.420354674684743
+2 1917 295 0 -6.28784925781463 0.420354674684743
+2 1918 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1367 0 -1365 0 *
+Ed
+1 913 0 3.43755557508736 4.4484661322549
+2 1587 265 0 3.43755557508736 4.4484661322549
+2 1588 295 0 3.43755557508736 4.4484661322549
+0
+0101000
++1365 0 -2858 0 *
+Wi
+0101100
+-1366 0 -1364 0 +2740 0 -1363 0 +1377 0 -2857 0 *
+Fa
+0 1e-07 295 0
+0101000
++1362 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 13.9900000002235
+0 0
+0101101
+Ed
+1 1215 0 -13.9900000002235 -12.9900000002235
+2 1919 265 0 -13.9900000002235 -12.9900000002235
+2 1920 440 0 -13.9900000002235 -12.9900000002235
+0
+0101000
++1360 0 -1372 0 *
+Ed
+1 916 0 3.43755557508736 4.4484661322549
+2 1593 265 0 3.43755557508736 4.4484661322549
+2 1594 296 0 3.43755557508736 4.4484661322549
+0
+0101000
++1360 0 -2856 0 *
+Wi
+0101100
++1370 0 +1359 0 -2855 0 -1358 0 *
+Fa
+0 1e-07 265 0
+0101000
++1357 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 20.9900000002235
+0 0
+0101101
+Ed
+1 917 0 3.43755557508736 4.4484661322549
+2 1595 265 0 3.43755557508736 4.4484661322549
+2 1596 297 0 3.43755557508736 4.4484661322549
+0
+0101000
++1355 0 -2854 0 *
+Ed
+1 1216 0 -21.9900000002235 -20.9900000002235
+2 1921 265 0 -21.9900000002235 -20.9900000002235
+2 1922 440 0 -21.9900000002235 -20.9900000002235
+0
+0101000
++1365 0 -1355 0 *
+Wi
+0101100
++1354 0 +1353 0 -2853 0 -1363 0 *
+Fa
+0 1e-07 265 0
+0101000
++1352 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 13.9900000002235
+0 0
+0101101
+Ed
+1 916 0 1.83471917492468 2.84562973209223
+2 1593 265 0 1.83471917492468 2.84562973209223
+2 1594 296 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1350 0 +2739 0 *
+Ed
+ 1e-08 1 1 0
+1 1217 0 -6.28784925781463 0.420354674684743
+2 1923 296 0 -6.28784925781463 0.420354674684743
+2 1924 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1350 0 -1360 0 *
+Ed
+ 1e-07 1 1 0
+1 920 0 0.408555049325884 2.90757052438606
+2 1601 298 0 0.408555049325884 2.90757052438606
+2 1602 296 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2852 0 +2735 0 *
+Wi
+0101100
+-1349 0 -1348 0 +2734 0 -1358 0 +1347 0 -2851 0 *
+Fa
+0 1e-07 296 0
+0101000
++1346 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 20.9900000002235
+0 0
+0101101
+Ed
+1 917 0 1.83471917492468 2.84562973209223
+2 1595 265 0 1.83471917492468 2.84562973209223
+2 1596 297 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1344 0 +2737 0 *
+Ed
+ 1e-08 1 1 0
+1 1218 0 -6.28784925781463 0.420354674684743
+2 1925 297 0 -6.28784925781463 0.420354674684743
+2 1926 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1344 0 -1355 0 *
+Ed
+ 1e-07 1 1 0
+1 922 0 0.408555049325884 2.90757052438606
+2 1605 297 0 0.408555049325884 2.90757052438606
+2 1606 299 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2850 0 +2733 0 *
+Wi
+0101100
+-1343 0 -1342 0 +2732 0 -1354 0 +1341 0 -2849 0 *
+Fa
+0 1e-07 297 0
+0101000
++1340 0 *
+Ve
+5 -8.07774721070176 14.0504970550537
+0 0
+0101101
+Ve
+5 -8.07774721070176 15.9170551300049
+0 0
+0101101
+Ed
+1 1219 0 11.0604970548302 12.9270551297814
+2 1927 298 0 11.0604970548302 12.9270551297814
+2 1928 457 0 11.0604970548302 12.9270551297814
+0
+0101000
++1338 0 -1337 0 *
+Ve
+-5 -8.07774721070176 14.0504970550537
+0 0
+0101101
+Ed
+1 1220 0 5.72892347272726 6.83744714163191
+2 1929 298 0 5.72892347272726 6.83744714163191
+2 1930 458 0 5.72892347272726 6.83744714163191
+0
+0101000
++1335 0 -1338 0 *
+Ve
+-5 -8.07774721070176 15.9170551300049
+0 0
+0101101
+Ed
+1 1221 0 5.72892347272726 6.83744714163191
+2 1931 298 0 5.72892347272726 6.83744714163191
+2 1932 459 0 5.72892347272726 6.83744714163191
+0
+0101000
++1333 0 -1337 0 *
+Ed
+1 1222 0 11.0604970548302 12.9270551297814
+2 1933 298 0 11.0604970548302 12.9270551297814
+2 1934 460 0 11.0604970548302 12.9270551297814
+0
+0101000
++1335 0 -1333 0 *
+Wi
+0101100
++1336 0 +1334 0 -1332 0 -1331 0 *
+Ed
+ 1e-07 1 1 0
+1 923 0 0.408555049325884 2.90757052438606
+2 1607 300 0 0.408555049325884 2.90757052438606
+2 1608 298 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2848 0 +2731 0 *
+Wi
+0101100
++1347 0 +2847 0 -2730 0 -1329 0 *
+Fa
+0 1e-07 298 0
+0101000
++1330 0 +1328 0 *
+Ve
+5 -8.07774721070175 19.0504970550537
+0 0
+0101101
+Ve
+5 -8.07774721070175 20.9170551300049
+0 0
+0101101
+Ed
+1 1223 0 16.0604970548302 17.9270551297814
+2 1935 299 0 16.0604970548302 17.9270551297814
+2 1936 461 0 16.0604970548302 17.9270551297814
+0
+0101000
++1326 0 -1325 0 *
+Ve
+-5 -8.07774721070175 19.0504970550537
+0 0
+0101101
+Ed
+1 1224 0 5.72892347272726 6.83744714163191
+2 1937 299 0 5.72892347272726 6.83744714163191
+2 1938 462 0 5.72892347272726 6.83744714163191
+0
+0101000
++1323 0 -1326 0 *
+Ve
+-5 -8.07774721070175 20.9170551300049
+0 0
+0101101
+Ed
+1 1225 0 5.72892347272726 6.83744714163191
+2 1939 299 0 5.72892347272726 6.83744714163191
+2 1940 463 0 5.72892347272726 6.83744714163191
+0
+0101000
++1321 0 -1325 0 *
+Ed
+1 1226 0 16.0604970548302 17.9270551297814
+2 1941 299 0 16.0604970548302 17.9270551297814
+2 1942 464 0 16.0604970548302 17.9270551297814
+0
+0101000
++1323 0 -1321 0 *
+Wi
+0101100
++1324 0 +1322 0 -1320 0 -1319 0 *
+Ed
+ 1e-07 1 1 0
+1 928 0 0.408555049325884 2.90757052438606
+2 1617 299 0 0.408555049325884 2.90757052438606
+2 1618 301 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2846 0 +2729 0 *
+Wi
+0101100
++1317 0 +2845 0 -2728 0 -1341 0 *
+Fa
+0 1e-07 299 0
+0101000
++1318 0 +1316 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 15.9900000002235
+0 0
+0101101
+Ed
+1 933 0 1.83471917492468 2.84562973209223
+2 1627 265 0 1.83471917492468 2.84562973209223
+2 1628 300 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1314 0 +2727 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 15.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 1227 0 -6.28784925781463 0.420354674684743
+2 1943 300 0 -6.28784925781463 0.420354674684743
+2 1944 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1314 0 -1312 0 *
+Ed
+1 933 0 3.43755557508736 4.4484661322549
+2 1627 265 0 3.43755557508736 4.4484661322549
+2 1628 300 0 3.43755557508736 4.4484661322549
+0
+0101000
++1312 0 -2844 0 *
+Wi
+0101100
+-1313 0 -1311 0 +2726 0 -1310 0 +1329 0 -2843 0 *
+Fa
+0 1e-07 300 0
+0101000
++1309 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 18.9900000002235
+0 0
+0101101
+Ed
+1 935 0 1.83471917492468 2.84562973209223
+2 1631 265 0 1.83471917492468 2.84562973209223
+2 1632 301 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1307 0 +2725 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 18.9900000002235
+0 0
+0101101
+Ed
+ 1e-08 1 1 0
+1 1228 0 -6.28784925781463 0.420354674684743
+2 1945 301 0 -6.28784925781463 0.420354674684743
+2 1946 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1307 0 -1305 0 *
+Ed
+1 935 0 3.43755557508736 4.4484661322549
+2 1631 265 0 3.43755557508736 4.4484661322549
+2 1632 301 0 3.43755557508736 4.4484661322549
+0
+0101000
++1305 0 -2842 0 *
+Wi
+0101100
+-1306 0 -1304 0 +2724 0 -1303 0 +1317 0 -2841 0 *
+Fa
+0 1e-07 301 0
+0101000
++1302 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 16.9900000002235
+0 0
+0101101
+Ed
+1 1229 0 -16.9900000002235 -15.9900000002235
+2 1947 265 0 -16.9900000002235 -15.9900000002235
+2 1948 440 0 -16.9900000002235 -15.9900000002235
+0
+0101000
++1300 0 -1312 0 *
+Ed
+1 938 0 3.43755557508736 4.4484661322549
+2 1637 265 0 3.43755557508736 4.4484661322549
+2 1638 302 0 3.43755557508736 4.4484661322549
+0
+0101000
++1300 0 -2840 0 *
+Wi
+0101100
++1310 0 +1299 0 -2839 0 -1298 0 *
+Fa
+0 1e-07 265 0
+0101000
++1297 0 *
+Ve
+2.800000002e-05
+-3.35410196624968 -11 17.9900000002235
+0 0
+0101101
+Ed
+1 939 0 3.43755557508736 4.4484661322549
+2 1639 265 0 3.43755557508736 4.4484661322549
+2 1640 303 0 3.43755557508736 4.4484661322549
+0
+0101000
++1295 0 -2838 0 *
+Ed
+1 1230 0 -18.9900000002235 -17.9900000002235
+2 1949 265 0 -18.9900000002235 -17.9900000002235
+2 1950 440 0 -18.9900000002235 -17.9900000002235
+0
+0101000
++1305 0 -1295 0 *
+Wi
+0101100
++1294 0 +1293 0 -2837 0 -1303 0 *
+Fa
+0 1e-07 265 0
+0101000
++1292 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 16.9900000002235
+0 0
+0101101
+Ed
+1 938 0 1.83471917492468 2.84562973209223
+2 1637 265 0 1.83471917492468 2.84562973209223
+2 1638 302 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1290 0 +2723 0 *
+Ed
+ 1e-08 1 1 0
+1 1231 0 -6.28784925781463 0.420354674684743
+2 1951 302 0 -6.28784925781463 0.420354674684743
+2 1952 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1290 0 -1300 0 *
+Ed
+ 1e-07 1 1 0
+1 942 0 0.408555049325884 2.90757052438606
+2 1645 304 0 0.408555049325884 2.90757052438606
+2 1646 302 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2836 0 +2719 0 *
+Wi
+0101100
+-1289 0 -1288 0 +2718 0 -1298 0 +1287 0 -2835 0 *
+Fa
+0 1e-07 302 0
+0101000
++1286 0 *
+Ve
+2.800000002e-05
+3.35410196624968 -11 17.9900000002235
+0 0
+0101101
+Ed
+1 939 0 1.83471917492468 2.84562973209223
+2 1639 265 0 1.83471917492468 2.84562973209223
+2 1640 303 0 1.83471917492468 2.84562973209223
+0
+0101000
+-1284 0 +2721 0 *
+Ed
+ 1e-08 1 1 0
+1 1232 0 -6.28784925781463 0.420354674684743
+2 1953 303 0 -6.28784925781463 0.420354674684743
+2 1954 440 0 -6.28784925781463 0.420354674684743
+0
+0101000
++1284 0 -1295 0 *
+Ed
+ 1e-07 1 1 0
+1 944 0 0.408555049325884 2.90757052438606
+2 1649 303 0 0.408555049325884 2.90757052438606
+2 1650 304 0 0.408555049325884 2.90757052438606
+0
+0101000
+-2834 0 +2717 0 *
+Wi
+0101100
+-1283 0 -1282 0 +2716 0 -1294 0 +1281 0 -2833 0 *
+Fa
+0 1e-07 303 0
+0101000
++1280 0 *
+Wi
+0101100
++1287 0 +2832 0 -2715 0 -1281 0 *
+Fa
+0 1e-07 304 0
+0101000
++1278 0 *
+Ed
+1 1233 0 -1.99000000022352 -0.990000000223517
+2 1955 265 0 -1.99000000022352 -0.990000000223517
+2 1956 440 0 -1.99000000022352 -0.990000000223517
+0
+0101000
++1596 0 -1620 0 *
+Wi
+0101100
++1619 0 -1276 0 +2818 0 -1595 0 *
+Fa
+0 1e-07 265 0
+0101000
++1275 0 *
+Ed
+1 1234 0 -33.9900000002235 -32.9900000002235
+2 1957 265 0 -33.9900000002235 -32.9900000002235
+2 1958 440 0 -33.9900000002235 -32.9900000002235
+0
+0101000
++1613 0 -1590 0 *
+Wi
+0101100
++1589 0 -1273 0 +2816 0 -1612 0 *
+Fa
+0 1e-07 265 0
+0101000
++1272 0 *
+Ed
+1 1235 0 -3.99000000022352 -2.99000000022352
+2 1959 265 0 -3.99000000022352 -2.99000000022352
+2 1960 440 0 -3.99000000022352 -2.99000000022352
+0
+0101000
++1554 0 -1578 0 *
+Wi
+0101100
++1577 0 -1270 0 +2802 0 -1553 0 *
+Fa
+0 1e-07 265 0
+0101000
++1269 0 *
+Ed
+1 1236 0 -31.9900000002235 -30.9900000002235
+2 1961 265 0 -31.9900000002235 -30.9900000002235
+2 1962 440 0 -31.9900000002235 -30.9900000002235
+0
+0101000
++1571 0 -1548 0 *
+Wi
+0101100
++1547 0 -1267 0 +2800 0 -1570 0 *
+Fa
+0 1e-07 265 0
+0101000
++1266 0 *
+Ed
+1 1237 0 -6.99000000022352 -5.99000000022352
+2 1963 265 0 -6.99000000022352 -5.99000000022352
+2 1964 440 0 -6.99000000022352 -5.99000000022352
+0
+0101000
++1494 0 -1518 0 *
+Wi
+0101100
++1517 0 -1264 0 +2786 0 -1493 0 *
+Fa
+0 1e-07 265 0
+0101000
++1263 0 *
+Ed
+1 1238 0 -28.9900000002235 -27.9900000002235
+2 1965 265 0 -28.9900000002235 -27.9900000002235
+2 1966 440 0 -28.9900000002235 -27.9900000002235
+0
+0101000
++1511 0 -1488 0 *
+Wi
+0101100
++1487 0 -1261 0 +2784 0 -1510 0 *
+Fa
+0 1e-07 265 0
+0101000
++1260 0 *
+Ed
+1 1239 0 -8.99000000022352 -7.99000000022352
+2 1967 265 0 -8.99000000022352 -7.99000000022352
+2 1968 440 0 -8.99000000022352 -7.99000000022352
+0
+0101000
++1452 0 -1476 0 *
+Wi
+0101100
++1475 0 -1258 0 +2770 0 -1451 0 *
+Fa
+0 1e-07 265 0
+0101000
++1257 0 *
+Ed
+1 1240 0 -26.9900000002235 -25.9900000002235
+2 1969 265 0 -26.9900000002235 -25.9900000002235
+2 1970 440 0 -26.9900000002235 -25.9900000002235
+0
+0101000
++1469 0 -1446 0 *
+Wi
+0101100
++1445 0 -1255 0 +2768 0 -1468 0 *
+Fa
+0 1e-07 265 0
+0101000
++1254 0 *
+Ed
+1 1241 0 -11.9900000002235 -10.9900000002235
+2 1971 265 0 -11.9900000002235 -10.9900000002235
+2 1972 440 0 -11.9900000002235 -10.9900000002235
+0
+0101000
++1392 0 -1416 0 *
+Wi
+0101100
++1415 0 -1252 0 +2754 0 -1391 0 *
+Fa
+0 1e-07 265 0
+0101000
++1251 0 *
+Ed
+1 1242 0 -23.9900000002235 -22.9900000002235
+2 1973 265 0 -23.9900000002235 -22.9900000002235
+2 1974 440 0 -23.9900000002235 -22.9900000002235
+0
+0101000
++1409 0 -1386 0 *
+Wi
+0101100
++1385 0 -1249 0 +2752 0 -1408 0 *
+Fa
+0 1e-07 265 0
+0101000
++1248 0 *
+Ed
+1 1243 0 -13.9900000002235 -12.9900000002235
+2 1975 265 0 -13.9900000002235 -12.9900000002235
+2 1976 440 0 -13.9900000002235 -12.9900000002235
+0
+0101000
++1350 0 -1374 0 *
+Wi
+0101100
++1373 0 -1246 0 +2738 0 -1349 0 *
+Fa
+0 1e-07 265 0
+0101000
++1245 0 *
+Ed
+1 1244 0 -21.9900000002235 -20.9900000002235
+2 1977 265 0 -21.9900000002235 -20.9900000002235
+2 1978 440 0 -21.9900000002235 -20.9900000002235
+0
+0101000
++1367 0 -1344 0 *
+Wi
+0101100
++1343 0 -1243 0 +2736 0 -1366 0 *
+Fa
+0 1e-07 265 0
+0101000
++1242 0 *
+Ed
+1 1245 0 -16.9900000002235 -15.9900000002235
+2 1979 265 0 -16.9900000002235 -15.9900000002235
+2 1980 440 0 -16.9900000002235 -15.9900000002235
+0
+0101000
++1290 0 -1314 0 *
+Wi
+0101100
++1313 0 -1240 0 +2722 0 -1289 0 *
+Fa
+0 1e-07 265 0
+0101000
++1239 0 *
+Ed
+1 1246 0 -18.9900000002235 -17.9900000002235
+2 1981 265 0 -18.9900000002235 -17.9900000002235
+2 1982 440 0 -18.9900000002235 -17.9900000002235
+0
+0101000
++1307 0 -1284 0 *
+Wi
+0101100
++1283 0 -1237 0 +2720 0 -1306 0 *
+Fa
+0 1e-07 265 0
+0101000
++1236 0 *
+Wi
+0101000
++2706 0 +2701 0 +2691 0 +2681 0 +2671 0 +2661 0 +2652 0 +2655 0 +2665 0 +2675 0
++2685 0 +2695 0 *
+Fa
+0 1e-07 465 0
+0101000
++1234 0 *
+Wi
+0101000
++2646 0 +2641 0 +2631 0 +2621 0 +2611 0 +2601 0 +2592 0 +2595 0 +2605 0 +2615 0
++2625 0 +2635 0 *
+Fa
+0 1e-07 466 0
+0101000
+-1232 0 *
+Ve
+1e-07
+-2.06109145955419 4.00023774235392 37
+0 0
+0101101
+Ve
+1e-07
+-3.54965751367666 6.88929833405398 37
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1247 0 4.5 7.75
+0
+0101000
++1230 0 -1229 0 *
+Ve
+1e-07
+2.05294383083092 4.0044252555708 37
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1248 0 1.09706513192818 2.04656324156928
+2 1983 467 0 1.09706513192818 2.04656324156928
