[AG-TECH] Winnov Videum 4400 VO Xpress video capture card
Choon Ng
cj at ngame.edu.au
Mon Oct 25 22:04:40 CDT 2010
Sorry I was supposed to meant VideoProducerServiceHD instead of
VideoProducerServiceH264. But anyway, I had this weird problem where the
native win32 vic.exe for both the VideoProducerServiceHD and
VideoConsumerServiceHD doesn't start unless I run it as "Administrator". But
I think that should be another problem.
Cheers,
Choon
On 26 October 2010 11:12, Douglas Kosovic <doug at uq.edu.au> wrote:
> Hi Choon,
> I’m not sure where you got VideoProducerServiceH264 from, but suspect it is
> old. With the AG 3.2 bundled installer it is now called
> VideoProducerServiceHD and uses a new VIC.
> I found lots of issues with a number of Bt878 based capture card vendor
> drivers, not just with VIC, but with other programs including Skype (e.g.
> green line artefacts) which don’t exist with the open source btWinCap Bt878
> driver. The btWinCap supports many more color space formats and found it
> more flexible that the vendor’s.
> Although the btWinCap website on sourceforge doesn’t have a 64bit driver
> http://btwincap.sourceforge.net/
> others have ported it to 64bit, e.g.:
> http://www.pixelmagicforum.com/forum/archive/index.php/t-2249.html
> Sorry I don’t know where to find the 64bit port of the btWinCap driver that
> was done by Sergey Sakharov anymore.
> Cheers,
> Doug
> *From:* ag-tech-bounces at lists.mcs.anl.gov [mailto:
> ag-tech-bounces at lists.mcs.anl.gov] *On Behalf Of *Choon Ng
> *Sent:* Monday, 25 October 2010 7:05 PM
> *To:* ag-tech at lists.mcs.anl.gov
> *Subject:* [AG-TECH] Winnov Videum 4400 VO Xpress video capture card
> Hi there,
> I'm currently using Windows 7 64-bit (x64) with ta Winnov Videum 4400 VO
> Xpress capture card. I can only install the DirectShow driver but not the
> VFW driver. When used in conjunction with VideoProducerServiceH264, it only
> produces a blank video. So there is no way I can output H264 or mpeg4 with
> that card. Anyone having such problem? I suspect it's a
> VideoProducerServiceH264 bug not supporting DirectShow or Winnov output
> format?
> Thanks.
Choon Jin Ng
nGAME Technical Support Team
School of Mathematics and Statistics
The University of Sydney
e-mail: cj at ngame.edu.au
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20101026/434e1350/attachment.htm>
