[AG-TECH] BlackMagic HDMI vic beta download
Gurcharan S. Khanna
gurcharan.khanna at rit.edu
Wed Feb 18 07:13:46 CST 2009
Mike,
are you using the Intensity Pro or the Decklink ExtremeHD card? i am
suspecting
there are differences between the two. i've seen 30 fps v 60 fps as the
specs for the
Decklink v. the Intensity come up on its GUI and don't know why this is
the case.
thanks,
-gurcharan
Mike.W.Daley at cs.cardiff.ac.uk wrote:
> Hi All
> Just to clarify.
> I'm using a SONY HDR-SR12E camera.
> I've tested it both in PAL and NTSC formats at 1080i and its all fine.
> In resting phase. (very little activity) I'm getting 1.8M/s transfer
> rate.
> Mike
> Quoting Nathan Gardiner <nathan.gardiner at canterbury.ac.nz>:
>> We have had problems trying to get an AVCHD camcorder to work with
>> BlackMagic card and i think most AVCHD camcorders that I tested didn't
>> seem to have true HDMI realtime output.
>> I don't think that NTSC and PAL should make much difference as the
>> BlackMagic card accepts input from either or.
>> Also, we should have a new JVC camcorder arriving in the next day or
>> so and will be testing that out.
>> Regards,
>> Nathan
>> On 18/02/2009, at 11:56 AM, Jimmy Miklavcic wrote:
>>> I did check it a while back and it was fine. I had to install a
>>> graphics card in order for Media Express to work. Right now I'm
>>> using the on-board VGA for the display. I didn't think I needed a
>>> high-end display card just to run the service manager. Anyway I
>>> think you and I are seeing the same symptoms. I'm using 720 @ 30p.
>>> Jimmy
>>> Jimmy Miklavcic
>>> Multimedia Specialist
>>> Jimmy.Miklavcic at utah.edu
>>> UNIVERSITY OF UTAH
>>> CTR FOR HIGH PERFORM COMPUTING
>>> 155 SOUTH 1452 EAST RM 405
>>> SALT LAKE CITY, UT 84112-0190
>>> Office: 801.585.9335
>>> Fax: 801.585.5366
>>> http://www.anotherlanguage.org
>>> From: adhesionmusic at gmail.com [mailto:adhesionmusic at gmail.com] On
>>> Behalf Of Andrew Ford
>>> Sent: Tuesday, February 17, 2009 2:43 PM
>>> To: Jimmy Miklavcic
>>> Cc: Mike.W.Daley at cs.cardiff.ac.uk; Nathan Gardiner; ag-
>>> tech at mcs.anl.gov
>>> Subject: Re: [AG-TECH] BlackMagic HDMI vic beta download
>>> Hi Jimmy,
>>> Did you try checking the HDMI input directly, via either Blackmagic
>>> Media Express or AMCap? If that works then we probably have the
>>> same problem - I can see the video fine in Media Express but vic
>>> just shows a black screen with any codec or size. Here we have the
>>> Blackmagic Intensity Pro cards with Sony HDR-SR11 cameras, which
>>> are AVCHD. Side note: I don't think the recording format makes
>>> much of a difference, just the specific video format, as in 1080i
>>> at a certain framerate.
>>> Nathan, is vic expecting a certain framerate? The format that
>>> worked with Media Express was 1080i @ 59.97. If it's only been
>>> tested with PAL so far, I would hazard a guess and say that the
>>> NTSC isn't using the right format/framerate in some way.
>>> --Andrew
>>> 2009/2/17 Jimmy Miklavcic <jimmy.miklavcic at utah.edu>
>>> Mike, it's great news that you have been able to get HIT Lab's vic to
>>> work. I haven't been so lucky. I have AVCHD (Panasonic AG-HMC150)
>>> video
>>> cameras. Mike I think that you have MPEG2 based HD cameras. Are yours
>>> Sony? Nathan, I don't think you tested with an AVCHD camera.
>>> All I get is black, which I think tells me that it sees the video card
>>> but not, the video stream. Mike, did you use 1080i/p or 720p?
>>> If anyone has any suggestions, I'm open.
>>> Jimmy
>>> Jimmy Miklavcic
>>> UNIVERSITY OF UTAH
>>> Fax: 801.585.5366
>>> -----Original Message-----
>>> From: ag-tech-bounces at lists.mcs.anl.gov
>>> [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of
>>> Sent: Tuesday, February 17, 2009 1:52 AM
>>> To: Nathan Gardiner
>>> Cc: ag-tech at mcs.anl.gov; Mike.W.Daley at cs.cardiff.ac.uk
>>> Hi Nathan
>>> Thanks otherwise all looking good.
>>> Not bad on bandwidth usage either.
>>> Mike
> Michael Daley M.Phil MBCS GCFA
> This message was sent using IMP, the Internet Messaging Program.
Gurcharan S. Khanna, Ph.D.
Director of Research Computing
Office of the Vice President for Research
http://rc.rit.edu
Assistant Research Professor, Ph.D. Program
Golisano College of Computing and Information Sciences
http://people.rit.edu/gskpop
Director, Interactive Collaboration Environments Laboratory,
Center for the Advancing the Study of Cyberinfrastructure
http://icelab.rit.edu
Rochester Institute of Technology
1 Lomb Memorial Drive
Rochester, New York 14623-5603
Phone: 585-475-7504 ~ Cell: 585-451-8370
Email: gurcharan.khanna at rit.edu