+2 1984 467 94 1.09706513192818 2.04656324156928
+2 1985 468 96 1.09706513192818 2.04656324156928
+2 1986 468 98 1.09706513192818 2.04656324156928
+2 1987 469 99 1.09706513192818 2.04656324156928
+2 1988 469 101 1.09706513192818 2.04656324156928
+0
+0101000
++1227 0 -1230 0 *
+Ve
+1e-07
+3.53562548643103 6.89651016237193 37
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1249 0 4.5 7.75
+0
+0101000
++1227 0 -1225 0 *
+Ed
+ 1e-07 1 1 0
+1 1250 0 1.09706513192818 2.04656324156928
+2 1989 470 0 1.09706513192818 2.04656324156928
+2 1990 470 94 1.09706513192818 2.04656324156928
+2 1991 471 96 1.09706513192818 2.04656324156928
+2 1992 471 98 1.09706513192818 2.04656324156928
+2 1993 472 99 1.09706513192818 2.04656324156928
+2 1994 472 101 1.09706513192818 2.04656324156928
+0
+0101000
++1225 0 -1229 0 *
+Wi
+0101100
+-1228 0 -1226 0 +1224 0 +1223 0 *
+Wi
+0101100
+-2575 0 -2572 0 -2586 0 -2581 0 *
+Fa
+0 1e-07 409 0
+0101000
++1222 0 +1221 99 *
+Ve
+1e-07
+-2.06109145955419 -4.00023774235392 37
+0 0
+0101101
+Ve
+1e-07
+-3.54965751367666 -6.88929833405398 37
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1251 0 4.5 7.75
+0
+0101000
++1219 0 -1218 0 *
+Ve
+1e-07
+2.05294383083092 -4.0044252555708 37
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1252 0 1.09706513192818 2.04656324156928
+2 1995 473 103 1.09706513192818 2.04656324156928
+2 1996 473 105 1.09706513192818 2.04656324156928
+0
+0101000
++1216 0 -1219 0 *
+Ve
+1e-07
+3.53562548643103 -6.89651016237193 37
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1253 0 4.5 7.75
+0
+0101000
++1216 0 -1214 0 *
+Ed
+ 1e-07 1 1 0
+1 1254 0 1.09706513192818 2.04656324156928
+2 1997 474 103 1.09706513192818 2.04656324156928
+2 1998 474 105 1.09706513192818 2.04656324156928
+0
+0101000
++1214 0 -1218 0 *
+Wi
+0101100
+-1217 0 -1215 0 +1213 0 +1212 0 *
+Wi
+0101100
+-2566 0 -2561 0 -2555 0 -2552 0 *
+Fa
+0 1e-07 410 0
+0101000
+-1211 0 +1210 103 *
+Ve
+1e-07
+0.583333333333333 0 6.875
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1255 0 0 0.583333333333333
+3 1999 2000CN 412 0 0 0.583333333333333
+0
+0101000
+-2547 0 +1208 0 *
+Ed
+ 1e-07 1 1 0
+1 1256 0 0 6.28318530717959
+2 2001 412 0 0 6.28318530717959
+2 2002 475 0 0 6.28318530717959
+0
+0101100
++1208 0 -1208 0 *
+Wi
+0101100
++1207 0 -2546 0 +1206 0 -1207 0 *
+Fa
+0 1e-07 412 0
+0101000
++1205 0 *
+Ve
+1e-07
+2.91666666666667 0 2.375
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1257 0 0 0.583333333333334
+3 2003 2004CN 413 0 0 0.583333333333334
+0
+0101000
+-2544 0 +1203 0 *
+Ed
+ 1e-07 1 1 0
+1 1258 0 0 6.28318530717959
+2 2005 413 0 0 6.28318530717959
+2 2006 476 0 0 6.28318530717959
+0
+0101100
++1203 0 -1203 0 *
+Wi
+0101100
++1202 0 -2543 0 +1201 0 -1202 0 *
+Fa
+0 1e-07 413 0
+0101000
++1200 0 *
+Wi
+0101100
++2498 0 +2182 0 -2508 0 -2536 0 *
+Fa
+0 1e-07 414 0
+0101000
++1198 0 *
+Ve
+1e-07
+8.5 0 -3
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1259 0 0 3
+3 2007 2008CN 415 0 0 3
+0
+0101000
+-1196 0 +2532 0 *
+Ed
+ 1e-07 1 1 0
+1 1260 0 0 6.28318530717959
+2 2009 477 0 0 6.28318530717959
+2 2010 415 0 0 6.28318530717959
+4 C0 477 0 415 0
+0
+0101100
++1196 0 -1196 0 *
+Wi
+0101100
++1195 0 +1194 0 -2531 0 -1195 0 *
+Fa
+0 1e-07 415 0
+0101000
++1193 0 *
+Wi
+0101100
++2519 0 +2185 0 -2514 0 -2504 0 *
+Fa
+0 1e-07 414 0
+0101000
++1191 0 *
+Wi
+0101100
++2484 0 +2179 0 -2472 0 -2462 0 *
+Fa
+0 1e-07 414 0
+0101000
++1189 0 *
+Wi
+0101100
++2456 0 +2176 0 -2466 0 -2477 0 *
+Fa
+0 1e-07 414 0
+0101000
++1187 0 *
+Ve
+1e-07
+5 20 30.9196109771729
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1261 0 11.9222527892982 13
+0
+0101000
++2448 0 -1185 108 *
+Ve
+1e-07
+5 20 29.1047172546387
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1262 0 0 1.81489372253418
+0
+0101000
++1185 0 -1183 0 *
+Ed
+ 1e-07 1 1 0
+1 1263 0 11.9222527892982 13
+0
+0101000
++2449 0 -1183 108 *
+Wi
+0101100
++1184 0 +2447 0 +1182 108 -1181 0 *
+Fa
+0 1e-07 416 0
+0101000
++1180 0 *
+Ve
+1e-07
+-5 20 29.1047172546387
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1264 0 -3.18325662612915 6.81674337387085
+0
+0101000
++1183 0 -1178 0 *
+Ed
+ 1e-07 1 1 0
+1 1265 0 11.9222527892982 13
+0
+0101000
++2446 0 -1178 108 *
+Wi
+0101100
++1181 0 -2445 0 +1177 108 -1176 0 *
+Fa
+0 1e-07 417 0
+0101000
++1175 0 *
+Ve
+1e-07
+-5 20 30.9196109771729
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1266 0 11.9222527892982 13
+0
+0101000
++2444 0 -1173 108 *
+Ed
+ 1e-07 1 1 0
+1 1267 0 -2.79093217849731 7.20906782150269
+0
+0101000
++1173 0 -1185 0 *
+Wi
+0101100
++1172 0 +2443 0 +1171 108 -1184 0 *
+Fa
+0 1e-07 418 0
+0101000
++1170 0 *
+Ed
+ 1e-07 1 1 0
+1 1268 0 0 1.81489372253418
+0
+0101000
++1178 0 -1173 0 *
+Wi
+0101100
++1176 0 -2442 0 +1168 108 -1172 0 *
+Fa
+0 1e-07 419 0
+0101000
++1167 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1269 0 11.9222527892982 13
+0
+0101000
++2436 0 -1165 109 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1270 0 0 1.81489372253418
+0
+0101000
++1165 0 -1163 0 *
+Ed
+ 1e-07 1 1 0
+1 1271 0 11.9222527892982 13
+0
+0101000
++2437 0 -1163 109 *
+Wi
+0101100
++1164 0 +2435 0 +1162 109 -1161 0 *
+Fa
+0 1e-07 420 0
+0101000
++1160 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1272 0 -3.18325662612915 6.81674337387085
+0
+0101000
++1163 0 -1158 0 *
+Ed
+ 1e-07 1 1 0
+1 1273 0 11.9222527892982 13
+0
+0101000
++2434 0 -1158 109 *
+Wi
+0101100
++1161 0 -2433 0 +1157 109 -1156 0 *
+Fa
+0 1e-07 421 0
+0101000
++1155 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1274 0 11.9222527892982 13
+0
+0101000
++2432 0 -1153 109 *
+Ed
+ 1e-07 1 1 0
+1 1275 0 -2.79093217849731 7.20906782150269
+0
+0101000
++1153 0 -1165 0 *
+Wi
+0101100
++1152 0 +2431 0 +1151 109 -1164 0 *
+Fa
+0 1e-07 422 0
+0101000
++1150 0 *
+Ed
+ 1e-07 1 1 0
+1 1276 0 0 1.81489372253418
+0
+0101000
++1158 0 -1153 0 *
+Wi
+0101100
++1156 0 -2430 0 +1148 109 -1152 0 *
+Fa
+0 1e-07 423 0
+0101000
++1147 0 *
+Wi
+0101100
++2424 0 +2173 0 -2412 0 -2402 0 *
+Fa
+0 1e-07 414 0
+0101000
++1145 0 *
+Wi
+0101100
++2396 0 +2170 0 -2406 0 -2417 0 *
+Fa
+0 1e-07 414 0
+0101000
++1143 0 *
+Wi
+0101100
++2382 0 +2167 0 -2370 0 -2360 0 *
+Fa
+0 1e-07 414 0
+0101000
++1141 0 *
+Wi
+0101100
++2354 0 +2164 0 -2364 0 -2375 0 *
+Fa
+0 1e-07 414 0
+0101000
++1139 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1277 0 11.9222527892982 13
+0
+0101000
++2346 0 -1137 112 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1278 0 0 1.81489372253418
+0
+0101000
++1137 0 -1135 0 *
+Ed
+ 1e-07 1 1 0
+1 1279 0 11.9222527892982 13
+0
+0101000
++2347 0 -1135 112 *
+Wi
+0101100
++1136 0 +2345 0 +1134 112 -1133 0 *
+Fa
+0 1e-07 424 0
+0101000
++1132 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1280 0 -3.18325662612915 6.81674337387085
+0
+0101000
++1135 0 -1130 0 *
+Ed
+ 1e-07 1 1 0
+1 1281 0 11.9222527892982 13
+0
+0101000
++2344 0 -1130 112 *
+Wi
+0101100
++1133 0 -2343 0 +1129 112 -1128 0 *
+Fa
+0 1e-07 425 0
+0101000
++1127 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1282 0 11.9222527892982 13
+0
+0101000
++2342 0 -1125 112 *
+Ed
+ 1e-07 1 1 0
+1 1283 0 -2.79093217849731 7.20906782150269
+0
+0101000
++1125 0 -1137 0 *
+Wi
+0101100
++1124 0 +2341 0 +1123 112 -1136 0 *
+Fa
+0 1e-07 426 0
+0101000
++1122 0 *
+Ed
+ 1e-07 1 1 0
+1 1284 0 0 1.81489372253418
+0
+0101000
++1130 0 -1125 0 *
+Wi
+0101100
++1128 0 -2340 0 +1120 112 -1124 0 *
+Fa
+0 1e-07 427 0
+0101000
++1119 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1285 0 11.9222527892982 13
+0
+0101000
++2334 0 -1117 115 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1286 0 0 1.81489372253418
+0
+0101000
++1117 0 -1115 0 *
+Ed
+ 1e-07 1 1 0
+1 1287 0 11.9222527892982 13
+0
+0101000
++2335 0 -1115 115 *
+Wi
+0101100
++1116 0 +2333 0 +1114 115 -1113 0 *
+Fa
+0 1e-07 428 0
+0101000
++1112 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1288 0 -3.18325662612915 6.81674337387085
+0
+0101000
++1115 0 -1110 0 *
+Ed
+ 1e-07 1 1 0
+1 1289 0 11.9222527892982 13
+0
+0101000
++2332 0 -1110 115 *
+Wi
+0101100
++1113 0 -2331 0 +1109 115 -1108 0 *
+Fa
+0 1e-07 429 0
+0101000
++1107 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1290 0 11.9222527892982 13
+0
+0101000
++2330 0 -1105 115 *
+Ed
+ 1e-07 1 1 0
+1 1291 0 -2.79093217849731 7.20906782150269
+0
+0101000
++1105 0 -1117 0 *
+Wi
+0101100
++1104 0 +2329 0 +1103 115 -1116 0 *
+Fa
+0 1e-07 430 0
+0101000
++1102 0 *
+Ed
+ 1e-07 1 1 0
+1 1292 0 0 1.81489372253418
+0
+0101000
++1110 0 -1105 0 *
+Wi
+0101100
++1108 0 -2328 0 +1100 115 -1104 0 *
+Fa
+0 1e-07 431 0
+0101000
++1099 0 *
+Wi
+0101100
++2322 0 +2161 0 -2310 0 -2300 0 *
+Fa
+0 1e-07 414 0
+0101000
++1097 0 *
+Wi
+0101100
++2294 0 +2158 0 -2304 0 -2315 0 *
+Fa
+0 1e-07 414 0
+0101000
++1095 0 *
+Wi
+0101100
++2280 0 +2155 0 -2268 0 -2258 0 *
+Fa
+0 1e-07 414 0
+0101000
++1093 0 *
+Wi
+0101100
++2252 0 +2152 0 -2262 0 -2273 0 *
+Fa
+0 1e-07 414 0
+0101000
++1091 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1293 0 11.9222527892982 13
+0
+0101000
++2244 0 -1089 118 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1294 0 0 1.81489372253418
+0
+0101000
++1089 0 -1087 0 *
+Ed
+ 1e-07 1 1 0
+1 1295 0 11.9222527892982 13
+0
+0101000
++2245 0 -1087 118 *
+Wi
+0101100
++1088 0 +2243 0 +1086 118 -1085 0 *
+Fa
+0 1e-07 432 0
+0101000
++1084 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1296 0 -3.18325662612915 6.81674337387085
+0
+0101000
++1087 0 -1082 0 *
+Ed
+ 1e-07 1 1 0
+1 1297 0 11.9222527892982 13
+0
+0101000
++2242 0 -1082 118 *
+Wi
+0101100
++1085 0 -2241 0 +1081 118 -1080 0 *
+Fa
+0 1e-07 433 0
+0101000
++1079 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1298 0 11.9222527892982 13
+0
+0101000
++2240 0 -1077 118 *
+Ed
+ 1e-07 1 1 0
+1 1299 0 -2.79093217849731 7.20906782150269
+0
+0101000
++1077 0 -1089 0 *
+Wi
+0101100
++1076 0 +2239 0 +1075 118 -1088 0 *
+Fa
+0 1e-07 434 0
+0101000
++1074 0 *
+Ed
+ 1e-07 1 1 0
+1 1300 0 0 1.81489372253418
+0
+0101000
++1082 0 -1077 0 *
+Wi
+0101100
++1080 0 -2238 0 +1072 118 -1076 0 *
+Fa
+0 1e-07 435 0
+0101000
++1071 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1301 0 11.9222527892982 13
+0
+0101000
++2232 0 -1069 121 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1302 0 0 1.81489372253418
+0
+0101000
++1069 0 -1067 0 *
+Ed
+ 1e-07 1 1 0
+1 1303 0 11.9222527892982 13
+0
+0101000
++2233 0 -1067 121 *
+Wi
+0101100
++1068 0 +2231 0 +1066 121 -1065 0 *
+Fa
+0 1e-07 436 0
+0101000
++1064 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1304 0 -3.18325662612915 6.81674337387085
+0
+0101000
++1067 0 -1062 0 *
+Ed
+ 1e-07 1 1 0
+1 1305 0 11.9222527892982 13
+0
+0101000
++2230 0 -1062 121 *
+Wi
+0101100
++1065 0 -2229 0 +1061 121 -1060 0 *
+Fa
+0 1e-07 437 0
+0101000
++1059 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1306 0 11.9222527892982 13
+0
+0101000
++2228 0 -1057 121 *
+Ed
+ 1e-07 1 1 0
+1 1307 0 -2.79093217849731 7.20906782150269
+0
+0101000
++1057 0 -1069 0 *
+Wi
+0101100
++1056 0 +2227 0 +1055 121 -1068 0 *
+Fa
+0 1e-07 438 0
+0101000
++1054 0 *
+Ed
+ 1e-07 1 1 0
+1 1308 0 0 1.81489372253418
+0
+0101000
++1062 0 -1057 0 *
+Wi
+0101100
++1060 0 -2226 0 +1052 121 -1056 0 *
+Fa
+0 1e-07 439 0
+0101000
++1051 0 *
+Wi
+0101100
++2220 0 +2149 0 -2208 0 -2198 0 *
+Fa
+0 1e-07 414 0
+0101000
++1049 0 *
+Wi
+0101100
++2192 0 +2146 0 -2202 0 -2213 0 *
+Fa
+0 1e-07 414 0
+0101000
++1047 0 *
+Wi
+0101100
+-2140 0 -2134 0 +2125 0 +2115 0 -2104 0 +2095 0 -2084 0 -2074 0 +2065 0 -2054 0
+-2044 0 +2035 0 -2024 0 -2014 0 +2005 0 -1994 0 -1984 0 +1975 0 -1964 0 -1954 0
++1945 0 -1934 0 -1924 0 +1915 0 -1904 0 +1895 0 +1886 0 +1889 0 +1899 0 +1909 0
++1919 0 +1929 0 +1939 0 +1949 0 +1959 0 +1969 0 +1979 0 +1989 0 +1999 0 +2009 0
++2019 0 +2029 0 +2039 0 +2049 0 +2059 0 +2069 0 +2079 0 -2090 0 +2099 0 +2109 0
++2119 0 +2129 0 *
+Fa
+0 1e-07 478 0
+0101000
++1045 0 *
+Wi
+0101100
+-1880 0 -1869 0 +1860 0 +1850 0 -1839 0 +1830 0 -1819 0 -1809 0 +1800 0 -1789 0
+-1779 0 +1770 0 -1759 0 -1749 0 +1740 0 -1729 0 -1719 0 +1710 0 -1699 0 -1689 0
++1680 0 -1669 0 -1659 0 +1650 0 -1639 0 +1630 0 +1626 0 +1634 0 +1644 0 +1654 0
++1664 0 +1674 0 +1684 0 +1694 0 +1704 0 +1714 0 +1724 0 +1734 0 +1744 0 +1754 0
++1764 0 +1774 0 +1784 0 +1794 0 +1804 0 +1814 0 +1824 0 -1835 0 +1844 0 +1854 0
++1864 0 +1874 0 *
+Fa
+0 1e-07 479 0
+0101000
++1043 0 *
+Wi
+0101100
++1617 0 +1276 0 -1605 0 -1594 0 *
+Fa
+0 1e-07 440 0
+0101000
++1041 0 *
+Wi
+0101100
++1588 0 +1273 0 -1599 0 -1610 0 *
+Fa
+0 1e-07 440 0
+0101000
++1039 0 *
+Wi
+0101100
++1575 0 +1270 0 -1563 0 -1552 0 *
+Fa
+0 1e-07 440 0
+0101000
++1037 0 *
+Wi
+0101100
++1546 0 +1267 0 -1557 0 -1568 0 *
+Fa
+0 1e-07 440 0
+0101000
++1035 0 *
+Ve
+1e-07
+5 -20 30.9170551300049
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1309 0 11.9222527892982 13
+0
+0101000
++1541 0 -1033 126 *
+Ve
+1e-07
+5 -20 29.0504970550537
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1310 0 0 1.86655807495117
+0
+0101000
++1033 0 -1031 0 *
+Ed
+ 1e-07 1 1 0
+1 1311 0 11.9222527892982 13
+0
+0101000
++1542 0 -1031 126 *
+Wi
+0101100
++1032 0 +1540 0 +1030 126 -1029 0 *
+Fa
+0 1e-07 441 0
+0101000
++1028 0 *
+Ve
+1e-07
+-5 -20 29.0504970550537
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1312 0 -1.62429714202881 8.37570285797119
+0
+0101000
++1031 0 -1026 0 *
+Ed
+ 1e-07 1 1 0
+1 1313 0 11.9222527892982 13
+0
+0101000
++1539 0 -1026 126 *
+Wi
+0101100
++1029 0 +1538 0 +1025 126 -1024 0 *
+Fa
+0 1e-07 442 0
+0101000
++1023 0 *
+Ve
+1e-07
+-5 -20 30.9170551300049
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1314 0 11.9222527892982 13
+0
+0101000
++1537 0 -1021 126 *
+Ed
+ 1e-07 1 1 0
+1 1315 0 -2.07959651947021 7.92040348052979
+0
+0101000
++1021 0 -1033 0 *
+Wi
+0101100
++1020 0 -1536 0 +1019 126 -1032 0 *
+Fa
+0 1e-07 443 0
+0101000
++1018 0 *
+Ed
+ 1e-07 1 1 0
+1 1316 0 0 1.86655807495117
+0
+0101000
++1026 0 -1021 0 *
+Wi
+0101100
++1024 0 -1535 0 +1016 126 -1020 0 *
+Fa
+0 1e-07 444 0
+0101000
++1015 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1317 0 11.9222527892982 13
+0
+0101000
++1529 0 -1013 127 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1318 0 0 1.86655807495117
