[AG-TECH] Fwd: Strange Windows XP RAT issue
Enrique Terrazas
Enrique.Terrazas at ucsf.edu
Fri Feb 20 18:49:27 CST 2009
No joy ... got RAT errors when I tried the options.append() method
(with both back and forward slashes), and when I tried the
os.system(cmd) method, I see a brief flash of a command line window
but unfortunately this happens a few second before the RAT window
shows up, and the option is not set. I tried to put in a sleep
command, but that messed things up since VIC would not open :(
Enrique Terrazas
On Feb 18, 2009, at 10:32 AM, Michael Miller wrote:
> Yes, the options are laid out in the same order as they are stored
> in the options array. I think either set of slashes will do, I'd
> try forward first and have your .bat in a location relative to the
> VenueClient (i.e. AGTK_LOCATION ??) so that your code is cross
> platform.
> myk
> "If you're clear in your vision and trust the people in your team
> with clear objectives, they will invariably do their best to achieve
> everything desired, and usually deliver everything you could have
> hoped for and even more." -Paul Debevec
> From: "Enrique Terrazas" <Enrique.Terrazas at ucsf.edu>
> To: "AG-TECH" <ag-tech at mcs.anl.gov>
> Cc: "Michael Miller" <mimiller at ncsa.uiuc.edu>
> Sent: Monday, February 16, 2009 1:36:36 PM GMT -06:00 US/Canada
> Central
> Subject: Re: [AG-TECH] Fwd: Strange Windows XP RAT issue
> That should work ... are the options typically called after the
> executable?
> ie. executable option1 option2
> If so, appending a last option of a call to my batch script should
> work ...
> Also, in Python, on the windows platform, should I add the path with
> forward slashes or backslashes?
> ie. "; C:\path\to\mycommand ;" or "; C:/path/to/mycommand ;" ?
> Maybe a system call after the self._Start( options ) would be better
> to avoid messing with the options?
> import os
> cmd = 'C:\path\to\mycommand'
> os.system(cmd)
> Thanks again.
> Enrique Terrazas
> On Feb 16, 2009, at 10:09 AM, Michael Miller wrote:
>> ah, yes, that wouldn't work. In looking at %APPDATA%
>> \AccessGrid3\local_services\AudioService\AudioService.py I find:
>> if self.streamDescription.encryptionFlag != 0:
>> options.append( "-crypt" )
>> options.append( self.streamDescription.encryptionKey )
>> options.append( '%s/%d' %
>> (self.streamDescription.location.host,
>> self.streamDescription.location.port))
>> self.log.info("Starting AudioService")
>> self.log.info(" executable = %s" % self.executable)
>> self.log.info(" options = %s" % options)
>> os.chdir(self.thepath)
>> at the end of the Start function of the AudioService class. You
>> could append another option for ";my mic command;" and that would
>> have the effect I was after in my previous email. While not ideal,
>> it might work. Then you can submit a feature request for an
>> "Addtional Commands" field in the Service config dialog box.
>> Tom, Eric, any thoughts?
>> myk
>> To: "Michael Miller" <mimiller at ncsa.uiuc.edu>
>> Cc: "ag-tech mailing list" <ag-tech at mcs.anl.gov>
>> Sent: Monday, February 16, 2009 11:44:57 AM GMT -06:00 US/Canada
>> Central
>> Subject: Re: [AG-TECH] Strange Windows XP RAT issue
>> Michael,
>> Thanks for your suggestion ... I'll try toggling the talk on/off
>> settings to see what effect that has.
>> Unfortunately, modifying the shortcut won't solve it as RAT is not
>> initialized until you enter a venue, and is also initialized when you
>> switch venues.
>> I think the 960 has two PCI slots (one is taken up by the video
>> board), so I may have to buy a sound card and bypass the onboard
>> audio
>> if I have a spare PCI slot.
>> Enrique Terrazas
>> On Feb 16, 2009, at 9:32 AM, Michael Miller wrote:
>>> Enrique,
>>> Not sure how to fix it, perhaps the talk on/off settings in the
>>> AudioService config?
>>> As for the command line, you could add the command at the end of the
>>> target field of the AG shortcut properties dialog box. Just
>>> separate it from the AG command with a ; and the shortcut should run
>>> both commands.
>>> Let me know how it goes.
>>> myk
>> Enrique Terrazas, MD, MS
>> Director, Laboratory Medicine Residency Program
>> Director, NCPL Laboratories
>> Chief, Laboratory Information Systems
>> HS Associate Clinical Professor
>> University of California, San Francisco
>> Clinical Laboratories, Box 0100
>> 4-8931, 415.514.8931(voice)
>> 3-4826, 415.353.4826(fax)
>> 415.443.0913(pager)
>> CONFIDENTIALITY NOTICE: The information contained in this
>> transmission, including any enclosed files, is confidential and
>> intended solely for the addressee. If you are not the intended
>> recipient, you are hereby notified that any distribution, copying,
>> disclosure and use of, the contents of this transmission is strictly
>> prohibited. If you have received this communication in error, please
>> notify the sender immediately by reply email and permanently delete
>> this message, enclosures and all copies.
> 415.443.0913(pager)
415.443.0913(pager)
