[cgma-dev] r1486 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Wed Dec 26 13:26:58 CST 2007
Author: janehu
Date: 2007-12-26 13:26:54 -0600 (Wed, 26 Dec 2007)
New Revision: 1486
Modified:
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.hpp
Log:
Added support for exporting standalone TopoDS_shell and TopoDS_Wire entities.
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-12-25 01:21:07 UTC (rev 1485)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-12-26 19:26:54 UTC (rev 1486)
@@ -137,6 +137,8 @@
OccToCGM = new std::map<int, TopologyBridge*>;
BodyList = new DLIList<OCCBody*>;
+ ShellList = new DLIList<OCCShell*>;
+ WireList = new DLIList<OCCLoop*>;
SurfaceList = new DLIList<OCCSurface*>;
CurveList = new DLIList<OCCCurve*>;
@@ -149,6 +151,13 @@
OCCQueryEngine::~OCCQueryEngine()
instance_ = NULL;
+ delete OCCMap;
+ delete[] OccToCGM;
+ delete[] BodyList;
+ delete[] ShellList;
+ delete[] WireList;
+ delete[] SurfaceList;
+ delete[] CurveList;
int OCCQueryEngine::get_major_version()
@@ -936,12 +945,26 @@
+ //Add standalone shells to export BRep file
+ for (i = 0; i < ShellList->size(); i++)
+ TopoDS_Shell *shell = ShellList->get_and_step()->get_TopoDS_Shell();
+ B.Add(Co, *shell);
for (i = 0; i < OCC_surfaces.size(); i++)
TopoDS_Face *face = OCC_surfaces.get_and_step()->get_TopoDS_Face();
B.Add(Co, *face);
+ //Add standalone wires to the export BRep file
+ for (i = 0; i < WireList->size(); i++)
+ TopoDS_Wire *wire = WireList->get_and_step()->get_TopoDS_Wire();
+ B.Add(Co, *wire);
for (i = 0; i < OCC_curves.size(); i++)
TopoDS_Edge *edge = OCC_curves.get_and_step()->get_TopoDS_Edge();
@@ -1016,13 +1039,13 @@
for (Ex.Init(aShape, TopAbs_SHELL, TopAbs_SOLID); Ex.More(); Ex.Next())
- tblist.append(populate_topology_bridge(TopoDS::Shell(Ex.Current())));
+ populate_topology_bridge(TopoDS::Shell(Ex.Current()), CUBIT_TRUE);
for (Ex.Init(aShape, TopAbs_FACE, TopAbs_SHELL); Ex.More(); Ex.Next())
tblist.append(populate_topology_bridge(TopoDS::Face(Ex.Current())));
for (Ex.Init(aShape, TopAbs_WIRE, TopAbs_FACE); Ex.More(); Ex.Next())
- tblist.append(populate_topology_bridge(TopoDS::Wire(Ex.Current())));
+ populate_topology_bridge(TopoDS::Wire(Ex.Current()), CUBIT_TRUE);
for (Ex.Init(aShape, TopAbs_EDGE, TopAbs_WIRE); Ex.More(); Ex.Next())
tblist.append(populate_topology_bridge(TopoDS::Edge(Ex.Current())));
@@ -1102,7 +1125,8 @@
return lump;
-OCCShell* OCCQueryEngine::populate_topology_bridge(TopoDS_Shell aShape)
+OCCShell* OCCQueryEngine::populate_topology_bridge(TopoDS_Shell aShape,
+ CubitBoolean standalone)
TopoDS_Shell *poshell = new TopoDS_Shell;
*poshell = aShape;
@@ -1116,6 +1140,8 @@
OCCMap->Bind(*poshell, iTotalTBCreated);
OccToCGM->insert(valType(iTotalTBCreated,
(TopologyBridge*)shell));
+ if(standalone)
+ ShellList->append(shell);
else
@@ -1158,7 +1184,8 @@
return surface;
-OCCLoop* OCCQueryEngine::populate_topology_bridge(TopoDS_Wire aShape)
+OCCLoop* OCCQueryEngine::populate_topology_bridge(TopoDS_Wire aShape,
TopoDS_Wire *powire = new TopoDS_Wire;
*powire = aShape;
@@ -1172,6 +1199,8 @@
OCCMap->Bind(*powire, iTotalTBCreated);
(TopologyBridge*)loop));
+ if(standalone)
+ WireList->append(loop);
else
@@ -1424,6 +1453,7 @@
Surface* surface = CAST_TO(children.get_and_step(), Surface);
unhook_Surface_from_OCC(surface);
+ ShellList->remove(CAST_TO(shell, OCCShell));
delete shell;
return CUBIT_SUCCESS;
@@ -1542,6 +1572,7 @@
Curve* curve = children.get_and_step()->curve();
unhook_Curve_from_OCC(curve);
+ WireList->remove(CAST_TO(loopsm, OCCLoop));
delete loopsm;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2007-12-25 01:21:07 UTC (rev 1485)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2007-12-26 19:26:54 UTC (rev 1486)
@@ -337,7 +337,9 @@
Point* populate_topology_bridge(TopoDS_Vertex aShape);
DLIList<OCCBody*> *BodyList ;
+ DLIList<OCCShell*> *ShellList; //standalone shell list
DLIList<OCCSurface*> *SurfaceList ;
+ DLIList<OCCLoop*> *WireList; //standalone wire list
DLIList<OCCCurve*> *CurveList ;
TopTools_DataMapOfShapeInteger* OCCMap;
std::map<int, TopologyBridge*>* OccToCGM;
@@ -348,8 +350,10 @@
private:
- OCCLoop* populate_topology_bridge(TopoDS_Wire aShape);
- OCCShell* populate_topology_bridge(TopoDS_Shell aShape);
+ OCCLoop* populate_topology_bridge(TopoDS_Wire aShape,
+ CubitBoolean standalone = CUBIT_FALSE);
+ OCCShell* populate_topology_bridge(TopoDS_Shell aShape,
+ CubitBoolean standalone = CUBIT_FALSE );
CubitStatus write_topology( const char* file_name,
DLIList<OCCBody*> &facet_bodies,
More information about the cgma-dev
