[AG-TECH] Support for IPv6
Piers O'Hanlon
p.ohanlon at cs.ucl.ac.uk
Mon Jan 10 09:27:13 CST 2011
We enabled AccessGrid for IPv6 access in 2005 under the 6Net project. See:
http://www-mice.cs.ucl.ac.uk/6net/
The AG patches are clearly pretty old and probably won't work but the
general idea was that we created a AG-proxy entity which proxied the
AG SOAP calls and appropriately converted the room addressing from
IPv4 to IPv6 and then employed the IPv4-IPv4 gateway mentioned on that
page.
As Andrew mentions you can use embedded RP - there are a few software
IPv6 router implementations out there - e.g. pim6d, Quagga, Xorp and
probably others. You can also just use provider based IPv6 multicast
addressing - either way you'll need IPv6 Rendezvous ponut set up - or
you can just connect/peer with the m6bone (though I'm not sure how
active it is now). There's also some other providers playing ip6
mcast:
http://www.sixxs.net/faq/connectivity/?faq=multicast
Piers
On 10 January 2011 14:29, Alberto Rossini <albertorossini.iet at gmail.com> wrote:
> Hi,
> I'd like to try Access Grid with IPv6 addressing. Someone know if it is
> possibile?
> Can you suggest how to proceed in order to support two way communication
> among the partecipants of same venue session?
> Regards,
> Alberto Rossini
