[AG-TECH] 회신: Problems of VenueManagement
Jason Bell
j.bell at cqu.edu.au
Thu Aug 5 19:04:38 CDT 2010
Tom, Sangil, Todd, Chris and all
I have just configured a freshly installed Venue Server with a new Server certificate.
I can replicate the issue...
Message from consol on the Venue Server side of things...
Traceback (most recent call last):
File "/usr/lib64/python2.6/site-packages/M2Crypto/SSL/SSLServer.py", line 33, in handle_request
request, client_address = self.get_request()
File "/usr/lib64/python2.6/SocketServer.py", line 444, in get_request
return self.socket.accept()
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/hosting/ZSI/ServiceContainer.py", line 156, in M2CryptoConnectionAccept
ret = ssl.accept_ssl()
File "/usr/lib64/python2.6/site-packages/M2Crypto/SSL/Connection.py", line 152, in accept_ssl
return m2.ssl_accept(self.ssl, self._timeout)
SSLError: tlsv1 alert unknown ca
Message from consol on the Venue Management side of things...
/usr/lib/python2.6/site-packages/ZSI/resolvers.py:7: DeprecationWarning: the multifile module has been deprecated since Python 2.5
import multifile, mimetools, urllib
08/06/10 09:36:04 140460321769216 Toolkit Toolkit.py:167 INFO Logfile Name: VenueManagement.log
08/06/10 09:36:04 140460321769216 VenueManagement VenueManagement:265 DEBUG There is no my servers file to load.
08/06/10 09:36:04 140460321769216 Toolkit Config.py:685 DEBUG retrieved local IP address 138.77.14.18
08/06/10 09:36:04 140460321769216 Toolkit Toolkit.py:117 DEBUG Initializing AG Toolkit version 3.2 rc1
08/06/10 09:36:04 140460321769216 Toolkit Toolkit.py:118 INFO Command and arguments: ['/usr/bin/VenueManagement', '-d']
08/06/10 09:36:04 140460321769216 Platform Config.py:897 INFO gnome directory /home/arcs-test/.gnome/application-info or /home/arcs-test/.gnome/mime-info not found, not registering file type .agpkg3 with gnome
08/06/10 09:36:04 140460321769216 Platform Config.py:897 INFO gnome directory /home/arcs-test/.gnome/application-info or /home/arcs-test/.gnome/mime-info not found, not registering file type .vv3d with gnome
08/06/10 09:36:04 140460321769216 VenueClient Preferences.py:206 DEBUG Preferences.LoadPreferences: open file
08/06/10 09:36:04 140460321769216 CertificateManager CertificateManager.py:212 DEBUG Opened repository /home/arcs-test/.AccessGrid3/Config/certRepo
08/06/10 09:36:04 140460321769216 Toolkit Toolkit.py:473 INFO Initialized certificate manager.
08/06/10 09:36:04 140460321769216 CertificateManager CertificateManager.py:575 DEBUG Configuring standard environment
08/06/10 09:36:04 140460321769216 CertificateManager CertificateManager.py:625 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/arcs-ag-test.cqu.edu.au
08/06/10 09:36:13 140460321769216 VenueManagement VenueManagement:422 DEBUG VenueManagementClient.ConnectToServer: Connect to server https://138.77.14.18:8000/VenueServer
VenueManagement 08/06/10 09:36:13 DEBUG VenueManagementClient.ConnectToServer: Connect to server https://138.77.14.18:8000/VenueServer
08/06/10 09:36:13 140460321769216 VenueManagement VenueManagement:430 DEBUG VenueManagementClient.ConnectToServer: Connect to server
08/06/10 09:36:13 140460321769216 Toolkit Toolkit.py:263 INFO Using unencrypted certificate: /home/arcs-test/.AccessGrid3/Config/certRepo/certificates/58e625459c405c5ba86407955bbdabac/bb10e3c80d44ae664798344f1fd143c0/cert.pem /home/arcs-test/.AccessGrid3/Config/certRepo/privatekeys/4e8ce0d9cd5e3e34d00f4a552b680e4b.pem
