[AG-TECH] BlackMagic HDMI vic beta download
Mike.W.Daley at cs.cardiff.ac.uk
Wed Feb 18 08:37:42 CST 2009
Hi Gurcharan
I'm using the Intensity Pro HDMI and Analog HD/SD Card.
I did push it to 30 fps.
Mike
Quoting "Gurcharan S. Khanna" <gurcharan.khanna at rit.edu>:
> Mike,
> are you using the Intensity Pro or the Decklink ExtremeHD card? i am
> suspecting
> there are differences between the two. i've seen 30 fps v 60 fps as the
> specs for the
> Decklink v. the Intensity come up on its GUI and don't know why this is
> the case.
> thanks,
> -gurcharan
> Mike.W.Daley at cs.cardiff.ac.uk wrote:
>> Hi All
>> Just to clarify.
>> I'm using a SONY HDR-SR12E camera.
>> I've tested it both in PAL and NTSC formats at 1080i and its all fine.
>> In resting phase. (very little activity) I'm getting 1.8M/s transfer rate.
>> Mike
>> Quoting Nathan Gardiner <nathan.gardiner at canterbury.ac.nz>:
>>> We have had problems trying to get an AVCHD camcorder to work with
>>> BlackMagic card and i think most AVCHD camcorders that I tested didn't
>>> seem to have true HDMI realtime output.
>>> I don't think that NTSC and PAL should make much difference as the
>>> BlackMagic card accepts input from either or.
>>> Also, we should have a new JVC camcorder arriving in the next day or
>>> so and will be testing that out.
>>> Regards,
>>> Nathan
>>> On 18/02/2009, at 11:56 AM, Jimmy Miklavcic wrote:
>>>> I did check it a while back and it was fine. I had to install a
>>>> graphics card in order for Media Express to work. Right now I'm
>>>> using the on-board VGA for the display. I didn't think I needed
>>>> a high-end display card just to run the service manager.
>>>> Anyway I think you and I are seeing the same symptoms. I'm
>>>> using 720 @ 30p.
>>>> Jimmy
>>>> Jimmy Miklavcic
>>>> Multimedia Specialist
>>>> Jimmy.Miklavcic at utah.edu
>>>> UNIVERSITY OF UTAH
>>>> CTR FOR HIGH PERFORM COMPUTING
>>>> 155 SOUTH 1452 EAST RM 405
>>>> SALT LAKE CITY, UT 84112-0190
>>>> Office: 801.585.9335
>>>> Fax: 801.585.5366
>>>> http://www.anotherlanguage.org
>>>> From: adhesionmusic at gmail.com [mailto:adhesionmusic at gmail.com] On
>>>> Behalf Of Andrew Ford
>>>> Sent: Tuesday, February 17, 2009 2:43 PM
>>>> To: Jimmy Miklavcic
>>>> Cc: Mike.W.Daley at cs.cardiff.ac.uk; Nathan Gardiner; ag- tech at mcs.anl.gov
>>>> Subject: Re: [AG-TECH] BlackMagic HDMI vic beta download
>>>> Hi Jimmy,
>>>> Did you try checking the HDMI input directly, via either
>>>> Blackmagic Media Express or AMCap? If that works then we
>>>> probably have the same problem - I can see the video fine in
>>>> Media Express but vic just shows a black screen with any codec
>>>> or size. Here we have the Blackmagic Intensity Pro cards with
>>>> Sony HDR-SR11 cameras, which are AVCHD. Side note: I don't
>>>> think the recording format makes much of a difference, just the
>>>> specific video format, as in 1080i at a certain framerate.
>>>> Nathan, is vic expecting a certain framerate? The format that
>>>> worked with Media Express was 1080i @ 59.97. If it's only been
>>>> tested with PAL so far, I would hazard a guess and say that the
>>>> NTSC isn't using the right format/framerate in some way.
>>>> --Andrew
>>>> 2009/2/17 Jimmy Miklavcic <jimmy.miklavcic at utah.edu>
>>>> Mike, it's great news that you have been able to get HIT Lab's vic to
>>>> work. I haven't been so lucky. I have AVCHD (Panasonic AG-HMC150) video
>>>> cameras. Mike I think that you have MPEG2 based HD cameras. Are yours
>>>> Sony? Nathan, I don't think you tested with an AVCHD camera.
>>>> All I get is black, which I think tells me that it sees the video card
>>>> but not, the video stream. Mike, did you use 1080i/p or 720p?
>>>> If anyone has any suggestions, I'm open.
>>>> Jimmy
>>>> Jimmy Miklavcic
>>>> UNIVERSITY OF UTAH
>>>> Fax: 801.585.5366
>>>> -----Original Message-----
>>>> From: ag-tech-bounces at lists.mcs.anl.gov
>>>> [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of
>>>> Sent: Tuesday, February 17, 2009 1:52 AM
>>>> To: Nathan Gardiner
>>>> Cc: ag-tech at mcs.anl.gov; Mike.W.Daley at cs.cardiff.ac.uk
>>>> Hi Nathan
>>>> Thanks otherwise all looking good.
>>>> Not bad on bandwidth usage either.
>>>> Mike
>> Michael Daley M.Phil MBCS GCFA
>> This message was sent using IMP, the Internet Messaging Program.
> Gurcharan S. Khanna, Ph.D.
> Director of Research Computing
> Office of the Vice President for Research
> http://rc.rit.edu
> Assistant Research Professor, Ph.D. Program
> Golisano College of Computing and Information Sciences
> http://people.rit.edu/gskpop
> Director, Interactive Collaboration Environments Laboratory,
> Center for the Advancing the Study of Cyberinfrastructure
> http://icelab.rit.edu
> Rochester Institute of Technology
> 1 Lomb Memorial Drive
> Rochester, New York 14623-5603
> Phone: 585-475-7504 ~ Cell: 585-451-8370
> Email: gurcharan.khanna at rit.edu
