[AG-TECH] [Fwd: Accessgrid Error Certificate]
ada1 at uma.es
ada1 at uma.es
Mon Apr 11 12:15:46 CDT 2011
Greetings from Malaga
thanks for the recent answer to our problem.
According to your instructions, I have done the following:
In Toolkit.py/AppBase.GetContext, change the following line:
self.__context.set_verify(SSL.verify_peer,10)
to this:
#self.__context.set_verify(SSL.verify_peer,10)
self.__context.set_verify(SSL.verify_peer,10,SSL.cb.ssl_verify_callback_allow_unknown_ca)
On Windows, the platform on which this bug applies, this file can be found
here:
c:\python24\lib\site-packages\accessgrid3\accessgrid\toolkit.py
But now i´ve got another problem.
To understand the new problem I attached the file "VenueManagement.log"
I hope this is the last mail exchanges concerning this issue. Thank you
very much for your dedication.
___________________________________________________________________________
Greetings from the University of Malaga
Asked recently by a problem of Venue Management Tool by which we could not
assign a multicast to a certain range Venue.
We really need to solve this problem, as there is a project to
interconnect all universities in Andalusia 233.2.254.45 multicast using
the range for UDP. Rank assigned by the CICA.
Our OS is XP. Is there a manual way to do this? I mean, I can manually
enter this data into a file? What?
Thanks.
I know you're busy, but it is important to solve this problem.
More information about de problem:
Greetings from Malaga University
last few days we can not access to "venue management tool" to the
configuration of multicast. Running "Venue Server" in debug mode shows
the
error "SSLError: TLSv1 alert unknow ca".
We have requested a new certificate type "service", we've installed it
and
the error is the same (NOTE: we have requested the certificate as
"service" type, but once is installed changes to "identity" type. Is it
normal?)
Do you think we have to try deleting all certificates and re-requesting
an "identity" (not "service" type this time) certificate instead of? In
any case we have requested a identity certificate for probing it. If no
is a problem we'll contact you again for help if the error exists
How many certificates are recomendable to have installed? With one is
sufficient? Is a problem to have installed two or more valid
certificates?
Screen capture attached.
Thanks for your dedication with us.
Thanks.
the
and
normal?)
certificates?
Type: image/bmp
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20110411/2b48d7ab/attachment-0001.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20110411/2b48d7ab/attachment-0001.obj>