Toolkit 08/06/10 09:36:13 INFO Using unencrypted certificate: /home/arcs-test/.AccessGrid3/Config/certRepo/certificates/58e625459c405c5ba86407955bbdabac/bb10e3c80d44ae664798344f1fd143c0/cert.pem /home/arcs-test/.AccessGrid3/Config/certRepo/privatekeys/4e8ce0d9cd5e3e34d00f4a552b680e4b.pem
08/06/10 09:36:13 140460321769216 VenueManagement VenueManagement:435 DEBUG VenueManagementClient.ConnectToServer: Get venues from server
VenueManagement 08/06/10 09:36:13 DEBUG VenueManagementClient.ConnectToServer: Get venues from server
08/06/10 09:36:13 140460321769216 VenueManagement VenueManagement:524 ERROR VenueManagementClient.ConnectToServer: Can not connect.:
File "/usr/bin/VenueManagement", line 438, in ConnectToServer
vl = self.server.GetVenues()
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/interfaces/VenueServer_client.py", line 168, in GetVenues
self.binding.Send(None, None, request, soapaction="urn:#GetVenues", **kw)
File "/usr/lib/python2.6/site-packages/ZSI/client.py", line 266, in Send
self.h.connect()
File "/usr/lib64/python2.6/site-packages/M2Crypto/httpslib.py", line 50, in connect
self.sock.connect((self.host, self.port))
File "/usr/lib64/python2.6/site-packages/M2Crypto/SSL/Connection.py", line 181, in connect
ret = self.connect_ssl()
File "/usr/lib64/python2.6/site-packages/M2Crypto/SSL/Connection.py", line 174, in connect_ssl
return m2.ssl_connect(self.ssl, self._timeout)
SSLError: certificate verify failed
VenueManagement 08/06/10 09:36:13 ERROR VenueManagementClient.ConnectToServer: Can not connect.:
self.h.connect()
CA certificate information
[arcs-ag-test at arcs-ag-test ~]$ certmgr_agtk
(ID mode) > ca
(CA mode) > list
1. /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid Developers CA
2. /DC=org/DC=DOEGrids/OU=Certificate Authorities/CN=DOEGrids CA 1
3. /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous Certificate Authority
4. /DC=net/DC=ES/O=ESnet/OU=Certificate Authorities/CN=ESnet Root CA 1
(CA mode) > show 1
Subject: /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid Developers CA
Issuer: /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid Developers CA
Certificate version: 2
Serial number: 2
Not valid before: 01/30/10 10:18:00
Not valid after: 01/28/20 10:18:00
md5 Fingerprint: 5B:03:A8:05:3E:85:3D:60:2B:86:CA:41:6D:56:51:54
Certificate location: /home/arcs-test/.AccessGrid3/Config/certRepo/certificates/809ecc45460c1482e61e26bdfbf9e18c/4665b7fa3dc5e3e1870d794559764226/cert.pem
(CA mode) >
Interestingly, I exported the new server certificate and imported in on a Windows XP machine. I am able to start a Venue Server and connect to it, via the Venue Management Tool via it’s ip address (it didn’t connect via localhost). Additionally, if I tried to connect to the Venue Server via the Fedora 13 system, I get the same error message.
Anyway, I hope this information is of use.
Many regards,
Jason.
-----Original Message-----
From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Thomas Uram
Sent: Friday, 6 August 2010 04:06 AM
To: Sangil Choi
Cc: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] 회신: Problems of VenueManagement
From the log I can see that you are using a VenueServer service certificate, which is good.
Based on the 'unknown ca' error message, I wonder about the validity of the CA certificate. Could you enter certificate management and check the validity of the AG-Dev CA certificate?
Tom
On Aug 3, 2010, at 9:27 AM, Sangil Choi wrote:
> I checked URL of my server (Server : https://210.125.84.210:8000/VenueServer) but there is no changes in result. I think the cause seems to be elsewhere.
> In addition, I used 'https://210.125.84.210:8000/Venues' and the result is consistent.
> Thanks for your help.
> Regards,
> Sangil Choi.
