[AG-TECH] Video capture card Advice request
Jason Bell
j.bell at cqu.edu.au
Tue Jun 23 23:40:15 CDT 2009
G'day Khanh
Did the suggestion Doug make help?
As I use a number of IVC-200 video cards without any problems on Fedora
10.
Jason.
-----Original Message-----
From: Douglas Kosovic [mailto:douglask at itee.uq.edu.au]
Sent: Tuesday, 12 May 2009 06:33 PM
To: Khanh ly; ag-tech at lists.mcs.anl.gov
Subject: Re: [AG-TECH] Video capture card Advice request
Hi Khanh,
> We are looking to replace the 4-cameras inputs IEI-IVC 200 cards.
> They are running well on the windows XP machine. However, they gave
> poor quality on the Fedora 10 system. Even worse, we must configure
> the video to transmit PAL signal (using H.261) every time we start
> Access Grid.
I suspect you haven't configured the Video Producer Service to use PAL
and saved the configuration. Or maybe you are setting it to PAL
directly in VIC, which it'll forget the next time VIC is started. See
the following on how to configure a Video Producer:
http://www.accessgrid.org/node/1770
you might also like to increase the bandwidth and quality sliders to see
if that makes any difference.
Cheers,
Doug
