[AG-TECH] BlackMagic HDMI vic beta download
Nathan Gardiner
nathan.gardiner at canterbury.ac.nz
Wed Feb 18 02:32:04 CST 2009
We have had problems trying to get an AVCHD camcorder to work with
BlackMagic card and i think most AVCHD camcorders that I tested didn't
seem to have true HDMI realtime output.
I don't think that NTSC and PAL should make much difference as the
BlackMagic card accepts input from either or.
Also, we should have a new JVC camcorder arriving in the next day or
so and will be testing that out.
Nathan
On 18/02/2009, at 11:56 AM, Jimmy Miklavcic wrote:
> I did check it a while back and it was fine. I had to install a
> graphics card in order for Media Express to work. Right now I'm
> using the on-board VGA for the display. I didn't think I needed a
> high-end display card just to run the service manager. Anyway I
> think you and I are seeing the same symptoms. I'm using 720 @ 30p.
> Jimmy
> Jimmy Miklavcic
> Multimedia Specialist
> Jimmy.Miklavcic at utah.edu
> UNIVERSITY OF UTAH
> CTR FOR HIGH PERFORM COMPUTING
> 155 SOUTH 1452 EAST RM 405
> SALT LAKE CITY, UT 84112-0190
> Office: 801.585.9335
> Fax: 801.585.5366
> http://www.anotherlanguage.org
> From: adhesionmusic at gmail.com [mailto:adhesionmusic at gmail.com] On
> Behalf Of Andrew Ford
> Sent: Tuesday, February 17, 2009 2:43 PM
> To: Jimmy Miklavcic
> Cc: Mike.W.Daley at cs.cardiff.ac.uk; Nathan Gardiner; ag-
> tech at mcs.anl.gov
> Subject: Re: [AG-TECH] BlackMagic HDMI vic beta download
> Hi Jimmy,
> Did you try checking the HDMI input directly, via either Blackmagic
> Media Express or AMCap? If that works then we probably have the same
> problem - I can see the video fine in Media Express but vic just
> shows a black screen with any codec or size. Here we have the
> Blackmagic Intensity Pro cards with Sony HDR-SR11 cameras, which are
> AVCHD. Side note: I don't think the recording format makes much of a
> difference, just the specific video format, as in 1080i at a certain
> framerate.
> Nathan, is vic expecting a certain framerate? The format that worked
> with Media Express was 1080i @ 59.97. If it's only been tested with
> PAL so far, I would hazard a guess and say that the NTSC isn't using
> the right format/framerate in some way.
> --Andrew
> 2009/2/17 Jimmy Miklavcic <jimmy.miklavcic at utah.edu>
> Mike, it's great news that you have been able to get HIT Lab's vic to
> work. I haven't been so lucky. I have AVCHD (Panasonic AG-HMC150)
> video
> cameras. Mike I think that you have MPEG2 based HD cameras. Are yours
> Sony? Nathan, I don't think you tested with an AVCHD camera.
> All I get is black, which I think tells me that it sees the video card
> but not, the video stream. Mike, did you use 1080i/p or 720p?
> If anyone has any suggestions, I'm open.
> Jimmy
> Jimmy Miklavcic
> UNIVERSITY OF UTAH
> Fax: 801.585.5366
> -----Original Message-----
> From: ag-tech-bounces at lists.mcs.anl.gov
> [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of
> Sent: Tuesday, February 17, 2009 1:52 AM
> To: Nathan Gardiner
> Cc: ag-tech at mcs.anl.gov; Mike.W.Daley at cs.cardiff.ac.uk
> Hi Nathan
> Thanks otherwise all looking good.
> Not bad on bandwidth usage either.
> Mike
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090218/f9be0b97/attachment-0001.htm>