+0
+0101000
++1013 0 -1011 0 *
+Ed
+ 1e-07 1 1 0
+1 1319 0 11.9222527892982 13
+0
+0101000
++1530 0 -1011 127 *
+Wi
+0101100
++1012 0 +1528 0 +1010 127 -1009 0 *
+Fa
+0 1e-07 445 0
+0101000
++1008 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1320 0 -1.62429714202881 8.37570285797119
+0
+0101000
++1011 0 -1006 0 *
+Ed
+ 1e-07 1 1 0
+1 1321 0 11.9222527892982 13
+0
+0101000
++1527 0 -1006 127 *
+Wi
+0101100
++1009 0 +1526 0 +1005 127 -1004 0 *
+Fa
+0 1e-07 446 0
+0101000
++1003 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1322 0 11.9222527892982 13
+0
+0101000
++1525 0 -1001 127 *
+Ed
+ 1e-07 1 1 0
+1 1323 0 -2.07959651947021 7.92040348052979
+0
+0101000
++1001 0 -1013 0 *
+Wi
+0101100
++1000 0 -1524 0 +999 127 -1012 0 *
+Fa
+0 1e-07 447 0
+0101000
++998 0 *
+Ed
+ 1e-07 1 1 0
+1 1324 0 0 1.86655807495117
+0
+0101000
++1006 0 -1001 0 *
+Wi
+0101100
++1004 0 -1523 0 +996 127 -1000 0 *
+Fa
+0 1e-07 448 0
+0101000
++995 0 *
+Wi
+0101100
++1515 0 +1264 0 -1503 0 -1492 0 *
+Fa
+0 1e-07 440 0
+0101000
++993 0 *
+Wi
+0101100
++1486 0 +1261 0 -1497 0 -1508 0 *
+Fa
+0 1e-07 440 0
+0101000
++991 0 *
+Wi
+0101100
++1473 0 +1258 0 -1461 0 -1450 0 *
+Fa
+0 1e-07 440 0
+0101000
++989 0 *
+Wi
+0101100
++1444 0 +1255 0 -1455 0 -1466 0 *
+Fa
+0 1e-07 440 0
+0101000
++987 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1325 0 11.9222527892982 13
+0
+0101000
++1439 0 -985 130 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1326 0 0 1.86655807495117
+0
+0101000
++985 0 -983 0 *
+Ed
+ 1e-07 1 1 0
+1 1327 0 11.9222527892982 13
+0
+0101000
++1440 0 -983 130 *
+Wi
+0101100
++984 0 +1438 0 +982 130 -981 0 *
+Fa
+0 1e-07 449 0
+0101000
++980 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1328 0 -1.62429714202881 8.37570285797119
+0
+0101000
++983 0 -978 0 *
+Ed
+ 1e-07 1 1 0
+1 1329 0 11.9222527892982 13
+0
+0101000
++1437 0 -978 130 *
+Wi
+0101100
++981 0 +1436 0 +977 130 -976 0 *
+Fa
+0 1e-07 450 0
+0101000
++975 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1330 0 11.9222527892982 13
+0
+0101000
++1435 0 -973 130 *
+Ed
+ 1e-07 1 1 0
+1 1331 0 -2.07959651947021 7.92040348052979
+0
+0101000
++973 0 -985 0 *
+Wi
+0101100
++972 0 -1434 0 +971 130 -984 0 *
+Fa
+0 1e-07 451 0
+0101000
++970 0 *
+Ed
+ 1e-07 1 1 0
+1 1332 0 0 1.86655807495117
+0
+0101000
++978 0 -973 0 *
+Wi
+0101100
++976 0 -1433 0 +968 130 -972 0 *
+Fa
+0 1e-07 452 0
+0101000
++967 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1333 0 11.9222527892982 13
+0
+0101000
++1427 0 -965 133 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1334 0 0 1.86655807495117
+0
+0101000
++965 0 -963 0 *
+Ed
+ 1e-07 1 1 0
+1 1335 0 11.9222527892982 13
+0
+0101000
++1428 0 -963 133 *
+Wi
+0101100
++964 0 +1426 0 +962 133 -961 0 *
+Fa
+0 1e-07 453 0
+0101000
++960 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1336 0 -1.62429714202881 8.37570285797119
+0
+0101000
++963 0 -958 0 *
+Ed
+ 1e-07 1 1 0
+1 1337 0 11.9222527892982 13
+0
+0101000
++1425 0 -958 133 *
+Wi
+0101100
++961 0 +1424 0 +957 133 -956 0 *
+Fa
+0 1e-07 454 0
+0101000
++955 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1338 0 11.9222527892982 13
+0
+0101000
++1423 0 -953 133 *
+Ed
+ 1e-07 1 1 0
+1 1339 0 -2.07959651947021 7.92040348052979
+0
+0101000
++953 0 -965 0 *
+Wi
+0101100
++952 0 -1422 0 +951 133 -964 0 *
+Fa
+0 1e-07 455 0
+0101000
++950 0 *
+Ed
+ 1e-07 1 1 0
+1 1340 0 0 1.86655807495117
+0
+0101000
++958 0 -953 0 *
+Wi
+0101100
++956 0 -1421 0 +948 133 -952 0 *
+Fa
+0 1e-07 456 0
+0101000
++947 0 *
+Wi
+0101100
++1413 0 +1252 0 -1401 0 -1390 0 *
+Fa
+0 1e-07 440 0
+0101000
++945 0 *
+Wi
+0101100
++1384 0 +1249 0 -1395 0 -1406 0 *
+Fa
+0 1e-07 440 0
+0101000
++943 0 *
+Wi
+0101100
++1371 0 +1246 0 -1359 0 -1348 0 *
+Fa
+0 1e-07 440 0
+0101000
++941 0 *
+Wi
+0101100
++1342 0 +1243 0 -1353 0 -1364 0 *
+Fa
+0 1e-07 440 0
+0101000
++939 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1341 0 11.9222527892982 13
+0
+0101000
++1337 0 -937 136 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1342 0 0 1.86655807495117
+0
+0101000
++937 0 -935 0 *
+Ed
+ 1e-07 1 1 0
+1 1343 0 11.9222527892982 13
+0
+0101000
++1338 0 -935 136 *
+Wi
+0101100
++936 0 +1336 0 +934 136 -933 0 *
+Fa
+0 1e-07 457 0
+0101000
++932 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1344 0 -1.62429714202881 8.37570285797119
+0
+0101000
++935 0 -930 0 *
+Ed
+ 1e-07 1 1 0
+1 1345 0 11.9222527892982 13
+0
+0101000
++1335 0 -930 136 *
+Wi
+0101100
++933 0 +1334 0 +929 136 -928 0 *
+Fa
+0 1e-07 458 0
+0101000
++927 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1346 0 11.9222527892982 13
+0
+0101000
++1333 0 -925 136 *
+Ed
+ 1e-07 1 1 0
+1 1347 0 -2.07959651947021 7.92040348052979
+0
+0101000
++925 0 -937 0 *
+Wi
+0101100
++924 0 -1332 0 +923 136 -936 0 *
+Fa
+0 1e-07 459 0
+0101000
++922 0 *
+Ed
+ 1e-07 1 1 0
+1 1348 0 0 1.86655807495117
+0
+0101000
++930 0 -925 0 *
+Wi
+0101100
++928 0 -1331 0 +920 136 -924 0 *
+Fa
+0 1e-07 460 0
+0101000
++919 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1349 0 11.9222527892982 13
+0
+0101000
++1325 0 -917 139 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1350 0 0 1.86655807495117
+0
+0101000
++917 0 -915 0 *
+Ed
+ 1e-07 1 1 0
+1 1351 0 11.9222527892982 13
+0
+0101000
++1326 0 -915 139 *
+Wi
+0101100
++916 0 +1324 0 +914 139 -913 0 *
+Fa
+0 1e-07 461 0
+0101000
++912 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1352 0 -1.62429714202881 8.37570285797119
+0
+0101000
++915 0 -910 0 *
+Ed
+ 1e-07 1 1 0
+1 1353 0 11.9222527892982 13
+0
+0101000
++1323 0 -910 139 *
+Wi
+0101100
++913 0 +1322 0 +909 139 -908 0 *
+Fa
+0 1e-07 462 0
+0101000
++907 0 *
+Ve
+1e-07
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1354 0 11.9222527892982 13
+0
+0101000
++1321 0 -905 139 *
+Ed
+ 1e-07 1 1 0
+1 1355 0 -2.07959651947021 7.92040348052979
+0
+0101000
++905 0 -917 0 *
+Wi
+0101100
++904 0 -1320 0 +903 139 -916 0 *
+Fa
+0 1e-07 463 0
+0101000
++902 0 *
+Ed
+ 1e-07 1 1 0
+1 1356 0 0 1.86655807495117
+0
+0101000
++910 0 -905 0 *
+Wi
+0101100
++908 0 -1319 0 +900 139 -904 0 *
+Fa
+0 1e-07 464 0
+0101000
++899 0 *
+Wi
+0101100
++1311 0 +1240 0 -1299 0 -1288 0 *
+Fa
+0 1e-07 440 0
+0101000
++897 0 *
+Wi
+0101100
++1282 0 +1237 0 -1293 0 -1304 0 *
+Fa
+0 1e-07 440 0
+0101000
++895 0 *
+Ed
+ 1e-07 1 1 0
+1 1357 0 0 2
+2 2011 469 0 0 2
+0
+0101000
++1230 73 -1230 140 *
+Ed
+ 1e-07 1 1 0
+1 1358 0 0 2
+2 2012 472 0 0 2
+0
+0101000
++1229 73 -1229 140 *
+Wi
+0101000
++893 0 -892 0 -1228 73 +1228 140 *
+Fa
+0 1e-07 480 0
+0101000
++891 0 *
+Ed
+ 1e-07 1 1 0
+1 1359 0 0 2
+2 2013 469 0 0 2
+0
+0101000
++1227 73 -1227 140 *
+Wi
+0101000
++889 0 -893 0 -1226 73 +1226 140 *
+Fa
+0 1e-07 469 0
+0101000
++888 0 *
+Ed
+ 1e-07 1 1 0
+1 1360 0 0 2
+2 2014 472 0 0 2
+0
+0101000
++1225 73 -1225 140 *
+Wi
+0101000
++889 0 -886 0 -1224 73 +1224 140 *
+Fa
+0 1e-07 481 0
+0101000
++885 0 *
+Wi
+0101000
++886 0 -892 0 -1223 73 +1223 140 *
+Fa
+0 1e-07 472 0
+0101000
++883 0 *
+Ed
+ 1e-07 1 1 0
+1 1361 0 0 2
+2 2015 473 0 0 2
+0
+0101000
++1219 74 -1219 141 *
+Ed
+ 1e-07 1 1 0
+1 1362 0 0 2
+2 2016 474 0 0 2
+0
+0101000
++1218 74 -1218 141 *
+Wi
+0101000
++881 0 -880 0 -1217 74 +1217 141 *
+Fa
+0 1e-07 482 0
+0101000
++879 0 *
+Ed
+ 1e-07 1 1 0
+1 1363 0 0 2
+2 2017 473 0 0 2
+0
+0101000
++1216 74 -1216 141 *
+Wi
+0101000
++877 0 -881 0 -1215 74 +1215 141 *
+Fa
+0 1e-07 473 0
+0101000
++876 0 *
+Ed
+ 1e-07 1 1 0
+1 1364 0 0 2
+2 2018 474 0 0 2
+0
+0101000
++1214 74 -1214 141 *
+Wi
+0101000
++877 0 -874 0 -1213 74 +1213 141 *
+Fa
+0 1e-07 483 0
+0101000
++873 0 *
+Wi
+0101000
++874 0 -880 0 -1212 74 +1212 141 *
+Fa
+0 1e-07 474 0
+0101000
++871 0 *
+Wi
+0101000
+-1206 0 *
+Ve
+2.25120000016e-06
+1.5 -1.16564123347968e-14 -2.16666666666667
+0 0
+0101101
+Ed
+ 7.44760245974182e-16 1 1 0
+1 1365 0 1.5707963267949 7.85398163397448
+2 2019 475 37 1.5707963267949 7.85398163397448
+2 2020 49 42 1.5707963267949 7.85398163397448
+0
+0101100
++868 0 -868 0 *
+Wi
+0101100
+-867 0 *
+Fa
+0 1e-07 475 0
+0101000
+-869 0 +866 38 *
+Wi
+0101000
+-1201 0 *
+Ve
+4.81612207651293e-07
+14.969615518138 -0.347296286634443 -2.16666666666667
+0 0
+0101101
+Ed
+1 1366 0 2.96705976326997 9.25024507044956
+2 2021 484 75 2.96705976326997 9.25024507044956
+2 2022 476 62 2.96705976326997 9.25024507044956
+0
+0101100
++863 0 -863 0 *
+Wi
+0101100
++862 0 *
+Fa
+0 1e-07 476 0
+0101000
+-864 0 +861 142 *
+Ve
+1e-07
+8 0 -3.5
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1367 0 0 0.707106781186548
+3 2023 2024C0 477 0 0 0.707106781186548
+0
+0101000
++1196 0 -859 0 *
+Ed
+ 1e-07 1 1 0
+1 1368 0 0 6.28318530717959
+2 2025 477 0 0 6.28318530717959
+2 2026 51 78 0 6.28318530717959
+4 C0 477 0 51 78
+0
+0101100
++859 0 -859 0 *
+Wi
+0101100
+-858 0 +1194 0 -857 0 +858 0 *
+Fa
+0 0 477 0
+0101000
++856 0 *
+Wi
+0101000
++1182 0 +1177 0 +1168 0 +1171 0 *
+Fa
+0 1e-07 485 0
+0101000
+-854 106 *
+Wi
+0101000
++1162 0 +1157 0 +1148 0 +1151 0 *
+Fa
+0 1e-07 485 0
+0101000
+-852 0 *
+Wi
+0101000
++1134 0 +1129 0 +1120 0 +1123 0 *
+Fa
+0 1e-07 485 0
+0101000
+-850 110 *
+Wi
+0101000
++1114 0 +1109 0 +1100 0 +1103 0 *
+Fa
+0 1e-07 485 0
+0101000
+-848 113 *
+Wi
+0101000
++1086 0 +1081 0 +1072 0 +1075 0 *
+Fa
+0 1e-07 485 0
+0101000
+-846 116 *
+Wi
+0101000
++1066 0 +1061 0 +1052 0 +1055 0 *
+Fa
+0 1e-07 485 0
+0101000
+-844 119 *
+Wi
+0101000
++1030 0 +1025 0 +1016 0 +1019 0 *
+Fa
+0 1e-07 486 0
+0101000
+-842 124 *
+Wi
+0101000
++1010 0 +1005 0 +996 0 +999 0 *
+Fa
+0 1e-07 486 0
+0101000
+-840 0 *
+Wi
+0101000
++982 0 +977 0 +968 0 +971 0 *
+Fa
+0 1e-07 486 0
+0101000
+-838 128 *
+Wi
+0101000
++962 0 +957 0 +948 0 +951 0 *
+Fa
+0 1e-07 486 0
+0101000
+-836 131 *
+Wi
+0101000
++934 0 +929 0 +920 0 +923 0 *
+Fa
+0 1e-07 486 0
+0101000
+-834 134 *
+Wi
+0101000
++914 0 +909 0 +900 0 +903 0 *
+Fa
+0 1e-07 486 0
+0101000
+-832 137 *
+Fa
+0 1e-07 409 0
+0101000
++1222 0 *
+Fa
+0 1e-07 410 0
+0101000
+-1211 0 *
+Ve
+1e-07
+1.5 0 56
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 73 0 0.5 1.83333333333333
+3 113 114CN 49 0 0.5 1.83333333333333
+0
+0101000
+-868 44 +828 0 *
+Ed
+ 1e-07 1 1 0
+1 1369 0 0 6.28318530717959
+2 2027 487 0 0 6.28318530717959
+2 2028 49 0 0 6.28318530717959
+4 C0 487 0 49 0
+0
+0101100
++828 0 -828 0 *
+Wi
+0101100
++827 42 +867 0 -826 42 -827 42 *
+Fa
+0 1e-07 49 0
+0101000
++825 44 *
+Ve
+1.38840931085035e-06
+14.969615518138 -0.347296286634443 -3.83333333333333
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1370 0 2.33333333333334 4
+3 2029 2030CN 484 0 2.33333333333334 4
+0
+0101000
++863 157 -823 157 *
+Ed
+1 1371 0 2.96705976326997 9.25024507044956
+2 2031 488 166 2.96705976326997 9.25024507044956
+2 2032 484 75 2.96705976326997 9.25024507044956
+0
+0101100
++823 0 -823 0 *
+Wi
+0101100
++822 75 -862 0 +821 0 -822 75 *
+Fa
+0 1e-07 484 0
+0101000
++820 157 *
+Wi
+0101100
++857 0 *
+Ve
+6.40000002e-06
+1.5 0 -3.5
+0 0
+0101101
+Ed
+ 0 1 1 0
+1 1372 0 1.5707963267949 7.85398163397448
+2 2033 51 78 1.5707963267949 7.85398163397448
+2 2034 49 0 1.5707963267949 7.85398163397448
+0
+0101100
++817 0 -817 0 *
+Wi
+0101100
+-816 0 *
+Fa
+0 1e-07 51 0
+0101000
++818 79 +815 79 *
+Ve
+1e-07
+1 0 56.5
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1373 0 0 0.707106781186548
+3 2035 2036C0 487 0 0 0.707106781186548
+0
+0101000
++828 0 -813 0 *
+Ed
+ 1e-07 1 1 0
+1 1374 0 0 6.28318530717959
+2 2037 487 0 0 6.28318530717959
+2 2038 489 168 0 6.28318530717959
+4 C0 487 0 489 168
+0
+0101100
++813 0 -813 0 *
+Wi
+0101100
+-812 0 +826 0 -811 0 +812 0 *
+Fa
+0 0 487 0
+0101000
++810 0 *
+Ve
+1e-07
+2.91666666666667 0 6.875
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1375 0 0 6.28318530717959
+2 2039 490 0 0 6.28318530717959
+2 2040 488 0 0 6.28318530717959
+0
+0101100
++808 0 -808 0 *
+Wi
+0101000
+-807 0 *
+Wi
+0101100
+-821 0 *
+Fa
+0 1e-07 488 0
+0101000
+-806 0 +805 169 *
+Ve
+1e-07
+1.5 0 -7
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 73 0 60 63.5
+3 113 114CN 49 0 60 63.5
+0
+0101000
+-803 0 +817 0 *
+Ed
+ 1e-07 1 1 0
+1 1376 0 0 6.28318530717959
+2 2041 491 0 0 6.28318530717959
+2 2042 49 0 0 6.28318530717959
+4 C0 491 0 49 0
+0
+0101100
++803 0 -803 0 *
+Wi
+0101100
++802 0 +801 0 -816 0 -802 0 *
+Fa
+0 1e-07 49 0
+0101000
++800 0 *
+Wi
+0101100
++811 0 *
+Fa
+0 1e-07 489 0
+0101000
++798 171 *
+Ve
+1.92823335063125e-06
+3.5 0 6.875
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1377 0 0 0.583333333333334
+3 2043 2044CN 490 0 0 0.583333333333334
+0
+0101000
+-796 0 +808 0 *
+Ed
+ 6.87499999999939e-08 1 1 0
+1 1378 0 0 6.28318530717959
+2 2045 492 172 0 6.28318530717959
+2 2046 490 0 0 6.28318530717959
+0
+0101100
++796 0 -796 0 *
+Wi
+0101100
++795 0 -794 0 +807 0 -795 0 *
+Fa
+0 1e-07 490 0
+0101000
++793 0 *
+Ve
+1e-07
+1 0 -7.5
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1379 0 0 0.707106781186548
+3 2047 2048C0 491 0 0 0.707106781186548
+0
+0101000
++803 0 -791 0 *
+Ed
+ 1e-07 1 1 0
+1 1380 0 0 6.28318530717959
+2 2049 491 0 0 6.28318530717959
+2 2050 489 174 0 6.28318530717959
+4 C0 491 0 489 174
+0
+0101100
++791 0 -791 0 *
+Wi
+0101100
+-790 0 +801 0 -789 0 +790 0 *
+Fa
+0 0 491 0
+0101000
++788 0 *
+Ve
+5.48233350631248e-07
+0 0 1.125
+0 0
+0101101
+Ed
+ 1.1249999999963e-08 1 1 0
+1 1381 0 3.14159265358979 9.42477796076938
+2 2051 493 0 3.14159265358979 9.42477796076938
+2 2052 494 0 3.14159265358979 9.42477796076938
+0
+0101100
++786 0 -786 0 *
+Wi
+0101100
++785 0 *
+Wi
+0101100
+-794 0 *
+Ve
+3.6542586680505e-07
+22.5577565994779 -0.320824177874158 -3.25
+0 0
+0101101
+Ve
+1e-07
+0 0 -1.35
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1382 0 0 0.582332237511623
+2 2053 495 0 0 0.582332237511623
+2 2054 495 183 0 0.582332237511623
+0
+0101000
+-782 180 +781 0 *
+Ve
+1e-07
+0 0.795603032049121 9.53287449408005
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1383 0 0 0.475430415035387
+0
+0101000
+-782 185 +779 0 *
+Ve
+1e-07
+0 -0.585743047808703 -1.21630797166827
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1384 0 2.69279370307697 3.14159265358979
+2 2055 496 0 2.69279370307697 3.14159265358979
+2 2056 496 183 2.69279370307697 3.14159265358979
+0
+0101000
++777 0 -781 0 *
+Ve
+1e-07
