[AG-TECH] BlackMagic HDMI vic beta download
Andrew Ford
acf0659 at rit.edu
Tue Feb 17 15:43:24 CST 2009
Hi Jimmy,
Did you try checking the HDMI input directly, via either Blackmagic Media
Express or AMCap? If that works then we probably have the same problem - I
can see the video fine in Media Express but vic just shows a black screen
with any codec or size. Here we have the Blackmagic Intensity Pro cards with
Sony HDR-SR11 cameras, which are AVCHD. Side note: I don't think the
recording format makes much of a difference, just the specific video format,
as in 1080i at a certain framerate.
Nathan, is vic expecting a certain framerate? The format that worked with
Media Express was 1080i @ 59.97. If it's only been tested with PAL so far, I
would hazard a guess and say that the NTSC isn't using the right
format/framerate in some way.
--Andrew
2009/2/17 Jimmy Miklavcic <jimmy.miklavcic at utah.edu>
> Mike, it's great news that you have been able to get HIT Lab's vic to
> work. I haven't been so lucky. I have AVCHD (Panasonic AG-HMC150) video
> cameras. Mike I think that you have MPEG2 based HD cameras. Are yours
> Sony? Nathan, I don't think you tested with an AVCHD camera.
> All I get is black, which I think tells me that it sees the video card
> but not, the video stream. Mike, did you use 1080i/p or 720p?
> If anyone has any suggestions, I'm open.
> Jimmy
> Jimmy Miklavcic
> Multimedia Specialist
> Jimmy.Miklavcic at utah.edu
> UNIVERSITY OF UTAH
> CTR FOR HIGH PERFORM COMPUTING
> 155 SOUTH 1452 EAST RM 405
> SALT LAKE CITY, UT 84112-0190
> Office: 801.585.9335
> Fax: 801.585.5366
> http://www.anotherlanguage.org
> -----Original Message-----
> From: ag-tech-bounces at lists.mcs.anl.gov
> [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of
> Mike.W.Daley at cs.cardiff.ac.uk
> Sent: Tuesday, February 17, 2009 1:52 AM
> To: Nathan Gardiner
> Cc: ag-tech at mcs.anl.gov; Mike.W.Daley at cs.cardiff.ac.uk
> Subject: Re: [AG-TECH] BlackMagic HDMI vic beta download
> Hi Nathan
> Thanks otherwise all looking good.
> Not bad on bandwidth usage either.
> Mike
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090217/581fcd0a/attachment.htm>
