[AG-TECH] VPC Screen AG 3.2 Windows XP
Gabriel Noronha
Gabriel.Noronha at newcastle.edu.au
Sun Oct 10 19:45:34 CDT 2010
Jason + List
No unfortunately that didn't solve the issue.
I'll going to investigate if pidgin is an issue, besides that I'm out of ideas.
Gabriel
Gabriel Noronha
Access Grid Support Officer
University of Newcastle
NSW, Australia
>>> Jason Bell <j.bell at cqu.edu.au> 5/10/2010 10:58 am >>>
Gabriel
Try deleting the old user node service directory and then if needed, add it again.
To delete the users node service, go to the directory
C:\Documents and Settings\[username]\Application Data\AccessGrid3\local_services
Then delete the folder "VPCScreenProducerService".
When you uninstall the AG software, it actually doesn't delete the user configurations and "sometimes" old node services and the likes do not get overwritten and therefore causes issues.
Let us know if this fixes your issues.
Cheers,
Jason.
-----Original Message-----
From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Gabriel Noronha
Sent: Sunday, 3 October 2010 08:52 AM
To: ag-tech at lists.mcs.anl.gov
Subject: [AG-TECH] VPC Screen AG 3.2 Windows XP
with Accessgrid 3.2
getting the following error from vpc screen capture if i save it in my default configuration.
window name: Error
ScreenCaptureFrame::initFrame:Failed to load about dialog
press OK
window name: Error
VPCScreenCapture::OnInit:Failed to initialise frame
press OK
window name: VPCScreenCapture Error
XRC resource 'VPCAbout' (class 'wxDialog') not found!
I seem to understand this error as unable to the make the wx GUI for the VPCscreen capture but no idea why it's failing.
Any ideas I just did a 3.2 upgrade and uninstalled AG 3.1 before hand ?
Gabriel
Gabriel Noronha
NSW, Australia