+0 0.862359821958175 8.20480563678825
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1385 0 0 0.698131700797731
+2 2057 497 0 0 0.698131700797731
+2 2058 497 186 0 0.698131700797731
+0
+0101000
++775 0 -779 0 *
+Ve
+1e-07
+0 -1.3406759617027 -2.31097671344672
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1386 0 0 0.698131700797731
+2 2059 498 0 0 0.698131700797731
+2 2060 498 183 0 0.698131700797731
+0
+0101000
++773 0 -777 0 *
+Ve
+1e-07
+0 1.71527144924655 8.06971770605389
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 6.07374579694026 6.17846555205992
+2 2061 499 0 6.07374579694026 6.17846555205992
+2 2062 499 186 6.07374579694026 6.17846555205992
+0
+0101000
++771 0 -775 0 *
+Ve
+1e-07
+0 -1.95470723521056 -1.82130311288263
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1388 0 0 0.785375477039538
+0
+0101000
++769 0 -773 0 *
+Ve
+1e-07
+0 2.18915677589979 9.3121572642981
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1389 0 0 0.698131700797731
+2 2063 500 0 0 0.698131700797731
+2 2064 500 186 0 0.698131700797731
+0
+0101000
++767 0 -771 0 *
+Ve
+1e-07
+0 -1.05547250133184 -0.84171123250929
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1390 0 0 0.698131700797731
+2 2065 501 0 0 0.698131700797731
+2 2066 501 183 0 0.698131700797731
+0
+0101000
++765 0 -769 0 *
+Ve
+1e-07
+0 2.76021325135306 9.15914314286783
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1391 0 0 0.591201166705703
+0
+0101000
++763 0 -767 0 *
+Ve
+1e-07
+0 -1.31615268144546 -0.300403260841024
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1384 0 1.79519580205131 2.24399475256414
+2 2067 502 0 1.79519580205131 2.24399475256414
+2 2068 502 183 1.79519580205131 2.24399475256414
+0
+0101000
++761 0 -765 0 *
+Ve
+1e-07
+0 2.54939020359334 7.84621625943501
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1392 0 0 0.698131700797731
+2 2069 503 0 0 0.698131700797731
+2 2070 503 186 0 0.698131700797731
+0
+0101000
++759 0 -763 0 *
+Ve
+1e-07
+0 -2.64269213954193 -0.392687738519769
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1393 0 0 0.698131700797731
+2 2071 504 0 0 0.698131700797731
+2 2072 504 183 0 0.698131700797731
+0
+0101000
++757 0 -761 0 *
+Ve
+1e-07
+0 3.35557730537538 7.53675002555145
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 5.86430628670094 5.9690260418206
+2 2073 505 0 5.86430628670094 5.9690260418206
+2 2074 505 186 5.86430628670094 5.9690260418206
+0
+0101000
++755 0 -759 0 *
+Ve
+1e-07
+0 -2.64269213954193 0.392687738519768
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1394 0 0 0.785375477039537
+0
+0101000
++753 0 -757 0 *
+Ve
+1e-07
+0 4.07742480995763 8.65351299898659
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1395 0 0 0.698131700797733
+2 2075 506 0 0 0.698131700797733
+2 2076 506 186 0 0.698131700797733
+0
+0101000
++751 0 -755 0 *
+Ve
+1e-07
+0 -1.31615268144546 0.300403260841024
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1396 0 0 0.698131700797737
+2 2077 507 0 0 0.698131700797737
+2 2078 507 183 0 0.698131700797737
+0
+0101000
++749 0 -753 0 *
+Ve
+1e-07
+0 4.60418890660018 8.38511328586726
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1397 0 0 0.591201166705702
+0
+0101000
++747 0 -751 0 *
+Ve
+1e-07
+0 -1.05547250133184 0.84171123250929
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1384 0 0.897597901025655 1.34639685153848
+2 2079 508 0 0.897597901025655 1.34639685153848
+2 2080 508 183 0.897597901025655 1.34639685153848
+0
+0101000
++745 0 -749 0 *
+Ve
+1e-07
+0 4.12500000000002 7.14470958122161
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1398 0 0 0.698131700797727
+2 2081 509 0 0 0.698131700797727
+2 2082 509 186 0 0.698131700797727
+0
+0101000
++743 0 -747 0 *
+Ve
+1e-07
+0 -1.95470723521056 1.82130311288263
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1399 0 0 0.69813170079773
+2 2083 510 0 0 0.69813170079773
+2 2084 510 183 0 0.69813170079773
+0
+0101000
++741 0 -745 0 *
+Ve
+1e-07
+0 4.84922833141292 6.6743902035933
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 5.65486677646162 5.75958653158128
+2 2085 511 0 5.65486677646162 5.75958653158128
+2 2086 511 186 5.65486677646162 5.75958653158128
+0
+0101000
++739 0 -743 0 *
+Ve
+1e-07
+0 -1.3406759617027 2.31097671344672
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1400 0 0 0.785375477039538
+0
+0101000
++737 0 -741 0 *
+Ve
+1e-07
+0 5.7874898141653 7.61666869145696
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1401 0 0 0.698131700797732
+2 2087 512 0 0 0.698131700797732
+2 2088 512 186 0 0.698131700797732
+0
+0101000
++735 0 -739 0 *
+Ve
+1e-07
+0 -0.585743047808703 1.21630797166827
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1402 0 0 0.698131700797732
+2 2089 513 0 0 0.698131700797732
+2 2090 513 183 0 0.698131700797732
+0
+0101000
++733 0 -737 0 *
+Ve
+1e-07
+0 6.24693941327929 7.24461374203661
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1403 0 0 0.591201166705703
+0
+0101000
++731 0 -735 0 *
+Ve
+1e-07
+0 0 1.35
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1384 0 0 0.448798950512828
+2 2091 514 0 0 0.448798950512828
+2 2092 514 183 0 0.448798950512828
+0
+0101000
++729 0 -733 0 *
+Ve
+1e-07
+0 5.52032750246059 6.13094481018849
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1404 0 0 0.698131700797733
+2 2093 515 0 0 0.698131700797733
+2 2094 515 186 0 0.698131700797733
+0
+0101000
++727 0 -731 0 *
+Ve
+1e-07
+0 0.205212085995401 2.66381557247155
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1405 0 0 0.698131700797732
+2 2095 516 0 0 0.698131700797732
+2 2096 516 183 0 0.698131700797732
+0
+0101000
++725 0 -729 0 *
+Ve
+1e-07
+0 6.13094481018851 5.52032750246057
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 5.44542726622231 5.55014702134197
+2 2097 517 0 5.44542726622231 5.55014702134197
+2 2098 517 186 5.44542726622231 5.55014702134197
+0
+0101000
++723 0 -727 0 *
+Ve
+1e-07
+0 0.970896560104362 2.48905308781432
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1406 0 0 0.785375477039538
+0
+0101000
++721 0 -725 0 *
+Ve
+1e-07
+0 7.24461374203663 6.24693941327926
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1407 0 0 0.698131700797726
+2 2099 518 0 0 0.698131700797726
+2 2100 518 186 0 0.698131700797726
+0
+0101000
++719 0 -723 0 *
+Ve
+1e-07
+0 0.585743047808703 1.21630797166827
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1408 0 0 0.698131700797733
+2 2101 519 0 0 0.698131700797733
+2 2102 519 183 0 0.698131700797733
+0
+0101000
++717 0 -721 0 *
+Ve
+1e-07
+0 7.61666869145698 5.78748981416527
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1409 0 0 0.591201166705704
+0
+0101000
++715 0 -719 0 *
+Ve
+1e-07
+0 1.05547250133184 0.84171123250929
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1384 0 5.38558740615393 5.83438635666676
+2 2103 520 0 5.38558740615393 5.83438635666676
+2 2104 520 183 5.38558740615393 5.83438635666676
+0
+0101000
++713 0 -717 0 *
+Ve
+1e-07
+0 6.67439020359333 4.84922833141289
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1410 0 0 0.698131700797732
+2 2105 521 0 0 0.698131700797732
+2 2106 521 186 0 0.698131700797732
+0
+0101000
++711 0 -715 0 *
+Ve
+1e-07
+0 2.21060252088314 1.50042057405435
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1411 0 0 0.69813170079773
+2 2107 522 0 0 0.69813170079773
+2 2108 522 183 0 0.69813170079773
+0
+0101000
++709 0 -713 0 *
+Ve
+1e-07
+0 7.14470958122163 4.12499999999999
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 5.23598775598299 5.34070751110265
+2 2109 523 0 5.23598775598299 5.34070751110265
+2 2110 523 186 5.23598775598299 5.34070751110265
+0
+0101000
++707 0 -711 0 *
+Ve
+1e-07
+0 2.55136416947229 0.792821719627716
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1412 0 0 0.785375477039538
+0
+0101000
++705 0 -709 0 *
+Ve
+1e-07
+0 8.38511328586728 4.60418890660014
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1413 0 0 0.698131700797736
+2 2111 524 0 0 0.698131700797736
+2 2112 524 186 0 0.698131700797736
+0
+0101000
++703 0 -707 0 *
+Ve
+1e-07
+0 1.31615268144546 0.300403260841024
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1414 0 0 0.698131700797733
+2 2113 525 0 0 0.698131700797733
+2 2114 525 183 0 0.698131700797733
+0
+0101000
++701 0 -705 0 *
+Ve
+1e-07
+0 8.6535129989866 4.07742480995759
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1415 0 0 0.591201166705693
+0
+0101000
++699 0 -703 0 *
+Ve
+1e-07
+0 1.31615268144546 -0.300403260841024
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1384 0 4.48798950512828 4.9367884556411
+2 2115 526 0 4.48798950512828 4.9367884556411
+2 2116 526 183 4.48798950512828 4.9367884556411
+0
+0101000
++697 0 -701 0 *
+Ve
+1e-07
+0 7.53675002555146 3.35557730537535
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1416 0 0 0.698131700797783
+2 2117 527 0 0 0.698131700797783
+2 2118 527 186 0 0.698131700797783
+0
+0101000
++695 0 -699 0 *
+Ve
+1e-07
+0 2.55136416947229 -0.792821719627716
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1417 0 0 0.698131700797733
+2 2119 528 0 0 0.698131700797733
+2 2120 528 183 0 0.698131700797733
+0
+0101000
++693 0 -697 0 *
+Ve
+1e-07
+0 7.84621625943502 2.54939020359331
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 5.02654824574367 5.13126800086333
+2 2121 529 0 5.02654824574367 5.13126800086333
+2 2122 529 186 5.02654824574367 5.13126800086333
+0
+0101000
++691 0 -695 0 *
+Ve
+1e-07
+0 2.21060252088314 -1.50042057405435
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1418 0 0 0.785375477039538
+0
+0101000
++689 0 -693 0 *
+Ve
+1e-07
+0 9.15914314286784 2.76021325135302
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1419 0 0 0.69813170079773
+2 2123 530 0 0 0.69813170079773
+2 2124 530 186 0 0.69813170079773
+0
+0101000
++687 0 -691 0 *
+Ve
+1e-07
+0 1.05547250133184 -0.84171123250929
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1420 0 0 0.698131700797729
+2 2125 531 0 0 0.698131700797729
+2 2126 531 183 0 0.698131700797729
+0
+0101000
++685 0 -689 0 *
+Ve
+1e-07
+0 9.31215726429811 2.18915677589975
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1421 0 0 0.591201166705702
+0
+0101000
++683 0 -687 0 *
+Ve
+1e-07
+0 0.585743047808703 -1.21630797166827
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1384 0 3.59039160410262 4.03919055461545
+2 2127 532 0 3.59039160410262 4.03919055461545
+2 2128 532 183 3.59039160410262 4.03919055461545
+0
+0101000
++681 0 -685 0 *
+Ve
+1e-07
+0 8.0697177060539 1.71527144924651
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1422 0 0 0.698131700797734
+2 2129 533 0 0 0.698131700797734
+2 2130 533 186 0 0.698131700797734
+0
+0101000
++679 0 -683 0 *
+Ve
+1e-07
+0 0.970896560104362 -2.48905308781432
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1423 0 0 0.698131700797733
+2 2131 534 0 0 0.698131700797733
+2 2132 534 183 0 0.698131700797733
+0
+0101000
++677 0 -681 0 *
+Ve
+1e-07
+0 8.20480563678826 0.862359821958139
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 4.81710873550435 4.92182849062401
+2 2133 535 0 4.81710873550435 4.92182849062401
+2 2134 535 186 4.81710873550435 4.92182849062401
+0
+0101000
++675 0 -679 0 *
+Ve
+22.3488637857124 -0.103285162141171 -3.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1424 0 0.157382650922508 0.785375477039538
+0
+0101000
++673 180 -677 0 *
+Ve
+1e-07
+0 9.53287449408006 0.795603032049078
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1425 0 0 0.698131700797732
+2 2135 536 0 0 0.698131700797732
+2 2136 536 186 0 0.698131700797732
+0
+0101000
++671 0 -675 0 *
+Ve
+1e-07
+0 0 8.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1426 0 0.122452388467584 0.69813170079773
+2 2137 537 0 0.122452388467584 0.69813170079773
+2 2138 537 186 0.122452388467584 0.69813170079773
+0
+0101000
++673 185 -669 0 *
+Ve
+1e-07
+0 9.56381557247154 0.205212085995401
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1427 0 0 0.591201166705702
+0
+0101000
++667 0 -671 0 *
+Ve
+1e-07
+0 -0.862359821958141 8.20480563678825
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 0 0.10471975511966
+2 2139 538 0 0 0.10471975511966
+2 2140 538 186 0 0.10471975511966
+0
+0101000
++669 0 -665 0 *
+Ve
+1e-07
+0 8.25 0
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1428 0 0 0.698131700797732
+2 2141 539 0 0 0.698131700797732
+2 2142 539 186 0 0.698131700797732
+0
+0101000
++663 0 -667 0 *
+Ve
+1e-07
+0 -1.20377885748233 9.48997348609396
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1429 0 0 0.698131700797727
+2 2143 540 0 0 0.698131700797727
+2 2144 540 186 0 0.698131700797727
+0
+0101000
++665 0 -661 0 *
+Ve
+1e-07
+0 8.20480563678826 -0.862359821958139
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 4.60766922526503 4.71238898038469
+2 2145 541 0 4.60766922526503 4.71238898038469
+2 2146 541 186 4.60766922526503 4.71238898038469
+0
+0101000
++659 0 -663 0 *
+Ve
+1e-07
+0 -1.78770135678379 9.39748924784919
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1430 0 0 0.591201166705705
+0
+0101000
++661 0 -657 0 *
+Ve
+1e-07
+0 9.48997348609396 -1.20377885748232
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1431 0 0 0.698131700797733
+2 2147 542 0 0 0.698131700797733
+2 2148 542 186 0 0.698131700797733
+0
+0101000
++655 0 -659 0 *
+Ve
+1e-07
+0 -1.71527144924651 8.0697177060539
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1432 0 0 0.698131700797732
+2 2149 543 0 0 0.698131700797732
+2 2150 543 186 0 0.698131700797732
+0
+0101000
++657 0 -653 0 *
+Ve
+1e-07
+0 9.39748924784919 -1.78770135678379
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1433 0 0 0.591201166705703
+0
+0101000
++651 0 -655 0 *
+Ve
+1e-07
+0 -2.54939020359332 7.84621625943502
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 0.20943951023932 0.31415926535898
+2 2151 544 0 0.20943951023932 0.31415926535898
+2 2152 544 186 0.20943951023932 0.31415926535898
+0
+0101000
++653 0 -649 0 *
+Ve
+1e-07
+0 8.0697177060539 -1.71527144924651
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1434 0 0 0.698131700797732
+2 2153 545 0 0 0.698131700797732
+2 2154 545 186 0 0.698131700797732
+0
+0101000
++647 0 -651 0 *
