[AG-TECH] Network and Bridge Questions
Christoph Willing
c.willing at uq.edu.au
Tue Nov 15 22:39:16 CST 2011
I think I've found the problem - the previous fix was incomplete. In
fact the previous fix worked with python 2.6 systems (which is what we
were concerned about at the time) but gave the problem to python 2.5
systems which were OK before the fix.
I'll submit the fix and build new Debuntu & Slackware packages and
Doug will hopefully make new packages for Fedora etc. However it may
take a while before they're all done; if you want to manually fix
existing installations, here are the steps:
1. find the file AGXMLRPCServer.py
(on lenny, /usr/lib/pymodules/python2.{5,6}/AccessGrid3/AccessGrid/
AGXMLRPCServer.py)
In that file, search for the line:
if sys.version < (2,6):
change it to
if sys.version_info < (2,6):
2. in that same file, near the beginning before all the import lines,
insert a new line:
import sys
chris
On 15/11/2011, at 10:42 PM, Miguel A. Sáez Llorente wrote:
> On 11/11/2011, at 4:24 AM, JULIAN CASTRO wrote:
>> And second, we have a problem with our bridge trying to make it
>> appear in the list of bridges: clients can see the bridge when
>> clicking in “find additional bridges” but only in the first 5
>> minutes after starting the bridge in the server. After that, no
>> client can see the bridge, but if it is in the cache of bridges it
>> is possible to connect to the bridge and it works. The problem is
>> “discovering the bridge”. If we copy the cache file with our bridge
>> on it in the clients pc´s, they can connect to the bridge but it
>> is not a good approach.
> Hello,
> I'm having exactly the same issue. I recently migrated my AG server
> to a new machine with a Debian Squeeze (2.6.32-5-686). I can start
> the bridge without any problem. Here is the the 'ps' output:
> 1201 2146 11.0 10.5 49336 26712 ? S 13:15 0:00 /
> usr/bin/python /usr/bin/Bridge3.py --name=ES.USC --location=Spain --
> registryUrl=http://www.accessgrid.org/registry/peers.txt
> But, same as Julian, the clients can only see the bridge the first
> few minutes after starting the bridge... I also get a new process
> running when this happens:
> 1201 2418 0.3 0.2 1736 640 ? S 13:20 0:00 /
> usr/bin/QuickBridge -g 233.4.200.18 -m 10002 -u 51688 -i 600
> At first i thought it was because i wasn't declaring some of the
> variables like the --registryurl but doing so doesn't help either.
> I also tried running the bridge manually instead of running it as a
> service inside an script: Bridge3.py -n ES.USC -l Spain .
> And last, i also made sure my server is using python2.5 as default
> instead of 2.6 if that helps with something.
> Any help on this will be very much appreciated.
> Regards,
> Soporte tareas multimedia - ATIC
> Univ. Santiago de Compostela (USC)
> Rúa de José María Suárez Núñez (Campus Sur) - Pavellón de Servicios
> 15705 Santiago de Compostela - SPAIN
> E-mail: miguelangel.saez at usc.es
> Tel: (+34 881811000) ext. 13035 / Directo 881813035
> Tel AG: (+34 881811000) ext. 16273 / Directo 881970144
> Fax: +34 981547070
> Web: http://www.usc.es/atic
> https://connectnow.acrobat.com/miguelangelsaez770
Christoph Willing +61 7 3365 8316
Research Computing Centre
University of Queensland
