[AG-TECH] FW: problem managing venue server
JULIAN CASTRO
jucama01 at hotmail.com
Wed Feb 16 19:21:12 CST 2011
Hi
We are Universidad Distrital "Francisco Jose de Caldas" studients, Bogota Colombia, right
now we are installing and configurating the venue server. so far we have
followed the existing documentation step by step, the server works just fine
running on fedora 13 but the problem is when we try to manage the server. we
cant connect to the server trough the venue manager. we hope someone can help and thanks. these are the logs thrown
by the Venueserver and the Venue Management:
Venue Management log
02/16/11 11:13:20 140643897829120 CertificateManager CertificateManager.py:212 DEBUG Opened repository /home/AccessGrid/.AccessGrid3/Config/certRepo
02/16/11 11:13:20 140643897829120 Toolkit Toolkit.py:473 INFO Initialized certificate manager.
02/16/11 11:13:20 140643897829120 CertificateManager CertificateManager.py:575 DEBUG Configuring standard environment
02/16/11 11:13:20 140643897829120 CertificateManager CertificateManager.py:625 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=correo.udistrital.edu.co/CN=Julian Castro
02/16/11 11:13:38 140643897829120 VenueManagement VenueManagement:422 DEBUG VenueManagementClient.ConnectToServer: Connect to server https://200.69.103.63:8000/VenueServer
02/16/11 11:13:38 140643897829120 VenueManagement VenueManagement:430 DEBUG VenueManagementClient.ConnectToServer: Connect to server
02/16/11 11:13:38 140643897829120 Toolkit Toolkit.py:251 INFO Using proxy certificate: /tmp/x509up_u500 /tmp/x509up_u500
02/16/11 11:13:38 140643897829120 VenueManagement VenueManagement:435 DEBUG VenueManagementClient.ConnectToServer: Get venues from server
02/16/11 11:13:38 140643897829120 VenueManagement VenueManagement:524 ERROR VenueManagementClient.ConnectToServer: Can not connect.:
Traceback (most recent call last):
File "/usr/bin/VenueManagement", line 438, in ConnectToServer
vl = self.server.GetVenues()
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/interfaces/VenueServer_client.py", line 168, in GetVenues
self.binding.Send(None, None, request, soapaction="urn:#GetVenues", **kw)
File "/usr/lib/python2.6/site-packages/ZSI/client.py", line 266, in Send
self.h.connect()
File "/usr/lib64/python2.6/site-packages/M2Crypto/httpslib.py", line 50, in connect
self.sock.connect((self.host, self.port))
File "/usr/lib64/python2.6/site-packages/M2Crypto/SSL/Connection.py", line 181, in connect
ret = self.connect_ssl()
File "/usr/lib64/python2.6/site-packages/M2Crypto/SSL/Connection.py", line 174, in connect_ssl
return m2.ssl_connect(self.ssl, self._timeout)
SSLError: certificate verify failed
Venue Server log
02/16/11 11:13:11 139694479308544 Toolkit Toolkit.py:694 INFO Service init: have profile None
02/16/11 11:13:11 139694479308544 Toolkit Toolkit.py:719 INFO Service Initialization Complete.
02/16/11 11:13:11 139694479308544 Toolkit VenueServer:102 INFO VenueServer running using hostname: ag.udistrital.edu.co
02/16/11 11:13:11 139694479308544 Toolkit VenueServer:105 INFO Running in secure mode
02/16/11 11:13:11 139694479308544 CertificateManager CertificateManager.py:212 DEBUG Opened repository /home/AccessGrid/.AccessGrid3/Config/certRepo
02/16/11 11:13:11 139694479308544 Toolkit Toolkit.py:473 INFO Initialized certificate manager.
02/16/11 11:13:11 139694479308544 CertificateManager CertificateManager.py:575 DEBUG Configuring standard environment
02/16/11 11:13:11 139694479308544 CertificateManager CertificateManager.py:625 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=correo.udistrital.edu.co/CN=Julian Castro
02/16/11 11:13:11 139694479308544 Toolkit Toolkit.py:251 INFO Using proxy certificate: /tmp/x509up_u500 /tmp/x509up_u500
02/16/11 11:13:11 139694479308544 VenueServer VenueServer.py:183 DEBUG VenueServer initializing authorization manager.