+Ve
+1e-07
+0 -3.15054983456992 9.03231509882041
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1435 0 0 0.698131700797731
+2 2155 546 0 0 0.698131700797731
+2 2156 546 186 0 0.698131700797731
+0
+0101000
++649 0 -645 0 *
+Ve
+1e-07
+0 7.84621625943502 -2.54939020359331
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 4.39822971502571 4.50294947014537
+2 2157 547 0 4.39822971502571 4.50294947014537
+2 2158 547 186 4.39822971502571 4.50294947014537
+0
+0101000
++643 0 -647 0 *
+Ve
+1e-07
+0 -3.70248367192868 8.8204475489393
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1436 0 0 0.591201166705705
+0
+0101000
++645 0 -641 0 *
+Ve
+1e-07
+0 9.03231509882042 -3.15054983456991
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1437 0 0 0.698131700797732
+2 2159 548 0 0 0.698131700797732
+2 2160 548 186 0 0.698131700797732
+0
+0101000
++639 0 -643 0 *
+Ve
+1e-07
+0 -3.35557730537535 7.53675002555146
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1438 0 0 0.698131700797728
+2 2161 549 0 0 0.698131700797728
+2 2162 549 186 0 0.698131700797728
+0
+0101000
++641 0 -637 0 *
+Ve
+1e-07
+0 8.8204475489393 -3.70248367192868
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1439 0 0 0.591201166705711
+0
+0101000
++635 0 -639 0 *
+Ve
+1e-07
+0 -4.125 7.14470958122162
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 0.418879020478639 0.523598775598299
+2 2163 550 0 0.418879020478639 0.523598775598299
+2 2164 550 186 0.418879020478639 0.523598775598299
+0
+0101000
++637 0 -633 0 *
+Ve
+1e-07
+0 7.53675002555146 -3.35557730537535
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1440 0 0 0.698131700797678
+2 2165 551 0 0 0.698131700797678
+2 2166 551 186 0 0.698131700797678
+0
+0101000
++631 0 -635 0 *
+Ve
+1e-07
+0 -4.95962666587139 8.17990119987187
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1441 0 0 0.698131700797727
+2 2167 552 0 0 0.698131700797727
+2 2168 552 186 0 0.698131700797727
+0
+0101000
++633 0 -629 0 *
+Ve
+1e-07
+0 7.14470958122163 -4.12499999999999
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 4.18879020478639 4.29350995990605
+2 2169 553 0 4.18879020478639 4.29350995990605
+2 2170 553 186 4.18879020478639 4.29350995990605
+0
+0101000
++627 0 -631 0 *
+Ve
+1e-07
+0 -5.45544968412246 7.85790996693752
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1442 0 0 0.591201166705705
+0
+0101000
++629 0 -625 0 *
+Ve
+1e-07
+0 8.17990119987188 -4.95962666587137
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1443 0 0 0.69813170079773
+2 2171 554 0 0 0.69813170079773
+2 2172 554 186 0 0.69813170079773
+0
+0101000
++623 0 -627 0 *
+Ve
+1e-07
+0 -4.8492283314129 6.67439020359332
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1444 0 0 0.698131700797731
+2 2173 555 0 0 0.698131700797731
+2 2174 555 186 0 0.698131700797731
+0
+0101000
++625 0 -621 0 *
+Ve
+1e-07
+0 7.85790996693753 -5.45544968412244
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1445 0 0 0.591201166705703
+0
+0101000
++619 0 -623 0 *
+Ve
+1e-07
+0 -5.52032750246058 6.1309448101885
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 0.628318530717959 0.733038285837618
+2 2175 556 0 0.628318530717959 0.733038285837618
+2 2176 556 186 0.628318530717959 0.733038285837618
+0
+0101000
++621 0 -617 0 *
+Ve
+1e-07
+0 6.67439020359333 -4.84922833141289
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1446 0 0 0.69813170079773
+2 2177 557 0 0 0.69813170079773
+2 2178 557 186 0 0.69813170079773
+0
+0101000
++615 0 -619 0 *
+Ve
+1e-07
+0 -6.55194401294508 6.96998636696808
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1447 0 0 0.698131700797731
+2 2179 558 0 0 0.698131700797731
+2 2180 558 186 0 0.698131700797731
+0
+0101000
++617 0 -613 0 *
+Ve
+1e-07
+0 6.13094481018851 -5.52032750246057
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 3.97935069454707 4.08407044966673
+2 2181 559 0 3.97935069454707 4.08407044966673
+2 2182 559 186 3.97935069454707 4.08407044966673
+0
+0101000
++611 0 -615 0 *
+Ve
+1e-07
+0 -6.96998636696808 6.55194401294508
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1448 0 0 0.591201166705705
+0
+0101000
++613 0 -609 0 *
+Ve
+1e-07
+0 6.9699863669681 -6.55194401294507
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1449 0 0 0.698131700797735
+2 2183 560 0 0 0.698131700797735
+2 2184 560 186 0 0.698131700797735
+0
+0101000
++607 0 -611 0 *
+Ve
+1e-07
+0 -6.1309448101885 5.52032750246058
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1450 0 0 0.698131700797732
+2 2185 561 0 0 0.698131700797732
+2 2186 561 186 0 0.698131700797732
+0
+0101000
++609 0 -605 0 *
+Ve
+1e-07
+0 6.55194401294509 -6.96998636696807
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1451 0 0 0.591201166705705
+0
+0101000
++603 0 -607 0 *
+Ve
+1e-07
+0 -6.67439020359332 4.8492283314129
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 0.837758040957278 0.942477796076938
+2 2187 562 0 0.837758040957278 0.942477796076938
+2 2188 562 186 0.837758040957278 0.942477796076938
+0
+0101000
++605 0 -601 0 *
+Ve
+1e-07
+0 5.52032750246059 -6.13094481018849
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1452 0 0 0.69813170079773
+2 2189 563 0 0 0.69813170079773
+2 2190 563 186 0 0.69813170079773
+0
+0101000
++599 0 -603 0 *
+Ve
+1e-07
+0 -7.85790996693752 5.45544968412246
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1453 0 0 0.698131700797731
+2 2191 564 0 0 0.698131700797731
+2 2192 564 186 0 0.698131700797731
+0
+0101000
++601 0 -597 0 *
+Ve
+1e-07
+0 4.84922833141291 -6.67439020359331
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 3.76991118430775 3.87463093942741
+2 2193 565 0 3.76991118430775 3.87463093942741
+2 2194 565 186 3.76991118430775 3.87463093942741
+0
+0101000
++595 0 -599 0 *
+Ve
+1e-07
+0 -8.17990120004263 4.9596266657281
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1454 0 0 0.591201166918879
+0
+0101000
++597 0 -593 0 *
+Ve
+1e-07
+0 5.45544968412247 -7.85790996693751
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1455 0 0 0.698131700797729
+2 2195 566 0 0 0.698131700797729
+2 2196 566 186 0 0.698131700797729
+0
+0101000
++591 0 -595 0 *
+Ve
+1e-07
+0 -7.144709581326 4.1249999998192
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1456 0 0 0.698131699497974
+2 2197 567 0 0 0.698131699497974
+2 2198 567 186 0 0.698131699497974
+0
+0101000
++593 0 -589 0 *
+Ve
+1e-07
+0 4.9596266658714 -8.17990119987186
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1457 0 0 0.591201166705707
+0
+0101000
++587 0 -591 0 *
+Ve
+1e-07
+0 -7.53674688209901 3.35558436567625
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 1.0471975512219 1.15191636953285
+2 2199 568 0 1.0471975512219 1.15191636953285
+2 2200 568 186 1.0471975512219 1.15191636953285
+0
+0101000
++589 0 -585 0 *
+Ve
+1e-07
+0 4.12500000000001 -7.14470958122161
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1458 0 0 0.698131700797723
+2 2201 569 0 0 0.698131700797723
+2 2202 569 186 0 0.698131700797723
+0
+0101000
++583 0 -587 0 *
+Ve
+1e-07
+0 -8.8204475489393 3.70248367192868
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1459 0 0 0.698111091562759
+2 2203 570 0 0 0.698111091562759
+2 2204 570 186 0 0.698111091562759
+0
+0101000
++585 0 -581 0 *
+Ve
+1e-07
+0 3.35557730537536 -7.53675002555145
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 3.56047167406843 3.66519142918809
+2 2205 571 0 3.56047167406843 3.66519142918809
+2 2206 571 186 3.56047167406843 3.66519142918809
+0
+0101000
++579 0 -583 0 *
+Ve
+1e-07
+0 -9.03231509882041 3.15054983456992
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1460 0 0 0.591201166705705
+0
+0101000
++581 0 -577 0 *
+Ve
+1e-07
+0 3.70248367192869 -8.8204475489393
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1461 0 0 0.698131700797733
+2 2207 572 0 0 0.698131700797733
+2 2208 572 186 0 0.698131700797733
+0
+0101000
++575 0 -579 0 *
+Ve
+1e-07
+0 -7.84621625943502 2.54939020359331
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1462 0 0 0.698131700797724
+2 2209 573 0 0 0.698131700797724
+2 2210 573 186 0 0.698131700797724
+0
+0101000
++577 0 -573 0 *
+Ve
+1e-07
+0 3.15054983456993 -9.03231509882041
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1463 0 0 0.591201166705706
+0
+0101000
++571 0 -575 0 *
+Ve
+1e-07
+0 -8.0697177060539 1.71527144924652
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 1.25663706143592 1.36135681655558
+2 2211 574 0 1.25663706143592 1.36135681655558
+2 2212 574 186 1.25663706143592 1.36135681655558
+0
+0101000
++573 0 -569 0 *
+Ve
+1e-07
+0 2.54939020359333 -7.84621625943501
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1464 0 0 0.698131700797731
+2 2213 575 0 0 0.698131700797731
+2 2214 575 186 0 0.698131700797731
+0
+0101000
++567 0 -571 0 *
+Ve
+1e-07
+0 -9.39748924784919 1.78770135678379
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1465 0 0 0.698131700797733
+2 2215 576 0 0 0.698131700797733
+2 2216 576 186 0 0.698131700797733
+0
+0101000
++569 0 -565 0 *
+Ve
+1e-07
+0 1.71527144924652 -8.06971770605389
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 3.35103216382911 3.45575191894877
+2 2217 577 0 3.35103216382911 3.45575191894877
+2 2218 577 186 3.35103216382911 3.45575191894877
+0
+0101000
++563 0 -567 0 *
+Ve
+1e-07
+0 -9.48997348609396 1.20377885748233
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1466 0 0 0.591201166705703
+0
+0101000
++565 0 -561 0 *
+Ve
+1e-07
+0 1.78770135678381 -9.39748924784919
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1467 0 0 0.698131700797732
+2 2219 578 0 0 0.698131700797732
+2 2220 578 186 0 0.698131700797732
+0
+0101000
++559 0 -563 0 *
+Ve
+1e-07
+0 -8.20480563678825 0.862359821958142
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1468 0 0 0.69813170079773
+2 2221 579 0 0 0.69813170079773
+2 2222 579 186 0 0.69813170079773
+0
+0101000
++561 0 -557 0 *
+Ve
+1e-07
+0 1.20377885748234 -9.48997348609396
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1469 0 0 0.591201166705707
+0
+0101000
++555 0 -559 0 *
+Ve
+1e-07
+0 -8.25 -1.83186799063151e-15
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 1.46607657167524 1.5707963267949
+2 2223 580 0 1.46607657167524 1.5707963267949
+2 2224 580 186 1.46607657167524 1.5707963267949
+0
+0101000
++557 0 -553 0 *
+Ve
+1e-07
+0 0.86235982195815 -8.20480563678825
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1470 0 0 0.698131700797733
+2 2225 581 0 0 0.698131700797733
+2 2226 581 186 0 0.698131700797733
+0
+0101000
++551 0 -555 0 *
+Ve
+1e-07
+0 -9.56381557247154 -0.205212085995403
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1471 0 0 0.698131700797755
+2 2227 582 0 0 0.698131700797755
+2 2228 582 186 0 0.698131700797755
+0
+0101000
++553 0 -549 0 *
+Ve
+1e-07
+0 7.32747196252603e-15 -8.25
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 3.14159265358979 3.24631240870945
+2 2229 583 0 3.14159265358979 3.24631240870945
+2 2230 583 186 3.14159265358979 3.24631240870945
+0
+0101000
++547 0 -551 0 *
+Ve
+1e-07
+0 -9.53287449408006 -0.795603032049078
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1472 0 0 0.5912011667057
+0
+0101000
++549 0 -545 0 *
+Ve
+1e-07
+0 -0.205212085995393 -9.56381557247154
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1473 0 0 0.698131700797732
+2 2231 584 0 0 0.698131700797732
+2 2232 584 186 0 0.698131700797732
+0
+0101000
++543 0 -547 0 *
+Ve
+1e-07
+0 -8.20480563678826 -0.862359821958139
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1474 0 0 0.698131700797732
+2 2233 585 0 0 0.698131700797732
+2 2234 585 186 0 0.698131700797732
+0
+0101000
++545 0 -541 0 *
+Ve
+1e-07
+0 -0.795603032049074 -9.53287449408006
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1475 0 0 0.591201166705707
+0
+0101000
++539 0 -543 0 *
+Ve
+1e-07
+0 -8.0697177060539 -1.71527144924651
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 1.67551608191456 1.78023583703422
+2 2235 586 0 1.67551608191456 1.78023583703422
+2 2236 586 186 1.67551608191456 1.78023583703422
+0
+0101000
++541 0 -537 0 *
+Ve
+1e-07
+0 -0.862359821958135 -8.20480563678826
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1476 0 0 0.698131700797731
+2 2237 587 0 0 0.698131700797731
+2 2238 587 186 0 0.698131700797731
+0
+0101000
++535 0 -539 0 *
+Ve
+1e-07
+0 -9.3121572642981 -2.18915677589976
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1477 0 0 0.698131700797743
+2 2239 588 0 0 0.698131700797743
+2 2240 588 186 0 0.698131700797743
+0
+0101000
++537 0 -533 0 *
+Ve
+1e-07
+0 -1.71527144924651 -8.0697177060539
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 2.93215314335047 3.03687289847013
+2 2241 589 0 2.93215314335047 3.03687289847013
+2 2242 589 186 2.93215314335047 3.03687289847013
+0
+0101000
++531 0 -535 0 *
+Ve
+1e-07
+0 -9.15914314286784 -2.76021325135302
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1478 0 0 0.591201166705703
+0
+0101000
++533 0 -529 0 *
+Ve
+1e-07
+0 -2.18915677589975 -9.31215726429811
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1479 0 0 0.698131700797734
+2 2243 590 0 0 0.698131700797734
+2 2244 590 186 0 0.698131700797734
+0
+0101000
++527 0 -531 0 *
+Ve
+1e-07
+0 -7.84621625943502 -2.54939020359331
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1480 0 0 0.698131700797722
+2 2245 591 0 0 0.698131700797722
+2 2246 591 186 0 0.698131700797722
+0
+0101000
++529 0 -525 0 *
+Ve
+1e-07
+0 -2.76021325135302 -9.15914314286784
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1481 0 0 0.591201166705706
+0
+0101000
++523 0 -527 0 *
+Ve
+1e-07
+0 -7.53675002555146 -3.35557730537534
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 1.88495559215388 1.98967534727353
+2 2247 592 0 1.88495559215388 1.98967534727353
+2 2248 592 186 1.88495559215388 1.98967534727353
+0
+0101000
++525 0 -521 0 *
+Ve
+1e-07
+0 -2.54939020359331 -7.84621625943502
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1482 0 0 0.698131700797732
+2 2249 593 0 0 0.698131700797732
+2 2250 593 186 0 0.698131700797732
+0
+0101000
++519 0 -523 0 *
+Ve
+1e-07
+0 -8.65351299898661 -4.07742480995759
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1483 0 0 0.698131700797701
