[AG-TECH] Fwd: Strange Windows XP RAT issue
Enrique Terrazas
Enrique.Terrazas at ucsf.edu
Mon Feb 16 13:36:36 CST 2009
That should work ... are the options typically called after the
executable?
ie. executable option1 option2
If so, appending a last option of a call to my batch script should
work ...
Also, in Python, on the windows platform, should I add the path with
forward slashes or backslashes?
ie. "; C:\path\to\mycommand ;" or "; C:/path/to/mycommand ;" ?
Maybe a system call after the self._Start( options ) would be better
to avoid messing with the options?
import os
cmd = 'C:\path\to\mycommand'
os.system(cmd)
Thanks again.
Enrique Terrazas
On Feb 16, 2009, at 10:09 AM, Michael Miller wrote:
> ah, yes, that wouldn't work. In looking at %APPDATA%
> \AccessGrid3\local_services\AudioService\AudioService.py I find:
> if self.streamDescription.encryptionFlag != 0:
> options.append( "-crypt" )
> options.append( self.streamDescription.encryptionKey )
> options.append( '%s/%d' %
> (self.streamDescription.location.host,
> self.streamDescription.location.port))
> self.log.info("Starting AudioService")
> self.log.info(" executable = %s" % self.executable)
> self.log.info(" options = %s" % options)
> os.chdir(self.thepath)
> at the end of the Start function of the AudioService class. You
> could append another option for ";my mic command;" and that would
> have the effect I was after in my previous email. While not ideal,
> it might work. Then you can submit a feature request for an
> "Addtional Commands" field in the Service config dialog box.
> Tom, Eric, any thoughts?
> myk
> "If you're clear in your vision and trust the people in your team
> with clear objectives, they will invariably do their best to achieve
> everything desired, and usually deliver everything you could have
> hoped for and even more." -Paul Debevec
> From: "Enrique Terrazas" <Enrique.Terrazas at ucsf.edu>
> To: "Michael Miller" <mimiller at ncsa.uiuc.edu>
> Cc: "ag-tech mailing list" <ag-tech at mcs.anl.gov>
> Sent: Monday, February 16, 2009 11:44:57 AM GMT -06:00 US/Canada
> Central
> Subject: Re: [AG-TECH] Strange Windows XP RAT issue
> Michael,
> Thanks for your suggestion ... I'll try toggling the talk on/off
> settings to see what effect that has.
> Unfortunately, modifying the shortcut won't solve it as RAT is not
> initialized until you enter a venue, and is also initialized when you
> switch venues.
> I think the 960 has two PCI slots (one is taken up by the video
> board), so I may have to buy a sound card and bypass the onboard audio
> if I have a spare PCI slot.
> Enrique Terrazas
> On Feb 16, 2009, at 9:32 AM, Michael Miller wrote:
>> Enrique,
>> Not sure how to fix it, perhaps the talk on/off settings in the
>> AudioService config?
>> As for the command line, you could add the command at the end of the
>> target field of the AG shortcut properties dialog box. Just
>> separate it from the AG command with a ; and the shortcut should run
>> both commands.
>> Let me know how it goes.
>> myk
> Enrique Terrazas, MD, MS
> Director, Laboratory Medicine Residency Program
> Director, NCPL Laboratories
> Chief, Laboratory Information Systems
> HS Associate Clinical Professor
> University of California, San Francisco
> Clinical Laboratories, Box 0100
> 4-8931, 415.514.8931(voice)
> 3-4826, 415.353.4826(fax)
> 415.443.0913(pager)
> CONFIDENTIALITY NOTICE: The information contained in this
> transmission, including any enclosed files, is confidential and
> intended solely for the addressee. If you are not the intended
> recipient, you are hereby notified that any distribution, copying,
> disclosure and use of, the contents of this transmission is strictly
> prohibited. If you have received this communication in error, please
> notify the sender immediately by reply email and permanently delete
> this message, enclosures and all copies.
415.443.0913(pager)
