[AG-TECH] 회신: Problems of VenueManagement
Sangil Choi
sichoi at netmedia.gist.ac.kr
Tue Aug 3 08:27:02 CDT 2010
I checked URL of my server (Server : https://210.125.84.210:8000/VenueServer) but there is no changes in result. I think the cause seems to be elsewhere.
In addition, I used 'https://210.125.84.210:8000/Venues' and the result is consistent.
Thanks for your help.
Sangil Choi.
보낸 사람: Christoph Willing [c.willing at uq.edu.au]
보낸 날짜: 2010년 8월 3일 화요일 오후 9:59
받는 사람: Sangil Choi
제목: Re: [AG-TECH] Problems of VenueManagement
Sangil,
Sometimes there is confusion about the name which the VenueServer is
running. Look in the server log file (~/.ACcessGrid/Logs/
VenueServer.log) for the line containing:
....... Venue.py:344 DEBUG ------------ STARTING VENUE
Then the next line will contain the name of that the server is running
as. It will be something like:
....... Venue.py:383 INFO Venue URI https://a.b.c.d:8000/Venues/0a0101ce20dd1d9654fb10b37feec5410c
Use that name (https://a.b.c.d:8000/Venues) when connecting with the
VenueManager
If you can't find the correct lines in the log file, restart the
VenueServer so they will be generated again.
chris
On 03/08/2010, at 8:10 PM, Sangil Choi wrote:
> Hi, everyone.
> I've problem about VenueManagement Tool.
> I install 'AGTk3.2 beta 1' on Fedora Core 12 and send certificate
> request message to agdev-ca at mcs.anl.gov<mailto:agdev-ca at mcs.anl.gov>.
> After I got a replied message, I install that certificate and check
> the '/usr/bin/certmgr_agtk' to make sure of its installation. In
> addition, VenueServer works well.
> I found some problem when I use VenueManagement Tool to create new
> venues in our venue server.
> I make an entry of “Venue Server Address” as follow:
> https://localhost:8000/VenueServer
> https://NFRI-AG-Server.nm.gist.ac.kr:8000/VenueServer - It is DNS of
> server machine
> https://NFRI-AG-Server.gist.ac.kr:8000/VenueServer - It is the name
> that uses in certificate request message.
> After I clinks go button, below message is shown.
> You were unable to connect to the venue server at: https://localhost:8000/VenueServer
> In command window that execute VenueServer prints error message like
> this.
> Traceback (nost recent call last):
> File "/usr/lib/python2.6/site-packages/M2Crypto/SSL/SSLServer.py",
> line 32, in handle_request
> request, client_address = self.get_request()
> File "/usr/lib/python2.6/SocketServer.py", line 444, in get_request
> return self.socket.accept()
> File "/usr/lib/python2.6/site-packages/AccessGrid3/hosting/ZSI/
> ServiceContainer.py", line 156, in M2CrytoConnectionAccept
> ret = ssl.accept_ssl()
> File "/usr/lib/python2.6/site-packages/M2Crypto/SSL/Connection.py",
> line 152, in accept_ssl
> return m2.ssl_accept(self.ssl, self._timeout)
> SSLError : tlsv1 alert unknown ca
> Last, the following message was printed in VenueManagement.log file.
> 08/03/2010 04:36:50 PM -1216825664 Platform Config.py:897 INFO
> gnome directory /home/ag/.gnome/application-info or /home/ag/.gnome/
> mime-info not found, not registering file type .agpkg3 with gnome
> mime-info not found, not registering file type .vv3d with gnome
> 08/03/2010 04:36:50 PM -1216825664 VenueClient Preferences.py:
> 206 DEBUG Preferences.LoadPreferences: open file
> 08/03/2010 04:36:50 PM -1216825664 Toolkit Toolkit.py:166 INFO
> Logfile Name: VenueManagement.log
> 08/03/2010 04:36:50 PM -1216825664 CertificateManager
> CertificateManager.py:212 DEBUG Opened repository /home/
> ag/.AccessGrid3/Config/certRepo
> 08/03/2010 04:36:50 PM -1216825664 Toolkit Toolkit.py:472 INFO
> Initialized certificate manager.
> CertificateManager.py:575 DEBUG Configuring standard environment
> CertificateManager.py:625 DEBUG Using default identity /O=Access
> Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/NFRI-AG-Server.gist.ac.kr
> 08/03/2010 04:36:52 PM -1216825664 VenueManagement
> VenueManagement:422 DEBUG VenueManagementClient.ConnectToServer:
> Connect to server https://localhost:8000/VenueServer
> VenueManagement:430 DEBUG VenueManagementClient.ConnectToServer:
> Connect to server
> 08/03/2010 04:36:52 PM -1216825664 Toolkit Toolkit.py:262 INFO
> Using unencrypted certificate: /home/ag/.AccessGrid3/Config/certRepo/
> certificates/174973e21fb8d6e777cf0199e079762b/
> c922e6eac654d6475a33f6e48af375e7/cert.pem /home/ag/.AccessGrid3/
> Config/certRepo/privatekeys/fb186c081f585da9ba71017c637bd452.pem
> VenueManagement:435 DEBUG VenueManagementClient.ConnectToServer: Get
> venues from server
> VenueManagement:521 ERROR VenueManagementClient.ConnectToServer: Can
> not connect.:
> Traceback (most recent call last):
> File "/usr/bin/VenueManagement", line 438, in ConnectToServer
> vl = self.server.GetVenues()
> File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/
> interfaces/VenueServer_client.py", line 168, in GetVenues
> self.binding.Send(None, None, request,
> soapaction="urn:#GetVenues", **kw)
> File "/usr/lib/python2.6/site-packages/ZSI/client.py", line 266, in
> Send
> self.h.connect()
> File "/usr/lib/python2.6/site-packages/M2Crypto/httpslib.py", line
> 50, in connect
> self.sock.connect((self.host, self.port))
> line 177, in connect
> self.socket.connect(addr)
> File "<string>", line 1, in connect
> error: [Errno 111] Connection refused
> What should I do to solve this problem?
> Regard,
> Sangil Choi
Christoph Willing +61 7 3365 8316
QCIF Access Grid Manager
University of Queensland