+2 2251 594 0 0 0.698131700797701
+2 2252 594 186 0 0.698131700797701
+0
+0101000
++521 0 -517 0 *
+Ve
+1e-07
+0 -3.35557730537535 -7.53675002555146
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 2.72271363311115 2.82743338823081
+2 2253 595 0 2.72271363311115 2.82743338823081
+2 2254 595 186 2.72271363311115 2.82743338823081
+0
+0101000
++515 0 -519 0 *
+Ve
+1e-07
+0 -8.38511328586728 -4.60418890660016
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1484 0 0 0.591201166705714
+0
+0101000
++517 0 -513 0 *
+Ve
+1e-07
+0 -4.0774248099576 -8.6535129989866
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1485 0 0 0.698131700797728
+2 2255 596 0 0 0.698131700797728
+2 2256 596 186 0 0.698131700797728
+0
+0101000
++511 0 -515 0 *
+Ve
+1e-07
+0 -7.14470958122162 -4.125
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1486 0 0 0.698131700797718
+2 2257 597 0 0 0.698131700797718
+2 2258 597 186 0 0.698131700797718
+0
+0101000
++513 0 -509 0 *
+Ve
+1e-07
+0 -4.60418890660016 -8.38511328586728
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1487 0 0 0.591201166705705
+0
+0101000
++507 0 -511 0 *
+Ve
+1e-07
+0 -6.67439020359332 -4.8492283314129
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 2.09439510239319 2.19911485751285
+2 2259 598 0 2.09439510239319 2.19911485751285
+2 2260 598 186 2.09439510239319 2.19911485751285
+0
+0101000
++509 0 -505 0 *
+Ve
+1e-07
+0 -4.125 -7.14470958122162
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1488 0 0 0.698131700797734
+2 2261 599 0 0 0.698131700797734
+2 2262 599 186 0 0.698131700797734
+0
+0101000
++503 0 -507 0 *
+Ve
+1e-07
+0 -7.61666869145698 -5.78748981416528
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1489 0 0 0.698131700797734
+2 2263 600 0 0 0.698131700797734
+2 2264 600 186 0 0.698131700797734
+0
+0101000
++505 0 -501 0 *
+Ve
+1e-07
+0 -4.8492283314129 -6.67439020359332
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 2.51327412287183 2.61799387799149
+2 2265 601 0 2.51327412287183 2.61799387799149
+2 2266 601 186 2.51327412287183 2.61799387799149
+0
+0101000
++499 0 -503 0 *
+Ve
+1e-07
+0 -7.24461374203662 -6.24693941327927
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1490 0 0 0.591201166705706
+0
+0101000
++501 0 -497 0 *
+Ve
+1e-07
+0 -5.78748981416528 -7.61666869145697
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1491 0 0 0.698131700797732
+2 2267 602 0 0 0.698131700797732
+2 2268 602 186 0 0.698131700797732
+0
+0101000
++495 0 -499 0 *
+Ve
+1e-07
+0 -6.1309448101885 -5.52032750246058
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1492 0 0 0.698131700797731
+2 2269 603 0 0 0.698131700797731
+2 2270 603 186 0 0.698131700797731
+0
+0101000
++497 0 -493 0 *
+Ve
+1e-07
+0 -6.24693941327927 -7.24461374203662
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1493 0 0 0.591201166705706
+0
+0101000
++491 0 -495 0 *
+Ve
+1e-07
+0 -5.52032750246058 -6.1309448101885
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1387 0 2.30383461263251 2.40855436775217
+2 2271 604 0 2.30383461263251 2.40855436775217
+2 2272 604 186 2.30383461263251 2.40855436775217
+0
+0101000
++493 0 -489 0 *
+Ed
+ 1e-07 1 1 0
+1 1494 0 0 0.698131700797729
+2 2273 605 0 0 0.698131700797729
+2 2274 605 186 0 0.698131700797729
+0
+0101000
++489 0 -491 0 *
+Wi
+0101100
++780 181 -778 184 +776 181 -774 184 +772 181 -770 184 +768 181 -766 184 +764 181 -762 184
++760 181 -758 184 +756 181 -754 184 +752 181 -750 184 +748 181 -746 184 +744 181 -742 184
++740 181 -738 184 +736 181 -734 184 +732 181 -730 184 +728 181 -726 184 +724 181 -722 184
++720 181 -718 184 +716 181 -714 184 +712 181 -710 184 +708 181 -706 184 +704 181 -702 184
++700 181 -698 184 +696 181 -694 184 +692 181 -690 184 +688 181 -686 184 +684 181 -682 184
++680 181 -678 184 +676 181 -674 184 +672 181 -670 184 -668 184 -666 184 -664 184 -662 184
+-660 184 -658 184 -656 184 -654 184 -652 184 -650 184 -648 184 -646 184 -644 184 -642 184
+-640 184 -638 184 -636 184 -634 184 -632 184 -630 184 -628 184 -626 184 -624 184 -622 184
+-620 184 -618 184 -616 184 -614 184 -612 184 -610 184 -608 184 -606 184 -604 184 -602 184
+-600 184 -598 184 -596 184 -594 184 -592 184 -590 184 -588 184 -586 184 -584 184 -582 184
+-580 184 -578 184 -576 184 -574 184 -572 184 -570 184 -568 184 -566 184 -564 184 -562 184
+-560 184 -558 184 -556 184 -554 184 -552 184 -550 184 -548 184 -546 184 -544 184 -542 184
+-540 184 -538 184 -536 184 -534 184 -532 184 -530 184 -528 184 -526 184 -524 184 -522 184
+-520 184 -518 184 -516 184 -514 184 -512 184 -510 184 -508 184 -506 184 -504 184 -502 184
+-500 184 -498 184 -496 184 -494 184 -492 184 -490 184 -488 184 -487 184 *
+Fa
+0 1e-07 493 0
+0101000
++784 0 -783 179 +486 180 *
+Wi
+0101100
++789 0 *
+Fa
+0 1e-07 489 0
+0101000
++484 188 *
+Ve
+1e-07
+0.583333333333333 0 1.125
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1495 0 0 0.583333333333333
+3 2275 2276CN 494 0 0 0.583333333333333
+0
+0101000
+-786 0 +482 0 *
+Ed
+ 1e-07 1 1 0
+1 1496 0 0 6.28318530717959
+2 2277 494 0 0 6.28318530717959
+2 2278 606 0 0 6.28318530717959
+0
+0101100
++482 0 -482 0 *
+Wi
+0101100
++481 0 -785 0 +480 0 -481 0 *
+Fa
+0 1e-07 494 0
+0101000
++479 0 *
+Ve
+1e-07
+22.5577565994779 -0.320824177874158 -6.75
+0 0
+0101101
+Ed
+ 5.34530881081264e-15 1 1 0
+1 1497 0 -3.5 0
+2 2279 495 181 -3.5 0
+2 2280 607 189 -3.5 0
+0
+0101000
++477 0 -782 0 *
+Ed
+ 1e-07 1 1 0
+1 1498 0 0 3.5
+2 2281 496 0 0 3.5
+2 2282 495 0 0 3.5
+0
+0101000
++781 0 -781 182 *
+Ed
+ 1e-07 1 1 0
+0
+0101000
+-477 191 +781 0 *
+Wi
+0101100
+-780 181 +476 0 +475 181 +474 190 *
+Fa
+0 1e-07 495 0
+0101000
++473 180 *
+Ed
+ 1e-07 1 1 0
+1 1383 0 0 0.475430415035388
+0
+0101000
+-477 192 +779 0 *
+Ed
+ 1e-07 1 1 0
+1 1499 0 0 3.5
+2 2283 497 0 0 3.5
+0
+0101000
++779 0 -779 172 *
+Wi
+0101100
+-471 189 -476 0 +470 189 +778 184 *
+Fa
+0 1e-07 607 0
+0101000
++469 192 *
+Ed
+ 1e-07 1 1 0
+1 1500 0 0 3.5
+2 2284 498 0 0 3.5
+2 2285 496 0 0 3.5
+0
+0101000
++777 0 -777 182 *
+Wi
+0101000
++467 0 -475 0 -776 0 +776 182 *
+Fa
+0 1e-07 496 0
+0101000
++466 0 *
+Ed
+ 1e-07 1 1 0
+1 1501 0 0 3.5
+2 2286 499 0 0 3.5
+2 2287 497 0 0 3.5
+0
+0101000
++775 0 -775 172 *
+Wi
+0101000
++464 0 -470 0 -774 0 +774 172 *
+Fa
+0 1e-07 497 0
+0101000
++463 0 *
+Ed
+ 1e-07 1 1 0
+1 1502 0 0 3.5
+2 2288 498 0 0 3.5
+0
+0101000
++773 0 -773 182 *
+Wi
+0101000
++461 0 -467 0 -772 0 +772 182 *
+Fa
+0 1e-07 498 0
+0101000
++460 0 *
+Ed
+ 1e-07 1 1 0
+1 1503 0 0 3.5
+2 2289 500 0 0 3.5
+2 2290 499 0 0 3.5
+0
+0101000
++771 0 -771 172 *
+Wi
+0101000
++458 0 -464 0 -770 0 +770 172 *
+Fa
+0 1e-07 499 0
+0101000
++457 0 *
+Ed
+ 1e-07 1 1 0
+1 1504 0 0 3.5
+2 2291 501 0 0 3.5
+0
+0101000
++769 0 -769 182 *
+Wi
+0101000
++455 0 -461 0 -768 0 +768 182 *
+Fa
+0 1e-07 608 0
+0101000
++454 0 *
+Ed
+ 1e-07 1 1 0
+1 1505 0 0 3.5
+2 2292 500 0 0 3.5
+0
+0101000
++767 0 -767 172 *
+Wi
+0101000
++452 0 -458 0 -766 0 +766 172 *
+Fa
+0 1e-07 500 0
+0101000
++451 0 *
+Ed
+ 1e-07 1 1 0
+1 1506 0 0 3.5
+2 2293 502 0 0 3.5
+2 2294 501 0 0 3.5
+0
+0101000
++765 0 -765 182 *
+Wi
+0101000
++449 0 -455 0 -764 0 +764 182 *
+Fa
+0 1e-07 501 0
+0101000
++448 0 *
+Ed
+ 1e-07 1 1 0
+1 1507 0 0 3.5
+2 2295 503 0 0 3.5
+0
+0101000
++763 0 -763 172 *
+Wi
+0101000
++446 0 -452 0 -762 0 +762 172 *
+Fa
+0 1e-07 609 0
+0101000
++445 0 *
+Ed
+ 1e-07 1 1 0
+1 1508 0 0 3.5
+2 2296 504 0 0 3.5
+2 2297 502 0 0 3.5
+0
+0101000
++761 0 -761 182 *
+Wi
+0101000
++443 0 -449 0 -760 0 +760 182 *
+Fa
+0 1e-07 502 0
+0101000
++442 0 *
+Ed
+ 1e-07 1 1 0
+1 1509 0 0 3.5
+2 2298 505 0 0 3.5
+2 2299 503 0 0 3.5
+0
+0101000
++759 0 -759 172 *
+Wi
+0101000
++440 0 -446 0 -758 0 +758 172 *
+Fa
+0 1e-07 503 0
+0101000
++439 0 *
+Ed
+ 1e-07 1 1 0
+1 1510 0 0 3.5
+2 2300 504 0 0 3.5
+0
+0101000
++757 0 -757 182 *
+Wi
+0101000
++437 0 -443 0 -756 0 +756 182 *
+Fa
+0 1e-07 504 0
+0101000
++436 0 *
+Ed
+ 1e-07 1 1 0
+1 1511 0 0 3.5
+2 2301 506 0 0 3.5
+2 2302 505 0 0 3.5
+0
+0101000
++755 0 -755 172 *
+Wi
+0101000
++434 0 -440 0 -754 0 +754 172 *
+Fa
+0 1e-07 505 0
+0101000
++433 0 *
+Ed
+ 1e-07 1 1 0
+1 1512 0 0 3.5
+2 2303 507 0 0 3.5
+0
+0101000
++753 0 -753 182 *
+Wi
+0101000
++431 0 -437 0 -752 0 +752 182 *
+Fa
+0 1e-07 610 0
+0101000
++430 0 *
+Ed
+ 1e-07 1 1 0
+1 1513 0 0 3.5
+2 2304 506 0 0 3.5
+0
+0101000
++751 0 -751 172 *
+Wi
+0101000
++428 0 -434 0 -750 0 +750 172 *
+Fa
+0 1e-07 506 0
+0101000
++427 0 *
+Ed
+ 1e-07 1 1 0
+1 1514 0 0 3.5
+2 2305 508 0 0 3.5
+2 2306 507 0 0 3.5
+0
+0101000
++749 0 -749 182 *
+Wi
+0101000
++425 0 -431 0 -748 0 +748 182 *
+Fa
+0 1e-07 507 0
+0101000
++424 0 *
+Ed
+ 1e-07 1 1 0
+1 1515 0 0 3.5
+2 2307 509 0 0 3.5
+0
+0101000
++747 0 -747 172 *
+Wi
+0101000
++422 0 -428 0 -746 0 +746 172 *
+Fa
+0 1e-07 611 0
+0101000
++421 0 *
+Ed
+ 1e-07 1 1 0
+1 1516 0 0 3.5
+2 2308 510 0 0 3.5
+2 2309 508 0 0 3.5
+0
+0101000
++745 0 -745 182 *
+Wi
+0101000
++419 0 -425 0 -744 0 +744 182 *
+Fa
+0 1e-07 508 0
+0101000
++418 0 *
+Ed
+ 1e-07 1 1 0
+1 1517 0 0 3.5
+2 2310 511 0 0 3.5
+2 2311 509 0 0 3.5
+0
+0101000
++743 0 -743 172 *
+Wi
+0101000
++416 0 -422 0 -742 0 +742 172 *
+Fa
+0 1e-07 509 0
+0101000
++415 0 *
+Ed
+ 1e-07 1 1 0
+1 1518 0 0 3.5
+2 2312 510 0 0 3.5
+0
+0101000
++741 0 -741 182 *
+Wi
+0101000
++413 0 -419 0 -740 0 +740 182 *
+Fa
+0 1e-07 510 0
+0101000
++412 0 *
+Ed
+ 1e-07 1 1 0
+1 1519 0 0 3.5
+2 2313 512 0 0 3.5
+2 2314 511 0 0 3.5
+0
+0101000
++739 0 -739 172 *
+Wi
+0101000
++410 0 -416 0 -738 0 +738 172 *
+Fa
+0 1e-07 511 0
+0101000
++409 0 *
+Ed
+ 1e-07 1 1 0
+1 1520 0 0 3.5
+2 2315 513 0 0 3.5
+0
+0101000
++737 0 -737 182 *
+Wi
+0101000
++407 0 -413 0 -736 0 +736 182 *
+Fa
+0 1e-07 612 0
+0101000
++406 0 *
+Ed
+ 1e-07 1 1 0
+1 1521 0 0 3.5
+2 2316 512 0 0 3.5
+0
+0101000
++735 0 -735 172 *
+Wi
+0101000
++404 0 -410 0 -734 0 +734 172 *
+Fa
+0 1e-07 512 0
+0101000
++403 0 *
+Ed
+ 1e-07 1 1 0
+1 1522 0 0 3.5
+2 2317 514 0 0 3.5
+2 2318 513 0 0 3.5
+0
+0101000
++733 0 -733 182 *
+Wi
+0101000
++401 0 -407 0 -732 0 +732 182 *
+Fa
+0 1e-07 513 0
+0101000
++400 0 *
+Ed
+ 1e-07 1 1 0
+1 1523 0 0 3.5
+2 2319 515 0 0 3.5
+0
+0101000
++731 0 -731 172 *
+Wi
+0101000
++398 0 -404 0 -730 0 +730 172 *
+Fa
+0 1e-07 613 0
+0101000
++397 0 *
+Ed
+ 1e-07 1 1 0
+1 1524 0 0 3.5
+2 2320 514 0 0 3.5
+2 2321 516 0 0 3.5
+0
+0101000
++729 0 -729 182 *
+Wi
+0101000
++395 0 -401 0 -728 0 +728 182 *
+Fa
+0 1e-07 514 0
+0101000
++394 0 *
+Ed
+ 1e-07 1 1 0
+1 1525 0 0 3.5
+2 2322 517 0 0 3.5
+2 2323 515 0 0 3.5
+0
+0101000
++727 0 -727 172 *
+Wi
+0101000
++392 0 -398 0 -726 0 +726 172 *
+Fa
+0 1e-07 515 0
+0101000
++391 0 *
+Ed
+ 1e-07 1 1 0
+1 1526 0 0 3.5
+2 2324 516 0 0 3.5
+0
+0101000
++725 0 -725 182 *
+Wi
+0101000
++389 0 -395 0 -724 0 +724 182 *
+Fa
+0 1e-07 516 0
+0101000
++388 0 *
+Ed
+ 1e-07 1 1 0
+1 1527 0 0 3.5
+2 2325 518 0 0 3.5
+2 2326 517 0 0 3.5
+0
+0101000
++723 0 -723 172 *
+Wi
+0101000
++386 0 -392 0 -722 0 +722 172 *
+Fa
+0 1e-07 517 0
+0101000
++385 0 *
+Ed
+ 1e-07 1 1 0
+1 1528 0 0 3.5
+2 2327 519 0 0 3.5
+0
+0101000
++721 0 -721 182 *
+Wi
+0101000
++383 0 -389 0 -720 0 +720 182 *
+Fa
+0 1e-07 614 0
+0101000
++382 0 *
+Ed
+ 1e-07 1 1 0
+1 1529 0 0 3.5
+2 2328 518 0 0 3.5
+0
+0101000
++719 0 -719 172 *
+Wi
+0101000
++380 0 -386 0 -718 0 +718 172 *
+Fa
+0 1e-07 518 0
+0101000
++379 0 *
+Ed
+ 1e-07 1 1 0
+1 1530 0 0 3.5
+2 2329 520 0 0 3.5
+2 2330 519 0 0 3.5
+0
+0101000
++717 0 -717 182 *
+Wi
+0101000
++377 0 -383 0 -716 0 +716 182 *
+Fa
+0 1e-07 519 0
+0101000
++376 0 *
+Ed
+ 1e-07 1 1 0
+1 1531 0 0 3.5
+2 2331 521 0 0 3.5
+0
+0101000
++715 0 -715 172 *
+Wi
+0101000
++374 0 -380 0 -714 0 +714 172 *
+Fa
+0 1e-07 615 0
+0101000
++373 0 *
+Ed
+ 1e-07 1 1 0
+1 1532 0 0 3.5
+2 2332 522 0 0 3.5
+2 2333 520 0 0 3.5
+0
+0101000
++713 0 -713 182 *
+Wi
+0101000
++371 0 -377 0 -712 0 +712 182 *
+Fa
+0 1e-07 520 0
+0101000
++370 0 *
+Ed
+ 1e-07 1 1 0
+1 1533 0 0 3.5
+2 2334 523 0 0 3.5
+2 2335 521 0 0 3.5
+0
+0101000
++711 0 -711 172 *
+Wi
+0101000
++368 0 -374 0 -710 0 +710 172 *
+Fa
+0 1e-07 521 0
+0101000
++367 0 *
+Ed
+ 1e-07 1 1 0
+1 1534 0 0 3.5
+2 2336 522 0 0 3.5
+0
+0101000
++709 0 -709 182 *
+Wi
+0101000
++365 0 -371 0 -708 0 +708 182 *
+Fa
+0 1e-07 522 0
+0101000
++364 0 *
+Ed
+ 1e-07 1 1 0
+1 1535 0 0 3.5
+2 2337 524 0 0 3.5
+2 2338 523 0 0 3.5
+0
+0101000
++707 0 -707 172 *
+Wi
+0101000
++362 0 -368 0 -706 0 +706 172 *
+Fa
+0 1e-07 523 0
+0101000
++361 0 *
+Ed
+ 1e-07 1 1 0
+1 1536 0 0 3.5
+2 2339 525 0 0 3.5
+0
+0101000
++705 0 -705 182 *
+Wi
+0101000
++359 0 -365 0 -704 0 +704 182 *
+Fa
+0 1e-07 616 0
+0101000
++358 0 *
+Ed
+ 1e-07 1 1 0
+1 1537 0 0 3.5
+2 2340 524 0 0 3.5
+0
+0101000
++703 0 -703 172 *
+Wi
+0101000
++356 0 -362 0 -702 0 +702 172 *
+Fa
+0 1e-07 524 0
+0101000
++355 0 *
+Ed
+ 1e-07 1 1 0
+1 1538 0 0 3.5
+2 2341 526 0 0 3.5
+2 2342 525 0 0 3.5
+0
+0101000
++701 0 -701 182 *
+Wi
+0101000
++353 0 -359 0 -700 0 +700 182 *
+Fa
+0 1e-07 525 0
+0101000
++352 0 *
+Ed
+ 1e-07 1 1 0
+1 1539 0 0 3.5
+2 2343 527 0 0 3.5
+0
+0101000
++699 0 -699 172 *
+Wi
+0101000
++350 0 -356 0 -698 0 +698 172 *
+Fa
+0 1e-07 617 0
+0101000
++349 0 *
+Ed
+ 1e-07 1 1 0
+1 1540 0 0 3.5
+2 2344 528 0 0 3.5
+2 2345 526 0 0 3.5
+0
+0101000
++697 0 -697 182 *
+Wi
+0101000
++347 0 -353 0 -696 0 +696 182 *
+Fa
+0 1e-07 526 0
+0101000
++346 0 *
+Ed
+ 1e-07 1 1 0
+1 1541 0 0 3.5
+2 2346 529 0 0 3.5
+2 2347 527 0 0 3.5
+0
+0101000
++695 0 -695 172 *
+Wi
+0101000
++344 0 -350 0 -694 0 +694 172 *
+Fa
+0 1e-07 527 0
+0101000
++343 0 *
+Ed
+ 1e-07 1 1 0
+1 1542 0 0 3.5
+2 2348 528 0 0 3.5
+0
+0101000
++693 0 -693 182 *
+Wi
+0101000
++341 0 -347 0 -692 0 +692 182 *
+Fa
+0 1e-07 528 0
+0101000
++340 0 *
+Ed
+ 1e-07 1 1 0
+1 1543 0 0 3.5
+2 2349 530 0 0 3.5
+2 2350 529 0 0 3.5
+0
+0101000
++691 0 -691 172 *
+Wi
+0101000
++338 0 -344 0 -690 0 +690 172 *
+Fa
+0 1e-07 529 0
+0101000
++337 0 *
+Ed
+ 1e-07 1 1 0
+1 1544 0 0 3.5
+2 2351 531 0 0 3.5
+0
+0101000
++689 0 -689 182 *
+Wi
+0101000
++335 0 -341 0 -688 0 +688 182 *
+Fa
+0 1e-07 618 0
+0101000
++334 0 *
+Ed
+ 1e-07 1 1 0
+1 1545 0 0 3.5
+2 2352 530 0 0 3.5
+0
+0101000
++687 0 -687 172 *
+Wi
+0101000
++332 0 -338 0 -686 0 +686 172 *
+Fa
+0 1e-07 530 0
+0101000
++331 0 *
+Ed
+ 1e-07 1 1 0
+1 1546 0 0 3.5
