[AG-TECH] BlackMagic HDMI vic beta download
Jimmy Miklavcic
jimmy.miklavcic at utah.edu
Tue Feb 17 16:56:34 CST 2009
I did check it a while back and it was fine. I had to install a graphics
card in order for Media Express to work. Right now I'm using the
on-board VGA for the display. I didn't think I needed a high-end display
card just to run the service manager. Anyway I think you and I are
seeing the same symptoms. I'm using 720 @ 30p.
Jimmy
Jimmy Miklavcic
Multimedia Specialist
Jimmy.Miklavcic at utah.edu <mailto:Jimmy.Miklavcic at utah.edu>
UNIVERSITY OF UTAH
CTR FOR HIGH PERFORM COMPUTING
155 SOUTH 1452 EAST RM 405
SALT LAKE CITY, UT 84112-0190
Office: 801.585.9335
Fax: 801.585.5366
http://www.anotherlanguage.org <http://www.anotherlanguage.org/>
From: adhesionmusic at gmail.com [mailto:adhesionmusic at gmail.com]
On Behalf Of Andrew Ford
Sent: Tuesday, February 17, 2009 2:43 PM
To: Jimmy Miklavcic
Cc: Mike.W.Daley at cs.cardiff.ac.uk; Nathan Gardiner;
ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] BlackMagic HDMI vic beta download
Hi Jimmy,
Did you try checking the HDMI input directly, via either
Blackmagic Media Express or AMCap? If that works then we probably have
the same problem - I can see the video fine in Media Express but vic
just shows a black screen with any codec or size. Here we have the
Blackmagic Intensity Pro cards with Sony HDR-SR11 cameras, which are
AVCHD. Side note: I don't think the recording format makes much of a
difference, just the specific video format, as in 1080i at a certain
framerate.
Nathan, is vic expecting a certain framerate? The format that
worked with Media Express was 1080i @ 59.97. If it's only been tested
with PAL so far, I would hazard a guess and say that the NTSC isn't
using the right format/framerate in some way.
--Andrew
2009/2/17 Jimmy Miklavcic <jimmy.miklavcic at utah.edu>
Mike, it's great news that you have been able to get
HIT Lab's vic to
work. I haven't been so lucky. I have AVCHD (Panasonic
AG-HMC150) video
cameras. Mike I think that you have MPEG2 based HD
cameras. Are yours
Sony? Nathan, I don't think you tested with an AVCHD
camera.
All I get is black, which I think tells me that it sees
the video card
but not, the video stream. Mike, did you use 1080i/p or
720p?
If anyone has any suggestions, I'm open.
Jimmy
Jimmy Miklavcic
UNIVERSITY OF UTAH
Fax: 801.585.5366
-----Original Message-----
[mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of
Sent: Tuesday, February 17, 2009 1:52 AM
To: Nathan Gardiner
Cc: ag-tech at mcs.anl.gov; Mike.W.Daley at cs.cardiff.ac.uk
Hi Nathan
Thanks otherwise all looking good.
Not bad on bandwidth usage either.
Mike
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090217/bfd7fab6/attachment.htm>
