[AG-TECH] BlackMagic HDMI vic beta download
Mike.W.Daley at cs.cardiff.ac.uk
Wed Feb 18 11:44:59 CST 2009
Yes OK I will check.
I was just altering the slider but did not take any notice of what I
actually got.
Just tried to stream it to Jimmy in Utah but currently having
multicast problems once again. It was fixed yesterday but broke today.
Hoping to test against Utah again next week.
Mike
Quoting Andrew Ford <adhesionmusic at gmail.com>:
> Mike,
> By that do you mean you set the framerate slider in vic to 30? If you have a
> PAL camera I don't think it would make a difference since the camera (if it
> can only be set to PAL) can only output 50Hz/25fps. You could check the
> framerate indicator next to the thumbnail to find out what's actually being
> sent.
> --Andrew
> 2009/2/18 <Mike.W.Daley at cs.cardiff.ac.uk>
>> Hi Gurcharan
>> I'm using the Intensity Pro HDMI and Analog HD/SD Card.
>> I did push it to 30 fps.
>> Mike
>> Quoting "Gurcharan S. Khanna" <gurcharan.khanna at rit.edu>:
>> Mike,
>>> are you using the Intensity Pro or the Decklink ExtremeHD card? i am
>>> suspecting
>>> there are differences between the two. i've seen 30 fps v 60 fps as the
>>> specs for the
>>> Decklink v. the Intensity come up on its GUI and don't know why this is
>>> the case.
>>> thanks,
>>> -gurcharan
>>> Mike.W.Daley at cs.cardiff.ac.uk wrote:
>>>> Hi All
>>>> Just to clarify.
>>>> I'm using a SONY HDR-SR12E camera.
>>>> I've tested it both in PAL and NTSC formats at 1080i and its all fine.
>>>> In resting phase. (very little activity) I'm getting 1.8M/s transfer
>>>> rate.
>>>> Mike
>>>> Quoting Nathan Gardiner <nathan.gardiner at canterbury.ac.nz>:
>>>> We have had problems trying to get an AVCHD camcorder to work with
>>>>> BlackMagic card and i think most AVCHD camcorders that I tested didn't
>>>>> seem to have true HDMI realtime output.
>>>>> I don't think that NTSC and PAL should make much difference as the
>>>>> BlackMagic card accepts input from either or.
>>>>> Also, we should have a new JVC camcorder arriving in the next day or
>>>>> so and will be testing that out.
>>>>> Regards,
>>>>> Nathan
>>>>> On 18/02/2009, at 11:56 AM, Jimmy Miklavcic wrote:
>>>>> I did check it a while back and it was fine. I had to install a
>>>>>> graphics card in order for Media Express to work. Right now
>>>>>> I'm using
>>>>>> the on-board VGA for the display. I didn't think I needed a high-end
>>>>>> display card just to run the service manager. Anyway I think
>>>>>> you and I
>>>>>> are seeing the same symptoms. I'm using 720 @ 30p.
>>>>>> Jimmy
>>>>>> Jimmy Miklavcic
>>>>>> Multimedia Specialist
>>>>>> Jimmy.Miklavcic at utah.edu
>>>>>> UNIVERSITY OF UTAH
>>>>>> CTR FOR HIGH PERFORM COMPUTING
>>>>>> 155 SOUTH 1452 EAST RM 405
>>>>>> SALT LAKE CITY, UT 84112-0190
>>>>>> Office: 801.585.9335
>>>>>> Fax: 801.585.5366
>>>>>> http://www.anotherlanguage.org
>>>>>> From: adhesionmusic at gmail.com [mailto:adhesionmusic at gmail.com] On
>>>>>> Behalf Of Andrew Ford
>>>>>> Sent: Tuesday, February 17, 2009 2:43 PM
>>>>>> To: Jimmy Miklavcic
>>>>>> Cc: Mike.W.Daley at cs.cardiff.ac.uk; Nathan Gardiner; ag-
>>>>>> tech at mcs.anl.gov
>>>>>> Subject: Re: [AG-TECH] BlackMagic HDMI vic beta download
>>>>>> Hi Jimmy,
>>>>>> Did you try checking the HDMI input directly, via either Blackmagic
>>>>>> Media Express or AMCap? If that works then we probably have the same
>>>>>> problem - I can see the video fine in Media Express but vic
>>>>>> just shows a
>>>>>> black screen with any codec or size. Here we have the
>>>>>> Blackmagic Intensity
>>>>>> Pro cards with Sony HDR-SR11 cameras, which are AVCHD. Side
>>>>>> note: I don't
>>>>>> think the recording format makes much of a difference, just
>>>>>> the specific
>>>>>> video format, as in 1080i at a certain framerate.
>>>>>> Nathan, is vic expecting a certain framerate? The format that worked
>>>>>> with Media Express was 1080i @ 59.97. If it's only been
>>>>>> tested with PAL
>>>>>> so far, I would hazard a guess and say that the NTSC isn't using the
>>>>>> right format/framerate in some way.
>>>>>> --Andrew
>>>>>> 2009/2/17 Jimmy Miklavcic <jimmy.miklavcic at utah.edu>
>>>>>> Mike, it's great news that you have been able to get HIT Lab's vic to
>>>>>> work. I haven't been so lucky. I have AVCHD (Panasonic AG-HMC150)
>>>>>> video
>>>>>> cameras. Mike I think that you have MPEG2 based HD cameras. Are yours
>>>>>> Sony? Nathan, I don't think you tested with an AVCHD camera.
>>>>>> All I get is black, which I think tells me that it sees the video card
>>>>>> but not, the video stream. Mike, did you use 1080i/p or 720p?
>>>>>> If anyone has any suggestions, I'm open.
>>>>>> Jimmy
>>>>>> Jimmy Miklavcic
>>>>>> UNIVERSITY OF UTAH
>>>>>> Fax: 801.585.5366
>>>>>> -----Original Message-----
>>>>>> From: ag-tech-bounces at lists.mcs.anl.gov
>>>>>> [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of
>>>>>> Sent: Tuesday, February 17, 2009 1:52 AM
>>>>>> To: Nathan Gardiner
>>>>>> Cc: ag-tech at mcs.anl.gov; Mike.W.Daley at cs.cardiff.ac.uk
>>>>>> Hi Nathan
>>>>>> Thanks otherwise all looking good.
>>>>>> Not bad on bandwidth usage either.
>>>>>> Mike
>>>> Michael Daley M.Phil MBCS GCFA
>>>> This message was sent using IMP, the Internet Messaging Program.
>>> Gurcharan S. Khanna, Ph.D.
>>> Director of Research Computing
>>> Office of the Vice President for Research
>>> http://rc.rit.edu
>>> Assistant Research Professor, Ph.D. Program
>>> Golisano College of Computing and Information Sciences
>>> http://people.rit.edu/gskpop
>>> Director, Interactive Collaboration Environments Laboratory,
>>> Center for the Advancing the Study of Cyberinfrastructure
>>> http://icelab.rit.edu
>>> Rochester Institute of Technology
>>> 1 Lomb Memorial Drive
>>> Rochester, New York 14623-5603
>>> Phone: 585-475-7504 ~ Cell: 585-451-8370
>>> Email: gurcharan.khanna at rit.edu
