[AG-TECH] Problems uploading files
Christoph Willing
c.willing at uq.edu.au
Thu Apr 22 19:35:24 CDT 2010
I wonder if this is related to the size of the data object. I just
tried (with Ubuntu 9.10 64bit) and found that a small file (6K) there
was no problem. With a larger file (12M) I saw exactly the same
problem - upload appears not to complete but has actually succeeded.
Re-entering the venue shows that the new data is there.
In your Windows test, are you uploading the same file (or something of
similar size) as in the Ubuntu case?
I will now be away for a few days so I can't do any more investigation
myself until I return. Maybe others can look into this in the
meantime ...
chris
On 23/04/2010, at 5:28 AM, Jesus Cea Oliva wrote:
> Thanks Tom for your fast response :).
> Well, atach the VenueClient log in this email, I can't see any
> problems :S.
> 04/22/10 21:16:50 140471913264880 VenueClient VenueClientUI.py:
> 1308 DEBUG VenueClientUI.AddDataCB: Trying to upload to 'ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007'
> 04/22/10 21:17:00 140471913264880 VenueClient VenueClientUI.py:
> 1395 DEBUG AddDataCB: URI of parent is
> 04/22/10 21:17:00 140471913264880 VenueClientController
> VenueClientController.py:821 DEBUG In
> VenueClientController.UploadVenueFiles
> VenueClientController.py:822 DEBUG fileList = [u'/home/ercea/
> Descargas/DSD-Tutorial-3.pdf']
> VenueClientController.py:848 DEBUG Serverpath:
> VenueClientController.py:857 DEBUG Have args, creating thread, url: ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007
> , files: [u'/home/ercea/Descargas/DSD-Tutorial-3.pdf']
> 04/22/10 21:17:00 140471479552272 VenueClientController
> VenueClientController.py:944 DEBUG Upload: getting identity
> VenueClientController.py:949 DEBUG Got identity <?xml version="1.0" ?
> ><Subject><Subject auth_data="" auth_type="x509" name="/O=Access
> Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous
> Authority/CN=Anonymous User 17130398eef9fd82cba8dc9d845a1768"/></
> Subject>
> VenueClientController.py:950 DEBUG get_ident_and_upload: Upload URL ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007
> VenueClientController.py:953 DEBUG Get_ident_and_upload: Word is:
> ftps:
> localhost:8006
> 04/22/10 21:17:00 140471479552272 DataStore DataStore.py:1267
> INFO UploadFiles: ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007
> 04/22/10 21:17:00 140471479552272 DataStore DataStore.py:1271
> DEBUG UploadFiles: ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007
> /home/ercea/Descargas/DSD-Tutorial-3.pdf [u'/home/ercea/Descargas/
> 04/22/10 21:17:00 140471479552272 FTPSClient FTPSClient.py:141
> DEBUG Entered FTPSUploadFile: localfile=/home/ercea/Descargas/DSD-
> Tutorial-3.pdf url=ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007
> VenueClientController.py:862 DEBUG Started thread
> 04/22/10 21:17:20 140471517653264 VenueClient VenueClient.py:605
> DEBUG Calling Heartbeat, time now: 1271963840
> 04/22/10 21:17:20 140471517653264 VenueClient VenueClient.py:629
> DEBUG Next Heartbeat needed within 36s
> 04/22/10 21:17:20 140471517653264 VenueClient VenueClient.py:639
> DEBUG heartBeatCounter = 2
> 04/22/10 21:17:56 140471401707792 VenueClient VenueClient.py:605
> DEBUG Calling Heartbeat, time now: 1271963876
> 04/22/10 21:17:56 140471401707792 VenueClient VenueClient.py:629
> 04/22/10 21:17:56 140471401707792 VenueClient VenueClient.py:639
> DEBUG heartBeatCounter = 3
> Here increment heartBeatCounter +1.
> Ah, I have this problem, in the same network, on ubuntu system
> (Ubuntu 9.10 64 bits), but I've tested on Windows 7 and I can upload
> files without problems.
> Regards!
> El dia 22 abr 2010 18:29, Thomas Uram <turam at mcs.anl.gov> escribió:
> Hi Jesus:
> There is probably some indication of the problem in the
> VenueClient.log file. If you submit a bug report from the Help menu
> after this happens, a recent portion of the VenueClient.log file
> will be included with the report, and we can review it. If you want
> to look yourself, the log file resides in the following locations
> based on platform:
> MacOS, Linux: ~/.AccessGrid3/Logs
> Windows: c:\documents and settings\username\application data
> \AccessGrid3\Logs (adjusted for your locale, of course)
> Tom
> On Apr 22, 2010, at 11:11 AM, Jesus Cea Oliva wrote:
> Hi list again, sorry for my constants problems xD.
> I'm trying upload files to our VenueServer and my problem is
> strange. Firstly, I've created a VenueServer locally, for testing.
> Well, when I try to upload a file, I can see the message on the
> VenueClient "Uploading file X" and a progressbar, but, when the
> progressbar is near to the end, stops and list of files (Data
> section) don't refresh. So I beleived that the file can't upload.
> But, really, the file has uploaded, because I can see the folder
> Data of my local VenueServer, and the file is copied in this folder.
> In this case, if I reset VenueServer and VenueClient, then, I can
> see the files in Data section.
> So I think that the file uploads fine but, the list of files don't
> refresh and the file uploaded don't appears.
> I must say that, sometimes, I can upload a file so I don't know
> whats really the problem (ports closed? firewall? path or name
> files? file size?) .
> Thanks again and apologize for any inconveniences
> Regards!
> <VenueClient.log>
Christoph Willing +61 7 3365 8316
QCIF Access Grid Manager
University of Queensland
