[AG-TECH] Odd Venue Server behavior
Vine, Derek A
Derek.Vine at usd.edu
Fri May 8 14:08:21 CDT 2009
Hello all,
I have been having issues with our Venue Server since I first set it up
last spring. First, I have never been able to use anything other than
the default lobby, the exits would not work for anything that I added.
Second, I have had issues using the Data, Services and Application
Sessions in the venue. When someone would try uploading a file it
wouldn't do anything and then may or may not be there the next time you
enter the venue. Third, I recently installed some Windows updates on
this machine and after the restart I have not been able to connect to
Venue Server with the Venue Management tool, it says unable to connect
and logs "SSLError: sslv3 alert certificate expired".
I have attached the venue server log. I will be replacing the existing
box with a new one sometime this summer and would hope to correct
some/all of the issues that I have had over the past year.
On a side note, does anyone have a Venue Server running on Windows
Server 2003? That is what our server team would like me to use so that
they can manage it with the rest of their equipment.
Thank you in advance for any assistance.
Derek Vine
Communication Network Specialist
The University of South Dakota
414 East Clark Street
Vermillion, SD 57069
(605) 677-8215
dvine at usd.edu <mailto:dvine at usd.edu>
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090508/80f1ee41/attachment-0001.htm>
Desc: venueserver.log
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090508/80f1ee41/attachment-0001.obj>