> 보낸 사람: Christoph Willing [c.willing at uq.edu.au]
> 보낸 날짜: 2010년 8월 3일 화요일 오후 9:59
> 받는 사람: Sangil Choi
> 제목: Re: [AG-TECH] Problems of VenueManagement
> Sangil,
> Sometimes there is confusion about the name which the VenueServer is
> running. Look in the server log file (~/.ACcessGrid/Logs/
> VenueServer.log) for the line containing:
> ....... Venue.py:344 DEBUG ------------ STARTING VENUE
> Then the next line will contain the name of that the server is running
> as. It will be something like:
> ....... Venue.py:383 INFO Venue URI https://a.b.c.d:8000/Venues/0a0101ce20dd1d9654fb10b37feec5410c
> Use that name (https://a.b.c.d:8000/Venues) when connecting with the
> VenueManager
> If you can't find the correct lines in the log file, restart the
> VenueServer so they will be generated again.
> chris
> On 03/08/2010, at 8:10 PM, Sangil Choi wrote:
>> Hi, everyone.
>> I've problem about VenueManagement Tool.
>> I install 'AGTk3.2 beta 1' on Fedora Core 12 and send certificate
>> request message to agdev-ca at mcs.anl.gov<mailto:agdev-ca at mcs.anl.gov>.
>> After I got a replied message, I install that certificate and check
>> the '/usr/bin/certmgr_agtk' to make sure of its installation. In
>> addition, VenueServer works well.
>> I found some problem when I use VenueManagement Tool to create new
>> venues in our venue server.
>> I make an entry of “Venue Server Address” as follow:
>> https://localhost:8000/VenueServer
>> https://NFRI-AG-Server.nm.gist.ac.kr:8000/VenueServer - It is DNS of
>> server machine
>> https://NFRI-AG-Server.gist.ac.kr:8000/VenueServer - It is the name
>> that uses in certificate request message.
>> After I clinks go button, below message is shown.
>> You were unable to connect to the venue server at: https://localhost:8000/VenueServer
>> In command window that execute VenueServer prints error message like
>> this.
>> Traceback (nost recent call last):
>> File "/usr/lib/python2.6/site-packages/M2Crypto/SSL/SSLServer.py",
>> line 32, in handle_request
>> File "/usr/lib/python2.6/SocketServer.py", line 444, in get_request
>> File "/usr/lib/python2.6/site-packages/AccessGrid3/hosting/ZSI/
>> ServiceContainer.py", line 156, in M2CrytoConnectionAccept
>> File "/usr/lib/python2.6/site-packages/M2Crypto/SSL/Connection.py",
>> SSLError : tlsv1 alert unknown ca
>> Last, the following message was printed in VenueManagement.log file.
>> 08/03/2010 04:36:50 PM -1216825664 Platform Config.py:897 INFO
>> gnome directory /home/ag/.gnome/application-info or /home/ag/.gnome/
>> 08/03/2010 04:36:50 PM -1216825664 VenueClient Preferences.py:
>> 08/03/2010 04:36:50 PM -1216825664 Toolkit Toolkit.py:166 INFO
>> 08/03/2010 04:36:50 PM -1216825664 CertificateManager
>> ag/.AccessGrid3/Config/certRepo
>> 08/03/2010 04:36:50 PM -1216825664 Toolkit Toolkit.py:472 INFO
>> Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/NFRI-AG-Server.gist.ac.kr
>> 08/03/2010 04:36:52 PM -1216825664 VenueManagement
>> Connect to server https://localhost:8000/VenueServer
>> Connect to server
>> 08/03/2010 04:36:52 PM -1216825664 Toolkit Toolkit.py:262 INFO
>> Using unencrypted certificate: /home/ag/.AccessGrid3/Config/certRepo/
>> certificates/174973e21fb8d6e777cf0199e079762b/
>> c922e6eac654d6475a33f6e48af375e7/cert.pem /home/ag/.AccessGrid3/
>> Config/certRepo/privatekeys/fb186c081f585da9ba71017c637bd452.pem
>> venues from server
>> VenueManagement:521 ERROR VenueManagementClient.ConnectToServer: Can
>> not connect.:
>> Send
>> self.h.connect()
>> File "/usr/lib/python2.6/site-packages/M2Crypto/httpslib.py", line
>> 50, in connect
>> line 177, in connect
>> self.socket.connect(addr)
>> File "<string>", line 1, in connect
>> error: [Errno 111] Connection refused
>> What should I do to solve this problem?
>> Regard,
>> Sangil Choi
> Christoph Willing +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100806/aaf7fe68/attachment-0001.htm>
