[AG-TECH] HDMI vic & AGVCR.
Douglas Kosovic
doug at uq.edu.au
Wed Jan 20 03:40:30 CST 2010
Regarding the HitLab VIC, I meant to say “higher resolutions and the Blackmagic pixelformat” modifications in the grabber code were made, not just “higher resolution support” modifications.
The Blackmagic pixelformat modifications involve doing color space conversions to planar YUV 4:2:0 and ensuring that the filters in the DirectShow filter graph are able to negotiate and connect for that pixelformat.
As for any other modifications elsewhere in HitLab NZ VICs code, I’m not sure as I only helped a bit with the DirectShow grabber stuff. I don’t have a copy of the HitLab NZ code myself.
Doug
From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Andrew Ford
Sent: Wednesday, 20 January 2010 7:41 AM
To: Jimmy Miklavcic
Cc: ag-tech at lists.mcs.anl.gov
Subject: Re: [AG-TECH] HDMI vic & AGVCR.
Hi Jimmy,
I think the 128Kbps issue you're seeing might just be the bitrate slider being limited - try the -B [bitrate] command line option, that will set the max value for the slider.
Also, the unfortunate thing is that due to HIT Lab's unresolved licensing issues, I'm not sure if it would be legal for anyone else to continue working on their code directly (and be able to release it). It might be possible for someone to recreate their work, since I'm not sure if it was much more than adding support for higher resolutions in the DirectShow grabber like Doug said, but I'm not sure of the legal issues involved with that.
The good news is that I've been having some success with testing x264 with Doug's Blackmagic card grabber on Linux. I can get near-full fps at full 1080 HD, albeit with some latency (think I got it down to about .8 seconds), and not too much CPU use either, around 2 cores on a 4-core 3Ghz machine. mpeg4 is probably a bust since I can't successfully enable multithreading on the encoding side, it just crashes.
We haven't gotten around to testing AGVCR extensively with HD material, but we did have some issues with artifacting in general that were intermittent, so when recording/playing back you might want to make sure the load on the machine is low and/or try different machines and different platforms.
--Andrew
2010/1/15 Jimmy Miklavcic <jimmy.miklavcic at utah.edu>
Last year, the HIT Lab in New Zealand was kind enough to knock an HD vic for the HDMI interface. Now Nathan Gardiner has moved on and I was wondering if there was anyone else there that can continue work on it. One major limitation is that it will stream at a maximum of 128 Kbps. That's way too low for what we need. Doesn't make much sense to use HD at 128 Kbps.
Is anyone picking up the work of Derek Piper and his AGVCR. I'm having some issues where it doesn't seem to handle the HD streams and during playback, I'm seeing some major artifacts and image break-up.
If anyone is working other HD solutions I am very interested in hearing about it.
Jimmy
Jimmy Miklavcic
Multimedia Specialist
Jimmy.Miklavcic at utah.edu <mailto:Jimmy.Miklavcic at utah.edu>
UNIVERSITY OF UTAH
CTR FOR HIGH PERFORM COMPUTING
155 SOUTH 1452 EAST RM 405
SALT LAKE CITY, UT 84112-0190
Office: 801.585.9335
Fax: 801.585.5366
http://www.anotherlanguage.org <http://www.anotherlanguage.org/>
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100120/56a499b8/attachment.htm>
