[AG-TECH] Network and Bridge Questions
"Miguel A. Sáez Llorente"
miguelangel.saez at usc.es
Tue Nov 15 06:42:14 CST 2011
On 11/11/2011, at 4:24 AM, JULIAN CASTRO wrote:
> And second, we have a problem with our bridge trying to make it appear
> in the list of bridges: clients can see the bridge when clicking in
> “find additional bridges” but only in the first 5 minutes after
> starting the bridge in the server. After that, no client can see the
> bridge, but if it is in the cache of bridges it is possible to connect
> to the bridge and it works. The problem is “discovering the bridge”.
> If we copy the cache file with our bridge on it in the clients pc´s,
> they can connect to the bridge but it is not a good approach.
Hello,
I'm having exactly the same issue. I recently migrated my AG server to a
new machine with a Debian Squeeze (2.6.32-5-686). I can start the bridge
without any problem. Here is the the 'ps' output:
1201 2146 11.0 10.5 49336 26712 ? S 13:15 0:00
/usr/bin/python /usr/bin/Bridge3.py --name=ES.USC --location=Spain
--registryUrl=http://www.accessgrid.org/registry/peers.txt
But, same as Julian, the clients can only see the bridge the first few
minutes after starting the bridge... I also get a new process running
when this happens:
1201 2418 0.3 0.2 1736 640 ? S 13:20 0:00
/usr/bin/QuickBridge -g 233.4.200.18 -m 10002 -u 51688 -i 600
At first i thought it was because i wasn't declaring some of the
variables like the --registryurl but doing so doesn't help either.
I also tried running the bridge manually instead of running it as a
service inside an script: Bridge3.py -n ES.USC -l Spain .
And last, i also made sure my server is using python2.5 as default
instead of 2.6 if that helps with something.
Any help on this will be very much appreciated.
Soporte tareas multimedia - ATIC
Univ. Santiago de Compostela (USC)
Rúa de José María Suárez Núñez (Campus Sur) - Pavellón de Servicios
15705 Santiago de Compostela - SPAIN
E-mail: miguelangel.saez at usc.es
Tel: (+34 881811000) ext. 13035 / Directo 881813035
Tel AG: (+34 881811000) ext. 16273 / Directo 881970144
Fax: +34 981547070
Web: http://www.usc.es/atic
https://connectnow.acrobat.com/miguelangelsaez770
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20111115/9a9e1b7f/attachment.htm>
