[AG-TECH] Fwd: Strange Windows XP RAT issue
Michael Miller
mimiller at ncsa.uiuc.edu
Wed Feb 18 12:32:38 CST 2009
Yes, the options are laid out in the same order as they are stored in the options array. I think either set of slashes will do, I'd try forward first and have your .bat in a location relative to the VenueClient (i.e. AGTK_LOCATION ??) so that your code is cross platform.
myk
"If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
----- Original Message -----
From: "Enrique Terrazas" <Enrique.Terrazas at ucsf.edu>
To: "AG-TECH" <ag-tech at mcs.anl.gov>
Cc: "Michael Miller" <mimiller at ncsa.uiuc.edu>
Sent: Monday, February 16, 2009 1:36:36 PM GMT -06:00 US/Canada Central
Subject: Re: [AG-TECH] Fwd: Strange Windows XP RAT issue
That should work ... are the options typically called after the
executable?
ie. executable option1 option2
If so, appending a last option of a call to my batch script should
work ...
Also, in Python, on the windows platform, should I add the path with
forward slashes or backslashes?
ie. "; C:\path\to\mycommand ;" or "; C:/path/to/mycommand ;" ?
Maybe a system call after the self._Start( options ) would be better
to avoid messing with the options?
import os
cmd = 'C:\path\to\mycommand'
os.system(cmd)
Thanks again.
Enrique Terrazas
On Feb 16, 2009, at 10:09 AM, Michael Miller wrote:
> ah, yes, that wouldn't work. In looking at %APPDATA%
> \AccessGrid3\local_services\AudioService\AudioService.py I find:
> if self.streamDescription.encryptionFlag != 0:
> options.append( "-crypt" )
> options.append( self.streamDescription.encryptionKey )
> options.append( '%s/%d' %
> (self.streamDescription.location.host,
> self.streamDescription.location.port))
> self.log.info("Starting AudioService")
> self.log.info(" executable = %s" % self.executable)
> self.log.info(" options = %s" % options)
> os.chdir(self.thepath)
> at the end of the Start function of the AudioService class. You
> could append another option for ";my mic command;" and that would
> have the effect I was after in my previous email. While not ideal,
> it might work. Then you can submit a feature request for an
> "Addtional Commands" field in the Service config dialog box.
> Tom, Eric, any thoughts?
> myk
> To: "Michael Miller" <mimiller at ncsa.uiuc.edu>
> Cc: "ag-tech mailing list" <ag-tech at mcs.anl.gov>
> Sent: Monday, February 16, 2009 11:44:57 AM GMT -06:00 US/Canada
> Central
> Subject: Re: [AG-TECH] Strange Windows XP RAT issue
> Michael,
> Thanks for your suggestion ... I'll try toggling the talk on/off
> settings to see what effect that has.
> Unfortunately, modifying the shortcut won't solve it as RAT is not
> initialized until you enter a venue, and is also initialized when you
> switch venues.
> I think the 960 has two PCI slots (one is taken up by the video
> board), so I may have to buy a sound card and bypass the onboard audio
> if I have a spare PCI slot.
> Enrique Terrazas
> On Feb 16, 2009, at 9:32 AM, Michael Miller wrote:
>> Enrique,
>> Not sure how to fix it, perhaps the talk on/off settings in the
>> AudioService config?
>> As for the command line, you could add the command at the end of the
>> target field of the AG shortcut properties dialog box. Just
>> separate it from the AG command with a ; and the shortcut should run
>> both commands.
>> Let me know how it goes.
>> myk
> Enrique Terrazas, MD, MS
> Director, Laboratory Medicine Residency Program
> Director, NCPL Laboratories
> Chief, Laboratory Information Systems
> HS Associate Clinical Professor
> University of California, San Francisco
> Clinical Laboratories, Box 0100
> 4-8931, 415.514.8931(voice)
> 3-4826, 415.353.4826(fax)
> 415.443.0913(pager)
> CONFIDENTIALITY NOTICE: The information contained in this
> transmission, including any enclosed files, is confidential and
> intended solely for the addressee. If you are not the intended
> recipient, you are hereby notified that any distribution, copying,
> disclosure and use of, the contents of this transmission is strictly
> prohibited. If you have received this communication in error, please
> notify the sender immediately by reply email and permanently delete
> this message, enclosures and all copies.
415.443.0913(pager)
