[AG-TECH] AGServiceManager.py uses lo instead of eth0
James Miller
millerjw at psc.edu
Mon Feb 16 08:31:26 CST 2009
Yep, that was it... thanks!
Christoph Willing wrote:
> On 14/02/2009, at 2:41 AM, James Miller wrote:
>> I am doing a quick upgrade of my capture machine running Ubuntu 8.10
>> and I installed the accessgrid3.2 package from the Univ of Queensland
>> vislab source. I've never had problems with past packages on previous
>> versions of ubuntu.
>> However, when I run AGServiceManager.py in a terminal, it's trying to
>> use the loopback address instead of eth0.
> James,
> What does your /etc/hosts file look like? On a machine named "mymachine"
> using dhcp, that file will begin with something like:
> 127.0.0.1 localhost.localdomain localhost
> 127.0.1.1 mymachine
> Try changing it so that the real IP address of mymachine and fully
> qualified domain name is in there, commenting out or removing the
> exisiting line with the machine's name e.g.
> #127.0.1.1 mymachine
> 123.45.67.89 mymachine.somedomain.xyz mymachine
> chris
> Christoph Willing +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
