[AG-TECH] Problems uploading files
Jesus Cea Oliva
jesus.cea at uca.es
Thu Apr 22 14:28:06 CDT 2010
Thanks Tom for your fast response :).
Well, atach the VenueClient log in this email, I can't see any problems :S.
04/22/10 21:16:50 140471913264880 VenueClient VenueClientUI.py:1308 DEBUG VenueClientUI.AddDataCB: Trying to upload to 'ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007'
04/22/10 21:17:00 140471913264880 VenueClient VenueClientUI.py:1395 DEBUG AddDataCB: URI of parent is
04/22/10 21:17:00 140471913264880 VenueClientController VenueClientController.py:821 DEBUG In VenueClientController.UploadVenueFiles
04/22/10 21:17:00 140471913264880 VenueClientController VenueClientController.py:822 DEBUG fileList = [u'/home/ercea/Descargas/DSD-Tutorial-3.pdf']
04/22/10 21:17:00 140471913264880 VenueClientController VenueClientController.py:848 DEBUG Serverpath:
04/22/10 21:17:00 140471913264880 VenueClientController VenueClientController.py:857 DEBUG Have args, creating thread, url: ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007, files: [u'/home/ercea/Descargas/DSD-Tutorial-3.pdf']
04/22/10 21:17:00 140471479552272 VenueClientController VenueClientController.py:944 DEBUG Upload: getting identity
04/22/10 21:17:00 140471479552272 VenueClientController VenueClientController.py:949 DEBUG Got identity <?xml version="1.0" ?><Subject><Subject auth_data="" auth_type="x509" name="/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 17130398eef9fd82cba8dc9d845a1768"/></Subject>
04/22/10 21:17:00 140471479552272 VenueClientController VenueClientController.py:950 DEBUG get_ident_and_upload: Upload URL ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007
04/22/10 21:17:00 140471479552272 VenueClientController VenueClientController.py:953 DEBUG Get_ident_and_upload: Word is: ftps:
04/22/10 21:17:00 140471479552272 VenueClientController VenueClientController.py:953 DEBUG Get_ident_and_upload: Word is: localhost:8006
04/22/10 21:17:00 140471479552272 VenueClientController VenueClientController.py:953 DEBUG Get_ident_and_upload: Word is: 7f00010133381d7afaba1c148fcabe1007
04/22/10 21:17:00 140471479552272 DataStore DataStore.py:1267 INFO UploadFiles: ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007 [u'/home/ercea/Descargas/DSD-Tutorial-3.pdf']
04/22/10 21:17:00 140471479552272 DataStore DataStore.py:1271 DEBUG UploadFiles: ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007 /home/ercea/Descargas/DSD-Tutorial-3.pdf [u'/home/ercea/Descargas/DSD-Tutorial-3.pdf']
04/22/10 21:17:00 140471479552272 FTPSClient FTPSClient.py:141 DEBUG Entered FTPSUploadFile: localfile=/home/ercea/Descargas/DSD-Tutorial-3.pdf url=ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007
04/22/10 21:17:00 140471913264880 VenueClientController VenueClientController.py:862 DEBUG Started thread
04/22/10 21:17:20 140471517653264 VenueClient VenueClient.py:605 DEBUG Calling Heartbeat, time now: 1271963840
04/22/10 21:17:20 140471517653264 VenueClient VenueClient.py:629 DEBUG Next Heartbeat needed within 36s
04/22/10 21:17:20 140471517653264 VenueClient VenueClient.py:639 DEBUG heartBeatCounter = 2
04/22/10 21:17:56 140471401707792 VenueClient VenueClient.py:605 DEBUG Calling Heartbeat, time now: 1271963876
04/22/10 21:17:56 140471401707792 VenueClient VenueClient.py:629 DEBUG Next Heartbeat needed within 36s
04/22/10 21:17:56 140471401707792 VenueClient VenueClient.py:639 DEBUG heartBeatCounter = 3
Here increment heartBeatCounter +1.
Ah, I have this problem, in the same network, on ubuntu system (Ubuntu 9.10 64 bits), but I've tested on Windows 7 and I can upload files without problems.
Regards!
El dia 22 abr 2010 18:29, Thomas Uram <turam at mcs.anl.gov> escribió:
> Hi Jesus:
> There is probably some indication of the problem in the VenueClient.log file. If you submit a bug report from the Help menu after this happens, a recent portion of the VenueClient.log file will be included with the report, and we can review it. If you want to look yourself, the log file resides in the following locations based on platform:
> MacOS, Linux: ~/.AccessGrid3/Logs
> Windows: c:\documents and settings\username\application data\AccessGrid3\Logs (adjusted for your locale, of course)
> Tom
> On Apr 22, 2010, at 11:11 AM, Jesus Cea Oliva wrote:
>> Hi list again, sorry for my constants problems xD.
>> I'm trying upload files to our VenueServer and my problem is strange. Firstly, I've created a VenueServer locally, for testing.
>> Well, when I try to upload a file, I can see the message on the VenueClient "Uploading file X" and a progressbar, but, when the progressbar is near to the end, stops and list of files (Data section) don't refresh. So I beleived that the file can't upload.
>> But, really, the file has uploaded, because I can see the folder Data of my local VenueServer, and the file is copied in this folder. In this case, if I reset VenueServer and VenueClient, then, I can see the files in Data section.
>> So I think that the file uploads fine but, the list of files don't refresh and the file uploaded don't appears.
>> I must say that, sometimes, I can upload a file so I don't know whats really the problem (ports closed? firewall? path or name files? file size?) .
>> Thanks again and apologize for any inconveniences
>> Regards!
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100422/55a1151d/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100422/55a1151d/attachment-0001.obj>
