[AG-TECH] Remote VenueVNC startup and shutdown
Jason Bell
j.bell at cqu.edu.au
Tue Feb 22 17:48:58 CST 2011
Colleagues
I am hoping that someone out there might have a "solution" to an issue I have.
Long story short, I have a dedicated machine outside our "network" which allows remote sites to easy connect to it as part of a VenueVNC session.
The problem is that this machine is not easy accessible (located in a machine room) and cannot be moved. The problem is that I would like to setup a system that everyday AG operators can connect to and launch a VenueVNC session when required (Note: the remote machine is a Linux machine). Obviously there are a few options, including such example like:
* Shell scripts that remotely connect (maybe via ssh) and start the VenueVNC service;
- An issue to consider is that ssh connections time out and when it does, it kills the VenueVNC session.
* A webserver that users can log into and via a website and launch appropriate service.
* Some other remote means (has any used a terminal server to do this);
- Note, I am not keen on using VNC, as it sends clear text passwords and I would like to make the process as simple as possible.
Obviously there are a few issues, such that the service may be required to started in different Virtual Venues and the duration for the session will differ.
Therefore, in an effort to save "re-inventing the wheel", has anyone implemented a system which would solve the problem posed above that I could re-use???
Many thanks in advance,
Jason.
Jason Bell, B.I.T. (Honours)
Video Collaboration Champion
Australian Research Collaboration Service
http://www.arcs.org.au/
Senior Research Technologies Officer
Information Technology Directorate
CQ University Australia
E-mail : j.bell at cqu.edu.au
Jason.bell at arcs.org.au
Work : +61 7 4930 9229
Mobile : 0409 630897
Postal : Building 19
Central Queensland University
Bruce Highway
Rockhampton, Queensland, Australia, 4702
Patience is a virtue.
But if I wanted Patience,
I would have become a Doctor.
