[AG-TECH] ubuntu 9.10 + AG 3.2 beta
    Porfirio Gaona
    pgg at unam.mx
    Wed Nov 18 18:03:42 CST 2009
Hello,
Yes, I have some actions to do.
1.- I have to connect just 1 capture card (preferable on a different
slot).
2.- Change permissions under /dev/video* (thanks Andrew Leahy).   My
username is on administrator group (I can make "sudo" commands), but
it can be a reason to no detect my capture cards on my AG 3.2 beta.
3.- I will test with another apps related with my capture video cardes
(Hauppauge based on BT878 chipset).
Thanks to all, I'll write my results.
Porfirio Gaona
On Nov 18, 2009, at 2:59 PM, Christoph Willing wrote:
> On 19/11/2009, at 5:36 AM, Porfirio Gaona wrote:
>> Hello,
>> I'm upgrading video machine from Fedora to Ubuntu 9.10(Ubuntu
>> Karmic).  I read from   http://www.vislab.uq.edu.au/research/accessgrid/software/debian/karmic.html
>>   that AG3.2 beta is practically "stable".
>> On this video machine, I have 2 Hauppauge capture video cards based
>> on BT878 Chipset.
>> I made a dmsg command and I put on bold font the messages that I
>> consider important.
> [snip]
>> [    8.394225] bttv0: using: Hauppauge (bt878) [card=10,autodetected]
>> [    8.394233] IRQ 21/bttv0: IRQF_DISABLED is not guaranteed on
>> shared IRQs
> [snip]
>> AG3.2 can not identify my /dev/video0 and /dev/video1, the Access
>> Grid Node Management just can identify X11 like video source, but
>> my ubuntu could identify my 2 video capture cards.
> Porfirio,
> It looks like a hardware issue - your cards are recognised but not
> enabled by the operating system, so AG software won't detect them.
> Is any other (non-AG) software able to use video from these cards?
> Since the problem appears to be at the system level - some IRQ
> sharing issue - I would first try with only 1 capture card
> installed. You may also have to move the card(s) to different slots
> and look for differences in behaviour.
> You mention that you've just upgraded your system - did you have AG
> software installed and running on the previous system with this same
> hardware combination?
> chris
> Christoph Willing                       +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
