[AG-TECH] VPCScreen and Keynote
Todd Zimmerman
todd.zimmerman at ubc.ca
Mon Nov 16 13:51:36 CST 2009
I actually ran into this issue today using Keynote and Vine Server.
The screen resolution was set to the same and I couldn't find a working
solution other than to export to Powerpoint.
I do see the Vine Server release notes
(http://www.testplant.com/documentation/Vine%20Server%20Release%20Notes.pdf)
indicate as something 'still to do':
Add "Send Full Screen" Mode - Useful for things like Keynote which
bypasses CGRemoteOperations API
Possibly Detect when machine enters such a mode - ie starts running Keynote
Not sure if anyone has any other work around, but other suggestions
would be great.,
Todd
On 11/12/2009 07:47 PM, Douglas Kosovic wrote:
> Hi Philippe,
> Be sure to set the Keynote "slide size" to be the same as the screen resolution set in the MacOS X system preferences, otherwise when Keynote goes to fullscreen mode it'll change the resolution of the screen to whatever the "slide size" is and I suspect confuse VPCScreen. Many screen capturing tools have this issue with fullscreen Keynote.
> Doug
>> -----Original Message-----
>> From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-
>> bounces at lists.mcs.anl.gov] On Behalf Of Philippe d'Anfray
>> Sent: Thursday, 12 November 2009 11:39 PM
>> To: ag-tech at mcs.anl.gov
>> Subject: [AG-TECH] VPCScreen and Keynote
>> Bonjour
>> During our last seminar we thought it was a good idea to use an apple
>> laptop for the "speaker machine".
>> If we run VPCScreen on it we can transmit PDF, OpenOffice, PowerPoint
>> and Keynote presentations and speakers just have to come with a USB
>> key.
>> Alas when you launch a keynote presentation VPCScreen only send a black
>> picture (ggrrrr).
>> Bonne journée
>> Philippe
Collaboration & Visualization Specialist
UBC Okanagan ITServices - http://web.ubc.ca/okanagan/itservices/
WestGrid - http://www.westgrid.ca
Ph. 250-807-9979
Todd Zimmerman - todd.zimmerman at ubc.ca
