[AG-TECH] Video capture card Advice request
Khanh ly
khanhly at wasp.uwa.edu.au
Sun Jun 28 20:29:41 CDT 2009
Hi Jason,
We happened to configure AG in a same way as Doug's suggestion,
however, it did not work.
The problem is the saved configuration did not loaded .
We encountered a different problem with the FC10 when replaced the
TripleheadToGo by dual graphics cards and have not fixed them yet.
However, the same systems when booted into Windows XP working well.
Regards
Khanh
Khanh Ly
Computer Support Officer
Western Australian Supercomputer Program (WASP)
The University of Western Australia
On 24/06/2009, at 12:40 PM, Jason Bell wrote:
> G'day Khanh
> Did the suggestion Doug make help?
> As I use a number of IVC-200 video cards without any problems on
> Fedora
> 10.
> Regards,
> Jason.
> -----Original Message-----
> From: Douglas Kosovic [mailto:douglask at itee.uq.edu.au]
> Sent: Tuesday, 12 May 2009 06:33 PM
> To: Khanh ly; ag-tech at lists.mcs.anl.gov
> Subject: Re: [AG-TECH] Video capture card Advice request
> Hi Khanh,
>> We are looking to replace the 4-cameras inputs IEI-IVC 200 cards.
>> They are running well on the windows XP machine. However, they gave
>> poor quality on the Fedora 10 system. Even worse, we must configure
>> the video to transmit PAL signal (using H.261) every time we start
>> Access Grid.
> I suspect you haven't configured the Video Producer Service to use PAL
> and saved the configuration. Or maybe you are setting it to PAL
> directly in VIC, which it'll forget the next time VIC is started. See
> the following on how to configure a Video Producer:
> http://www.accessgrid.org/node/1770
> you might also like to increase the bandwidth and quality sliders to
> see
> if that makes any difference.
> Cheers,
> Doug
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090629/f8e44127/attachment.htm>
