[AG-TECH] Fwd: Strange Windows XP RAT issue
Michael Miller
mimiller at ncsa.uiuc.edu
Mon Feb 16 12:09:33 CST 2009
ah, yes, that wouldn't work. In looking at %APPDATA%\AccessGrid3\local_services\AudioService\AudioService.py I find:
if self.streamDescription.encryptionFlag != 0:
options.append( "-crypt" )
options.append( self.streamDescription.encryptionKey )
options.append( '%s/%d' % (self.streamDescription.location.host,
self.streamDescription.location.port))
self.log.info("Starting AudioService")
self.log.info(" executable = %s" % self.executable)
self.log.info(" options = %s" % options)
os.chdir(self.thepath)
self._Start( options )
at the end of the Start function of the AudioService class. You could append another option for ";my mic command;" and that would have the effect I was after in my previous email. While not ideal, it might work. Then you can submit a feature request for an "Addtional Commands" field in the Service config dialog box.
Tom, Eric, any thoughts?
myk
"If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
----- Original Message -----
From: "Enrique Terrazas" <Enrique.Terrazas at ucsf.edu>
To: "Michael Miller" <mimiller at ncsa.uiuc.edu>
Cc: "ag-tech mailing list" <ag-tech at mcs.anl.gov>
Sent: Monday, February 16, 2009 11:44:57 AM GMT -06:00 US/Canada Central
Subject: Re: [AG-TECH] Strange Windows XP RAT issue
Michael,
Thanks for your suggestion ... I'll try toggling the talk on/off
settings to see what effect that has.
Unfortunately, modifying the shortcut won't solve it as RAT is not
initialized until you enter a venue, and is also initialized when you
switch venues.
I think the 960 has two PCI slots (one is taken up by the video
board), so I may have to buy a sound card and bypass the onboard audio
if I have a spare PCI slot.
Enrique Terrazas
On Feb 16, 2009, at 9:32 AM, Michael Miller wrote:
> Enrique,
> Not sure how to fix it, perhaps the talk on/off settings in the
> AudioService config?
> As for the command line, you could add the command at the end of the
> target field of the AG shortcut properties dialog box. Just
> separate it from the AG command with a ; and the shortcut should run
> both commands.
> Let me know how it goes.
> myk
Enrique Terrazas, MD, MS
Director, Laboratory Medicine Residency Program
Director, NCPL Laboratories
Chief, Laboratory Information Systems
HS Associate Clinical Professor
University of California, San Francisco
Clinical Laboratories, Box 0100
4-8931, 415.514.8931(voice)
3-4826, 415.353.4826(fax)
415.443.0913(pager)
CONFIDENTIALITY NOTICE: The information contained in this
transmission, including any enclosed files, is confidential and
intended solely for the addressee. If you are not the intended
recipient, you are hereby notified that any distribution, copying,
disclosure and use of, the contents of this transmission is strictly
prohibited. If you have received this communication in error, please
notify the sender immediately by reply email and permanently delete
this message, enclosures and all copies.
