[AG-TECH] Help with pAG ?
Tobias Schiebeck
Tobias.Schiebeck at manchester.ac.uk
Mon Sep 7 10:09:06 CDT 2009
Hi Philippe,
On Mon, 2009-09-07 at 15:52 +0200, Philippe d'Anfray wrote:
> Bonjour
> I'm not sure this is the right list to post (...) but I don't know where to find some help
> We use AccessGrid to broadcast our seminars on the internet and are very interested in using PAG
> as it is very easy for anyone to connect to the virtual room through a web browser.
> http://www.rcs.manchester.ac.uk/research/PAG
> "Portal Access Grid" has been reported to work with Gridsphere uPortal and Pluto, this
> last one beeing a priori the easiest to install and use if you want to run only this
> specific portlet.
> http://portals.apache.org/pluto/
> But there is not so much documentation for all those tools...
> 1) I got the pluto bundle (which installs both pluto and tomcat)
> everything is OK
> 2) I downloaded and untar pag_1-1.tar in .../pluto/webapps
You might need to change the web.xml file in the pag folder to the
version attached. The file in the package is written for gridsphere.
Best wishes
Tobias
> Now PAG is listed (and working) in the Tomcat application manager
> but it is not listed in the Portlet applications list in the Pluto Admin menu
> I tried various things...(with the WEB_INF, etc...) but could not go further,
> I probably missed some crucial step .. ?
> D'avance Merci
> Bien cordialement,
> Philippe
Tobias Schiebeck tobias.schiebeck at manchester.ac.uk
Research Computing Services http://www.rcs.manchester.ac.uk
The University of Manchester tel: (+44) 161-275-0601
Type: application/xml
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090907/0f5df17c/attachment.xml>
