[AG-TECH] VPCscreen, Multicast and TTL
Christoph Willing
c.willing at uq.edu.au
Thu Apr 1 10:34:50 CDT 2010
On 02/04/2010, at 12:26 AM, Philippe d'Anfray wrote:
> Bonjour,
> Yes, bien sûr, I can test, we are using ubuntu 9.10 64bit version
Philippe,
Could you try some tests with:
http://www.vislab.uq.edu.au/debuntu/tests/vpcscreen_0.2-4_amd64.deb
You'll have to download manually and use dpkg to install (rather than
apt-get etc.):
sudo dpkg -i vpcscreen_0.2-4_amd64.deb
chris
> Christoph Willing a écrit :
>> Anyway, I think I've found the cause in the vpcscreen code and will
>> apply a simple minded fix for testing. Would you be able to test
>> it? I
>> can't easily replicate your problem here to confirm that the fix
>> works. If you are able to help with the testing, could you confirm
>> that you're using Ubuntu 9.10 and whether you're using 32 or 64bit
>> version please, so that I can build the appropriate version for you?
> <Philippe_d-Anfray.vcf>
Christoph Willing +61 7 3365 8316
QCIF Access Grid Manager
University of Queensland
