[AG-TECH] ubuntu 9.10 + AG 3.2 beta
    Christoph Willing
    c.willing at uq.edu.au
    Thu Nov 19 05:51:36 CST 2009
On 19/11/2009, at 10:03 AM, Porfirio Gaona wrote:
> Hello,
> Yes, I have some actions to do.
> 1.- I have to connect just 1 capture card (preferable on a different
> slot).
Porfirio,
I've just noticed that I also have the "IRQF_DISABLED is not
guaranteed on shared IRQs" message on at least one of our machines.
yet the vic video works fine i.e. you may not have a hardware problem
at all.
That definitely makes Andrew's suggestion about a permissions problem
something to consider.
> 2.- Change permissions under /dev/video* (thanks Andrew Leahy).   My
> username is on administrator group (I can make "sudo" commands), but
> it can be a reason to no detect my capture cards on my AG 3.2 beta.
Any user should be able to access the /dev/video* devices provided
they are a member of /dev/video*'s group - thats usually the "video"
group. You can check whether you are a member of the group by running
the command:
     groups
which will return a list of the groups the current user is a member
of. If you are not a member of the video group, add yourself to it in
the /etc/group file. After any changes to this file, you may need to
log in again for the changes to have an effect (at least on the
"groups" command).
chris
> 3.- I will test with another apps related with my capture video
> cardes (Hauppauge based on BT878 chipset).
> Thanks to all, I'll write my results.
> Porfirio Gaona
> On Nov 18, 2009, at 2:59 PM, Christoph Willing wrote:
>> On 19/11/2009, at 5:36 AM, Porfirio Gaona wrote:
>>> Hello,
>>> I'm upgrading video machine from Fedora to Ubuntu 9.10(Ubuntu
>>> Karmic).  I read from   http://www.vislab.uq.edu.au/research/accessgrid/software/debian/karmic.html
>>>   that AG3.2 beta is practically "stable".
>>> On this video machine, I have 2 Hauppauge capture video cards
>>> based on BT878 Chipset.
>>> I made a dmsg command and I put on bold font the messages that I
>>> consider important.
>> [snip]
>>> [    8.394225] bttv0: using: Hauppauge (bt878)
>>> [card=10,autodetected]
>>> [    8.394233] IRQ 21/bttv0: IRQF_DISABLED is not guaranteed on
>>> shared IRQs
>> [snip]
>>> AG3.2 can not identify my /dev/video0 and /dev/video1, the Access
>>> Grid Node Management just can identify X11 like video source, but
>>> my ubuntu could identify my 2 video capture cards.
>> Porfirio,
>> It looks like a hardware issue - your cards are recognised but not
>> enabled by the operating system, so AG software won't detect them.
>> Is any other (non-AG) software able to use video from these cards?
>> Since the problem appears to be at the system level - some IRQ
>> sharing issue - I would first try with only 1 capture card
>> installed. You may also have to move the card(s) to different slots
>> and look for differences in behaviour.
>> You mention that you've just upgraded your system - did you have AG
>> software installed and running on the previous system with this
>> same hardware combination?
>> chris
>> Christoph Willing                       +61 7 3365 8316
>> QCIF Access Grid Manager
>> University of Queensland
