[AG-TECH] Network and Bridge Questions
Christoph Willing
c.willing at uq.edu.au
Wed Nov 16 13:04:23 CST 2011
On 16/11/2011, at 2:39 PM, Christoph Willing wrote:
> I think I've found the problem - the previous fix was incomplete. In
> fact the previous fix worked with python 2.6 systems (which is what we
> were concerned about at the time) but gave the problem to python 2.5
> systems which were OK before the fix.
> I'll submit the fix and build new Debuntu
A new accessgrid3.2 package which includes the new fix is now
available for Debian Squeeze - just update/upgrade.
chris
> & Slackware packages and
> Doug will hopefully make new packages for Fedora etc. However it may
> take a while before they're all done; if you want to manually fix
> existing installations, here are the steps:
> 1. find the file AGXMLRPCServer.py
> (on lenny, /usr/lib/pymodules/python2.{5,6}/AccessGrid3/AccessGrid/
> AGXMLRPCServer.py)
> In that file, search for the line:
> if sys.version < (2,6):
> change it to
> if sys.version_info < (2,6):
> 2. in that same file, near the beginning before all the import lines,
> insert a new line:
> import sys
> chris
> On 15/11/2011, at 10:42 PM, Miguel A. Sáez Llorente wrote:
>> On 11/11/2011, at 4:24 AM, JULIAN CASTRO wrote:
>>> And second, we have a problem with our bridge trying to make it
>>> appear in the list of bridges: clients can see the bridge when
>>> clicking in “find additional bridges” but only in the first 5
>>> minutes after starting the bridge in the server. After that, no
>>> client can see the bridge, but if it is in the cache of bridges it
>>> is possible to connect to the bridge and it works. The problem is
>>> “discovering the bridge”. If we copy the cache file with our bridge
>>> on it in the clients pc´s, they can connect to the bridge but it
>>> is not a good approach.
>> Hello,
>> I'm having exactly the same issue. I recently migrated my AG server
>> to a new machine with a Debian Squeeze (2.6.32-5-686). I can start
>> the bridge without any problem. Here is the the 'ps' output:
>> 1201 2146 11.0 10.5 49336 26712 ? S 13:15 0:00 /
>> usr/bin/python /usr/bin/Bridge3.py --name=ES.USC --location=Spain --
>> registryUrl=http://www.accessgrid.org/registry/peers.txt
>> But, same as Julian, the clients can only see the bridge the first
>> few minutes after starting the bridge... I also get a new process
>> running when this happens:
>> 1201 2418 0.3 0.2 1736 640 ? S 13:20 0:00 /
>> usr/bin/QuickBridge -g 233.4.200.18 -m 10002 -u 51688 -i 600
>> At first i thought it was because i wasn't declaring some of the
>> variables like the --registryurl but doing so doesn't help either.
>> I also tried running the bridge manually instead of running it as a
>> service inside an script: Bridge3.py -n ES.USC -l Spain .
>> And last, i also made sure my server is using python2.5 as default
>> instead of 2.6 if that helps with something.
>> Any help on this will be very much appreciated.
>> Regards,
>> Soporte tareas multimedia - ATIC
>> Univ. Santiago de Compostela (USC)
>> Rúa de José María Suárez Núñez (Campus Sur) - Pavellón de Servicios
>> 15705 Santiago de Compostela - SPAIN
>> E-mail: miguelangel.saez at usc.es
>> Tel: (+34 881811000) ext. 13035 / Directo 881813035
>> Tel AG: (+34 881811000) ext. 16273 / Directo 881970144
>> Fax: +34 981547070
>> Web: http://www.usc.es/atic
>> https://connectnow.acrobat.com/miguelangelsaez770
> Christoph Willing +61 7 3365 8316
> Research Computing Centre
> University of Queensland
