[AG-TECH] VideoConsumerService HD crash log
Griebel, Keith
Keith.Griebel at sdstate.edu
Fri Apr 8 10:25:55 CDT 2011
Hi Jason,
We, at 3 separate sites, have also seen this issue. In our testing it appears to be 64bit related, since if we move the card(s) to a 32bit Windows machine (both Windows 7), the Vic crash does not happen and it all works fine. We have also noticed that this affects multiple Viewcast Osprey card models, including the 440 (pci) and 450e (pci-express). There is also some odd/inconsistent behavior where, if you disable the Osprey devices, open Access Grid Venue Client, then re-enable some (not always able to do all) of them, they will become available to add into a service, enter a venue, and actually work (send video through Vic). Obviously this is not really a solution, but maybe some developers will find it valuable.
A while back Doug Kosovic was working on this some, I am not sure if he got anywhere with HD Vic to prevent the crashes. Our workaround now is to use a 32bit capture machine to send SD video alongside our HD capture (which uses 3 Blackmagic Decklink SDI cards) and we control both HD and SD capture machines from our Display machine with Service Manager.
Since we've had this issue for almost a year now, we have had the opportunity to test with multiple releases of the 64bit drivers for these cards, hoping they would solve the problem, to no avail. It appears Viewcast has now released all the beta versions, so theoretically the drivers should be stable, but I still consider that a possible cause. It is interesting however that other capture programs appear to display the video from these Osprey cards just fine in 64bit Windows, so hopefully it is just a matter of modifying some HD Vic code.
Please let us know if you come up with or hear of a solution! We are happy to provide logs or any other info upon request.
Thanks!
Keith
Keith Griebel
Communications Technician
Classroom Technology Services
South Dakota State University
From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Jason Bell
Sent: Thursday, April 07, 2011 9:51 PM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] FW: VideoConsumerService HD crash log
Colleagues
I am forwarding an issue from a colleague, in which an "Osprey 440e" device on Windows 7-64bit causes vic to crash. Note, this issue only occurs on the newer version of vic (ie, The HD Video* services). The non-HD Video Services appears to work fine.
If the device is disabled, vic appears to work fine.
Has anyone else seen this issue?
Many thanks,
Jason.
Sent: Thursday, 7 April 2011 11:08 AM
To: Jason Bell
Cc: Lloyd Pearson
Subject: VideoConsumerService HD crash log
Win 7 64bit and Osprey 440e
This is the log -
04/07/11 13:02:25 3784 VenueClient venueclientui.py:2902 DEBUG add user: Otago ITS AVC 1
04/07/11 13:02:49 2396 VenueClient venueclient.py:609 DEBUG Calling Heartbeat, time now: 1302138169
04/07/11 13:02:49 2396 VenueClient venueclient.py:633 DEBUG Next Heartbeat needed within 36s
04/07/11 13:02:49 2396 VenueClient venueclient.py:643 DEBUG heartBeatCounter = 5
04/07/11 13:03:25 3440 VenueClient venueclient.py:609 DEBUG Calling Heartbeat, time now: 1302138205
04/07/11 13:03:25 3440 VenueClient venueclient.py:633 DEBUG Next Heartbeat needed within 36s
04/07/11 13:03:25 3440 VenueClient venueclient.py:643 DEBUG heartBeatCounter = 6
04/07/11 13:03:30 1352 VenueClient venueclientui.py:1732 DEBUG VenueClientFrame.ManageNodeCB: open node management
04/07/11 13:03:30 1352 VenueClient venueclientui.py:1733 DEBUG nodeservice url: http://156.62.46.22:11000/NodeService
04/07/11 13:03:30 1352 NodeService agnodeservice.py:299 INFO NodeService.GetServiceManagers
04/07/11 13:03:30 1352 ServiceManager agservicemanager.py:225 INFO AGServiceManager.GetServices
04/07/11 13:03:37 1352 ServiceManager agservicemanager.py:103 INFO AGServiceManager.AddService
04/07/11 13:03:37 1352 ServiceManager agservicemanager.py:350 INFO Installed service version: 3.4, package version: 3.4
04/07/11 13:03:37 1352 ServiceManager agservicemanager.py:358 INFO Importing inline service class VideoConsumerServiceHD
04/07/11 13:03:43 1352 ServiceManager agservicemanager.py:163 ERROR AddService
Traceback (most recent call last):
File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\AGServiceManager.py", line 151, in AddService
serviceObj,pid = self.__AddInlineService(servicePackage)
File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\AGServiceManager.py", line 367, in __AddInlineService
serviceObj = serviceClass()
File ".\VideoConsumerServiceHD.py", line 49, in __init__
deviceDOM = xml.dom.minidom.parse(proc.stdout)
File "C:\Python24\lib\site-packages\_xmlplus\dom\minidom.py", line 1915, in parse
return expatbuilder.parse(file)
File "C:\Python24\lib\site-packages\_xmlplus\dom\expatbuilder.py", line 930, in parse
result = builder.parseFile(file)
File "C:\Python24\lib\site-packages\_xmlplus\dom\expatbuilder.py", line 211, in parseFile
parser.Parse("", True)
ExpatError: no element found: line 1, column 0
04/07/11 13:03:43 3784 bajjer.io io.py:161 DEBUG RECV:
04/07/11 13:03:43 1352 NodeManagementUIClasses nodemanagementuiclasses.py:1010 ERROR Add Service failed:VideoConsumerServiceHD
File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\NodeManagementUIClasses.py", line 968, in AddService
self.app.GetPreferences().GetProfile())
Living.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20110408/8688efd3/attachment-0001.htm>