02/16/11 11:13:11 139694479308544 VenueServer VenueServer.py:504 DEBUG Reading authorization policy.
02/16/11 11:13:11 139694479308544 FTPSServer FTPSServer.py:40 DEBUG FTPSServer __init__: path=Data hostname=ag.udistrital.edu.co port=8006
02/16/11 11:13:11 139694479308544 FTPSServer FTPSServer.py:77 DEBUG Entered FTPSServer.run_in_thread
02/16/11 11:13:11 139694267483920 FTPSServer FTPSServer.py:57 DEBUG Entered FTPSServer.run
02/16/11 11:13:11 139694479308544 VenueServer VenueServer.py:1410 DEBUG Register service <AccessGrid.VenueServerService.VenueServerServiceDescription instance at 0x2f01638>
02/16/11 11:13:11 139694267483920 FTPSServer ftps_server.py:338 INFO M2Crypto (Medusa) FTP/TLS server started at Wed Feb 16 11:13:11 2011
Authz: <AccessGrid.FTPSServer.authorizer instance at 0x2f01488>
Hostname: ag
Port: 8006
02/16/11 11:13:11 139694479308544 VenueServer VenueServer.py:1410 DEBUG Register service <AccessGrid.VenueServerService.VenueServerServiceDescription instance at 0x2f01cb0>
02/16/11 11:13:11 139694479308544 VenueServer VenueServer.py:539 DEBUG Reading persisted Venues from: VenueServer.dat
02/16/11 11:13:11 139694479308544 VenueServer VenueServer.py:544 DEBUG Loading Venue: c845673f0b881e30b7841da2aac5503d9c
02/16/11 11:13:11 139694479308544 VenueServer Venue.py:344 DEBUG ------------ STARTING VENUE
02/16/11 11:13:11 139694479308544 VenueServer Venue.py:383 INFO Venue URI https://200.69.103.63:8000/Venues/c845673f0b881e30b7841da2aac5503d9c
02/16/11 11:13:11 139694479308544 VenueServer Venue.py:393 DEBUG data store location: Data
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:226 DEBUG __init__: Datastore path is Data/c845673f0b881e30b7841da2aac5503d9c
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:265 DEBUG =================== ENTERED LoadPersistentInfo ==================
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:266 DEBUG Reading persisted data from: Data/c845673f0b881e30b7841da2aac5503d9c/DataStore.dat
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:271 DEBUG Loading a directory in root-dir!
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:281 DEBUG LoadPersistentInfo: Server Path: Data/c845673f0b881e30b7841da2aac5503d9c
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:285 DEBUG Getting file list of ./Data/c845673f0b881e30b7841da2aac5503d9c/
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:295 DEBUG LOADPERSISTENTINFO: Path to use is /home/AccessGrid/Data/c845673f0b881e30b7841da2aac5503d9c
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:300 DEBUG Found file Images_1297295525867.zip !
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:306 DEBUG LoadPersistentInfo: Adding file Images_1297295525867.zip to location
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:353 DEBUG LoadPersistentInfo: Filename Images_1297295525867.zip
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:795 DEBUG GetDownLoadDescriptor: Pathname is Data/c845673f0b881e30b7841da2aac5503d9c
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:796 DEBUG GetDownLoadDescriptor: Filename is Images_1297295525867.zip
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:800 DEBUG GetDownLoadDescriptor: Joined Path is Data/c845673f0b881e30b7841da2aac5503d9c/Images_1297295525867.zip
02/16/11 11:13:11 139694479308544 FTPSServer FTPSServer.py:104 DEBUG Entered FTPSServer.GetDownloadDescriptor
02/16/11 11:13:11 139694479308544 FTPSServer FTPSServer.py:110 DEBUG descriptor = ftps://ag.udistrital.edu.co:8006/c845673f0b881e30b7841da2aac5503d9c/Images_1297295525867.zip
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:300 DEBUG Found file Images_1297295365814.zip !
