[AG-TECH] VPCscreen, Multicast and TTL
Philippe d'Anfray
Philippe.d-Anfray at cea.fr
Thu Apr 1 09:26:01 CDT 2010
Bonjour,
Yes, bien sûr, I can test, we are using ubuntu 9.10 64bit version
Merci !!
Philippe
Christoph Willing a écrit :
> Anyway, I think I've found the cause in the vpcscreen code and will
> apply a simple minded fix for testing. Would you be able to test it? I
> can't easily replicate your problem here to confirm that the fix
> works. If you are able to help with the testing, could you confirm
> that you're using Ubuntu 9.10 and whether you're using 32 or 64bit
> version please, so that I can build the appropriate version for you?
Type: text/x-vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100401/ebf074f8/attachment.vcf>
