[AG-TECH] AGServiceManager.py uses lo instead of eth0
Christoph Willing
c.willing at uq.edu.au
Fri Feb 13 14:47:25 CST 2009
On 14/02/2009, at 2:41 AM, James Miller wrote:
> I am doing a quick upgrade of my capture machine running Ubuntu 8.10
> and I installed the accessgrid3.2 package from the Univ of
> Queensland vislab source. I've never had problems with past
> packages on previous versions of ubuntu.
> However, when I run AGServiceManager.py in a terminal, it's trying
> to use the loopback address instead of eth0.
James,
What does your /etc/hosts file look like? On a machine named
"mymachine" using dhcp, that file will begin with something like:
127.0.0.1 localhost.localdomain localhost
127.0.1.1 mymachine
Try changing it so that the real IP address of mymachine and fully
qualified domain name is in there, commenting out or removing the
exisiting line with the machine's name e.g.
#127.0.1.1 mymachine
123.45.67.89 mymachine.somedomain.xyz mymachine
chris
Christoph Willing +61 7 3365 8316
QCIF Access Grid Manager
University of Queensland
