[AG-TECH] BlackMagic HDMI vic beta download
Mike.W.Daley at cs.cardiff.ac.uk
Wed Feb 18 03:17:11 CST 2009
Hi All
Just to clarify.
I'm using a SONY HDR-SR12E camera.
I've tested it both in PAL and NTSC formats at 1080i and its all fine.
In resting phase. (very little activity) I'm getting 1.8M/s transfer rate.
Mike
Quoting Nathan Gardiner <nathan.gardiner at canterbury.ac.nz>:
> We have had problems trying to get an AVCHD camcorder to work with
> BlackMagic card and i think most AVCHD camcorders that I tested didn't
> seem to have true HDMI realtime output.
> I don't think that NTSC and PAL should make much difference as the
> BlackMagic card accepts input from either or.
> Also, we should have a new JVC camcorder arriving in the next day or
> so and will be testing that out.
> Regards,
> Nathan
> On 18/02/2009, at 11:56 AM, Jimmy Miklavcic wrote:
>> I did check it a while back and it was fine. I had to install a
>> graphics card in order for Media Express to work. Right now I'm
>> using the on-board VGA for the display. I didn't think I needed a
>> high-end display card just to run the service manager. Anyway I
>> think you and I are seeing the same symptoms. I'm using 720 @ 30p.
>> Jimmy
>> Jimmy Miklavcic
>> Multimedia Specialist
>> Jimmy.Miklavcic at utah.edu
>> UNIVERSITY OF UTAH
>> CTR FOR HIGH PERFORM COMPUTING
>> 155 SOUTH 1452 EAST RM 405
>> SALT LAKE CITY, UT 84112-0190
>> Office: 801.585.9335
>> Fax: 801.585.5366
>> http://www.anotherlanguage.org
>> From: adhesionmusic at gmail.com [mailto:adhesionmusic at gmail.com] On
>> Behalf Of Andrew Ford
>> Sent: Tuesday, February 17, 2009 2:43 PM
>> To: Jimmy Miklavcic
>> Cc: Mike.W.Daley at cs.cardiff.ac.uk; Nathan Gardiner; ag- tech at mcs.anl.gov
>> Subject: Re: [AG-TECH] BlackMagic HDMI vic beta download
>> Hi Jimmy,
>> Did you try checking the HDMI input directly, via either Blackmagic
>> Media Express or AMCap? If that works then we probably have the
>> same problem - I can see the video fine in Media Express but vic
>> just shows a black screen with any codec or size. Here we have the
>> Blackmagic Intensity Pro cards with Sony HDR-SR11 cameras, which
>> are AVCHD. Side note: I don't think the recording format makes
>> much of a difference, just the specific video format, as in 1080i
>> at a certain framerate.
>> Nathan, is vic expecting a certain framerate? The format that
>> worked with Media Express was 1080i @ 59.97. If it's only been
>> tested with PAL so far, I would hazard a guess and say that the
>> NTSC isn't using the right format/framerate in some way.
>> --Andrew
>> 2009/2/17 Jimmy Miklavcic <jimmy.miklavcic at utah.edu>
>> Mike, it's great news that you have been able to get HIT Lab's vic to
>> work. I haven't been so lucky. I have AVCHD (Panasonic AG-HMC150) video
>> cameras. Mike I think that you have MPEG2 based HD cameras. Are yours
>> Sony? Nathan, I don't think you tested with an AVCHD camera.
>> All I get is black, which I think tells me that it sees the video card
>> but not, the video stream. Mike, did you use 1080i/p or 720p?
>> If anyone has any suggestions, I'm open.
>> Jimmy
>> Jimmy Miklavcic
>> UNIVERSITY OF UTAH
>> Fax: 801.585.5366
>> -----Original Message-----
>> From: ag-tech-bounces at lists.mcs.anl.gov
>> [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of
>> Sent: Tuesday, February 17, 2009 1:52 AM
>> To: Nathan Gardiner
>> Cc: ag-tech at mcs.anl.gov; Mike.W.Daley at cs.cardiff.ac.uk
>> Hi Nathan
>> Thanks otherwise all looking good.
>> Not bad on bandwidth usage either.
>> Mike
Michael Daley M.Phil MBCS GCFA
This message was sent using IMP, the Internet Messaging Program.
