[AG-TECH] BlackMagic HDMI vic beta download
Andrew Ford
adhesionmusic at gmail.com
Wed Feb 18 10:35:26 CST 2009
Mike,
By that do you mean you set the framerate slider in vic to 30? If you have a
PAL camera I don't think it would make a difference since the camera (if it
can only be set to PAL) can only output 50Hz/25fps. You could check the
framerate indicator next to the thumbnail to find out what's actually being
sent.
--Andrew
2009/2/18 <Mike.W.Daley at cs.cardiff.ac.uk>
> Hi Gurcharan
> I'm using the Intensity Pro HDMI and Analog HD/SD Card.
> I did push it to 30 fps.
> Mike
> Quoting "Gurcharan S. Khanna" <gurcharan.khanna at rit.edu>:
> Mike,
>> are you using the Intensity Pro or the Decklink ExtremeHD card? i am
>> suspecting
>> there are differences between the two. i've seen 30 fps v 60 fps as the
>> specs for the
>> Decklink v. the Intensity come up on its GUI and don't know why this is
>> the case.
>> thanks,
>> -gurcharan
>> Mike.W.Daley at cs.cardiff.ac.uk wrote:
>>> Hi All
>>> Just to clarify.
>>> I'm using a SONY HDR-SR12E camera.
>>> I've tested it both in PAL and NTSC formats at 1080i and its all fine.
>>> In resting phase. (very little activity) I'm getting 1.8M/s transfer
>>> rate.
>>> Mike
>>> Quoting Nathan Gardiner <nathan.gardiner at canterbury.ac.nz>:
>>> We have had problems trying to get an AVCHD camcorder to work with
>>>> BlackMagic card and i think most AVCHD camcorders that I tested didn't
>>>> seem to have true HDMI realtime output.
>>>> I don't think that NTSC and PAL should make much difference as the
>>>> BlackMagic card accepts input from either or.
>>>> Also, we should have a new JVC camcorder arriving in the next day or
>>>> so and will be testing that out.
>>>> Regards,
>>>> Nathan
>>>> On 18/02/2009, at 11:56 AM, Jimmy Miklavcic wrote:
>>>> I did check it a while back and it was fine. I had to install a
>>>>> graphics card in order for Media Express to work. Right now I'm using
>>>>> the on-board VGA for the display. I didn't think I needed a high-end
>>>>> display card just to run the service manager. Anyway I think you and I
>>>>> are seeing the same symptoms. I'm using 720 @ 30p.
>>>>> Jimmy
>>>>> Jimmy Miklavcic
>>>>> Multimedia Specialist
>>>>> Jimmy.Miklavcic at utah.edu
>>>>> UNIVERSITY OF UTAH
>>>>> CTR FOR HIGH PERFORM COMPUTING
>>>>> 155 SOUTH 1452 EAST RM 405
>>>>> SALT LAKE CITY, UT 84112-0190
>>>>> Office: 801.585.9335
>>>>> Fax: 801.585.5366
>>>>> http://www.anotherlanguage.org
>>>>> From: adhesionmusic at gmail.com [mailto:adhesionmusic at gmail.com] On
>>>>> Behalf Of Andrew Ford
>>>>> Sent: Tuesday, February 17, 2009 2:43 PM
>>>>> To: Jimmy Miklavcic
>>>>> Cc: Mike.W.Daley at cs.cardiff.ac.uk; Nathan Gardiner; ag-
>>>>> tech at mcs.anl.gov
>>>>> Subject: Re: [AG-TECH] BlackMagic HDMI vic beta download
>>>>> Hi Jimmy,
>>>>> Did you try checking the HDMI input directly, via either Blackmagic
>>>>> Media Express or AMCap? If that works then we probably have the same
>>>>> problem - I can see the video fine in Media Express but vic just shows a
>>>>> black screen with any codec or size. Here we have the Blackmagic Intensity
>>>>> Pro cards with Sony HDR-SR11 cameras, which are AVCHD. Side note: I don't
>>>>> think the recording format makes much of a difference, just the specific
>>>>> video format, as in 1080i at a certain framerate.
>>>>> Nathan, is vic expecting a certain framerate? The format that worked
>>>>> with Media Express was 1080i @ 59.97. If it's only been tested with PAL
>>>>> so far, I would hazard a guess and say that the NTSC isn't using the
>>>>> right format/framerate in some way.
>>>>> --Andrew
>>>>> 2009/2/17 Jimmy Miklavcic <jimmy.miklavcic at utah.edu>
>>>>> Mike, it's great news that you have been able to get HIT Lab's vic to
>>>>> work. I haven't been so lucky. I have AVCHD (Panasonic AG-HMC150)
>>>>> video
>>>>> cameras. Mike I think that you have MPEG2 based HD cameras. Are yours
>>>>> Sony? Nathan, I don't think you tested with an AVCHD camera.
>>>>> All I get is black, which I think tells me that it sees the video card
>>>>> but not, the video stream. Mike, did you use 1080i/p or 720p?
>>>>> If anyone has any suggestions, I'm open.
>>>>> Jimmy
>>>>> Jimmy Miklavcic
>>>>> UNIVERSITY OF UTAH
>>>>> Fax: 801.585.5366
>>>>> -----Original Message-----
>>>>> From: ag-tech-bounces at lists.mcs.anl.gov
>>>>> [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of
>>>>> Sent: Tuesday, February 17, 2009 1:52 AM
>>>>> To: Nathan Gardiner
>>>>> Cc: ag-tech at mcs.anl.gov; Mike.W.Daley at cs.cardiff.ac.uk
>>>>> Hi Nathan
>>>>> Thanks otherwise all looking good.
>>>>> Not bad on bandwidth usage either.
>>>>> Mike
>>> Michael Daley M.Phil MBCS GCFA
>>> This message was sent using IMP, the Internet Messaging Program.
>> Gurcharan S. Khanna, Ph.D.
>> Director of Research Computing
>> Office of the Vice President for Research
>> http://rc.rit.edu
>> Assistant Research Professor, Ph.D. Program
>> Golisano College of Computing and Information Sciences
>> http://people.rit.edu/gskpop
>> Director, Interactive Collaboration Environments Laboratory,
>> Center for the Advancing the Study of Cyberinfrastructure
>> http://icelab.rit.edu
>> Rochester Institute of Technology
>> 1 Lomb Memorial Drive
>> Rochester, New York 14623-5603
>> Phone: 585-475-7504 ~ Cell: 585-451-8370
>> Email: gurcharan.khanna at rit.edu
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090218/8fb47a2d/attachment-0001.htm>
