[AG-USERS] Re: AccessGrid Venue Client question
Dioselin Gonzalez
dioselin at purdue.edu
Wed Jan 26 17:01:35 CST 2005
Hello Arijit,
If I'm not mistaken, AG uses the temporary folder set up as your TEMP
environment variable. So changing this in your system properties
(control panel -> system -> advanced tab) should work.
Dio.-
Arijit Mukherjee wrote:
>Hi
>I am new to the AG Venue Client. I installed the software on WinXP, got
>a certificate, and I can join the venues. But it seems all the profile
>settings/temporary files/video files are stored in "C:\Document And
>Settings\<login-name>\Application Data". Our university has a set limit
>for the profile space for each user and whenever I run the venue client,
>the profile space is filled up almost instantly - which stops me from
>doing anything. Is there a way to tell the venue client to use another
>folder on my local hard drive? I tried setting the "run in" box in the
>program properties to another folder - but that had no effect.
>Regards
>Arijit
>"And when the night is cloudy,
>There is still a light that shines on me,
>Shine on until tomorrow, let it be. "
>John Lennon/Paul McCartney
More information about the ag-users
