[AG-TECH] 회신: Problems of VenueManagement
Thomas Uram
turam at mcs.anl.gov
Thu Aug 5 13:05:46 CDT 2010
From the log I can see that you are using a VenueServer service certificate, which is good.
Based on the 'unknown ca' error message, I wonder about the validity of the CA certificate. Could you enter certificate management and check the validity of the AG-Dev CA certificate?
Tom
On Aug 3, 2010, at 9:27 AM, Sangil Choi wrote:
> I checked URL of my server (Server : https://210.125.84.210:8000/VenueServer) but there is no changes in result. I think the cause seems to be elsewhere.
> In addition, I used 'https://210.125.84.210:8000/Venues' and the result is consistent.
> Thanks for your help.
> Regards,
> Sangil Choi.
> 보낸 사람: Christoph Willing [c.willing at uq.edu.au]
> 보낸 날짜: 2010년 8월 3일 화요일 오후 9:59
> 받는 사람: Sangil Choi
> 제목: Re: [AG-TECH] Problems of VenueManagement
> Sangil,
> Sometimes there is confusion about the name which the VenueServer is
> running. Look in the server log file (~/.ACcessGrid/Logs/
> VenueServer.log) for the line containing:
> ....... Venue.py:344 DEBUG ------------ STARTING VENUE
> Then the next line will contain the name of that the server is running
> as. It will be something like:
> ....... Venue.py:383 INFO Venue URI https://a.b.c.d:8000/Venues/0a0101ce20dd1d9654fb10b37feec5410c
> Use that name (https://a.b.c.d:8000/Venues) when connecting with the
> VenueManager
> If you can't find the correct lines in the log file, restart the
> VenueServer so they will be generated again.
> chris
> On 03/08/2010, at 8:10 PM, Sangil Choi wrote:
>> Hi, everyone.
>> I've problem about VenueManagement Tool.
>> I install 'AGTk3.2 beta 1' on Fedora Core 12 and send certificate
>> request message to agdev-ca at mcs.anl.gov<mailto:agdev-ca at mcs.anl.gov>.
>> After I got a replied message, I install that certificate and check
>> the '/usr/bin/certmgr_agtk' to make sure of its installation. In
>> addition, VenueServer works well.
>> I found some problem when I use VenueManagement Tool to create new
>> venues in our venue server.
>> I make an entry of “Venue Server Address” as follow:
>> https://localhost:8000/VenueServer
>> https://NFRI-AG-Server.nm.gist.ac.kr:8000/VenueServer - It is DNS of
>> server machine
>> https://NFRI-AG-Server.gist.ac.kr:8000/VenueServer - It is the name
>> that uses in certificate request message.
>> After I clinks go button, below message is shown.
>> You were unable to connect to the venue server at: https://localhost:8000/VenueServer
>> In command window that execute VenueServer prints error message like
>> this.
>> Traceback (nost recent call last):
>> File "/usr/lib/python2.6/site-packages/M2Crypto/SSL/SSLServer.py",
>> line 32, in handle_request
>> request, client_address = self.get_request()
>> File "/usr/lib/python2.6/SocketServer.py", line 444, in get_request
>> return self.socket.accept()
>> File "/usr/lib/python2.6/site-packages/AccessGrid3/hosting/ZSI/
>> ServiceContainer.py", line 156, in M2CrytoConnectionAccept
>> ret = ssl.accept_ssl()
>> File "/usr/lib/python2.6/site-packages/M2Crypto/SSL/Connection.py",
>> line 152, in accept_ssl
>> return m2.ssl_accept(self.ssl, self._timeout)
>> SSLError : tlsv1 alert unknown ca
>> Last, the following message was printed in VenueManagement.log file.
>> 08/03/2010 04:36:50 PM -1216825664 Platform Config.py:897 INFO
>> gnome directory /home/ag/.gnome/application-info or /home/ag/.gnome/
>> mime-info not found, not registering file type .agpkg3 with gnome
>> mime-info not found, not registering file type .vv3d with gnome
>> 08/03/2010 04:36:50 PM -1216825664 VenueClient Preferences.py:
>> 206 DEBUG Preferences.LoadPreferences: open file
>> 08/03/2010 04:36:50 PM -1216825664 Toolkit Toolkit.py:166 INFO
>> Logfile Name: VenueManagement.log
>> 08/03/2010 04:36:50 PM -1216825664 CertificateManager
>> CertificateManager.py:212 DEBUG Opened repository /home/
>> ag/.AccessGrid3/Config/certRepo
>> 08/03/2010 04:36:50 PM -1216825664 Toolkit Toolkit.py:472 INFO
>> Initialized certificate manager.
>> CertificateManager.py:575 DEBUG Configuring standard environment
>> CertificateManager.py:625 DEBUG Using default identity /O=Access
>> Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/NFRI-AG-Server.gist.ac.kr
>> 08/03/2010 04:36:52 PM -1216825664 VenueManagement
>> VenueManagement:422 DEBUG VenueManagementClient.ConnectToServer:
>> Connect to server https://localhost:8000/VenueServer
>> VenueManagement:430 DEBUG VenueManagementClient.ConnectToServer:
>> Connect to server
>> 08/03/2010 04:36:52 PM -1216825664 Toolkit Toolkit.py:262 INFO
>> Using unencrypted certificate: /home/ag/.AccessGrid3/Config/certRepo/
>> certificates/174973e21fb8d6e777cf0199e079762b/
>> c922e6eac654d6475a33f6e48af375e7/cert.pem /home/ag/.AccessGrid3/
>> Config/certRepo/privatekeys/fb186c081f585da9ba71017c637bd452.pem
>> VenueManagement:435 DEBUG VenueManagementClient.ConnectToServer: Get
>> venues from server
>> VenueManagement:521 ERROR VenueManagementClient.ConnectToServer: Can
>> not connect.:
>> Traceback (most recent call last):
>> File "/usr/bin/VenueManagement", line 438, in ConnectToServer
>> vl = self.server.GetVenues()
>> File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/
>> interfaces/VenueServer_client.py", line 168, in GetVenues
>> self.binding.Send(None, None, request,
>> soapaction="urn:#GetVenues", **kw)
>> File "/usr/lib/python2.6/site-packages/ZSI/client.py", line 266, in
>> Send
>> self.h.connect()
>> File "/usr/lib/python2.6/site-packages/M2Crypto/httpslib.py", line
>> 50, in connect
>> self.sock.connect((self.host, self.port))
>> line 177, in connect
>> self.socket.connect(addr)
>> File "<string>", line 1, in connect
>> error: [Errno 111] Connection refused
>> What should I do to solve this problem?
>> Regard,
>> Sangil Choi
> Christoph Willing +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