+2 2353 532 0 0 3.5
+2 2354 531 0 0 3.5
+0
+0101000
++685 0 -685 182 *
+Wi
+0101000
++329 0 -335 0 -684 0 +684 182 *
+Fa
+0 1e-07 531 0
+0101000
++328 0 *
+Ed
+ 1e-07 1 1 0
+1 1547 0 0 3.5
+2 2355 533 0 0 3.5
+0
+0101000
++683 0 -683 172 *
+Wi
+0101000
++326 0 -332 0 -682 0 +682 172 *
+Fa
+0 1e-07 619 0
+0101000
++325 0 *
+Ed
+ 1e-07 1 1 0
+1 1548 0 0 3.5
+2 2356 534 0 0 3.5
+2 2357 532 0 0 3.5
+0
+0101000
++681 0 -681 182 *
+Wi
+0101000
++323 0 -329 0 -680 0 +680 182 *
+Fa
+0 1e-07 532 0
+0101000
++322 0 *
+Ed
+ 1e-07 1 1 0
+1 1549 0 0 3.5
+2 2358 535 0 0 3.5
+2 2359 533 0 0 3.5
+0
+0101000
++679 0 -679 172 *
+Wi
+0101000
++320 0 -326 0 -678 0 +678 172 *
+Fa
+0 1e-07 533 0
+0101000
++319 0 *
+Ed
+ 1e-07 1 1 0
+1 1550 0 0 3.5
+2 2360 534 0 0 3.5
+0
+0101000
++677 0 -677 182 *
+Wi
+0101000
++317 0 -323 0 -676 0 +676 182 *
+Fa
+0 1e-07 534 0
+0101000
++316 0 *
+Ed
+ 1e-07 1 1 0
+1 1551 0 0 3.5
+2 2361 536 0 0 3.5
+2 2362 535 0 0 3.5
+0
+0101000
++675 0 -675 172 *
+Wi
+0101000
++314 0 -320 0 -674 0 +674 172 *
+Fa
+0 1e-07 535 0
+0101000
++313 0 *
+Ve
+1e-07
+22.3488637857124 -0.103285162141171 -6.75
+0 0
+0101101
+Ed
+ 5.4962741650995e-15 1 1 0
+1 1552 0 -3.5 -2.66453525910037e-15
+2 2363 620 181 -3.5 -2.66453525910037e-15
+2 2364 537 189 -3.5 -2.66453525910037e-15
+0
+0101000
++673 0 -311 0 *
+Ed
+ 1e-07 1 1 0
+1 1424 0 0.157382650922507 0.785375477039538
+0
+0101000
++311 191 -677 0 *
+Wi
+0101100
+-672 181 +310 0 -317 181 +309 190 *
+Fa
+0 1e-07 620 0
+0101000
++308 180 *
+Ed
+ 1e-07 1 1 0
+1 1553 0 0 3.5
+2 2365 536 0 0 3.5
+0
+0101000
++671 0 -671 172 *
+Wi
+0101000
++306 0 -314 0 -670 0 +670 172 *
+Fa
+0 1e-07 536 0
+0101000
++305 0 *
+Ed
+ 1e-07 1 1 0
+1 1426 0 0.122452388467585 0.69813170079773
+2 2137 537 0 0.122452388467585 0.69813170079773
+2 2138 537 186 0.122452388467585 0.69813170079773
+0
+0101000
++311 192 -669 0 *
+Ed
+ 1e-07 1 1 0
+1 1554 0 0 3.5
+2 2366 538 0 0 3.5
+2 2367 537 0 0 3.5
+0
+0101000
++669 0 -669 172 *
+Wi
+0101100
+-303 189 -310 0 -302 189 +668 184 *
+Fa
+0 1e-07 537 0
+0101000
++301 192 *
+Ed
+ 1e-07 1 1 0
+1 1555 0 0 3.5
+2 2368 539 0 0 3.5
+0
+0101000
++667 0 -667 172 *
+Wi
+0101000
++299 0 -306 0 -666 0 +666 172 *
+Fa
+0 1e-07 621 0
+0101000
++298 0 *
+Ed
+ 1e-07 1 1 0
+1 1556 0 0 3.5
+2 2369 538 0 0 3.5
+2 2370 540 0 0 3.5
+0
+0101000
++665 0 -665 172 *
+Wi
+0101000
++302 0 -296 0 -664 0 +664 172 *
+Fa
+0 1e-07 538 0
+0101000
++295 0 *
+Ed
+ 1e-07 1 1 0
+1 1557 0 0 3.5
+2 2371 541 0 0 3.5
+2 2372 539 0 0 3.5
+0
+0101000
++663 0 -663 172 *
+Wi
+0101000
++293 0 -299 0 -662 0 +662 172 *
+Fa
+0 1e-07 539 0
+0101000
++292 0 *
+Ed
+ 1e-07 1 1 0
+1 1558 0 0 3.5
+2 2373 540 0 0 3.5
+0
+0101000
++661 0 -661 172 *
+Wi
+0101000
++296 0 -290 0 -660 0 +660 172 *
+Fa
+0 1e-07 540 0
+0101000
++289 0 *
+Ed
+ 1e-07 1 1 0
+1 1559 0 0 3.5
+2 2374 542 0 0 3.5
+2 2375 541 0 0 3.5
+0
+0101000
++659 0 -659 172 *
+Wi
+0101000
++287 0 -293 0 -658 0 +658 172 *
+Fa
+0 1e-07 541 0
+0101000
++286 0 *
+Ed
+ 1e-07 1 1 0
+1 1560 0 0 3.5
+2 2376 543 0 0 3.5
+0
+0101000
++657 0 -657 172 *
+Wi
+0101000
++290 0 -284 0 -656 0 +656 172 *
+Fa
+0 1e-07 622 0
+0101000
++283 0 *
+Ed
+ 1e-07 1 1 0
+1 1561 0 0 3.5
+2 2377 542 0 0 3.5
+0
+0101000
++655 0 -655 172 *
+Wi
+0101000
++281 0 -287 0 -654 0 +654 172 *
+Fa
+0 1e-07 542 0
+0101000
++280 0 *
+Ed
+ 1e-07 1 1 0
+1 1562 0 0 3.5
+2 2378 543 0 0 3.5
+2 2379 544 0 0 3.5
+0
+0101000
++653 0 -653 172 *
+Wi
+0101000
++284 0 -278 0 -652 0 +652 172 *
+Fa
+0 1e-07 543 0
+0101000
++277 0 *
+Ed
+ 1e-07 1 1 0
+1 1563 0 0 3.5
+2 2380 545 0 0 3.5
+0
+0101000
++651 0 -651 172 *
+Wi
+0101000
++275 0 -281 0 -650 0 +650 172 *
+Fa
+0 1e-07 623 0
+0101000
++274 0 *
+Ed
+ 1e-07 1 1 0
+1 1564 0 0 3.5
+2 2381 544 0 0 3.5
+2 2382 546 0 0 3.5
+0
+0101000
++649 0 -649 172 *
+Wi
+0101000
++278 0 -272 0 -648 0 +648 172 *
+Fa
+0 1e-07 544 0
+0101000
++271 0 *
+Ed
+ 1e-07 1 1 0
+1 1565 0 0 3.5
+2 2383 547 0 0 3.5
+2 2384 545 0 0 3.5
+0
+0101000
++647 0 -647 172 *
+Wi
+0101000
++269 0 -275 0 -646 0 +646 172 *
+Fa
+0 1e-07 545 0
+0101000
++268 0 *
+Ed
+ 1e-07 1 1 0
+1 1566 0 0 3.5
+2 2385 546 0 0 3.5
+0
+0101000
++645 0 -645 172 *
+Wi
+0101000
++272 0 -266 0 -644 0 +644 172 *
+Fa
+0 1e-07 546 0
+0101000
++265 0 *
+Ed
+ 1e-07 1 1 0
+1 1567 0 0 3.5
+2 2386 548 0 0 3.5
+2 2387 547 0 0 3.5
+0
+0101000
++643 0 -643 172 *
+Wi
+0101000
++263 0 -269 0 -642 0 +642 172 *
+Fa
+0 1e-07 547 0
+0101000
++262 0 *
+Ed
+ 1e-07 1 1 0
+1 1568 0 0 3.5
+2 2388 549 0 0 3.5
+0
+0101000
++641 0 -641 172 *
+Wi
+0101000
++266 0 -260 0 -640 0 +640 172 *
+Fa
+0 1e-07 624 0
+0101000
++259 0 *
+Ed
+ 1e-07 1 1 0
+1 1569 0 0 3.5
+2 2389 548 0 0 3.5
+0
+0101000
++639 0 -639 172 *
+Wi
+0101000
++257 0 -263 0 -638 0 +638 172 *
+Fa
+0 1e-07 548 0
+0101000
++256 0 *
+Ed
+ 1e-07 1 1 0
+1 1570 0 0 3.5
+2 2390 549 0 0 3.5
+2 2391 550 0 0 3.5
+0
+0101000
++637 0 -637 172 *
+Wi
+0101000
++260 0 -254 0 -636 0 +636 172 *
+Fa
+0 1e-07 549 0
+0101000
++253 0 *
+Ed
+ 1e-07 1 1 0
+1 1571 0 0 3.5
+2 2392 551 0 0 3.5
+0
+0101000
++635 0 -635 172 *
+Wi
+0101000
++251 0 -257 0 -634 0 +634 172 *
+Fa
+0 1e-07 625 0
+0101000
++250 0 *
+Ed
+ 1e-07 1 1 0
+1 1572 0 0 3.5
+2 2393 550 0 0 3.5
+2 2394 552 0 0 3.5
+0
+0101000
++633 0 -633 172 *
+Wi
+0101000
++254 0 -248 0 -632 0 +632 172 *
+Fa
+0 1e-07 550 0
+0101000
++247 0 *
+Ed
+ 1e-07 1 1 0
+1 1573 0 0 3.5
+2 2395 553 0 0 3.5
+2 2396 551 0 0 3.5
+0
+0101000
++631 0 -631 172 *
+Wi
+0101000
++245 0 -251 0 -630 0 +630 172 *
+Fa
+0 1e-07 551 0
+0101000
++244 0 *
+Ed
+ 1e-07 1 1 0
+1 1574 0 0 3.5
+2 2397 552 0 0 3.5
+0
+0101000
++629 0 -629 172 *
+Wi
+0101000
++248 0 -242 0 -628 0 +628 172 *
+Fa
+0 1e-07 552 0
+0101000
++241 0 *
+Ed
+ 1e-07 1 1 0
+1 1575 0 0 3.5
+2 2398 554 0 0 3.5
+2 2399 553 0 0 3.5
+0
+0101000
++627 0 -627 172 *
+Wi
+0101000
++239 0 -245 0 -626 0 +626 172 *
+Fa
+0 1e-07 553 0
+0101000
++238 0 *
+Ed
+ 1e-07 1 1 0
+1 1576 0 0 3.5
+2 2400 555 0 0 3.5
+0
+0101000
++625 0 -625 172 *
+Wi
+0101000
++242 0 -236 0 -624 0 +624 172 *
+Fa
+0 1e-07 626 0
+0101000
++235 0 *
+Ed
+ 1e-07 1 1 0
+1 1577 0 0 3.5
+2 2401 554 0 0 3.5
+0
+0101000
++623 0 -623 172 *
+Wi
+0101000
++233 0 -239 0 -622 0 +622 172 *
+Fa
+0 1e-07 554 0
+0101000
++232 0 *
+Ed
+ 1e-07 1 1 0
+1 1578 0 0 3.5
+2 2402 555 0 0 3.5
+2 2403 556 0 0 3.5
+0
+0101000
++621 0 -621 172 *
+Wi
+0101000
++236 0 -230 0 -620 0 +620 172 *
+Fa
+0 1e-07 555 0
+0101000
++229 0 *
+Ed
+ 1e-07 1 1 0
+1 1579 0 0 3.5
+2 2404 557 0 0 3.5
+0
+0101000
++619 0 -619 172 *
+Wi
+0101000
++227 0 -233 0 -618 0 +618 172 *
+Fa
+0 1e-07 627 0
+0101000
++226 0 *
+Ed
+ 1e-07 1 1 0
+1 1580 0 0 3.5
+2 2405 556 0 0 3.5
+2 2406 558 0 0 3.5
+0
+0101000
++617 0 -617 172 *
+Wi
+0101000
++230 0 -224 0 -616 0 +616 172 *
+Fa
+0 1e-07 556 0
+0101000
++223 0 *
+Ed
+ 1e-07 1 1 0
+1 1581 0 0 3.5
+2 2407 559 0 0 3.5
+2 2408 557 0 0 3.5
+0
+0101000
++615 0 -615 172 *
+Wi
+0101000
++221 0 -227 0 -614 0 +614 172 *
+Fa
+0 1e-07 557 0
+0101000
++220 0 *
+Ed
+ 1e-07 1 1 0
+1 1582 0 0 3.5
+2 2409 558 0 0 3.5
+0
+0101000
++613 0 -613 172 *
+Wi
+0101000
++224 0 -218 0 -612 0 +612 172 *
+Fa
+0 1e-07 558 0
+0101000
++217 0 *
+Ed
+ 1e-07 1 1 0
+1 1583 0 0 3.5
+2 2410 560 0 0 3.5
+2 2411 559 0 0 3.5
+0
+0101000
++611 0 -611 172 *
+Wi
+0101000
++215 0 -221 0 -610 0 +610 172 *
+Fa
+0 1e-07 559 0
+0101000
++214 0 *
+Ed
+ 1e-07 1 1 0
+1 1584 0 0 3.5
+2 2412 561 0 0 3.5
+0
+0101000
++609 0 -609 172 *
+Wi
+0101000
++218 0 -212 0 -608 0 +608 172 *
+Fa
+0 1e-07 628 0
+0101000
++211 0 *
+Ed
+ 1e-07 1 1 0
+1 1585 0 0 3.5
+2 2413 560 0 0 3.5
+0
+0101000
++607 0 -607 172 *
+Wi
+0101000
++209 0 -215 0 -606 0 +606 172 *
+Fa
+0 1e-07 560 0
+0101000
++208 0 *
+Ed
+ 1e-07 1 1 0
+1 1586 0 0 3.5
+2 2414 561 0 0 3.5
+2 2415 562 0 0 3.5
+0
+0101000
++605 0 -605 172 *
+Wi
+0101000
++212 0 -206 0 -604 0 +604 172 *
+Fa
+0 1e-07 561 0
+0101000
++205 0 *
+Ed
+ 1e-07 1 1 0
+1 1587 0 0 3.5
+2 2416 563 0 0 3.5
+0
+0101000
++603 0 -603 172 *
+Wi
+0101000
++203 0 -209 0 -602 0 +602 172 *
+Fa
+0 1e-07 629 0
+0101000
++202 0 *
+Ed
+ 1e-07 1 1 0
+1 1588 0 0 3.5
+2 2417 562 0 0 3.5
+2 2418 564 0 0 3.5
+0
+0101000
++601 0 -601 172 *
+Wi
+0101000
++206 0 -200 0 -600 0 +600 172 *
+Fa
+0 1e-07 562 0
+0101000
++199 0 *
+Ed
+ 1e-07 1 1 0
+1 1589 0 0 3.5
+2 2419 565 0 0 3.5
+2 2420 563 0 0 3.5
+0
+0101000
++599 0 -599 172 *
+Wi
+0101000
++197 0 -203 0 -598 0 +598 172 *
+Fa
+0 1e-07 563 0
+0101000
++196 0 *
+Ed
+ 1e-07 1 1 0
+1 1590 0 0 3.5
+2 2421 564 0 0 3.5
+0
+0101000
++597 0 -597 172 *
+Wi
+0101000
++200 0 -194 0 -596 0 +596 172 *
+Fa
+0 1e-07 564 0
+0101000
++193 0 *
+Ed
+ 1e-07 1 1 0
+1 1591 0 0 3.5
+2 2422 566 0 0 3.5
+2 2423 565 0 0 3.5
+0
+0101000
++595 0 -595 172 *
+Wi
+0101000
++191 0 -197 0 -594 0 +594 172 *
+Fa
+0 1e-07 565 0
+0101000
++190 0 *
+Ed
+ 1e-07 1 1 0
+1 1592 0 0 3.5
+2 2424 567 0 0 3.5
+0
+0101000
++593 0 -593 172 *
+Wi
+0101000
++194 0 -188 0 -592 0 +592 172 *
+Fa
+0 1e-07 630 0
+0101000
++187 0 *
+Ed
+ 1e-07 1 1 0
+1 1593 0 0 3.5
+2 2425 566 0 0 3.5
+0
+0101000
++591 0 -591 172 *
+Wi
+0101000
++185 0 -191 0 -590 0 +590 172 *
+Fa
+0 1e-07 566 0
+0101000
++184 0 *
+Ed
+ 1e-07 1 1 0
+1 1594 0 0 3.5
+2 2426 567 0 0 3.5
+2 2427 568 0 0 3.5
+0
+0101000
++589 0 -589 172 *
+Wi
+0101000
++188 0 -182 0 -588 0 +588 172 *
+Fa
+0 1e-07 567 0
+0101000
++181 0 *
+Ed
+ 1e-07 1 1 0
+1 1595 0 0 3.5
+2 2428 569 0 0 3.5
+0
+0101000
++587 0 -587 172 *
+Wi
+0101000
++179 0 -185 0 -586 0 +586 172 *
+Fa
+0 1e-07 631 0
+0101000
++178 0 *
+Ed
+ 1e-07 1 1 0
+1 1596 0 0 3.5
+2 2429 568 0 0 3.5
+2 2430 570 0 0 3.5
+0
+0101000
++585 0 -585 172 *
+Wi
+0101000
++182 0 -176 0 -584 0 +584 172 *
+Fa
+0 1e-07 568 0
+0101000
++175 0 *
+Ed
+ 1e-07 1 1 0
+1 1597 0 0 3.5
+2 2431 571 0 0 3.5
+2 2432 569 0 0 3.5
+0
+0101000
++583 0 -583 172 *
+Wi
+0101000
++173 0 -179 0 -582 0 +582 172 *
+Fa
+0 1e-07 569 0
+0101000
++172 0 *
+Ed
+ 1e-07 1 1 0
+1 1598 0 0 3.5
+2 2433 570 0 0 3.5
+0
+0101000
++581 0 -581 172 *
+Wi
+0101000
++176 0 -170 0 -580 0 +580 172 *
+Fa
+0 1e-07 570 0
+0101000
++169 0 *
+Ed
+ 1e-07 1 1 0
+1 1599 0 0 3.5
+2 2434 572 0 0 3.5
+2 2435 571 0 0 3.5
+0
+0101000
++579 0 -579 172 *
+Wi
+0101000
++167 0 -173 0 -578 0 +578 172 *
+Fa
+0 1e-07 571 0
+0101000
++166 0 *
+Ed
+ 1e-07 1 1 0
+1 1600 0 0 3.5
+2 2436 573 0 0 3.5
+0
+0101000
++577 0 -577 172 *
+Wi
+0101000
++170 0 -164 0 -576 0 +576 172 *
+Fa
+0 1e-07 632 0
+0101000
++163 0 *
+Ed
+ 1e-07 1 1 0
+1 1601 0 0 3.5
+2 2437 572 0 0 3.5
+0
+0101000
++575 0 -575 172 *
+Wi
+0101000
++161 0 -167 0 -574 0 +574 172 *
+Fa
+0 1e-07 572 0
+0101000
++160 0 *
+Ed
+ 1e-07 1 1 0
+1 1602 0 0 3.5
+2 2438 573 0 0 3.5
+2 2439 574 0 0 3.5
+0
+0101000
++573 0 -573 172 *
+Wi
+0101000
++164 0 -158 0 -572 0 +572 172 *
+Fa
+0 1e-07 573 0
+0101000
++157 0 *
+Ed
+ 1e-07 1 1 0
+1 1603 0 0 3.5
+2 2440 575 0 0 3.5
+0
+0101000
++571 0 -571 172 *
+Wi
+0101000
++155 0 -161 0 -570 0 +570 172 *
+Fa
+0 1e-07 633 0
+0101000
++154 0 *
+Ed
+ 1e-07 1 1 0
+1 1604 0 0 3.5
+2 2441 574 0 0 3.5
+2 2442 576 0 0 3.5
+0
+0101000
++569 0 -569 172 *
+Wi
+0101000
++158 0 -152 0 -568 0 +568 172 *
+Fa
+0 1e-07 574 0
+0101000
++151 0 *
+Ed
+ 1e-07 1 1 0
+1 1605 0 0 3.5
+2 2443 577 0 0 3.5
+2 2444 575 0 0 3.5
+0
+0101000
++567 0 -567 172 *
+Wi
+0101000
++149 0 -155 0 -566 0 +566 172 *
+Fa
+0 1e-07 575 0
+0101000
++148 0 *
+Ed
+ 1e-07 1 1 0
+1 1606 0 0 3.5
+2 2445 576 0 0 3.5
+0
+0101000
++565 0 -565 172 *
+Wi
+0101000
++152 0 -146 0 -564 0 +564 172 *
+Fa
+0 1e-07 576 0
+0101000
++145 0 *
+Ed
+ 1e-07 1 1 0
+1 1607 0 0 3.5
+2 2446 578 0 0 3.5
+2 2447 577 0 0 3.5
+0
+0101000
++563 0 -563 172 *
+Wi
+0101000
++143 0 -149 0 -562 0 +562 172 *
+Fa
+0 1e-07 577 0
+0101000
++142 0 *
+Ed
+ 1e-07 1 1 0
+1 1608 0 0 3.5
+2 2448 579 0 0 3.5
+0
+0101000
++561 0 -561 172 *
+Wi
+0101000
++146 0 -140 0 -560 0 +560 172 *
+Fa
+0 1e-07 634 0
+0101000
++139 0 *
+Ed
+ 1e-07 1 1 0
+1 1609 0 0 3.5
+2 2449 578 0 0 3.5
+0
+0101000
++559 0 -559 172 *
+Wi
+0101000
++137 0 -143 0 -558 0 +558 172 *
+Fa
+0 1e-07 578 0
+0101000
++136 0 *
+Ed
+ 1e-07 1 1 0
+1 1610 0 0 3.5
+2 2450 579 0 0 3.5
+2 2451 580 0 0 3.5
+0
+0101000
++557 0 -557 172 *
+Wi
+0101000
++140 0 -134 0 -556 0 +556 172 *
+Fa
+0 1e-07 579 0
+0101000
++133 0 *
+Ed
+ 1e-07 1 1 0
+1 1611 0 0 3.5
+2 2452 581 0 0 3.5
+0
+0101000
++555 0 -555 172 *
+Wi
+0101000
++131 0 -137 0 -554 0 +554 172 *
+Fa
+0 1e-07 635 0
+0101000
++130 0 *
+Ed
+ 1e-07 1 1 0
+1 1612 0 0 3.5
+2 2453 580 0 0 3.5
+2 2454 582 0 0 3.5
+0
+0101000
++553 0 -553 172 *
+Wi
+0101000
++134 0 -128 0 -552 0 +552 172 *
+Fa
+0 1e-07 580 0
+0101000
++127 0 *
+Ed
+ 1e-07 1 1 0
+1 1613 0 0 3.5
+2 2455 583 0 0 3.5
+2 2456 581 0 0 3.5
+0
+0101000
++551 0 -551 172 *
+Wi
+0101000
++125 0 -131 0 -550 0 +550 172 *
+Fa
+0 1e-07 581 0
+0101000
++124 0 *
+Ed
+ 1e-07 1 1 0
+1 1614 0 0 3.5
+2 2457 582 0 0 3.5
+0
+0101000
++549 0 -549 172 *
+Wi
+0101000
++128 0 -122 0 -548 0 +548 172 *
+Fa
+0 1e-07 582 0
+0101000
++121 0 *
+Ed
+ 1e-07 1 1 0
+1 1615 0 0 3.5
+2 2458 584 0 0 3.5
+2 2459 583 0 0 3.5
+0
+0101000
++547 0 -547 172 *
+Wi
+0101000
++119 0 -125 0 -546 0 +546 172 *
+Fa
+0 1e-07 583 0
+0101000
++118 0 *
+Ed
+ 1e-07 1 1 0
+1 1616 0 0 3.5
+2 2460 585 0 0 3.5
+0
+0101000
++545 0 -545 172 *
+Wi
+0101000
++122 0 -116 0 -544 0 +544 172 *
+Fa
+0 1e-07 636 0
+0101000
++115 0 *
+Ed
+ 1e-07 1 1 0
+1 1617 0 0 3.5
+2 2461 584 0 0 3.5
+0
+0101000
++543 0 -543 172 *
+Wi
+0101000
++113 0 -119 0 -542 0 +542 172 *
+Fa
+0 1e-07 584 0
+0101000
++112 0 *
+Ed
+ 1e-07 1 1 0
+1 1618 0 0 3.5
+2 2462 585 0 0 3.5
+2 2463 586 0 0 3.5
+0
+0101000
++541 0 -541 172 *
+Wi
+0101000
++116 0 -110 0 -540 0 +540 172 *
+Fa
+0 1e-07 585 0
+0101000
++109 0 *
+Ed
+ 1e-07 1 1 0
+1 1619 0 0 3.5
+2 2464 587 0 0 3.5
+0
+0101000
++539 0 -539 172 *
+Wi
+0101000
++107 0 -113 0 -538 0 +538 172 *
+Fa
+0 1e-07 637 0
+0101000
++106 0 *
+Ed
+ 1e-07 1 1 0
+1 1620 0 0 3.5
+2 2465 586 0 0 3.5
+2 2466 588 0 0 3.5
+0
+0101000
++537 0 -537 172 *
+Wi
+0101000
++110 0 -104 0 -536 0 +536 172 *
+Fa
+0 1e-07 586 0
+0101000
++103 0 *
+Ed
+ 1e-07 1 1 0
+1 1621 0 0 3.5
+2 2467 589 0 0 3.5
+2 2468 587 0 0 3.5
+0
+0101000
++535 0 -535 172 *
+Wi
+0101000
++101 0 -107 0 -534 0 +534 172 *
+Fa
+0 1e-07 587 0
+0101000
++100 0 *
+Ed
+ 1e-07 1 1 0
+1 1622 0 0 3.5
+2 2469 588 0 0 3.5
+0
+0101000
++533 0 -533 172 *
