[AG-TECH] VPCScreen and Keynote
    Andrew Rowley
    Andrew.Rowley at manchester.ac.uk
    Tue Nov 17 02:55:21 CST 2009
I believe the problem with this and VPCScreen is that KeyNote uses hardware acceleration to display the presentation.  This means that although you see the image on the screen, software screen captures will not as the image doesn't exist within the operating system screen buffers.
The only way to avoid this is to disable hardware acceleration either within the operating system or within KeyNote itself (I have no idea if this is possible in either Mac or KeyNote).
Andrew :)
   Andrew G D Rowley
   Senior Development Officer
   Research Computing Services
   The University of Manchester
   Devonshire House, Oxford Road
   Manchester, M13 9PL
   t :  +44 (0) 161 275 0685
   e :  Andrew.Rowley at manchester.ac.uk
   w :  www.manchester.ac.uk/researchcomputing
-----Original Message-----
From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Todd Zimmerman
Sent: 16 November 2009 19:52
Cc: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] VPCScreen and Keynote
I actually ran into this issue today using Keynote and Vine Server.
The screen resolution was set to the same and I couldn't find a working
solution other than to export to Powerpoint.
I do see the Vine Server release notes
(http://www.testplant.com/documentation/Vine%20Server%20Release%20Notes.pdf)
indicate as something 'still to do':
Add "Send Full Screen" Mode - Useful for things like Keynote which
bypasses CGRemoteOperations API
Possibly Detect when machine enters such a mode - ie starts running Keynote
Not sure if anyone has any other work around, but other suggestions
would be great.,
Todd
On 11/12/2009 07:47 PM, Douglas Kosovic wrote:
> Hi Philippe,
> Be sure to set the Keynote "slide size" to be the same as the screen resolution set in the MacOS X system preferences, otherwise when Keynote goes to fullscreen mode it'll change the resolution of the screen to whatever the "slide size" is and I suspect confuse VPCScreen. Many screen capturing tools have this issue with fullscreen Keynote.
> Doug
>> bounces at lists.mcs.anl.gov] On Behalf Of Philippe d'Anfray
>> Sent: Thursday, 12 November 2009 11:39 PM
>> To: ag-tech at mcs.anl.gov
>> Subject: [AG-TECH] VPCScreen and Keynote
>> Bonjour
>> During our last seminar we thought it was a good idea to use an apple
>> laptop for the "speaker machine".
>> If we run VPCScreen on it we can transmit PDF, OpenOffice, PowerPoint
>> and Keynote presentations and speakers just have to come with a USB
>> key.
>> Alas when you launch a keynote presentation VPCScreen only send a black
>> picture (ggrrrr).
>> Bonne journée
>> Philippe
Collaboration & Visualization Specialist
UBC Okanagan ITServices - http://web.ubc.ca/okanagan/itservices/
WestGrid - http://www.westgrid.ca
Ph. 250-807-9979
Todd Zimmerman - todd.zimmerman at ubc.ca