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:306 DEBUG LoadPersistentInfo: Adding file Images_1297295365814.zip to location
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:353 DEBUG LoadPersistentInfo: Filename Images_1297295365814.zip
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:796 DEBUG GetDownLoadDescriptor: Filename is Images_1297295365814.zip
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:800 DEBUG GetDownLoadDescriptor: Joined Path is Data/c845673f0b881e30b7841da2aac5503d9c/Images_1297295365814.zip
02/16/11 11:13:11 139694479308544 FTPSServer FTPSServer.py:110 DEBUG descriptor = ftps://ag.udistrital.edu.co:8006/c845673f0b881e30b7841da2aac5503d9c/Images_1297295365814.zip
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:300 DEBUG Found file 230209_Bogot___The_EELA-2_Project.pdf !
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:306 DEBUG LoadPersistentInfo: Adding file 230209_Bogot___The_EELA-2_Project.pdf to location
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:353 DEBUG LoadPersistentInfo: Filename 230209_Bogot___The_EELA-2_Project.pdf
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:796 DEBUG GetDownLoadDescriptor: Filename is 230209_Bogot___The_EELA-2_Project.pdf
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:800 DEBUG GetDownLoadDescriptor: Joined Path is Data/c845673f0b881e30b7841da2aac5503d9c/230209_Bogot___The_EELA-2_Project.pdf
02/16/11 11:13:11 139694479308544 FTPSServer FTPSServer.py:110 DEBUG descriptor = ftps://ag.udistrital.edu.co:8006/c845673f0b881e30b7841da2aac5503d9c/230209_Bogot___The_EELA-2_Project.pdf
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:300 DEBUG Found file Images_1297295552718.zip !
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:306 DEBUG LoadPersistentInfo: Adding file Images_1297295552718.zip to location
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:353 DEBUG LoadPersistentInfo: Filename Images_1297295552718.zip
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:796 DEBUG GetDownLoadDescriptor: Filename is Images_1297295552718.zip
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:800 DEBUG GetDownLoadDescriptor: Joined Path is Data/c845673f0b881e30b7841da2aac5503d9c/Images_1297295552718.zip
02/16/11 11:13:11 139694479308544 FTPSServer FTPSServer.py:110 DEBUG descriptor = ftps://ag.udistrital.edu.co:8006/c845673f0b881e30b7841da2aac5503d9c/Images_1297295552718.zip
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:368 DEBUG Adding Description Images_1297295525867.zip
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:368 DEBUG Adding Description Images_1297295365814.zip
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:368 DEBUG Adding Description 230209_Bogot___The_EELA-2_Project.pdf
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:368 DEBUG Adding Description Images_1297295552718.zip
02/16/11 11:13:11 139694479308544 DataStore DataStore.py:372 DEBUG =================== EXITED LoadPersistentInfo ==================
02/16/11 11:13:11 139694479308544 FTPSServer FTPSServer.py:92 DEBUG Entered FTPSServer.GetUploadDescriptor
02/16/11 11:13:11 139694479308544 FTPSServer FTPSServer.py:97 DEBUG descriptor = ftps://ag.udistrital.edu.co:8006/c845673f0b881e30b7841da2aac5503d9c
02/16/11 11:13:11 139694479308544 VenueServer Venue.py:417 INFO Have upload url: ftps://ag.udistrital.edu.co:8006/c845673f0b881e30b7841da2aac5503d9c
02/16/11 11:13:11 139694479308544 EventService GroupMsgService.py:102 INFO connectionMade None:None
02/16/11 11:13:11 139694479308544 EventService GroupMsgService.py:149 INFO addedConnection None:None id:c845673f13481e37ecb7681e2944db4e1f
02/16/11 11:13:11 139694479308544 EventClient InsecureVenueEventClient.py:60 INFO BaseVenueEventClient made connection.
02/16/11 11:13:11 139694479308544 VenueServer Venue.py:1156 DEBUG Calling SetConnections.
02/16/11 11:13:11 139694479308544 VenueServer VenueServer.py:998 INFO initializing with default policy
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:516 INFO Tried to add role that already exists <?xml version="1.0" ?>
<Role><Role name="AllowedEntry"/></Role>
<Role><Role name="VenueUsers"/></Role>
<Role><Role name="Administrators"/></Role>
<Role><Role name="Everybody"/></Role>
02/16/11 11:13:11 139694479308544 VenueServer Venue.py:509 INFO Building auth policy.
