[AG-TECH] BlackMagic HDMI vic beta download
Douglas Kosovic
douglask at itee.uq.edu.au
Wed Feb 18 03:54:25 CST 2009
For the people using an Intensity Pro (i.e. the one with both analog and HDMI inputs) and are getting a black video, to confirm what might be wrong, download GraphStudio from:
http://blog.monogram.sk/janos/tools/monogram-graphstudio/
With VIC running, run GraphStudio then "File" menu -> "Connect to Remote Graph...", then click the connect button. You'll then see the DirectShow Filter graph vic is using.
Right mouse button click on the left most filter and select properties, then click the capture tab, if you see MEDIASUBTYPE_UYVY and scroll down a bit and see biWidth and biHeight set to 720x486, then the Intensity Pro has most likely defaulted to the Analog input.
Doug
From: ag-tech-bounces at lists.mcs.anl.gov on behalf of Mike.W.Daley at cs.cardiff.ac.uk
Sent: Wed 18/02/2009 7:17 PM
To: Nathan Gardiner
Cc: Mike.W.Daley at cs.cardiff.ac.uk; ag-tech at mcs.anl.gov; ChangHyeok Bae
Subject: Re: [AG-TECH] BlackMagic HDMI vic beta download
Hi All
Just to clarify.
I'm using a SONY HDR-SR12E camera.
I've tested it both in PAL and NTSC formats at 1080i and its all fine.
In resting phase. (very little activity) I'm getting 1.8M/s transfer rate.
Mike
Quoting Nathan Gardiner <nathan.gardiner at canterbury.ac.nz>:
> We have had problems trying to get an AVCHD camcorder to work with
> BlackMagic card and i think most AVCHD camcorders that I tested didn't
> seem to have true HDMI realtime output.
> I don't think that NTSC and PAL should make much difference as the
> BlackMagic card accepts input from either or.
> Also, we should have a new JVC camcorder arriving in the next day or
> so and will be testing that out.
> Regards,
> Nathan
> On 18/02/2009, at 11:56 AM, Jimmy Miklavcic wrote:
>> I did check it a while back and it was fine. I had to install a
>> graphics card in order for Media Express to work. Right now I'm
>> using the on-board VGA for the display. I didn't think I needed a
>> high-end display card just to run the service manager. Anyway I
>> think you and I are seeing the same symptoms. I'm using 720 @ 30p.
>> Jimmy
>> Jimmy Miklavcic
>> Multimedia Specialist
>> Jimmy.Miklavcic at utah.edu
>> UNIVERSITY OF UTAH
>> CTR FOR HIGH PERFORM COMPUTING
>> 155 SOUTH 1452 EAST RM 405
>> SALT LAKE CITY, UT 84112-0190
>> Office: 801.585.9335
>> Fax: 801.585.5366
>> http://www.anotherlanguage.org <http://www.anotherlanguage.org/>
>> From: adhesionmusic at gmail.com [mailto:adhesionmusic at gmail.com] On
>> Behalf Of Andrew Ford
>> Sent: Tuesday, February 17, 2009 2:43 PM
>> To: Jimmy Miklavcic
>> Cc: Mike.W.Daley at cs.cardiff.ac.uk; Nathan Gardiner; ag- tech at mcs.anl.gov
>> Hi Jimmy,
>> Did you try checking the HDMI input directly, via either Blackmagic
>> Media Express or AMCap? If that works then we probably have the
>> same problem - I can see the video fine in Media Express but vic
>> just shows a black screen with any codec or size. Here we have the
>> Blackmagic Intensity Pro cards with Sony HDR-SR11 cameras, which
>> are AVCHD. Side note: I don't think the recording format makes
>> much of a difference, just the specific video format, as in 1080i
>> at a certain framerate.
>> Nathan, is vic expecting a certain framerate? The format that
>> worked with Media Express was 1080i @ 59.97. If it's only been
>> tested with PAL so far, I would hazard a guess and say that the
>> NTSC isn't using the right format/framerate in some way.
>> --Andrew
>> 2009/2/17 Jimmy Miklavcic <jimmy.miklavcic at utah.edu>
>> Mike, it's great news that you have been able to get HIT Lab's vic to
>> work. I haven't been so lucky. I have AVCHD (Panasonic AG-HMC150) video
>> cameras. Mike I think that you have MPEG2 based HD cameras. Are yours
>> Sony? Nathan, I don't think you tested with an AVCHD camera.
>> All I get is black, which I think tells me that it sees the video card
>> but not, the video stream. Mike, did you use 1080i/p or 720p?
>> If anyone has any suggestions, I'm open.
>> Jimmy
>> Jimmy Miklavcic
>> UNIVERSITY OF UTAH
>> Fax: 801.585.5366
>> -----Original Message-----
>> [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of
>> Sent: Tuesday, February 17, 2009 1:52 AM
>> To: Nathan Gardiner
>> Cc: ag-tech at mcs.anl.gov; Mike.W.Daley at cs.cardiff.ac.uk
>> Hi Nathan
>> Thanks otherwise all looking good.
>> Not bad on bandwidth usage either.
>> Mike
Michael Daley M.Phil MBCS GCFA
This message was sent using IMP, the Internet Messaging Program.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090218/b2ce98b2/attachment.htm>