+Wi
+0101000
++104 0 -98 0 -532 0 +532 172 *
+Fa
+0 1e-07 588 0
+0101000
++97 0 *
+Ed
+ 1e-07 1 1 0
+1 1623 0 0 3.5
+2 2470 590 0 0 3.5
+2 2471 589 0 0 3.5
+0
+0101000
++531 0 -531 172 *
+Wi
+0101000
++95 0 -101 0 -530 0 +530 172 *
+Fa
+0 1e-07 589 0
+0101000
++94 0 *
+Ed
+ 1e-07 1 1 0
+1 1624 0 0 3.5
+2 2472 591 0 0 3.5
+0
+0101000
++529 0 -529 172 *
+Wi
+0101000
++98 0 -92 0 -528 0 +528 172 *
+Fa
+0 1e-07 638 0
+0101000
++91 0 *
+Ed
+ 1e-07 1 1 0
+1 1625 0 0 3.5
+2 2473 590 0 0 3.5
+0
+0101000
++527 0 -527 172 *
+Wi
+0101000
++89 0 -95 0 -526 0 +526 172 *
+Fa
+0 1e-07 590 0
+0101000
++88 0 *
+Ed
+ 1e-07 1 1 0
+1 1626 0 0 3.5
+2 2474 591 0 0 3.5
+2 2475 592 0 0 3.5
+0
+0101000
++525 0 -525 172 *
+Wi
+0101000
++92 0 -86 0 -524 0 +524 172 *
+Fa
+0 1e-07 591 0
+0101000
++85 0 *
+Ed
+ 1e-07 1 1 0
+1 1627 0 0 3.5
+2 2476 593 0 0 3.5
+0
+0101000
++523 0 -523 172 *
+Wi
+0101000
++83 0 -89 0 -522 0 +522 172 *
+Fa
+0 1e-07 639 0
+0101000
++82 0 *
+Ed
+ 1e-07 1 1 0
+1 1628 0 0 3.5
+2 2477 592 0 0 3.5
+2 2478 594 0 0 3.5
+0
+0101000
++521 0 -521 172 *
+Wi
+0101000
++86 0 -80 0 -520 0 +520 172 *
+Fa
+0 1e-07 592 0
+0101000
++79 0 *
+Ed
+ 1e-07 1 1 0
+1 1629 0 0 3.5
+2 2479 595 0 0 3.5
+2 2480 593 0 0 3.5
+0
+0101000
++519 0 -519 172 *
+Wi
+0101000
++77 0 -83 0 -518 0 +518 172 *
+Fa
+0 1e-07 593 0
+0101000
++76 0 *
+Ed
+ 1e-07 1 1 0
+1 1630 0 0 3.5
+2 2481 594 0 0 3.5
+0
+0101000
++517 0 -517 172 *
+Wi
+0101000
++80 0 -74 0 -516 0 +516 172 *
+Fa
+0 1e-07 594 0
+0101000
++73 0 *
+Ed
+ 1e-07 1 1 0
+1 1631 0 0 3.5
+2 2482 596 0 0 3.5
+2 2483 595 0 0 3.5
+0
+0101000
++515 0 -515 172 *
+Wi
+0101000
++71 0 -77 0 -514 0 +514 172 *
+Fa
+0 1e-07 595 0
+0101000
++70 0 *
+Ed
+ 1e-07 1 1 0
+1 1632 0 0 3.5
+2 2484 597 0 0 3.5
+0
+0101000
++513 0 -513 172 *
+Wi
+0101000
++74 0 -68 0 -512 0 +512 172 *
+Fa
+0 1e-07 640 0
+0101000
++67 0 *
+Ed
+ 1e-07 1 1 0
+1 1633 0 0 3.5
+2 2485 596 0 0 3.5
+0
+0101000
++511 0 -511 172 *
+Wi
+0101000
++65 0 -71 0 -510 0 +510 172 *
+Fa
+0 1e-07 596 0
+0101000
++64 0 *
+Ed
+ 1e-07 1 1 0
+1 1634 0 0 3.5
+2 2486 597 0 0 3.5
+2 2487 598 0 0 3.5
+0
+0101000
++509 0 -509 172 *
+Wi
+0101000
++68 0 -62 0 -508 0 +508 172 *
+Fa
+0 1e-07 597 0
+0101000
++61 0 *
+Ed
+ 1e-07 1 1 0
+1 1635 0 0 3.5
+2 2488 599 0 0 3.5
+0
+0101000
++507 0 -507 172 *
+Wi
+0101000
++59 0 -65 0 -506 0 +506 172 *
+Fa
+0 1e-07 641 0
+0101000
++58 0 *
+Ed
+ 1e-07 1 1 0
+1 1636 0 0 3.5
+2 2489 598 0 0 3.5
+2 2490 600 0 0 3.5
+0
+0101000
++505 0 -505 172 *
+Wi
+0101000
++62 0 -56 0 -504 0 +504 172 *
+Fa
+0 1e-07 598 0
+0101000
++55 0 *
+Ed
+ 1e-07 1 1 0
+1 1637 0 0 3.5
+2 2491 601 0 0 3.5
+2 2492 599 0 0 3.5
+0
+0101000
++503 0 -503 172 *
+Wi
+0101000
++53 0 -59 0 -502 0 +502 172 *
+Fa
+0 1e-07 599 0
+0101000
++52 0 *
+Ed
+ 1e-07 1 1 0
+1 1638 0 0 3.5
+2 2493 600 0 0 3.5
+0
+0101000
++501 0 -501 172 *
+Wi
+0101000
++56 0 -50 0 -500 0 +500 172 *
+Fa
+0 1e-07 600 0
+0101000
++49 0 *
+Ed
+ 1e-07 1 1 0
+1 1639 0 0 3.5
+2 2494 602 0 0 3.5
+2 2495 601 0 0 3.5
+0
+0101000
++499 0 -499 172 *
+Wi
+0101000
++47 0 -53 0 -498 0 +498 172 *
+Fa
+0 1e-07 601 0
+0101000
++46 0 *
+Ed
+ 1e-07 1 1 0
+1 1640 0 0 3.5
+2 2496 603 0 0 3.5
+0
+0101000
++497 0 -497 172 *
+Wi
+0101000
++50 0 -44 0 -496 0 +496 172 *
+Fa
+0 1e-07 642 0
+0101000
++43 0 *
+Ed
+ 1e-07 1 1 0
+1 1641 0 0 3.5
+2 2497 602 0 0 3.5
+0
+0101000
++495 0 -495 172 *
+Wi
+0101000
++41 0 -47 0 -494 0 +494 172 *
+Fa
+0 1e-07 602 0
+0101000
++40 0 *
+Ed
+ 1e-07 1 1 0
+1 1642 0 0 3.5
+2 2498 603 0 0 3.5
+2 2499 604 0 0 3.5
+0
+0101000
++493 0 -493 172 *
+Wi
+0101000
++44 0 -38 0 -492 0 +492 172 *
+Fa
+0 1e-07 603 0
+0101000
++37 0 *
+Ed
+ 1e-07 1 1 0
+1 1643 0 0 3.5
+2 2500 605 0 0 3.5
+0
+0101000
++491 0 -491 172 *
+Wi
+0101000
++35 0 -41 0 -490 0 +490 172 *
+Fa
+0 1e-07 643 0
+0101000
++34 0 *
+Ed
+ 1e-07 1 1 0
+1 1644 0 0 3.5
+2 2501 604 0 0 3.5
+2 2502 605 0 0 3.5
+0
+0101000
++489 0 -489 172 *
+Wi
+0101000
++38 0 -32 0 -488 0 +488 172 *
+Fa
+0 1e-07 604 0
+0101000
++31 0 *
+Wi
+0101000
++32 0 -35 0 -487 0 +487 172 *
+Fa
+0 1e-07 605 0
+0101000
++29 0 *
+Wi
+0101000
+-480 0 *
+Fa
+0 1e-07 606 0
+0101000
+-27 0 *
+Ve
+3.5 0 1.125
+0 0
+0101101
+Ed
+1 1645 0 0 6.28318530717959
+2 2503 493 182 0 6.28318530717959
+2 2504 644 0 0 6.28318530717959
+0
+0101100
++25 0 -25 0 *
+Wi
+0101100
+-24 0 *
+Ve
+1.92823335063125e-06
+0 0 6.875
+0 0
+0101101
+Ed
+ 6.87499999999939e-08 1 1 0
+1 1646 0 3.14159265358979 9.42477796076938
+2 2505 492 0 3.14159265358979 9.42477796076938
+2 2506 645 0 3.14159265358979 9.42477796076938
+0
+0101100
++22 0 -22 0 *
+Wi
+0101100
++21 0 *
+Wi
+0101100
++474 190 -471 189 +776 190 -774 189 +772 190 -770 189 +768 190 -766 189 +764 190 -762 189
++760 190 -758 189 +756 190 -754 189 +752 190 -750 189 +748 190 -746 189 +744 190 -742 189
++740 190 -738 189 +736 190 -734 189 +732 190 -730 189 +728 190 -726 189 +724 190 -722 189
++720 190 -718 189 +716 190 -714 189 +712 190 -710 189 +708 190 -706 189 +704 190 -702 189
++700 190 -698 189 +696 190 -694 189 +692 190 -690 189 +688 190 -686 189 +684 190 -682 189
++680 190 -678 189 +676 190 -674 189 +309 190 -670 189 -303 189 -666 189 -664 189 -662 189
+-660 189 -658 189 -656 189 -654 189 -652 189 -650 189 -648 189 -646 189 -644 189 -642 189
+-640 189 -638 189 -636 189 -634 189 -632 189 -630 189 -628 189 -626 189 -624 189 -622 189
+-620 189 -618 189 -616 189 -614 189 -612 189 -610 189 -608 189 -606 189 -604 189 -602 189
+-600 189 -598 189 -596 189 -594 189 -592 189 -590 189 -588 189 -586 189 -584 189 -582 189
+-580 189 -578 189 -576 189 -574 189 -572 189 -570 189 -568 189 -566 189 -564 189 -562 189
+-560 189 -558 189 -556 189 -554 189 -552 189 -550 189 -548 189 -546 189 -544 189 -542 189
+-540 189 -538 189 -536 189 -534 189 -532 189 -530 189 -528 189 -526 189 -524 189 -522 189
+-520 189 -518 189 -516 189 -514 189 -512 189 -510 189 -508 189 -506 189 -504 189 -502 189
+-500 189 -498 189 -496 189 -494 189 -492 189 -490 189 -488 189 -487 189 *
+Fa
+0 1e-07 493 0
+0101000
++23 183 -20 194 +19 191 *
+Ve
+1e-07
+2.91666666666667 0 1.125
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1647 0 0 0.583333333333334
+3 2507 2508CN 644 0 0 0.583333333333334
+0
+0101000
+-25 0 +17 0 *
+Ed
+ 1e-07 1 1 0
+1 1648 0 0 6.28318530717959
+2 2509 644 0 0 6.28318530717959
+2 2510 646 0 0 6.28318530717959
+0
+0101100
++17 0 -17 0 *
+Wi
+0101100
++16 0 -24 0 +15 0 -16 0 *
+Fa
+0 1e-07 644 0
+0101000
++14 0 *
+Ve
+1e-07
+0.583333333333333 0 6.875
+0 0
+0101101
+Ed
+ 1e-07 1 1 0
+1 1649 0 0 0.583333333333333
+3 2511 2512CN 645 0 0 0.583333333333333
+0
+0101000
+-22 0 +12 0 *
+Ed
+ 1e-07 1 1 0
+1 1650 0 0 6.28318530717959
+2 2513 645 0 0 6.28318530717959
+2 2514 647 0 0 6.28318530717959
+0
+0101100
++12 0 -12 0 *
+Wi
+0101100
++11 0 -21 0 +10 0 -11 0 *
+Fa
+0 1e-07 645 0
+0101000
++9 0 *
+Wi
+0101000
+-15 0 *
+Fa
+0 1e-07 646 0
+0101000
+-7 0 *
+Wi
+0101000
+-10 0 *
+Fa
+0 1e-07 647 0
+0101000
+-5 0 *
+Sh
+0101100
++4362 37 -4357 37 +4352 42 +4010 46 +3923 60 -3918 62 -3912 37 -3908 62 -3905 37 -3902 62
+-3899 37 -3896 62 -3893 37 -3890 62 -3887 37 -3884 62 -3881 37 -3878 62 -3875 37 -3872 62
+-3869 37 -3866 62 -3863 37 -3860 62 -3857 37 -3854 62 -3851 37 -3848 62 -3845 37 -3842 62
+-3839 37 -3836 62 -3833 37 -3830 62 -3827 37 -3824 62 -3821 37 -3818 62 -3815 37 -3812 62
+-3809 37 -3806 62 -3803 37 -3800 62 -3797 37 -3794 62 -3791 37 -3788 62 -3785 37 -3782 62
+-3779 37 -3776 62 -3773 37 -3770 62 -3767 37 -3764 62 -3761 37 -3758 62 -3755 37 -3752 62
+-3749 37 -3746 62 -3743 37 -3740 62 -3737 37 -3734 62 -3731 37 -3728 62 -3725 37 -3722 62
+-3719 37 -3716 62 -3713 37 -3710 62 -3707 37 -3704 62 -3701 37 -3698 62 -3695 37 -3692 62
+-3689 37 -3686 62 -3683 37 -3680 62 -3677 37 -3674 62 -3671 37 -3668 62 -3665 37 -3662 62
+-3659 37 -3656 62 -3653 37 -3650 62 -3647 37 -3644 62 -3641 37 -3638 62 -3635 37 -3632 62
+-3629 37 -3624 62 -3621 37 -3617 37 -3614 37 -3611 37 -3608 37 -3605 37 -3602 37 -3599 37
+-3596 37 -3593 37 -3590 37 -3587 37 -3584 37 -3581 37 -3578 37 -3575 37 -3572 37 -3569 37
+-3566 37 -3563 37 -3560 37 -3557 37 -3554 37 -3551 37 -3548 37 -3545 37 -3542 37 -3539 37
+-3536 37 -3533 37 -3530 37 -3527 37 -3524 37 -3521 37 -3518 37 -3515 37 -3512 37 -3509 37
+-3506 37 -3503 37 -3500 37 -3497 37 -3494 37 -3491 37 -3488 37 -3485 37 -3482 37 -3479 37
+-3476 37 -3473 37 -3470 37 -3467 37 -3464 37 -3461 37 -3458 37 -3455 37 -3452 37 -3449 37
+-3446 37 -3443 37 -3440 37 -3437 37 -3434 37 -3431 37 -3428 37 -3425 37 -3422 37 -3419 37
+-3416 37 -3413 37 -3410 37 -3408 37 -3401 42 -3284 42 +3167 42 -3057 42 +2947 42 -2830 42
++2713 42 -2710 42 -2703 42 -2698 42 -2693 42 -2688 42 -2683 42 -2678 42 -2673 42 -2668 42
+-2663 42 -2658 42 -2653 42 -2650 42 +2643 42 +2638 42 +2633 42 +2628 42 +2623 42 +2618 42
++2613 42 +2608 42 +2603 42 +2598 42 +2593 42 +2590 42 -2583 42 -2578 42 -2573 42 -2570 42
++2563 42 +2558 42 +2553 42 +2550 42 +2548 75 -2540 37 +2533 42 -2526 42 -2523 42 -2516 42
+-2511 42 -2506 42 +2500 42 -2494 42 -2491 42 -2488 42 -2481 42 +2474 42 -2469 42 -2464 42
++2458 42 -2452 42 -2440 42 -2428 42 -2421 42 +2414 42 -2409 42 -2404 42 +2398 42 -2392 42
+-2389 42 -2386 42 -2379 42 +2372 42 -2367 42 -2362 42 +2356 42 -2350 42 -2338 42 -2326 42
+-2319 42 +2312 42 -2307 42 -2302 42 +2296 42 -2290 42 -2287 42 -2284 42 -2277 42 +2270 42
+-2265 42 -2260 42 +2254 42 -2248 42 -2236 42 -2224 42 -2217 42 +2210 42 -2205 42 -2200 42
++2194 42 -2188 42 -2186 42 -2183 42 -2180 42 -2177 42 -2174 42 -2171 42 -2168 42 -2165 42
+-2162 42 -2159 42 -2156 42 -2153 42 -2150 42 -2147 42 -2144 42 -2137 42 -2132 42 +2127 42
++2122 42 +2117 42 +2112 42 +2107 42 -2102 42 +2097 42 +2092 42 -2087 42 -2082 42 +2077 42
+-2072 42 +2067 42 +2062 42 +2057 42 -2052 42 +2047 42 -2042 42 +2037 42 +2032 42 +2027 42
+-2022 42 +2017 42 -2012 42 +2007 42 +2002 42 +1997 42 -1992 42 +1987 42 -1982 42 +1977 42
++1972 42 +1967 42 -1962 42 +1957 42 -1952 42 +1947 42 +1942 42 +1937 42 -1932 42 +1927 42
+-1922 42 +1917 42 +1912 42 +1907 42 -1902 42 +1897 42 +1892 42 +1887 42 +1884 42 +1877 42
+-1872 42 +1867 42 -1862 42 -1857 42 -1852 42 -1847 42 -1842 42 +1837 42 +1832 42 -1827 42
+-1822 42 +1817 42 -1812 42 +1807 42 -1802 42 -1797 42 -1792 42 +1787 42 -1782 42 +1777 42
+-1772 42 -1767 42 -1762 42 +1757 42 -1752 42 +1747 42 -1742 42 -1737 42 -1732 42 +1727 42
+-1722 42 +1717 42 -1712 42 -1707 42 -1702 42 +1697 42 -1692 42 +1687 42 -1682 42 -1677 42
+-1672 42 +1667 42 -1662 42 +1657 42 -1652 42 -1647 42 -1642 42 +1637 42 -1632 42 -1627 42
+-1624 42 -1621 42 -1614 42 +1607 42 -1602 42 -1597 42 +1591 42 -1585 42 -1582 42 -1579 42
+-1572 42 +1565 42 -1560 42 -1555 42 +1549 42 -1543 42 -1531 42 -1519 42 -1512 42 +1505 42
+-1500 42 -1495 42 +1489 42 -1483 42 -1480 42 -1477 42 -1470 42 +1463 42 -1458 42 -1453 42
++1447 42 -1441 42 -1429 42 -1417 42 -1410 42 +1403 42 -1398 42 -1393 42 +1387 42 -1381 42
+-1378 42 -1375 42 -1368 42 +1361 42 -1356 42 -1351 42 +1345 42 -1339 42 -1327 42 -1315 42
+-1308 42 +1301 42 -1296 42 -1291 42 +1285 42 -1279 42 -1277 42 -1274 42 -1271 42 -1268 42
+-1265 42 -1262 42 -1259 42 -1256 42 -1253 42 -1250 42 -1247 42 -1244 42 -1241 42 -1238 42
+-1235 42 +1233 90 +1231 91 -1220 92 -1209 102 -1204 37 -1199 62 +1197 42 +1192 42 +1190 42
++1188 42 +1186 42 -1179 42 -1174 42 -1169 42 -1166 42 -1159 42 -1154 42 -1149 42 -1146 42
++1144 42 +1142 42 +1140 42 +1138 42 -1131 42 -1126 42 -1121 42 -1118 42 -1111 42 -1106 42
+-1101 42 -1098 42 +1096 42 +1094 42 +1092 42 +1090 42 -1083 42 -1078 42 -1073 42 -1070 42
+-1063 42 -1058 42 -1053 42 -1050 42 +1048 42 +1046 42 -1044 122 +1042 123 -1040 42 -1038 42
+-1036 42 -1034 42 +1027 42 +1022 42 +1017 42 +1014 42 +1007 42 +1002 42 +997 42 +994 42
+-992 42 -990 42 -988 42 -986 42 +979 42 +974 42 +969 42 +966 42 +959 42 +954 42
++949 42 +946 42 -944 42 -942 42 -940 42 -938 42 +931 42 +926 42 +921 42 +918 42
++911 42 +906 42 +901 42 +898 42 -896 42 -894 42 +890 42 +887 42 -884 42 -882 42
+-878 42 -875 42 +872 42 +870 42 +865 37 +860 62 -855 42 -853 143 -851 144 -849 145
+-847 146 -845 147 -843 148 +841 149 +839 150 +837 151 +835 152 +833 153 +831 154 +830 155
++829 156 +824 42 +819 75 -814 167 +809 42 +804 166 +799 42 +797 170 -792 166 -787 42
+-485 178 -483 187 -478 178 -472 178 -468 166 -465 178 -462 166 -459 178 -456 166 -453 178
+-450 166 -447 178 -444 166 -441 178 -438 166 -435 178 -432 166 -429 178 -426 166 -423 178
+-420 166 -417 178 -414 166 -411 178 -408 166 -405 178 -402 166 -399 178 -396 166 -393 178
+-390 166 -387 178 -384 166 -381 178 -378 166 -375 178 -372 166 -369 178 -366 166 -363 178
+-360 166 -357 178 -354 166 -351 178 -348 166 -345 178 -342 166 -339 178 -336 166 -333 178
+-330 166 -327 178 -324 166 -321 178 -318 166 -315 178 -312 166 -307 178 -304 166 -300 166
+-297 166 -294 166 -291 166 -288 166 -285 166 -282 166 -279 166 -276 166 -273 166 -270 166
+-267 166 -264 166 -261 166 -258 166 -255 166 -252 166 -249 166 -246 166 -243 166 -240 166
+-237 166 -234 166 -231 166 -228 166 -225 166 -222 166 -219 166 -216 166 -213 166 -210 166
+-207 166 -204 166 -201 166 -198 166 -195 166 -192 166 -189 166 -186 166 -183 166 -180 166
+-177 166 -174 166 -171 166 -168 166 -165 166 -162 166 -159 166 -156 166 -153 166 -150 166
+-147 166 -144 166 -141 166 -138 166 -135 166 -132 166 -129 166 -126 166 -123 166 -120 166
+-117 166 -114 166 -111 166 -108 166 -105 166 -102 166 -99 166 -96 166 -93 166 -90 166
+-87 166 -84 166 -81 166 -78 166 -75 166 -72 166 -69 166 -66 166 -63 166 -60 166
+-57 166 -54 166 -51 166 -48 166 -45 166 -42 166 -39 166 -36 166 -33 166 -30 166
+-28 166 +26 178 +18 193 -13 178 -8 166 +6 178 +4 166 *
+So
+0100000
++3 0 *
+Co
+0100000
++4369 0 +2 0 *
++1 0
\ No newline at end of file
Modified: cgm/trunk/test/makept.cpp
--- cgm/trunk/test/makept.cpp 2007-12-11 17:58:50 UTC (rev 1465)
+++ cgm/trunk/test/makept.cpp 2007-12-11 17:59:18 UTC (rev 1466)
@@ -109,6 +109,14 @@
CubitStatus status = read_geometry(1, &argv);
if (status == CUBIT_FAILURE) exit(1);
+ argv = "./62_shaver1.brep";
+ status = read_geometry(1, &argv);
+ if (status == CUBIT_FAILURE) exit(1);
+ argv = "./72_shaver6.brep";
CubitVector vector(10,10,10);
DLIList<RefEntity*> free_entities;
gti->get_free_ref_entities(free_entities);
More information about the cgma-dev