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: Enter
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: Exit
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetStreams
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: UpdateLifetime
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: NegotiateCapabilities
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetStaticStreams
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetUploadDescriptor
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: AsVenueDescription
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetRolesForSubject
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: CreateApplication
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: UpdateApplication
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: DestroyApplication
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: UpdateClientProfile
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: AddService
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: RemoveService
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: UpdateService
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetServices
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: AddData
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: UpdateData
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: RemoveData
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetDataStoreInformation
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetDataDescriptions
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: AddNetworkService
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: RemoveNetworkService
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetNetworkServices
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetClients
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetCachedProfiles
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: AddConnection
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: RemoveConnection
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetConnections
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: SetConnections
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetEncryptMedia
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetDescription
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetName
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetApplication
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetApplications
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: AddNetworkLocationToStream
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: RemoveNetworkLocationFromStream
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetEventServiceLocation
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: DetermineSubjectRoles
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: AddNetService
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: RemoveNetService
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: IsAuthorized
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: IsValid
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: AllocateMulticastLocation
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: RecycleMulticastLocation
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetState
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: AddDir
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetDescById
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: RemoveDir
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: HDDump
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetVersion
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:430 ERROR Coudn't find action: GetDataSize
02/16/11 11:13:11 139694479308544 VenueServer VenueServer.py:1009 INFO auth policy ? 0
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:568 DEBUG Adding Subject: /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=correo.udistrital.edu.co/CN=Julian Castro to Role: Administrators
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:302 DEBUG RequireIdentification: <type 'int'> 0
02/16/11 11:13:11 139694479308544 VenueServer VenueServer.py:722 DEBUG No applications to load for Venue c845673f0b881e30b7841da2aac5503d9c
02/16/11 11:13:11 139694479308544 VenueServer VenueServer.py:291 DEBUG CFG: Default Venue: c845673f0b881e30b7841da2aac5503d9c
02/16/11 11:13:11 139694479308544 VenueServer VenueServer.py:293 DEBUG Setting default venue.
02/16/11 11:13:11 139694479308544 VenueServer VenueServer.py:1204 INFO Setting default venue; oid=c845673f0b881e30b7841da2aac5503d9c
02/16/11 11:13:11 139694479308544 VenueServer VenueServer.py:337 WARNING Performance data configuration incorrect.
02/16/11 11:13:11 139694256994064 VenueServer VenueServer.py:841 INFO Checkpoint starting at: Wed Feb 16 11:13:11 2011
02/16/11 11:13:11 139694479308544 VenueServer VenueServer.py:374 DEBUG Default Subject: /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=correo.udistrital.edu.co/CN=Julian Castro
02/16/11 11:13:11 139694256994064 Security AuthorizationManager.py:307 DEBUG IsIdentificationRequired returning <type 'int'> 0
02/16/11 11:13:11 139694479308544 Security AuthorizationManager.py:580 WARNING Not adding subject /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=correo.udistrital.edu.co/CN=Julian Castro to role Administrators, it's already there.
02/16/11 11:13:11 139694256994064 VenueServer VenueServer.py:875 INFO Checkpointing venues completed at: Wed Feb 16 11:13:11 2011
02/16/11 11:13:11 139694479308544 Toolkit VenueServer:121 DEBUG Starting Hosting Environment.
02/16/11 11:13:38 139694236014352 Hosting ServiceContainer.py:187 ERROR None
File "/usr/lib64/python2.6/site-packages/M2Crypto/SSL/SSLServer.py", line 33, in handle_request
request, client_address = self.get_request()
File "/usr/lib64/python2.6/SocketServer.py", line 444, in get_request
return self.socket.accept()
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/hosting/ZSI/ServiceContainer.py", line 156, in M2CryptoConnectionAccept
ret = ssl.accept_ssl()
File "/usr/lib64/python2.6/site-packages/M2Crypto/SSL/Connection.py", line 152, in accept_ssl
return m2.ssl_accept(self.ssl, self._timeout)
SSLError: tlsv1 alert unknown ca
Sebastian Quintero Zuluaga
Estudiante Ing. Sistemas
3112078083
Julian Castro Mayorga
3143127384
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20110216/e932e992/attachment-0001.htm>
