[AG-TECH] Remote VenueVNC startup and shutdown
Tran, Quang V.
qtran3 at lsuhsc.edu
Tue Feb 22 20:16:55 CST 2011
Have you tried the nohup command in Linux (ie: ./venueVNC_script.sh & nohup)
It allows a service to run after you log off. I use this with my bridge's script.
-----Original Message-----
From: ag-tech-bounces at lists.mcs.anl.gov on behalf of Jason Bell
Sent: Tue 2/22/2011 5:48 PM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Remote VenueVNC startup and shutdown
Caution: The following message did not originate from within LSUHSC and may be a scam to trick you into divulging your LSUHSC password. LSUHSC never asks you to reveal your password in an email or web form. Your network access will be deactivated if you do reveal your LSUHSC password.
If you think the following email is a scam, please forward it to spam at lsuhsc.edu for further analysis.
The original email follows:
Colleagues
I am hoping that someone out there might have a "solution" to an issue I have.
Long story short, I have a dedicated machine outside our "network" which allows remote sites to easy connect to it as part of a VenueVNC session.
The problem is that this machine is not easy accessible (located in a machine room) and cannot be moved. The problem is that I would like to setup a system that everyday AG operators can connect to and launch a VenueVNC session when required (Note: the remote machine is a Linux machine). Obviously there are a few options, including such example like:
* Shell scripts that remotely connect (maybe via ssh) and start the VenueVNC service;
- An issue to consider is that ssh connections time out and when it does, it kills the VenueVNC session.
* A webserver that users can log into and via a website and launch appropriate service.
* Some other remote means (has any used a terminal server to do this);
- Note, I am not keen on using VNC, as it sends clear text passwords and I would like to make the process as simple as possible.
Obviously there are a few issues, such that the service may be required to started in different Virtual Venues and the duration for the session will differ.
Therefore, in an effort to save "re-inventing the wheel", has anyone implemented a system which would solve the problem posed above that I could re-use???
Many thanks in advance,
Jason.
Jason Bell, B.I.T. (Honours)
Video Collaboration Champion
Australian Research Collaboration Service
http://www.arcs.org.au/
Senior Research Technologies Officer
Information Technology Directorate
CQ University Australia
E-mail : j.bell at cqu.edu.au
Jason.bell at arcs.org.au
Work : +61 7 4930 9229
Mobile : 0409 630897
Postal : Building 19
Central Queensland University
Bruce Highway
Rockhampton, Queensland, Australia, 4702
Patience is a virtue.
But if I wanted Patience,
I would have become a Doctor.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20110222/95bd9091/attachment.htm>
